[U-Boot] [PATCH] ARM: da850-evm: Fix Lowlevel init
A previous patch for enabling the NAND config set a flag called CONFIG_SKIP_LOWLEVEL_INIT when it should have been called CONFIG_SKIP_LOWLEVEL_INIT_ONLY. The affect this had was creating a delay on startup for the NOR version which is XIP and doesn't have SPL, so the lowlevel initialization functions need to operate. This delay was not really noticeable at first, but the delays have been getting longer, finally reached the point of nearly seven seconds before the board would appear to start.
This patch sets the CONFIG_SKIP_LOWLEVEL_INIT_ONLY instead which means "The normal CP15 init (such as enabling the instruction cache) is still performed" per the README. It doesn't appear to have any adverse behavior on the SPI Flash or the NAND flash boards which use SPL.
Fixes: 93f3362762f0 ("ARM: configs: Add da850evm_nand to boot from NAND")
Signed-off-by: Adam Ford aford173@gmail.com
diff --git a/include/configs/da850evm.h b/include/configs/da850evm.h index ff536131ba..0281dbd7b4 100644 --- a/include/configs/da850evm.h +++ b/include/configs/da850evm.h @@ -26,7 +26,7 @@ #define CONFIG_SYS_OSCIN_FREQ 24000000 #define CONFIG_SYS_TIMERBASE DAVINCI_TIMER0_BASE #define CONFIG_SYS_HZ_CLOCK clk_get(DAVINCI_AUXCLK_CLKID) -#define CONFIG_SKIP_LOWLEVEL_INIT +#define CONFIG_SKIP_LOWLEVEL_INIT_ONLY
#ifdef CONFIG_DIRECT_NOR_BOOT #define CONFIG_ARCH_CPU_INIT
Adam Ford
