[U-Boot] [PATCH 1/2] spi: add support for ARM PL022 SPI controller
This adds support for the ARM PL022 SPI controller for the standard variant (0x00041022) which has a 16bit wide and 8 locations deep TX/RX FIFO.
A few parts were borrowed from the Linux kernel driver.
Cc: Armando Visconti armando.visconti@st.com Cc: Vipin Kumar vipin.kumar@st.com Signed-off-by: Quentin Schulz quentin.schulz@bootlin.com ---
Based on "[PATCH v6] spi: pl022_spi: Add support for ARM PL022 spi controller" from Armando Visconti sent about 5 years ago.
Modifications: - use readw/writew instead of readl/writel functions since the registers are 16bit wide and not 32, - flush the RX FIFO before claiming and releasing the bus (taken from the Linux kernel driver), - migrate to DM, - rework the register access (defines instead of a structure), - fix the set_speed function (taken from Linux kernel driver),
drivers/spi/Kconfig | 8 +- drivers/spi/Makefile | 1 +- drivers/spi/pl022_spi.c | 337 +++++++++++++++++++++++++++++++++++++++++- include/pl022_spi.h | 28 +++- 4 files changed, 374 insertions(+) create mode 100644 drivers/spi/pl022_spi.c create mode 100644 include/pl022_spi.h
diff --git a/drivers/spi/Kconfig b/drivers/spi/Kconfig index dcd719f..7d4d47d 100644 --- a/drivers/spi/Kconfig +++ b/drivers/spi/Kconfig @@ -125,6 +125,14 @@ config PIC32_SPI to access the SPI NOR flash, MMC-over-SPI on platforms based on Microchip PIC32 family devices.
+config PL022_SPI + bool "ARM AMBA PL022 SSP controller driver" + depends on ARM + help + This selects the ARM(R) AMBA(R) PrimeCell PL022 SSP + controller. If you have an embedded system with an AMBA(R) + bus and a PL022 controller, say Y or M here. + config RENESAS_RPC_SPI bool "Renesas RPC SPI driver" depends on RCAR_GEN3 diff --git a/drivers/spi/Makefile b/drivers/spi/Makefile index 728e30c..6679987 100644 --- a/drivers/spi/Makefile +++ b/drivers/spi/Makefile @@ -38,6 +38,7 @@ obj-$(CONFIG_MXS_SPI) += mxs_spi.o obj-$(CONFIG_ATCSPI200_SPI) += atcspi200_spi.o obj-$(CONFIG_OMAP3_SPI) += omap3_spi.o obj-$(CONFIG_PIC32_SPI) += pic32_spi.o +obj-$(CONFIG_PL022_SPI) += pl022_spi.o obj-$(CONFIG_RENESAS_RPC_SPI) += renesas_rpc_spi.o obj-$(CONFIG_ROCKCHIP_SPI) += rk_spi.o obj-$(CONFIG_SANDBOX_SPI) += sandbox_spi.o diff --git a/drivers/spi/pl022_spi.c b/drivers/spi/pl022_spi.c new file mode 100644 index 0000000..dc494a5 --- /dev/null +++ b/drivers/spi/pl022_spi.c @@ -0,0 +1,337 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2012 + * Armando Visconti, ST Microelectronics, armando.visconti@st.com. + * + * (C) Copyright 2018 + * Quentin Schulz, Bootlin, quentin.schulz@bootlin.com + * + * Driver for ARM PL022 SPI Controller. + */ + +#include <asm/io.h> +#include <clk.h> +#include <common.h> +#include <dm.h> +#include <fdtdec.h> +#include <linux/bitops.h> +#include <linux/bug.h> +#include <linux/io.h> +#include <pl022_spi.h> +#include <spi.h> + +#define SSP_CR0(r) (r + 0x000) +#define SSP_CR1(r) (r + 0x004) +#define SSP_DR(r) (r + 0x008) +#define SSP_SR(r) (r + 0x00C) +#define SSP_CPSR(r) (r + 0x010) +#define SSP_IMSC(r) (r + 0x014) +#define SSP_RIS(r) (r + 0x018) +#define SSP_MIS(r) (r + 0x01C) +#define SSP_ICR(r) (r + 0x020) +#define SSP_DMACR(r) (r + 0x024) +#define SSP_CSR(r) (r + 0x030) /* vendor extension */ +#define SSP_ITCR(r) (r + 0x080) +#define SSP_ITIP(r) (r + 0x084) +#define SSP_ITOP(r) (r + 0x088) +#define SSP_TDR(r) (r + 0x08C) + +#define SSP_PID0(r) (r + 0xFE0) +#define SSP_PID1(r) (r + 0xFE4) +#define SSP_PID2(r) (r + 0xFE8) +#define SSP_PID3(r) (r + 0xFEC) + +#define SSP_CID0(r) (r + 0xFF0) +#define SSP_CID1(r) (r + 0xFF4) +#define SSP_CID2(r) (r + 0xFF8) +#define SSP_CID3(r) (r + 0xFFC) + +/* SSP Control Register 0 - SSP_CR0 */ +#define SSP_CR0_SPO (0x1 << 6) +#define SSP_CR0_SPH (0x1 << 7) +#define SSP_CR0_BIT_MODE(x) ((x) - 1) +#define SSP_SCR_MIN (0x00) +#define SSP_SCR_MAX (0xFF) +#define SSP_SCR_SHFT 8 +#define DFLT_CLKRATE 2 + +/* SSP Control Register 1 - SSP_CR1 */ +#define SSP_CR1_MASK_SSE (0x1 << 1) + +#define SSP_CPSR_MIN (0x02) +#define SSP_CPSR_MAX (0xFE) +#define DFLT_PRESCALE (0x40) + +/* SSP Status Register - SSP_SR */ +#define SSP_SR_MASK_TFE (0x1 << 0) /* Transmit FIFO empty */ +#define SSP_SR_MASK_TNF (0x1 << 1) /* Transmit FIFO not full */ +#define SSP_SR_MASK_RNE (0x1 << 2) /* Receive FIFO not empty */ +#define SSP_SR_MASK_RFF (0x1 << 3) /* Receive FIFO full */ +#define SSP_SR_MASK_BSY (0x1 << 4) /* Busy Flag */ + +struct pl022_spi_slave { + void *base; +#if !CONFIG_IS_ENABLED(OF_PLATDATA) + struct clk clk; +#else + unsigned int freq; +#endif +}; + +/* + * ARM PL022 exists in different 'flavors'. + * This drivers currently support the standard variant (0x00041022), that has a + * 16bit wide and 8 locations deep TX/RX FIFO. + */ +static int pl022_is_supported(struct pl022_spi_slave *ps) +{ + /* PL022 version is 0x00041022 */ + if ((readw(SSP_PID0(ps->base)) == 0x22) && + (readw(SSP_PID1(ps->base)) == 0x10) && + ((readw(SSP_PID2(ps->base)) & 0xf) == 0x04) && + (readw(SSP_PID3(ps->base)) == 0x00)) + return 1; + + return 0; +} + +static int pl022_spi_ofdata_to_platdata(struct udevice *bus) +{ +#if !CONFIG_IS_ENABLED(OF_PLATDATA) + struct pl022_spi_pdata *plat = bus->platdata; + const void *fdt = gd->fdt_blob; + int node = dev_of_offset(bus); + + plat->addr = fdtdec_get_addr_size(fdt, node, "reg", &plat->size); + + return clk_get_by_index(bus, 0, &plat->clk); +#else + return 0; +#endif +} + +static int pl022_spi_probe(struct udevice *bus) +{ + struct pl022_spi_pdata *plat = dev_get_platdata(bus); + struct pl022_spi_slave *ps = dev_get_priv(bus); + + ps->base = ioremap(plat->addr, plat->size); +#if !CONFIG_IS_ENABLED(OF_PLATDATA) + ps->clk = plat->clk; +#else + ps->freq = plat->freq; +#endif + + /* Check the PL022 version */ + if (!pl022_is_supported(ps)) + return -ENOTSUPP; + + /* 12 bits per word, high polarity and default clock rate */ + writew(SSP_CR0_BIT_MODE(8) | SSP_CR0_SPH | + (DFLT_CLKRATE << SSP_SCR_SHFT), SSP_CR0(ps->base)); + writew(DFLT_PRESCALE, SSP_CPSR(ps->base)); + + return 0; +} + +static void flush(struct pl022_spi_slave *ps) +{ + do { + while (readw(SSP_SR(ps->base)) & SSP_SR_MASK_RNE) + readw(SSP_DR(ps->base)); + } while (readw(SSP_SR(ps->base)) & SSP_SR_MASK_BSY); +} + +static int pl022_spi_claim_bus(struct udevice *dev) +{ + struct udevice *bus = dev->parent; + struct pl022_spi_slave *ps = dev_get_priv(bus); + u16 reg; + + flush(ps); + + /* Enable the SPI hardware */ + reg = readw(SSP_CR1(ps->base)); + reg |= SSP_CR1_MASK_SSE; + writew(reg, SSP_CR1(ps->base)); + + return 0; +} + +static int pl022_spi_release_bus(struct udevice *dev) +{ + struct udevice *bus = dev->parent; + struct pl022_spi_slave *ps = dev_get_priv(bus); + u16 reg; + + /* Disable the SPI hardware */ + reg = readw(SSP_CR1(ps->base)); + reg &= ~SSP_CR1_MASK_SSE; + writew(reg, SSP_CR1(ps->base)); + + flush(ps); + + return 0; +} + +static int pl022_spi_xfer(struct udevice *dev, unsigned int bitlen, + const void *dout, void *din, unsigned long flags) +{ + struct udevice *bus = dev->parent; + struct pl022_spi_slave *ps = dev_get_priv(bus); + u32 len_tx = 0, len_rx = 0, len; + u32 ret = 0; + const u8 *txp = dout; + u8 *rxp = din, value; + + if (bitlen == 0) + /* Finish any previously submitted transfers */ + return 0; + + /* + * TODO: The controller can do non-multiple-of-8 bit + * transfers, but this driver currently doesn't support it. + * + * It's also not clear how such transfers are supposed to be + * represented as a stream of bytes...this is a limitation of + * the current SPI interface. + */ + if (bitlen % 8) { + /* Errors always terminate an ongoing transfer */ + flags |= SPI_XFER_END; + return -1; + } + + len = bitlen / 8; + + while (len_tx < len) { + if (readw(SSP_SR(ps->base)) & SSP_SR_MASK_TNF) { + value = (txp) ? *txp++ : 0; + writew(value, SSP_DR(ps->base)); + len_tx++; + } + + if (readw(SSP_SR(ps->base)) & SSP_SR_MASK_RNE) { + value = readw(SSP_DR(ps->base)); + if (rxp) + *rxp++ = value; + len_rx++; + } + } + + while (len_rx < len_tx) { + if (readw(SSP_SR(ps->base)) & SSP_SR_MASK_RNE) { + value = readw(SSP_DR(ps->base)); + if (rxp) + *rxp++ = value; + len_rx++; + } + } + + return ret; +} + +static inline u32 spi_rate(u32 rate, u16 cpsdvsr, u16 scr) +{ + return rate / (cpsdvsr * (1 + scr)); +} + +static int pl022_spi_set_speed(struct udevice *bus, uint speed) +{ + struct pl022_spi_slave *ps = dev_get_priv(bus); + u16 scr = SSP_SCR_MIN, tmp, cr0 = 0, cpsr = SSP_CPSR_MIN, best_scr, + best_cpsr; + u32 min, max, best_freq = 0; +#if !CONFIG_IS_ENABLED(OF_PLATDATA) + u32 rate = clk_get_rate(&ps->clk); +#else + u32 