[U-Boot] [PATCH v15] Introduced btrfs file-system with btrload command
Introduces btrfs file-system to read file from volume/sub-volumes with btrload command. This implementation has read-only support. This btrfs implementation is based on syslinux btrfs code.
v15: add $(PLATFORM_NO_UNALIGNED) to CFLAGS v14: Merge conflicts, makefile updates and do_load API changes v13: Added pre-calculated crc for BE & LE v11: Mirro super block check. v10: patch problem reworked. v5: merged with master. v4: btrls command added.
[port of syslinux commit 269ebc845ebc8b46ef4b0be7fa0005c7fdb95b8d]
Signed-off-by: Adnan Ali adnan.ali@codethink.co.uk Signed-off-by: Koen Kooi koen@dominion.thruhere.net ---
Slightly better:
U-Boot# btrls mmc 1:2 <DIR> root U-Boot# help btrls btrls - list files in a directory (default /)
Usage: btrls <interface> [<dev[:part]>] [directory] - list files from 'dev' on 'interface' in a 'directory' U-Boot# btrls mmc 1:2 /root/boot data abort
MAYBE you should read doc/README.arm-unaligned-accesses
pc : [<9f758534>] lr : [<9f77b51c>] sp : 9f628d80 ip : 000004f0 fp : 9f629618 r10: 00000014 r9 : 9f628f28 r8 : 9f629a40 r7 : 9f629948 r6 : 9ffba794 r5 : 9f79cd80 r4 : 69697073 r3 : 00697073 r2 : 00000069 r1 : 9f629918 r0 : 69697073 Flags: nzCv IRQs off FIQs on Mode SVC_32 Resetting CPU ...
reloc off = 0x1EF49000
[koen@rrmbp u-boot]$ arm-angstrom-linux-gnueabi-addr2line -f -e u-boot 0x8080F534 free /mnt/wwn-0x50004cf20775efdb-part2/u-boot/common/dlmalloc.c:2460
common/Makefile | 1 + common/cmd_btr.c | 65 +++ fs/Makefile | 1 + fs/btrfs/Makefile | 15 + fs/btrfs/btrfs.c | 1336 ++++++++++++++++++++++++++++++++++++++++++++ fs/fs.c | 10 + include/btrfs.h | 417 ++++++++++++++ include/config_fallbacks.h | 4 + include/crc.h | 5 + include/fs.h | 1 + lib/Makefile | 1 + lib/crc32_c.c | 108 ++++ 12 files changed, 1964 insertions(+) create mode 100644 common/cmd_btr.c create mode 100644 fs/btrfs/Makefile create mode 100644 fs/btrfs/btrfs.c create mode 100644 include/btrfs.h create mode 100644 lib/crc32_c.c
diff --git a/common/Makefile b/common/Makefile index 74404be..6025a12 100644 --- a/common/Makefile +++ b/common/Makefile @@ -57,6 +57,7 @@ obj-$(CONFIG_CMD_BMP) += cmd_bmp.o obj-$(CONFIG_CMD_BOOTMENU) += cmd_bootmenu.o obj-$(CONFIG_CMD_BOOTLDR) += cmd_bootldr.o obj-$(CONFIG_CMD_BOOTSTAGE) += cmd_bootstage.o +obj-$(CONFIG_CMD_BTR) += cmd_btr.o obj-$(CONFIG_CMD_CACHE) += cmd_cache.o obj-$(CONFIG_CMD_CBFS) += cmd_cbfs.o obj-$(CONFIG_CMD_CONSOLE) += cmd_console.o diff --git a/common/cmd_btr.c b/common/cmd_btr.c new file mode 100644 index 0000000..02a4bf1 --- /dev/null +++ b/common/cmd_btr.c @@ -0,0 +1,65 @@ +/* + * (C) Copyright 2013 Codethink Limited + * Btrfs port to Uboot by + * Adnan Ali adnan.ali@codethink.co.uk + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* + * Boot support + */ +#include <fs.h> +#include <btrfs.h> + +char subvolname[BTRFS_MAX_SUBVOL_NAME]; + +int do_btr_fsload(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + if (argc > 5) + strcpy(subvolname, argv[5]); + else + subvolname[0] = '\0'; + + return do_load(cmdtp, flag, argc, argv, FS_TYPE_BTR); +} + + +U_BOOT_CMD( +btrload, 7, 0, do_btr_fsload, + "load binary file from a btr filesystem", + "<interface> [<dev[:part]>] <addr> <filename> [subvol_name]\n" + " - Load binary file 'filename' from 'dev' on 'interface'\n" + " to address 'addr' from better filesystem.\n" + " the load stops on end of file.\n" + " subvol_name is used read that file from this subvolume.\n" + " All numeric parameters are assumed to be hex." +); + +static int do_btr_ls(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + return do_ls(cmdtp, flag, argc, argv, FS_TYPE_BTR); +} + +U_BOOT_CMD( + btrls, 4, 1, do_btr_ls, + "list files in a directory (default /)", + "<interface> [<dev[:part]>] [directory]\n" + " - list files from 'dev' on 'interface' in a 'directory'" +); + diff --git a/fs/Makefile b/fs/Makefile index 34dc035..a31bf70 100644 --- a/fs/Makefile +++ b/fs/Makefile @@ -22,4 +22,5 @@ obj-$(CONFIG_SANDBOX) += sandbox/ obj-$(CONFIG_CMD_UBIFS) += ubifs/ obj-$(CONFIG_YAFFS2) += yaffs2/ obj-$(CONFIG_CMD_ZFS) += zfs/ +obj-$(CONFIG_CMD_BTR) += btrfs/ endif diff --git a/fs/btrfs/Makefile b/fs/btrfs/Makefile new file mode 100644 index 0000000..80cdfd6 --- /dev/null +++ b/fs/btrfs/Makefile @@ -0,0 +1,15 @@ +# +# (C) Copyright 2006 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# (C) Copyright 2003 +# Pavel Bartusek, Sysgo Real-Time Solutions AG, pba@sysgo.de +# +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y := btrfs.o + +# SEE README.arm-unaligned-accesses +$(obj)btrfs.o: CFLAGS += $(PLATFORM_NO_UNALIGNED) diff --git a/fs/btrfs/btrfs.c b/fs/btrfs/btrfs.c new file mode 100644 index 0000000..f4dec57 --- /dev/null +++ b/fs/btrfs/btrfs.c @@ -0,0 +1,1336 @@ +/* + * (C) Copyright 2013 Codethink Limited + * Btrfs port to Uboot by + * Adnan Ali adnan.ali@codethink.co.uk + + * btrfs.c -- readonly btrfs support for syslinux + * Some data structures are derivated from btrfs-tools-0.19 ctree.h + * Copyright 2009 Intel Corporation; author: alek.du@intel.com + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation, Inc., 53 Temple Place Ste 330, + * Boston MA 02111-1307, USA; either version 2 of the License, or + * (at your option) any later version; incorporated herein by reference. + * + */ + +#include <malloc.h> +#include <common.h> +#include <btrfs.h> +#include <command.h> +#include <config.h> +#include <crc.h> +#include <fs.h> +#include <linux/compiler.h> +#include <linux/ctype.h> +#include <linux/stat.h> +#include <asm/byteorder.h> + +unsigned long btr_part_offset; +/* Actual file structures (we don't have malloc yet...) */ +struct file files[BTRFS_MAX_OPEN]; +static block_dev_desc_t *btrfs_block_dev_desc; +static disk_partition_t *part_info; +struct inode parent_inode; + +/* Bit-reflected CRC32C polynomial 0x82F63B78 */ + +static inline u32 crc32c_le(u32 crc, const char *data, size_t length) +{ + return crc32c_cal(crc, data, length); +} + +void btrfs_type(char num) +{ + switch (num) { + case BTRFS_FILE: + puts("<FILE> "); break; + case BTRFS_DIR: + puts("<DIR> "); break; + case BTRFS_SYMLNK: + puts("<SYM> "); break; + default: + puts("<UNKNOWN>"); break; + } +} + +static inline __le32 next_psector(__le32 psector, uint32_t skip) +{ + if (EXTENT_SPECIAL(psector)) + return psector; + else + return psector + skip; +} + +static inline __le32 next_pstart(const struct extent *e) +{ + return next_psector(e->pstart, e->len); +} + +static inline struct inode *get_inode(struct inode *inode) +{ + inode->refcnt++; + + return inode; +} + +/* compare function used for bin_search */ +typedef int (*cmp_func)(void *ptr1, void *ptr2); + +static int bin_search(void *ptr, int item_size, void *cmp_item, cmp_func func, + int min, int max, int *slot) +{ + int low = min; + int high = max; + int mid; + int ret; + unsigned long offset; + void *item; + + while (low < high) { + mid = (low + high) / 2; + offset = mid * item_size; + + item = ptr + offset; + ret = func(item, cmp_item); + + if (ret < 0) + low = mid + 1; + else if (ret > 0) + high = mid; + else { + *slot = mid; + return 0; + } + } + *slot = low; + + return 1; +} + +/* XXX: these should go into the filesystem instance structure */ +static struct btrfs_chunk_map chunk_map; +static struct btrfs_super_block sb; +static u64 fs_tree; +/* compare btrfs chunk map in list*/ +static int btrfs_comp_chunk_map(struct btrfs_chunk_map_item *m1, + struct btrfs_chunk_map_item *m2) +{ + if (__le64_to_cpu(m1->logical) > __le64_to_cpu(m2->logical)) + return 1; + + if (__le64_to_cpu(m1->logical) < __le64_to_cpu(m2->logical)) + return -1; + + return 0; +} + +/* insert a new chunk mapping item */ +static void insert_map(struct btrfs_chunk_map_item *item) +{ + int ret; + int slot; + int i; + + if (chunk_map.map == NULL) { /* first item */ + chunk_map.map_length = BTRFS_MAX_CHUNK_ENTRIES; + chunk_map.map = (struct btrfs_chunk_map_item *) + malloc(chunk_map.map_length * sizeof(*chunk_map.map)); + chunk_map.map[0] = *item; + chunk_map.cur_length = 1; + + return; + } + ret = bin_search(chunk_map.map, sizeof(*item), item, + (cmp_func)btrfs_comp_chunk_map, 0, + chunk_map.cur_length, &slot); + if (ret == 0)/* already in map */ + return; + + if (chunk_map.cur_length == BTRFS_MAX_CHUNK_ENTRIES) { + /* should be impossible */ + puts("too many chunk items\n"); + return; + } + for (i = chunk_map.cur_length; i > slot; i--) + chunk_map.map[i] = chunk_map.map[i-1]; + chunk_map.map[slot] = *item; + chunk_map.cur_length++; +} + +/* + * from sys_chunk_array or chunk_tree, we can convert a logical address to + * a physical address we can not support multi device case yet + */ +static u64 logical_physical(u64 logical) +{ + struct btrfs_chunk_map_item item; + int slot, ret; + + item.logical = logical; + ret = bin_search(chunk_map.map, sizeof(*chunk_map.map), &item, + (cmp_func)btrfs_comp_chunk_map, 0, + chunk_map.cur_length, &slot); + if (ret == 0) + slot++; + else if (slot == 0) + return -1; + + if (logical >= + chunk_map.map[slot-1].logical + chunk_map.map[slot-1].length) + return -1; + + return chunk_map.map[slot-1].physical + logical - + chunk_map.map[slot-1].logical; +} + +int btrfs_devread(int sector, int byte_offset, int byte_len, char *buf) +{ + ALLOC_CACHE_ALIGN_BUFFER(char, sec_buf, BTRFS_SS); + unsigned block_len; + + /* Get the read to the beginning of a partition */ + sector += byte_offset >> BTRFS_SECTOR_BITS; + byte_offset &= BTRFS_SS - 1; + + if (btrfs_block_dev_desc == NULL) { + puts("** Invalid Block Device Descriptor (NULL)\n"); + return 0; + } + if (byte_offset != 0) { + /* read first part which isn't aligned with start of sector */ + if (btrfs_block_dev_desc-> + block_read(btrfs_block_dev_desc->dev, + part_info->start + sector, 1, + (unsigned long *) sec_buf) != 1) { + puts(" ** btrfs_devread() read error **\n"); + return 0; + } + memcpy(buf, sec_buf + byte_offset, + min(BTRFS_SS - byte_offset, byte_len)); + buf += min(BTRFS_SS - byte_offset, byte_len); + byte_len -= min(BTRFS_SS - byte_offset, byte_len); + sector++; + } + /* read sector aligned part */ + + block_len = byte_len & ~(BTRFS_SS - 1); + + if (block_len == 0) { + ALLOC_CACHE_ALIGN_BUFFER(u8, p, BTRFS_SS); + + block_len = BTRFS_SS; + btrfs_block_dev_desc->block_read(btrfs_block_dev_desc->dev, + part_info->start + sector, + 1, (unsigned long *)p); + memcpy(buf, p, byte_len); + return 1; + } + ALLOC_CACHE_ALIGN_BUFFER(u8, t, block_len); + if (btrfs_block_dev_desc->block_read(btrfs_block_dev_desc->dev, + part_info->start + sector, + block_len / BTRFS_SS, + (unsigned long *) t) != + block_len / BTRFS_SS) { + debug(" ** %s read error - block\n", __func__); + return 0; + } + + memcpy(buf, t, block_len); + block_len = byte_len & ~(BTRFS_SS - 1); + buf += block_len; + byte_len -= block_len; + sector += block_len / BTRFS_SS; + if (byte_len != 0) { + /* read rest of data which are not in whole sector */ + if (btrfs_block_dev_desc-> + block_read(btrfs_block_dev_desc->dev, + part_info->start + sector, 1, + (unsigned long *) sec_buf) != 1) { + debug("* %s read error - last part\n", __func__); + return 0; + } + memcpy(buf, sec_buf, byte_len); + } + + return 1; +} +/* btrfs has several super block mirrors, need to calculate their location */ +static inline u64 btrfs_sb_offset(int mirror) +{ + u64 start = 16 * 1024; + + if (mirror) + return start << (BTRFS_SUPER_MIRROR_SHIFT * mirror); + + return BTRFS_SUPER_INFO_OFFSET; +} + +/* find the most recent super block */ +static int btrfs_read_super_block(struct btrfs_info *fs) +{ + int i; + u8 fsid[BTRFS_FSID_SIZE]; + u64 offset; + u64 transid = 0; + struct btrfs_super_block buf; + + sb.total_bytes = ~0; /* Unknown as of yet */ + + /* + * Only first header is checked for filesystem verification + * mirror of this header can be used if required + */ + /* find most recent super block */ + for (i = 0; i < BTRFS_SUPER_MIRROR_MAX; i++) { + + offset = btrfs_sb_offset(i); + if (offset >= sb.total_bytes) + break; + + if (btrfs_devread((offset/BTRFS_SS), 0, + sizeof(struct btrfs_super_block), + (char *)&buf) != 1) + return -1; + + if (buf.bytenr != offset || + strncmp((char *)(&buf.magic), + BTRFS_MAGIC, sizeof(buf.magic))) + return -1; + + if (i == 0) + memcpy(fsid, buf.fsid, sizeof(fsid)); + else if (memcmp(fsid, buf.fsid, sizeof(fsid))) { + puts("fsid doesn't match\n"); + return -1; + } + + if (buf.generation > transid) { + memcpy(&sb, &buf, sizeof(sb)); + transid = buf.generation; + } + } + + return 0; +} + +static inline unsigned long btrfs_chunk_item_size(int num_stripes) +{ + return sizeof(struct btrfs_chunk) + + sizeof(struct btrfs_stripe) * (num_stripes - 1); +} + +static void clear_path(struct btrfs_path *path) +{ + memset(path, 0, sizeof(*path)); +} + +static int btrfs_comp_keys(struct btrfs_disk_key *k1, struct btrfs_disk_key *k2) +{ + if (k1->objectid > k2->objectid) + return 1; + if (k1->objectid < k2->objectid) + return -1; + if (k1->type > k2->type) + return 1; + if (k1->type < k2->type) + return -1; + if (k1->offset > k2->offset) + return 1; + if (k1->offset < k2->offset) + return -1; + + return 0; +} + +/* compare keys but ignore offset, is useful to enumerate all same kind keys */ +static int btrfs_comp_keys_type(struct btrfs_disk_key *k1, + struct btrfs_disk_key *k2) +{ + if (k1->objectid > k2->objectid) + return 1; + if (k1->objectid < k2->objectid) + return -1; + if (k1->type > k2->type) + return 1; + if (k1->type < k2->type) + return -1; + + return 0; +} + +/* seach tree directly on disk ... */ +static int search_tree(struct btrfs_info *fs, u64 loffset, + struct btrfs_disk_key *key, struct btrfs_path *path) +{ + u8 buf[BTRFS_MAX_LEAF_SIZE]; + struct btrfs_header *header = (struct btrfs_header *)buf; + struct btrfs_node *node = (struct btrfs_node *)buf; + struct btrfs_leaf *leaf = (struct btrfs_leaf *)buf; + int slot, ret; + u64 offset; + + offset = logical_physical(loffset); + btrfs_devread(offset/BTRFS_SS, (offset%BTRFS_SS), + sizeof(*header), (char *)header); + if (header->level) { /*node*/ + btrfs_devread(((offset+sizeof(*header))/BTRFS_SS), + ((offset+sizeof(*header))%BTRFS_SS), + __le32_to_cpu(sb.nodesize) - sizeof(*header), + (char *)&node->ptrs[0]); + path->itemsnr[header->level] = header->nritems; + path->offsets[header->level] = loffset; + ret = bin_search(&node->ptrs[0], sizeof(struct btrfs_key_ptr), + key, (cmp_func)btrfs_comp_keys, + path->slots[header->level], header->nritems, &slot); + if (ret && slot > path->slots[header->level]) + slot--; + path->slots[header->level] = slot; + ret = search_tree(fs, node->ptrs[slot].blockptr, key, path); + } else { /*leaf*/ + btrfs_devread(((offset+sizeof(*header))/BTRFS_SS), + ((offset+sizeof(*header))%BTRFS_SS), + (sb.leafsize) - sizeof(*header), + (char *)&leaf->items); + path->itemsnr[header->level] = header->nritems; + path->offsets[0] = loffset; + ret = bin_search(&leaf->items[0], sizeof(struct btrfs_item), + key, (cmp_func)btrfs_comp_keys, path->slots[0], + header->nritems, &slot); + if (ret && slot > path->slots[header->level]) + slot--; + path->slots[0] = slot; + path->item = leaf->items[slot]; + btrfs_devread( + ((offset + sizeof(*header) + leaf->items[slot].offset) + /BTRFS_SS), + ((offset + sizeof(*header) + leaf->items[slot].offset) + %BTRFS_SS), + leaf->items[slot].size, (char *)&path->data); + } + + return ret; +} + +/* return 0 if leaf found */ +static int next_leaf(struct btrfs_info *fs, struct btrfs_disk_key *key, + struct btrfs_path *path) +{ + int slot; + int level = 1; + + while (level < BTRFS_MAX_LEVEL) { + if (!path->itemsnr[level]) /* no more nodes */ + return 1; + + slot = path->slots[level] + 1; + if (slot >= path->itemsnr[level]) { + level++; + continue; + } + path->slots[level] = slot; + path->slots[level-1] = 0; /* reset low level slots info */ + search_tree(fs, path->offsets[level], key, path); + break; + } + if (level == BTRFS_MAX_LEVEL) + return 1; + + return 0; +} + +/* return 0 if slot found */ +static int next_slot(struct btrfs_info *fs, struct btrfs_disk_key *key, + struct btrfs_path *path) +{ + int slot; + + if (!path->itemsnr[0]) + return 1; + + slot = path->slots[0] + 1; + if (slot >= path->itemsnr[0]) + return 1; + + path->slots[0] = slot; + search_tree(fs, path->offsets[0], key, path); + + return 0; +} + +/* + * read chunk_array in super block + */ +static void btrfs_read_sys_chunk_array(void) +{ + struct btrfs_chunk_map_item item; + struct btrfs_disk_key *key; + struct btrfs_chunk *chunk; + int cur; + + /* read chunk array in superblock */ + cur = 0; + + while (cur < __le32_to_cpu(sb.sys_chunk_array_size)) { + key = (struct btrfs_disk_key *)(sb.sys_chunk_array + cur); + cur += sizeof(*key); + chunk = (struct btrfs_chunk *)(sb.sys_chunk_array + cur); + cur += btrfs_chunk_item_size(chunk->num_stripes); + /* insert to mapping table, ignore multi stripes */ + item.logical = key->offset; + item.length = chunk->length; + item.devid = chunk->stripe.devid; + item.physical = chunk->stripe.offset;/*ignore other stripes */ + insert_map(&item); + } +} + +/* read chunk items from chunk_tree and insert them to chunk map */ +static void btrfs_read_chunk_tree(struct btrfs_info *fs) +{ + struct btrfs_disk_key search_key; + struct btrfs_chunk *chunk; + struct btrfs_chunk_map_item item; + struct btrfs_path path; + + if (!(__le64_to_cpu(sb.flags) & BTRFS_SUPER_FLAG_METADUMP)) { + if (__le64_to_cpu(sb.num_devices) > 1) { + debug("warning: only support one btrfs device %lld\n", + __le64_to_cpu(sb.num_devices)); + return; + } + /* read chunk from chunk_tree */ + search_key.objectid = BTRFS_FIRST_CHUNK_TREE_OBJECTID; + search_key.type = BTRFS_CHUNK_ITEM_KEY; + search_key.offset = 0; + clear_path(&path); + search_tree(fs, (sb.chunk_root), &search_key, &path); + do { + do { + if (btrfs_comp_keys_type(&search_key, + &path.item.key)) + break; + chunk = (struct btrfs_chunk *)(path.data); + /* insert to mapping table, ignore stripes */ + item.logical = path.item.key.offset; + item.length = chunk->length; + item.devid = chunk->stripe.devid; + item.physical = chunk->stripe.offset; + insert_map(&item); + } while (!next_slot(fs, &search_key, &path)); + if (btrfs_comp_keys_type(&search_key, &path.item.key)) + break; + } while (!next_leaf(fs, &search_key, &path)); + } +} + +static inline u64 btrfs_name_hash(const char *name, int len) +{ + return btrfs_crc32c((u32)~1, name, len); +} + +static struct inode *btrfs_iget_by_inr(struct btrfs_info *fs, u64 inr) +{ + struct inode *inode; + struct btrfs_inode_item *inode_item; + struct btrfs_disk_key search_key; + struct btrfs_path path; + struct btrfs_pvt_inode *pvt; + int ret; + + /* + *FIXME: some BTRFS inode member are u64, while our logical inode + *is u32, we may need change them to u64 later + */ + search_key.objectid = inr; + search_key.type = BTRFS_INODE_ITEM_KEY; + search_key.offset = 0; + clear_path(&path); + ret = search_tree(fs, fs_tree, &search_key, &path); + if (ret) { + debug("%s search_tree failed\n", __func__); + return NULL; + } + + inode_item = (struct btrfs_inode_item *)path.data; + inode = alloc_inode(fs, inr, sizeof(struct btrfs_pvt_inode)); + if (!