[PATCH u-boot-marvell 0/3] Turris Omnia DDR speed change with reset button (for 2024.10)
Hello Stefan,
this series adds the ability to select 1333H DDR speed mode for DDR training (instead of the default 1600K) with the factory reset button.
If possible, I would like if this series went for U-Boot 2024.10 release. The heavy stuff to support DDR speed change is already in, this just adds the ability to do it with reset button instead of console command (which is inconvenient for most users).
On Omnia, the user can select factory reset type by pressing the reset button on the rear panel and holding it. The front LEDs light on in sequence, representing a counter. Every ~2.5 second another LED lights on. When only the first LED is on, the board will do a standard reboot. Then different kinds of factory reboot will happen for reset types 1 to 7 (when 1, 2, ... or 7 LEDs are on) [1].
This series adds another reset type, number 10, which will make the board boot in 1333H DDR speed mode, and also write this setting to EEPROM, so that subsequent boots will also train in 1333H mode.
The user can set back the default mode with the `eeprom` U-Boot command, or with the `omnia-eeprom` Linux command.
Marek
[1] https://docs.turris.cz/hw/omnia/rescue-modes/
Marek Behún (3): arm: mvebu: turris_omnia: Rename variable holding EEPROM udevice arm: mvebu: turris_omnia: Use the i2c_eeprom misc driver for EEPROM reading in U-Boot proper arm: mvebu: turris_omnia: Switch DDR speed to 1333H when reset 9 is selected
arch/arm/mach-mvebu/Kconfig | 1 + board/CZ.NIC/turris_omnia/turris_omnia.c | 101 +++++++++++++++++++---- configs/turris_omnia_defconfig | 1 - 3 files changed, 86 insertions(+), 17 deletions(-)
Rename the variable holding the EEPROM udevice from `chip` to `eeprom`.
Signed-off-by: Marek Behún kabel@kernel.org --- board/CZ.NIC/turris_omnia/turris_omnia.c | 10 +++++----- 1 file changed, 5 insertions(+), 5 deletions(-)
diff --git a/board/CZ.NIC/turris_omnia/turris_omnia.c b/board/CZ.NIC/turris_omnia/turris_omnia.c index 2f29d26edf8..392df53a6d8 100644 --- a/board/CZ.NIC/turris_omnia/turris_omnia.c +++ b/board/CZ.NIC/turris_omnia/turris_omnia.c @@ -464,16 +464,16 @@ static bool check_eeprom_crc(const void *buf, size_t size, u32 expected,
static bool omnia_read_eeprom(struct omnia_eeprom *oep) { - struct udevice *chip; + struct udevice *eeprom; int ret;
- chip = omnia_get_i2c_chip("EEPROM", OMNIA_I2C_EEPROM_CHIP_ADDR, - OMNIA_I2C_EEPROM_CHIP_LEN); + eeprom = omnia_get_i2c_chip("EEPROM", OMNIA_I2C_EEPROM_CHIP_ADDR, + OMNIA_I2C_EEPROM_CHIP_LEN);
- if (!chip) + if (!eeprom) return false;
- ret = dm_i2c_read(chip, 0, (void *)oep, sizeof(*oep)); + ret = dm_i2c_read(eeprom, 0, (void *)oep, sizeof(*oep)); if (ret) { printf("dm_i2c_read failed: %i, cannot read EEPROM\n", ret); return false;
- struct udevice *eeprom; int ret;
- eeprom = omnia_get_i2c_chip("EEPROM", OMNIA_I2C_EEPROM_CHIP_ADDR,
- if (!chip)
- if (!eeprom) return false;
- ret = dm_i2c_read(eeprom, 0, (void *)oep, sizeof(*oep)); if (ret) { printf("dm_i2c_read failed: %i, cannot read EEPROM\n", ret); return false;
Thanks, Stefan
Use the i2c_eeprom miscellaneous driver for reading Turris Omnia EEPROM in U-Boot proper. Keep using dm_i2c_read() in SPL build, since adding the i2c_eeprom driver to SPL build increases the image by 1.5 KiB.
