[U-Boot] [PATCH v2] kconfig: use bool instead of boolean for type definition attributes
Linux stopped the use of keyword 'boolean' in Kconfig.
Refer to commit 6341e62b212a2541efb0160c470e90bd226d5496 ("kconfig: use bool instead of boolean for type definition attributes") in Linux Kernel.
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
Changes in v2: - Fix a conflict so that it can apply to the mainline
arch/arm/cpu/armv7/Kconfig | 8 ++++---- arch/arm/cpu/armv8/Kconfig | 2 +- board/sunxi/Kconfig | 16 ++++++++-------- drivers/power/Kconfig | 14 +++++++------- drivers/spmi/Kconfig | 4 ++-- 5 files changed, 22 insertions(+), 22 deletions(-)
diff --git a/arch/arm/cpu/armv7/Kconfig b/arch/arm/cpu/armv7/Kconfig index bd6108e..41c6639 100644 --- a/arch/arm/cpu/armv7/Kconfig +++ b/arch/arm/cpu/armv7/Kconfig @@ -7,14 +7,14 @@ config CPU_V7_HAS_VIRT bool
config ARMV7_NONSEC - boolean "Enable support for booting in non-secure mode" if EXPERT + bool "Enable support for booting in non-secure mode" if EXPERT depends on CPU_V7_HAS_NONSEC default y ---help--- Say Y here to enable support for booting in non-secure / SVC mode.
config ARMV7_BOOT_SEC_DEFAULT - boolean "Boot in secure mode by default" if EXPERT + bool "Boot in secure mode by default" if EXPERT depends on ARMV7_NONSEC default y if TEGRA ---help--- @@ -25,14 +25,14 @@ config ARMV7_BOOT_SEC_DEFAULT variable to "sec" or "nonsec".
config ARMV7_VIRT - boolean "Enable support for hardware virtualization" if EXPERT + bool "Enable support for hardware virtualization" if EXPERT depends on CPU_V7_HAS_VIRT && ARMV7_NONSEC default y ---help--- Say Y here to boot in hypervisor (HYP) mode when booting non-secure.
config ARMV7_LPAE - boolean "Use LPAE page table format" if EXPERT + bool "Use LPAE page table format" if EXPERT depends on CPU_V7 default n ---help--- diff --git a/arch/arm/cpu/armv8/Kconfig b/arch/arm/cpu/armv8/Kconfig index acf2460..7e1fc4c 100644 --- a/arch/arm/cpu/armv8/Kconfig +++ b/arch/arm/cpu/armv8/Kconfig @@ -1,7 +1,7 @@ if ARM64
config ARMV8_MULTIENTRY - boolean "Enable multiple CPUs to enter into U-Boot" + bool "Enable multiple CPUs to enter into U-Boot"
config ARMV8_SPIN_TABLE bool "Support spin-table enable method" diff --git a/board/sunxi/Kconfig b/board/sunxi/Kconfig index 323e972..1b30669 100644 --- a/board/sunxi/Kconfig +++ b/board/sunxi/Kconfig @@ -249,7 +249,7 @@ config UART0_PORT_F Only enable this if you really know what you are doing.
config OLD_SUNXI_KERNEL_COMPAT - boolean "Enable workarounds for booting old kernels" + bool "Enable workarounds for booting old kernels" default n ---help--- Set this to enable various workarounds for old kernels, this results in @@ -419,13 +419,13 @@ config I2C4_ENABLE endif
config AXP_GPIO - boolean "Enable support for gpio-s on axp PMICs" + bool "Enable support for gpio-s on axp PMICs" default n ---help--- Say Y here to enable support for the gpio pins of the axp PMIC ICs.
config VIDEO - boolean "Enable graphical uboot console on HDMI, LCD or VGA" + bool "Enable graphical uboot console on HDMI, LCD or VGA" depends on !MACH_SUN8I_A83T && !MACH_SUN8I_H3 && !MACH_SUN9I && !MACH_SUN50I_A64 default y ---help--- @@ -434,21 +434,21 @@ config VIDEO info on how to select the video output and mode.
config VIDEO_HDMI - boolean "HDMI output support" + bool "HDMI output support" depends on VIDEO && !MACH_SUN8I default y ---help--- Say Y here to add support for outputting video over HDMI.