rate = ps->freq; +#endif + bool found = false; + + max = spi_rate(rate, SSP_CPSR_MIN, SSP_SCR_MIN); + min = spi_rate(rate, SSP_CPSR_MAX, SSP_SCR_MAX); + + if (speed > max || speed < min) { + pr_err("Tried to set speed to %dHz but min=%d and max=%d\n", + speed, min, max); + return -EINVAL; + } + + while (cpsr <= SSP_CPSR_MAX && !found) { + while (scr <= SSP_SCR_MAX) { + tmp = spi_rate(rate, cpsr, scr); + + if (tmp > speed) { + scr++; + continue; + } + + if (tmp > best_freq) { + best_freq = tmp; + best_cpsr = cpsr; + best_scr = scr; + + if (tmp == speed) + found = true; + } + + break; + } + cpsr += 2; + scr = SSP_SCR_MIN; + } + + writew(best_cpsr, SSP_CPSR(ps->base)); + cr0 = readw(SSP_CR0(ps->base)); + writew(cr0 | (best_scr << SSP_SCR_SHFT), SSP_CR0(ps->base)); + + return 0; +} + +static int pl022_spi_set_mode(struct udevice *bus, uint mode) +{ + struct pl022_spi_slave *ps = dev_get_priv(bus); + u16 reg; + + reg = readw(SSP_CR0(ps->base)); + reg &= ~(SSP_CR0_SPH | SSP_CR0_SPO); + if (mode & SPI_CPHA) + reg |= SSP_CR0_SPH; + if (mode & SPI_CPOL) + reg |= SSP_CR0_SPO; + writew(reg, SSP_CR0(ps->base)); + + return 0; +} + +static int pl022_cs_info(struct udevice *bus, uint cs, + struct spi_cs_info *info) +{ + return 0; +} + +static const struct dm_spi_ops pl022_spi_ops = { + .claim_bus = pl022_spi_claim_bus, + .release_bus = pl022_spi_release_bus, + .xfer = pl022_spi_xfer, + .set_speed = pl022_spi_set_speed, + .set_mode = pl022_spi_set_mode, + .cs_info = pl022_cs_info, +}; + +static const struct udevice_id pl022_spi_ids[] = { + { .compatible = "arm,pl022-spi" }, + { } +}; + +U_BOOT_DRIVER(pl022_spi) = { + .name = "pl022_spi", + .id = UCLASS_SPI, + .of_match = pl022_spi_ids, + .ops = &pl022_spi_ops, + .ofdata_to_platdata = pl022_spi_ofdata_to_platdata, + .platdata_auto_alloc_size = sizeof(struct pl022_spi_pdata), + .priv_auto_alloc_size = sizeof(struct pl022_spi_slave), + .probe = pl022_spi_probe, +}; diff --git a/include/pl022_spi.h b/include/pl022_spi.h new file mode 100644 index 0000000..e707b23 --- /dev/null +++ b/include/pl022_spi.h @@ -0,0 +1,28 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2018 + * Quentin Schulz, Bootlin, quentin.schulz@bootlin.com + * + * Structure for use with U_BOOT_DEVICE for pl022 SPI devices or to use + * in ofdata_to_platdata. + */ + +#ifndef __PL022_SPI_H__ +#define __PL022_SPI_H__ + +#if !CONFIG_IS_ENABLED(OF_PLATDATA) +#include <clk.h> +#endif +#include <fdtdec.h> + +struct pl022_spi_pdata { + fdt_addr_t addr; + fdt_size_t size; +#if !CONFIG_IS_ENABLED(OF_PLATDATA) + struct clk clk; +#else + unsigned int freq; +#endif +}; + +#endif
base-commit: bb694d4e898b1368ba96e01481dc0a79c491e77c
There are three separate clocks for each SSP (SPI) controller in the SoC. These SPI controllers are ARM PL022 controllers.
Let's enable the clocks when support for PL022 SPI controller is enabled.