Signed-off-by: Marek Behún kabel@kernel.org --- arch/arm/mach-mvebu/Kconfig | 1 + board/CZ.NIC/turris_omnia/turris_omnia.c | 9 +++++++-- configs/turris_omnia_defconfig | 1 - 3 files changed, 8 insertions(+), 3 deletions(-)
diff --git a/arch/arm/mach-mvebu/Kconfig b/arch/arm/mach-mvebu/Kconfig index 4a8328760eb..c1a1a333e6c 100644 --- a/arch/arm/mach-mvebu/Kconfig +++ b/arch/arm/mach-mvebu/Kconfig @@ -149,6 +149,7 @@ config TARGET_TURRIS_OMNIA select SPL_SYS_MALLOC_SIMPLE select SYS_I2C_MVTWSI select ATSHA204A + select I2C_EEPROM select ARMADA_38X_SUPPORT_OLD_DDR3_TRAINING
config TARGET_TURRIS_MOX diff --git a/board/CZ.NIC/turris_omnia/turris_omnia.c b/board/CZ.NIC/turris_omnia/turris_omnia.c index 392df53a6d8..46f20f05c05 100644 --- a/board/CZ.NIC/turris_omnia/turris_omnia.c +++ b/board/CZ.NIC/turris_omnia/turris_omnia.c @@ -23,6 +23,7 @@ #include <dt-bindings/gpio/gpio.h> #include <fdt_support.h> #include <hexdump.h> +#include <i2c_eeprom.h> #include <time.h> #include <turris-omnia-mcu-interface.h> #include <linux/bitops.h> @@ -473,9 +474,13 @@ static bool omnia_read_eeprom(struct omnia_eeprom *oep) if (!eeprom) return false;
- ret = dm_i2c_read(eeprom, 0, (void *)oep, sizeof(*oep)); + if (IS_ENABLED(CONFIG_SPL_BUILD)) + ret = dm_i2c_read(eeprom, 0, (void *)oep, sizeof(*oep)); + else + ret = i2c_eeprom_read(eeprom, 0, (void *)oep, sizeof(*oep)); + if (ret) { - printf("dm_i2c_read failed: %i, cannot read EEPROM\n", ret); + printf("cannot read EEPROM: %d\n", ret); return false; }
diff --git a/configs/turris_omnia_defconfig b/configs/turris_omnia_defconfig index c8756a3a788..93f0bc53f9e 100644 --- a/configs/turris_omnia_defconfig +++ b/configs/turris_omnia_defconfig @@ -92,7 +92,6 @@ CONFIG_SPL_OF_TRANSLATE=y CONFIG_AHCI_PCI=y CONFIG_AHCI_MVEBU=y CONFIG_DM_PCA953X=y -CONFIG_I2C_EEPROM=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_MV=y CONFIG_DM_MTD=y
- if (IS_ENABLED(CONFIG_SPL_BUILD))
- else
So whats the advantage using i2c_eeprom_read() here in U-Boot proper? The only thing that stands out to me is that the code get more complex because of the SPL/non-SPL distinction.
Thanks, Stefan
- if (ret) {
return false; }printf("cannot read EEPROM: %d\n", ret);
- select I2C_EEPROM select ARMADA_38X_SUPPORT_OLD_DDR3_TRAINING config TARGET_TURRIS_MOX
- else
The reasons are as follows: - it's "more correct" semantically
- the i2c_eeprom driver was already enabled for U-Boot proper in defconfig (with this commit selected by the board), because of the `eeprom` commmand, so I thought "why not use it?" (looking at the code now, it goes i2c_eeprom_read() dereference of i2c_eeprom_ops->read method i2c_eeprom_std_read() dm_i2c_read() so the complication is trivial, IMO)
- the following commit adds code that writes the eeprom, and this cannot be done with simple dm_i2c_write(), because each eeprom page has to be written by another transaction, which is what i2c_eeprom_write() does.
So I knew that I was going to add i2c_eeprom_write(), and I thought that it would seem weird writing with i2c_eeprom_write() but reading with dm_i2c_read().
Marek
- else
That's what I thought after reviewing patch 3/3. Okay, makes sense. Let's see, if we can pull this into the upcoming release.
Thanks, Stefan
Users experiencing random kernel crashes due to new versions of Marvell's DDR training algorithm can solve the issue by setting DDR speed to 1333H.
But if kernel crashes, it has to be done in U-Boot, which is impossible without UART connection.
In order to make it easier for users, use the rescue button mechanism: when rescue mode 9 is selected (that is when 10 LEDs are ON), U-Boot will train DDR in 1333H mode and also update EEPROM so that subsequent boot will use this mode.
User has to use the `eeprom` command in U-Boot or `omnia-eeprom` command in OS to switch back to 1600K mode.
