[PATCH v3 0/5] Add support for StarFive JH7110 TRNG driver
This patchset adds to support StarFive JH7110 TRNG driver. Due to lack of readl_relaxed API, the first patch tries to import the APIs(read/write_relaxed) from Linux kernel's implementation. The second patch adds the missing security clocks which are required by the trng IP.
This IP can support 128-bit and 256-bit random number generation but this patch makes 256-bit default mode for convenience.
Changes from v2: - Patch #3: Add error handling codes of probe() which are suggested by Jaehoon
Changes from v1: - Patch #3: Apply Heinrich's reviews and his codes - Patch #5: Add Heinrich's R-b tag
Chanho Park (5): riscv: import read/write_relaxed functions clk: starfive: jh7110: Add security clocks rng: Add StarFive JH7110 RNG driver riscv: dts: jh7110: Add rng device tree node configs: visionfive2: Enable JH7110 RNG driver
arch/riscv/dts/jh7110.dtsi | 10 + arch/riscv/include/asm/io.h | 45 ++++ configs/starfive_visionfive2_defconfig | 2 + drivers/clk/starfive/clk-jh7110.c | 10 + drivers/rng/Kconfig | 6 + drivers/rng/Makefile | 1 + drivers/rng/jh7110_rng.c | 271 +++++++++++++++++++++++++ 7 files changed, 345 insertions(+) create mode 100644 drivers/rng/jh7110_rng.c
This imports mmio functions from Linux's arch/riscv/include/asm/mmio.h to use read/write[b|w|l|q]_relaxed functions.
Signed-off-by: Chanho Park chanho61.park@samsung.com --- arch/riscv/include/asm/io.h | 45 +++++++++++++++++++++++++++++++++++++ 1 file changed, 45 insertions(+)
diff --git a/arch/riscv/include/asm/io.h b/arch/riscv/include/asm/io.h index b16e6dfa3760..4170877a1ae0 100644 --- a/arch/riscv/include/asm/io.h +++ b/arch/riscv/include/asm/io.h @@ -323,6 +323,51 @@ static inline void writesl(unsigned int *addr, const void *data, int longlen) #define insw_p(port, to, len) insw(port, to, len) #define insl_p(port, to, len) insl(port, to, len)
+/* + * Unordered I/O memory access primitives. These are even more relaxed than + * the relaxed versions, as they don't even order accesses between successive + * operations to the I/O regions. + */ +#define readb_cpu(c) ({ u8 __r = __raw_readb(c); __r; }) +#define readw_cpu(c) ({ u16 __r = le16_to_cpu((__force __le16)__raw_readw(c)); __r; }) +#define readl_cpu(c) ({ u32 __r = le32_to_cpu((__force __le32)__raw_readl(c)); __r; }) + +#define writeb_cpu(v, c) ((void)__raw_writeb((v), (c))) +#define writew_cpu(v, c) ((void)__raw_writew((__force u16)cpu_to_le16(v), (c))) +#define writel_cpu(v, c) ((void)__raw_writel((__force u32)cpu_to_le32(v), (c))) + +#ifdef CONFIG_64BIT +#define readq_cpu(c) ({ u64 __r = le64_to_cpu((__force __le64)__raw_readq(c)); __r; }) +#define writeq_cpu(v, c) ((void)__raw_writeq((__force u64)cpu_to_le64(v), (c))) +#endif + +/* + * Relaxed I/O memory access primitives. These follow the Device memory + * ordering rules but do not guarantee any ordering relative to Normal memory + * accesses. These are defined to order the indicated access (either a read or + * write) with all other I/O memory accesses to the same peripheral. Since the + * platform specification defines that all I/O regions are strongly ordered on + * channel 0, no explicit fences are required to enforce this ordering. + */ +/* FIXME: These are now the same as asm-generic */ +#define __io_rbr() do {} while (0) +#define __io_rar() do {} while (0) +#define __io_rbw() do {} while (0) +#define __io_raw() do {} while (0) + +#define readb_relaxed(c) ({ u8 __v; __io_rbr(); __v = readb_cpu(c); __io_rar(); __v; }) +#define readw_relaxed(c) ({ u16 __v; __io_rbr(); __v = readw_cpu(c); __io_rar(); __v; }) +#define readl_relaxed(c) ({ u32 __v; __io_rbr(); __v = readl_cpu(c); __io_rar(); __v; }) + +#define writeb_relaxed(v, c) ({ __io_rbw(); writeb_cpu((v), (c)); __io_raw(); }) +#define writew_relaxed(v, c) ({ __io_rbw(); writew_cpu((v), (c)); __io_raw(); }) +#define writel_relaxed(v, c) ({ __io_rbw(); writel_cpu((v), (c)); __io_raw(); }) + +#ifdef CONFIG_64BIT +#define readq_relaxed(c) ({ u64 __v; __io_rbr(); __v = readq_cpu(c); __io_rar(); __v; }) +#define writeq_relaxed(v, c) ({ __io_rbw(); writeq_cpu((v), (c)); __io_raw(); }) +#endif + #include <asm-generic/io.h>
#endif /* __ASM_RISCV_IO_H */
Add STGCLK_SEC_HCLK and STGCLK_SEC_MISCAHB clocks for JH7110 TRNG device.
