Re: [U-Boot] [PATCH] Add mpc5125ads board and processor to the mpc512x family
Hello Wolfgang,
I am planning to resubmit this patch very soon - by Tuesday perhaps. Considering there is some differences in the memory layout esp for the iopin struct (going from 32-bit to byte sizes) I am not sure how I can get around the #defs you suggest. Perhaps an entirely separate .c file for this part ??
Much of what you pointed to was copied over from the mpc5121ads ... so I didn't pay that much attention. I will fix these too and also fix the 5121 code later.
When do you need it so I can give you enough time to look it over?
Thanks Wolfgang, Martha
-----Original Message----- From: Wolfgang Denk wd@denx.de Sent 10/3/2009 6:43:51 PM To: Martha M Stan mmarx@silicontkx.com Cc: u-boot@lists.denx.de Subject: Re: [U-Boot] [PATCH] Add mpc5125ads board and processor to the mpc512x family
Dear Martha M Stan,
do you plan to send an updated patch for this release?
In addition to Fabio's comments here a few more:
In message 12535648622828-git-send-email-mmarx@silicontkx.com you wrote:
... diff --git a/board/freescale/mpc5125ads/mpc5125ads.c b/board/freescale/mpc5125ads/mpc5125ads.c new file mode 100644 index 0000000..445c765 --- /dev/null +++ b/board/freescale/mpc5125ads/mpc5125ads.c ... +if (in_8((u8 *)(CONFIG_SYS_CPLD_BASE + 0x08)) & 0x04) { +out_8((u8 *)(CONFIG_SYS_CPLD_BASE + 0x08), 0xc1); +} else { +/* running from Backup flash */ +out_8((u8 *)(CONFIG_SYS_CPLD_BASE + 0x08), 0x32); +}
Please do not use base address plus offset, but define a C struct to describe the CPLD's register layout.
[That would also be most welcome to fix similar code in "board/freescale/mpc5121ads/mpc5121ads.c"; sorry - due to lack of documentation I was not able to clean this up yet.]
+#endif +/* + * initialize function mux & slew rate for all IO pins + * there are two peripheral options controlled by switch 8 + */ + if (IS_CFG1_SWITCH) {
Indentation not by TAB.
+#ifdef CONFIG_MISC_INIT_R +int misc_init_r(void) +{ +u8 tmp_val; + +extern int ads5121_diu_init(void); + + immap_t *im = (immap_t *) CONFIG_SYS_IMMR; + u32 bkup_size = flash_info[0].size; + u32 bkup_start = 0xffffffff - bkup_size +1;
Indentation not by TAB. Please fix globally.
+/* Verify if enabled */ +tmp_val = 0; +i2c_read(0x38, 0x08, 1, &tmp_val, sizeof(tmp_val)); ... +tmp_val = 0; +i2c_read(0x38, 0x0A, 1, &tmp_val, sizeof(tmp_val));
Which sense does it make to set tmp_val when you overwrite the value immediately by running i2c_read()?
And would it be not a good idea to check i2c_read() / i2c_write() return codes?
+int checkboard (void) +{ +ushort brd_rev = *(vu_short *) (CONFIG_SYS_CPLD_BASE + 0x00); +uchar cpld_rev = *(vu_char *) (CONFIG_SYS_CPLD_BASE + 0x02); +uchar cpld_min_rev = *(vu_char *) (CONFIG_SYS_CPLD_BASE + 0x03);
See above - please use a C struct to describe the CPLD layout.
