[U-Boot] [PATCH v2 0/4] dm: Update on serial driver progress
Only two serial drivers remain to be converted. This series drops one of those, since the boards appear to be unmaintained.
Thank you to Marcel Ziswiler for converting the pxa serial driver.
With this, only blackfin remains.
The blackfin driver probably needs to be converted as there is recent activity with these boards. I am copying the maintainer so that this work can be completed.
Changes in v2: - Drop the pxa patches since it is now converted
Simon Glass (4): serial: Update docs to indicate mcfuart supports DM_SERIAL arm: Remove smdk2410 board arm: Remove VCMA9 board serial: Drop the s3c24x0 serial driver
arch/arm/Kconfig | 10 - board/mpl/common/common_util.c | 23 -- board/mpl/vcma9/Kconfig | 15 - board/mpl/vcma9/MAINTAINERS | 6 - board/mpl/vcma9/Makefile | 11 - board/mpl/vcma9/cmd_vcma9.c | 119 -------- board/mpl/vcma9/lowlevel_init.S | 500 --------------------------------- board/mpl/vcma9/vcma9.c | 209 -------------- board/mpl/vcma9/vcma9.h | 28 -- board/samsung/smdk2410/Kconfig | 15 - board/samsung/smdk2410/MAINTAINERS | 6 - board/samsung/smdk2410/Makefile | 9 - board/samsung/smdk2410/lowlevel_init.S | 146 ---------- board/samsung/smdk2410/smdk2410.c | 139 --------- configs/VCMA9_defconfig | 17 -- configs/smdk2410_defconfig | 18 -- doc/driver-model/serial-howto.txt | 2 - drivers/serial/Makefile | 1 - drivers/serial/serial_s3c24x0.c | 208 -------------- include/configs/VCMA9.h | 205 -------------- include/configs/smdk2410.h | 180 ------------ scripts/config_whitelist.txt | 4 - 22 files changed, 1871 deletions(-) delete mode 100644 board/mpl/vcma9/Kconfig delete mode 100644 board/mpl/vcma9/MAINTAINERS delete mode 100644 board/mpl/vcma9/Makefile delete mode 100644 board/mpl/vcma9/cmd_vcma9.c delete mode 100644 board/mpl/vcma9/lowlevel_init.S delete mode 100644 board/mpl/vcma9/vcma9.c delete mode 100644 board/mpl/vcma9/vcma9.h delete mode 100644 board/samsung/smdk2410/Kconfig delete mode 100644 board/samsung/smdk2410/MAINTAINERS delete mode 100644 board/samsung/smdk2410/Makefile delete mode 100644 board/samsung/smdk2410/lowlevel_init.S delete mode 100644 board/samsung/smdk2410/smdk2410.c delete mode 100644 configs/VCMA9_defconfig delete mode 100644 configs/smdk2410_defconfig delete mode 100644 drivers/serial/serial_s3c24x0.c delete mode 100644 include/configs/VCMA9.h delete mode 100644 include/configs/smdk2410.h
This driver was converted so we should remove it from the list.
Changes in v2: None
doc/driver-model/serial-howto.txt | 1 - 1 file changed, 1 deletion(-)
diff --git a/doc/driver-model/serial-howto.txt b/doc/driver-model/serial-howto.txt index cddfb9f..3720274 100644 --- a/doc/driver-model/serial-howto.txt +++ b/doc/driver-model/serial-howto.txt @@ -4,7 +4,6 @@ How to port a serial driver to driver model Almost all of the serial drivers have been converted as at January 2016. These ones remain:
- mcfuart.c serial_bfin.c serial_pxa.c serial_s3c24x0.c
This board has not been converted to DM_SERIAL by the deadline. Remove it.
Changes in v2: None
arch/arm/Kconfig | 5 - board/samsung/smdk2410/Kconfig | 15 --- board/samsung/smdk2410/MAINTAINERS | 6 -- board/samsung/smdk2410/Makefile | 9 -- board/samsung/smdk2410/lowlevel_init.S | 146 -------------------------- board/samsung/smdk2410/smdk2410.c | 139 ------------------------- configs/smdk2410_defconfig | 18 ---- include/configs/smdk2410.h | 180 --------------------------------- scripts/config_whitelist.txt | 2 - 9 files changed, 520 deletions(-) delete mode 100644 board/samsung/smdk2410/Kconfig delete mode 100644 board/samsung/smdk2410/MAINTAINERS delete mode 100644 board/samsung/smdk2410/Makefile delete mode 100644 board/samsung/smdk2410/lowlevel_init.S delete mode 100644 board/samsung/smdk2410/smdk2410.c delete mode 100644 configs/smdk2410_defconfig delete mode 100644 include/configs/smdk2410.h
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index acd689b..398dbe0 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -146,10 +146,6 @@ config TARGET_VCMA9 bool "Support VCMA9" select CPU_ARM920T
-config TARGET_SMDK2410 - bool "Support smdk2410" - select CPU_ARM920T - config TARGET_ASPENITE bool "Support aspenite" select CPU_ARM926EJS @@ -980,7 +976,6 @@ source "board/olimex/mx23_olinuxino/Kconfig" source "board/phytec/pcm051/Kconfig" source "board/phytec/pcm052/Kconfig" source "board/ppcag/bg0900/Kconfig" -source "board/samsung/smdk2410/Kconfig" source "board/sandisk/sansa_fuze_plus/Kconfig" source "board/schulercontrol/sc_sps_1/Kconfig" source "board/siemens/draco/Kconfig" diff --git a/board/samsung/smdk2410/Kconfig b/board/samsung/smdk2410/Kconfig deleted file mode 100644 index e987b64..0000000 --- a/board/samsung/smdk2410/Kconfig +++ /dev/null @@ -1,15 +0,0 @@ -if TARGET_SMDK2410 - -config SYS_BOARD - default "smdk2410" - -config SYS_VENDOR - default "samsung" - -config SYS_SOC - default "s3c24x0" - -config SYS_CONFIG_NAME - default "smdk2410" - -endif diff --git a/board/samsung/smdk2410/MAINTAINERS b/board/samsung/smdk2410/MAINTAINERS deleted file mode 100644 index 12a25e8..0000000 --- a/board/samsung/smdk2410/MAINTAINERS +++ /dev/null @@ -1,6 +0,0 @@ -SMDK2410 BOARD -M: David Müller d.mueller@elsoft.ch -S: Maintained -F: board/samsung/smdk2410/ -F: include/configs/smdk2410.h -F: configs/smdk2410_defconfig diff --git a/board/samsung/smdk2410/Makefile b/board/samsung/smdk2410/Makefile deleted file mode 100644 index 1939a21..0000000 --- a/board/samsung/smdk2410/Makefile +++ /dev/null @@ -1,9 +0,0 @@ -# -# (C) Copyright 2000-2006 -# Wolfgang Denk, DENX Software Engineering, wd@denx.de. -# -# SPDX-License-Identifier: GPL-2.0+ -# - -obj-y := smdk2410.o -obj-y += lowlevel_init.o diff --git a/board/samsung/smdk2410/lowlevel_init.S b/board/samsung/smdk2410/lowlevel_init.S deleted file mode 100644 index c3f4187..0000000 --- a/board/samsung/smdk2410/lowlevel_init.S +++ /dev/null @@ -1,146 +0,0 @@ -/* - * Memory Setup stuff - taken from blob memsetup.S - * - * Copyright (C) 1999 2000 2001 Erik Mouw (J.A.K.Mouw@its.tudelft.nl) and - * Jan-Derk Bakker (J.D.Bakker@its.tudelft.nl) - * - * Modified for the Samsung SMDK2410 by - * (C) Copyright 2002 - * David Mueller, ELSOFT AG, d.mueller@elsoft.ch - * - * SPDX-License-Identifier: GPL-2.0+ - */ - - -#include <config.h> - -/* some parameters for the board */ - -/* - * - * Taken from linux/arch/arm/boot/compressed/head-s3c2410.S - * - * Copyright (C) 2002 Samsung Electronics SW.LEE hitchcar@sec.samsung.com - * - */ - -#define BWSCON 0x48000000 - -/* BWSCON */ -#define DW8 (0x0) -#define DW16 (0x1) -#define DW32 (0x2) -#define WAIT (0x1<<2) -#define UBLB (0x1<<3) - -#define B1_BWSCON (DW32) -#define B2_BWSCON (DW16) -#define B3_BWSCON (DW16 + WAIT + UBLB) -#define B4_BWSCON (DW16) -#define B5_BWSCON (DW16) -#define B6_BWSCON (DW32) -#define B7_BWSCON (DW32) - -/* BANK0CON */ -#define B0_Tacs 0x0 /* 0clk */ -#define B0_Tcos 0x0 /* 0clk */ -#define B0_Tacc 0x7 /* 14clk */ -#define B0_Tcoh 0x0 /* 0clk */ -#define B0_Tah 0x0 /* 0clk */ -#define B0_Tacp 0x0 -#define B0_PMC 0x0 /* normal */ - -/* BANK1CON */ -#define B1_Tacs 0x0 /* 0clk */ -#define B1_Tcos 0x0 /* 0clk */ -#define B1_Tacc 0x7 /* 14clk */ -#define B1_Tcoh 0x0 /* 0clk */ -#define B1_Tah 0x0 /* 0clk */ -#define B1_Tacp 0x0 -#define B1_PMC 0x0 - -#define B2_Tacs 0x0 -#define B2_Tcos 0x0 -#define B2_Tacc 0x7 -#define B2_Tcoh 0x0 -#define B2_Tah 0x0 -#define B2_Tacp 0x0 -#define B2_PMC 0x0 - -#define B3_Tacs 0x0 /* 0clk */ -#define B3_Tcos 0x3 /* 4clk */ -#define B3_Tacc 0x7 /* 14clk */ -#define B3_Tcoh 0x1 /* 1clk */ -#define B3_Tah 0x0 /* 0clk */ -#define B3_Tacp 0x3 /* 6clk */ -#define B3_PMC 0x0 /* normal */ - -#define B4_Tacs 0x0 /* 0clk */ -#define B4_Tcos 0x0 /* 0clk */ -#define B4_Tacc 0x7 /* 14clk */ -#define B4_Tcoh 0x0 /* 0clk */ -#define B4_Tah 0x0 /* 0clk */ -#define B4_Tacp 0x0 -#define B4_PMC 0x0 /* normal */ - -#define B5_Tacs 0x0 /* 0clk */ -#define B5_Tcos 0x0 /* 0clk */ -#define B5_Tacc 0x7 /* 14clk */ -#define B5_Tcoh 0x0 /* 0clk */ -#define B5_Tah 0x0 /* 0clk */ -#define B5_Tacp 0x0 -#define B5_PMC 0x0 /* normal */ - -#define B6_MT 0x3 /* SDRAM */ -#define B6_Trcd 0x1 -#define B6_SCAN 0x1 /* 9bit */ - -#define B7_MT 0x3 /* SDRAM */ -#define B7_Trcd 0x1 /* 3clk */ -#define B7_SCAN 0x1 /* 9bit */ - -/* REFRESH parameter */ -#define REFEN 0x1 /* Refresh enable */ -#define TREFMD 0x0 /* CBR(CAS before RAS)/Auto refresh */ -#define Trp 0x0 /* 2clk */ -#define Trc 0x3 /* 7clk */ -#define Tchr 0x2 /* 3clk */ -#define REFCNT 1113 /* period=15.6us, HCLK=60Mhz, (2048+1-15.6*60) */ -/**************************************/ - -.globl lowlevel_init -lowlevel_init: - /* memory control configuration */ - /* make r0 relative the current location so that it */ - /* reads SMRDATA out of FLASH rather than memory ! */ - ldr r0, =SMRDATA - ldr r1, =CONFIG_SYS_TEXT_BASE - sub r0, r0, r1 - ldr r1, =BWSCON /* Bus Width Status Controller */ - add r2, r0, #13*4 -0: - ldr r3, [r0], #4 - str r3, [r1], #4 - cmp r2, r0 - bne 0b - - /* everything is fine now */ - mov pc, lr - - .ltorg -/* the literal pools origin */ - -SMRDATA: - .word (0+(B1_BWSCON<<4)+(B2_BWSCON<<8)+(B3_BWSCON<<12)+(B4_BWSCON<<16)+(B5_BWSCON<<20)+(B6_BWSCON<<24)+(B7_BWSCON<<28)) - .word ((B0_Tacs<<13)+(B0_Tcos<<11)+(B0_Tacc<<8)+(B0_Tcoh<<6)+(B0_Tah<<4)+(B0_Tacp<<2)+(B0_PMC)) - .word ((B1_Tacs<<13)+(B1_Tcos<<11)+(B1_Tacc<<8)+(B1_Tcoh<<6)+(B1_Tah<<4)+(B1_Tacp<<2)+(B1_PMC)) - .word ((B2_Tacs<<13)+(B2_Tcos<<11)+(B2_Tacc<<8)+(B2_Tcoh<<6)+(B2_Tah<<4)+(B2_Tacp<<2)+(B2_PMC)) - .word ((B3_Tacs<<13)+(B3_Tcos<<11)+(B3_Tacc<<8)+(B3_Tcoh<<6)+(B3_Tah<<4)+(B3_Tacp<<2)+(B3_PMC)) - .word ((B4_Tacs<<13)+(B4_Tcos<<11)+(B4_Tacc<<8)+(B4_Tcoh<<6)+(B4_Tah<<4)+(B4_Tacp<<2)+(B4_PMC)) - .word ((B5_Tacs<<13)+(B5_Tcos<<11)+(B5_Tacc<<8)+(B5_Tcoh<<6)+(B5_Tah<<4)+(B5_Tacp<<2)+(B5_PMC)) - .word ((B6_MT<<15)+(B6_Trcd<<2)+(B6_SCAN)) - .word ((B7_MT<<15)+(B7_Trcd<<2)+(B7_SCAN)) - .word ((REFEN<<23)+(TREFMD<<22)+(Trp<<20)+(Trc<<18)+(Tchr<<16)+REFCNT) - .word 0x32 - .word 0x30 - .word 0x30 diff --git a/board/samsung/smdk2410/smdk2410.c b/board/samsung/smdk2410/smdk2410.c deleted file mode 100644 index 6e678c7..0000000 --- a/board/samsung/smdk2410/smdk2410.c +++ /dev/null @@ -1,139 +0,0 @@ -/* - * (C) Copyright 2002 - * Sysgo Real-Time Solutions, GmbH <www.elinos.com> - * Marius Groeger mgroeger@sysgo.de - * - * (C) Copyright 2002, 2010 - * David Mueller, ELSOFT AG, d.mueller@elsoft.ch - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <netdev.h> -#include <asm/io.h> -#include <asm/arch/s3c24x0_cpu.h> - -DECLARE_GLOBAL_DATA_PTR; - -#define FCLK_SPEED 1 - -#if (FCLK_SPEED == 0) /* Fout = 203MHz, Fin = 12MHz for Audio */ -#define M_MDIV 0xC3 -#define M_PDIV 0x4 -#define M_SDIV 0x1 -#elif (FCLK_SPEED == 1) /* Fout = 202.8MHz */ -#define M_MDIV 0xA1 -#define M_PDIV 0x3 -#define M_SDIV 0x1 -#endif - -#define USB_CLOCK 1 - -#if (USB_CLOCK == 0) -#define U_M_MDIV 0xA1 -#define U_M_PDIV 0x3 -#define U_M_SDIV 0x1 -#elif (USB_CLOCK == 1) -#define U_M_MDIV 0x48 -#define U_M_PDIV 0x3 -#define U_M_SDIV 0x2 -#endif - -static inline void pll_delay(unsigned long loops) -{ - __asm__ volatile ("1:\n" - "subs %0, %1, #1\n" - "bne 1b" : "=r" (loops) : "0" (loops)); -} - -/* - * Miscellaneous platform dependent initialisations - */ - -int board_early_init_f(void) -{ - struct s3c24x0_clock_power * const clk_power = - s3c24x0_get_base_clock_power(); - struct s3c24x0_gpio * const gpio = s3c24x0_get_base_gpio(); - - /* to reduce PLL lock time, adjust the LOCKTIME register */ - writel(0xFFFFFF, &clk_power->locktime); - - /* configure MPLL */ - writel((M_MDIV << 12) + (M_PDIV << 4) + M_SDIV, - &clk_power->mpllcon); - - /* some delay between MPLL and UPLL */ - pll_delay(4000); - - /* configure UPLL */ - writel((U_M_MDIV << 12) + (U_M_PDIV << 4) + U_M_SDIV, - &clk_power->upllcon); - - /* some delay between MPLL and UPLL */ - pll_delay(8000); - - /* set up the I/O ports */ - writel(0x007FFFFF, &gpio->gpacon); - writel(0x00044555, &gpio->gpbcon); - writel(0x000007FF, &gpio->gpbup); - writel(0xAAAAAAAA, &gpio->gpccon); - writel(0x0000FFFF, &gpio->gpcup); - writel(0xAAAAAAAA, &gpio->gpdcon); - writel(0x0000FFFF, &gpio->gpdup); - writel(0xAAAAAAAA, &gpio->gpecon); - writel(0x0000FFFF, &gpio->gpeup); - writel(0x000055AA, &gpio->gpfcon); - writel(0x000000FF, &gpio->gpfup); - writel(0xFF95FFBA, &gpio->gpgcon); - writel(0x0000FFFF, &gpio->gpgup); - writel(0x002AFAAA, &gpio->gphcon); - writel(0x000007FF, &gpio->gphup); - - return 0; -} - -int board_init(void) -{ - /* arch number of SMDK2410-Board */ - gd->bd->bi_arch_number = MACH_TYPE_SMDK2410; - - /* adress of boot parameters */ - gd->bd->bi_boot_params = 0x30000100; - - icache_enable(); - dcache_enable(); - - return 0; -} - -int dram_init(void) -{ - /* dram_init must store complete ramsize in gd->ram_size */ - gd->ram_size = PHYS_SDRAM_1_SIZE; - return 0; -} - -#ifdef CONFIG_CMD_NET -int board_eth_init(bd_t *bis) -{ - int rc = 0; -#ifdef CONFIG_CS8900 - rc = cs8900_initialize(0, CONFIG_CS8900_BASE); -#endif - return rc; -} -#endif - -/* - * Hardcoded flash setup: - * Flash 0 is a non-CFI AMD AM29LV800BB flash. - */ -ulong board_flash_get_legacy(ulong base, int banknum, flash_info_t *info) -{ - info->portwidth = FLASH_CFI_16BIT; - info->chipwidth = FLASH_CFI_BY16; - info->interface = FLASH_CFI_X16; - return 1; -} diff --git a/configs/smdk2410_defconfig b/configs/smdk2410_defconfig deleted file mode 100644 index 1eba4f9..0000000 --- a/configs/smdk2410_defconfig +++ /dev/null @@ -1,18 +0,0 @@ -CONFIG_ARM=y -CONFIG_TARGET_SMDK2410=y -CONFIG_BOOTDELAY=5 -# CONFIG_SYS_STDIO_DEREGISTER is not set -# CONFIG_DISPLAY_BOARDINFO is not set -CONFIG_HUSH_PARSER=y -CONFIG_SYS_PROMPT="SMDK2410 # " -CONFIG_CMD_USB=y -# CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_DHCP=y -CONFIG_CMD_PING=y -CONFIG_CMD_CACHE=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_FAT=y -CONFIG_CMD_UBI=y -CONFIG_USB=y -CONFIG_USB_STORAGE=y -CONFIG_USB_KEYBOARD=y diff --git a/include/configs/smdk2410.h b/include/configs/smdk2410.h deleted file mode 100644 index 1578310..0000000 --- a/include/configs/smdk2410.h +++ /dev/null @@ -1,180 +0,0 @@ -/* - * (C) Copyright 2002 - * Sysgo Real-Time Solutions, GmbH <www.elinos.com> - * Marius Groeger mgroeger@sysgo.de - * Gary Jennejohn garyj@denx.de - * David Mueller d.mueller@elsoft.ch - * - * Configuation settings for the SAMSUNG SMDK2410 board. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#ifndef __CONFIG_H -#define __CONFIG_H - -/* - * High Level Configuration Options - * (easy to change) - */ -#define CONFIG_S3C24X0 /* This is a SAMSUNG S3C24x0-type SoC */ -#define CONFIG_S3C2410 /* specifically a SAMSUNG S3C2410 SoC */ -#define CONFIG_SMDK2410 /* on a SAMSUNG SMDK2410 Board */ - -#define CONFIG_SYS_TEXT_BASE 0x0 - -#define CONFIG_SYS_ARM_CACHE_WRITETHROUGH - -/* input clock of PLL (the SMDK2410 has 12MHz input clock) */ -#define CONFIG_SYS_CLK_FREQ 12000000 - -#define CONFIG_CMDLINE_TAG /* enable passing of ATAGs */ -#define CONFIG_SETUP_MEMORY_TAGS -#define CONFIG_INITRD_TAG - -/* - * Hardware drivers - */ -#define CONFIG_CS8900 /* we have a CS8900 on-board */ -#define CONFIG_CS8900_BASE 0x19000300 -#define CONFIG_CS8900_BUS16 /* the Linux driver does accesses as shorts */ - -/* - * select serial console configuration - */ -#define CONFIG_S3C24X0_SERIAL -#define CONFIG_SERIAL1 1 /* we use SERIAL 1 on SMDK2410 */ - -/************************************************************ - * USB support (currently only works with D-cache off) - ************************************************************/ -#define CONFIG_USB_OHCI -#define CONFIG_USB_OHCI_S3C24XX -#define CONFIG_DOS_PARTITION - -/************************************************************ - * RTC - ************************************************************/ -#define CONFIG_RTC_S3C24X0 - -#define CONFIG_BAUDRATE 115200 - -/* - * BOOTP options - */ -#define CONFIG_BOOTP_BOOTFILESIZE -#define CONFIG_BOOTP_BOOTPATH -#define CONFIG_BOOTP_GATEWAY -#define CONFIG_BOOTP_HOSTNAME - -/* - * Command line configuration. - */ -#define CONFIG_CMD_BSP -#define CONFIG_CMD_DATE -#define CONFIG_CMD_NAND -#define CONFIG_CMD_REGINFO - -#define CONFIG_CMDLINE_EDITING - -/* autoboot */ -#define CONFIG_BOOT_RETRY_TIME -1 -#define CONFIG_RESET_TO_RETRY - -#define CONFIG_NETMASK 255.255.255.0 -#define CONFIG_IPADDR 10.0.0.110 -#define CONFIG_SERVERIP 10.0.0.1 - -#if defined(CONFIG_CMD_KGDB) -#define CONFIG_KGDB_BAUDRATE 115200 /* speed to run kgdb serial port */ -#endif - -/* - * Miscellaneous configurable options - */ -#define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_CBSIZE 256 -/* Print Buffer Size */ -#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ - sizeof(CONFIG_SYS_PROMPT)+16) -#define CONFIG_SYS_MAXARGS 16 -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE - -#define CONFIG_SYS_MEMTEST_START 0x30000000 /* memtest works on */ -#define CONFIG_SYS_MEMTEST_END 0x33F00000 /* 63 MB in DRAM */ - -#define CONFIG_SYS_LOAD_ADDR 0x30800000 - -/* support additional compression methods */ -#define CONFIG_BZIP2 -#define CONFIG_LZO -#define CONFIG_LZMA - -/*----------------------------------------------------------------------- - * Physical Memory Map - */ -#define CONFIG_NR_DRAM_BANKS 1 /* we have 1 bank of DRAM */ -#define PHYS_SDRAM_1 0x30000000 /* SDRAM Bank #1 */ -#define PHYS_SDRAM_1_SIZE 0x04000000 /* 64 MB */ - -#define PHYS_FLASH_1 0x00000000 /* Flash Bank #0 */ - -#define CONFIG_SYS_FLASH_BASE PHYS_FLASH_1 - -/*----------------------------------------------------------------------- - * FLASH and environment organization - */ - -#define CONFIG_SYS_FLASH_CFI -#define CONFIG_FLASH_CFI_DRIVER -#define CONFIG_FLASH_CFI_LEGACY -#define CONFIG_SYS_FLASH_LEGACY_512Kx16 -#define CONFIG_FLASH_SHOW_PROGRESS 45 - -#define CONFIG_SYS_MAX_FLASH_BANKS 1 -#define CONFIG_SYS_FLASH_BANKS_LIST { CONFIG_SYS_FLASH_BASE } -#define CONFIG_SYS_MAX_FLASH_SECT (19) - -#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + 0x070000) -#define CONFIG_ENV_IS_IN_FLASH -#define CONFIG_ENV_SIZE 0x10000 -/* allow to overwrite serial and ethaddr */ -#define CONFIG_ENV_OVERWRITE - -/* - * Size of malloc() pool - * BZIP2 / LZO / LZMA need a lot of RAM - */ -#define CONFIG_SYS_MALLOC_LEN (4 * 1024 * 1024) - -#define CONFIG_SYS_MONITOR_LEN (448 * 1024) -#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE - -/* - * NAND configuration - */ -#ifdef CONFIG_CMD_NAND -#define CONFIG_NAND_S3C2410 -#define CONFIG_SYS_S3C2410_NAND_HWECC -#define CONFIG_SYS_MAX_NAND_DEVICE 1 -#define CONFIG_SYS_NAND_BASE 0x4E000000 -#endif - -/* - * File system - */ -#define CONFIG_CMD_UBIFS -#define CONFIG_CMD_MTDPARTS -#define CONFIG_MTD_DEVICE -#define CONFIG_MTD_PARTITIONS -#define CONFIG_YAFFS2 -#define CONFIG_RBTREE - -/* additions for new relocation code, must be added to all boards */ -#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 -#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_SDRAM_BASE + 0x1000 - \ - GENERATED_GBL_DATA_SIZE) - -#define CONFIG_BOARD_EARLY_INIT_F - -#endif /* __CONFIG_H */ diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index d6b2a45..a573210 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -165,7 +165,6 @@ CONFIG_ARCH_RMOBILE_EXTRAM_BOOT CONFIG_ARCH_RPC CONFIG_ARCH_S3C2440 CONFIG_ARCH_SHARK -CONFIG_ARCH_SMDK2410 CONFIG_ARCH_TEGRA CONFIG_ARCH_USE_BUILTIN_BSWAP CONFIG_ARCH_VERSATILE_PB @@ -4105,7 +4104,6 @@ CONFIG_SMC_B3TIM_VAL CONFIG_SMC_GCTL_VAL CONFIG_SMC_USE_32_BIT CONFIG_SMC_USE_IOFUNCS -CONFIG_SMDK2410 CONFIG_SMDK5420 CONFIG_SMDKC100 CONFIG_SMDKV310
Acked-by: David Müller d.mueller@elsoft.ch
< snip>
Code relate to this still there in arch/arm/include/asm/mach-types.h, better to remove.
thanks!
< snip>
That's a file we sync(ed) from the kernel and should leave alone, imho.
< snip>
I always think that the code related to the CONFIG_* which are listed in config_whitelist.txt should be dropped as there is no usage on the tree.
thanks!
< snip>
Yes, but that's a special case of a file that we should just not touch.
I will however accept the argument that we should re-sync the file with a generated copy from v4.8 for example but only take the MACH_TYPE_xxx part and remove all of the machine_is_xxx parts of the file.
Signed-off-by: Simon Glass sjg@chromium.org Acked-by: David Müller d.mueller@elsoft.ch
Changes in v2: None
arch/arm/Kconfig | 5 - board/mpl/common/common_util.c | 23 -- board/mpl/vcma9/Kconfig | 15 -- board/mpl/vcma9/MAINTAINERS | 6 - board/mpl/vcma9/Makefile | 11 - board/mpl/vcma9/cmd_vcma9.c | 119 ---------- board/mpl/vcma9/lowlevel_init.S | 500 ---------------------------------------- board/mpl/vcma9/vcma9.c | 209 ----------------- board/mpl/vcma9/vcma9.h | 28 --- configs/VCMA9_defconfig | 17 -- include/configs/VCMA9.h | 205 ---------------- scripts/config_whitelist.txt | 1 - 12 files changed, 1139 deletions(-) delete mode 100644 board/mpl/vcma9/Kconfig delete mode 100644 board/mpl/vcma9/MAINTAINERS delete mode 100644 board/mpl/vcma9/Makefile delete mode 100644 board/mpl/vcma9/cmd_vcma9.c delete mode 100644 board/mpl/vcma9/lowlevel_init.S delete mode 100644 board/mpl/vcma9/vcma9.c delete mode 100644 board/mpl/vcma9/vcma9.h delete mode 100644 configs/VCMA9_defconfig delete mode 100644 include/configs/VCMA9.h
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 398dbe0..993485a 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -142,10 +142,6 @@ config TARGET_EDB93XX bool "Support edb93xx" select CPU_ARM920T
