[U-Boot] [PULL] u-boot-rockchip patch queue 2018-10-03
Tom,
Here’s the u-boot-rockchip patch queue for v2018.11 with the respective Travis-CI run at https://travis-ci.org/ptomsich/u-boot-rockchip/builds/436047523
Thanks, Philipp.
The following changes since commit 2ba8bf207481cfb319f54a1bef67f6f068831a58:
Prepare v2018.11-rc1 (2018-10-01 20:32:03 -0400)
git://git.denx.de/u-boot-rockchip.git tags/rockchip-for-v2018.11
for you to fetch changes up to e4d5fa3db0b9ad6551752f90b153d64706bbddef:
rockchip: rk3188: explicitly set vcc_sd0 pin to gpio on rk3188-radxarock (2018-10-02 09:35:39 +0200)
---------------------------------------------------------------- Rockchip changes for 2018.11
---------------------------------------------------------------- Heiko Stuebner (4): mmc: dw_mmc: check fifo status with a timeout in fifo mode rockchip: dwmmc: add rk2928-dw-mshc compatible rockchip: rk3188: add u-boot-specific mmc properties rockchip: rk3188: explicitly set vcc_sd0 pin to gpio on rk3188-radxarock
arch/arm/dts/rk3188-radxarock-u-boot.dtsi | 15 +++++++++++++++ arch/arm/dts/rk3188-radxarock.dts | 8 ++++++++ drivers/mmc/dw_mmc.c | 32 ++++++++++++++++++++++++++++++-- drivers/mmc/rockchip_dw_mmc.c | 1 + include/dwmmc.h | 2 ++ 5 files changed, 56 insertions(+), 2 deletions(-)
On Wed, Oct 03, 2018 at 06:08:54PM +0200, Philipp Tomsich wrote:
Tom,
Thanks for doing a tag. Next time please put a little more detail into the commit message please.
Thanks, Philipp.
Philipp Tomsich