(inode)) { + debug("%s alloc_inode failed\n", __func__); + return NULL; + } + inode->ino = inr; + inode->size = inode_item->size; + inode->mode = BTRFS_IFTODT(inode_item->mode); + if (inode->mode == BTRFS_DT_REG || inode->mode == BTRFS_DT_LNK) { + struct btrfs_file_extent_item *extent_item; + u64 offset; + + /* get file_extent_item */ + search_key.type = BTRFS_EXTENT_DATA_KEY; + search_key.offset = 0; + clear_path(&path); + ret = search_tree(fs, fs_tree, &search_key, &path); + if (ret) + return NULL; /* impossible */ + extent_item = (struct btrfs_file_extent_item *)path.data; + if (extent_item->type == BTRFS_FILE_EXTENT_INLINE) + offset = path.offsets[0] + sizeof(struct btrfs_header) + + path.item.offset + + offsetof(struct btrfs_file_extent_item, + disk_bytenr); + else + offset = extent_item->disk_bytenr; + pvt = (struct btrfs_pvt_inode *)inode->pvt; + pvt->offset = offset; + } + + return inode; +} + +static struct inode *btrfs_iget_root(struct btrfs_info *fs) +{ + /* BTRFS_FIRST_CHUNK_TREE_OBJECTID(256) actually + * is first OBJECTID for FS_TREE + */ + return btrfs_iget_by_inr(fs, BTRFS_FIRST_CHUNK_TREE_OBJECTID); +} + +static struct inode *btrfs_iget(const char *name, struct inode *parent) +{ + struct btrfs_info *fs = parent->fs; + struct btrfs_disk_key search_key; + struct btrfs_path path; + struct btrfs_dir_item dir_item; + int ret; + + search_key.objectid = parent->ino; + search_key.type = BTRFS_DIR_ITEM_KEY; + search_key.offset = btrfs_name_hash(name, strlen(name)); + clear_path(&path); + ret = search_tree(fs, fs_tree, &search_key, &path); + if (ret) + return NULL; + + dir_item = *(struct btrfs_dir_item *)path.data; + + return btrfs_iget_by_inr(fs, dir_item.location.objectid); +} + +static int btrfs_readlink(struct inode *inode, char *buf) +{ + struct btrfs_pvt_inode *pvt = (struct btrfs_pvt_inode *)inode->pvt; + btrfs_devread((logical_physical(pvt->offset)/BTRFS_SS), + (logical_physical(pvt->offset)%BTRFS_SS), + inode->size, (char *)buf); + buf[inode->size] = '\0'; + return inode->size; +} + +static int btrfs_readdir(struct file *file, struct btrfs_dirent *btrfs_dirent) +{ + struct btrfs_info *fs = file->fs; + struct inode *inode = file->inode; + struct btrfs_disk_key search_key; + struct btrfs_path path; + struct btrfs_dir_item *dir_item; + int ret; + + /* + * we use file->offset to store last search key.offset, will will search + * key that lower that offset, 0 means first search and we will search + * -1UL, which is the biggest possible key + */ + search_key.objectid = inode->ino; + search_key.type = BTRFS_DIR_ITEM_KEY; + search_key.offset = file->offset - 1; + clear_path(&path); + ret = search_tree(fs, fs_tree, &search_key, &path); + + if (ret) { + if (btrfs_comp_keys_type(&search_key, &path.item.key)) + return -1; + } + + dir_item = (struct btrfs_dir_item *)path.data; + file->offset = path.item.key.offset; + btrfs_dirent->d_ino = dir_item->location.objectid; + btrfs_dirent->d_off = file->offset; + btrfs_dirent->d_reclen = offsetof(struct btrfs_dirent, d_name) + + dir_item->name_len + 1; + btrfs_dirent->d_type = BTRFS_IFTODT(dir_item->type); + memcpy(btrfs_dirent->d_name, dir_item + 1, dir_item->name_len); + btrfs_dirent->d_name[dir_item->name_len] = '\0'; + btrfs_type(dir_item->type); + printf(" %s\n", btrfs_dirent->d_name); + + return 0; +} + +static int btrfs_next_extent(struct inode *inode, uint32_t lstart) +{ + struct btrfs_disk_key search_key; + struct btrfs_file_extent_item *extent_item; + struct btrfs_path path; + int ret; + u64 offset; + struct btrfs_info *fs = inode->fs; + struct btrfs_pvt_inode *pvt; + u32 sec_shift = BTRFS_SECTOR_BITS; + u32 sec_size = BTRFS_SS; + + search_key.objectid = inode->ino; + search_key.type = BTRFS_EXTENT_DATA_KEY; + search_key.offset = lstart << sec_shift; + clear_path(&path); + ret = search_tree(fs, fs_tree, &search_key, &path); + if (ret) { /* impossible */ + puts("btrfs: search extent data error\n"); + return -1; + } + extent_item = (struct btrfs_file_extent_item *)path.data; + + if (extent_item->encryption) { + puts("btrfs: found encrypted data, cannot continue\n"); + return -1; + } + if (extent_item->compression) { + puts("btrfs: found compressed data, cannot continue\n"); + return -1; + } + + if (extent_item->type == BTRFS_FILE_EXTENT_INLINE) {/* inline file */ + /* we fake a extent here, and PVT of inode will tell us */ + offset = path.offsets[0] + sizeof(struct btrfs_header) + + path.item.offset + + offsetof(struct btrfs_file_extent_item, disk_bytenr); + inode->next_extent.len = + (inode->size + sec_size - 1) >> sec_shift; + } else { + offset = extent_item->disk_bytenr + extent_item->offset; + inode->next_extent.len = + (extent_item->num_bytes + sec_size - 1) >> sec_shift; + } + inode->next_extent.pstart = + logical_physical(offset) >> sec_shift; + pvt = (struct btrfs_pvt_inode *)inode->pvt; + pvt->offset = offset; + return 0; +} + +static uint32_t btrfs_getfssec(struct file *file, char *buf, int sectors, + char *have_more) +{ + u32 ret; + struct btrfs_pvt_inode *pvt = + (struct btrfs_pvt_inode *)file->inode->pvt; + u32 off = pvt->offset % BTRFS_SS; + char handle_inline = 0; + + if (off && !file->offset) {/* inline file first read patch */ + file->inode->size += off; + handle_inline = 1; + } + ret = generic_getfssec(file, buf, sectors, have_more); + if (!ret) + return ret; + + off = pvt->offset % BTRFS_SS; + if (handle_inline) {/* inline file patch */ + ret -= off; + memcpy(buf, buf + off, ret); + } + + return ret; +} + +static void btrfs_get_fs_tree(struct btrfs_info *fs) +{ + struct btrfs_disk_key search_key; + struct btrfs_path path; + struct btrfs_root_item *tree; + char subvol_ok = 0; + + /* check if subvol is filled by installer */ + if (*subvolname) { + search_key.objectid = BTRFS_FS_TREE_OBJECTID; + search_key.type = BTRFS_ROOT_REF_KEY; + search_key.offset = 0; + clear_path(&path); + if (search_tree(fs, __le64_to_cpu(sb.root), &search_key, &path)) + next_slot(fs, &search_key, &path); + do { + do { + struct btrfs_root_ref *ref; + int pathlen; + + if (btrfs_comp_keys_type(&search_key, + &path.item.key)) + break; + ref = (struct btrfs_root_ref *)path.data; + pathlen = + path.item.size - sizeof(struct btrfs_root_ref); + + debug("sub_vol found %s\n", (char *)(ref+1)); + if (!strncmp((char *)(ref + 1), + subvolname, pathlen)) { + subvol_ok = 1; + break; + } + } while (!next_slot(fs, &search_key, &path)); + if (subvol_ok) + break; + if (btrfs_comp_keys_type(&search_key, &path.item.key)) + break; + } while (!next_leaf(fs, &search_key, &path)); + if (!subvol_ok) + puts("no subvol found\n"); + } + /* find fs_tree from tree_root */ + if (subvol_ok) + search_key.objectid = path.item.key.offset; + else /* "default" volume */ + search_key.objectid = BTRFS_FS_TREE_OBJECTID; + search_key.type = BTRFS_ROOT_ITEM_KEY; + search_key.offset = -1; + clear_path(&path); + search_tree(fs, (sb.root), &search_key, &path); + tree = (struct btrfs_root_item *)path.data; + fs_tree = tree->bytenr; +} + +/* init. the fs meta data, return the block size shift bits. */ +int btrfs_fs_init(struct btrfs_info *fs) +{ + btrfs_read_super_block(fs); + if (strncmp((char *)(&sb.magic), BTRFS_MAGIC, sizeof(sb.magic))) + return -1; + + btrfs_read_sys_chunk_array(); + btrfs_read_chunk_tree(fs); + btrfs_get_fs_tree(fs); + fs->root = btrfs_iget_root(fs); + parent_inode = *(fs->root); + + return 1; +} +static inline uint16_t file_to_handle(struct file *file) +{ + return file ? (file - files) + 1 : 0; +} + +static inline struct file *handle_to_file(uint16_t handle) +{ + return handle ? &files[handle - 1] : NULL; +} + +/* + * Free