-config TARGET_VCMA9 - bool "Support VCMA9" - select CPU_ARM920T - config TARGET_ASPENITE bool "Support aspenite" select CPU_ARM926EJS @@ -971,7 +967,6 @@ source "board/h2200/Kconfig" source "board/hisilicon/hikey/Kconfig" source "board/imx31_phycore/Kconfig" source "board/isee/igep0033/Kconfig" -source "board/mpl/vcma9/Kconfig" source "board/olimex/mx23_olinuxino/Kconfig" source "board/phytec/pcm051/Kconfig" source "board/phytec/pcm052/Kconfig" diff --git a/board/mpl/common/common_util.c b/board/mpl/common/common_util.c index a6edb6d..101b6ef 100644 --- a/board/mpl/common/common_util.c +++ b/board/mpl/common/common_util.c @@ -273,29 +273,6 @@ mpl_prg(uchar *src, ulong size) return (1); } #endif /* defined(CONFIG_PATI) */ - -#elif defined(CONFIG_VCMA9) - start = 0; - - /* search end sector */ - for (i = 0; i < info->sector_count; i++) - if (size < info->start[i]) - break; - - flash_protect(FLAG_PROTECT_CLEAR, - start, - size, - info); - - /* now erase flash */ - printf("Erasing at %lx (sector %d) (start %lx)\n", - start,0,info->start[0]); - if ((rc = flash_erase (info, 0, i)) != 0) { - puts("ERROR "); - flash_perror(rc); - return (1); - } - #endif printf("flash erased, programming from 0x%lx 0x%lx Bytes\n", (ulong)src, size); diff --git a/board/mpl/vcma9/Kconfig b/board/mpl/vcma9/Kconfig deleted file mode 100644 index a156452..0000000 --- a/board/mpl/vcma9/Kconfig +++ /dev/null @@ -1,15 +0,0 @@ -if TARGET_VCMA9 - -config SYS_BOARD - default "vcma9" - -config SYS_VENDOR - default "mpl" - -config SYS_SOC - default "s3c24x0" - -config SYS_CONFIG_NAME - default "VCMA9" - -endif diff --git a/board/mpl/vcma9/MAINTAINERS b/board/mpl/vcma9/MAINTAINERS deleted file mode 100644 index 3817436..0000000 --- a/board/mpl/vcma9/MAINTAINERS +++ /dev/null @@ -1,6 +0,0 @@ -VCMA9 BOARD -M: David Müller d.mueller@elsoft.ch -S: Maintained -F: board/mpl/vcma9/ -F: include/configs/VCMA9.h -F: configs/VCMA9_defconfig diff --git a/board/mpl/vcma9/Makefile b/board/mpl/vcma9/Makefile deleted file mode 100644 index 175a19f..0000000 --- a/board/mpl/vcma9/Makefile +++ /dev/null @@ -1,11 +0,0 @@ -# -# (C) Copyright 2000-2006 -# Wolfgang Denk, DENX Software Engineering, wd@denx.de. -# -# SPDX-License-Identifier: GPL-2.0+ -# - -obj-y := ../common/common_util.o -obj-y += vcma9.o cmd_vcma9.o - -obj-y += lowlevel_init.o diff --git a/board/mpl/vcma9/cmd_vcma9.c b/board/mpl/vcma9/cmd_vcma9.c deleted file mode 100644 index c2d62e4..0000000 --- a/board/mpl/vcma9/cmd_vcma9.c +++ /dev/null @@ -1,119 +0,0 @@ -/* - * (C) Copyright 2002 - * Denis Peter, MPL AG Switzerland, d.peter@mpl.ch - * - * adapted for VCMA9 - * David Mueller, ELSOFT AG, d.mueller@elsoft.ch - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <command.h> -#include <net.h> -#include "vcma9.h" -#include "../common/common_util.h" - -#if defined(CONFIG_CS8900) -#include <../drivers/net/cs8900.h> - -static uchar cs8900_chksum(ushort data) -{ - return((data >> 8) & 0x00FF) + (data & 0x00FF); -} - -#endif - -DECLARE_GLOBAL_DATA_PTR; - -/* ------------------------------------------------------------------------- */ - -int do_vcma9(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) -{ - struct eth_device *dev; - char cs8900_name[10]; - if (strcmp(argv[1], "info") == 0) - { - vcma9_print_info(); - return 0; - } -#if defined(CONFIG_CS8900) - if (strcmp(argv[1], "cs8900") == 0) { - sprintf(cs8900_name, "%s-0", CS8900_DRIVERNAME); - dev = eth_get_dev_by_name(cs8900_name); - if (!dev) { - printf("Couldn't find CS8900 driver"); - return 0; - } - if (strcmp(argv[2], "read") == 0) { - uchar addr; ushort data; - - addr = simple_strtoul(argv[3], NULL, 16); - cs8900_e2prom_read(dev, addr, &data); - printf("0x%2.2X: 0x%4.4X\n", addr, data); - } else if (strcmp(argv[2], "write") == 0) { - uchar addr; ushort data; - - addr = simple_strtoul(argv[3], NULL, 16); - data = simple_strtoul(argv[4], NULL, 16); - cs8900_e2prom_write(dev, addr, data); - } else if (strcmp(argv[2], "setaddr") == 0) { - uchar addr, i, csum; ushort data; - uchar ethaddr[6]; - - /* check for valid ethaddr */ - if (eth_getenv_enetaddr("ethaddr", ethaddr)) { - addr = 1; - data = 0x2158; - cs8900_e2prom_write(dev, addr, data); - csum = cs8900_chksum(data); - addr++; - for (i = 0; i < 6; i+=2) { - data = ethaddr[i+1] << 8 | - ethaddr[i]; - cs8900_e2prom_write(dev, addr, data); - csum += cs8900_chksum(data); - addr++; - } - /* calculate header link byte */ - data = 0xA100 | (addr * 2); - cs8900_e2prom_write(dev, 0, data); - csum += cs8900_chksum(data); - /* write checksum word */ - cs8900_e2prom_write(dev, addr, (0 - csum) << 8); - } else { - puts("\nplease defined 'ethaddr'\n"); - } - } else if (strcmp(argv[2], "dump") == 0) { - uchar addr = 0, endaddr, csum; ushort data; - - puts("Dump of CS8900 config device: "); - cs8900_e2prom_read(dev, addr, &data); - if ((data & 0xE000) == 0xA000) { - endaddr = (data & 0x00FF) / 2; - csum = cs8900_chksum(data); - for (addr = 1; addr <= endaddr; addr++) { - cs8900_e2prom_read(dev, addr, &data); - printf("\n0x%2.2X: 0x%4.4X", addr, data); - csum += cs8900_chksum(data); - } - printf("\nChecksum: %s", (csum == 0) ? "ok" : "wrong"); - } else { - puts("no valid config found"); - } - puts("\n"); - } - - return 0; - } -#endif - - return (do_mplcommon(cmdtp, flag, argc, argv)); -} - -U_BOOT_CMD( - vcma9, 6, 1, do_vcma9, - "VCMA9 specific commands", - "flash mem [SrcAddr] - updates U-Boot with image in memory\n" - "vcma9 info - displays board information" -); diff --git a/board/mpl/vcma9/lowlevel_init.S b/board/mpl/vcma9/lowlevel_init.S deleted file mode 100644 index c0d6cc8..0000000 --- a/board/mpl/vcma9/lowlevel_init.S +++ /dev/null @@ -1,500 +0,0 @@ -/* - * Memory Setup stuff - taken from blob memsetup.S - * - * Copyright (C) 1999 2000 2001 Erik Mouw (J.A.K.Mouw@its.tudelft.nl) and - * Jan-Derk Bakker (J.D.Bakker@its.tudelft.nl) - * - * Modified for MPL VCMA9 by - * David Mueller, ELSOFT AG, d.mueller@elsoft.ch - * (C) Copyright 2002, 2003, 2004, 2005 - * - * SPDX-License-Identifier: GPL-2.0+ - */ - - -#include <config.h> - -/* register definitions */ - -#define PLD_BASE 0x28000000 -#define MISC_REG 0x103 -#define SDRAM_REG 0x106 -#define BWSCON 0x48000000 -#define CLKBASE 0x4C000000 -#define LOCKTIME 0x0 -#define MPLLCON 0x4 -#define UPLLCON 0x8 -#define GPIOBASE 0x56000000 -#define GSTATUS1 0xB0 -#define FASTCPU 0x02 - -/* some parameters for the board */ -/* BWSCON */ -#define DW8 (0x0) -#define DW16 (0x1) -#define DW32 (0x2) -#define WAIT (0x1<<2) -#define UBLB (0x1<<3) - -/* BANKSIZE */ -#define BURST_EN (0x1<<7) - -/* BANK0CON 200 */ -#define B0_Tacs_200 0x0 /* 0clk (or 0x1 1clk) */ -#define B0_Tcos_200 0x1 /* 1clk (or 0x2 2clk) */ -#define B0_Tacc_200 0x5 /* 8clk (or 0x6 10clk) */ -#define B0_Tcoh_200 0x0 /* 0clk */ -#define B0_Tcah_200 0x3 /* 4clk (or0x01 1clk) */ -#define B0_Tacp_200 0x0 /* page mode is not used */ -#define B0_PMC_200 0x0 /* page mode disabled */ - -/* BANK0CON 250 */ -#define B0_Tacs_250 0x0 /* 0clk (or 0x1 1clk) */ -#define B0_Tcos_250 0x1 /* 1clk (or 0x2 2clk) */ -#define B0_Tacc_250 0x5 /* 8clk (or 0x7 14clk) */ -#define B0_Tcoh_250 0x0 /* 0clk */ -#define B0_Tcah_250 0x3 /* 4clk (or 0x1 1clk) */ -#define B0_Tacp_250 0x0 /* page mode is not used */ -#define B0_PMC_250 0x0 /* page mode disabled */ - -/* BANK0CON 266 */ -#define B0_Tacs_266 0x0 /* 0clk (or 0x1 1clk) */ -#define B0_Tcos_266 0x1 /* 1clk (or 0x2 2clk) */ -#define B0_Tacc_266 0x6 /* 10clk (or 0x7 14clk) */ -#define B0_Tcoh_266 0x0 /* 0clk */ -#define B0_Tcah_266 0x3 /* 4clk (or 0x1 1clk) */ -#define B0_Tacp_266 0x0 /* page mode is not used */ -#define B0_PMC_266 0x0 /* page mode disabled */ - -/* BANK1CON 200 */ -#define B1_Tacs_200 0x0 /* 0clk (or 0x1 1clk) */ -#define B1_Tcos_200 0x1 /* 1clk (or 0x2 2clk) */ -#define B1_Tacc_200 0x5 /* 8clk (or 0x6 10clk) */ -#define B1_Tcoh_200 0x0 /* 0clk */ -#define B1_Tcah_200 0x3 /* 4clk (or 0x1 1clk) */ -#define B1_Tacp_200 0x0 /* page mode is not used */ -#define B1_PMC_200 0x0 /* page mode disabled */ - -/* BANK1CON 250 */ -#define B1_Tacs_250 0x0 /* 0clk (or 0x1 1clk) */ -#define B1_Tcos_250 0x1 /* 1clk (or 0x2 2clk) */ -#define B1_Tacc_250 0x5 /* 8clk (or 0x7 14clk) */ -#define B1_Tcoh_250 0x0 /* 0clk */ -#define B1_Tcah_250 0x3 /* 4clk (or 0x1 1clk) */ -#define B1_Tacp_250 0x0 /* page mode is not used */ -#define B1_PMC_250 0x0 /* page mode disabled */ - -/* BANK1CON 266 */ -#define B1_Tacs_266 0x0 /* 0clk (or 0x1 1clk) */ -#define B1_Tcos_266 0x1 /* 1clk (or 0x2 2clk) */ -#define B1_Tacc_266 0x6 /* 10clk (or 0x7 14clk) */ -#define B1_Tcoh_266 