Signed-off-by: Marek Behún kabel@kernel.org --- board/CZ.NIC/turris_omnia/turris_omnia.c | 90 ++++++++++++++++++++---- 1 file changed, 77 insertions(+), 13 deletions(-)
diff --git a/board/CZ.NIC/turris_omnia/turris_omnia.c b/board/CZ.NIC/turris_omnia/turris_omnia.c index 46f20f05c05..eb88ee7f1ed 100644 --- a/board/CZ.NIC/turris_omnia/turris_omnia.c +++ b/board/CZ.NIC/turris_omnia/turris_omnia.c @@ -47,6 +47,9 @@ DECLARE_GLOBAL_DATA_PTR; #define OMNIA_I2C_EEPROM_CHIP_LEN 2 #define OMNIA_I2C_EEPROM_MAGIC 0x0341a034
+#define OMNIA_RESET_TO_LOWER_DDR_SPEED 9 +#define OMNIA_LOWER_DDR_SPEED "1333H" + #define A385_SYS_RSTOUT_MASK MVEBU_REGISTER(0x18260) #define A385_SYS_RSTOUT_MASK_WD BIT(10)
@@ -206,6 +209,20 @@ static u32 omnia_mcu_crc32(const void *p, size_t len) return ~bitrev32(crc); }
+static int omnia_mcu_get_reset(void) +{ + u8 reset_status; + int ret; + + ret = omnia_mcu_read(CMD_GET_RESET, &reset_status, 1); + if (ret) { + printf("omnia_mcu_read failed: %i, reset status unknown!\n", ret); + return ret; + } + + return reset_status; +} + /* Can only be called after relocation, since it needs cleared BSS */ static int omnia_mcu_board_info(char *serial, u8 *mac, char *version) { @@ -463,14 +480,17 @@ static bool check_eeprom_crc(const void *buf, size_t size, u32 expected, return true; }
+static struct udevice *omnia_get_eeprom(void) +{ + return omnia_get_i2c_chip("EEPROM", OMNIA_I2C_EEPROM_CHIP_ADDR, + OMNIA_I2C_EEPROM_CHIP_LEN); +} + static bool omnia_read_eeprom(struct omnia_eeprom *oep) { - struct udevice *eeprom; + struct udevice *eeprom = omnia_get_eeprom(); int ret;
- eeprom = omnia_get_i2c_chip("EEPROM", OMNIA_I2C_EEPROM_CHIP_ADDR, - OMNIA_I2C_EEPROM_CHIP_LEN); - if (!eeprom) return false;
@@ -502,6 +522,35 @@ static bool omnia_read_eeprom(struct omnia_eeprom *oep) return true; }
+static void omnia_eeprom_set_lower_ddr_speed(void) +{ + struct udevice *eeprom = omnia_get_eeprom(); + struct omnia_eeprom oep; + int ret; + + if (!eeprom || !omnia_read_eeprom(&oep)) + return; + + puts("Setting DDR speed to " OMNIA_LOWER_DDR_SPEED " in EEPROM as requested by reset button... "); + + /* check if already set */ + if (!strncmp(oep.ddr_speed, OMNIA_LOWER_DDR_SPEED, sizeof(oep.ddr_speed)) && + (oep.old_ddr_training == 0 || oep.old_ddr_training == 0xff)) { + puts("was already set\n"); + return; + } + + strncpy(oep.ddr_speed, OMNIA_LOWER_DDR_SPEED, sizeof(oep.ddr_speed)); + oep.old_ddr_training = 0xff; + oep.crc2 = crc32(0, (const void *)&oep, offsetof(struct omnia_eeprom, crc2)); + + ret = i2c_eeprom_write(eeprom, 0, (const void *)&oep, sizeof(oep)); + if (ret) + printf("cannot write EEPROM: %d\n", ret); + else + puts("done\n"); +} + int omnia_get_ram_size_gb(void) { static int ram_size; @@ -531,6 +580,13 @@ bool board_use_old_ddr3_training(void) { struct omnia_eeprom oep;
+ /* + * If lower DDR speed is requested by reset button, we can't use old DDR + * training algorithm. + */ + if (omnia_mcu_get_reset() == OMNIA_RESET_TO_LOWER_DDR_SPEED) + return false; + if (!omnia_read_eeprom(&oep)) return false;
@@ -711,13 +767,19 @@ static void fixup_speed_in_ddr_topology(struct mv_ddr_topology_map *topology) const struct omnia_ddr_speed *setting; const char *speed; static bool done; + int reset_status;
