[U-Boot] [PATCH v2 0/5] sunxi: video: add DE2 LCD and ANX6345 drivers
This series adds drivers that are necessary to get LCD working on Pinebook: - ANX6345 eDP bridge driver that allows to connect eDP panels to SoCs that have parallel LCD interface - DE2 LCD driver for Allwinner A64. Similar hardware is present in V3s and R40, but is not supported by this driver yet.
Whole combination (along with PWM driver which is sent in another series) is tested on Pinebook which is based on Allwiner A64 SoC.
Please see https://github.com/anarsoul/u-boot-pine64/ if you want to test it.
Add an operation to read EDID, since bridge may have ability to read EDID from the panel that is connected to it, for example LCD<->eDP bridge.
Signed-off-by: Vasily Khoruzhick anarsoul@gmail.com --- v2: - no changes
drivers/video/bridge/video-bridge-uclass.c | 10 ++++++++++ include/video_bridge.h | 20 ++++++++++++++++++++ 2 files changed, 30 insertions(+)
diff --git a/drivers/video/bridge/video-bridge-uclass.c b/drivers/video/bridge/video-bridge-uclass.c index 07270bac9e..79facd02a6 100644 --- a/drivers/video/bridge/video-bridge-uclass.c +++ b/drivers/video/bridge/video-bridge-uclass.c @@ -8,6 +8,7 @@ #include <common.h> #include <dm.h> #include <errno.h> +#include <edid.h> #include <video_bridge.h>
int video_bridge_set_backlight(struct udevice *dev, int percent) @@ -45,6 +46,15 @@ int video_bridge_check_attached(struct udevice *dev) return ops->check_attached(dev); }
+int video_bridge_read_edid(struct udevice *dev, u8 *buf, int buf_size) +{ + struct video_bridge_ops *ops = video_bridge_get_ops(dev); + + if (!ops || !ops->read_edid) + return -ENOSYS; + return ops->read_edid(dev, buf, buf_size); +} + static int video_bridge_pre_probe(struct udevice *dev) { struct video_bridge_priv *uc_priv = dev_get_uclass_priv(dev); diff --git a/include/video_bridge.h b/include/video_bridge.h index c7b8681849..0699a8dda8 100644 --- a/include/video_bridge.h +++ b/include/video_bridge.h @@ -53,6 +53,16 @@ struct video_bridge_ops { * @return 0 if OK, -ve on error */ int (*set_backlight)(struct udevice *dev, int percent); + + /** + * read_edid() - Read information from EDID + * + * @dev: Device to read from + * @buf: Buffer to read into + * @buf_size: Buffer size + * @return number of bytes read, <=0 for error + */ + int (*read_edid)(struct udevice *dev, u8 *buf, int buf_size); };
#define video_bridge_get_ops(dev) \ @@ -89,4 +99,14 @@ int video_bridge_set_active(struct udevice *dev, bool active); */ int video_bridge_check_attached(struct udevice *dev);
+/** + * video_bridge_read_edid() - Read information from EDID + * + * @dev: Device to read from + * @buf: Buffer to read into + * @buf_size: Buffer size + * @return number of bytes read, <=0 for error + */ +int video_bridge_read_edid(struct udevice *dev, u8 *buf, int buf_size); + #endif
On Wed, 20 Sep 2017 23:29:07 -0700 Vasily Khoruzhick anarsoul@gmail.com wrote:
v2: - no changes
Applied to u-boot-video/master, thanks!
-- Anatolij
This header will be used in anx6345 driver
drivers/video/anx9804.c | 54 +-------------------------- include/anx98xx-edp.h | 98 +++++++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 99 insertions(+), 53 deletions(-) create mode 100644 include/anx98xx-edp.h
diff --git a/drivers/video/anx9804.c b/drivers/video/anx9804.c index 37ad69a039..67f7da7d18 100755 --- a/drivers/video/anx9804.c +++ b/drivers/video/anx9804.c @@ -12,61 +12,9 @@
#include <common.h> #include <i2c.h> +#include <anx98xx-edp.h> #include "anx9804.h"
-/* Registers at i2c address 0x38 */ - -#define ANX9804_HDCP_CONTROL_0_REG 0x01 - -#define ANX9804_SYS_CTRL2_REG 0x81 -#define ANX9804_SYS_CTRL2_CHA_STA 0x04 - -#define ANX9804_SYS_CTRL3_REG 0x82 -#define ANX9804_SYS_CTRL3_VALID_CTRL BIT(0) -#define ANX9804_SYS_CTRL3_F_VALID BIT(1) -#define ANX9804_SYS_CTRL3_HPD_CTRL BIT(4) -#define ANX9804_SYS_CTRL3_F_HPD BIT(5) - -#define ANX9804_LINK_BW_SET_REG 0xa0 -#define ANX9804_LANE_COUNT_SET_REG 0xa1 -#define ANX9804_TRAINING_PTN_SET_REG 0xa2 -#define ANX9804_TRAINING_LANE0_SET_REG 0xa3 -#define ANX9804_TRAINING_LANE1_SET_REG 0xa4 -#define ANX9804_TRAINING_LANE2_SET_REG 0xa5 -#define ANX9804_TRAINING_LANE3_SET_REG 0xa6 - -#define ANX9804_LINK_TRAINING_CTRL_REG 0xa8 -#define ANX9804_LINK_TRAINING_CTRL_EN BIT(0) - -#define ANX9804_LINK_DEBUG_REG 0xb8 -#define ANX9804_PLL_CTRL_REG 0xc7 -#define ANX9804_ANALOG_POWER_DOWN_REG 0xc8 - -/* Registers at i2c address 0x39 */ - -#define ANX9804_DEV_IDH_REG 0x03 - -#define ANX9804_POWERD_CTRL_REG 0x05 -#define ANX9804_POWERD_AUDIO BIT(4) - -#define ANX9804_RST_CTRL_REG 0x06 - -#define ANX9804_RST_CTRL2_REG 0x07 -#define ANX9804_RST_CTRL2_AUX BIT(2) -#define ANX9804_RST_CTRL2_AC_MODE BIT(6) - -#define ANX9804_VID_CTRL1_REG 0x08 -#define ANX9804_VID_CTRL1_VID_EN BIT(7) -#define ANX9804_VID_CTRL1_EDGE BIT(0) - -#define ANX9804_VID_CTRL2_REG 0x09 -#define ANX9804_ANALOG_DEBUG_REG1 0xdc -#define ANX9804_ANALOG_DEBUG_REG3 0xde -#define ANX9804_PLL_FILTER_CTRL1 0xdf -#define ANX9804_PLL_FILTER_CTRL3 0xe1 -#define ANX9804_PLL_FILTER_CTRL 0xe2 -#define ANX9804_PLL_CTRL3 0xe6 - /** * anx9804_init() - Init anx9804 parallel lcd to edp bridge chip * diff --git a/include/anx98xx-edp.h b/include/anx98xx-edp.h new file mode 100644 index 0000000000..f7e8baa167 --- /dev/null +++ b/include/anx98xx-edp.h @@ -0,0 +1,98 @@ +/* + * Copyright (C) 2015 Hans de Goede hdegoede@redhat.com + * Copyright (C) 2017 Vasily Khoruzhick anarsoul@gmail.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/* Registers at i2c address 0x38 */ + +#define ANX9804_HDCP_CONTROL_0_REG 0x01 + +#define ANX9804_SYS_CTRL1_REG 0x80 +#define ANX9804_SYS_CTRL1_PD_IO 0x80 +#define ANX9804_SYS_CTRL1_PD_VID 0x40 +#define ANX9804_SYS_CTRL1_PD_LINK 0x20 +#define ANX9804_SYS_CTRL1_PD_TOTAL 0x10 +#define ANX9804_SYS_CTRL1_MODE_SEL 0x08 +#define ANX9804_SYS_CTRL1_DET_STA 0x04 +#define ANX9804_SYS_CTRL1_FORCE_DET 0x02 +#define ANX9804_SYS_CTRL1_DET_CTRL 0x01 + +#define ANX9804_SYS_CTRL2_REG 0x81 +#define ANX9804_SYS_CTRL2_CHA_STA 0x04 + +#define ANX9804_SYS_CTRL3_REG 0x82 +#define ANX9804_SYS_CTRL3_VALID_CTRL BIT(0) +#define ANX9804_SYS_CTRL3_F_VALID BIT(1) +#define ANX9804_SYS_CTRL3_HPD_CTRL BIT(4) +#define ANX9804_SYS_CTRL3_F_HPD BIT(5) + +#define ANX9804_LINK_BW_SET_REG 0xa0 +#define ANX9804_LANE_COUNT_SET_REG 0xa1 +#define ANX9804_TRAINING_PTN_SET_REG 0xa2 +#define ANX9804_TRAINING_LANE0_SET_REG 0xa3 +#define ANX9804_TRAINING_LANE1_SET_REG 0xa4 +#define ANX9804_TRAINING_LANE2_SET_REG 0xa5 +#define ANX9804_TRAINING_LANE3_SET_REG 0xa6 + +#define ANX9804_LINK_TRAINING_CTRL_REG 0xa8 +#define ANX9804_LINK_TRAINING_CTRL_EN BIT(0) + +#define ANX9804_LINK_DEBUG_REG 0xb8 +#define ANX9804_PLL_CTRL_REG 0xc7 +#define ANX9804_ANALOG_POWER_DOWN_REG 0xc8 + +#define ANX9804_AUX_CH_STA 0xe0 +#define ANX9804_AUX_BUSY BIT(4) +#define ANX9804_AUX_STATUS_MASK 0x0f + +#define ANX9804_DP_AUX_RX_COMM 0xe3 +#define ANX9804_AUX_RX_COMM_I2C_DEFER BIT(3) +#define ANX9804_AUX_RX_COMM_AUX_DEFER BIT(1) + +#define ANX9804_DP_AUX_CH_CTL_1 0xe5 +#define ANX9804_AUX_LENGTH(x) (((x - 1) & 0x0f) << 4) +#define ANX9804_AUX_TX_COMM_MASK 0x0f +#define ANX9804_AUX_TX_COMM_DP_TRANSACTION BIT(3) +#define ANX9804_AUX_TX_COMM_MOT BIT(2) +#define ANX9804_AUX_TX_COMM_READ BIT(0) + +#define ANX9804_DP_AUX_ADDR_7_0 0xe6 +#define ANX9804_DP_AUX_ADDR_15_8 0xe7 +#define ANX9804_DP_AUX_ADDR_19_16 0xe8 + +#define ANX9804_DP_AUX_CH_CTL_2 0xe9 +#define ANX9804_ADDR_ONLY BIT(1) +#define ANX9804_AUX_EN BIT(0) + +#define ANX9804_BUF_DATA_0 0xf0 + +/* Registers at i2c address 0x39 */ + +#define ANX9804_DEV_IDH_REG 0x03 + +#define ANX9804_POWERD_CTRL_REG 0x05 +#define ANX9804_POWERD_AUDIO BIT(4) + +#define ANX9804_RST_CTRL_REG 0x06 + +#define ANX9804_RST_CTRL2_REG 0x07 +#define ANX9804_RST_CTRL2_AUX BIT(2) +#define ANX9804_RST_CTRL2_AC_MODE BIT(6) + +#define ANX9804_VID_CTRL1_REG 0x08 +#define ANX9804_VID_CTRL1_VID_EN BIT(7) +#define ANX9804_VID_CTRL1_EDGE BIT(0) + +#define ANX9804_VID_CTRL2_REG 0x09 +#define ANX9804_ANALOG_DEBUG_REG1 0xdc +#define ANX9804_ANALOG_DEBUG_REG3 0xde +#define ANX9804_PLL_FILTER_CTRL1 0xdf +#define ANX9804_PLL_FILTER_CTRL3 0xe1 +#define ANX9804_PLL_FILTER_CTRL 0xe2 +#define ANX9804_PLL_CTRL3 0xe6 + +#define ANX9804_DP_INT_STA 0xf7 +#define ANX9804_RPLY_RECEIV BIT(1) +#define ANX9804_AUX_ERR BIT(0)
Signed-off-by: Vasily Khoruzhick anarsoul@gmail.com Signed-off-by: Anatolij Gustschin agust@denx.de --- v3: - moved header to drivers/video v2: - no changes
drivers/video/anx9804.c | 54 +------------------------ drivers/video/anx98xx-edp.h | 98 +++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 99 insertions(+), 53 deletions(-) create mode 100644 drivers/video/anx98xx-edp.h
diff --git a/drivers/video/anx9804.c b/drivers/video/anx9804.c index 37ad69a039..3910458bf1 100755 --- a/drivers/video/anx9804.c +++ b/drivers/video/anx9804.c @@ -12,61 +12,9 @@
