[U-Boot] Please pull u-boot-x86
Hi Tom,
The following changes since commit 19ce924ff914f315dc2fdf79f357825c513aed6e:
Prepare v2016.07 (2016-07-11 15:01:01 -0400)
git://git.denx.de/u-boot-x86.git master
for you to fetch changes up to 9532fe3b40ddf66ef976dee3d5cf1d8b3396bf4d:
x86: link: Correct a failure in DRAM init (2016-07-12 13:59:45 +0800)
---------------------------------------------------------------- Bin Meng (9): pci: Remove CONFIG_ALWAYS_LOAD_OPROM pci: Make load_oprom and run_oprom independent pci: Add board_ prefix to should_load_oprom() and make it weak x86: baytrail: Introduce a Kconfig option for the internal UART x86: fsp: Wrap setup_internal_uart() call with CONFIG_INTERNAL_UART x86: baytrail: Introduce ACPI global NVS x86: quark: Introduce ACPI global NVS x86: acpi: Pack global NVS into ACPI table x86: baytrail: acpi: Hide internal UART per GNVS setting
George McCollister (1): x86: Add Advantech SOM-DB5800/SOM-6867 support
Simon Glass (1): x86: link: Correct a failure in DRAM init
Stefan Roese (1): x86: conga-qeval20-qa3: Add support for internal UART
arch/x86/Kconfig | 4 ++ arch/x86/cpu/baytrail/Kconfig | 11 ++++ arch/x86/cpu/baytrail/acpi.c | 26 ++++++++ arch/x86/cpu/ivybridge/sdram.c | 5 ++ arch/x86/cpu/quark/acpi.c | 7 ++ arch/x86/dts/Makefile | 3 +- arch/x86/dts/baytrail_som-db5800-som-6867.dts | 289 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ arch/x86/include/asm/acpi/global_nvs.h | 19 ++++++ arch/x86/include/asm/acpi_table.h | 4 ++ arch/x86/include/asm/arch-baytrail/acpi/global_nvs.asl | 15 +++++ arch/x86/include/asm/arch-baytrail/acpi/lpc.asl | 19 +++--- arch/x86/include/asm/arch-baytrail/acpi/platform.asl | 3 + arch/x86/include/asm/arch-baytrail/global_nvs.h | 21 ++++++ arch/x86/include/asm/arch-quark/acpi/global_nvs.asl | 14 ++++ arch/x86/include/asm/arch-quark/acpi/platform.asl | 3 + arch/x86/include/asm/arch-quark/global_nvs.h | 20 ++++++ arch/x86/lib/acpi_table.c | 22 +++++++ arch/x86/lib/fsp/fsp_support.c | 2 +- board/advantech/Kconfig | 28 ++++++++ board/advantech/som-db5800-som-6867/.gitignore | 3 + board/advantech/som-db5800-som-6867/Kconfig | 28 ++++++++ board/advantech/som-db5800-som-6867/MAINTAINERS | 7 ++ board/advantech/som-db5800-som-6867/Makefile | 8 +++ board/advantech/som-db5800-som-6867/acpi/mainboard.asl | 11 ++++ board/advantech/som-db5800-som-6867/dsdt.asl | 14 ++++ board/advantech/som-db5800-som-6867/som-db5800-som-6867.c | 24 +++++++ board/advantech/som-db5800-som-6867/start.S | 9 +++ board/congatec/conga-qeval20-qa3-e3845/conga-qeval20-qa3.c | 2 + configs/bayleybay_defconfig | 1 + configs/conga-qeval20-qa3-e3845-internal-uart_defconfig | 63 ++++++++++++++++++ configs/minnowmax_defconfig | 1 + configs/som-db5800-som-6867_defconfig | 61 ++++++++++++++++++ doc/README.x86 | 2 - drivers/pci/pci_rom.c | 11 +--- include/configs/som-db5800-som-6867.h | 36 +++++++++++ 35 files changed, 773 insertions(+), 23 deletions(-) create mode 100644 arch/x86/dts/baytrail_som-db5800-som-6867.dts create mode 100644 arch/x86/include/asm/acpi/global_nvs.h create mode 100644 arch/x86/include/asm/arch-baytrail/acpi/global_nvs.asl create mode 100644 arch/x86/include/asm/arch-baytrail/global_nvs.h create mode 100644 arch/x86/include/asm/arch-quark/acpi/global_nvs.asl create mode 100644 arch/x86/include/asm/arch-quark/global_nvs.h create mode 100644 board/advantech/Kconfig create mode 100644 board/advantech/som-db5800-som-6867/.gitignore create mode 100644 board/advantech/som-db5800-som-6867/Kconfig create mode 100644 board/advantech/som-db5800-som-6867/MAINTAINERS create mode 100644 board/advantech/som-db5800-som-6867/Makefile create mode 100644 board/advantech/som-db5800-som-6867/acpi/mainboard.asl create mode 100644 board/advantech/som-db5800-som-6867/dsdt.asl create mode 100644 board/advantech/som-db5800-som-6867/som-db5800-som-6867.c create mode 100644 board/advantech/som-db5800-som-6867/start.S create mode 100644 configs/conga-qeval20-qa3-e3845-internal-uart_defconfig create mode 100644 configs/som-db5800-som-6867_defconfig create mode 100644 include/configs/som-db5800-som-6867.h
Regards, Bin
On Tue, Jul 12, 2016 at 02:09:06PM +0800, Bin Meng wrote:
Hi Tom,
Bin Meng
