[U-Boot] [PATCH] drivers/spi: fsl_qspi: fix controller busy check
During QSPI reads, current is_busy_controller function sporadically fails with -ETIMEDOUT due to fixed number of 5 test loops. This patch fixes this by using the readl_poll_timeout function with 1000 us timeout.
Signed-off-by: Thomas Schaefer thomas.schaefer@kontron.com Signed-off-by: Fabio Estevam festevam@gmail.com --- drivers/spi/fsl_qspi.c | 18 ++++++------------ 1 file changed, 6 insertions(+), 12 deletions(-)
diff --git a/drivers/spi/fsl_qspi.c b/drivers/spi/fsl_qspi.c index 1598c4f698..41abe1996f 100644 --- a/drivers/spi/fsl_qspi.c +++ b/drivers/spi/fsl_qspi.c @@ -10,6 +10,7 @@ #include <spi.h> #include <asm/io.h> #include <linux/sizes.h> +#include <linux/iopoll.h> #include <dm.h> #include <errno.h> #include <watchdog.h> @@ -150,20 +151,13 @@ static void qspi_write32(u32 flags, u32 *addr, u32 val) static inline int is_controller_busy(const struct fsl_qspi_priv *priv) { u32 val; - const u32 mask = QSPI_SR_BUSY_MASK | QSPI_SR_AHB_ACC_MASK | - QSPI_SR_IP_ACC_MASK; - unsigned int retry = 5; + u32 mask = QSPI_SR_BUSY_MASK | QSPI_SR_AHB_ACC_MASK | + QSPI_SR_IP_ACC_MASK;
- do { - val = qspi_read32(priv->flags, &priv->regs->sr); + if (priv->flags & QSPI_FLAG_REGMAP_ENDIAN_BIG) + mask = (u32)cpu_to_be32(mask);
- if ((~val & mask) == mask) - return 0; - - udelay(1); - } while (--retry); - - return -ETIMEDOUT; + return readl_poll_timeout(&priv->regs->sr, val, !(val & mask), 1000); }
/* QSPI support swapping the flash read/write data
This sounds like two different functionalities into one patch. better create a timeout fix in one patch and another patch to migrate read_poll.
Fabio Estevam
Jagan Teki