#include <common.h> #include <i2c.h> +#include "anx98xx-edp.h" #include "anx9804.h"
-/* Registers at i2c address 0x38 */ - -#define ANX9804_HDCP_CONTROL_0_REG 0x01 - -#define ANX9804_SYS_CTRL2_REG 0x81 -#define ANX9804_SYS_CTRL2_CHA_STA 0x04 - -#define ANX9804_SYS_CTRL3_REG 0x82 -#define ANX9804_SYS_CTRL3_VALID_CTRL BIT(0) -#define ANX9804_SYS_CTRL3_F_VALID BIT(1) -#define ANX9804_SYS_CTRL3_HPD_CTRL BIT(4) -#define ANX9804_SYS_CTRL3_F_HPD BIT(5) - -#define ANX9804_LINK_BW_SET_REG 0xa0 -#define ANX9804_LANE_COUNT_SET_REG 0xa1 -#define ANX9804_TRAINING_PTN_SET_REG 0xa2 -#define ANX9804_TRAINING_LANE0_SET_REG 0xa3 -#define ANX9804_TRAINING_LANE1_SET_REG 0xa4 -#define ANX9804_TRAINING_LANE2_SET_REG 0xa5 -#define ANX9804_TRAINING_LANE3_SET_REG 0xa6 - -#define ANX9804_LINK_TRAINING_CTRL_REG 0xa8 -#define ANX9804_LINK_TRAINING_CTRL_EN BIT(0) - -#define ANX9804_LINK_DEBUG_REG 0xb8 -#define ANX9804_PLL_CTRL_REG 0xc7 -#define ANX9804_ANALOG_POWER_DOWN_REG 0xc8 - -/* Registers at i2c address 0x39 */ - -#define ANX9804_DEV_IDH_REG 0x03 - -#define ANX9804_POWERD_CTRL_REG 0x05 -#define ANX9804_POWERD_AUDIO BIT(4) - -#define ANX9804_RST_CTRL_REG 0x06 - -#define ANX9804_RST_CTRL2_REG 0x07 -#define ANX9804_RST_CTRL2_AUX BIT(2) -#define ANX9804_RST_CTRL2_AC_MODE BIT(6) - -#define ANX9804_VID_CTRL1_REG 0x08 -#define ANX9804_VID_CTRL1_VID_EN BIT(7) -#define ANX9804_VID_CTRL1_EDGE BIT(0) - -#define ANX9804_VID_CTRL2_REG 0x09 -#define ANX9804_ANALOG_DEBUG_REG1 0xdc -#define ANX9804_ANALOG_DEBUG_REG3 0xde -#define ANX9804_PLL_FILTER_CTRL1 0xdf -#define ANX9804_PLL_FILTER_CTRL3 0xe1 -#define ANX9804_PLL_FILTER_CTRL 0xe2 -#define ANX9804_PLL_CTRL3 0xe6 - /** * anx9804_init() - Init anx9804 parallel lcd to edp bridge chip * diff --git a/drivers/video/anx98xx-edp.h b/drivers/video/anx98xx-edp.h new file mode 100644 index 0000000000..f7e8baa167 --- /dev/null +++ b/drivers/video/anx98xx-edp.h @@ -0,0 +1,98 @@ +/* + * Copyright (C) 2015 Hans de Goede hdegoede@redhat.com + * Copyright (C) 2017 Vasily Khoruzhick anarsoul@gmail.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/* Registers at i2c address 0x38 */ + +#define ANX9804_HDCP_CONTROL_0_REG 0x01 + +#define ANX9804_SYS_CTRL1_REG 0x80 +#define ANX9804_SYS_CTRL1_PD_IO 0x80 +#define ANX9804_SYS_CTRL1_PD_VID 0x40 +#define ANX9804_SYS_CTRL1_PD_LINK 0x20 +#define ANX9804_SYS_CTRL1_PD_TOTAL 0x10 +#define ANX9804_SYS_CTRL1_MODE_SEL 0x08 +#define ANX9804_SYS_CTRL1_DET_STA 0x04 +#define ANX9804_SYS_CTRL1_FORCE_DET 0x02 +#define ANX9804_SYS_CTRL1_DET_CTRL 0x01 + +#define ANX9804_SYS_CTRL2_REG 0x81 +#define ANX9804_SYS_CTRL2_CHA_STA 0x04 + +#define ANX9804_SYS_CTRL3_REG 0x82 +#define ANX9804_SYS_CTRL3_VALID_CTRL BIT(0) +#define ANX9804_SYS_CTRL3_F_VALID BIT(1) +#define ANX9804_SYS_CTRL3_HPD_CTRL BIT(4) +#define ANX9804_SYS_CTRL3_F_HPD BIT(5) + +#define ANX9804_LINK_BW_SET_REG 0xa0 +#define ANX9804_LANE_COUNT_SET_REG 0xa1 +#define ANX9804_TRAINING_PTN_SET_REG 0xa2 +#define ANX9804_TRAINING_LANE0_SET_REG 0xa3 +#define ANX9804_TRAINING_LANE1_SET_REG 0xa4 +#define ANX9804_TRAINING_LANE2_SET_REG 0xa5 +#define ANX9804_TRAINING_LANE3_SET_REG 0xa6 + +#define ANX9804_LINK_TRAINING_CTRL_REG 0xa8 +#define ANX9804_LINK_TRAINING_CTRL_EN BIT(0) + +#define ANX9804_LINK_DEBUG_REG 0xb8 +#define ANX9804_PLL_CTRL_REG 0xc7 +#define ANX9804_ANALOG_POWER_DOWN_REG 0xc8 + +#define ANX9804_AUX_CH_STA 0xe0 +#define ANX9804_AUX_BUSY BIT(4) +#define ANX9804_AUX_STATUS_MASK 0x0f + +#define ANX9804_DP_AUX_RX_COMM 0xe3 +#define ANX9804_AUX_RX_COMM_I2C_DEFER BIT(3) +#define ANX9804_AUX_RX_COMM_AUX_DEFER BIT(1) + +#define ANX9804_DP_AUX_CH_CTL_1 0xe5 +#define ANX9804_AUX_LENGTH(x) (((x - 1) & 0x0f) << 4) +#define ANX9804_AUX_TX_COMM_MASK 0x0f +#define ANX9804_AUX_TX_COMM_DP_TRANSACTION BIT(3) +#define ANX9804_AUX_TX_COMM_MOT BIT(2) +#define ANX9804_AUX_TX_COMM_READ BIT(0) + +#define ANX9804_DP_AUX_ADDR_7_0 0xe6 +#define ANX9804_DP_AUX_ADDR_15_8 0xe7 +#define ANX9804_DP_AUX_ADDR_19_16 0xe8 + +#define ANX9804_DP_AUX_CH_CTL_2 0xe9 +#define ANX9804_ADDR_ONLY BIT(1) +#define ANX9804_AUX_EN BIT(0) + +#define ANX9804_BUF_DATA_0 0xf0 + +/* Registers at i2c address 0x39 */ + +#define ANX9804_DEV_IDH_REG 0x03 + +#define ANX9804_POWERD_CTRL_REG 0x05 +#define ANX9804_POWERD_AUDIO BIT(4) + +#define ANX9804_RST_CTRL_REG 0x06 + +#define ANX9804_RST_CTRL2_REG 0x07 +#define ANX9804_RST_CTRL2_AUX BIT(2) +#define ANX9804_RST_CTRL2_AC_MODE BIT(6) + +#define ANX9804_VID_CTRL1_REG 0x08 +#define ANX9804_VID_CTRL1_VID_EN BIT(7) +#define ANX9804_VID_CTRL1_EDGE BIT(0) + +#define ANX9804_VID_CTRL2_REG 0x09 +#define ANX9804_ANALOG_DEBUG_REG1 0xdc +#define ANX9804_ANALOG_DEBUG_REG3 0xde +#define ANX9804_PLL_FILTER_CTRL1 0xdf +#define ANX9804_PLL_FILTER_CTRL3 0xe1 +#define ANX9804_PLL_FILTER_CTRL 0xe2 +#define ANX9804_PLL_CTRL3 0xe6 + +#define ANX9804_DP_INT_STA 0xf7 +#define ANX9804_RPLY_RECEIV BIT(1) +#define ANX9804_AUX_ERR BIT(0)
-- Anatolij
This is a eDP bridge similar to ANX9804, it allows to connect eDP panels to the chips that can output only parallel signal
Signed-off-by: Vasily Khoruzhick anarsoul@gmail.com Signed-off-by: Anatolij Gustschin agust@denx.de --- v3: - fixed checkpatch errors/warnings v2: - no changes
drivers/video/bridge/Kconfig | 8 + drivers/video/bridge/Makefile | 1 + drivers/video/bridge/anx6345.c | 426 +++++++++++++++++++++++++++++++++++++++++ 3 files changed, 435 insertions(+) create mode 100644 drivers/video/bridge/anx6345.c
diff --git a/drivers/video/bridge/Kconfig b/drivers/video/bridge/Kconfig index 2a3b6c4bee..765f7380b8 100644 --- a/drivers/video/bridge/Kconfig +++ b/drivers/video/bridge/Kconfig @@ -25,3 +25,11 @@ config VIDEO_BRIDGE_NXP_PTN3460 signalling) converter. It enables an LVDS LCD panel to be connected to an eDP output device such as an SoC that lacks LVDS capability, or where LVDS requires too many signals to route on the PCB. + +config VIDEO_BRIDGE_ANALOGIX_ANX6345 + bool "Support Analogix ANX6345 RGB->DP bridge" + depends on VIDEO_BRIDGE + select DM_I2C + help + The Analogix ANX6345 is RGB-to-DP converter. It enables an eDP LCD + panel to be connected to an parallel LCD interface. diff --git a/drivers/video/bridge/Makefile b/drivers/video/bridge/Makefile index ce731fa4ca..2a746c6f8b 100644 --- a/drivers/video/bridge/Makefile +++ b/drivers/video/bridge/Makefile @@ -7,3 +7,4 @@ obj-$(CONFIG_VIDEO_BRIDGE) += video-bridge-uclass.o obj-$(CONFIG_VIDEO_BRIDGE_PARADE_PS862X) += ps862x.o obj-$(CONFIG_VIDEO_BRIDGE_NXP_PTN3460) += ptn3460.o +obj-$(CONFIG_VIDEO_BRIDGE_ANALOGIX_ANX6345) += anx6345.o diff --git a/drivers/video/bridge/anx6345.c b/drivers/video/bridge/anx6345.c new file mode 100644 index 0000000000..0a94affb9f --- /dev/null +++ b/drivers/video/bridge/anx6345.c @@ -0,0 +1,426 @@ +/* + * Copyright (C) 2017 Vasily Khoruzhick anarsoul@gmail.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <dm.h> +#include <errno.h> +#include <i2c.h> +#include <edid.h> +#include <video_bridge.h> +#include "../anx98xx-edp.h" + +#define DP_MAX_LINK_RATE 0x001 +#define DP_MAX_LANE_COUNT 0x002 +#define DP_MAX_LANE_COUNT_MASK 0x1f + +DECLARE_GLOBAL_DATA_PTR; + +struct anx6345_priv { + u8 edid[EDID_SIZE]; +}; + +static int anx6345_write(struct udevice *dev, unsigned int addr_off, + unsigned char reg_addr, unsigned char value) +{ + uint8_t buf[2]; + struct i2c_msg msg; + int ret; + + msg.addr = addr_off; + msg.flags = 0; + buf[0] = reg_addr; + buf[1] = value; + msg.buf = buf; + msg.len = 2; + ret = dm_i2c_xfer(dev, &msg, 1); + if (ret) { + debug("%s: write failed, reg=%#x, value=%#x, ret=%d\n", + __func__, reg_addr, value, ret); + return ret; + } + + return 0; +} + +static int anx6345_read(struct udevice *dev, unsigned int addr_off, + unsigned char reg_addr, unsigned char *value) +{ + uint8_t addr, val; + struct i2c_msg msg[2]; + int ret; + + msg[0].addr = addr_off; + msg[0].flags = 0; + addr = reg_addr; + msg[0].buf = &addr; + msg[0].len = 1; + msg[1].addr = addr_off; + msg[1].flags = I2C_M_RD; + msg[1].buf = &val; + msg[1].len = 1; + ret = dm_i2c_xfer(dev, msg, 2); + if (ret) { + debug("%s: read failed, reg=%.2x, value=%p, ret=%d\n", + __func__, (int)reg_addr, value, ret); + return ret; + } + *value = val; + + return 0; +} + +static int anx6345_write_r0(struct udevice *dev, unsigned char reg_addr, + unsigned char value) +{ + struct dm_i2c_chip *chip = dev_get_parent_platdata(dev); + + return anx6345_write(dev, chip->chip_addr, reg_addr, value); +} + +static int anx6345_read_r0(struct udevice *dev, unsigned char reg_addr, + unsigned char *value) +{ + struct dm_i2c_chip *chip = dev_get_parent_platdata(dev); + + return anx6345_read(dev, chip->chip_addr, reg_addr, value); +} + +static int anx6345_write_r1(struct udevice *dev, unsigned char reg_addr, + unsigned char value) +{ + struct dm_i2c_chip *chip = dev_get_parent_platdata(dev); + + return anx6345_write(dev, chip->chip_addr + 1, reg_addr, value); +} + +static int anx6345_read_r1(struct udevice *dev, unsigned char reg_addr, + unsigned char *value) +{ + struct dm_i2c_chip *chip = dev_get_parent_platdata(dev); + + return anx6345_read(dev, chip->chip_addr + 1, reg_addr, value); +} + +static int anx6345_set_backlight(struct udevice *dev, int percent) +{ + return -ENOSYS; +} + +static int anx6345_aux_wait(struct udevice *dev) +{ + int ret = -ETIMEDOUT; + u8 v; + int retries = 1000; + + do { + anx6345_read_r0(dev, ANX9804_DP_AUX_CH_CTL_2, &v); + if (!