Signed-off-by: Chanho Park chanho61.park@samsung.com --- drivers/clk/starfive/clk-jh7110.c | 10 ++++++++++ 1 file changed, 10 insertions(+)
diff --git a/drivers/clk/starfive/clk-jh7110.c b/drivers/clk/starfive/clk-jh7110.c index 31aaf3340f94..a835541e48e9 100644 --- a/drivers/clk/starfive/clk-jh7110.c +++ b/drivers/clk/starfive/clk-jh7110.c @@ -539,6 +539,16 @@ static int jh7110_stgcrg_init(struct udevice *dev) "pcie1_tl", "stg_axiahb", OFFSET(JH7110_STGCLK_PCIE1_TL)));
+ /* Security clocks */ + clk_dm(JH7110_STG_ID_TRANS(JH7110_STGCLK_SEC_HCLK), + starfive_clk_gate(priv->reg, + "sec_ahb", "stg_axiahb", + OFFSET(JH7110_STGCLK_SEC_HCLK))); + clk_dm(JH7110_STG_ID_TRANS(JH7110_STGCLK_SEC_MISCAHB), + starfive_clk_gate(priv->reg, + "sec_misc_ahb", "stg_axiahb", + OFFSET(JH7110_STGCLK_SEC_MISCAHB))); + return 0; }
Adds to support JH7110 TRNG driver which is based on linux kernel's jh7110-trng.c. This can support to generate 256-bit random numbers and 128-bit but this makes 256-bit default for convenience.
Signed-off-by: Chanho Park chanho61.park@samsung.com --- drivers/rng/Kconfig | 6 + drivers/rng/Makefile | 1 + drivers/rng/jh7110_rng.c | 271 +++++++++++++++++++++++++++++++++++++++ 3 files changed, 278 insertions(+) create mode 100644 drivers/rng/jh7110_rng.c
diff --git a/drivers/rng/Kconfig b/drivers/rng/Kconfig index 994cc35b2744..0dba1e06b429 100644 --- a/drivers/rng/Kconfig +++ b/drivers/rng/Kconfig @@ -91,4 +91,10 @@ config TPM_RNG functionality. Enable random number generator on TPM devices.
