[U-Boot] [PATCH] Enable high speed support for USB device framework and usbtty
This patch adds the support for high speed in usb device framework and usbtty driver. This feature has been kept within a macro CONFIG_USBD_HS, so the board configuration files have to define this macro to enable high speed support.
Along with that specific peripheral drivers also need to define a function to let the framework know that the enumeration has happened at high speed. This function prototype is "int is_usbd_high_speed(void)"
Signed-off-by: Vipin Kumar vipin.kumar@st.com Signed-off-by: Amit Virdi amit.virdi@st.com --- README | 8 +++++++ drivers/serial/usbtty.c | 50 ++++++++++++++++++++++++++++++++++++++++++++- drivers/serial/usbtty.h | 4 +++ drivers/usb/gadget/core.c | 14 ++++++++++++ drivers/usb/gadget/ep0.c | 24 ++++++++++++++++++--- include/usbdescriptors.h | 15 +++++++++++++ include/usbdevice.h | 24 ++++++++++++++++++++- 7 files changed, 133 insertions(+), 6 deletions(-)
diff --git a/README b/README index eba6378..d54bb68 100644 --- a/README +++ b/README @@ -1165,6 +1165,14 @@ The following options need to be configured: Define this to have a tty type of device available to talk to the UDC device
+ CONFIG_USBD_HS + Define this to enable the high speed support for usb + device and usbtty. If this feature is enabled, a routine + int is_usbd_high_speed(void) + also needs to be defined by the driver to dynamically poll + whether the enumeration has succeded at high speed or full + speed. + CONFIG_SYS_CONSOLE_IS_IN_ENV Define this if you want stdin, stdout &/or stderr to be set to usbtty. diff --git a/drivers/serial/usbtty.c b/drivers/serial/usbtty.c index 550bc58..0374c7d 100644 --- a/drivers/serial/usbtty.c +++ b/drivers/serial/usbtty.c @@ -133,6 +133,19 @@ static struct usb_device_descriptor device_descriptor = { };
+#if defined(CONFIG_USBD_HS) +static struct usb_qualifier_descriptor qualifier_descriptor = { + .bLength = sizeof(struct usb_qualifier_descriptor), + .bDescriptorType = USB_DT_QUAL, + .bcdUSB = cpu_to_le16(USB_BCD_VERSION), + .bDeviceClass = COMMUNICATIONS_DEVICE_CLASS, + .bDeviceSubClass = 0x00, + .bDeviceProtocol = 0x00, + .bMaxPacketSize0 = EP0_MAX_PACKET_SIZE, + .bNumConfigurations = NUM_CONFIGS +}; +#endif + /* * Static CDC ACM specific descriptors */ @@ -638,6 +651,9 @@ static void usbtty_init_instances (void) memset (device_instance, 0, sizeof (struct usb_device_instance)); device_instance->device_state = STATE_INIT; device_instance->device_descriptor = &device_descriptor; +#if defined(CONFIG_USBD_HS) + device_instance->qualifier_descriptor = &qualifier_descriptor; +#endif device_instance->event = usbtty_event_handler; device_instance->cdc_recv_setup = usbtty_cdc_setup; device_instance->bus = bus_instance; @@ -751,6 +767,10 @@ static void usbtty_init_terminal_type(short type) device_descriptor.idProduct = cpu_to_le16(CONFIG_USBD_PRODUCTID_CDCACM);