0x0 /* 0clk */ -#define B1_Tcah_266 0x3 /* 4clk (or 0x1 1clk) */ -#define B1_Tacp_266 0x0 /* page mode is not used */ -#define B1_PMC_266 0x0 /* page mode disabled */ - -/* BANK2CON 200 + 250 + 266 */ -#define B2_Tacs 0x3 /* 4clk */ -#define B2_Tcos 0x3 /* 4clk */ -#define B2_Tacc 0x7 /* 14clk */ -#define B2_Tcoh 0x3 /* 4clk */ -#define B2_Tcah 0x3 /* 4clk */ -#define B2_Tacp 0x0 /* page mode is not used */ -#define B2_PMC 0x0 /* page mode disabled */ - -/* BANK3CON 200 + 250 + 266 */ -#define B3_Tacs 0x3 /* 4clk */ -#define B3_Tcos 0x3 /* 4clk */ -#define B3_Tacc 0x7 /* 14clk */ -#define B3_Tcoh 0x3 /* 4clk */ -#define B3_Tcah 0x3 /* 4clk */ -#define B3_Tacp 0x0 /* page mode is not used */ -#define B3_PMC 0x0 /* page mode disabled */ - -/* BANK4CON 200 */ -#define B4_Tacs_200 0x1 /* 1clk */ -#define B4_Tcos_200 0x3 /* 4clk */ -#define B4_Tacc_200 0x7 /* 14clk */ -#define B4_Tcoh_200 0x3 /* 4clk */ -#define B4_Tcah_200 0x2 /* 2clk */ -#define B4_Tacp_200 0x0 /* page mode is not used */ -#define B4_PMC_200 0x0 /* page mode disabled */ - -/* BANK4CON 250 */ -#define B4_Tacs_250 0x1 /* 1clk */ -#define B4_Tcos_250 0x3 /* 4clk */ -#define B4_Tacc_250 0x7 /* 14clk */ -#define B4_Tcoh_250 0x3 /* 4clk */ -#define B4_Tcah_250 0x2 /* 2clk */ -#define B4_Tacp_250 0x0 /* page mode is not used */ -#define B4_PMC_250 0x0 /* page mode disabled */ - -/* BANK4CON 266 */ -#define B4_Tacs_266 0x1 /* 1clk */ -#define B4_Tcos_266 0x3 /* 4clk */ -#define B4_Tacc_266 0x7 /* 14clk */ -#define B4_Tcoh_266 0x3 /* 4clk */ -#define B4_Tcah_266 0x2 /* 2clk */ -#define B4_Tacp_266 0x0 /* page mode is not used */ -#define B4_PMC_266 0x0 /* page mode disabled */ - -/* BANK5CON 200 */ -#define B5_Tacs_200 0x0 /* 0clk */ -#define B5_Tcos_200 0x3 /* 4clk */ -#define B5_Tacc_200 0x4 /* 6clk */ -#define B5_Tcoh_200 0x3 /* 4clk */ -#define B5_Tcah_200 0x1 /* 1clk */ -#define B5_Tacp_200 0x0 /* page mode is not used */ -#define B5_PMC_200 0x0 /* page mode disabled */ - -/* BANK5CON 250 */ -#define B5_Tacs_250 0x0 /* 0clk */ -#define B5_Tcos_250 0x3 /* 4clk */ -#define B5_Tacc_250 0x5 /* 8clk */ -#define B5_Tcoh_250 0x3 /* 4clk */ -#define B5_Tcah_250 0x1 /* 1clk */ -#define B5_Tacp_250 0x0 /* page mode is not used */ -#define B5_PMC_250 0x0 /* page mode disabled */ - -/* BANK5CON 266 */ -#define B5_Tacs_266 0x0 /* 0clk */ -#define B5_Tcos_266 0x3 /* 4clk */ -#define B5_Tacc_266 0x5 /* 8clk */ -#define B5_Tcoh_266 0x3 /* 4clk */ -#define B5_Tcah_266 0x1 /* 1clk */ -#define B5_Tacp_266 0x0 /* page mode is not used */ -#define B5_PMC_266 0x0 /* page mode disabled */ - -#define B6_MT 0x3 /* SDRAM */ -#define B6_Trcd_200 0x0 /* 2clk */ -#define B6_Trcd_250 0x1 /* 3clk */ -#define B6_Trcd_266 0x1 /* 3clk */ -#define B6_SCAN 0x2 /* 10bit */ - -#define B7_MT 0x3 /* SDRAM */ -#define B7_Trcd_200 0x0 /* 2clk */ -#define B7_Trcd_250 0x1 /* 3clk */ -#define B7_Trcd_266 0x1 /* 3clk */ -#define B7_SCAN 0x2 /* 10bit */ - -/* REFRESH parameter */ -#define REFEN 0x1 /* Refresh enable */ -#define TREFMD 0x0 /* CBR(CAS before RAS)/Auto refresh */ -#define Trp_200 0x0 /* 2clk */ -#define Trp_250 0x1 /* 3clk */ -#define Trp_266 0x1 /* 3clk */ -#define Tsrc_200 0x1 /* 5clk */ -#define Tsrc_250 0x2 /* 6clk */ -#define Tsrc_266 0x3 /* 7clk */ - -/* period=15.6us, HCLK=100Mhz, (2048+1-15.6*100) */ -#define REFCNT_200 489 -/* period=15.6us, HCLK=125Mhz, (2048+1-15.6*125) */ -#define REFCNT_250 99 -/* period=15.6us, HCLK=133Mhz, (2048+1-15.6*133) */ -#define REFCNT_266 0 -/**************************************/ - -.globl lowlevel_init -lowlevel_init: - /* use r0 to relocate DATA read/write to flash rather than memory ! */ - ldr r0, =CONFIG_SYS_TEXT_BASE - ldr r13, =BWSCON - - /* enable minimal access to PLD */ - ldr r1, [r13] /* load default BWSCON */ - orr r1, r1, #(DW8 + UBLB) << 20 /* set necessary CS attrs */ - str r1, [r13] /* set BWSCON */ - ldr r1, =0x7FF0 /* select slowest timing */ - str r1, [r13, #0x18] /* set BANKCON5 */ - - ldr r1, =PLD_BASE - ldr r2, =SETUPDATA - ldrb r1, [r1, #MISC_REG] - sub r2, r2, r0 - tst r1, #FASTCPU /* FASTCPU available ? */ - addeq r2, r2, #SETUPENTRY_SIZE - - /* memory control configuration */ - /* r2 = pointer into timing table */ - /* r13 = pointer to MEM controller regs (starting with BWSCON) */ - add r3, r2, #CSDATA_OFFSET - add r4, r3, #CSDATAENTRY_SIZE -0: - ldr r1, [r3], #4 - str r1, [r13], #4 - cmp r3, r4 - bne 0b - - /* PLD access is now possible */ - /* r3 = SDRAMDATA */ - /* r13 = pointer to MEM controller regs */ - ldr r1, =PLD_BASE - mov r4, #SDRAMENTRY_SIZE - ldrb r1, [r1, #SDRAM_REG] - /* calculate start and end point */ - mla r3, r4, r1, r3 - add r4, r3, r4 -0: - ldr r1, [r3], #4 - str r1, [r13], #4 - cmp r3, r4 - bne 0b - - /* setup MPLL registers */ - ldr r1, =CLKBASE - ldr r4, =0xFFFFFF - add r3, r2, #4 /* r3 points to PLL values */ - str r4, [r1, #LOCKTIME] - ldmia r3, {r4,r5} - str r5, [r1, #UPLLCON] /* writing PLL register */ - /* !! order seems to be important !! */ - /* a little delay */ - ldr r3, =0x4000 -0: - subs r3, r3, #1 - bne 0b - - str r4, [r1, #MPLLCON] /* writing PLL register */ - /* !! order seems to be important !! */ - /* a little delay */ - ldr r3, =0x4000 -0: - subs r3, r3, #1 - bne 0b - - /* everything is fine now */ - mov pc, lr - - .ltorg -/* the literal pools origin */ - -#define MK_BWSCON(bws1, bws2, bws3, bws4, bws5, bws6, bws7) \ - ((bws1) << 4) + \ - ((bws2) << 8) + \ - ((bws3) << 12) + \ - ((bws4) << 16) + \ - ((bws5) << 20) + \ - ((bws6) << 24) + \ - ((bws7) << 28) - -#define MK_BANKCON(tacs, tcos, tacc, tcoh, tcah, tacp, pmc) \ - ((tacs) << 13) + \ - ((tcos) << 11) + \ - ((tacc) << 8) + \ - ((tcoh) << 6) + \ - ((tcah) << 4) + \ - ((tacp) << 2) + \ - (pmc) - -#define MK_BANKCON_SDRAM(trcd, scan) \ - ((0x03) << 15) + \ - ((trcd) << 2) + \ - (scan) - -#define MK_SDRAM_REFRESH(enable, trefmd, trp, tsrc, cnt) \ - ((enable) << 23) + \ - ((trefmd) << 22) + \ - ((trp) << 20) + \ - ((tsrc) << 18) + \ - (cnt) - -SETUPDATA: - .word 0x32410002 - /* PLL values (MDIV, PDIV, SDIV) for 250 MHz */ - .word (0x75 << 12) + (0x01 << 4) + (0x01 << 0) - /* PLL values for USB clock */ - .word (0x48 << 12) + (0x03 << 4) + (0x02 << 0) - - /* timing for 250 MHz*/ -0: - .equiv CSDATA_OFFSET, (. - SETUPDATA) - .word MK_BWSCON(DW16, \ - DW32, \ - DW32, \ - DW16 + WAIT + UBLB, \ - DW8 + UBLB, \ - DW32, \ - DW32) - - .word MK_BANKCON(B0_Tacs_250, \ - B0_Tcos_250, \ - B0_Tacc_250, \ - B0_Tcoh_250, \ - B0_Tcah_250, \ - B0_Tacp_250, \ - B0_PMC_250) - - .word MK_BANKCON(B1_Tacs_250, \ - B1_Tcos_250, \ - B1_Tacc_250, \ - B1_Tcoh_250, \ - B1_Tcah_250, \ - B1_Tacp_250, \ - B1_PMC_250) - - .word MK_BANKCON(B2_Tacs, \ - B2_Tcos, \ - B2_Tacc, \ - B2_Tcoh, \ - B2_Tcah, \ - B2_Tacp, \ - B2_PMC) - - .word MK_BANKCON(B3_Tacs, \ - B3_Tcos, \ - B3_Tacc, \ - B3_Tcoh, \ - B3_Tcah, \ - B3_Tacp, \ - B3_PMC) - - .word MK_BANKCON(B4_Tacs_250, \ - B4_Tcos_250, \ - B4_Tacc_250, \ - B4_Tcoh_250, \ - B4_Tcah_250, \ - B4_Tacp_250, \ - B4_PMC_250) - - .word MK_BANKCON(B5_Tacs_250, \ - B5_Tcos_250, \ - B5_Tacc_250, \ - B5_Tcoh_250, \ - B5_Tcah_250, \ - B5_Tacp_250, \ - B5_PMC_250) - - .equiv CSDATAENTRY_SIZE, (. - 0b) - /* 4Mx8x4 */ -0: - .word MK_BANKCON_SDRAM(B6_Trcd_250, B6_SCAN) - .word MK_BANKCON_SDRAM(B7_Trcd_250, B7_SCAN) - .word MK_SDRAM_REFRESH(REFEN, TREFMD, Trp_250, Tsrc_250, REFCNT_250) - .word 0x32 + BURST_EN - .word 0x30 - .word 0x30 - .equiv SDRAMENTRY_SIZE, (. - 0b) - - /* 8Mx8x4 */ - .word MK_BANKCON_SDRAM(B6_Trcd_250, B6_SCAN) - .word MK_BANKCON_SDRAM(B7_Trcd_250, B7_SCAN) - .word