Signed-off-by: Quentin Schulz quentin.schulz@bootlin.com --- arch/arm/cpu/arm926ejs/spear/cpu.c | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/arch/arm/cpu/arm926ejs/spear/cpu.c b/arch/arm/cpu/arm926ejs/spear/cpu.c index 0970aca..8046ad0 100644 --- a/arch/arm/cpu/arm926ejs/spear/cpu.c +++ b/arch/arm/cpu/arm926ejs/spear/cpu.c @@ -49,6 +49,9 @@ int arch_cpu_init(void) #if defined(CONFIG_USB_EHCI_SPEAR) periph1_clken |= PERIPH_USBH1 | PERIPH_USBH2; #endif +#if defined(CONFIG_PL022_SPI) + periph1_clken |= PERIPH_SSP1 | PERIPH_SSP2 | PERIPH_SSP3; +#endif
writel(periph1_clken, &misc_p->periph1_clken);
Quentin,
Thx for resurrecting it! I took a quick look and it seems good to me.
Armando
Modifications:
- migrate to DM,
+config PL022_SPI
- bool "ARM AMBA PL022 SSP controller driver"
- depends on ARM
- help
- config RENESAS_RPC_SPI bool "Renesas RPC SPI driver" depends on RCAR_GEN3
- (C) Copyright 2012
- Armando Visconti, ST Microelectronics, armando.visconti@st.com.
- (C) Copyright 2018
- Quentin Schulz, Bootlin, quentin.schulz@bootlin.com
- Driver for ARM PL022 SPI Controller.
- void *base;
- struct clk clk;
+#else
- unsigned int freq;
+#endif +};
- ARM PL022 exists in different 'flavors'.
- This drivers currently support the standard variant (0x00041022), that has a
- 16bit wide and 8 locations deep TX/RX FIFO.
- /* PL022 version is 0x00041022 */
- if ((readw(SSP_PID0(ps->base)) == 0x22) &&
return 1;
- struct pl022_spi_pdata *plat = bus->platdata;
- const void *fdt = gd->fdt_blob;
- int node = dev_of_offset(bus);
- plat->addr = fdtdec_get_addr_size(fdt, node, "reg", &plat->size);
- return clk_get_by_index(bus, 0, &plat->clk);
+#else
+#endif +}
- struct pl022_spi_pdata *plat = dev_get_platdata(bus);
- struct pl022_spi_slave *ps = dev_get_priv(bus);
- ps->base = ioremap(plat->addr, plat->size);
- ps->clk = plat->clk;
+#else
- ps->freq = plat->freq;
- /* Check the PL022 version */
- if (!pl022_is_supported(ps))
return -ENOTSUPP;
- /* 12 bits per word, high polarity and default clock rate */
- writew(SSP_CR0_BIT_MODE(8) | SSP_CR0_SPH |
- writew(DFLT_PRESCALE, SSP_CPSR(ps->base));
- do {
- } while (readw(SSP_SR(ps->base)) & SSP_SR_MASK_BSY);
- struct udevice *bus = dev->parent;
- u16 reg;
- flush(ps);
- /* Enable the SPI hardware */
- reg = readw(SSP_CR1(ps->base));
- reg |= SSP_CR1_MASK_SSE;
- writew(reg, SSP_CR1(ps->base));
- u16 reg;
- /* Disable the SPI hardware */
- reg &= ~SSP_CR1_MASK_SSE;
- flush(ps);
- u32 len_tx = 0, len_rx = 0, len;
- u32 ret = 0;
- const u8 *txp = dout;
- u8 *rxp = din, value;
- if (bitlen == 0)
- if (bitlen % 8) {
return -1;
- len = bitlen / 8;
- while (len_tx < len) {
len_tx++;
if (rxp)
*rxp++ = value;
len_rx++;
- while (len_rx < len_tx) {
if (rxp)
*rxp++ = value;
len_rx++;
- return ret;
- return rate / (cpsdvsr * (1 + scr));
- u16 scr = SSP_SCR_MIN, tmp, cr0 = 0, cpsr = SSP_CPSR_MIN, best_scr,