+if (IS_CFG1_SWITCH) /* CAN1+2, SDHC1, USB1+2, FEC1+2, I2C1+2*/ +printf("Peripheral Option Set 1\n"); +else/* CAN1+2, SDHC1, DIU, USB1, FEC1, I2C1+3*/ +printf("Peripheral Option Set 0\n");
Don't repeat long strings without need. How about:
printf("Peripheral Option Set %d\n", IS_CFG1_SWITCH != 0);
Hm... I wonder what the output format will look like. I guess there might be vertical alignment issues?
diff --git a/board/freescale/mpc5125ads/u-boot.lds b/board/freescale/mpc5125ads/u-boot.lds new file mode 100644 index 0000000..f2f6e14 --- /dev/null +++ b/board/freescale/mpc5125ads/u-boot.lds
Do you really need a private linker script? Why?
diff --git a/cpu/mpc512x/fixed_sdram.c b/cpu/mpc512x/fixed_sdram.c index 63a3035..12ac44d 100644 --- a/cpu/mpc512x/fixed_sdram.c +++ b/cpu/mpc512x/fixed_sdram.c @@ -36,6 +36,7 @@ u32 default_mddrc_config[4] = {
u32 default_init_seq[] = { +#ifndef CONFIG_SYS_DDR_OVRIDE_DEF CONFIG_SYS_DDRCMD_NOP, CONFIG_SYS_DDRCMD_NOP, CONFIG_SYS_DDRCMD_NOP, @@ -67,6 +68,7 @@ u32 default_init_seq[] = { CONFIG_SYS_DDRCMD_OCD_DEFAULT, CONFIG_SYS_DDRCMD_PCHG_ALL, CONFIG_SYS_DDRCMD_NOP +#endif
Isn't there way to do without such #ifdef's in common code?
/* Initialize IO Control */ -out_be32(io_ctrl.io_control_mem, IOCTRL_MUX_DDR); +#ifdef CONFIG_MPC5125 +out_8(io_ctrl.io_control_mem, IOCTRL_MUX_DDR); +#else + out_be32(io_ctrl.io_control_mem, IOCTRL_MUX_DDR); +#endif
Ditto here.
diff --git a/cpu/mpc512x/iopin.c b/cpu/mpc512x/iopin.c index be20947..ab5dd1c 100644 --- a/cpu/mpc512x/iopin.c +++ b/cpu/mpc512x/iopin.c @@ -28,15 +28,27 @@ void iopin_initialize(iopin_t *ioregs_init, int len) { short i, j, p; -u32 *reg; immap_t *im = (immap_t *)CONFIG_SYS_IMMR;
-reg = (u32 *)&(im-io_ctrl); +#ifdef CONFIG_MPC5125 +u8 *reg =(u8 *)&(im-io_ctrl); +#else +u32 *reg =(u32 *)&(im-io_ctrl); +#endif
And here again.
This is becoming an #ifdef mess, it seems. Usually this is an indiaction of a major design issue.
+#ifdef CONFIG_MPC5125 +for (p = 0, j = ioregs_init[i].p_offset; +p ioregs_init[i].nr_pins; p++, j++) { +if (ioregs_init[i].bit_or) +setbits_8(&(reg[j]), ioregs_init[i].val); +else +out_8(®[j], ioregs_init[i].val); +} +#else for (p = 0, j = ioregs_init[i].p_offset / sizeof(u_long); p ioregs_init[i].nr_pins; p++, j++) { if (ioregs_init[i].bit_or) @@ -44,6 +56,7 @@ void iopin_initialize(iopin_t *ioregs_init, int len) else out_be32 (reg + j, ioregs_init[i].val); } +#endif
And again. That's enough: NAK!
diff --git a/drivers/net/mpc512x_fec.c b/drivers/net/mpc512x_fec.c index fb2c19a..3ff1c31 100644 --- a/drivers/net/mpc512x_fec.c +++ b/drivers/net/mpc512x_fec.c @@ -41,7 +41,11 @@ static int rx_buff_idx = 0; static void mpc512x_fec_phydump (char *devname) { u16 phyStatus, i; -u8 phyAddr = CONFIG_PHY_ADDR; +#ifdef CONFIG_MPC5125 +uint8 phyAddr = ((devname[3]=='2') ? CONFIG_PHY2_ADDR : CONFIG_PHY_ADDR); +#else +uint8 phyAddr = CONFIG_PHY_ADDR; +#endif
Umm.. does this work with CONFIG_NET_MULTI ?
diff --git a/include/asm-ppc/immap_512x.h b/include/asm-ppc/immap_512x.h index 79cdd80..50ef20c 100644 --- a/include/asm-ppc/immap_512x.h +++ b/include/asm-ppc/immap_512x.h @@ -36,6 +36,8 @@ #define_START_OFFSETEXC_OFF_SYS_RESET
#define SPR_5121E0x80180000 +#define SPR_51250x80190000 +
Please don't add random white space.