(v & ANX9804_AUX_EN)) { + ret = 0; + break; + } + udelay(100); + } while (retries--); + + if (ret) { + debug("%s: timed out waiting for AUX_EN to clear\n", __func__); + return ret; + } + + ret = -ETIMEDOUT; + retries = 1000; + do { + anx6345_read_r1(dev, ANX9804_DP_INT_STA, &v); + if (v & ANX9804_RPLY_RECEIV) { + ret = 0; + break; + } + udelay(100); + } while (retries--); + + if (ret) { + debug("%s: timed out waiting to receive reply\n", __func__); + return ret; + } + + /* Clear RPLY_RECEIV bit */ + anx6345_write_r1(dev, ANX9804_DP_INT_STA, v); + + anx6345_read_r0(dev, ANX9804_AUX_CH_STA, &v); + if ((v & ANX9804_AUX_STATUS_MASK) != 0) { + debug("AUX status: %d\n", v & ANX9804_AUX_STATUS_MASK); + ret = -EIO; + } + + return ret; +} + +static void anx6345_aux_addr(struct udevice *dev, u32 addr) +{ + u8 val; + + val = addr & 0xff; + anx6345_write_r0(dev, ANX9804_DP_AUX_ADDR_7_0, val); + val = (addr >> 8) & 0xff; + anx6345_write_r0(dev, ANX9804_DP_AUX_ADDR_15_8, val); + val = (addr >> 16) & 0x0f; + anx6345_write_r0(dev, ANX9804_DP_AUX_ADDR_19_16, val); +} + +static int anx6345_aux_transfer(struct udevice *dev, u8 req, + u32 addr, u8 *buf, size_t len) +{ + int i, ret; + u8 ctrl1 = req; + u8 ctrl2 = ANX9804_AUX_EN; + + if (len > 16) + return -E2BIG; + + if (len) + ctrl1 |= ANX9804_AUX_LENGTH(len); + else + ctrl2 |= ANX9804_ADDR_ONLY; + + if (len && !(req & ANX9804_AUX_TX_COMM_READ)) { + for (i = 0; i < len; i++) + anx6345_write_r0(dev, ANX9804_BUF_DATA_0 + i, buf[i]); + } + + anx6345_aux_addr(dev, addr); + anx6345_write_r0(dev, ANX9804_DP_AUX_CH_CTL_1, ctrl1); + anx6345_write_r0(dev, ANX9804_DP_AUX_CH_CTL_2, ctrl2); + ret = anx6345_aux_wait(dev); + if (ret) { + debug("AUX transaction timed out\n"); + return ret; + } + + if (len && (req & ANX9804_AUX_TX_COMM_READ)) { + for (i = 0; i < len; i++) + anx6345_read_r0(dev, ANX9804_BUF_DATA_0 + i, &buf[i]); + } + + return 0; +} + +static int anx6345_read_aux_i2c(struct udevice *dev, u8 chip_addr, + u8 offset, size_t count, u8 *buf) +{ + int i, ret; + size_t cur_cnt; + u8 cur_offset; + + for (i = 0; i < count; i += 16) { + cur_cnt = (count - i) > 16 ? 16 : count - i; + cur_offset = offset + i; + ret = anx6345_aux_transfer(dev, ANX9804_AUX_TX_COMM_MOT, + chip_addr, &cur_offset, 1); + if (ret) { + debug("%s: failed to set i2c offset: %d\n", + __func__, ret); + return ret; + } + ret = anx6345_aux_transfer(dev, ANX9804_AUX_TX_COMM_READ, + chip_addr, buf + i, cur_cnt); + if (ret) { + debug("%s: failed to read from i2c device: %d\n", + __func__, ret); + return ret; + } + } + + return 0; +} + +static int anx6345_read_dpcd(struct udevice *dev, u32 reg, u8 *val) +{ + int ret; + + ret = anx6345_aux_transfer(dev, + ANX9804_AUX_TX_COMM_READ | + ANX9804_AUX_TX_COMM_DP_TRANSACTION, + reg, val, 1); + if (ret) { + debug("Failed to read DPCD\n"); + return ret; + } + + return 0; +} + +static int anx6345_read_edid(struct udevice *dev, u8 *buf, int size) +{ + struct anx6345_priv *priv = dev_get_priv(dev); + + if (size > EDID_SIZE) + size = EDID_SIZE; + memcpy(buf, priv->edid, size); + + return size; +} + +static int anx6345_attach(struct udevice *dev) +{ + /* No-op */ + return 0; +} + +static int anx6345_enable(struct udevice *dev) +{ + u8 chipid, colordepth, lanes, data_rate, c; + int ret, i, bpp; + struct display_timing timing; + struct anx6345_priv *priv = dev_get_priv(dev); + + /* Deassert reset and enable power */ + ret = video_bridge_set_active(dev, true); + if (ret) + return ret; + + /* Reset */ + anx6345_write_r1(dev, ANX9804_RST_CTRL_REG, 1); + mdelay(100); + anx6345_write_r1(dev, ANX9804_RST_CTRL_REG, 0); + + /* Write 0 to the powerdown reg (powerup everything) */ + anx6345_write_r1(dev, ANX9804_POWERD_CTRL_REG, 0); + + ret = anx6345_read_r1(dev, ANX9804_DEV_IDH_REG, &chipid); + if (ret) + debug("%s: read id failed: %d\n", __func__, ret); + + switch (chipid) { + case 0x63: + debug("ANX63xx detected.\n"); + break; + default: + debug("Error anx6345 chipid mismatch: %.2x\n", (int)chipid); + return -ENODEV; + } + + for (i = 0; i < 100; i++) { + anx6345_read_r0(dev, ANX9804_SYS_CTRL2_REG, &c); + anx6345_write_r0(dev, ANX9804_SYS_CTRL2_REG, c); + anx6345_read_r0(dev, ANX9804_SYS_CTRL2_REG, &c); + if ((c & ANX9804_SYS_CTRL2_CHA_STA) == 0) + break; + + mdelay(5); + } + if (i == 100) + debug("Error anx6345 clock is not stable\n"); + + /* Set a bunch of analog related register values */ + anx6345_write_r0(dev, ANX9804_PLL_CTRL_REG, 0x00); + anx6345_write_r1(dev, ANX9804_ANALOG_DEBUG_REG1, 0x70); + anx6345_write_r0(dev, ANX9804_LINK_DEBUG_REG, 0x30); + + /* Force HPD */ + anx6345_write_r0(dev, ANX9804_SYS_CTRL3_REG, + ANX9804_SYS_CTRL3_F_HPD | ANX9804_SYS_CTRL3_HPD_CTRL); + + /* Power up and configure lanes */ + anx6345_write_r0(dev, ANX9804_ANALOG_POWER_DOWN_REG, 0x00); + anx6345_write_r0(dev, ANX9804_TRAINING_LANE0_SET_REG, 0x00); + anx6345_write_r0(dev, ANX9804_TRAINING_LANE1_SET_REG, 0x00); + anx6345_write_r0(dev, ANX9804_TRAINING_LANE2_SET_REG, 0x00); + anx6345_write_r0(dev, ANX9804_TRAINING_LANE3_SET_REG, 0x00); + + /* Reset AUX CH */ + anx6345_write_r1(dev, ANX9804_RST_CTRL2_REG, + ANX9804_RST_CTRL2_AUX); + anx6345_write_r1(dev, ANX9804_RST_CTRL2_REG, 0); + + /* Powerdown audio and some other unused bits */ + anx6345_write_r1(dev, ANX9804_POWERD_CTRL_REG, ANX9804_POWERD_AUDIO); + anx6345_write_r0(dev, ANX9804_HDCP_CONTROL_0_REG, 0x00); + anx6345_write_r0(dev, 0xa7, 0x00); + + anx6345_read_aux_i2c(dev, 0x50, 0x0, EDID_SIZE, priv->edid); + if (edid_get_timing(priv->edid, EDID_SIZE, &timing, &bpp) != 0) { + debug("Failed to parse EDID\n"); + return -EIO; + } + debug("%s: panel found: %dx%d, bpp %d\n", __func__, + timing.hactive.typ, timing.vactive.typ, bpp); + if (bpp == 6) + colordepth = 0x00; /* 6 bit */ + else + colordepth = 0x10; /* 8 bit */ + anx6345_write_r1(dev, ANX9804_VID_CTRL2_REG, colordepth); + + if (anx6345_read_dpcd(dev, DP_MAX_LINK_RATE, &data_rate)) { + debug("%s: Failed to DP_MAX_LINK_RATE\n", __func__); + return -EIO; + } + debug("%s: data_rate: %d\n", __func__, (int)data_rate); + if (anx6345_read_dpcd(dev, DP_MAX_LANE_COUNT, &lanes)) { + debug("%s: Failed to read DP_MAX_LANE_COUNT\n", __func__); + return -EIO; + } + lanes &= DP_MAX_LANE_COUNT_MASK; + debug("%s: lanes: %d\n", __func__, (int)lanes); + + /* Set data-rate / lanes */ + anx6345_write_r0(dev, ANX9804_LINK_BW_SET_REG, data_rate); + anx6345_write_r0(dev, ANX9804_LANE_COUNT_SET_REG, lanes); + + /* Link training */ + anx6345_write_r0(dev, ANX9804_LINK_TRAINING_CTRL_REG, + ANX9804_LINK_TRAINING_CTRL_EN); + mdelay(5); + for (i = 0; i < 100; i++) { + anx6345_read_r0(dev, ANX9804_LINK_TRAINING_CTRL_REG, &c); + if ((chipid == 0x63) && (c & 0x80) == 0) + break; + + mdelay(5); + } + if (i == 100) { + debug("Error anx6345 link training timeout\n"); + return -ENODEV; + } + + /* Enable */ + anx6345_write_r1(dev, ANX9804_VID_CTRL1_REG, + ANX9804_VID_CTRL1_VID_EN | ANX9804_VID_CTRL1_EDGE); + /* Force stream valid */ + anx6345_write_r0(dev, ANX9804_SYS_CTRL3_REG, + ANX9804_SYS_CTRL3_F_HPD | + ANX9804_SYS_CTRL3_HPD_CTRL | + ANX9804_SYS_CTRL3_F_VALID | + ANX9804_SYS_CTRL3_VALID_CTRL); + + return 0; +} + +static int anx6345_probe(struct udevice *dev) +{ + if (device_get_uclass_id(dev->parent) != UCLASS_I2C) + return -EPROTONOSUPPORT; + + return anx6345_enable(dev); +} + +struct video_bridge_ops anx6345_ops = { + .attach = anx6345_attach, + .set_backlight = anx6345_set_backlight, + .read_edid = anx6345_read_edid, +}; + +static const struct udevice_id anx6345_ids[] = { + { .compatible = "analogix,anx6345", }, + { } +}; + +U_BOOT_DRIVER(analogix_anx6345) = { + .name = "analogix_anx6345", + .id = UCLASS_VIDEO_BRIDGE, + .of_match = anx6345_ids, + .probe = anx6345_probe, + .ops = &anx6345_ops, + .priv_auto_alloc_size = sizeof(struct anx6345_priv), +};
-- Anatolij
drivers/video/bridge/Kconfig | 8 + drivers/video/bridge/Makefile | 1 + drivers/video/bridge/anx6345.c | 419 +++++++++++++++++++++++++++++++++++++++++ 3 files changed, 428 insertions(+) create mode 100644 drivers/video/bridge/anx6345.c