+config RNG_JH7110 + bool "StarFive JH7110 Random Number Generator support" + depends on DM_RNG && STARFIVE_JH7110 + help + Enable True Random Number Generator in StarFive JH7110 SoCs. + endif diff --git a/drivers/rng/Makefile b/drivers/rng/Makefile index 47b323e61ee3..9de762c8a1c3 100644 --- a/drivers/rng/Makefile +++ b/drivers/rng/Makefile @@ -15,3 +15,4 @@ obj-$(CONFIG_RNG_IPROC200) += iproc_rng200.o obj-$(CONFIG_RNG_SMCCC_TRNG) += smccc_trng.o obj-$(CONFIG_RNG_ARM_RNDR) += arm_rndr.o obj-$(CONFIG_TPM_RNG) += tpm_rng.o +obj-$(CONFIG_RNG_JH7110) += jh7110_rng.o diff --git a/drivers/rng/jh7110_rng.c b/drivers/rng/jh7110_rng.c new file mode 100644 index 000000000000..075a2d78eb2c --- /dev/null +++ b/drivers/rng/jh7110_rng.c @@ -0,0 +1,271 @@ +// SPDX-License-Identifier: GPL-2.0-or-later +/* + * TRNG driver for the StarFive JH7110 SoC + * + */ + +#include <clk.h> +#include <dm.h> +#include <reset.h> +#include <rng.h> +#include <asm/io.h> +#include <linux/iopoll.h> + +/* trng register offset */ +#define STARFIVE_CTRL 0x00 +#define STARFIVE_STAT 0x04 +#define STARFIVE_MODE 0x08 +#define STARFIVE_SMODE 0x0C +#define STARFIVE_IE 0x10 +#define STARFIVE_ISTAT 0x14 +#define STARFIVE_RAND0 0x20 +#define STARFIVE_RAND1 0x24 +#define STARFIVE_RAND2 0x28 +#define STARFIVE_RAND3 0x2C +#define STARFIVE_RAND4 0x30 +#define STARFIVE_RAND5 0x34 +#define STARFIVE_RAND6 0x38 +#define STARFIVE_RAND7 0x3C +#define STARFIVE_AUTO_RQSTS 0x60 +#define STARFIVE_AUTO_AGE 0x64 + +/* CTRL CMD */ +#define STARFIVE_CTRL_EXEC_NOP 0x0 +#define STARFIVE_CTRL_GENE_RANDNUM 0x1 +#define STARFIVE_CTRL_EXEC_RANDRESEED 0x2 + +/* STAT */ +#define STARFIVE_STAT_NONCE_MODE BIT(2) +#define STARFIVE_STAT_R256 BIT(3) +#define STARFIVE_STAT_MISSION_MODE BIT(8) +#define STARFIVE_STAT_SEEDED BIT(9) +#define STARFIVE_STAT_LAST_RESEED(x) ((x) << 16) +#define STARFIVE_STAT_SRVC_RQST BIT(27) +#define STARFIVE_STAT_RAND_GENERATING BIT(30) +#define STARFIVE_STAT_RAND_SEEDING BIT(31) +#define STARFIVE_STAT_RUNNING (STARFIVE_STAT_RAND_GENERATING | \ + STARFIVE_STAT_RAND_SEEDING) + +/* MODE */ +#define STARFIVE_MODE_R256 BIT(3) + +/* SMODE */ +#define STARFIVE_SMODE_NONCE_MODE BIT(2) +#define STARFIVE_SMODE_MISSION_MODE BIT(8) +#define STARFIVE_SMODE_MAX_REJECTS(x) ((x) << 16) + +/* IE */ +#define STARFIVE_IE_RAND_RDY_EN BIT(0) +#define STARFIVE_IE_SEED_DONE_EN BIT(1) +#define STARFIVE_IE_LFSR_LOCKUP_EN BIT(4) +#define STARFIVE_IE_GLBL_EN BIT(31) + +#define STARFIVE_IE_ALL (STARFIVE_IE_GLBL_EN | \ + STARFIVE_IE_RAND_RDY_EN | \ + STARFIVE_IE_SEED_DONE_EN | \ + STARFIVE_IE_LFSR_LOCKUP_EN) + +/* ISTAT */ +#define STARFIVE_ISTAT_RAND_RDY BIT(0) +#define STARFIVE_ISTAT_SEED_DONE BIT(1) +#define STARFIVE_ISTAT_LFSR_LOCKUP BIT(4) + +#define STARFIVE_RAND_LEN sizeof(u32) + +enum mode { + PRNG_128BIT, + PRNG_256BIT, +}; + +struct starfive_trng_plat { + void *base; + struct clk *hclk; + struct clk *ahb; + struct reset_ctl *rst; + u32 mode; +}; + +static inline int starfive_trng_wait_idle(struct starfive_trng_plat *trng) +{ + u32 stat; + + return readl_relaxed_poll_timeout(trng->base + STARFIVE_STAT, stat, + !