[U-Boot] [PATCH] integratorcp: make the board compile
This defines the requires CONFIG_SYS_* variables to make the Integrator CP board compile.
Signed-off-by: Linus Walleij linus.walleij@linaro.org --- This complements the other Integrator patches so that the CP variants also build cleanly with the new build system. --- include/configs/integratorcp.h | 6 ++++++ 1 files changed, 6 insertions(+), 0 deletions(-)
diff --git a/include/configs/integratorcp.h b/include/configs/integratorcp.h index 210bc9d..e9b68c6 100644 --- a/include/configs/integratorcp.h +++ b/include/configs/integratorcp.h @@ -142,6 +142,12 @@ SIB at Block62 End Block62 address 0x24f80000 #define CONFIG_NR_DRAM_BANKS 1 /* we have 1 bank of DRAM */ #define PHYS_SDRAM_1 0x00000000 /* SDRAM Bank #1 */ #define PHYS_SDRAM_1_SIZE 0x08000000 /* 128 MB */ +#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 +#define CONFIG_SYS_INIT_RAM_SIZE PHYS_SDRAM_1_SIZE +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_SDRAM_BASE + \ + CONFIG_SYS_INIT_RAM_SIZE - \ + GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_ADDR CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- * FLASH and environment organization
Linus Walleij