MK_SDRAM_REFRESH(REFEN, TREFMD, Trp_250, Tsrc_250, REFCNT_250) - .word 0x32 + BURST_EN - .word 0x30 - .word 0x30 - - /* 2Mx8x4 */ - .word MK_BANKCON_SDRAM(B6_Trcd_250, B6_SCAN) - .word MK_BANKCON_SDRAM(B7_Trcd_250, B7_SCAN) - .word MK_SDRAM_REFRESH(REFEN, TREFMD, Trp_250, Tsrc_250, REFCNT_250) - .word 0x32 + BURST_EN - .word 0x30 - .word 0x30 - - /* 4Mx8x2 */ - .word MK_BANKCON_SDRAM(B6_Trcd_250, B6_SCAN) - .word MK_BANKCON_SDRAM(B7_Trcd_250, B7_SCAN) - .word MK_SDRAM_REFRESH(REFEN, TREFMD, Trp_250, Tsrc_250, REFCNT_250) - .word 0x32 + BURST_EN - .word 0x30 - .word 0x30 - - .equiv SETUPENTRY_SIZE, (. - SETUPDATA) - - .word 0x32410000 - /* PLL values (MDIV, PDIV, SDIV) for 200 MHz (Fout = 202.8MHz) */ - .word (0xA1 << 12) + (0x03 << 4) + (0x01 << 0) - /* PLL values for USB clock */ - .word (0x48 << 12) + (0x03 << 4) + (0x02 << 0) - - /* timing for 200 MHz and default*/ - .word MK_BWSCON(DW16, \ - DW32, \ - DW32, \ - DW16 + WAIT + UBLB, \ - DW8 + UBLB, \ - DW32, \ - DW32) - - .word MK_BANKCON(B0_Tacs_200, \ - B0_Tcos_200, \ - B0_Tacc_200, \ - B0_Tcoh_200, \ - B0_Tcah_200, \ - B0_Tacp_200, \ - B0_PMC_200) - - .word MK_BANKCON(B1_Tacs_200, \ - B1_Tcos_200, \ - B1_Tacc_200, \ - B1_Tcoh_200, \ - B1_Tcah_200, \ - B1_Tacp_200, \ - B1_PMC_200) - - .word MK_BANKCON(B2_Tacs, \ - B2_Tcos, \ - B2_Tacc, \ - B2_Tcoh, \ - B2_Tcah, \ - B2_Tacp, \ - B2_PMC) - - .word MK_BANKCON(B3_Tacs, \ - B3_Tcos, \ - B3_Tacc, \ - B3_Tcoh, \ - B3_Tcah, \ - B3_Tacp, \ - B3_PMC) - - .word MK_BANKCON(B4_Tacs_200, \ - B4_Tcos_200, \ - B4_Tacc_200, \ - B4_Tcoh_200, \ - B4_Tcah_200, \ - B4_Tacp_200, \ - B4_PMC_200) - - .word MK_BANKCON(B5_Tacs_200, \ - B5_Tcos_200, \ - B5_Tacc_200, \ - B5_Tcoh_200, \ - B5_Tcah_200, \ - B5_Tacp_200, \ - B5_PMC_200) - - /* 4Mx8x4 */ - .word MK_BANKCON_SDRAM(B6_Trcd_200, B6_SCAN) - .word MK_BANKCON_SDRAM(B7_Trcd_200, B7_SCAN) - .word MK_SDRAM_REFRESH(REFEN, TREFMD, Trp_200, Tsrc_200, REFCNT_200) - .word 0x32 + BURST_EN - .word 0x30 - .word 0x30 - - /* 8Mx8x4 */ - .word MK_BANKCON_SDRAM(B6_Trcd_200, B6_SCAN) - .word MK_BANKCON_SDRAM(B7_Trcd_200, B7_SCAN) - .word MK_SDRAM_REFRESH(REFEN, TREFMD, Trp_200, Tsrc_200, REFCNT_200) - .word 0x32 + BURST_EN - .word 0x30 - .word 0x30 - - /* 2Mx8x4 */ - .word MK_BANKCON_SDRAM(B6_Trcd_200, B6_SCAN) - .word MK_BANKCON_SDRAM(B7_Trcd_200, B7_SCAN) - .word MK_SDRAM_REFRESH(REFEN, TREFMD, Trp_200, Tsrc_200, REFCNT_200) - .word 0x32 + BURST_EN - .word 0x30 - .word 0x30 - - /* 4Mx8x2 */ - .word MK_BANKCON_SDRAM(B6_Trcd_200, B6_SCAN) - .word MK_BANKCON_SDRAM(B7_Trcd_200, B7_SCAN) - .word MK_SDRAM_REFRESH(REFEN, TREFMD, Trp_200, Tsrc_200, REFCNT_200) - .word 0x32 + BURST_EN - .word 0x30 - .word 0x30 - - .equiv SETUPDATA_SIZE, (. - SETUPDATA) diff --git a/board/mpl/vcma9/vcma9.c b/board/mpl/vcma9/vcma9.c deleted file mode 100644 index 43a3d47..0000000 --- a/board/mpl/vcma9/vcma9.c +++ /dev/null @@ -1,209 +0,0 @@ -/* - * (C) Copyright 2002 - * Sysgo Real-Time Solutions, GmbH <www.elinos.com> - * Marius Groeger mgroeger@sysgo.de - * - * (C) Copyright 2002, 2010 - * David Mueller, ELSOFT AG, d.mueller@elsoft.ch - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <netdev.h> -#include <i2c.h> -#include <asm/io.h> -#include <asm/arch/s3c24x0_cpu.h> - -#include "vcma9.h" -#include "../common/common_util.h" - -DECLARE_GLOBAL_DATA_PTR; - -/* - * Miscellaneous platform dependent initialisations - */ - -int board_early_init_f(void) -{ - struct s3c24x0_gpio * const gpio = s3c24x0_get_base_gpio(); - - /* set up the I/O ports */ - writel(0x007FFFFF, &gpio->gpacon); - writel(0x002AAAAA, &gpio->gpbcon); - writel(0x000002BF, &gpio->gpbup); - writel(0xAAAAAAAA, &gpio->gpccon); - writel(0x0000FFFF, &gpio->gpcup); - writel(0xAAAAAAAA, &gpio->gpdcon); - writel(0x0000FFFF, &gpio->gpdup); - writel(0xAAAAAAAA, &gpio->gpecon); - writel(0x000037F7, &gpio->gpeup); - writel(0x00000000, &gpio->gpfcon); - writel(0x00000000, &gpio->gpfup); - writel(0xFFEAFF5A, &gpio->gpgcon); - writel(0x0000F0DC, &gpio->gpgup); - writel(0x0028AAAA, &gpio->gphcon); - writel(0x00000656, &gpio->gphup); - - /* setup correct IRQ modes for NIC (rising edge mode) */ - writel((readl(&gpio->extint2) & ~(7<<8)) | (4<<8), &gpio->extint2); - - /* select USB port 2 to be host or device (setup as host for now) */ - writel(readl(&gpio->misccr) | 0x08, &gpio->misccr); - - return 0; -} - -int board_init(void) -{ - /* adress of boot parameters */ - gd->bd->bi_boot_params = 0x30000100; - - icache_enable(); - dcache_enable(); - - return 0; -} - -/* - * Get some Board/PLD Info - */ - -static u8 get_pld_reg(enum vcma9_pld_regs reg) -{ - return readb(VCMA9_PLD_BASE + reg); -} - -static u8 get_pld_version(void) -{ - return (get_pld_reg(VCMA9_PLD_ID) >> 4) & 0x0F; -} - -static u8 get_pld_revision(void) -{ - return get_pld_reg(VCMA9_PLD_ID) & 0x0F; -} - -static uchar get_board_pcb(void) -{ - return ((get_pld_reg(VCMA9_PLD_BOARD) >> 4) & 0x03) + 'A'; -} - -static u8 get_nr_chips(void) -{ - switch ((get_pld_reg(VCMA9_PLD_SDRAM) >> 4) & 0x0F) { - case 0: return 4; - case 1: return 1; - case 2: return 2; - default: return 0; - } -} - -static ulong get_chip_size(void) -{ - switch (get_pld_reg(VCMA9_PLD_SDRAM) & 0x0F) { - case 0: return 16 * (1024*1024); - case 1: return 32 * (1024*1024); - case 2: return 8 * (1024*1024); - case 3: return 8 * (1024*1024); - default: return 0; - } -} - -static const char *get_chip_geom(void) -{ - switch (get_pld_reg(VCMA9_PLD_SDRAM) & 0x0F) { - case 0: return "4Mx8x4"; - case 1: return "8Mx8x4"; - case 2: return "2Mx8x4"; - case 3: return "4Mx8x2"; - default: return "unknown"; - } -} - -static void vcma9_show_info(char *board_name, char *serial) -{ - printf("Board: %s SN: %s PCB Rev: %c PLD(%d,%d)\n", - board_name, serial, - get_board_pcb(), get_pld_version(), get_pld_revision()); - printf("SDRAM: %d chips %s\n", get_nr_chips(), get_chip_geom()); -} - -int dram_init(void) -{ - /* dram_init must store complete ramsize in gd->ram_size */ - gd->ram_size = get_chip_size() * get_nr_chips(); - return 0; -} - -/* - * Check Board Identity: - */ - -int checkboard(void) -{ - char s[50]; - int i; - backup_t *b = (backup_t *) s; - - i = getenv_f("serial#", s, 32); - if ((i < 0) || strncmp (s, "VCMA9", 5)) { - get_backup_values (b); - if (strncmp (b->signature, "MPL\0", 4) != 0) { - puts ("### No HW ID - assuming VCMA9"); - } else { - b->serial_name[5] = 0; - vcma9_show_info(b->serial_name, &b->serial_name[6]); - } - } else { - s[5] = 0; - vcma9_show_info(s, &s[6]); - } - - return 0; -} - -int board_late_init(void) -{ - /* - * check if environment is healthy, otherwise restore values - * from shadow copy - */ - check_env(); - return 0; -} - -void vcma9_print_info(void) -{ - char *s = getenv("serial#"); - - if (!s) { - puts ("### No HW ID - assuming VCMA9"); - } else { - s[5] = 0; - vcma9_show_info(s, &s[6]); - } -} - -#ifdef CONFIG_CMD_NET -int board_eth_init(bd_t *bis) -{ - int rc = 0; -#ifdef CONFIG_CS8900 - rc = cs8900_initialize(0, CONFIG_CS8900_BASE); -#endif - return rc; -} -#endif - -/* - * Hardcoded flash setup: - * Flash 0 is a non-CFI AMD AM29F400BB flash. - */ -ulong board_flash_get_legacy(ulong base, int banknum, flash_info_t *info) -{ - info->portwidth = FLASH_CFI_16BIT; - info->chipwidth = FLASH_CFI_BY16; - info->interface = FLASH_CFI_X16; - return 1; -} diff --git a/board/mpl/vcma9/vcma9.h b/board/mpl/vcma9/vcma9.h deleted file mode 100644 index c585c8e..0000000 --- a/board/mpl/vcma9/vcma9.h +++ /dev/null @@ -1,28 +0,0 @@ -/* - * (C) Copyright 2002, 2003 - * David Mueller, ELSOFT