[U-Boot] [PATCH] arm: dra7xx: Extend bootloader partition
With FIT images support enabled, u-boot.img size increases up to 612 KiB. Extend "bootloader" partition size accordingly.
With extended "bootloader" partition there is no gap between "misc" and "efs" partitions anymore. Keep "efs" partition alignment intact anyway (start=1280K), so that Android partitions addresses are compatible with older versions of u-boot, while size of rest partitions can be adjusted.
Signed-off-by: Sam Protsenko semen.protsenko@linaro.org --- include/configs/dra7xx_evm.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/include/configs/dra7xx_evm.h b/include/configs/dra7xx_evm.h index 79b6c09..92373ac 100644 --- a/include/configs/dra7xx_evm.h +++ b/include/configs/dra7xx_evm.h @@ -56,7 +56,7 @@ "partitions_android=" \ "uuid_disk=${uuid_gpt_disk};" \ "name=xloader,start=128K,size=128K,uuid=${uuid_gpt_xloader};" \ - "name=bootloader,size=384K,uuid=${uuid_gpt_bootloader};" \ + "name=bootloader,size=768K,uuid=${uuid_gpt_bootloader};" \ "name=environment,size=128K,uuid=${uuid_gpt_environment};" \ "name=misc,size=128K,uuid=${uuid_gpt_misc};" \ "name=efs,start=1280K,size=16M,uuid=${uuid_gpt_efs};" \
That's... really huge. Is there something else that can perhaps come out to allow that to fit in? Can you share the rest of the config? I'm not seeing anything close to that by default here. And I bring this up because...
- "name=bootloader,size=768K,uuid=${uuid_gpt_bootloader};" \ "name=environment,size=128K,uuid=${uuid_gpt_environment};" \ "name=misc,size=128K,uuid=${uuid_gpt_misc};" \ "name=efs,start=1280K,size=16M,uuid=${uuid_gpt_efs};" \
Given the problem with compatibility with other systems, I think we need to have xloader-a and xloader-b, or to make the names still be compatible: "uuid_disk=${uuid_gpt_disk};" \ "name=xloader-b,start=128K,size=128K,uuid=${uuid_gpt_xloader};" \ "name=xloader,start=128K,size=128K,uuid=${uuid_gpt_xloader};" \ "name=bootloader,size=512K,uuid=${uuid_gpt_bootloader};" \
So that the first xloader is written to what the ROM considers the 3rd try location. If dra7xx won't actually try from that (I can't easily test right this moment) then we need another misc inbetween xloader @ 128KiB in and u-boot @ 386KiB in so that the U-Boot location is compatible with the non-Android option.
Reviewed-by: Lokesh Vutla lokeshvutla@ti.com
Thanks and regards, Lokesh
Lokesh Vutla
Sam Protsenko
