[U-Boot] [PATCH] clk: Allow clock defaults to be set also during re-reloc state
The earlier commit f4fcba5c5ba ("clk: implement clk_set_defaults()") which introduced the functionality for setting clock defaults such as rates and parents will skip the processing when executing in a re-reloc state. This for example can prevent the assigning of clock parents when running in SPL code. Go ahead and remove this limitation.
Signed-off-by: Andreas Dannenberg dannenberg@ti.com Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- - This was introduced to skip assigned-clock-rates in SPL. Instead CONFIG_OF_SPL_REMOVE_PROPS should be used to remove not needed properties in SPL.
drivers/clk/clk-uclass.c | 4 ---- 1 file changed, 4 deletions(-)
diff --git a/drivers/clk/clk-uclass.c b/drivers/clk/clk-uclass.c index 2b15978e14..04b369aa5a 100644 --- a/drivers/clk/clk-uclass.c +++ b/drivers/clk/clk-uclass.c @@ -243,10 +243,6 @@ int clk_set_defaults(struct udevice *dev) { int ret;
- /* If this is running pre-reloc state, don't take any action. */ - if (!(gd->flags & GD_FLG_RELOC)) - return 0; - debug("%s(%s)\n", __func__, dev_read_name(dev));
ret = clk_set_default_parents(dev);
Lokesh Vutla
