[U-Boot-Users] [PATCH] 83xx/85xx/86xx: add more MxMR local bus definitions
This patch adds more macro definitions for the UPM Machine Mode Registers They are copied from "include/mpc82xx.h" to simplify the merge of all 8xxx common local bus definitions into include/asm-ppc/fsl_lbc.h. They are required for my forthcoming FSL NAND UPM driver re-write and the support for the TQM8548 module.
This patch is based on the following two patches from Anton Vorontsov:
http://www.mail-archive.com/u-boot-users@lists.sourceforge.net/msg06511.html http://www.mail-archive.com/u-boot-users@lists.sourceforge.net/msg06587.html
I leave coding style violation fixes, code beautification and name corrections to somebody else ;-(.
Signed-off-by: Wolfgang Grandegger wg@grandegger.com --- include/asm-ppc/fsl_lbc.h | 43 ++++++++++++++++++++++++++++++++++++++----- 1 file changed, 38 insertions(+), 5 deletions(-)
Index: u-boot/include/asm-ppc/fsl_lbc.h =================================================================== --- u-boot.orig/include/asm-ppc/fsl_lbc.h +++ u-boot/include/asm-ppc/fsl_lbc.h @@ -161,11 +161,6 @@ #define OR_UPM_EAD 0x00000001 #define OR_UPM_EAD_SHIFT 0
-#define MxMR_OP_NORM 0x00000000 /* Normal Operation */ -#define MxMR_DSx_2_CYCL 0x00400000 /* 2 cycle Disable Period */ -#define MxMR_OP_WARR 0x10000000 /* Write to Array */ -#define MxMR_BSEL 0x80000000 /* Bus Select */ - #define OR_SDRAM_AM 0xFFFF8000 #define OR_SDRAM_AM_SHIFT 15 #define OR_SDRAM_XAM 0x00006000 @@ -198,6 +193,44 @@ #define OR_AM_2GB 0x80000000 #define OR_AM_4GB 0x00000000
+/* MxMR - UPM Machine A/B/C Mode Registers + */ +#define MxMR_MAD_MSK 0x0000003f /* Machine Address Mask */ +#define MxMR_TLFx_MSK 0x000003c0 /* Refresh Loop Field Mask */ +#define MxMR_WLFx_MSK 0x00003c00 /* Write Loop Field Mask */ +#define MxMR_WLFx_1X 0x00000400 /* executed 1 time */ +#define MxMR_WLFx_2X 0x00000800 /* executed 2 times */ +#define MxMR_WLFx_3X 0x00000c00 /* executed 3 times */ +#define MxMR_WLFx_4X 0x00001000 /* executed 4 times */ +#define MxMR_WLFx_5X 0x00001400 /* executed 5 times */ +#define MxMR_WLFx_6X 0x00001800 /* executed 6 times */ +#define MxMR_WLFx_7X 0x00001c00 /* executed 7 times */ +#define MxMR_WLFx_8X 0x00002000 /* executed 8 times */ +#define MxMR_WLFx_9X 0x00002400 /* executed 9 times */ +#define MxMR_WLFx_10X 0x00002800 /* executed 10 times */ +#define MxMR_WLFx_11X 0x00002c00 /* executed 11 times */ +#define MxMR_WLFx_12X 0x00003000 /* executed 12 times */ +#define MxMR_WLFx_13X 0x00003400 /* executed 13 times */ +#define MxMR_WLFx_14X 0x00003800 /* executed 14 times */ +#define MxMR_WLFx_15X 0x00003c00 /* executed 15 times */ +#define MxMR_WLFx_16X 0x00000000 /* executed 16 times */ +#define MxMR_RLFx_MSK 0x0003c000 /* Read Loop Field Mask */ +#define MxMR_GPL_x4DIS 0x00040000 /* GPL_A4 Ouput Line Disable */ +#define MxMR_G0CLx_MSK 0x00380000 /* General Line 0 Control Mask */ +#define MxMR_DSx_1_CYCL 0x00000000 /* 1 cycle Disable Period */ +#define MxMR_DSx_2_CYCL 0x00400000 /* 2 cycle Disable Period */ +#define MxMR_DSx_3_CYCL 0x00800000 /* 3 cycle Disable Period */ +#define MxMR_DSx_4_CYCL 0x00c00000 /* 4 cycle Disable Period */ +#define MxMR_DSx_MSK 0x00c00000 /* Disable Timer Period Mask */ +#define MxMR_AMx_MSK 0x07000000 /* Addess Multiplex Size Mask */ +#define MxMR_OP_NORM 0x00000000 /* Normal Operation */ +#define MxMR_OP_WARR 0x10000000 /* Write to Array */ +#define MxMR_OP_RARR 0x20000000 /* Read from Array */ +#define MxMR_OP_RUNP 0x30000000 /* Run Pattern */ +#define MxMR_OP_MSK 0x30000000 /* Command Opcode Mask */ +#define MxMR_RFEN 0x40000000 /* Refresh Enable */ +#define MxMR_BSEL 0x80000000 /* Bus Select */ + #define LBLAWAR_EN 0x80000000 #define LBLAWAR_4KB 0x0000000B #define LBLAWAR_8KB 0x0000000C
We should move them rather than copy, and then include asm/fsl_lbc.h from asm/mpc8260.h.
-Scott
Moving FSL local bus definitions from asm/mpc8260.h to asm/fsl_lbc.h is a big change as Anton already pointed out in
and not only restricted to the MxMR definitions.
Wolfgang.
We should move them rather than copy, and then include asm/ fsl_lbc.h from asm/mpc8260.h.
We need to be careful here as the localbus on 8260 while similar to 83xx/85xx/86xx isn't nearly as close as the LBC and eLBC on the 83xx/ 85xx/86xx parts are to each other.
- k
Applied, thanks
Andy
Andy Fleming
Kumar Gala
Scott Wood
Wolfgang Grandegger
