[U-Boot] [PATCH v2] zlib: fix code when DEBUG is defined
Removed stdio.h inclusion and moved trace macros to use printf avoiding to write debug informations to standard error.
Signed-off-by: Giuseppe Condorelli giuseppe.condorelli@st.com --- lib_generic/zlib.c | 4 ++-- 1 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/lib_generic/zlib.c b/lib_generic/zlib.c index 1b6db32..25ae88f 100644 --- a/lib_generic/zlib.c +++ b/lib_generic/zlib.c @@ -27,6 +27,7 @@ #define ZLIB_INTERNAL
#include "u-boot/zlib.h" +#include <common.h> /* To avoid a build time warning */ #ifdef STDC #include <malloc.h> @@ -83,10 +84,10 @@ typedef unsigned long ulg;
/* Diagnostic functions */ #ifdef DEBUG -#include <stdio.h> extern int z_verbose; extern void z_error OF((char *m)); #define Assert(cond,msg) {if(!(cond)) z_error(msg);} +#define fprintf(fp,...) printf(__VA_ARGS__) #define Trace(x) {if (z_verbose>=0) fprintf x ;} #define Tracev(x) {if (z_verbose>0) fprintf x ;} #define Tracevv(x) {if (z_verbose>1) fprintf x ;} @@ -2000,7 +2001,6 @@ void z_error (m) char *m; { fprintf(stderr, "%s\n", m); - exit(1); } #endif
Dear Giuseppe CONDORELLI,
In message 1251970209-9053-1-git-send-email-giuseppe.condorelli@st.com you wrote:
old: 1 files changed, 29 insertions(+), 30 deletions(-) new: 1 files changed, 2 insertions(+), 2 deletions(-)
Isn't that great?
- exit(1);
} #endif
Sorry for not catching this in the first round.
What happens when we return here? Obviously this function is supposed to never return. Should we call hang() here?
Dear Wolfgang Denk,
Isn't that great?
Sure!!! :)
Given that z_error is invoked by Assert macro (never used) and that "exit" function (other than closing all opened stream) will terminate program execution, I suggest to remove it without adding others instructions letting u-boot to hang by itself (if it will do this).
What's your idea? Thanks, Giuseppe
-----Original Message----- From: Wolfgang Denk [mailto:wd@denx.de] Sent: Thursday, September 03, 2009 10:26 AM To: Giuseppe CONDORELLI Cc: u-boot@lists.denx.de Subject: Re: [U-Boot] [PATCH v2] zlib: fix code when DEBUG is defined
Isn't that great?
- exit(1);
} #endif
Well, if you just return from z_error() after an error condition was detected, and continue to run, this will cause undefined behaviour. I prefer to have a clear error condition which halts the system, instead of having a system which continues to run but does random things on me, eventually causing bigger damages.
Giuseppe CONDORELLI