/* * IMMRBAR - Internal Memory Register Base Address @@ -210,21 +212,25 @@ typedef struct clk512x { #define CLOCK_SCCR1_TPR_EN0x00001000 #define CLOCK_SCCR1_PCI_EN0x00000800 #define CLOCK_SCCR1_DDR_EN0x00000400 +#define CLOCK_SCCR1_FEC2_EN0x00000200
/* System Clock Control Register 2 commands */ #define CLOCK_SCCR2_DIU_EN0x80000000 #define CLOCK_SCCR2_AXE_EN0x40000000 #define CLOCK_SCCR2_MEM_EN0x20000000 -#define CLOCK_SCCR2_USB2_EN0x10000000 -#define CLOCK_SCCR2_USB1_EN0x08000000 +#define CLOCK_SCCR2_USB1_EN0x10000000 +#define CLOCK_SCCR2_USB2_EN0x08000000
Is this a bug fix to existing code? This should be a separate patch, then.
#define CLOCK_SCCR2_BDLC_EN0x02000000 +#define CLOCK_SCCR2_AUTO_EN0x02000000 #define CLOCK_SCCR2_SDHC_EN0x01000000 +#define CLOCK_SCCR2_AUTO_EN0x02000000
Why are you adding CLOCK_SCCR2_AUTO_EN twice?
typedef struct ioctrl512x { -u32io_control_mem;/* MEM pad ctrl reg */ -u32io_control_gp;/* GP pad ctrl reg */ -u32io_control_lpc_clk;/* LPC_CLK pad ctrl reg */ -u32io_control_lpc_oe;/* LPC_OE pad ctrl reg */ -u32io_control_lpc_rw;/* LPC_R/W pad ctrl reg */ -u32io_control_lpc_ack;/* LPC_ACK pad ctrl reg */ -u32io_control_lpc_cs0;/* LPC_CS0 pad ctrl reg */ -u32io_control_nfc_ce0;/* NFC_CE0 pad ctrl reg */ -u32io_control_lpc_cs1;/* LPC_CS1 pad ctrl reg */ -u32io_control_lpc_cs2;/* LPC_CS2 pad ctrl reg */ -u32io_control_lpc_ax03;/* LPC_AX03 pad ctrl reg */ -u32io_control_emb_ax02;/* EMB_AX02 pad ctrl reg */ -u32io_control_emb_ax01;/* EMB_AX01 pad ctrl reg */ -u32io_control_emb_ax00;/* EMB_AX00 pad ctrl reg */ -u32io_control_emb_ad31;/* EMB_AD31 pad ctrl reg */ ... -u32io_control_usb_phy_drvvbus;/* USB2_DRVVBUS pad ctrl reg */ -u8reserved[0x0cfc];/* fill to 4096 bytes size */ +#ifdef CONFIG_MPC5125 +u8 io_control_mem;/* offset 0x00 mem pad ctrl reg */ +u8 io_control_gbobe;/* offset 0x01 gbobe pad ctrl reg */ +u8res1[2]; +u8 io_control_lpc_clk;/* offset 0x04 lpc_clk pad ctrl reg */ +u8 io_control_lpc_oe_b;/* offset 0x05 lpc_oe_b pad ctrl reg */ +u8 io_control_lpc_rwb;/* offset 0x06 lpc_rwb pad ctrl reg */ +u8 io_control_lpc_cs0_b;/* offset 0x07 lpc_cs0_b*/ +u8 io_control_lpc_ack_b;/* offset 0x08 lpc_ack_b pad ctrl reg */ +u8 io_control_lpc_ax03;/* offset 0x09 lpc_ax03 pad ctrl reg */ +u8 io_control_emb_ax02;/* offset 0x0a emb_ax02 pad ctrl reg */ +u8 io_control_emb_ax01;/* offset 0x0b emb_ax01 pad ctrl reg */ +u8 io_control_emb_ax00;/* offset 0x0c emb_ax00 pad ctrl reg */ +u8 io_control_emb_ad31;/* offset 0x0d emb_ad31 pad ctrl reg */
NAK!!! If structures are so fundamentally different, it makes zero sense trying to make them look the same. Instead, make clear that these are separate, incompatible things. Declare a new struct for the 5125.