AG, d.mueller@elsoft.ch - * - * SPDX-License-Identifier: GPL-2.0+ - */ - /**************************************************************************** - * Global routines used for VCMA9 - *****************************************************************************/ - -#include <asm/arch/s3c24x0_cpu.h> - -extern void vcma9_print_info(void); -extern int do_mplcommon(cmd_tbl_t *cmdtp, int flag, - int argc, char *const argv[]); - -/* VCMA9 PLD registers */ -enum vcma9_pld_regs { - VCMA9_PLD_ID, - VCMA9_PLD_NIC, - VCMA9_PLD_CAN, - VCMA9_PLD_MISC, - VCMA9_PLD_GPCD, - VCMA9_PLD_BOARD, - VCMA9_PLD_SDRAM -}; - -#define VCMA9_PLD_BASE (0x2C000100) diff --git a/configs/VCMA9_defconfig b/configs/VCMA9_defconfig deleted file mode 100644 index e464c21..0000000 --- a/configs/VCMA9_defconfig +++ /dev/null @@ -1,17 +0,0 @@ -CONFIG_ARM=y -CONFIG_TARGET_VCMA9=y -CONFIG_IDENT_STRING="\n(c) 2003 - 2011 by MPL AG Switzerland, MEV-10080-001 unstable" -CONFIG_BOOTDELAY=5 -CONFIG_HUSH_PARSER=y -CONFIG_SYS_PROMPT="VCMA9 # " -CONFIG_CMD_I2C=y -CONFIG_CMD_USB=y -# CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_DHCP=y -CONFIG_CMD_PING=y -CONFIG_CMD_CACHE=y -CONFIG_CMD_FAT=y -CONFIG_CMD_UBI=y -CONFIG_USB=y -CONFIG_USB_STORAGE=y -CONFIG_USB_KEYBOARD=y diff --git a/include/configs/VCMA9.h b/include/configs/VCMA9.h deleted file mode 100644 index bb26261..0000000 --- a/include/configs/VCMA9.h +++ /dev/null @@ -1,205 +0,0 @@ -/* - * (C) Copyright 2002, 2003 - * Sysgo Real-Time Solutions, GmbH <www.elinos.com> - * Marius Groeger mgroeger@sysgo.de - * Gary Jennejohn garyj@denx.de - * David Mueller d.mueller@elsoft.ch - * - * Configuation settings for the MPL VCMA9 board. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#ifndef __CONFIG_H -#define __CONFIG_H - -#define MACH_TYPE_MPL_VCMA9 227 - -/* - * High Level Configuration Options - * (easy to change) - */ -#define CONFIG_SYS_THUMB_BUILD - -#define CONFIG_S3C24X0 /* This is a SAMSUNG S3C24x0-type SoC */ -#define CONFIG_S3C2410 /* specifically a SAMSUNG S3C2410 SoC */ -#define CONFIG_VCMA9 /* on a MPL VCMA9 Board */ -#define CONFIG_MACH_TYPE MACH_TYPE_MPL_VCMA9 /* Machine type */ - -#define CONFIG_SYS_TEXT_BASE 0x0 - -#define CONFIG_SYS_ARM_CACHE_WRITETHROUGH - -/* input clock of PLL (VCMA9 has 12MHz input clock) */ -#define CONFIG_SYS_CLK_FREQ 12000000 - -#define CONFIG_CMDLINE_TAG /* enable passing of ATAGs */ -#define CONFIG_SETUP_MEMORY_TAGS -#define CONFIG_INITRD_TAG - -/* - * BOOTP options - */ -#define CONFIG_BOOTP_BOOTFILESIZE -#define CONFIG_BOOTP_BOOTPATH -#define CONFIG_BOOTP_GATEWAY -#define CONFIG_BOOTP_HOSTNAME - -/* - * Command line configuration. - */ -#define CONFIG_CMD_EEPROM -#define CONFIG_CMD_REGINFO -#define CONFIG_CMD_DATE -#define CONFIG_CMD_BSP -#define CONFIG_CMD_NAND - -#define CONFIG_BOARD_LATE_INIT - -#define CONFIG_CMDLINE_EDITING - -/* - * I2C stuff: - * the MPL VCMA9 is equipped with an ATMEL 24C256 EEPROM at - * address 0x50 with 16bit addressing - */ -#define CONFIG_SYS_I2C - -/* we use the built-in I2C controller */ -#define CONFIG_SYS_I2C_S3C24X0 -#define CONFIG_SYS_I2C_S3C24X0_SPEED 100000 /* I2C speed */ -#define CONFIG_SYS_I2C_S3C24X0_SLAVE 0x7F /* I2C slave addr */ - -#define CONFIG_SYS_I2C_EEPROM_ADDR 0x50 -#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 2 -/* use EEPROM for environment vars */ -#define CONFIG_ENV_IS_IN_EEPROM 1 -/* environment starts at offset 0 */ -#define CONFIG_ENV_OFFSET 0x000 -/* 2KB should be more than enough */ -#define CONFIG_ENV_SIZE 0x800 - -#undef CONFIG_SYS_I2C_EEPROM_ADDR_OVERFLOW -/* 64 bytes page write mode on 24C256 */ -#define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 6 -#define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 10 - -/* - * Hardware drivers - */ -#define CONFIG_CS8900 /* we have a CS8900 on-board */ -#define CONFIG_CS8900_BASE 0x20000300 -#define CONFIG_CS8900_BUS16 - -/* - * select serial console configuration - */ -#define CONFIG_S3C24X0_SERIAL -#define CONFIG_SERIAL1 1 /* we use SERIAL 1 on VCMA9 */ - -/* USB support (currently only works with D-cache off) */ -#define CONFIG_USB_OHCI -#define CONFIG_USB_OHCI_S3C24XX -#define CONFIG_DOS_PARTITION - -/* Enable needed helper functions */ - -/* RTC */ -#define CONFIG_RTC_S3C24X0 - -/* allow to overwrite serial and ethaddr */ -#define CONFIG_ENV_OVERWRITE - -#define CONFIG_BAUDRATE 9600 - -#define CONFIG_BOOT_RETRY_TIME -1 -#define CONFIG_RESET_TO_RETRY - -#define CONFIG_NETMASK 255.255.255.0 -#define CONFIG_IPADDR 10.0.0.110 -#define CONFIG_SERVERIP 10.0.0.1 - -#if defined(CONFIG_CMD_KGDB) -/* speed to run kgdb serial port */ -#define CONFIG_KGDB_BAUDRATE 115200 -#endif - -/* Miscellaneous configurable options */ -#define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_CBSIZE 256 -/* Print Buffer Size */ -#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) -#define CONFIG_SYS_MAXARGS 16 -/* Boot Argument Buffer Size */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE - -#define CONFIG_SYS_MEMTEST_START 0x30000000 /* memtest works on */ -#define CONFIG_SYS_MEMTEST_END 0x31FFFFFF /* 32 MB in DRAM */ - -#define CONFIG_SYS_ALT_MEMTEST -#define CONFIG_SYS_LOAD_ADDR 0x30800000 - -/* we configure PWM Timer 4 to 1ms 1000Hz */ - -/* support additional compression methods */ -#define CONFIG_BZIP2 -#define CONFIG_LZO -#define CONFIG_LZMA - -/* Physical Memory Map */ -#define CONFIG_NR_DRAM_BANKS 1 /* we have 1 bank of DRAM */ -#define PHYS_SDRAM_1 0x30000000 /* SDRAM Bank #1 */ -#define PHYS_FLASH_1 0x00000000 /* Flash Bank #1 */ - -#define CONFIG_SYS_FLASH_BASE PHYS_FLASH_1 - -/* FLASH and environment organization */ - -#define CONFIG_SYS_FLASH_CFI -#define CONFIG_FLASH_CFI_DRIVER -#define CONFIG_FLASH_CFI_LEGACY -#define CONFIG_SYS_FLASH_LEGACY_512Kx16 -#define CONFIG_FLASH_SHOW_PROGRESS 45 -#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* max number of memory banks */ -#define CONFIG_SYS_FLASH_BANKS_LIST { CONFIG_SYS_FLASH_BASE } -#define CONFIG_SYS_MAX_FLASH_SECT (19) - -/* - * Size of malloc() pool - * BZIP2 / LZO / LZMA need a lot of RAM - */ -#define CONFIG_SYS_MALLOC_LEN (4 * 1024 * 1024) -#define CONFIG_SYS_MONITOR_LEN (512 * 1024) -#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE - -/* NAND configuration */ -#ifdef CONFIG_CMD_NAND -#define CONFIG_NAND_S3C2410 -#define CONFIG_SYS_S3C2410_NAND_HWECC -#define CONFIG_SYS_MAX_NAND_DEVICE 1 -#define CONFIG_SYS_NAND_BASE 0x4E000000 -#define CONFIG_S3C24XX_CUSTOM_NAND_TIMING -#define CONFIG_S3C24XX_TACLS 1 -#define CONFIG_S3C24XX_TWRPH0 5 -#define CONFIG_S3C24XX_TWRPH1 3 -#endif - -#define MULTI_PURPOSE_SOCKET_ADDR 0x08000000 - -/* File system */ -#define CONFIG_CMD_UBIFS -#define CONFIG_CMD_JFFS2 -#define CONFIG_YAFFS2 -#define CONFIG_RBTREE -#define CONFIG_MTD_DEVICE /* needed for mtdparts commands */ -#define CONFIG_MTD_PARTITIONS -#define CONFIG_CMD_MTDPARTS -#define CONFIG_LZO - -#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 -#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_SDRAM_BASE + 0x1000 - \ - GENERATED_GBL_DATA_SIZE) - -#define CONFIG_BOARD_EARLY_INIT_F - -#endif /* __CONFIG_H */ diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index a573210..208c6e4 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -8229,7 +8229,6 @@ CONFIG_U_QE CONFIG_V38B CONFIG_VAL CONFIG_VAR_SIZE_SPL -CONFIG_VCMA9 CONFIG_VCO_HZ CONFIG_VCO_MULT CONFIG_VCT_NOR
On Sat, Nov 26, 2016 at 12:55 PM, David Müller (ELSOFT AG) d.mueller@elsoft.ch wrote:
Reviewed-by: Jagan Teki jagan@openedev.com
thanks!