a refcounted inode + */ +void put_inode(struct inode *inode) +{ + while (inode && --inode->refcnt == 0) { + struct inode *dead = inode; + inode = inode->parent; + if (dead->name) + free((char *)dead->name); + free(dead); + } +} + +/* + * Get a new inode structure + */ +struct inode *alloc_inode(struct btrfs_info *fs, uint32_t ino, size_t data) +{ + struct inode *inode = malloc(sizeof(struct inode) + data); + + if (inode) { + inode->fs = fs; + inode->ino = ino; + inode->refcnt = 1; + } + + return inode; +} + +/* + * Get an empty file structure + */ +static struct file *alloc_file(void) +{ + int i; + struct file *file = files; + + for (i = 0; i < BTRFS_MAX_OPEN; i++) { + if (!file->fs) + return file; + + file++; + } + + return NULL; +} + +/* + * Close and free a file structure + */ +static inline void free_file(struct file *file) +{ + memset(file, 0, sizeof *file); +} + +void close_file(struct file *file) +{ + if (file->inode) { + file->offset = 0; + put_inode(file->inode); + } +} + +void btrfs_close_file(struct file *file) +{ + if (file->fs) + close_file(file); + free_file(file); +} + +void btrfs_mangle_name(char *dst, const char *src) +{ + char *p = dst, ch, len; + int i = BTRFS_FILENAME_MAX-1; + + len = strlen(src); + ch = *src; + while (!isspace(ch)) { + if (*src == '/') { + if (src[1] == '/') { + src++; + i--; + continue; + } + } + if (!len) + break; + i--; + len--; + *dst++ = *src++; + ch = *src; + } + while (1) { + if (dst == p) + break; + if (dst[-1] != '/') + break; + if ((dst[-1] == '/') && ((dst - 1) == p)) + break; + + dst--; + i++; + } + + i++; + for (; i > 0; i--) + *dst++ = '\0'; + +} + +int searchdir(const char *name) +{ + struct inode *inode = NULL; + struct inode *parent = &parent_inode; + struct file *file; + char *pathbuf = NULL; + char *part, *p, echar; + int symlink_count = BTRFS_MAX_SYMLINK_CNT; + + file = alloc_file(); + if (!(file)) + goto err_no_close; + + p = pathbuf = strdup(name); + if (!pathbuf) + goto err; + + do { +got_link: + if (*p == '/') { + put_inode(parent); + parent = &parent_inode; + } + + do { + inode = get_inode(parent); + + while (*p == '/') + p++; + + if (!*p) + break; + + part = p; + while ((echar = *p) && echar != '/') + p++; + *p++ = '\0'; + if (part[0] == '.' && part[1] == '.' && + part[2] == '\0') { + if (inode->parent) { + put_inode(parent); + parent = get_inode(inode->parent); + put_inode(inode); + inode = NULL; + if (!echar) { + /* Terminal double dots */ + inode = parent; + parent = inode->parent ? + get_inode(inode->parent) : NULL; + } + } + } else if (part[0] != '.' || part[1] != '\0') { + inode = btrfs_iget(part, parent); + if (!inode) + goto err; + if (inode->mode == BTRFS_DT_LNK) { + char *linkbuf, *q; + int name_len = echar ? strlen(p) : 0; + int total_len = inode->size + + name_len + 2; + int link_len; + + if (--symlink_count == 0 || + total_len > BTRFS_MAX_SYMLINK_BUF) + goto err; + + linkbuf = malloc(total_len); + if (!linkbuf) + goto err; + + link_len = + btrfs_readlink(inode, linkbuf); + if (link_len <= 0) { + free(linkbuf); + goto err; + } + + q = linkbuf + link_len; + + if (echar) { + if (link_len > 0 && + q[-1] != '/') + *q++ = '/'; + memcpy(q, p, name_len+1); + } else { + *q = '\0'; + } + + free(pathbuf); + p = pathbuf = linkbuf; + put_inode(inode); + inode = NULL; + goto got_link; + } + + inode->name = (u8 *)strdup(part); + + inode->parent = parent; + parent = NULL; + + if (!echar) + break; + + if (inode->mode != BTRFS_DT_DIR) + goto err; + + parent = inode; + inode = NULL; + } + } while (echar); + } while (0); + + free(pathbuf); + pathbuf = NULL; + put_inode(parent); + parent = NULL; + + if (!inode) + goto err; + + file->inode = inode; + file->offset = 0; + + return file_to_handle(file); + +err: + put_inode(inode); + put_inode(parent); + if (pathbuf != NULL) + free(pathbuf); + btrfs_close_file(file); +err_no_close: + return -1; +} + +int btrfs_open_file(const char *name, struct com32_filedata *filedata) +{ + int rv; + struct file *file; + char mangled_name[BTRFS_FILENAME_MAX]; + + btrfs_mangle_name(mangled_name, name); + rv = searchdir(mangled_name); + if (rv < 0) + return rv; + + file = handle_to_file(rv); + filedata->size = file->inode->size; + filedata->handle = rv; + + return rv; +} + +static void get_next_extent(struct inode *inode) +{ + /* The logical start address that we care about... */ + uint32_t lstart = inode->this_extent.lstart + inode->this_extent.len; + + if (btrfs_next_extent(inode, lstart)) + inode->next_extent.len = 0; /* ERROR */ + inode->next_extent.lstart = lstart; +} + +int getfssec(struct com32_filedata *filedata, char * buf) +{ + int sectors; + char have_more; + uint32_t bytes_read; + struct file *file; + if (filedata->size >= 512) { + sectors = filedata->size/BTRFS_SS; + sectors += (filedata->size%BTRFS_SS) ? 1 : 0; + } else + sectors = 2; + + file = handle_to_file(filedata->handle); + + bytes_read = btrfs_getfssec(file, buf, sectors, &have_more); + + return bytes_read; +} + +uint32_t generic_getfssec(struct file *file, char *buf, + int sectors, char *have_more) +{ + struct inode *inode = file->inode; + uint32_t bytes_read = 0; + uint32_t bytes_left = inode->size - file->offset; + uint32_t sectors_left = (bytes_left + BTRFS_SS - 1) >> 9; + uint32_t lsector; + + if (sectors > sectors_left) + sectors = sectors_left; + + if (!sectors) + return 0; + + lsector = file->offset >> 9; + + if (lsector < inode->this_extent.lstart || + lsector >= inode->this_extent.lstart + inode->this_extent.len) { + /* inode->this_extent unusable, maybe next_extent is... */ + inode->this_extent = inode->next_extent; + } + + if (lsector < inode->this_extent.lstart || + lsector >= inode->this_extent.lstart + inode->this_extent.len) { + /* Still nothing useful... */ + inode->this_extent.lstart = lsector; + inode->this_extent.len = 0; + } else { + /* We have some usable information */ + uint32_t delta = lsector - inode->this_extent.lstart; + inode->this_extent.lstart = lsector; + inode->this_extent.len -= delta; + inode->this_extent.pstart + = next_psector(inode->this_extent.pstart, delta); + } + + while (sectors) { + uint32_t chunk; + size_t len; + + while (sectors > inode->this_extent.len) { + if (!inode->next_extent.len || + inode->next_extent.lstart != + inode->this_extent.lstart + + inode->this_extent.len) + get_next_extent(inode); + if (!inode->this_extent.len) { + /* Doesn't matter if it's contiguous... */ + inode->this_extent = inode->next_extent; + if (!inode->next_extent.len) { + sectors = 0; /* Failed to get anything*/ + break; + } + } else if (inode->next_extent.len && + inode->next_extent.pstart == + next_pstart(&inode->this_extent)) { + /* Coalesce extents and