typedef struct psc512x { +#ifdef CONFIG_MPC5125 +volatile u8mr1;/* PSC + 0x00 */ +volatile u8res0[3]; +volatile u8mr2;/* PSC + 0x04 */ +volatile u8res0a[3]; +volatile u16psc_status;/* PSC + 0x08 */ +volatile u16res1; +volatile u16psc_clock_select;/* PSC + 0x0C mpc5125 manual has this as u8 */ + /* it has u8 res after it and for compatibility */ + /* will keep u16 so high bits are set as before */ +volatile u16res1a; +volatile u8command;/* PSC + 0x10 */ +volatile u8res2[3]; +union {/* PSC + 0x14 */ +volatile u8buffer_8; +volatile u16buffer_16; +volatile u32buffer_32; +} buffer;
Same here. Such huge monster-#ifdef's make zero sense. If structs are different, they _are_ different and code shoud reflect that.
diff --git a/include/configs/mpc5121ads.h b/include/configs/mpc5121ads.h index ebc518c..35e69c4 100644 --- a/include/configs/mpc5121ads.h +++ b/include/configs/mpc5121ads.h @@ -28,6 +28,7 @@ #define __CONFIG_H
#define CONFIG_MPC5121ADS 1 + /*
What exactly is the intention behind such a random whitespace change? Please do not mess aroiund with unrelated files.
diff --git a/include/configs/mpc5125ads.h b/include/configs/mpc5125ads.h new file mode 100644 index 0000000..2ba7ba3 --- /dev/null +++ b/include/configs/mpc5125ads.h ... +/* video */ +#undef CONFIG_VIDEO
Please do not add dead code - do not undef undefined stuff.
+ * Enable Fast boot + */ +#define CONFIG_FASTBOOT
And do not add non-existing #defines either.
... +#define CONFIG_SYS_CS_ALETIMING0x00000005/* Use alternative CS timing for CS0 and CS2 */
Lines too long. Please fix globally.
+/* + * IIM - IC Identification Module + */ +#undef CONFIG_IIM
See above. Don;t add dead code.
+/* I2C */ +#define CONFIG_HARD_I2C/* defd in ads5121 I2C with hardware support */ +#undef CONFIG_SOFT_I2C/* so disable bit-banged I2C */
Ditto.
+#if defined(CONFIG_HARD_I2C) || defined(CONFIG_SOFT_I2C) +#define CONFIG_I2C_MULTI_BUS +#define CONFIG_I2C_CMD_TREE +#define CONFIG_SYS_I2C_SPEED100000/* I2C speed and slave address */ +#define CONFIG_SYS_I2C_SLAVE0x7F +#if 0 +#define CONFIG_SYS_I2C_NOPROBES{{0,0x69}}/* Don't probe these addrs */ +#endif
And again.
+/* #define CONFIG_WATCHDOG *//* enable watchdog */
And again - please fix globally.
+#define CONFIG_SYS_LONGHELP/* undef to save memory */ +#define CONFIG_SYS_LOAD_ADDR0x2000000/* default load address */
Probably too low for most recent kernel versions... And inconsistent with later settings...
Seems this needs a major overhaul.
Dear Martha,
umm... your mail header still says "m marx".
This depends on the situation. If the struct layout is absolutely identical, just with different datatypes, we might use a #defined type in the sruct. If not (which seems to be the case almost everywhere where I looked), then we have to use at least different structs.
Not paying much attention is always a bad thing which adds avoidable efforts.
It depends. If you want to see this go in for the current release, we should have clean and stable code in a week or two. Of head for the next release, then ther eis no hurry at all.
m marx
