[U-Boot] [PATCH] rockchip: rk3399: orangepi: Add SPL_TEXT_BASE
CONFIG_SPL_TEXT_BASE was available in configs/rk3399_common.h when the OrangePI rk3399 board supported during first version patch.
But, later below change which move this config into Kconfig and same has been merged in mainline tree. "configs: move CONFIG_SPL_TEXT_BASE to Kconfig" (sha1: f89d6133eef2e068f9c33853b6584d7fcbfa9d2e)
Unfortunately, the maintainer applied the initial version patch, instead of looking for next version changes.
Fix it by adding SPL_TEXT_BASE in orangepi-rk3399 defconfig.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- configs/orangepi-rk3399_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/orangepi-rk3399_defconfig b/configs/orangepi-rk3399_defconfig index cdccf221b5..ba13976cc6 100644 --- a/configs/orangepi-rk3399_defconfig +++ b/configs/orangepi-rk3399_defconfig @@ -17,6 +17,7 @@ CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-rockchip/make_fit_atf.py" CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-orangepi.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_TEXT_BASE=0xff8c2000 CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x4000 CONFIG_SPL_ATF=y
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
Jagan Teki
Kever Yang