+#if defined(CONFIG_USBD_HS) + qualifier_descriptor.bDeviceClass = + COMMUNICATIONS_DEVICE_CLASS; +#endif /* Assign endpoint indices */ tx_endpoint = ACM_TX_ENDPOINT; rx_endpoint = ACM_RX_ENDPOINT; @@ -779,7 +799,9 @@ static void usbtty_init_terminal_type(short type) device_descriptor.bDeviceClass = 0xFF; device_descriptor.idProduct = cpu_to_le16(CONFIG_USBD_PRODUCTID_GSERIAL); - +#if defined(CONFIG_USBD_HS) + qualifier_descriptor.bDeviceClass = 0xFF; +#endif /* Assign endpoint indices */ tx_endpoint = GSERIAL_TX_ENDPOINT; rx_endpoint = GSERIAL_RX_ENDPOINT; @@ -932,6 +954,9 @@ static int usbtty_configured (void) static void usbtty_event_handler (struct usb_device_instance *device, usb_device_event_t event, int data) { +#if defined(CONFIG_USBD_HS) + int i; +#endif switch (event) { case DEVICE_RESET: case DEVICE_BUS_INACTIVE: @@ -942,6 +967,29 @@ static void usbtty_event_handler (struct usb_device_instance *device, break;
case DEVICE_ADDRESS_ASSIGNED: +#if defined(CONFIG_USBD_HS) + /* + * is_usbd_high_speed routine needs to be defined by + * specific gadget driver + * It returns TRUE if device enumerates at High speed + * Retuns FALSE otherwise + */ + for (i = 1; i <= NUM_ENDPOINTS; i++) { + if (((ep_descriptor_ptrs[i - 1]->bmAttributes & + USB_ENDPOINT_XFERTYPE_MASK) == + USB_ENDPOINT_XFER_BULK) + && is_usbd_high_speed()) { + + ep_descriptor_ptrs[i - 1]->wMaxPacketSize = + CONFIG_USBD_SERIAL_BULK_HS_PKTSIZE; + } + + endpoint_instance[i].tx_packetSize = + ep_descriptor_ptrs[i - 1]->wMaxPacketSize; + endpoint_instance[i].rcv_packetSize = + ep_descriptor_ptrs[i - 1]->wMaxPacketSize; + } +#endif usbtty_init_endpoints ();
default: diff --git a/drivers/serial/usbtty.h b/drivers/serial/usbtty.h index 6731c38..bd3bcbc 100644 --- a/drivers/serial/usbtty.h +++ b/drivers/serial/usbtty.h @@ -72,6 +72,10 @@ #define CONFIG_USBD_SERIAL_INT_PKTSIZE UDC_INT_PACKET_SIZE #define CONFIG_USBD_SERIAL_BULK_PKTSIZE UDC_BULK_PACKET_SIZE
+#if defined(CONFIG_USBD_HS) +#define CONFIG_USBD_SERIAL_BULK_HS_PKTSIZE UDC_BULK_HS_PACKET_SIZE +#endif + #define USBTTY_DEVICE_CLASS COMMUNICATIONS_DEVICE_CLASS
#define USBTTY_BCD_DEVICE 0x00 diff --git a/drivers/usb/gadget/core.c b/drivers/usb/gadget/core.c index 4f2ebab..b2212b4 100644 --- a/drivers/usb/gadget/core.c +++ b/drivers/usb/gadget/core.c @@ -212,6 +212,20 @@ struct usb_device_descriptor *usbd_device_device_descriptor (struct usb_device_i return (device->device_descriptor); }
+#if defined(CONFIG_USBD_HS) +/** + * usbd_device_qualifier_descriptor + * @device: which device + * @port: which port + * + * Return the specified qualifier descriptor for the specified device. + */ +struct usb_qualifier_descriptor *usbd_device_qualifier_descriptor( + struct usb_device_instance *device, int port) +{ + return device->qualifier_descriptor; +} +#endif
/** * usbd_device_configuration_descriptor diff --git a/drivers/usb/gadget/ep0.c b/drivers/usb/gadget/ep0.c index 22499d3..ba8f906 100644 --- a/drivers/usb/gadget/ep0.c +++ b/drivers/usb/gadget/ep0.c @@ -338,12 +338,28 @@ static int ep0_get_descriptor (struct usb_device_instance *device, } break; case USB_DESCRIPTOR_TYPE_DEVICE_QUALIFIER: +#if defined(CONFIG_USBD_HS) { - /* If a USB device supports both a full speed and low speed operation - * we must send a Device_Qualifier descriptor here - */ - return -1; + struct usb_qualifier_descriptor *qualifier_descriptor; + + qualifier_descriptor = usbd_device_qualifier_descriptor + (device, port); + if (!qualifier_descriptor) + return -1; + + /* copy descriptor for this device */ + copy_config(urb, qualifier_descriptor, + sizeof(struct usb_qualifier_descriptor), + max); + } + dbg_ep0(3, "copied qualifier descriptor, actual_length: 0x%x", + urb->actual_length); +#else + return -1; +#endif + break; + default: return -1; } diff --git a/include/usbdescriptors.h b/include/usbdescriptors.h index 2dec3b9..de1069f 100644 --- a/include/usbdescriptors.h +++ b/include/usbdescriptors.h @@ -241,6 +241,21 @@ struct usb_device_descriptor { u8 bNumConfigurations; } __attribute__ ((packed));
+#if defined(CONFIG_USBD_HS) +struct usb_qualifier_descriptor { + u8 bLength; + u8 bDescriptorType; + + u16 bcdUSB; + u8 bDeviceClass; + u8 bDeviceSubClass; + u8 bDeviceProtocol; + u8 bMaxPacketSize0; + u8 bNumConfigurations; + u8 breserved; +} __attribute__ ((packed)); +#endif + struct usb_string_descriptor { u8 bLength; u8 bDescriptorType; /* 0x03 */ diff --git a/include/usbdevice.h b/include/usbdevice.h index 9eb8849..e3eb748 100644 --- a/include/usbdevice.h +++ b/include/usbdevice.h @@ -210,6 +210,10 @@ struct usb_bus_instance; #define USB_DT_INTERFACE 0x04 #define USB_DT_ENDPOINT 0x05
+#if defined(CONFIG_USBD_HS) +#define USB_DT_QUAL 0x06 +#endif + #define USB_DT_HID (USB_TYPE_CLASS | 0x01) #define USB_DT_REPORT (USB_TYPE_CLASS | 0x02) #define USB_DT_PHYSICAL (USB_TYPE_CLASS | 0x03) @@ -291,7 +295,11 @@ struct usb_bus_instance; * USB Spec Release number */
+#if defined(CONFIG_USBD_HS) +#define USB_BCD_VERSION 0x0200 +#else #define USB_BCD_VERSION 0x0110 +#endif
/* @@ -567,6 +575,9 @@ struct usb_device_instance { /* generic */ char *name; struct usb_device_descriptor *device_descriptor; /* per device descriptor */ +#if defined(CONFIG_USBD_HS) + struct usb_qualifier_descriptor *qualifier_descriptor; +#endif
void (*event) (struct usb_device_instance *device, usb_device_event_t event, int data);
@@ -659,8 +670,19 @@ struct usb_class_report_descriptor *usbd_device_class_report_descriptor_index( s struct usb_endpoint_descriptor *usbd_device_endpoint_descriptor (struct usb_device_instance *, int, int, int, int, int); int usbd_device_endpoint_transfersize (struct usb_device_instance *, int, int, int, int, int); struct usb_string_descriptor *usbd_get_string (u8); -struct usb_device_descriptor *usbd_device_device_descriptor (struct usb_device_instance *, int); +struct usb_device_descriptor *usbd_device_device_descriptor(struct + usb_device_instance *, int);
+#if defined(CONFIG_USBD_HS) +struct usb_qualifier_descriptor *usbd_device_qualifier_descriptor( + struct usb_device_instance *, int); +/* + * is_usbd_high_speed routine needs to be defined by specific gadget driver + * It returns TRUE if device enumerates at High speed + * Retuns FALSE otherwise + */ +int is_usbd_high_speed(void); +#endif int usbd_endpoint_halted (struct usb_device_instance *device, int endpoint); void usbd_rcv_complete(struct usb_endpoint_instance *endpoint, int len, int urb_bad); void usbd_tx_complete (struct usb_endpoint_instance *endpoint);
CONFIG_USBD_HS
poll
full
speed.