(stat & STARFIVE_STAT_RUNNING), + 100000); +} + +static inline void starfive_trng_irq_mask_clear(struct starfive_trng_plat *trng) +{ + /* clear register: ISTAT */ + u32 data = readl(trng->base + STARFIVE_ISTAT); + + writel(data, trng->base + STARFIVE_ISTAT); +} + +static int starfive_trng_cmd(struct starfive_trng_plat *trng, u32 cmd) +{ + u32 stat, flg; + int ret; + + switch (cmd) { + case STARFIVE_CTRL_GENE_RANDNUM: + writel(cmd, trng->base + STARFIVE_CTRL); + flg = STARFIVE_ISTAT_RAND_RDY; + break; + case STARFIVE_CTRL_EXEC_RANDRESEED: + writel(cmd, trng->base + STARFIVE_CTRL); + flg = STARFIVE_ISTAT_SEED_DONE; + break; + default: + return -EINVAL; + } + + ret = readl_relaxed_poll_timeout(trng->base + STARFIVE_ISTAT, stat, + (stat & flg), 1000); + writel(flg, trng->base + STARFIVE_ISTAT); + + return ret; +} + +static int starfive_trng_read(struct udevice *dev, void *data, size_t len) +{ + struct starfive_trng_plat *trng = dev_get_plat(dev); + u8 *buffer = data; + int iter_mask; + + if (trng->mode == PRNG_256BIT) + iter_mask = 7; + else + iter_mask = 3; + + for (int i = 0; len; ++i, i &= iter_mask) { + u32 val; + size_t step; + int ret; + + ret = starfive_trng_cmd(trng, STARFIVE_CTRL_GENE_RANDNUM); + if (ret) + return ret; + + val = readl(trng->base + STARFIVE_RAND0 + + (i * STARFIVE_RAND_LEN)); + step = min_t(size_t, len, STARFIVE_RAND_LEN); + memcpy(buffer, &val, step); + buffer += step; + len -= step; + } + + return 0; +} + +static int starfive_trng_init(struct starfive_trng_plat *trng) +{ + u32 mode, intr = 0; + + /* setup Auto Request/Age register */ + writel(0, trng->base + STARFIVE_AUTO_AGE); + writel(0, trng->base + STARFIVE_AUTO_RQSTS); + + /* clear register: ISTAT */ + starfive_trng_irq_mask_clear(trng); + + intr |= STARFIVE_IE_ALL; + writel(intr, trng->base + STARFIVE_IE); + + mode = readl(trng->base + STARFIVE_MODE); + + switch (trng->mode) { + case PRNG_128BIT: + mode &= ~STARFIVE_MODE_R256; + break; + case PRNG_256BIT: + mode |= STARFIVE_MODE_R256; + break; + default: + mode |= STARFIVE_MODE_R256; + break; + } + + writel(mode, trng->base + STARFIVE_MODE); + + return starfive_trng_cmd(trng, STARFIVE_CTRL_EXEC_RANDRESEED); +} + +static int starfive_trng_probe(struct udevice *dev) +{ + struct starfive_trng_plat *pdata = dev_get_plat(dev); + int err; + + err = clk_enable(pdata->hclk); + if (err) + return err; + + err = clk_enable(pdata->ahb); + if (err) + goto err_ahb; + + err = reset_deassert(pdata->rst); + if (err) + goto err_reset; + + pdata->mode = PRNG_256BIT; + + err = starfive_trng_init(pdata); + if (err) + goto err_trng_init; + + return 0; + +err_trng_init: + reset_assert(pdata->rst); +err_reset: + clk_disable(pdata->ahb); +err_ahb: + clk_disable(pdata->hclk); + + return err; +} + +static int starfive_trng_of_to_plat(struct udevice *dev) +{ + struct starfive_trng_plat *pdata = dev_get_plat(dev); + + pdata->base = (void *)dev_read_addr(dev); + if (!pdata->base) + return -ENODEV; + + pdata->hclk = devm_clk_get(dev, "hclk"); + if (IS_ERR(pdata->hclk)) + return -ENODEV; + + pdata->ahb = devm_clk_get(dev, "ahb"); + if (IS_ERR(pdata->ahb)) + return -ENODEV; + + pdata->rst = devm_reset_control_get(dev, NULL); + if (IS_ERR(pdata->rst)) + return -ENODEV; + + return 0; +} + +static const struct dm_rng_ops starfive_trng_ops = { + .read = starfive_trng_read, +}; + +static const struct udevice_id starfive_trng_match[] = { + { + .compatible = "starfive,jh7110-trng", + }, + {}, +}; + +U_BOOT_DRIVER(starfive_trng) = { + .name = "jh7110-trng", + .id = UCLASS_RNG, + .of_match = starfive_trng_match, + .probe = starfive_trng_probe, + .ops = &starfive_trng_ops, + .plat_auto = sizeof(struct starfive_trng_plat), + .of_to_plat = starfive_trng_of_to_plat, +};
+config RNG_JH7110
- bool "StarFive JH7110 Random Number Generator support"
- depends on DM_RNG && STARFIVE_JH7110
- help
- endif
- TRNG driver for the StarFive JH7110 SoC
+enum mode {
- PRNG_128BIT,
- PRNG_256BIT,
- void *base;
- struct clk *hclk;
- struct clk *ahb;
- struct reset_ctl *rst;
- u32 mode;
- u32 stat;
- return readl_relaxed_poll_timeout(trng->base + STARFIVE_STAT, stat,
100000);
- /* clear register: ISTAT */
- u32 data = readl(trng->base + STARFIVE_ISTAT);
- writel(data, trng->base + STARFIVE_ISTAT);
- u32 stat, flg;
- int ret;
- switch (cmd) {
- case STARFIVE_CTRL_GENE_RANDNUM:
break;
- case STARFIVE_CTRL_EXEC_RANDRESEED:
break;
- default:
return -EINVAL;
- ret = readl_relaxed_poll_timeout(trng->base + STARFIVE_ISTAT, stat,
- writel(flg, trng->base + STARFIVE_ISTAT);
- return ret;
- struct starfive_trng_plat *trng = dev_get_plat(dev);
- u8 *buffer = data;
- int iter_mask;
- if (trng->mode == PRNG_256BIT)
iter_mask = 7;
- else
iter_mask = 3;
- for (int i = 0; len; ++i, i &= iter_mask) {
u32 val;
size_t step;
int ret;
I think you are missing
if (!i) {
here as one call to starfive_trng_cmd is giving you 128 or 256 bits of entropy.
Best regards
Heinrich
if (ret)
return ret;
buffer += step;
len -= step;
- u32 mode, intr = 0;
- /* setup Auto Request/Age register */
- writel(0, trng->base + STARFIVE_AUTO_AGE);
- writel(0, trng->base + STARFIVE_AUTO_RQSTS);
- starfive_trng_irq_mask_clear(trng);
- intr |= STARFIVE_IE_ALL;
- writel(intr, trng->base + STARFIVE_IE);
- mode = readl(trng->base + STARFIVE_MODE);
- switch (trng->mode) {
- case PRNG_128BIT:
break;
- case PRNG_256BIT:
break;
- default:
break;
- writel(mode, trng->base + STARFIVE_MODE);
- return starfive_trng_cmd(trng, STARFIVE_CTRL_EXEC_RANDRESEED);
- struct starfive_trng_plat *pdata = dev_get_plat(dev);
- int err;
- err = clk_enable(pdata->hclk);
- if (err)
return err;
- err = clk_enable(pdata->ahb);
- if (err)
goto err_ahb;
- err = reset_deassert(pdata->rst);
- if (err)
goto err_reset;
- pdata->mode = PRNG_256BIT;
- err = starfive_trng_init(pdata);
- if (err)
goto err_trng_init;
+err_trng_init:
- reset_assert(pdata->rst);
+err_reset:
- clk_disable(pdata->ahb);
+err_ahb:
- clk_disable(pdata->hclk);
