[U-Boot] [PATCH] fm: Don't allow disabling of FM1-DTSEC1
The MDIO controller to talk to external PHYs is on FM1-DTSEC1 so don't allow disabling. If we disable it we end up powering the block down in the SoC and thus can't communicate to any external PHYs.
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- drivers/net/fm/p1023.c | 5 +++++ drivers/net/fm/p3060.c | 5 +++++ drivers/net/fm/p4080.c | 5 +++++ drivers/net/fm/p5020.c | 5 +++++ 4 files changed, 20 insertions(+), 0 deletions(-)
diff --git a/drivers/net/fm/p1023.c b/drivers/net/fm/p1023.c index b17dc40..9765da5 100644 --- a/drivers/net/fm/p1023.c +++ b/drivers/net/fm/p1023.c @@ -39,6 +39,11 @@ static int is_device_disabled(enum fm_port port) void fman_disable_port(enum fm_port port) { ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); + + /* don't allow disabling of DTSEC1 as its needed for MDIO */ + if (port == FM1_DTSEC1) + return; + setbits_be32(&gur->devdisr, port_to_devdisr[port]); }
diff --git a/drivers/net/fm/p3060.c b/drivers/net/fm/p3060.c index b25bca7..0b7b765 100644 --- a/drivers/net/fm/p3060.c +++ b/drivers/net/fm/p3060.c @@ -45,6 +45,11 @@ static int is_device_disabled(enum fm_port port) void fman_disable_port(enum fm_port port) { ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); + + /* don't allow disabling of DTSEC1 as its needed for MDIO */ + if (port == FM1_DTSEC1) + return; + setbits_be32(&gur->devdisr2, port_to_devdisr[port]); }
diff --git a/drivers/net/fm/p4080.c b/drivers/net/fm/p4080.c index 791caab..9dc6049 100644 --- a/drivers/net/fm/p4080.c +++ b/drivers/net/fm/p4080.c @@ -47,6 +47,11 @@ static int is_device_disabled(enum fm_port port) void fman_disable_port(enum fm_port port) { ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); + + /* don't allow disabling of DTSEC1 as its needed for MDIO */ + if (port == FM1_DTSEC1) + return; + setbits_be32(&gur->devdisr2, port_to_devdisr[port]); }
diff --git a/drivers/net/fm/p5020.c b/drivers/net/fm/p5020.c index 69c27d2..a7a6e43 100644 --- a/drivers/net/fm/p5020.c +++ b/drivers/net/fm/p5020.c @@ -43,6 +43,11 @@ static int is_device_disabled(enum fm_port port) void fman_disable_port(enum fm_port port) { ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); + + /* don't allow disabling of DTSEC1 as its needed for MDIO */ + if (port == FM1_DTSEC1) + return; + setbits_be32(&gur->devdisr2, port_to_devdisr[port]); }
applied to 85xx
- k
Kumar Gala