diff --git a/drivers/video/bridge/Kconfig b/drivers/video/bridge/Kconfig index 2a3b6c4bee..765f7380b8 100644 --- a/drivers/video/bridge/Kconfig +++ b/drivers/video/bridge/Kconfig @@ -25,3 +25,11 @@ config VIDEO_BRIDGE_NXP_PTN3460 signalling) converter. It enables an LVDS LCD panel to be connected to an eDP output device such as an SoC that lacks LVDS capability, or where LVDS requires too many signals to route on the PCB. + +config VIDEO_BRIDGE_ANALOGIX_ANX6345 + bool "Support Analogix ANX6345 RGB->DP bridge" + depends on VIDEO_BRIDGE + select DM_I2C + help + The Analogix ANX6345 is RGB-to-DP converter. It enables an eDP LCD + panel to be connected to an parallel LCD interface. diff --git a/drivers/video/bridge/Makefile b/drivers/video/bridge/Makefile index ce731fa4ca..2a746c6f8b 100644 --- a/drivers/video/bridge/Makefile +++ b/drivers/video/bridge/Makefile @@ -7,3 +7,4 @@ obj-$(CONFIG_VIDEO_BRIDGE) += video-bridge-uclass.o obj-$(CONFIG_VIDEO_BRIDGE_PARADE_PS862X) += ps862x.o obj-$(CONFIG_VIDEO_BRIDGE_NXP_PTN3460) += ptn3460.o +obj-$(CONFIG_VIDEO_BRIDGE_ANALOGIX_ANX6345) += anx6345.o diff --git a/drivers/video/bridge/anx6345.c b/drivers/video/bridge/anx6345.c new file mode 100644 index 0000000000..6bac9a51a9 --- /dev/null +++ b/drivers/video/bridge/anx6345.c @@ -0,0 +1,419 @@ +/* + * Copyright (C) 2017 Vasily Khoruzhick anarsoul@gmail.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <dm.h> +#include <errno.h> +#include <i2c.h> +#include <edid.h> +#include <video_bridge.h> +#include <anx98xx-edp.h> + +#define DP_MAX_LINK_RATE 0x001 +#define DP_MAX_LANE_COUNT 0x002 +#define DP_MAX_LANE_COUNT_MASK 0x1f + +DECLARE_GLOBAL_DATA_PTR; + +struct anx6345_priv { + u8 edid[EDID_SIZE]; +}; + +static int anx6345_write(struct udevice *dev, unsigned addr_off, + unsigned char reg_addr, unsigned char value) +{ + uint8_t buf[2]; + struct i2c_msg msg; + int ret; + + msg.addr = addr_off; + msg.flags = 0; + buf[0] = reg_addr; + buf[1] = value; + msg.buf = buf; + msg.len = 2; + ret = dm_i2c_xfer(dev, &msg, 1); + if (ret) { + debug("%s: write failed, reg=%#x, value=%#x, ret=%d\n", + __func__, reg_addr, value, ret); + return ret; + } + + return 0; +} + +static int anx6345_read(struct udevice *dev, unsigned addr_off, + unsigned char reg_addr, unsigned char *value) +{ + uint8_t addr, val; + struct i2c_msg msg[2]; + int ret; + + msg[0].addr = addr_off; + msg[0].flags = 0; + addr = reg_addr; + msg[0].buf = &addr; + msg[0].len = 1; + msg[1].addr = addr_off; + msg[1].flags = I2C_M_RD; + msg[1].buf = &val; + msg[1].len = 1; + ret = dm_i2c_xfer(dev, msg, 2); + if (ret) { + debug("%s: read failed, reg=%.2x, value=%p, ret=%d\n", + __func__, (int)reg_addr, value, ret); + return ret; + } + *value = val; + + return 0; +} + +static int anx6345_write_r0(struct udevice *dev, unsigned char reg_addr, + unsigned char value) +{ + struct dm_i2c_chip *chip = dev_get_parent_platdata(dev); + return anx6345_write(dev, chip->chip_addr, reg_addr, value); +} + +static int anx6345_read_r0(struct udevice *dev, unsigned char reg_addr, + unsigned char *value) +{ + struct dm_i2c_chip *chip = dev_get_parent_platdata(dev); + return anx6345_read(dev, chip->chip_addr, reg_addr, value); +} + +static int anx6345_write_r1(struct udevice *dev, unsigned char reg_addr, + unsigned char value) +{ + struct dm_i2c_chip *chip = dev_get_parent_platdata(dev); + return anx6345_write(dev, chip->chip_addr + 1, reg_addr, value); +} + +static int anx6345_read_r1(struct udevice *dev, unsigned char reg_addr, + unsigned char *value) +{ + struct dm_i2c_chip *chip = dev_get_parent_platdata(dev); + return anx6345_read(dev, chip->chip_addr + 1, reg_addr, value); +} + +static int anx6345_set_backlight(struct udevice *dev, int percent) +{ + return -ENOSYS; +} + +static int anx6345_aux_wait(struct udevice *dev) +{ + int ret = -ETIMEDOUT; + u8 v; + int retries = 1000; + do { + anx6345_read_r0(dev, ANX9804_DP_AUX_CH_CTL_2, &v); + if (!(v & ANX9804_AUX_EN)) { + ret = 0; + break; + } + udelay(100); + } while (retries--); + + if (ret) { + debug("%s: timed out waiting for AUX_EN to clear\n", __func__); + return ret; + } + + ret = -ETIMEDOUT; + retries = 1000; + do { + anx6345_read_r1(dev, ANX9804_DP_INT_STA, &v); + if (v & ANX9804_RPLY_RECEIV) { + ret = 0; + break; + } + udelay(100); + } while (retries--); + + if (ret) { + debug("%s: timed out waiting to receive reply\n", __func__); + return ret; + } + + /* Clear RPLY_RECEIV bit */ + anx6345_write_r1(dev, ANX9804_DP_INT_STA, v); + + anx6345_read_r0(dev, ANX9804_AUX_CH_STA, &v); + if ((v & ANX9804_AUX_STATUS_MASK) != 0) { + debug("AUX status: %d\n", v & ANX9804_AUX_STATUS_MASK); + ret = -EIO; + } + + return ret; +} + +static void anx6345_aux_addr(struct udevice *dev, u32 addr) +{ + u8 val; + + val = addr & 0xff; + anx6345_write_r0(dev, ANX9804_DP_AUX_ADDR_7_0, val); + val = (addr >> 8) & 0xff; + anx6345_write_r0(dev, ANX9804_DP_AUX_ADDR_15_8, val); + val = (addr >> 16) & 0x0f; + anx6345_write_r0(dev, ANX9804_DP_AUX_ADDR_19_16, val); +} + +static int anx6345_aux_transfer(struct udevice *dev, u8 req, u32 addr, u8 *buf, size_t len) +{ + int i, ret; + u8 ctrl1 = req; + u8 ctrl2 = ANX9804_AUX_EN; + + if (len > 16) + return -E2BIG; + + if (len) + ctrl1 |= ANX9804_AUX_LENGTH(len); + else + ctrl2 |= ANX9804_ADDR_ONLY; + + if (len && !(req & ANX9804_AUX_TX_COMM_READ)) { + for (i = 0; i < len; i++) + anx6345_write_r0(dev, ANX9804_BUF_DATA_0 + i, buf[i]); + } + + anx6345_aux_addr(dev, addr); + anx6345_write_r0(dev, ANX9804_DP_AUX_CH_CTL_1, ctrl1); + anx6345_write_r0(dev, ANX9804_DP_AUX_CH_CTL_2, ctrl2); + ret = anx6345_aux_wait(dev); + if (ret) { + debug("AUX transaction timed out\n"); + return ret; + } + + if (len && (req & ANX9804_AUX_TX_COMM_READ)) { + for (i = 0; i < len; i++) + anx6345_read_r0(dev, ANX9804_BUF_DATA_0 + i, &buf[i]); + } + + return 0; + +} + +static int anx6345_read_aux_i2c(struct udevice *dev, u8 chip_addr, + u8 offset, + size_t count, + u8 *buf) +{ + int i, ret; + size_t cur_cnt; + u8 cur_offset; + for (i = 0; i < count; i += 16) { + cur_cnt = (count - i) > 16 ? 16 : count - i; + cur_offset = offset + i; + ret = anx6345_aux_transfer(dev, ANX9804_AUX_TX_COMM_MOT, + chip_addr, &cur_offset, 1); + if (ret) { + debug("%s: failed to set i2c offset: %d\n", __func__, ret); + return ret; + } + ret = anx6345_aux_transfer(dev, ANX9804_AUX_TX_COMM_READ, + chip_addr, buf + i, cur_cnt); + if (ret) { + debug("%s: failed to read from i2c device: %d\n", __func__, ret); + return ret; + } + } + + return 0; +} + +static int anx6345_read_dpcd(struct udevice *dev, u32 reg, u8 *val) +{ + int ret; + + ret = anx6345_aux_transfer(dev, + ANX9804_AUX_TX_COMM_READ | + ANX9804_AUX_TX_COMM_DP_TRANSACTION, + reg, val, 1); + if (ret) { + debug ("Failed to read DPCD\n"); + return ret; + } + + return 0; +} + +static int anx6345_read_edid(struct udevice *dev, u8 *buf, int size) +{ + struct anx6345_priv *priv = dev_get_priv(dev); + + if (size > EDID_SIZE) + size = EDID_SIZE; + memcpy(buf, priv->edid, size); + + return size; +} + +static int anx6345_attach(struct udevice *dev) +{ + /* No-op */ + return 0; +} + +static int anx6345_enable(struct udevice *dev) +{ + u8 chipid, colordepth, lanes, data_rate, c; + int ret, i, bpp; + struct display_timing timing; + struct anx6345_priv *priv = dev_get_priv(dev); + + /* Deassert reset and enable power */ + ret = video_bridge_set_active(dev, true); + if (ret) + return ret; + + /* Reset */ + anx6345_write_r1(dev, ANX9804_RST_CTRL_REG, 1); + mdelay(100); + anx6345_write_r1(dev, ANX9804_RST_CTRL_REG, 0); + + /* Write 0 to the powerdown reg (powerup everything) */ + anx6345_write_r1(dev, ANX9804_POWERD_CTRL_REG, 0); + + ret = anx6345_read_r1(dev, ANX9804_DEV_IDH_REG, &chipid); + if (ret) + debug("%s: read id failed: %d\n", __func__, ret); + + switch (chipid) { + case 0x63: + debug("ANX63xx detected.