loop */ + inode->this_extent.len += + inode->next_extent.len; + } else { + /* Discontiguous extents */ + break; + } + } + + chunk = min(sectors, inode->this_extent.len); + len = chunk << 9; + + if (inode->this_extent.pstart == BTRFS_EXTENT_ZERO) { + memset(buf, 0, len); + } else { + btrfs_block_dev_desc->block_read( + btrfs_block_dev_desc->dev, part_info->start + + (inode->this_extent.pstart), chunk, buf); + inode->this_extent.pstart += chunk; + } + + buf += len; + sectors -= chunk; + bytes_read += len; + inode->this_extent.lstart += chunk; + inode->this_extent.len -= chunk; + } + + bytes_read = min(bytes_read, bytes_left); + file->offset += bytes_read; + + if (have_more) + *have_more = bytes_read < bytes_left; + + return bytes_read; +} + +/* + * Open a directory + */ +struct _DIR_ *opendir(const char *path) +{ + int rv; + struct file *file; + rv = searchdir(path); + if (rv < 0) + return NULL; + + file = handle_to_file(rv); + + if (file->inode->mode != BTRFS_DT_DIR) { + btrfs_close_file(file); + return NULL; + } + + return (struct _DIR_ *)file; +} + +/* + * Read one directory entry at one time + */ +struct btrfs_dirent *readdir(struct _DIR_ *dir) +{ + static struct btrfs_dirent buf; + struct file *dd_dir = (struct file *)dir; + int rv = -1; + + if (dd_dir) + rv = btrfs_readdir(dd_dir, &buf); + + return rv < 0 ? NULL : &buf; +} + +/* + * Btrfs file-system Interface + * + */ + +struct btrfs_info fs; + +/* + * mount btrfs file-system + */ +int btrfs_probe(block_dev_desc_t *rbdd, disk_partition_t *info) +{ + btrfs_block_dev_desc = rbdd; + part_info = info; + btr_part_offset = info->start; + if (btrfs_fs_init(&fs) < 0) { + puts("btrfs probe failed\n"); + return -1; + } + + return 0; +} + +/* + * Read file data + */ +int btrfs_read_file(const char *filename, void *buf, int offset, int len) +{ + int file_len = 0; + int len_read; + struct com32_filedata filedata; + int handle; + if (offset != 0) { + puts("** Cannot support non-zero offset **\n"); + return -1; + } + + handle = btrfs_open_file(filename, &filedata); + if (handle < 0) { + debug("** File not found %s Invalid handle**\n", filename); + return -1; + } + + /*file handle is valid get the size of the file*/ + len = filedata.size; + if (len == 0) + len = file_len; + + len_read = getfssec(&filedata, (char *)buf); + if (len_read != len) { + debug("** Unable to read file %s **\n", filename); + return -1; + } + + return len_read; +} + +/* + * Show directory entries + */ +int btrfs_ls(const char *dirn) +{ + struct btrfs_dirent *de; + char *dirname = (char *)dirn; + struct _DIR_ *dir; + + if (*dirname == '/' && *(dirname+1) == 0) + *dirname = '.'; + + dir = opendir(dirname); + if (dir == NULL) + return -1; + + /* readdir prints contents on media*/ + de = readdir(dir); + while (de != NULL) + de = readdir(dir); + + return 0; +} + +/* + * umount btrfs file-system + */ +void btrfs_close(void) +{ +} diff --git a/fs/fs.c b/fs/fs.c index be1855d..3bca04c 100644 --- a/fs/fs.c +++ b/fs/fs.c @@ -17,6 +17,7 @@ #include <config.h> #include <common.h> #include <part.h> +#include <btrfs.h> #include <ext4fs.h> #include <fat.h> #include <fs.h> @@ -96,6 +97,15 @@ static struct fstype_info fstypes[] = { .write = fs_write_sandbox, }, #endif +#ifdef CONFIG_FS_BTR + { + .fstype = FS_TYPE_BTR, + .probe = btrfs_probe, + .close = btrfs_close, + .ls = btrfs_ls, + .read = btrfs_read_file, + }, +#endif { .fstype = FS_TYPE_ANY, .probe = fs_probe_unsupported, diff --git a/include/btrfs.h b/include/btrfs.h new file mode 100644 index 0000000..6246670 --- /dev/null +++ b/include/btrfs.h @@ -0,0 +1,417 @@ +#ifndef _BTRFS_H_ +#define _BTRFS_H_ + +#include <asm/byteorder.h> +/* type that store on disk, but it is same as cpu type for i386 arch */ + +#define BTRFS_CURRENTDIR_MAX 15 +#define BTRFS_MAX_OPEN 5 +#define BTRFS_FILENAME_MAX 20 +#define BTRFS_MAX_SYMLINK_CNT 20 +#define BTRFS_MAX_SYMLINK_BUF 4096 +#define BTRFS_SECTOR_SHIFT(fs) ((fs)->sector_shift) +#define BTRFS_IFTODT(mode) (((mode) & 0170000) >> 12) +#define BTRFS_SECTOR_SIZE 0x200 +#define BTRFS_SECTOR_BITS 9 +#define BTRFS_EXTENT_ZERO ((uint32_t)-1) /* All-zero extent */ +#define BTRFS_EXTENT_VOID ((uint32_t)-2) /* Invalid information */ +#define BTRFS_DT_LNK 10 +#define BTRFS_DT_REG 8 +#define BTRFS_DT_DIR 4 +#define EXTENT_SPECIAL(x) ((x) >= BTRFS_EXTENT_VOID) +#define BTRFS_MAX_SUBVOL_NAME 50 + +#define BTRFS_FILE 1 +#define BTRFS_DIR 2 +#define BTRFS_SYMLNK 7 +#define BTRFS_SS BTRFS_SECTOR_SIZE + +extern char subvolname[BTRFS_MAX_SUBVOL_NAME]; +struct _DIR_; + +struct com32_filedata { + size_t size; /* File size */ + int blocklg2; /* log2(block size) */ + uint16_t handle; /* File handle */ +}; + +struct btrfs_info { + const struct fs_ops *fs_ops; + struct device *fs_dev; + void *btrfs_info; /* The fs-specific information */ + int sector_shift, sector_size; + int block_shift, block_size; + struct inode *root, *cwd; /* Root and current directories */ + char cwd_name[BTRFS_CURRENTDIR_MAX]; /* Current directory by name */ +}; +/* + * Extent structure: contains the mapping of some chunk of a file + * that is contiguous on disk. + */ +struct extent { + uint64_t pstart; + uint32_t lstart; /* Logical start sector */ + uint32_t len; /* Number of contiguous sectors */ +} __packed; + + +struct inode { + struct btrfs_info *fs; /* The filesystem inode is associated with */ + struct inode *parent; /* Parent directory, if any */ + const u8 *name; /* Name, valid for generic path search only */ + uint32_t refcnt; + uint32_t mode; /* FILE , DIR or SYMLINK */ + uint32_t size; + uint32_t blocks; /* How many blocks the file take */ + uint32_t ino; /* Inode number */ + uint32_t atime; /* Access time */ + uint32_t mtime; /* Modify time */ + uint32_t ctime; /* Create time */ + uint32_t dtime; /* Delete time */ + uint32_t flags; + uint32_t file_acl; + struct extent this_extent, next_extent; + u8 pvt[0]; /* Private filesystem data */ +} __packed; +struct file { + struct btrfs_info *fs; + uint64_t offset; /* for next read */ + struct inode *inode; /* The file-specific information */ +} __packed; + +#define NAME_MAX 20 +struct btrfs_dirent { + uint32_t d_ino; + uint32_t d_off; + uint16_t d_reclen; + uint16_t d_type; + char d_name[NAME_MAX + 1]; +}; + +#define btrfs_crc32c crc32c_le + +#define BTRFS_SUPER_INFO_OFFSET (64 * 1024) +#define BTRFS_SUPER_INFO_SIZE 4096 +#define BTRFS_MAX_LEAF_SIZE 4096 +#define BTRFS_BLOCK_SHIFT 12 + +#define BTRFS_SUPER_MIRROR_MAX 3 +#define BTRFS_SUPER_MIRROR_SHIFT 12 +#define BTRFS_CSUM_SIZE 32 +#define BTRFS_FSID_SIZE 16 +#define BTRFS_LABEL_SIZE 256 +#define BTRFS_SYSTEM_CHUNK_ARRAY_SIZE 2048 +#define BTRFS_UUID_SIZE 16 + +#define BTRFS_MAGIC "_BHRfS_M" + +#define