[PATCH v2] ARM: amlogic: update JetHub D1/H1 configs (was: add SYS_LOAD_ADDR to JetHub D1/H1 configs)
- late fix for 49c8ef0e45a91ec894ef15e7d043dafe8f1c5efd commit by Tom Rini. - enable i2c, rtc, eeprom
Changes: - add i2c, rtc, eeprom
Signed-off-by: Vyacheslav Bocharov adeep@lexina.in --- configs/jethub_j100_defconfig | 8 ++++++++ configs/jethub_j80_defconfig | 8 ++++++++ 2 files changed, 16 insertions(+)
diff --git a/configs/jethub_j100_defconfig b/configs/jethub_j100_defconfig index 290ce4db85..533f251855 100644 --- a/configs/jethub_j100_defconfig +++ b/configs/jethub_j100_defconfig @@ -11,21 +11,27 @@ CONFIG_DEBUG_UART_BASE=0xff803000 CONFIG_DEBUG_UART_CLOCK=24000000 CONFIG_IDENT_STRING=" jethubj100" CONFIG_DEBUG_UART=y +CONFIG_SYS_LOAD_ADDR=0x01000000 CONFIG_OF_BOARD_SETUP=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_MISC_INIT_R=y # CONFIG_CMD_BDI is not set # CONFIG_CMD_IMI is not set +CONFIG_CMD_EEPROM=y CONFIG_CMD_GPIO=y CONFIG_RANDOM_UUID=y +CONFIG_CMD_I2C=y # CONFIG_CMD_LOADS is not set CONFIG_CMD_MMC=y CONFIG_CMD_USB=y CONFIG_CMD_USB_MASS_STORAGE=y +CONFIG_CMD_RTC=y CONFIG_CMD_REGULATOR=y CONFIG_PARTITION_TYPE_GUID=y CONFIG_OF_CONTROL=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_MESON=y CONFIG_MMC_MESON_GX=y CONFIG_MTD_UBI=y CONFIG_PHY_REALTEK=y @@ -37,6 +43,8 @@ CONFIG_PINCTRL_MESON_AXG=y CONFIG_DM_REGULATOR=y CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_RESET=y +CONFIG_DM_RTC=y +CONFIG_RTC_PCF8563=y CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_DEBUG_UART_SKIP_INIT=y CONFIG_MESON_SERIAL=y diff --git a/configs/jethub_j80_defconfig b/configs/jethub_j80_defconfig index 7db05af3b0..ad6bec0c43 100644 --- a/configs/jethub_j80_defconfig +++ b/configs/jethub_j80_defconfig @@ -12,25 +12,31 @@ CONFIG_DEBUG_UART_BASE=0xc81004c0 CONFIG_DEBUG_UART_CLOCK=24000000 CONFIG_IDENT_STRING=" jethubj80" CONFIG_DEBUG_UART=y +CONFIG_SYS_LOAD_ADDR=0x01000000 CONFIG_OF_BOARD_SETUP=y CONFIG_CONSOLE_MUX=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_MISC_INIT_R=y # CONFIG_CMD_BDI is not set # CONFIG_CMD_IMI is not set +CONFIG_CMD_EEPROM=y CONFIG_CMD_ADC=y CONFIG_CMD_GPIO=y CONFIG_RANDOM_UUID=y +CONFIG_CMD_I2C=y # CONFIG_CMD_LOADS is not set CONFIG_CMD_MMC=y CONFIG_CMD_USB=y CONFIG_CMD_USB_MASS_STORAGE=y +CONFIG_CMD_RTC=y CONFIG_CMD_REGULATOR=y CONFIG_PARTITION_TYPE_GUID=y CONFIG_OF_CONTROL=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SARADC_MESON=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_MESON=y CONFIG_MMC_MESON_GX=y CONFIG_MTD_UBI=y CONFIG_PHY_MESON_GXL=y @@ -45,6 +51,8 @@ CONFIG_PINCTRL_MESON_GXL=y CONFIG_DM_REGULATOR=y CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_RESET=y +CONFIG_DM_RTC=y +CONFIG_RTC_PCF8563=y CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_DEBUG_UART_SKIP_INIT=y CONFIG_MESON_SERIAL=y
thanks, I'll squash it on the previous patch on my u-boot-amlogic-next tree.
Neil
Changes:
Neil Armstrong
Vyacheslav Bocharov