config VIDEO_VGA - boolean "VGA output support" + bool "VGA output support" depends on VIDEO && (MACH_SUN4I || MACH_SUN7I) default n ---help--- Say Y here to add support for outputting video over VGA.
config VIDEO_VGA_VIA_LCD - boolean "VGA via LCD controller support" + bool "VGA via LCD controller support" depends on VIDEO && (MACH_SUN5I || MACH_SUN6I || MACH_SUN8I) default n ---help--- @@ -457,7 +457,7 @@ config VIDEO_VGA_VIA_LCD Olimex A13 boards.
config VIDEO_VGA_VIA_LCD_FORCE_SYNC_ACTIVE_HIGH - boolean "Force sync active high for VGA via LCD controller support" + bool "Force sync active high for VGA via LCD controller support" depends on VIDEO_VGA_VIA_LCD default n ---help--- @@ -475,7 +475,7 @@ config VIDEO_VGA_EXTERNAL_DAC_EN format understood by sunxi_name_to_gpio, e.g. PH1 for pin 1 of port H.
config VIDEO_COMPOSITE - boolean "Composite video output support" + bool "Composite video output support" depends on VIDEO && (MACH_SUN4I || MACH_SUN5I || MACH_SUN7I) default n ---help--- diff --git a/drivers/power/Kconfig b/drivers/power/Kconfig index b422703..f2c5629 100644 --- a/drivers/power/Kconfig +++ b/drivers/power/Kconfig @@ -15,12 +15,12 @@ choice default SUNXI_NO_PMIC if MACH_SUN8I_H3 || MACH_SUN50I
config SUNXI_NO_PMIC - boolean "board without a pmic" + bool "board without a pmic" ---help--- Select this for boards which do not use a PMIC.
config AXP152_POWER - boolean "axp152 pmic support" + bool "axp152 pmic support" depends on MACH_SUN5I select CMD_POWEROFF ---help--- @@ -28,7 +28,7 @@ config AXP152_POWER A10s boards.
config AXP209_POWER - boolean "axp209 pmic support" + bool "axp209 pmic support" depends on MACH_SUN4I || MACH_SUN5I || MACH_SUN7I select CMD_POWEROFF ---help--- @@ -36,7 +36,7 @@ config AXP209_POWER A10, A13 and A20 boards.
config AXP221_POWER - boolean "axp221 / axp223 pmic support" + bool "axp221 / axp223 pmic support" depends on MACH_SUN6I || MACH_SUN8I_A23 || MACH_SUN8I_A33 select CMD_POWEROFF ---help--- @@ -44,14 +44,14 @@ config AXP221_POWER A23 and A31 boards.
config AXP809_POWER - boolean "axp809 pmic support" + bool "axp809 pmic support" depends on MACH_SUN9I select CMD_POWEROFF ---help--- Say y here to enable support for the axp809 pmic found on A80 boards.
config AXP818_POWER - boolean "axp818 pmic support" + bool "axp818 pmic support" depends on MACH_SUN8I_A83T select CMD_POWEROFF ---help--- @@ -59,7 +59,7 @@ config AXP818_POWER A83T dev board.
config SY8106A_POWER - boolean "SY8106A pmic support" + bool "SY8106A pmic support" depends on MACH_SUN8I_H3 ---help--- Select this to enable support for the SY8106A pmic found on some diff --git a/drivers/spmi/Kconfig b/drivers/spmi/Kconfig index 8d25b45..ab4878e 100644 --- a/drivers/spmi/Kconfig +++ b/drivers/spmi/Kconfig @@ -9,13 +9,13 @@ config SPMI to connect PMIC devices on various SoCs.
config SPMI_MSM - boolean "Support Qualcomm SPMI bus" + bool "Support Qualcomm SPMI bus" depends on SPMI ---help--- Support SPMI bus implementation found on Qualcomm Snapdragon SoCs.
config SPMI_SANDBOX - boolean "Support for Sandbox SPMI bus" + bool "Support for Sandbox SPMI bus" depends on SPMI ---help--- Demo SPMI bus implementation. Emulates part of PM8916 as single
Masahiro Yamada
