[PATCH v2] board: sifive: Fix a potential build warning in board_fdt_blob_setup()
Commit 47d73ba4f4a4 ("board: sifive: overwrite board_fdt_blob_setup in u-boot proper") added a board-specific implementation of board_fdt_blob_setup() which takes a pointer as the return value, but it does not return anything if CONFIG_OF_SEPARATE is not enabled. This will cause a build warning seen when testing booting S-mode U-Boot directly from QEMU, per the instructions in [1]:
board/sifive/unleashed/unleashed.c: In function ‘board_fdt_blob_setup’: board/sifive/unleashed/unleashed.c:125:1: warning: control reaches end of non-void function [-Wreturn-type]
Return &_end as the default case.
[1] https://qemu.readthedocs.io/en/latest/system/riscv/sifive_u.html#running-u-b...
Signed-off-by: Bin Meng bmeng.cn@gmail.com
Changes in v2: - Correct the commit title
board/sifive/unleashed/unleashed.c | 4 ++-- board/sifive/unmatched/unmatched.c | 4 ++-- 2 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/board/sifive/unleashed/unleashed.c b/board/sifive/unleashed/unleashed.c index 8cd514df30..33baeda986 100644 --- a/board/sifive/unleashed/unleashed.c +++ b/board/sifive/unleashed/unleashed.c @@ -119,9 +119,9 @@ void *board_fdt_blob_setup(void) if (IS_ENABLED(CONFIG_OF_SEPARATE)) { if (gd->arch.firmware_fdt_addr) return (ulong *)gd->arch.firmware_fdt_addr; - else - return (ulong *)&_end; } + + return (ulong *)&_end; }
int board_init(void) diff --git a/board/sifive/unmatched/unmatched.c b/board/sifive/unmatched/unmatched.c index d90b252bae..8773b660fa 100644 --- a/board/sifive/unmatched/unmatched.c +++ b/board/sifive/unmatched/unmatched.c @@ -16,9 +16,9 @@ void *board_fdt_blob_setup(void) if (IS_ENABLED(CONFIG_OF_SEPARATE)) { if (gd->arch.firmware_fdt_addr) return (ulong *)gd->arch.firmware_fdt_addr; - else - return (ulong *)&_end; } + + return (ulong *)&_end; }
Reviewed-by: Leo Yu-Chi Liang ycliang@andestech.com CONFIDENTIALITY NOTICE:
This e-mail (and its attachments) may contain confidential and legally privileged information or information protected from disclosure. If you are not the intended recipient, you are hereby notified that any disclosure, copying, distribution, or use of the information contained herein is strictly prohibited. In this case, please immediately notify the sender by return e-mail, delete the message (and any accompanying documents) and destroy all printed hard copies. Thank you for your cooperation.
Copyright ANDES TECHNOLOGY CORPORATION - All Rights Reserved.
Hi Bin
There's a similar discussion in a cleanup series I've sent [1] On Sat, Sep 11, 2021 at 10:31:23PM +0800, Bin Meng wrote:
It's not only a build warning, you don't even have a DTB to begin with.
Changes in v2:
else
}return (ulong *)&_end;
else
is _end correct here? Doesn't the placement depend on CONFIG_SPL_BUILD and CONFIG_SPL_SEPARATE_BSS?
To sum up the other thread I think the overall approach here is not ideal. OF_SEPARATE is used in conjunction with SPL in these boards. What happens (assuming I didn't miss anything), is that SPL passes the DTB to OpenSBI, which in it turn copies to a1 before invoking U-Boot. But we are better of with stricter rules for DTB. - OF_SEPARATE means: I'll read the DTB from the U-Boot binary. - OF_BOARD: The board will somehow provide it.
So II think the patch should look something along the lines of:
if (IS_ENABLED(CONFIG_OF_SEPARATE)) { #ifdef CONFIG_SPL_BUILD /* FDT is at end of BSS unless it is in a different memory region */ if (IS_ENABLED(CONFIG_SPL_SEPARATE_BSS)) fdt_blob = (void *)&_image_binary_end; else fdt_blob = (void *)&__bss_end; #else /* FDT is at end of image */ fdt_blob = (void *)&_end;
if (IS_ENABLED(CONFIG_OF_BOARD)) { fdt_blob = (void *)gd->arch.firmware_fdt_addr; }
2.25.1
[1] https://lore.kernel.org/u-boot/YVRiVFP+sYGZhJiY@apalos.home/
Cheers /Ilias
Hi Ilias,
On Wed, Sep 29, 2021 at 9:07 PM Ilias Apalodimas ilias.apalodimas@linaro.org wrote:
Hi Bin
Changes in v2:
else
else
I will have to leave this to Zong to comment as he introduced this via commit 47d73ba4f4a4 ("board: sifive: overwrite board_fdt_blob_setup in u-boot proper").
I don't know what user case that Zong wanted to support on Unleased and Unmatched.
Missing #endif here?
Regards, Bin
else
Okay. The I think we can fix this correctly. We can probably use OF_BOARD in those boards, as long as the SPL generated DTB is always there and passed over to OpenSBI.
Missing #endif here?o
Yea it wasn't supposed to be real code.
Regards, Bin
Regards /Ilias
Bin Meng
Ilias Apalodimas
Leo Liang