\n"); + break; + default: + debug("Error anx6345 chipid mismatch: %.2x\n", (int)chipid); + return -ENODEV; + } + + for (i = 0; i < 100; i++) { + anx6345_read_r0(dev, ANX9804_SYS_CTRL2_REG, &c); + anx6345_write_r0(dev, ANX9804_SYS_CTRL2_REG, c); + anx6345_read_r0(dev, ANX9804_SYS_CTRL2_REG, &c); + if ((c & ANX9804_SYS_CTRL2_CHA_STA) == 0) + break; + + mdelay(5); + } + if (i == 100) + debug("Error anx6345 clock is not stable\n"); + + /* Set a bunch of analog related register values */ + anx6345_write_r0(dev, ANX9804_PLL_CTRL_REG, 0x00); + anx6345_write_r1(dev, ANX9804_ANALOG_DEBUG_REG1, 0x70); + anx6345_write_r0(dev, ANX9804_LINK_DEBUG_REG, 0x30); + + /* Force HPD */ + anx6345_write_r0(dev, ANX9804_SYS_CTRL3_REG, + ANX9804_SYS_CTRL3_F_HPD | ANX9804_SYS_CTRL3_HPD_CTRL); + + /* Power up and configure lanes */ + anx6345_write_r0(dev, ANX9804_ANALOG_POWER_DOWN_REG, 0x00); + anx6345_write_r0(dev, ANX9804_TRAINING_LANE0_SET_REG, 0x00); + anx6345_write_r0(dev, ANX9804_TRAINING_LANE1_SET_REG, 0x00); + anx6345_write_r0(dev, ANX9804_TRAINING_LANE2_SET_REG, 0x00); + anx6345_write_r0(dev, ANX9804_TRAINING_LANE3_SET_REG, 0x00); + + /* Reset AUX CH */ + anx6345_write_r1(dev, ANX9804_RST_CTRL2_REG, + ANX9804_RST_CTRL2_AUX); + anx6345_write_r1(dev, ANX9804_RST_CTRL2_REG, 0); + + /* Powerdown audio and some other unused bits */ + anx6345_write_r1(dev, ANX9804_POWERD_CTRL_REG, ANX9804_POWERD_AUDIO); + anx6345_write_r0(dev, ANX9804_HDCP_CONTROL_0_REG, 0x00); + anx6345_write_r0(dev, 0xa7, 0x00); + + anx6345_read_aux_i2c(dev, 0x50, 0x0, EDID_SIZE, priv->edid); + if (edid_get_timing(priv->edid, EDID_SIZE, &timing, &bpp) != 0) { + debug("Failed to parse EDID\n"); + return -EIO; + } + debug("%s: panel found: %dx%d, bpp %d\n", __func__, + timing.hactive.typ, timing.vactive.typ, + bpp); + if (bpp == 6) + colordepth = 0x00; /* 6 bit */ + else + colordepth = 0x10; /* 8 bit */ + anx6345_write_r1(dev, ANX9804_VID_CTRL2_REG, colordepth); + + if (anx6345_read_dpcd(dev, DP_MAX_LINK_RATE, &data_rate)) { + debug("%s: Failed to DP_MAX_LINK_RATE\n", __func__); + return -EIO; + } + debug("%s: data_rate: %d\n", __func__, (int)data_rate); + if (anx6345_read_dpcd(dev, DP_MAX_LANE_COUNT, &lanes)) { + debug("%s: Failed to read DP_MAX_LANE_COUNT\n", __func__); + return -EIO; + } + lanes &= DP_MAX_LANE_COUNT_MASK; + debug("%s: lanes: %d\n", __func__, (int)lanes); + + /* Set data-rate / lanes */ + anx6345_write_r0(dev, ANX9804_LINK_BW_SET_REG, data_rate); + anx6345_write_r0(dev, ANX9804_LANE_COUNT_SET_REG, lanes); + + /* Link training */ + anx6345_write_r0(dev, ANX9804_LINK_TRAINING_CTRL_REG, + ANX9804_LINK_TRAINING_CTRL_EN); + mdelay(5); + for (i = 0; i < 100; i++) { + anx6345_read_r0(dev, ANX9804_LINK_TRAINING_CTRL_REG, &c); + if ((chipid == 0x63) && (c & 0x80) == 0) + break; + + mdelay(5); + } + if(i == 100) { + debug("Error anx6345 link training timeout\n"); + return -ENODEV; + } + + /* Enable */ + anx6345_write_r1(dev, ANX9804_VID_CTRL1_REG, + ANX9804_VID_CTRL1_VID_EN | ANX9804_VID_CTRL1_EDGE); + /* Force stream valid */ + anx6345_write_r0(dev, ANX9804_SYS_CTRL3_REG, + ANX9804_SYS_CTRL3_F_HPD | ANX9804_SYS_CTRL3_HPD_CTRL | + ANX9804_SYS_CTRL3_F_VALID | ANX9804_SYS_CTRL3_VALID_CTRL); + + return 0; +} + +static int anx6345_probe(struct udevice *dev) +{ + if (device_get_uclass_id(dev->parent) != UCLASS_I2C) + return -EPROTONOSUPPORT; + + return anx6345_enable(dev); +} + +struct video_bridge_ops anx6345_ops = { + .attach = anx6345_attach, + .set_backlight = anx6345_set_backlight, + .read_edid = anx6345_read_edid, +}; + +static const struct udevice_id anx6345_ids[] = { + { .compatible = "analogix,anx6345", }, + { } +}; + +U_BOOT_DRIVER(analogix_anx6345) = { + .name = "analogix_anx6345", + .id = UCLASS_VIDEO_BRIDGE, + .of_match = anx6345_ids, + .probe = anx6345_probe, + .ops = &anx6345_ops, + .priv_auto_alloc_size = sizeof(struct anx6345_priv), +};
It will be reused in new DM LCD driver.
arch/arm/include/asm/arch-sunxi/lcdc.h | 2 + drivers/video/sunxi/lcdc.c | 117 ++++++++++++++++++++++++++++++- drivers/video/sunxi/sunxi_display.c | 121 ++------------------------------- 3 files changed, 124 insertions(+), 116 deletions(-)
diff --git a/arch/arm/include/asm/arch-sunxi/lcdc.h b/arch/arm/include/asm/arch-sunxi/lcdc.h index a751698b4f..5d9253aaa5 100644 --- a/arch/arm/include/asm/arch-sunxi/lcdc.h +++ b/arch/arm/include/asm/arch-sunxi/lcdc.h @@ -124,5 +124,7 @@ void lcdc_tcon0_mode_set(struct sunxi_lcdc_reg * const lcdc, void lcdc_tcon1_mode_set(struct sunxi_lcdc_reg * const lcdc, const struct display_timing *mode, bool ext_hvsync, bool is_composite); +void lcdc_pll_set(struct sunxi_ccm_reg * const ccm, int tcon, + int dotclock, int *clk_div, int *clk_double);
#endif /* _LCDC_H */ diff --git a/drivers/video/sunxi/lcdc.c b/drivers/video/sunxi/lcdc.c index 7d215b713e..023a30cb1e 100644 --- a/drivers/video/sunxi/lcdc.c +++ b/drivers/video/sunxi/lcdc.c @@ -10,6 +10,7 @@
#include <common.h>
+#include <asm/arch/clock.h> #include <asm/arch/lcdc.h> #include <asm/io.h>
@@ -100,7 +101,7 @@ void lcdc_tcon0_mode_set(struct sunxi_lcdc_reg * const lcdc, writel(SUNXI_LCDC_TCON0_TIMING_V_TOTAL(total) | SUNXI_LCDC_TCON0_TIMING_V_BP(bp), &lcdc->tcon0_timing_v);
-#ifdef CONFIG_VIDEO_LCD_IF_PARALLEL +#if defined(CONFIG_VIDEO_LCD_IF_PARALLEL) || defined(CONFIG_VIDEO_DE2) writel(SUNXI_LCDC_X(mode->hsync_len.typ) | SUNXI_LCDC_Y(mode->vsync_len.typ), &lcdc->tcon0_timing_sync);
@@ -207,3 +208,117 @@ void lcdc_tcon1_mode_set(struct sunxi_lcdc_reg * const lcdc, SUNXI_LCDC_MUX_CTRL_SRC0(1)); #endif } + +void lcdc_pll_set(struct sunxi_ccm_reg *ccm, int tcon, int dotclock, + int *clk_div, int *clk_double) +{ + int value, n, m, min_m, max_m, diff; + int best_n = 0, best_m = 0, best_diff = 0x0FFFFFFF; + int best_double = 0; + bool use_mipi_pll = false; + + if (tcon == 0) { +#if defined(CONFIG_VIDEO_LCD_IF_PARALLEL) || defined(CONFIG_SUNXI_DE2) + min_m = 6; + max_m = 127; +#endif +#ifdef CONFIG_VIDEO_LCD_IF_LVDS + min_m = max_m = 7; +#endif + } else { + min_m = 1; + max_m = 15; + } + + /* + * Find the lowest divider resulting in a matching clock, if there + * is no match, pick the closest lower clock, as monitors tend to + * not sync to higher frequencies. + */ + for (m = min_m; m <= max_m; m++) { +#ifndef CONFIG_SUNXI_DE2 + n = (m * dotclock) / 3000; + + if ((n >= 9) && (n <= 127)) { + value = (3000 * n) / m; + diff = dotclock - value; + if (diff < best_diff) { + best_diff = diff; + best_m = m; + best_n = n; + best_double = 0; + } + } + + /* These are just duplicates */ + if (!(m & 1)) + continue; +#endif + + /* No double clock on DE2 */ + n = (m * dotclock) / 6000; + if ((n >= 9) && (n <= 127)) { + value = (6000 * n) / m; + diff = dotclock - value; + if (diff < best_diff) { + best_diff = diff; + best_m = m; + best_n = n; + best_double = 1; + } + } + } + +#ifdef CONFIG_MACH_SUN6I + /* + * Use the MIPI pll if we've been unable to find any matching setting + * for PLL3, this happens with high dotclocks because of min_m = 6. + */ + if (tcon == 0 && best_n == 0) { + use_mipi_pll = true; + best_m = 6; /* Minimum m for tcon0 */ + } + + if (use_mipi_pll) { + clock_set_pll3(297000000); /* Fix the video pll at 297 MHz */ + clock_set_mipi_pll(best_m * dotclock * 1000); + debug("dotclock: %dkHz = %dkHz via mipi pll\n", + dotclock, clock_get_mipi_pll() / best_m / 1000); + } else +#endif + { + clock_set_pll3(best_n * 3000000); + debug("dotclock: %dkHz = %dkHz: (%d * 3MHz * %d) / %d\n", + dotclock, + (best_double + 1) * clock_get_pll3() / best_m / 1000, + best_double + 1, best_n, best_m); + } + + if (tcon == 0) { + u32 pll; + + if (use_mipi_pll) + pll = CCM_LCD_CH0_CTRL_MIPI_PLL; + else if (best_double) + pll = CCM_LCD_CH0_CTRL_PLL3_2X; + else + pll = CCM_LCD_CH0_CTRL_PLL3; + + writel(CCM_LCD_CH0_CTRL_GATE | CCM_LCD_CH0_CTRL_RST | pll, + &ccm->lcd0_clk_cfg); + } +#ifndef CONFIG_SUNXI_DE2 + else { + writel(CCM_LCD_CH1_CTRL_GATE | + (best_double ? CCM_LCD_CH1_CTRL_PLL3_2X : + CCM_LCD_CH1_CTRL_PLL3) | + CCM_LCD_CH1_CTRL_M(best_m), &ccm->lcd0_ch1_clk_cfg); + if (sunxi_is_composite()) + setbits_le32(&ccm->lcd0_ch1_clk_cfg, + CCM_LCD_CH1_CTRL_HALF_SCLK1); + } +#endif + + *clk_div = best_m; + *clk_double = best_double; +} diff --git a/drivers/video/sunxi/sunxi_display.c b/drivers/video/sunxi/sunxi_display.c index de768ba94a..f3db125305 100644 --- a/drivers/video/sunxi/sunxi_display.c +++ b/drivers/video/sunxi/sunxi_display.c @@ -515,119 +515,6 @@ static void sunxi_composer_enable(void) setbits_le32(&de_be->mode, SUNXI_DE_BE_MODE_START); }
-/* - * LCDC, what allwinner calls a CRTC, so timing controller and serializer. - */ -static void sunxi_lcdc_pll_set(int tcon, int dotclock, - int *clk_div, int *clk_double) -{ - struct sunxi_ccm_reg * const ccm = - (struct sunxi_ccm_reg *)SUNXI_CCM_BASE; - int value, n, m, min_m, max_m, diff; - int best_n = 0, best_m = 0, best_diff = 0x0FFFFFFF; - int best_double = 0; - bool use_mipi_pll = false; - - if (tcon == 0) { -#ifdef CONFIG_VIDEO_LCD_IF_PARALLEL - min_m = 6; - max_m = 127; -#endif -#ifdef CONFIG_VIDEO_LCD_IF_LVDS - min_m = max_m = 7; -#endif - } else { - min_m = 1; - max_m = 15; - } - - /* - * Find the lowest divider resulting in a matching clock, if there - * is no match, pick the closest lower clock, as monitors tend to - * not sync to higher frequencies. - */ - for (m = min_m; m <= max_m; m++) { - n = (m * dotclock) / 3000; - - if ((n >= 9) && (n <= 127)) { - value = (3000 * n) / m; - diff = dotclock - value; - if (diff < best_diff) { - best_diff = diff; - best_m = m; - best_n = n; - best_double = 0; - } - } - - /* These are just duplicates */ - if (!