- return err;
- pdata->base = (void *)dev_read_addr(dev);
- if (!pdata->base)
return -ENODEV;
- pdata->hclk = devm_clk_get(dev, "hclk");
- if (IS_ERR(pdata->hclk))
return -ENODEV;
- pdata->ahb = devm_clk_get(dev, "ahb");
- if (IS_ERR(pdata->ahb))
return -ENODEV;
- pdata->rst = devm_reset_control_get(dev, NULL);
- if (IS_ERR(pdata->rst))
return -ENODEV;
- .read = starfive_trng_read,
- .name = "jh7110-trng",
- .id = UCLASS_RNG,
- .of_match = starfive_trng_match,
- .probe = starfive_trng_probe,
- .ops = &starfive_trng_ops,
- .plat_auto = sizeof(struct starfive_trng_plat),
- .of_to_plat = starfive_trng_of_to_plat,
-----Original Message----- From: Heinrich Schuchardt xypron.glpk@gmx.de Sent: Wednesday, November 1, 2023 9:00 PM To: Chanho Park chanho61.park@samsung.com Cc: Sughosh Ganu sughosh.ganu@linaro.org; u-boot@lists.denx.de; Rick Chen rick@andestech.com; Leo ycliang@andestech.com; Jaehoon Chung jh80.chung@samsung.com Subject: Re: [PATCH v3 3/5] rng: Add StarFive JH7110 RNG driver
+config RNG_JH7110
- help
- endif
+enum mode {
- PRNG_128BIT,
- PRNG_256BIT,
- void *base;
- struct clk *hclk;
- struct clk *ahb;
- u32 mode;
*trng)
- u32 stat;
100000);
- u32 stat, flg;
- int ret;
- switch (cmd) {
break;
break;
- default:
return -EINVAL;
- return ret;
len)
- int iter_mask;
iter_mask = 7;
- else
iter_mask = 3;
u32 val;
size_t step;
int ret;
if (!i) {
Oh. I missed this while I made the patches. Thanks for the heads up. I'll quickly update it in the next patch.
Best Regards, Chanho Park
Adds jh7110 trng device tree node.
Signed-off-by: Chanho Park chanho61.park@samsung.com --- arch/riscv/dts/jh7110.dtsi | 10 ++++++++++ 1 file changed, 10 insertions(+)
diff --git a/arch/riscv/dts/jh7110.dtsi b/arch/riscv/dts/jh7110.dtsi index ec237a46ffba..13c47f7caa36 100644 --- a/arch/riscv/dts/jh7110.dtsi +++ b/arch/riscv/dts/jh7110.dtsi @@ -627,6 +627,16 @@ status = "disabled"; };
+ rng: rng@1600c000 { + compatible = "starfive,jh7110-trng"; + reg = <0x0 0x1600C000 0x0 0x4000>; + clocks = <&stgcrg JH7110_STGCLK_SEC_HCLK>, + <&stgcrg JH7110_STGCLK_SEC_MISCAHB>; + clock-names = "hclk", "ahb"; + resets = <&stgcrg JH7110_STGRST_SEC_TOP_HRESETN>; + interrupts = <30>; + }; + aoncrg: clock-controller@17000000 { compatible = "starfive,jh7110-aoncrg"; reg = <0x0 0x17000000 0x0 0x10000>;
Enables JH7110 RNG driver to visionfive2 board.
Signed-off-by: Chanho Park chanho61.park@samsung.com Reviewed-by: Heinrich Schuchardt xypron.glpk@gmx.de --- configs/starfive_visionfive2_defconfig | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/configs/starfive_visionfive2_defconfig b/configs/starfive_visionfive2_defconfig index b21754feafce..b15e7d24db19 100644 --- a/configs/starfive_visionfive2_defconfig +++ b/configs/starfive_visionfive2_defconfig @@ -120,6 +120,8 @@ CONFIG_SPL_PINCTRL_STARFIVE=y CONFIG_SPL_PINCTRL_STARFIVE_JH7110=y CONFIG_PINCTRL_STARFIVE=y # CONFIG_RAM_SIFIVE is not set +CONFIG_DM_RNG=y +CONFIG_RNG_JH7110=y CONFIG_SYS_NS16550=y CONFIG_CADENCE_QSPI=y CONFIG_TIMER_EARLY=y
Chanho Park