Signed-off-by: Simon Glass sjg@chromium.org Acked-by: David Müller d.mueller@elsoft.ch Reviewed-by: Jagan Teki jagan@openedev.com
This is not used by any boards. Drop it.
doc/driver-model/serial-howto.txt | 1 - drivers/serial/Makefile | 1 - drivers/serial/serial_s3c24x0.c | 208 -------------------------------------- scripts/config_whitelist.txt | 1 - 4 files changed, 211 deletions(-) delete mode 100644 drivers/serial/serial_s3c24x0.c
diff --git a/doc/driver-model/serial-howto.txt b/doc/driver-model/serial-howto.txt index 3720274..a0df9a7 100644 --- a/doc/driver-model/serial-howto.txt +++ b/doc/driver-model/serial-howto.txt @@ -6,7 +6,6 @@ ones remain:
serial_bfin.c serial_pxa.c - serial_s3c24x0.c
The deadline for this work was the end of January 2016. If no one steps forward to convert these, at some point there may come a patch to remove them! diff --git a/drivers/serial/Makefile b/drivers/serial/Makefile index 21b1292..8430668 100644 --- a/drivers/serial/Makefile +++ b/drivers/serial/Makefile @@ -31,7 +31,6 @@ obj-$(CONFIG_MESON_SERIAL) += serial_meson.o ifdef CONFIG_SPL_BUILD obj-$(CONFIG_ROCKCHIP_SERIAL) += serial_rockchip.o endif -obj-$(CONFIG_S3C24X0_SERIAL) += serial_s3c24x0.o obj-$(CONFIG_XILINX_UARTLITE) += serial_xuartlite.o obj-$(CONFIG_SANDBOX_SERIAL) += sandbox.o obj-$(CONFIG_SCIF_CONSOLE) += serial_sh.o diff --git a/drivers/serial/serial_s3c24x0.c b/drivers/serial/serial_s3c24x0.c deleted file mode 100644 index 0f0878a..0000000 --- a/drivers/serial/serial_s3c24x0.c +++ /dev/null @@ -1,208 +0,0 @@ -/* - * (C) Copyright 2002 - * Gary Jennejohn, DENX Software Engineering, garyj@denx.de - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <linux/compiler.h> -#include <asm/arch/s3c24x0_cpu.h> - -DECLARE_GLOBAL_DATA_PTR; - -#ifdef CONFIG_SERIAL1 -#define UART_NR S3C24X0_UART0 - -#elif defined(CONFIG_SERIAL2) -#define UART_NR S3C24X0_UART1 - -#elif defined(CONFIG_SERIAL3) -#define UART_NR S3C24X0_UART2 - -#else -#error "Bad: you didn't configure serial ..." -#endif - -#include <asm/io.h> -#include <serial.h> - -/* Multi serial device functions */ -#define DECLARE_S3C_SERIAL_FUNCTIONS(port) \ - int s3serial##port##_init(void) \ - { \ - return serial_init_dev(port); \ - } \ - void s3serial##port##_setbrg(void) \ - { \ - serial_setbrg_dev(port); \ - } \ - int s3serial##port##_getc(void) \ - { \ - return serial_getc_dev(port); \ - } \ - int s3serial##port##_tstc(void) \ - { \ - return serial_tstc_dev(port); \ - } \ - void s3serial##port##_putc(const char c) \ - { \ - serial_putc_dev(port, c); \ - } \ - void s3serial##port##_puts(const char *s) \ - { \ - serial_puts_dev(port, s); \ - } - -#define INIT_S3C_SERIAL_STRUCTURE(port, __name) { \ - .name = __name, \ - .start = s3serial##port##_init, \ - .stop = NULL, \ - .setbrg = s3serial##port##_setbrg, \ - .getc = s3serial##port##_getc, \ - .tstc = s3serial##port##_tstc, \ - .putc = s3serial##port##_putc, \ - .puts = s3serial##port##_puts, \ -} - -static void _serial_setbrg(const int dev_index) -{ - struct s3c24x0_uart *uart = s3c24x0_get_base_uart(dev_index); - unsigned int reg = 0; - int i; - - /* value is calculated so : (int)(PCLK/16./baudrate) -1 */ - reg = get_PCLK() / (16 * gd->baudrate) - 1; - - writel(reg, &uart->ubrdiv); - for (i = 0; i < 100; i++) - /* Delay */ ; -} - -static inline void serial_setbrg_dev(unsigned int dev_index) -{ - _serial_setbrg(dev_index); -} - -/* Initialise the serial port. The settings are always 8 data bits, no parity, - * 1 stop bit, no start bits. - */ -static int serial_init_dev(const int dev_index) -{ - struct s3c24x0_uart *uart = s3c24x0_get_base_uart(dev_index); - - /* FIFO enable, Tx/Rx FIFO clear */ - writel(0x07, &uart->ufcon); - writel(0x0, &uart->umcon); - - /* Normal,No parity,1 stop,8 bit */ - writel(0x3, &uart->ulcon); - /* - * tx=level,rx=edge,disable timeout int.,enable rx error int., - * normal,interrupt or polling - */ - writel(0x245, &uart->ucon); - - _serial_setbrg(dev_index); - - return (0); -} - -/* - * Read a single byte from the serial port. Returns 1 on success, 0 - * otherwise. When the function is succesfull, the character read is - * written into its argument c. - */ -static int _serial_getc(const int dev_index) -{ - struct s3c24x0_uart *uart = s3c24x0_get_base_uart(dev_index); - - while (!(readl(&uart->utrstat) & 0x1)) - /* wait for character to arrive */ ; - - return readb(&uart->urxh) & 0xff; -} - -static inline int serial_getc_dev(unsigned int dev_index) -{ - return _serial_getc(dev_index); -} - -/* - * Output a single byte to the serial port. - */ -static void _serial_putc(const char c, const int dev_index) -{ - struct s3c24x0_uart *uart = s3c24x0_get_base_uart(dev_index); - - /* If \n, also do \r */ - if (c == '\n') - serial_putc('\r'); - - while (!(readl(&uart->utrstat) & 0x2)) - /* wait for room in the tx FIFO */ ; - - writeb(c, &uart->utxh); -} - -static inline void serial_putc_dev(unsigned int dev_index, const char c) -{ - _serial_putc(c, dev_index); -} - -/* - * Test whether a character is in the RX buffer - */ -static int _serial_tstc(const int dev_index) -{ - struct s3c24x0_uart *uart = s3c24x0_get_base_uart(dev_index); - - return readl(&uart->utrstat) & 0x1; -} - -static inline int serial_tstc_dev(unsigned int dev_index) -{ - return _serial_tstc(dev_index); -} - -static void _serial_puts(const char *s, const int dev_index) -{ - while (*s) { - _serial_putc(*s++, dev_index); - } -} - -static inline void serial_puts_dev(int dev_index, const char *s) -{ - _serial_puts(s, dev_index); -} - -DECLARE_S3C_SERIAL_FUNCTIONS(0); -struct serial_device s3c24xx_serial0_device = -INIT_S3C_SERIAL_STRUCTURE(0, "s3ser0"); -DECLARE_S3C_SERIAL_FUNCTIONS(1); -struct serial_device s3c24xx_serial1_device = -INIT_S3C_SERIAL_STRUCTURE(1, "s3ser1"); -DECLARE_S3C_SERIAL_FUNCTIONS(2); -struct serial_device s3c24xx_serial2_device = -INIT_S3C_SERIAL_STRUCTURE(2, "s3ser2"); - -__weak struct serial_device *default_serial_console(void) -{ -#if defined(CONFIG_SERIAL1) - return &s3c24xx_serial0_device; -#elif defined(CONFIG_SERIAL2) - return &s3c24xx_serial1_device; -#elif defined(CONFIG_SERIAL3) - return &s3c24xx_serial2_device; -#else -#error "CONFIG_SERIAL? missing." -#endif -} - -void s3c24xx_serial_initialize(void) -{ - serial_register(&s3c24xx_serial0_device); - serial_register(&s3c24xx_serial1_device); - serial_register(&s3c24xx_serial2_device); -} diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 208c6e4..6cb836e 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -3879,7 +3879,6 @@ CONFIG_S3C2410_NAND_BBT CONFIG_S3C2410_NAND_HWECC CONFIG_S3C2440 CONFIG_S3C24X0 -CONFIG_S3C24X0_SERIAL CONFIG_S3C24XX_CUSTOM_NAND_TIMING CONFIG_S3C24XX_TACLS CONFIG_S3C24XX_TWRPH0
thanks!
Jagan Teki