(m & 1)) - continue; - - n = (m * dotclock) / 6000; - if ((n >= 9) && (n <= 127)) { - value = (6000 * n) / m; - diff = dotclock - value; - if (diff < best_diff) { - best_diff = diff; - best_m = m; - best_n = n; - best_double = 1; - } - } - } - -#ifdef CONFIG_MACH_SUN6I - /* - * Use the MIPI pll if we've been unable to find any matching setting - * for PLL3, this happens with high dotclocks because of min_m = 6. - */ - if (tcon == 0 && best_n == 0) { - use_mipi_pll = true; - best_m = 6; /* Minimum m for tcon0 */ - } - - if (use_mipi_pll) { - clock_set_pll3(297000000); /* Fix the video pll at 297 MHz */ - clock_set_mipi_pll(best_m * dotclock * 1000); - debug("dotclock: %dkHz = %dkHz via mipi pll\n", - dotclock, clock_get_mipi_pll() / best_m / 1000); - } else -#endif - { - clock_set_pll3(best_n * 3000000); - debug("dotclock: %dkHz = %dkHz: (%d * 3MHz * %d) / %d\n", - dotclock, - (best_double + 1) * clock_get_pll3() / best_m / 1000, - best_double + 1, best_n, best_m); - } - - if (tcon == 0) { - u32 pll; - - if (use_mipi_pll) - pll = CCM_LCD_CH0_CTRL_MIPI_PLL; - else if (best_double) - pll = CCM_LCD_CH0_CTRL_PLL3_2X; - else - pll = CCM_LCD_CH0_CTRL_PLL3; - - writel(CCM_LCD_CH0_CTRL_GATE | CCM_LCD_CH0_CTRL_RST | pll, - &ccm->lcd0_ch0_clk_cfg); - } else { - writel(CCM_LCD_CH1_CTRL_GATE | - (best_double ? CCM_LCD_CH1_CTRL_PLL3_2X : - CCM_LCD_CH1_CTRL_PLL3) | - CCM_LCD_CH1_CTRL_M(best_m), &ccm->lcd0_ch1_clk_cfg); - if (sunxi_is_composite()) - setbits_le32(&ccm->lcd0_ch1_clk_cfg, - CCM_LCD_CH1_CTRL_HALF_SCLK1); - } - - *clk_div = best_m; - *clk_double = best_double; -} - static void sunxi_lcdc_init(void) { struct sunxi_ccm_reg * const ccm = @@ -754,6 +641,8 @@ static void sunxi_lcdc_tcon0_mode_set(const struct ctfb_res_modes *mode, { struct sunxi_lcdc_reg * const lcdc = (struct sunxi_lcdc_reg *)SUNXI_LCD0_BASE; + struct sunxi_ccm_reg * const ccm = + (struct sunxi_ccm_reg *)SUNXI_CCM_BASE; int clk_div, clk_double, pin; struct display_timing timing;
@@ -773,7 +662,7 @@ static void sunxi_lcdc_tcon0_mode_set(const struct ctfb_res_modes *mode, #endif }
- sunxi_lcdc_pll_set(0, mode->pixclock_khz, &clk_div, &clk_double); + lcdc_pll_set(ccm, 0, mode->pixclock_khz, &clk_div, &clk_double);
sunxi_ctfb_mode_to_display_timing(mode, &timing); lcdc_tcon0_mode_set(lcdc, &timing, clk_div, for_ext_vga_dac, @@ -787,6 +676,8 @@ static void sunxi_lcdc_tcon1_mode_set(const struct ctfb_res_modes *mode, { struct sunxi_lcdc_reg * const lcdc = (struct sunxi_lcdc_reg *)SUNXI_LCD0_BASE; + struct sunxi_ccm_reg * const ccm = + (struct sunxi_ccm_reg *)SUNXI_CCM_BASE; struct display_timing timing;
sunxi_ctfb_mode_to_display_timing(mode, &timing); @@ -798,7 +689,7 @@ static void sunxi_lcdc_tcon1_mode_set(const struct ctfb_res_modes *mode, sunxi_gpio_set_cfgpin(SUNXI_GPD(27), SUNXI_GPD_LCD0); }
- sunxi_lcdc_pll_set(1, mode->pixclock_khz, clk_div, clk_double); + lcdc_pll_set(ccm, 1, mode->pixclock_khz, clk_div, clk_double); } #endif /* CONFIG_VIDEO_HDMI || defined CONFIG_VIDEO_VGA || CONFIG_VIDEO_COMPOSITE */
On Wed, 20 Sep 2017 23:29:10 -0700 Vasily Khoruzhick anarsoul@gmail.com wrote:
v2: - no changes
This patch breaks building for many sunxi boards, please see build logs here:
https://travis-ci.org/vdsao/u-boot-video/jobs/293307123 https://travis-ci.org/vdsao/u-boot-video/jobs/293307125 https://travis-ci.org/vdsao/u-boot-video/jobs/293307128 https://travis-ci.org/vdsao/u-boot-video/jobs/293307131
-- Anatolij
Hi Anatolij,
I'll look into it tonight.
Regards, Vasily
v2: - no changes
-- Anatolij
Signed-off-by: Vasily Khoruzhick anarsoul@gmail.com --- v2-v3: no changes v4: - fix compilation for boards that use sunxi_display.c - rebased and fixed checkpatch errors
arch/arm/include/asm/arch-sunxi/lcdc.h | 3 + drivers/video/sunxi/lcdc.c | 122 +++++++++++++++++++++++++++++++- drivers/video/sunxi/sunxi_display.c | 123 +++------------------------------ 3 files changed, 132 insertions(+), 116 deletions(-)
diff --git a/arch/arm/include/asm/arch-sunxi/lcdc.h b/arch/arm/include/asm/arch-sunxi/lcdc.h index a751698b4f..132c480106 100644 --- a/arch/arm/include/asm/arch-sunxi/lcdc.h +++ b/arch/arm/include/asm/arch-sunxi/lcdc.h @@ -124,5 +124,8 @@ void lcdc_tcon0_mode_set(struct sunxi_lcdc_reg * const lcdc, void lcdc_tcon1_mode_set(struct sunxi_lcdc_reg * const lcdc, const struct display_timing *mode, bool ext_hvsync, bool is_composite); +void lcdc_pll_set(struct sunxi_ccm_reg * const ccm, int tcon, + int dotclock, int *clk_div, int *clk_double, + bool is_composite);
#endif /* _LCDC_H */ diff --git a/drivers/video/sunxi/lcdc.c b/drivers/video/sunxi/lcdc.c index 7d215b713e..4cb86fb7ff 100644 --- a/drivers/video/sunxi/lcdc.c +++ b/drivers/video/sunxi/lcdc.c @@ -10,6 +10,7 @@
#include <common.h>
@@ -207,3 +208,122 @@ void lcdc_tcon1_mode_set(struct sunxi_lcdc_reg * const lcdc, SUNXI_LCDC_MUX_CTRL_SRC0(1)); #endif } + +void lcdc_pll_set(struct sunxi_ccm_reg *ccm, int tcon, int dotclock, + int *clk_div, int *clk_double, bool is_composite) +{ + int value, n, m, min_m, max_m, diff; + int best_n = 0, best_m = 0, best_diff = 0x0FFFFFFF; + int best_double = 0; + bool use_mipi_pll = false; + + if (tcon == 0) { +#if defined(CONFIG_VIDEO_LCD_IF_PARALLEL) || defined(CONFIG_SUNXI_DE2) + min_m = 6; + max_m = 127; +#endif +#ifdef CONFIG_VIDEO_LCD_IF_LVDS + min_m = 7; + max_m = 7; +#endif + } else { + min_m = 1; + max_m = 15; + } + + /* + * Find the lowest divider resulting in a matching clock, if there + * is no match, pick the closest lower clock, as monitors tend to + * not sync to higher frequencies. + */ + for (m = min_m; m <= max_m; m++) { +#ifndef CONFIG_SUNXI_DE2 + n = (m * dotclock) / 3000; + + if ((n >= 9) && (n <= 127)) { + value = (3000 * n) / m; + diff = dotclock - value; + if (diff < best_diff) { + best_diff = diff; + best_m = m; + best_n = n; + best_double = 0; + } + } + + /* These are just duplicates */ + if (!(m & 1)) + continue; +#endif + + /* No double clock on DE2 */ + n = (m * dotclock) / 6000; + if ((n >= 9) && (n <= 127)) { + value = (6000 * n) / m; + diff = dotclock - value; + if (diff < best_diff) { + best_diff = diff; + best_m = m; + best_n = n; + best_double = 1; + } + } + } + +#ifdef CONFIG_MACH_SUN6I + /* + * Use the MIPI pll if we've been unable to find any matching setting + * for PLL3, this happens with high dotclocks because of min_m = 6. + */ + if (tcon == 0 && best_n == 0) { + use_mipi_pll = true; + best_m = 6; /* Minimum m for tcon0 */ + } + + if (use_mipi_pll) { + clock_set_pll3(297000000); /* Fix the video pll at 297 MHz */ + clock_set_mipi_pll(best_m * dotclock * 1000); + debug("dotclock: %dkHz = %dkHz via mipi pll\n", + dotclock, clock_get_mipi_pll() / best_m / 1000); + } else +#endif + { + clock_set_pll3(best_n * 3000000); + debug("dotclock: %dkHz = %dkHz: (%d * 3MHz * %d) / %d\n", + dotclock, + (best_double + 1) * clock_get_pll3() / best_m / 1000, + best_double + 1, best_n, best_m); + } + + if (tcon == 0) { + u32 pll; + + if (use_mipi_pll) + pll = CCM_LCD_CH0_CTRL_MIPI_PLL; + else if (best_double) + pll = CCM_LCD_CH0_CTRL_PLL3_2X; + else + pll = CCM_LCD_CH0_CTRL_PLL3; +#ifndef CONFIG_SUNXI_DE2 + writel(CCM_LCD_CH0_CTRL_GATE | CCM_LCD_CH0_CTRL_RST | pll, + &ccm->lcd0_ch0_clk_cfg); +#else + writel(CCM_LCD_CH0_CTRL_GATE | CCM_LCD_CH0_CTRL_RST | pll, + &ccm->lcd0_clk_cfg); +#endif + } +#ifndef CONFIG_SUNXI_DE2 + else { + writel(CCM_LCD_CH1_CTRL_GATE | + (best_double ? CCM_LCD_CH1_CTRL_PLL3_2X : + CCM_LCD_CH1_CTRL_PLL3) | + CCM_LCD_CH1_CTRL_M(best_m), &ccm->lcd0_ch1_clk_cfg); + if (is_composite) + setbits_le32(&ccm->lcd0_ch1_clk_cfg, + CCM_LCD_CH1_CTRL_HALF_SCLK1); + } +#endif + + *clk_div = best_m; + *clk_double = best_double; +} diff --git a/drivers/video/sunxi/sunxi_display.c b/drivers/video/sunxi/sunxi_display.c index de768ba94a..87a1a4496d 100644 --- a/drivers/video/sunxi/sunxi_display.c +++ b/drivers/video/sunxi/sunxi_display.c @@ -515,119 +515,6 @@ static void sunxi_composer_enable(void) setbits_le32(&de_be->mode, SUNXI_DE_BE_MODE_START); }
@@ -773,7 +662,8 @@ static void sunxi_lcdc_tcon0_mode_set(const struct ctfb_res_modes *mode, #endif }
- sunxi_lcdc_pll_set(0, mode->pixclock_khz, &clk_div, &clk_double); + lcdc_pll_set(ccm, 0, mode->pixclock_khz, &clk_div, &clk_double, + sunxi_is_composite());
sunxi_ctfb_mode_to_display_timing(mode, &timing); lcdc_tcon0_mode_set(lcdc, &timing, clk_div, for_ext_vga_dac, @@ -787,6 +677,8 @@ static void sunxi_lcdc_tcon1_mode_set(const struct ctfb_res_modes *mode, { struct sunxi_lcdc_reg * const lcdc = (struct sunxi_lcdc_reg *)SUNXI_LCD0_BASE; + struct sunxi_ccm_reg * const ccm = + (struct sunxi_ccm_reg *)SUNXI_CCM_BASE; struct display_timing timing;
sunxi_ctfb_mode_to_display_timing(mode, &timing); @@ -798,7 +690,8 @@ static void sunxi_lcdc_tcon1_mode_set(const struct ctfb_res_modes *mode, sunxi_gpio_set_cfgpin(SUNXI_GPD(27), SUNXI_GPD_LCD0); }
- sunxi_lcdc_pll_set(1, mode->pixclock_khz, clk_div, clk_double); + lcdc_pll_set(ccm, 1, mode->pixclock_khz, clk_div, clk_double, + sunxi_is_composite()); } #endif /* CONFIG_VIDEO_HDMI || defined CONFIG_VIDEO_VGA || CONFIG_VIDEO_COMPOSITE */
Extend DE2 driver with LCD support. Tested on Pinebook which is based on A64 and has ANX6345 eDP bridge with eDP panel connected to it.