if (done) return;
done = true;
- speed = omnia_get_ddr_speed(); + reset_status = omnia_mcu_get_reset(); + if (reset_status == OMNIA_RESET_TO_LOWER_DDR_SPEED) + speed = OMNIA_LOWER_DDR_SPEED; + else + speed = omnia_get_ddr_speed(); + if (!speed) return;
@@ -734,7 +796,10 @@ static void fixup_speed_in_ddr_topology(struct mv_ddr_topology_map *topology) if (params->speed_bin_index == setting->speed_bin) return;
- printf("Fixing up DDR3 speed (EEPROM defines %s)\n", speed); + if (reset_status == OMNIA_RESET_TO_LOWER_DDR_SPEED) + printf("Fixing up DDR3 speed to %s as requested by reset button\n", speed); + else + printf("Fixing up DDR3 speed (EEPROM defines %s)\n", speed);
params->speed_bin_index = setting->speed_bin; params->memory_freq = setting->freq; @@ -771,8 +836,7 @@ static int set_regdomain(void) static void handle_reset_button(void) { const char * const vars[1] = { "bootcmd_rescue", }; - int ret; - u8 reset_status; + int reset_status;
/* * Ensure that bootcmd_rescue has always stock value, so that running @@ -781,12 +845,12 @@ static void handle_reset_button(void) */ env_set_default_vars(1, (char * const *)vars, 0);
- ret = omnia_mcu_read(CMD_GET_RESET, &reset_status, 1); - if (ret) { - printf("omnia_mcu_read failed: %i, reset status unknown!\n", - ret); + reset_status = omnia_mcu_get_reset(); + if (reset_status < 0) return; - } + + if (reset_status == OMNIA_RESET_TO_LOWER_DDR_SPEED) + return omnia_eeprom_set_lower_ddr_speed();
env_set_ulong("omnia_reset", reset_status);
- #define A385_SYS_RSTOUT_MASK MVEBU_REGISTER(0x18260) #define A385_SYS_RSTOUT_MASK_WD BIT(10)
- u8 reset_status;
- int ret;
- if (ret) {
return ret;
- return reset_status;
- /* Can only be called after relocation, since it needs cleared BSS */ static int omnia_mcu_board_info(char *serial, u8 *mac, char *version) {
- return omnia_get_i2c_chip("EEPROM", OMNIA_I2C_EEPROM_CHIP_ADDR,
- static bool omnia_read_eeprom(struct omnia_eeprom *oep) {
- struct udevice *eeprom = omnia_get_eeprom(); int ret;
- struct omnia_eeprom oep;
- int ret;
- if (!eeprom || !omnia_read_eeprom(&oep))
return;
- puts("Setting DDR speed to " OMNIA_LOWER_DDR_SPEED " in EEPROM as requested by reset button... ");
- /* check if already set */
- if (!strncmp(oep.ddr_speed, OMNIA_LOWER_DDR_SPEED, sizeof(oep.ddr_speed)) &&
return;
- strncpy(oep.ddr_speed, OMNIA_LOWER_DDR_SPEED, sizeof(oep.ddr_speed));
- oep.old_ddr_training = 0xff;
- oep.crc2 = crc32(0, (const void *)&oep, offsetof(struct omnia_eeprom, crc2));
- ret = i2c_eeprom_write(eeprom, 0, (const void *)&oep, sizeof(oep));
- if (ret)
- else
puts("done\n");
- int omnia_get_ram_size_gb(void) { static int ram_size;
- if (omnia_mcu_get_reset() == OMNIA_RESET_TO_LOWER_DDR_SPEED)
return false;
- if (!omnia_read_eeprom(&oep)) return false;
int reset_status;
if (done) return;
done = true;
- reset_status = omnia_mcu_get_reset();
- if (reset_status == OMNIA_RESET_TO_LOWER_DDR_SPEED)
- else
- if (!speed) return;
else
- int ret;
- u8 reset_status;
int reset_status;
- Ensure that bootcmd_rescue has always stock value, so that running
- if (ret) {
ret);
- if (reset_status < 0) return;
Thanks, Stefan
Hello Stefan,
Applied to u-boot-marvell/master
Thanks, Stefan
Marek
Viele Grüße, Stefan Roese
Marek Behún
Stefan Roese