- .bLength = sizeof(struct usb_qualifier_descriptor),
- .bDescriptorType = USB_DT_QUAL,
- .bcdUSB = cpu_to_le16(USB_BCD_VERSION),
- .bDeviceClass = COMMUNICATIONS_DEVICE_CLASS,
- .bDeviceSubClass = 0x00,
- .bDeviceProtocol = 0x00,
- .bMaxPacketSize0 = EP0_MAX_PACKET_SIZE,
- .bNumConfigurations = NUM_CONFIGS
+}; +#endif
- Static CDC ACM specific descriptors
- device_instance->qualifier_descriptor = &qualifier_descriptor;
- int i;
Start with i = 0 and end with i < NUM_ENDPOINTS to avoid these i-1 below. Then fix those [i] with [i+1], there's less of those.
- usbd_device_qualifier_descriptor
- @device: which device
- @port: which port
- Return the specified qualifier descriptor for the specified device.
Make this static, but do you really need this function at all?
Otherwise seems ok
- return device->qualifier_descriptor;
+} +#endif
- usbd_device_configuration_descriptor
speed operation
return -1;
(device, port);
return -1;
max);
+#else
return -1;
break;
- default: return -1; }
- u8 bLength;
- u8 bDescriptorType;
- u16 bcdUSB;
- u8 bDeviceClass;
- u8 bDeviceSubClass;
- u8 bDeviceProtocol;
- u8 bMaxPacketSize0;
- u8 bNumConfigurations;
- u8 breserved;
- USB Spec Release number
descriptor
- struct usb_qualifier_descriptor *qualifier_descriptor;
int);
- is_usbd_high_speed routine needs to be defined by specific gadget
- Retuns FALSE otherwise
Hello Marek,
- int i;
for (i = 1; i<= NUM_ENDPOINTS; i++) {
Start with i = 0 and end with i< NUM_ENDPOINTS to avoid these i-1 below. Then fix those [i] with [i+1], there's less of those.
Ok.
if (((ep_descriptor_ptrs[i - 1]->bmAttributes&
- @port: which port
Well... usbd_device_qualifier_descriptor can't be static as the function is called from another file (ep0.c). However, since it is used only for EP0, it can be omitted for the time being keeping in mind we might need to define it in future (if the need arises). What do you think?
Otherwise seems ok
Thanks Amit Virdi
Hello Marek,
- int i;
Ok.
- @port: which port
What do you mean. If this is called from ep0.c, it has to be exported and that's how it is. On the other hand, if ep0.c already has access to the "device", it can directly access the device_descriptor field, which is I believe expressive enough.
Thanks for your good work so far, keep it up!
M
Otherwise seems ok
Thanks Amit Virdi
Hi Marek,
- @port: which port
Yes, ep0.c has direct access to the "device" field. I'll omit the usbd_device_qualifier_descriptor function in V2.
Thanks Amit Virdi
Hi Marek,
- @port: which port
Thank you :-)
M
Hi Marek,
How's V2 going?
Unfortunately Amit is not well and he is taking rest. He would resume on this from next week.
-- regards Shiraz
Dear Shiraz Hashim,
Hi Marek,
How's V2 going?
Please forward him that I wish him getting better ASAP.
Best regards, Marek Vasut
On 3/19/2012 3:58 PM, Marek Vasut wrote:
Dear Shiraz Hashim,
Hi Marek,
How's V2 going?
Thanks for your wishes Marek, I'm well now and back to office! I shall finish sending V2 of all the patches I have sent till date, within a couple of days.
Best Regards Amit Virdi
Dear Amit Virdi,
Dear Shiraz Hashim,
Hi Marek,
How's V2 going?
Good to see you back. Thanks for your efforts ;-)
Amit Virdi
Shiraz Hashim
