[U-Boot] [PATCH 1/2] spi: Kconfig: Move FSL_QSPI entry to non-dm place
Since FSL_QSPI driver still supporting non-dm code better to move the Kconfig from DM undefined place.
Cc: Stefano Babic sbabic@denx.de Cc: Peng Fan peng.fan@nxp.com Signed-off-by: Jagan Teki jteki@openedev.com --- drivers/spi/Kconfig | 14 +++++++------- 1 file changed, 7 insertions(+), 7 deletions(-)
diff --git a/drivers/spi/Kconfig b/drivers/spi/Kconfig index aca385d..5da66a6 100644 --- a/drivers/spi/Kconfig +++ b/drivers/spi/Kconfig @@ -61,13 +61,6 @@ config FSL_DSPI this Freescale DSPI IP core. LS102xA and Colibri VF50/VF61 platforms use this driver.
-config FSL_QSPI - bool "Freescale QSPI driver" - help - Enable the Freescale Quad-SPI (QSPI) driver. This driver can be - used to access the SPI NOR flash on platforms embedding this - Freescale IP core. - config ICH_SPI bool "Intel ICH SPI driver" help @@ -188,6 +181,13 @@ config FSL_ESPI access the SPI interface and SPI NOR flash on platforms embedding this Freescale eSPI IP core.
+config FSL_QSPI + bool "Freescale QSPI driver" + help + Enable the Freescale Quad-SPI (QSPI) driver. This driver can be + used to access the SPI NOR flash on platforms embedding this + Freescale IP core. + config TI_QSPI bool "TI QSPI driver" help
Moved FSL_QSPI/SPI/SPI-FLASH configs from include/configs into respective used defconfigs. - CONFIG_FSL_QSPI - CONFIG_SPI_FLASH - CONFIG_SPI_FLASH_BAR - CONFIG_SPI_FLASH_STMICRO
Cc: Stefano Babic sbabic@denx.de Cc: Peng Fan peng.fan@nxp.com Signed-off-by: Jagan Teki jteki@openedev.com --- configs/mx6sxsabreauto_defconfig | 1 + configs/mx6ul_14x14_evk_defconfig | 4 ++++ configs/mx6ul_9x9_evk_defconfig | 4 ++++ include/configs/mx6sxsabreauto.h | 1 - include/configs/mx6ul_14x14_evk.h | 4 ---- 5 files changed, 9 insertions(+), 5 deletions(-)
diff --git a/configs/mx6sxsabreauto_defconfig b/configs/mx6sxsabreauto_defconfig index 41d46f6..e80bb4e 100644 --- a/configs/mx6sxsabreauto_defconfig +++ b/configs/mx6sxsabreauto_defconfig @@ -23,6 +23,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_FSL_QSPI=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/mx6ul_14x14_evk_defconfig b/configs/mx6ul_14x14_evk_defconfig index 9b4c4a4..a829a18 100644 --- a/configs/mx6ul_14x14_evk_defconfig +++ b/configs/mx6ul_14x14_evk_defconfig @@ -32,4 +32,8 @@ CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_FSL_QSPI=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_BAR=y +CONFIG_SPI_FLASH_STMICRO=y CONFIG_OF_LIBFDT=y diff --git a/configs/mx6ul_9x9_evk_defconfig b/configs/mx6ul_9x9_evk_defconfig index e88a1dc..eaf3cfd 100644 --- a/configs/mx6ul_9x9_evk_defconfig +++ b/configs/mx6ul_9x9_evk_defconfig @@ -32,4 +32,8 @@ CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_FSL_QSPI=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_BAR=y +CONFIG_SPI_FLASH_STMICRO=y CONFIG_OF_LIBFDT=y diff --git a/include/configs/mx6sxsabreauto.h b/include/configs/mx6sxsabreauto.h index 274cb36..c30e3dd 100644 --- a/include/configs/mx6sxsabreauto.h +++ b/include/configs/mx6sxsabreauto.h @@ -173,7 +173,6 @@
#define CONFIG_IMX_THERMAL
-#define CONFIG_FSL_QSPI #ifdef CONFIG_FSL_QSPI #define CONFIG_SYS_FSL_QSPI_AHB #define CONFIG_SF_DEFAULT_BUS 0 diff --git a/include/configs/mx6ul_14x14_evk.h b/include/configs/mx6ul_14x14_evk.h index 823405f..925a418 100644 --- a/include/configs/mx6ul_14x14_evk.h +++ b/include/configs/mx6ul_14x14_evk.h @@ -186,15 +186,11 @@ #ifndef CONFIG_SYS_DCACHE_OFF #endif
-#define CONFIG_FSL_QSPI #ifdef CONFIG_FSL_QSPI -#define CONFIG_SPI_FLASH -#define CONFIG_SPI_FLASH_BAR #define CONFIG_SF_DEFAULT_BUS 0 #define CONFIG_SF_DEFAULT_CS 0 #define CONFIG_SF_DEFAULT_SPEED 40000000 #define CONFIG_SF_DEFAULT_MODE SPI_MODE_0 -#define CONFIG_SPI_FLASH_STMICRO #define FSL_QSPI_FLASH_NUM 1 #define FSL_QSPI_FLASH_SIZE SZ_32M #endif
- CONFIG_FSL_QSPI
- CONFIG_SPI_FLASH
Reviewed-by: Peng Fan peng.fan@nxp.com
Thanks, Peng.
#endif
2.7.4
- CONFIG_FSL_QSPI
- CONFIG_SPI_FLASH
Applied to u-boot-spi/master
thanks!
Thanks, Peng.
-config FSL_QSPI
- help
Freescale IP core.
+config FSL_QSPI
- help
Freescale IP core.
config TI_QSPI bool "TI QSPI driver" help -- 2.7.4
thanks!
Jagan Teki
Peng Fan