BTRFS_SUPER_FLAG_METADUMP (1ULL << 33) + +#define BTRFS_DEV_ITEM_KEY 216 +#define BTRFS_CHUNK_ITEM_KEY 228 +#define BTRFS_ROOT_REF_KEY 156 +#define BTRFS_ROOT_ITEM_KEY 132 +#define BTRFS_EXTENT_DATA_KEY 108 +#define BTRFS_DIR_ITEM_KEY 84 +#define BTRFS_INODE_ITEM_KEY 1 + +#define BTRFS_EXTENT_TREE_OBJECTID 2ULL +#define BTRFS_FS_TREE_OBJECTID 5ULL + +#define BTRFS_FIRST_CHUNK_TREE_OBJECTID 256ULL + +#define BTRFS_FILE_EXTENT_INLINE 0 +#define BTRFS_FILE_EXTENT_REG 1 +#define BTRFS_FILE_EXTENT_PREALLOC 2 + +#define BTRFS_MAX_LEVEL 8 +#define BTRFS_MAX_CHUNK_ENTRIES 256 + +#define BTRFS_FT_REG_FILE 1 +#define BTRFS_FT_DIR 2 +#define BTRFS_FT_SYMLINK 7 + +#define ROOT_DIR_WORD 0x002f + +struct btrfs_dev_item { + uint64_t devid; + uint64_t total_bytes; + uint64_t bytes_used; + uint32_t io_align; + uint32_t io_width; + uint32_t sector_size; + uint64_t type; + uint64_t generation; + uint64_t start_offset; + uint32_t dev_group; + u8 seek_speed; + u8 bandwidth; + u8 uuid[BTRFS_UUID_SIZE]; + u8 fsid[BTRFS_UUID_SIZE]; +} __packed; + +struct btrfs_super_block { + u8 csum[BTRFS_CSUM_SIZE]; + /* the first 4 fields must match struct btrfs_header */ + u8 fsid[BTRFS_FSID_SIZE]; /* FS specific uuid */ + uint64_t bytenr; /* this block number */ + uint64_t flags; + + /* allowed to be different from the btrfs_header from here own down */ + uint64_t magic; + uint64_t generation; + uint64_t root; + uint64_t chunk_root; + uint64_t log_root; + + /* this will help find the new super based on the log root */ + uint64_t log_root_transid; + uint64_t total_bytes; + uint64_t bytes_used; + uint64_t root_dir_objectid; + uint64_t num_devices; + uint32_t sectorsize; + uint32_t nodesize; + uint32_t leafsize; + uint32_t stripesize; + uint32_t sys_chunk_array_size; + uint64_t chunk_root_generation; + uint64_t compat_flags; + uint64_t compat_ro_flags; + uint64_t incompat_flags; + __le16 csum_type; + u8 root_level; + u8 chunk_root_level; + u8 log_root_level; + struct btrfs_dev_item dev_item; + + char label[BTRFS_LABEL_SIZE]; + + uint64_t cache_generation; + + /* future expansion */ + uint64_t reserved[31]; + u8 sys_chunk_array[BTRFS_SYSTEM_CHUNK_ARRAY_SIZE]; +} __packed; + +struct btrfs_disk_key { + uint64_t objectid; + u8 type; + uint64_t offset; +} __packed; + +struct btrfs_stripe { + uint64_t devid; + uint64_t offset; + u8 dev_uuid[BTRFS_UUID_SIZE]; +} __packed; + +struct btrfs_chunk { + uint64_t length; + uint64_t owner; + uint64_t stripe_len; + uint64_t type; + uint32_t io_align; + uint32_t io_width; + uint32_t sector_size; + __le16 num_stripes; + __le16 sub_stripes; + struct btrfs_stripe stripe; +} __packed; + +struct btrfs_header { + /* these first four must match the super block */ + u8 csum[BTRFS_CSUM_SIZE]; + u8 fsid[BTRFS_FSID_SIZE]; /* FS specific uuid */ + uint64_t bytenr; /* which block this node is supposed to live in */ + uint64_t flags; + + /* allowed to be different from the super from here on down */ + u8 chunk_tree_uuid[BTRFS_UUID_SIZE]; + uint64_t generation; + uint64_t owner; + uint32_t nritems; + u8 level; +} __packed; + +struct btrfs_item { + struct btrfs_disk_key key; + uint32_t offset; + uint32_t size; +} __packed; + +struct btrfs_leaf { + struct btrfs_header header; + struct btrfs_item items[]; +} __packed; + +struct btrfs_key_ptr { + struct btrfs_disk_key key; + uint64_t blockptr; + uint64_t generation; +} __packed; + +struct btrfs_node { + struct btrfs_header header; + struct btrfs_key_ptr ptrs[]; +} __packed; + +/* remember how we get to a node/leaf */ +struct btrfs_path { + uint64_t offsets[BTRFS_MAX_LEVEL]; + uint32_t itemsnr[BTRFS_MAX_LEVEL]; + uint32_t slots[BTRFS_MAX_LEVEL]; + /* remember last slot's item and data */ + struct btrfs_item item; + u32 data[BTRFS_MAX_LEAF_SIZE]; +}; + +/* store logical offset to physical offset mapping */ +struct btrfs_chunk_map_item { + uint64_t logical; + uint64_t length; + uint64_t devid; + uint64_t physical; +}; + +struct btrfs_chunk_map { + struct btrfs_chunk_map_item *map; + uint32_t map_length; + uint32_t cur_length; +}; + +struct btrfs_timespec { + uint64_t sec; + uint32_t nsec; +} __packed; + +struct btrfs_inode_item { + /* nfs style generation number */ + uint64_t generation; + /* transid that last touched this inode */ + uint64_t transid; + uint64_t size; + uint64_t nbytes; + uint64_t block_group; + uint32_t nlink; + uint32_t uid; + uint32_t gid; + uint32_t mode; + uint64_t rdev; + uint64_t flags; + + /* modification sequence number for NFS */ + uint64_t sequence; + + /* + * a little future expansion, for more than this we can + * just grow the inode item and version it + */ + uint64_t reserved[4]; + struct btrfs_timespec atime; + struct btrfs_timespec ctime; + struct btrfs_timespec mtime; + struct btrfs_timespec otime; +} __packed; + +struct btrfs_root_item { + struct btrfs_inode_item inode; + uint64_t generation; + uint64_t root_dirid; + uint64_t bytenr; + uint64_t byte_limit; + uint64_t bytes_used; + uint64_t last_snapshot; + uint64_t flags; + uint32_t refs; + struct btrfs_disk_key drop_progress; + u8 drop_level; + u8 level; +} __packed; + +struct btrfs_dir_item { + struct btrfs_disk_key location; + uint64_t transid; + __le16 data_len; + __le16 name_len; + u8 type; +} __packed; + +struct btrfs_file_extent_item { + uint64_t generation; + uint64_t ram_bytes; + u8 compression; + u8 encryption; + __le16 other_encoding; /* spare for later use */ + u8 type; + uint64_t disk_bytenr; + uint64_t disk_num_bytes; + uint64_t offset; + uint64_t num_bytes; +} __packed; + +struct btrfs_root_ref { + uint64_t dirid; + uint64_t sequence; + __le16 name_len; +} __packed; + +/* + * btrfs private inode information + */ +struct btrfs_pvt_inode { + uint64_t offset; +}; + + +int btrfs_probe(block_dev_desc_t *rbdd , disk_partition_t *info); + +/* + *search through disk and mount file-system + */ +int btrfs_fs_init(struct btrfs_info *fs); + +/* + *save inode in list + */ +void put_inode(struct inode *inode); + +/* + *memory allocation for new inode + */ +struct inode *alloc_inode(struct btrfs_info *fs, uint32_t ino, size_t data); + +/* + * open btrfs file + */ +int btrfs_open_file(const char *name, struct com32_filedata *filedata); +/* + * reading data from file + */ +int getfssec(struct com32_filedata *filedata, char *buf); +uint32_t generic_getfssec(struct file *file, char *buf, + int sectors, char *have_more); + +/* + * mount btrfs file-system + */ +int btrfs_probe(block_dev_desc_t *rbdd , disk_partition_t *info); + +/* + * listing file/directory on btrfs partition/disk + */ +int btrfs_ls(const char *); + +/* + * read file data + */ +int btrfs_read_file(const char *filename, void *buf, int offset, int len); + +/* + * umount btrfs file-system + */ +void btrfs_close(void); + +#define PVT(i) ((struct btrfs_pvt_inode *)((i)->pvt)) + +#endif diff --git a/include/config_fallbacks.h b/include/config_fallbacks.h index 3633b09..daa99c6 100644 --- a/include/config_fallbacks.h +++ b/include/config_fallbacks.h @@ -42,6 +42,10 @@ #define CONFIG_EXT4_WRITE #endif
