[PATCH] CI: Print out unmigrated symbols when failing
To make addressing the problem of migrated symbols being present in board config header files, update the CI test to them print what symbols are causing it to fail. Also report all failures in the tree, rather than stopping at the first failing file.
Signed-off-by: Tom Rini trini@konsulko.com --- .azure-pipelines.yml | 7 +++++-- .gitlab-ci.yml | 9 ++++++--- 2 files changed, 11 insertions(+), 5 deletions(-)
diff --git a/.azure-pipelines.yml b/.azure-pipelines.yml index 314d27718926..ec77c7ab5fcf 100644 --- a/.azure-pipelines.yml +++ b/.azure-pipelines.yml @@ -63,6 +63,7 @@ stages: - script: | KSYMLST=`mktemp` KUSEDLST=`mktemp` + RET=0 cat `find . -name "Kconfig*"` | \ sed -n -e 's/^\s*config *([A-Za-z0-9_]*).*$/CONFIG_\1/p' \ -e 's/^\s*menuconfig *([A-Za-z0-9_]*).*$/CONFIG_\1/p' \ @@ -76,10 +77,12 @@ stages: NUM=`comm -123 --total --output-delimiter=, ${KSYMLST} ${KUSEDLST} | \ cut -d , -f 3` if [[ $NUM -ne 0 ]]; then - echo "Unmigrated symbols found in $CFG" - exit 1 + echo "Unmigrated symbols found in $CFG:" + comm -12 ${KSYMLST} ${KUSEDLST} + RET=1 fi done + exit $RET
- job: cppcheck displayName: 'Static code analysis with cppcheck' diff --git a/.gitlab-ci.yml b/.gitlab-ci.yml index 43fe8c64991c..f193ffd3cbc4 100644 --- a/.gitlab-ci.yml +++ b/.gitlab-ci.yml @@ -124,6 +124,7 @@ check for migrated symbols in board header: script: - KSYMLST=`mktemp`; KUSEDLST=`mktemp`; + RET=0; cat `find . -name "Kconfig*"` | sed -n -e 's/^\s*config *([A-Za-z0-9_]*).*$/CONFIG_\1/p' -e 's/^\s*menuconfig *([A-Za-z0-9_]*).*$/CONFIG_\1/p' @@ -137,10 +138,12 @@ check for migrated symbols in board header: NUM=`comm -123 --total --output-delimiter=, ${KSYMLST} ${KUSEDLST} | cut -d , -f 3`; if [[ $NUM -ne 0 ]]; then - echo "Unmigrated symbols found in $CFG"; - exit 1; + echo "Unmigrated symbols found in $CFG:"; + comm -12 ${KSYMLST} ${KUSEDLST}; + RET=1; fi; - done + done; + exit $RET
# QA jobs for code analytics # static code analysis with cppcheck (we can add --enable=all later)