Signed-off-by: Vasily Khoruzhick anarsoul@gmail.com --- v4: - adapted to v4 changes in patch 4/5 v3: - rebased and fixed checkpatch errors/warnings
v2: - drop redundant clock_set_pll10() call - fallback to timings from DT if reading EDID from bridge failed - read panel_bpp from DT arch/arm/mach-sunxi/Kconfig | 2 +- drivers/video/sunxi/Makefile | 2 +- drivers/video/sunxi/sunxi_de2.c | 17 +++++ drivers/video/sunxi/sunxi_lcd.c | 152 ++++++++++++++++++++++++++++++++++++++++ 4 files changed, 171 insertions(+), 2 deletions(-) create mode 100644 drivers/video/sunxi/sunxi_lcd.c
diff --git a/arch/arm/mach-sunxi/Kconfig b/arch/arm/mach-sunxi/Kconfig index 2309f59999..06d697e3a7 100644 --- a/arch/arm/mach-sunxi/Kconfig +++ b/arch/arm/mach-sunxi/Kconfig @@ -680,7 +680,7 @@ config VIDEO_LCD_MODE
config VIDEO_LCD_DCLK_PHASE int "LCD panel display clock phase" - depends on VIDEO + depends on VIDEO || DM_VIDEO default 1 ---help--- Select LCD panel display clock phase shift, range 0-3. diff --git a/drivers/video/sunxi/Makefile b/drivers/video/sunxi/Makefile index 0d64c2021f..8c91766c24 100644 --- a/drivers/video/sunxi/Makefile +++ b/drivers/video/sunxi/Makefile @@ -6,4 +6,4 @@ #
obj-$(CONFIG_VIDEO_SUNXI) += sunxi_display.o lcdc.o tve_common.o ../videomodes.o -obj-$(CONFIG_VIDEO_DE2) += sunxi_de2.o sunxi_dw_hdmi.o lcdc.o ../dw_hdmi.o +obj-$(CONFIG_VIDEO_DE2) += sunxi_de2.o sunxi_dw_hdmi.o lcdc.o ../dw_hdmi.o sunxi_lcd.o diff --git a/drivers/video/sunxi/sunxi_de2.c b/drivers/video/sunxi/sunxi_de2.c index ee67764ac5..49c36b8d73 100644 --- a/drivers/video/sunxi/sunxi_de2.c +++ b/drivers/video/sunxi/sunxi_de2.c @@ -232,6 +232,23 @@ static int sunxi_de2_probe(struct udevice *dev) if (!(gd->flags & GD_FLG_RELOC)) return 0;
+ ret = uclass_find_device_by_name(UCLASS_DISPLAY, + "sunxi_lcd", &disp); + if (!ret) { + int mux; + + mux = 0; + + ret = sunxi_de2_init(dev, plat->base, VIDEO_BPP32, disp, mux, + false); + if (!ret) { + video_set_flush_dcache(dev, 1); + return 0; + } + } + + debug("%s: lcd display not found (ret=%d)\n", __func__, ret); + ret = uclass_find_device_by_name(UCLASS_DISPLAY, "sunxi_dw_hdmi", &disp); if (!ret) { diff --git a/drivers/video/sunxi/sunxi_lcd.c b/drivers/video/sunxi/sunxi_lcd.c new file mode 100644 index 0000000000..2f51aebe27 --- /dev/null +++ b/drivers/video/sunxi/sunxi_lcd.c @@ -0,0 +1,152 @@ +/* + * Allwinner LCD driver + * + * (C) Copyright 2017 Vasily Khoruzhick anarsoul@gmail.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <display.h> +#include <video_bridge.h> +#include <backlight.h> +#include <dm.h> +#include <edid.h> +#include <asm/io.h> +#include <asm/arch/clock.h> +#include <asm/arch/lcdc.h> +#include <asm/arch/gpio.h> +#include <asm/gpio.h> + +struct sunxi_lcd_priv { + struct display_timing timing; + int panel_bpp; +}; + +static void sunxi_lcdc_config_pinmux(void) +{ +#ifdef CONFIG_MACH_SUN50I + int pin; + + for (pin = SUNXI_GPD(0); pin <= SUNXI_GPD(21); pin++) { + sunxi_gpio_set_cfgpin(pin, SUNXI_GPD_LCD0); + sunxi_gpio_set_drv(pin, 3); + } +#endif +} + +static int sunxi_lcd_enable(struct udevice *dev, int bpp, + const struct display_timing *edid) +{ + struct sunxi_ccm_reg * const ccm = + (struct sunxi_ccm_reg *)SUNXI_CCM_BASE; + struct sunxi_lcdc_reg * const lcdc = + (struct sunxi_lcdc_reg *)SUNXI_LCD0_BASE; + struct sunxi_lcd_priv *priv = dev_get_priv(dev); + struct udevice *backlight; + int clk_div, clk_double, ret; + + /* Reset off */ + setbits_le32(&ccm->ahb_reset1_cfg, 1 << AHB_RESET_OFFSET_LCD0); + /* Clock on */ + setbits_le32(&ccm->ahb_gate1, 1 << AHB_GATE_OFFSET_LCD0); + + lcdc_init(lcdc); + sunxi_lcdc_config_pinmux(); + lcdc_pll_set(ccm, 0, edid->pixelclock.typ / 1000, + &clk_div, &clk_double, false); + lcdc_tcon0_mode_set(lcdc, edid, clk_div, false, + priv->panel_bpp, CONFIG_VIDEO_LCD_DCLK_PHASE); + lcdc_enable(lcdc, priv->panel_bpp); + + ret = uclass_get_device(UCLASS_PANEL_BACKLIGHT, 0, &backlight); + if (!ret) + backlight_enable(backlight); + + return 0; +} + +static int sunxi_lcd_read_timing(struct udevice *dev, + struct display_timing *timing) +{ + struct sunxi_lcd_priv *priv = dev_get_priv(dev); + + memcpy(timing, &priv->timing, sizeof(struct display_timing)); + + return 0; +} + +static int sunxi_lcd_probe(struct udevice *dev) +{ + struct udevice *cdev; + struct sunxi_lcd_priv *priv = dev_get_priv(dev); + int ret; + int node, timing_node, val; + +#ifdef CONFIG_VIDEO_BRIDGE + /* Try to get timings from bridge first */ + ret = uclass_get_device(UCLASS_VIDEO_BRIDGE, 0, &cdev); + if (!ret) { + u8 edid[EDID_SIZE]; + int channel_bpp; + + ret = video_bridge_attach(cdev); + if (ret) { + debug("video bridge attach failed: %d\n", ret); + return ret; + } + ret = video_bridge_read_edid(cdev, edid, EDID_SIZE); + if (ret > 0) { + ret = edid_get_timing(edid, ret, + &priv->timing, &channel_bpp); + priv->panel_bpp = channel_bpp * 3; + if (!ret) + return ret; + } + } +#endif + + /* Fallback to timings from DT if there's no bridge or + * if reading EDID failed + */ + ret = uclass_get_device(UCLASS_PANEL, 0, &cdev); + if (ret) { + debug("video panel not found: %d\n", ret); + return ret; + } + + if (fdtdec_decode_display_timing(gd->fdt_blob, dev_of_offset(cdev), + 0, &priv->timing)) { + debug("%s: Failed to decode display timing\n", __func__); + return -EINVAL; + } + timing_node = fdt_subnode_offset(gd->fdt_blob, dev_of_offset(cdev), + "display-timings"); + node = fdt_first_subnode(gd->fdt_blob, timing_node); + val = fdtdec_get_int(gd->fdt_blob, node, "bits-per-pixel", -1); + if (val != -1) + priv->panel_bpp = val; + else + priv->panel_bpp = 18; + + return 0; +} + +static const struct dm_display_ops sunxi_lcd_ops = { + .read_timing = sunxi_lcd_read_timing, + .enable = sunxi_lcd_enable, +}; + +U_BOOT_DRIVER(sunxi_lcd) = { + .name = "sunxi_lcd", + .id = UCLASS_DISPLAY, + .ops = &sunxi_lcd_ops, + .probe = sunxi_lcd_probe, + .priv_auto_alloc_size = sizeof(struct sunxi_lcd_priv), +}; + +#ifdef CONFIG_MACH_SUN50I +U_BOOT_DEVICE(sunxi_lcd) = { + .name = "sunxi_lcd" +}; +#endif
On Thu, 26 Oct 2017 21:51:52 -0700 Vasily Khoruzhick anarsoul@gmail.com wrote:
-- Anatolij
On Thu, 26 Oct 2017 21:51:51 -0700 Vasily Khoruzhick anarsoul@gmail.com wrote:
-- Anatolij
Signed-off-by: Vasily Khoruzhick anarsoul@gmail.com --- v2: - drop redundant clock_set_pll10() call - fallback to timings from DT if reading EDID from bridge failed - read panel_bpp from DT
arch/arm/mach-sunxi/Kconfig | 2 +- drivers/video/sunxi/Makefile | 2 +- drivers/video/sunxi/sunxi_de2.c | 17 +++++ drivers/video/sunxi/sunxi_lcd.c | 149 ++++++++++++++++++++++++++++++++++++++++ 4 files changed, 168 insertions(+), 2 deletions(-) create mode 100644 drivers/video/sunxi/sunxi_lcd.c
obj-$(CONFIG_VIDEO_SUNXI) += sunxi_display.o lcdc.o tve_common.o ../videomodes.o -obj-$(CONFIG_VIDEO_DE2) += sunxi_de2.o sunxi_dw_hdmi.o lcdc.o ../dw_hdmi.o +obj-$(CONFIG_VIDEO_DE2) += sunxi_de2.o sunxi_dw_hdmi.o lcdc.o ../dw_hdmi.o sunxi_lcd.o diff --git a/drivers/video/sunxi/sunxi_de2.c b/drivers/video/sunxi/sunxi_de2.c index ee67764ac5..a838bbacd1 100644 --- a/drivers/video/sunxi/sunxi_de2.c +++ b/drivers/video/sunxi/sunxi_de2.c @@ -232,6 +232,23 @@ static int sunxi_de2_probe(struct udevice *dev) if (!(gd->flags & GD_FLG_RELOC)) return 0;
+ ret = uclass_find_device_by_name(UCLASS_DISPLAY, + "sunxi_lcd", &disp); + if (!ret) { + int mux; + + mux = 0; + + ret = sunxi_de2_init(dev, plat->base, VIDEO_BPP32, disp, mux, + false); + if (!ret) { + video_set_flush_dcache(dev, 1); + return 0; + } + } + + debug("%s: lcd display not found (ret=%d)\n", __func__, ret); + ret = uclass_find_device_by_name(UCLASS_DISPLAY, "sunxi_dw_hdmi", &disp); if (!ret) { diff --git a/drivers/video/sunxi/sunxi_lcd.c b/drivers/video/sunxi/sunxi_lcd.c new file mode 100644 index 0000000000..b8e4b0e344 --- /dev/null +++ b/drivers/video/sunxi/sunxi_lcd.c @@ -0,0 +1,149 @@ +/* + * Allwinner LCD driver + * + * (C) Copyright 2017 Vasily Khoruzhick anarsoul@gmail.