+#if defined(CONFIG_CMD_BTR) && !defined(CONFIG_FS_BTR) +#define CONFIG_FS_BTR +#endif + /* Rather than repeat this expression each time, add a define for it */ #if defined(CONFIG_CMD_IDE) || \ defined(CONFIG_CMD_SATA) || \ diff --git a/include/crc.h b/include/crc.h index 5085d4e..216a172 100644 --- a/include/crc.h +++ b/include/crc.h @@ -66,4 +66,9 @@ cyg_ether_crc32_accumulate(uint32_t crc, unsigned char *s, int len);
extern uint16_t cyg_crc16(unsigned char *s, int len);
+ +/* CRC calculate for btrfs file-system*/ + +u32 crc32c_cal(u32 crc, const char *data, size_t length); + #endif /* _SERVICES_CRC_CRC_H_ */ diff --git a/include/fs.h b/include/fs.h index 7d9403e..a4192ab 100644 --- a/include/fs.h +++ b/include/fs.h @@ -22,6 +22,7 @@ #define FS_TYPE_FAT 1 #define FS_TYPE_EXT 2 #define FS_TYPE_SANDBOX 3 +#define FS_TYPE_BTR 4
/* * Tell the fs layer which block device an partition to use for future diff --git a/lib/Makefile b/lib/Makefile index e787f77..5d17656 100644 --- a/lib/Makefile +++ b/lib/Makefile @@ -51,6 +51,7 @@ obj-y += errno.o obj-y += display_options.o obj-$(CONFIG_BCH) += bch.o obj-y += crc32.o +obj-y += crc32_c.o obj-y += ctype.o obj-y += div64.o obj-y += hang.o diff --git a/lib/crc32_c.c b/lib/crc32_c.c new file mode 100644 index 0000000..a6bc17d --- /dev/null +++ b/lib/crc32_c.c @@ -0,0 +1,108 @@ +/* + * Copied from Linux kernel crypto/crc32c.c + * Copyright (c) 2004 Cisco Systems, Inc. + * Copyright (c) 2008 Herbert Xu herbert@gondor.apana.org.au + * + * This program is free software; you can redistribute it and/or modify it + * under the terms of the GNU General Public License as published by the Free + * Software Foundation; either version 2 of the License, or (at your option) + * any later version. + * + */ +#include <linux/stat.h> +#include <command.h> +#include <asm/byteorder.h> +#include <linux/compiler.h> +#include <common.h> +#include <config.h> + +#if defined(CONFIG_HW_WATCHDOG) || defined(CONFIG_WATCHDOG) +#include <watchdog.h> +#endif +#include <u-boot/crc.h> + +#define __BYTE_ORDER __LITTLE_ENDIAN + +static const uint32_t crc32c_table[256] = { + (0x00000000), (0xf26b8303), (0xe13b70f7), (0x1350f3f4), + (0xc79a971f), (0x35f1141c), (0x26a1e7e8), (0xd4ca64eb), + (0x8ad958cf), (0x78b2dbcc), (0x6be22838), (0x9989ab3b), + (0x4d43cfd0), (0xbf284cd3), (0xac78bf27), (0x5e133c24), + (0x105ec76f), (0xe235446c), (0xf165b798), (0x030e349b), + (0xd7c45070), (0x25afd373), (0x36ff2087), (0xc494a384), + (0x9a879fa0), (0x68ec1ca3), (0x7bbcef57), (0x89d76c54), + (0x5d1d08bf), (0xaf768bbc), (0xbc267848), (0x4e4dfb4b), + (0x20bd8ede), (0xd2d60ddd), (0xc186fe29), (0x33ed7d2a), + (0xe72719c1), (0x154c9ac2), (0x061c6936), (0xf477ea35), + (0xaa64d611), (0x580f5512), (0x4b5fa6e6), (0xb93425e5), + (0x6dfe410e), (0x9f95c20d), (0x8cc531f9), (0x7eaeb2fa), + (0x30e349b1), (0xc288cab2), (0xd1d83946), (0x23b3ba45), + (0xf779deae), (0x05125dad), (0x1642ae59), (0xe4292d5a), + (0xba3a117e), (0x4851927d), (0x5b016189), (0xa96ae28a), + (0x7da08661), (0x8fcb0562), (0x9c9bf696), (0x6ef07595), + (0x417b1dbc), (0xb3109ebf), (0xa0406d4b), (0x522bee48), + (0x86e18aa3), (0x748a09a0), (0x67dafa54), (0x95b17957), + (0xcba24573), (0x39c9c670), (0x2a993584), (0xd8f2b687), + (0x0c38d26c), (0xfe53516f), (0xed03a29b), (0x1f682198), + (0x5125dad3), (0xa34e59d0), (0xb01eaa24), (0x42752927), + (0x96bf4dcc), (0x64d4cecf), (0x77843d3b), (0x85efbe38), + (0xdbfc821c), (0x2997011f), (0x3ac7f2eb), (0xc8ac71e8), + (0x1c661503), (0xee0d9600), (0xfd5d65f4), (0x0f36e6f7), + (0x61c69362), (0x93ad1061), (0x80fde395), (0x72966096), + (0xa65c047d), (0x5437877e), (0x4767748a), (0xb50cf789), + (0xeb1fcbad), (0x197448ae), (0x0a24bb5a), (0xf84f3859), + (0x2c855cb2), (0xdeeedfb1), (0xcdbe2c45), (0x3fd5af46), + (0x7198540d), (0x83f3d70e), (0x90a324fa), (0x62c8a7f9), + (0xb602c312), (0x44694011), (0x5739b3e5), (0xa55230e6), + (0xfb410cc2), (0x092a8fc1), (0x1a7a7c35), (0xe811ff36), + (0x3cdb9bdd), (0xceb018de), (0xdde0eb2a), (0x2f8b6829), + (0x82f63b78), (0x709db87b), (0x63cd4b8f), (0x91a6c88c), + (0x456cac67), (0xb7072f64), (0xa457dc90), (0x563c5f93), + (0x082f63b7), (0xfa44e0b4), (0xe9141340), (0x1b7f9043), + (0xcfb5f4a8), (0x3dde77ab), (0x2e8e845f), (0xdce5075c), + (0x92a8fc17), (0x60c37f14), (0x73938ce0), (0x81f80fe3), + (0x55326b08), (0xa759e80b), (0xb4091bff), (0x466298fc), + (0x1871a4d8), (0xea1a27db), (0xf94ad42f), (0x0b21572c), + (0xdfeb33c7), (0x2d80b0c4), (0x3ed04330), (0xccbbc033), + (0xa24bb5a6), (0x502036a5), (0x4370c551), (0xb11b4652), + (0x65d122b9), (0x97baa1ba), (0x84ea524e), (0x7681d14d), + (0x2892ed69), (0xdaf96e6a), (0xc9a99d9e), (0x3bc21e9d), + (0xef087a76), (0x1d63f975), (0x0e330a81), (0xfc588982), + (0xb21572c9), (0x407ef1ca), (0x532e023e), (0xa145813d), + (0x758fe5d6), (0x87e466d5), (0x94b49521), (0x66df1622), + (0x38cc2a06), (0xcaa7a905), (0xd9f75af1), (0x2b9cd9f2), + (0xff56bd19), (0x0d3d3e1a), (0x1e6dcdee), (0xec064eed), + (0xc38d26c4), (0x31e6a5c7), (0x22b65633), (0xd0ddd530), + (0x0417b1db), (0xf67c32d8), (0xe52cc12c), (0x1747422f), + (0x49547e0b), (0xbb3ffd08), (0xa86f0efc), (0x5a048dff), + (0x8ecee914), (0x7ca56a17), (0x6ff599e3), (0x9d9e1ae0), + (0xd3d3e1ab), (0x21b862a8), (0x32e8915c), (0xc083125f), + (0x144976b4), (0xe622f5b7), (0xf5720643), (0x07198540), + (0x590ab964), (0xab613a67), (0xb831c993), (0x4a5a4a90), + (0x9e902e7b), (0x6cfbad78), (0x7fab5e8c), (0x8dc0dd8f), + (0xe330a81a), (0x115b2b19), (0x020bd8ed), (0xf0605bee), + (0x24aa3f05), (0xd6c1bc06), (0xc5914ff2), (0x37faccf1), + (0x69e9f0d5), (0x9b8273d6), (0x88d28022), (0x7ab90321), + (0xae7367ca), (0x5c18e4c9), (0x4f48173d), (0xbd23943e), + (0xf36e6f75), (0x0105ec76), (0x12551f82), (0xe03e9c81), + (0x34f4f86a), (0xc69f7b69), (0xd5cf889d), (0x27a40b9e), + (0x79b737ba), (0x8bdcb4b9), (0x988c474d), (0x6ae7c44e), + (0xbe2da0a5), (0x4c4623a6), (0x5f16d052), (0xad7d5351), +}; + +/* ========================================================================= */ +# if __BYTE_ORDER == __LITTLE_ENDIAN +# define DO_CRC(x) crc = crc32c_table[(crc ^ (x)) & 255] ^ (crc >> 8) +# else +# define DO_CRC(x) crc = crc32c_table[((crc >> 24) ^ (x)) & 255] ^ (crc << 8) +# endif + +u32 crc32c_cal(u32 crc, const char *data, size_t length) +{ + while (length--) + crc = DO_CRC(*data++); +#if defined(CONFIG_HW_WATCHDOG) || defined(CONFIG_WATCHDOG) + WATCHDOG_RESET(); +#endif + return crc; +}
Koen Kooi