best_cpsr;
- u32 min, max, best_freq = 0;
- u32 rate = clk_get_rate(&ps->clk);
+#else
- u32 rate = ps->freq;
- bool found = false;
- max = spi_rate(rate, SSP_CPSR_MIN, SSP_SCR_MIN);
- min = spi_rate(rate, SSP_CPSR_MAX, SSP_SCR_MAX);
- if (speed > max || speed < min) {
speed, min, max);
return -EINVAL;
- while (cpsr <= SSP_CPSR_MAX && !found) {
if (tmp > speed) {
scr++;
continue;
best_freq = tmp;
best_cpsr = cpsr;
best_scr = scr;
if (tmp == speed)
found = true;
break;
cpsr += 2;
scr = SSP_SCR_MIN;
- writew(best_cpsr, SSP_CPSR(ps->base));
- cr0 = readw(SSP_CR0(ps->base));
- writew(cr0 | (best_scr << SSP_SCR_SHFT), SSP_CR0(ps->base));
- u16 reg;
- reg = readw(SSP_CR0(ps->base));
- reg &= ~(SSP_CR0_SPH | SSP_CR0_SPO);
- if (mode & SPI_CPHA)
reg |= SSP_CR0_SPH;
- if (mode & SPI_CPOL)
reg |= SSP_CR0_SPO;
- writew(reg, SSP_CR0(ps->base));
- .claim_bus = pl022_spi_claim_bus,
- .release_bus = pl022_spi_release_bus,
- .xfer = pl022_spi_xfer,
- .set_speed = pl022_spi_set_speed,
- .set_mode = pl022_spi_set_mode,
- .cs_info = pl022_cs_info,
- { .compatible = "arm,pl022-spi" },
- .name = "pl022_spi",
- .id = UCLASS_SPI,
- .of_match = pl022_spi_ids,
- .ops = &pl022_spi_ops,
- .ofdata_to_platdata = pl022_spi_ofdata_to_platdata,
- .platdata_auto_alloc_size = sizeof(struct pl022_spi_pdata),
- .priv_auto_alloc_size = sizeof(struct pl022_spi_slave),
- .probe = pl022_spi_probe,
- Structure for use with U_BOOT_DEVICE for pl022 SPI devices or to use
- in ofdata_to_platdata.
- fdt_addr_t addr;
- fdt_size_t size;
- struct clk clk;
+#else
+#endif +};
On Tue, Aug 7, 2018 at 2:47 PM, Quentin Schulz quentin.schulz@bootlin.com wrote:
Modifications:
- migrate to DM,
+config PL022_SPI
depends on ARM
help
This make confusing to add exctra calculation on reg base, better to use struct or use base + MACRO diretctly
void *base;
Are you planning to support this driver for platdata as well?
struct clk clk;
+#else
unsigned int freq;
+#endif +};
return 1;
+#else
Move DT code at once instead of using seprately in each function, see [1]
+#else
return -ENOTSUPP;
do {
u16 reg;
flush(ps);
u16 reg;
flush(ps);
u32 ret = 0;
if (bitlen == 0)
if (bitlen % 8) {
return -1;
len = bitlen / 8;
len_tx++;
if (rxp)
*rxp++ = value;
len_rx++;
if (rxp)
*rxp++ = value;
len_rx++;
return ret;
best_cpsr;
+#else
bool found = false;
speed, min, max);
return -EINVAL;
if (tmp > speed) {
scr++;
continue;
best_freq = tmp;
best_cpsr = cpsr;
best_scr = scr;
if (tmp == speed)
found = true;
break;
cpsr += 2;
scr = SSP_SCR_MIN;
u16 reg;
reg |= SSP_CR0_SPH;
reg |= SSP_CR0_SPO;
This can't use it on PLATDATA.
[1] https://patchwork.ozlabs.org/patch/954373/
.id = UCLASS_SPI,
fdt_addr_t addr;
fdt_size_t size;
struct clk clk;
+#else
unsigned int freq;
+#endif +};
If you use this for PLATDATA, add it in include/dm/platform_data/
Armando Visconti
Jagan Teki
Quentin Schulz
