[U-Boot] [GIT PULL] u-boot-uniphier/master
Hi Tom,
This is the first uniphier PR for v2017.09. Please pull!
The following changes since commit 609bf924117950b88987a5fa477acf1239bfdbc1:
Convert CONFIG_ENV_IS_IN_ONENAND to Kconfig (2017-07-25 21:34:39 -0400)
git://git.denx.de/u-boot-uniphier.git
for you to fetch changes up to a3f54bc74fb20c98aefebd9ca9a250e2f3f9e538:
ARM: uniphier: enable CONFIG_CMD_FS_GENERIC (2017-07-26 22:27:15 +0900)
---------------------------------------------------------------- Masahiro Yamada (4): ARM: uniphier: remove SPL support for ARMv8 SoCs doc: uniphier: rework README.uniphier ARM: uniphier: remove part number info from the boot log ARM: uniphier: enable CONFIG_CMD_FS_GENERIC
arch/arm/dts/uniphier-ld11-global.dts | 9 - arch/arm/dts/uniphier-ld11-ref.dts | 9 - arch/arm/dts/uniphier-ld11.dtsi | 3 - arch/arm/dts/uniphier-ld20-global.dts | 9 - arch/arm/dts/uniphier-ld20-ref.dts | 9 - arch/arm/dts/uniphier-ld20.dtsi | 3 - arch/arm/mach-uniphier/Kconfig | 27 +- arch/arm/mach-uniphier/arm64/Makefile | 9 - arch/arm/mach-uniphier/arm64/arm-cci500.c | 42 --- arch/arm/mach-uniphier/arm64/smp.S | 19 -- arch/arm/mach-uniphier/arm64/smp_kick_cpus.c | 32 -- arch/arm/mach-uniphier/arm64/timer.c | 37 --- arch/arm/mach-uniphier/board_init.c | 9 - arch/arm/mach-uniphier/boards.c | 71 ---- arch/arm/mach-uniphier/boot-device/Makefile | 4 - arch/arm/mach-uniphier/boot-device/spl_board.c | 262 --------------- arch/arm/mach-uniphier/clk/Makefile | 2 - arch/arm/mach-uniphier/clk/clk-dram-ld11.c | 25 -- arch/arm/mach-uniphier/clk/clk-dram-ld20.c | 28 -- arch/arm/mach-uniphier/clk/clk-early-ld11.c | 20 -- arch/arm/mach-uniphier/clk/dpll-ld11.c | 16 - arch/arm/mach-uniphier/clk/dpll-ld20.c | 19 -- arch/arm/mach-uniphier/cpu-info.c | 22 +- arch/arm/mach-uniphier/dram/Makefile | 2 - arch/arm/mach-uniphier/dram/ddruqphy-regs.h | 79 ----- arch/arm/mach-uniphier/dram/umc-ld11.c | 491 ---------------------------- arch/arm/mach-uniphier/dram/umc-ld20.c | 636 ------------------------------------ arch/arm/mach-uniphier/dram/umc64-regs.h | 85 ----- arch/arm/mach-uniphier/init.h | 18 - arch/arm/mach-uniphier/spl_board_init.c | 26 -- configs/uniphier_ld11_defconfig | 41 --- configs/uniphier_ld20_defconfig | 40 --- configs/uniphier_ld4_sld8_defconfig | 1 + configs/uniphier_pro4_defconfig | 1 + configs/uniphier_pxs2_ld6b_defconfig | 1 + configs/uniphier_sld3_defconfig | 1 + configs/uniphier_v8_defconfig | 1 + doc/README.uniphier | 118 +++---- drivers/pinctrl/uniphier/pinctrl-uniphier-ld11.c | 22 +- drivers/pinctrl/uniphier/pinctrl-uniphier-ld20.c | 22 +- drivers/pinctrl/uniphier/pinctrl-uniphier-pxs3.c | 22 +- include/configs/uniphier.h | 36 +- 42 files changed, 117 insertions(+), 2212 deletions(-) delete mode 100644 arch/arm/mach-uniphier/arm64/arm-cci500.c delete mode 100644 arch/arm/mach-uniphier/arm64/smp.S delete mode 100644 arch/arm/mach-uniphier/arm64/smp_kick_cpus.c delete mode 100644 arch/arm/mach-uniphier/arm64/timer.c delete mode 100644 arch/arm/mach-uniphier/boot-device/spl_board.c delete mode 100644 arch/arm/mach-uniphier/clk/clk-dram-ld11.c delete mode 100644 arch/arm/mach-uniphier/clk/clk-dram-ld20.c delete mode 100644 arch/arm/mach-uniphier/clk/clk-early-ld11.c delete mode 100644 arch/arm/mach-uniphier/clk/dpll-ld11.c delete mode 100644 arch/arm/mach-uniphier/clk/dpll-ld20.c delete mode 100644 arch/arm/mach-uniphier/dram/ddruqphy-regs.h delete mode 100644 arch/arm/mach-uniphier/dram/umc-ld11.c delete mode 100644 arch/arm/mach-uniphier/dram/umc-ld20.c delete mode 100644 arch/arm/mach-uniphier/dram/umc64-regs.h delete mode 100644 configs/uniphier_ld11_defconfig delete mode 100644 configs/uniphier_ld20_defconfig
On Wed, Jul 26, 2017 at 10:56:50PM +0900, Masahiro Yamada wrote:
Hi Tom,
Masahiro Yamada
