[U-Boot] [PATCH] config: Define BOOTP client architecture and VCI for ARMv8
Reuse the 32-bit ARM client architecture and identify ARMv8 specifically by setting the BOOTP VCI string.
Cc: Dennis Gilmore dennis@ausil.us Cc: Tom Rini trini@konsulko.com Signed-off-by: Thierry Reding treding@nvidia.com --- include/config_distro_defaults.h | 4 +++- 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/include/config_distro_defaults.h b/include/config_distro_defaults.h index f4a01ba80642..8237239c0021 100644 --- a/include/config_distro_defaults.h +++ b/include/config_distro_defaults.h @@ -20,10 +20,12 @@ #define CONFIG_BOOTP_PXE #define CONFIG_BOOTP_SUBNETMASK
-#if defined(__arm__) +#if defined(__arm__) || defined(__aarch64__) #define CONFIG_BOOTP_PXE_CLIENTARCH 0x100 #if defined(__ARM_ARCH_7__) || defined(__ARM_ARCH_7A__) #define CONFIG_BOOTP_VCI_STRING "U-boot.armv7" +#elif defined(__aarch64__) +#define CONFIG_BOOTP_VCI_STRING "U-boot.armv8" #else #define CONFIG_BOOTP_VCI_STRING "U-boot.arm" #endif
Is there a newer version of https://www.rfc-editor.org/rfc/rfc4578.txt that says what this value should be? Even 32-bit ARM isn't in that document, so I'm not sure where 0x100 came from.
http://www.iana.org/assignments/bootp-dhcp-parameters/bootp-dhcp-parameters.... lists RFC4578 as the document that defines these options, so I guess values have never been allocated for ARM?
I wonder if 0x100 is treated by the PXE implementations as "set but invalid, don't use". Digging into some PXE servers would shed some light here.
I can't actually find any use of this in ISC DHCPd. At most, it might be a value that user config files can match against if they want. I guess it's not worth worrying about?
Yeah, sounds like it to me.
Stephen Warren
Thierry Reding