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <display.h> +#include <video_bridge.h> +#include <backlight.h> +#include <dm.h> +#include <edid.h> +#include <asm/io.h> +#include <asm/arch/clock.h> +#include <asm/arch/lcdc.h> +#include <asm/arch/gpio.h> +#include <asm/gpio.h> + +struct sunxi_lcd_priv { + struct display_timing timing; + int panel_bpp; +}; + +static void sunxi_lcdc_config_pinmux(void) +{ +#ifdef CONFIG_MACH_SUN50I + int pin; + for (pin = SUNXI_GPD(0); pin <= SUNXI_GPD(21); pin++) { + sunxi_gpio_set_cfgpin(pin, SUNXI_GPD_LCD0); + sunxi_gpio_set_drv(pin, 3); + } +#endif +} + +static int sunxi_lcd_enable(struct udevice *dev, int bpp, + const struct display_timing *edid) +{ + struct sunxi_ccm_reg * const ccm = + (struct sunxi_ccm_reg *)SUNXI_CCM_BASE; + struct sunxi_lcdc_reg * const lcdc = + (struct sunxi_lcdc_reg *)SUNXI_LCD0_BASE; + struct sunxi_lcd_priv *priv = dev_get_priv(dev); + struct udevice *backlight; + int clk_div, clk_double, ret; + + /* Reset off */ + setbits_le32(&ccm->ahb_reset1_cfg, 1 << AHB_RESET_OFFSET_LCD0); + /* Clock on */ + setbits_le32(&ccm->ahb_gate1, 1 << AHB_GATE_OFFSET_LCD0); + + lcdc_init(lcdc); + sunxi_lcdc_config_pinmux(); + lcdc_pll_set(ccm, 0, edid->pixelclock.typ / 1000, + &clk_div, &clk_double); + lcdc_tcon0_mode_set(lcdc, edid, clk_div, false, + priv->panel_bpp, CONFIG_VIDEO_LCD_DCLK_PHASE); + lcdc_enable(lcdc, priv->panel_bpp); + + ret = uclass_get_device(UCLASS_PANEL_BACKLIGHT, 0, &backlight); + if (!ret) + backlight_enable(backlight); + + return 0; +} + +static int sunxi_lcd_read_timing(struct udevice *dev, + struct display_timing *timing) +{ + struct sunxi_lcd_priv *priv = dev_get_priv(dev); + memcpy(timing, &priv->timing, sizeof(struct display_timing)); + + return 0; +} + +static int sunxi_lcd_probe(struct udevice *dev) +{ + struct udevice *cdev; + struct sunxi_lcd_priv *priv = dev_get_priv(dev); + int ret; + int node, timing_node, val; + +#ifdef CONFIG_VIDEO_BRIDGE + /* Try to get timings from bridge first */ + ret = uclass_get_device(UCLASS_VIDEO_BRIDGE, 0, &cdev); + if (!ret) { + u8 edid[EDID_SIZE]; + int channel_bpp; + + ret = video_bridge_attach(cdev); + if (ret) { + debug("video bridge attach failed: %d\n", ret); + return ret; + } + ret = video_bridge_read_edid(cdev, edid, EDID_SIZE); + if (ret > 0) { + ret = edid_get_timing(edid, ret, &priv->timing, &channel_bpp); + priv->panel_bpp = channel_bpp * 3; + if (!ret) + return ret; + } + } +#endif + + /* Fallback to timings from DT if there's no bridge or + * if reading EDID failed + */ + ret = uclass_get_device(UCLASS_PANEL, 0, &cdev); + if (ret) { + debug("video panel not found: %d\n", ret); + return ret; + } + + if (fdtdec_decode_display_timing(gd->fdt_blob, dev_of_offset(cdev), + 0, &priv->timing)) { + debug("%s: Failed to decode display timing\n", __func__); + return -EINVAL; + } + timing_node = fdt_subnode_offset(gd->fdt_blob, dev_of_offset(cdev), + "display-timings"); + node = fdt_first_subnode(gd->fdt_blob, timing_node); + val = fdtdec_get_int(gd->fdt_blob, node, "bits-per-pixel", -1); + if (val != -1) + priv->panel_bpp = val; + else + priv->panel_bpp = 18; + + return 0; +} + +static const struct dm_display_ops sunxi_lcd_ops = { + .read_timing = sunxi_lcd_read_timing, + .enable = sunxi_lcd_enable, +}; + +U_BOOT_DRIVER(sunxi_lcd) = { + .name = "sunxi_lcd", + .id = UCLASS_DISPLAY, + .ops = &sunxi_lcd_ops, + .probe = sunxi_lcd_probe, + .priv_auto_alloc_size = sizeof(struct sunxi_lcd_priv), +}; + +#ifdef CONFIG_MACH_SUN50I +U_BOOT_DEVICE(sunxi_lcd) = { + .name = "sunxi_lcd" +}; +#endif
Signed-off-by: Vasily Khoruzhick anarsoul@gmail.com Signed-off-by: Anatolij Gustschin agust@denx.de --- v3: - rebased and fixed checkpatch errors/warnings
arch/arm/mach-sunxi/Kconfig | 2 +- drivers/video/sunxi/Makefile | 2 +- drivers/video/sunxi/sunxi_de2.c | 17 +++++ drivers/video/sunxi/sunxi_lcd.c | 151 ++++++++++++++++++++++++++++++++++++++++ 4 files changed, 170 insertions(+), 2 deletions(-) create mode 100644 drivers/video/sunxi/sunxi_lcd.c
diff --git a/arch/arm/mach-sunxi/Kconfig b/arch/arm/mach-sunxi/Kconfig index bb57d4ff81..09cfec6f57 100644 --- a/arch/arm/mach-sunxi/Kconfig +++ b/arch/arm/mach-sunxi/Kconfig @@ -682,7 +682,7 @@ config VIDEO_LCD_MODE
config VIDEO_LCD_DCLK_PHASE int "LCD panel display clock phase" - depends on VIDEO_SUNXI + depends on VIDEO_SUNXI || DM_VIDEO default 1 ---help--- Select LCD panel display clock phase shift, range 0-3. diff --git a/drivers/video/sunxi/Makefile b/drivers/video/sunxi/Makefile index aec32b79b9..fa12d43029 100644 --- a/drivers/video/sunxi/Makefile +++ b/drivers/video/sunxi/Makefile @@ -6,4 +6,4 @@ #
obj-$(CONFIG_VIDEO_SUNXI) += sunxi_display.o simplefb_common.o lcdc.o tve_common.o ../videomodes.o -obj-$(CONFIG_VIDEO_DE2) += sunxi_de2.o sunxi_dw_hdmi.o simplefb_common.o lcdc.o ../dw_hdmi.o +obj-$(CONFIG_VIDEO_DE2) += sunxi_de2.o sunxi_dw_hdmi.o simplefb_common.o lcdc.o ../dw_hdmi.o sunxi_lcd.o diff --git a/drivers/video/sunxi/sunxi_de2.c b/drivers/video/sunxi/sunxi_de2.c index 67b937098c..e8903400ec 100644 --- a/drivers/video/sunxi/sunxi_de2.c +++ b/drivers/video/sunxi/sunxi_de2.c @@ -236,6 +236,23 @@ static int sunxi_de2_probe(struct udevice *dev) return 0;
ret = uclass_find_device_by_name(UCLASS_DISPLAY, + "sunxi_lcd", &disp); + if (!ret) { + int mux; + + mux = 0; + + ret = sunxi_de2_init(dev, plat->base, VIDEO_BPP32, disp, mux, + false); + if (!ret) { + video_set_flush_dcache(dev, 1); + return 0; + } + } + + debug("%s: lcd display not found (ret=%d)\n", __func__, ret); + + ret = uclass_find_device_by_name(UCLASS_DISPLAY, "sunxi_dw_hdmi", &disp); if (!ret) { int mux; diff --git a/drivers/video/sunxi/sunxi_lcd.c b/drivers/video/sunxi/sunxi_lcd.c new file mode 100644 index 0000000000..1e7d3ae3f7 --- /dev/null +++ b/drivers/video/sunxi/sunxi_lcd.c @@ -0,0 +1,151 @@ +/* + * Allwinner LCD driver + * + * (C) Copyright 2017 Vasily Khoruzhick anarsoul@gmail.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <display.h> +#include <video_bridge.h> +#include <backlight.h> +#include <dm.h> +#include <edid.h> +#include <asm/io.h> +#include <asm/arch/clock.h> +#include <asm/arch/lcdc.h> +#include <asm/arch/gpio.h> +#include <asm/gpio.h> + +struct sunxi_lcd_priv { + struct display_timing timing; + int panel_bpp; +}; + +static void sunxi_lcdc_config_pinmux(void) +{ +#ifdef CONFIG_MACH_SUN50I + int pin; + + for (pin = SUNXI_GPD(0); pin <= SUNXI_GPD(21); pin++) { + sunxi_gpio_set_cfgpin(pin, SUNXI_GPD_LCD0); + sunxi_gpio_set_drv(pin, 3); + } +#endif +} + +static int sunxi_lcd_enable(struct udevice *dev, int bpp, + const struct display_timing *edid) +{ + struct sunxi_ccm_reg * const ccm = + (struct sunxi_ccm_reg *)SUNXI_CCM_BASE; + struct sunxi_lcdc_reg * const lcdc = + (struct sunxi_lcdc_reg *)SUNXI_LCD0_BASE; + struct sunxi_lcd_priv *priv = dev_get_priv(dev); + struct udevice *backlight; + int clk_div, clk_double, ret; + + /* Reset off */ + setbits_le32(&ccm->ahb_reset1_cfg, 1 << AHB_RESET_OFFSET_LCD0); + /* Clock on */ + setbits_le32(&ccm->ahb_gate1, 1 << AHB_GATE_OFFSET_LCD0); + + lcdc_init(lcdc); + sunxi_lcdc_config_pinmux(); + lcdc_pll_set(ccm, 0, edid->pixelclock.typ / 1000, + &clk_div, &clk_double); + lcdc_tcon0_mode_set(lcdc, edid, clk_div, false, + priv->panel_bpp, CONFIG_VIDEO_LCD_DCLK_PHASE); + lcdc_enable(lcdc, priv->panel_bpp); + + ret = uclass_get_device(UCLASS_PANEL_BACKLIGHT, 0, &backlight); + if (!ret) + backlight_enable(backlight); + + return 0; +} + +static int sunxi_lcd_read_timing(struct udevice *dev, + struct display_timing *timing) +{ + struct sunxi_lcd_priv *priv = dev_get_priv(dev); + + memcpy(timing, &priv->timing, sizeof(struct display_timing)); + return 0; +} + +static int sunxi_lcd_probe(struct udevice *dev) +{ + struct udevice *cdev; + struct sunxi_lcd_priv *priv = dev_get_priv(dev); + int ret; + int node, timing_node, val; + +#ifdef CONFIG_VIDEO_BRIDGE + /* Try to get timings from bridge first */ + ret = uclass_get_device(UCLASS_VIDEO_BRIDGE, 0, &cdev); + if (!ret) { + u8 edid[EDID_SIZE]; + int channel_bpp; + + ret = video_bridge_attach(cdev); + if (ret) { + debug("video bridge attach failed: %d\n", ret); + return ret; + } + ret = video_bridge_read_edid(cdev, edid, EDID_SIZE); + if (ret > 0) { + ret = edid_get_timing(edid, ret, &priv->timing, + &channel_bpp); + priv->panel_bpp = channel_bpp * 3; + if (!ret) + return ret; + } + } +#endif + + /* Fallback to timings from DT if there's no bridge or + * if reading EDID failed + */ + ret = uclass_get_device(UCLASS_PANEL, 0, &cdev); + if (ret) { + debug("video panel not found: %d\n", ret); + return ret; + } + + if (fdtdec_decode_display_timing(gd->fdt_blob, dev_of_offset(cdev), + 0, &priv->timing)) { + debug("%s: Failed to decode display timing\n", __func__); + return -EINVAL; + } + timing_node = fdt_subnode_offset(gd->fdt_blob, dev_of_offset(cdev), + "display-timings"); + node = fdt_first_subnode(gd->fdt_blob, timing_node); + val = fdtdec_get_int(gd->fdt_blob, node, "bits-per-pixel", -1); + if (val != -1) + priv->panel_bpp = val; + else + priv->panel_bpp = 18; + + return 0; +} + +static const struct dm_display_ops sunxi_lcd_ops = { + .read_timing = sunxi_lcd_read_timing, + .enable = sunxi_lcd_enable, +}; + +U_BOOT_DRIVER(sunxi_lcd) = { + .name = "sunxi_lcd", + .id = UCLASS_DISPLAY, + .ops = &sunxi_lcd_ops, + .probe = sunxi_lcd_probe, + .priv_auto_alloc_size = sizeof(struct sunxi_lcd_priv), +}; + +#ifdef CONFIG_MACH_SUN50I +U_BOOT_DEVICE(sunxi_lcd) = { + .name = "sunxi_lcd" +}; +#endif
Anatolij Gustschin
Vasily Khoruzhick
