[PATCH] dm: core: Use device_foreach_child where possible
We have some nice macros for iterating over devices in device.h, but they are not used by the driver core. Convert all the users I could find.
Signed-off-by: Sean Anderson seanga2@gmail.com ---
drivers/core/device-remove.c | 4 ++-- drivers/core/device.c | 21 ++++++++++----------- drivers/core/devres.c | 2 +- drivers/core/dump.c | 2 +- 4 files changed, 14 insertions(+), 15 deletions(-)
diff --git a/drivers/core/device-remove.c b/drivers/core/device-remove.c index 73d2e9e420..a86b9325dd 100644 --- a/drivers/core/device-remove.c +++ b/drivers/core/device-remove.c @@ -29,7 +29,7 @@ int device_chld_unbind(struct udevice *dev, struct driver *drv)
assert(dev);
- list_for_each_entry_safe(pos, n, &dev->child_head, sibling_node) { + device_foreach_child_safe(pos, n, dev) { if (drv && (pos->driver != drv)) continue;
@@ -52,7 +52,7 @@ int device_chld_remove(struct udevice *dev, struct driver *drv,
assert(dev);
- list_for_each_entry_safe(pos, n, &dev->child_head, sibling_node) { + device_foreach_child_safe(pos, n, dev) { int ret;
if (drv && (pos->driver != drv)) diff --git a/drivers/core/device.c b/drivers/core/device.c index 1b356f12dd..a7bfc47191 100644 --- a/drivers/core/device.c +++ b/drivers/core/device.c @@ -284,8 +284,7 @@ int device_reparent(struct udevice *dev, struct udevice *new_parent) assert(dev); assert(new_parent);
- list_for_each_entry_safe(pos, n, &dev->parent->child_head, - sibling_node) { + device_foreach_child_safe(pos, n, dev->parent) { if (pos->driver != dev->driver) continue;
@@ -729,7 +728,7 @@ int device_get_child(const struct udevice *parent, int index, { struct udevice *dev;
- list_for_each_entry(dev, &parent->child_head, sibling_node) { + device_foreach_child(dev, parent) { if (!index--) return device_get_device_tail(dev, 0, devp); } @@ -742,7 +741,7 @@ int device_get_child_count(const struct udevice *parent) struct udevice *dev; int count = 0;
- list_for_each_entry(dev, &parent->child_head, sibling_node) + device_foreach_child(dev, parent) count++;
return count; @@ -753,7 +752,7 @@ int device_get_decendent_count(const struct udevice *parent) const struct udevice *dev; int count = 1;
- list_for_each_entry(dev, &parent->child_head, sibling_node) + device_foreach_child(dev, parent) count += device_get_decendent_count(dev);
return count; @@ -766,7 +765,7 @@ int device_find_child_by_seq(const struct udevice *parent, int seq,
*devp = NULL;
- list_for_each_entry(dev, &parent->child_head, sibling_node) { + device_foreach_child(dev, parent) { if (dev->seq_ == seq) { *devp = dev; return 0; @@ -795,7 +794,7 @@ int device_find_child_by_of_offset(const struct udevice *parent, int of_offset,
*devp = NULL;
- list_for_each_entry(dev, &parent->child_head, sibling_node) { + device_foreach_child(dev, parent) { if (dev_of_offset(dev) == of_offset) { *devp = dev; return 0; @@ -824,7 +823,7 @@ static struct udevice *_device_find_global_by_ofnode(struct udevice *parent, if (ofnode_equal(dev_ofnode(parent), ofnode)) return parent;
- list_for_each_entry(dev, &parent->child_head, sibling_node) { + device_foreach_child(dev, parent) { found = _device_find_global_by_ofnode(dev, ofnode); if (found) return found; @@ -902,7 +901,7 @@ int device_find_first_inactive_child(const struct udevice *parent, struct udevice *dev;
*devp = NULL; - list_for_each_entry(dev, &parent->child_head, sibling_node) { + device_foreach_child(dev, parent) { if (!device_active(dev) && device_get_uclass_id(dev) == uclass_id) { *devp = dev; @@ -920,7 +919,7 @@ int device_find_first_child_by_uclass(const struct udevice *parent, struct udevice *dev;
*devp = NULL; - list_for_each_entry(dev, &parent->child_head, sibling_node) { + device_foreach_child(dev, parent) { if (device_get_uclass_id(dev) == uclass_id) { *devp = dev; return 0; @@ -937,7 +936,7 @@ int device_find_child_by_namelen(const struct udevice *parent, const char *name,
*devp = NULL;
- list_for_each_entry(dev, &parent->child_head, sibling_node) { + device_foreach_child(dev, parent) { if (!strncmp(dev->name, name, len) && strlen(dev->name) == len) { *devp = dev; diff --git a/drivers/core/devres.c b/drivers/core/devres.c index 313ddc7089..78914bdf7f 100644 --- a/drivers/core/devres.c +++ b/drivers/core/devres.c @@ -232,7 +232,7 @@ static void dump_resources(struct udevice *dev, int depth) (unsigned long)dr->size, dr->name, devres_phase_name[dr->phase]);
- list_for_each_entry(child, &dev->child_head, sibling_node) + device_foreach_child(child, dev) dump_resources(child, depth + 1); }
diff --git a/drivers/core/dump.c b/drivers/core/dump.c index f2f9cacc56..fe97dca954 100644 --- a/drivers/core/dump.c +++ b/drivers/core/dump.c @@ -39,7 +39,7 @@ static void show_devices(struct udevice *dev, int depth, int last_flag)
printf("%s\n", dev->name);
- list_for_each_entry(child, &dev->child_head, sibling_node) { + device_foreach_child(child, dev) { is_last = list_is_last(&child->sibling_node, &dev->child_head); show_devices(child, depth + 1, (last_flag << 1) | is_last); }
Applied to u-boot-dm, thanks!
Sean Anderson
