[U-Boot] Pull request: u-boot-sunxi/master
Hi Tom,
Please pull this PR.
thanks, Jagan.
The following changes since commit 5e9a9645816edcc68c09729f257e0c863292bf26:
mach-stm32: Rename CONFIG_SPL_RESET_SUPPORT to CONFIG_SPL_DM_RESET (2018-07-13 14:47:29 -0400)
git://git.denx.de/u-boot-sunxi.git master
for you to fetch changes up to 32f67bb7a15cec4afa117bd168265ece2107b0d6:
sunxi: Enable eMMC on Libre Computer Board ALL-H3-CC boards (2018-07-17 21:07:34 +0530)
---------------------------------------------------------------- Adam Sampson (2): dm: mmc: sunxi: Add A10/A20 compatible strings dm: sunxi: Use DM for MMC and SATA on all A10 boards
Andre Przywara (6): sunxi: DT: A64: update device tree file for Allwinner A64 SoC sunxi: DT: A64: update board .dts files from Linux sunxi: DT: update device tree files for Allwinner H3 and H5 SoCs sunxi: DT: H5: update board .dts files from Linux sunxi: DT: H3: update board .dts files from Linux sunxi: DT: A64: add proper SoPine baseboard device tree
Chen-Yu Tsai (1): sunxi: Enable eMMC on Libre Computer Board ALL-H3-CC boards
Lothar Felten (6): sunxi: R40: add gigabit ethernet clocks net: sun8i-emac: fix printing NULL character net: sun8i-emac: set mux and clock by driver data net: sun8i-emac: support R40 GMAC sunxi: R40: add gigabit ethernet devicetree node configs: Bananapi_M2_Ultra: enable gigabit ethernet
arch/arm/dts/Makefile | 3 +- arch/arm/dts/axp803.dtsi | 155 +++++ arch/arm/dts/sun50i-a64-bananapi-m64.dts | 195 +++++- arch/arm/dts/sun50i-a64-nanopi-a64.dts | 111 ++- arch/arm/dts/sun50i-a64-olinuxino.dts | 153 ++++- arch/arm/dts/sun50i-a64-orangepi-win.dts | 135 +++- arch/arm/dts/sun50i-a64-pine64-plus-u-boot.dtsi | 59 -- arch/arm/dts/sun50i-a64-pine64-plus.dts | 17 +- arch/arm/dts/sun50i-a64-pine64.dts | 186 ++++- arch/arm/dts/sun50i-a64-sopine-baseboard.dts | 150 +++++ arch/arm/dts/sun50i-a64-sopine.dtsi | 142 ++++ arch/arm/dts/sun50i-a64.dtsi | 305 ++++++++- arch/arm/dts/sun50i-h5-libretech-all-h3-cc.dts | 5 +- arch/arm/dts/sun50i-h5-nanopi-neo-plus2.dts | 122 +++- arch/arm/dts/sun50i-h5-nanopi-neo2.dts | 91 ++- arch/arm/dts/sun50i-h5-orangepi-pc2.dts | 151 ++++- arch/arm/dts/sun50i-h5-orangepi-prime.dts | 176 ++++- arch/arm/dts/sun50i-h5-orangepi-zero-plus2.dts | 64 +- arch/arm/dts/sun50i-h5.dtsi | 38 +- arch/arm/dts/sun8i-h2-plus-orangepi-zero.dts | 55 +- arch/arm/dts/sun8i-h3-bananapi-m2-plus.dts | 96 ++- arch/arm/dts/sun8i-h3-libretech-all-h3-cc.dts | 3 +- arch/arm/dts/sun8i-h3-nanopi-m1-plus.dts | 78 +++ arch/arm/dts/sun8i-h3-nanopi-m1.dts | 42 ++ arch/arm/dts/sun8i-h3-nanopi-neo-air.dts | 28 +- arch/arm/dts/sun8i-h3-nanopi-neo.dts | 17 + arch/arm/dts/sun8i-h3-nanopi.dtsi | 13 +- arch/arm/dts/sun8i-h3-orangepi-2.dts | 92 ++- arch/arm/dts/sun8i-h3-orangepi-lite.dts | 57 +- arch/arm/dts/sun8i-h3-orangepi-one.dts | 116 +++- arch/arm/dts/sun8i-h3-orangepi-pc-plus.dts | 11 +- arch/arm/dts/sun8i-h3-orangepi-pc.dts | 141 +++- arch/arm/dts/sun8i-h3-orangepi-plus.dts | 29 +- arch/arm/dts/sun8i-h3-orangepi-plus2e.dts | 15 +- arch/arm/dts/sun8i-h3.dtsi | 602 +++-------------- arch/arm/dts/sun8i-r40-bananapi-m2-ultra.dts | 16 + arch/arm/dts/sun8i-r40.dtsi | 34 + arch/arm/dts/sunxi-h3-h5.dtsi | 860 ++++++++++++++++++++++++ arch/arm/dts/sunxi-libretech-all-h3-cc.dtsi | 11 +- arch/arm/include/asm/arch-sunxi/clock_sun6i.h | 10 +- arch/arm/mach-sunxi/Kconfig | 2 + configs/Bananapi_M2_Ultra_defconfig | 4 + configs/libretech_all_h3_cc_h2_plus_defconfig | 1 + configs/libretech_all_h3_cc_h3_defconfig | 1 + configs/libretech_all_h3_cc_h5_defconfig | 1 + configs/sopine_baseboard_defconfig | 2 +- drivers/mmc/sunxi_mmc.c | 2 + drivers/net/sun8i_emac.c | 115 ++-- include/dt-bindings/clock/sun8i-de2.h | 18 + include/dt-bindings/clock/sun8i-r-ccu.h | 59 ++ include/dt-bindings/reset/sun8i-de2.h | 14 + include/dt-bindings/reset/sun8i-r-ccu.h | 53 ++ 52 files changed, 3893 insertions(+), 963 deletions(-) create mode 100644 arch/arm/dts/axp803.dtsi delete mode 100644 arch/arm/dts/sun50i-a64-pine64-plus-u-boot.dtsi create mode 100644 arch/arm/dts/sun50i-a64-sopine-baseboard.dts create mode 100644 arch/arm/dts/sun50i-a64-sopine.dtsi create mode 100644 arch/arm/dts/sunxi-h3-h5.dtsi create mode 100644 include/dt-bindings/clock/sun8i-de2.h create mode 100644 include/dt-bindings/clock/sun8i-r-ccu.h create mode 100644 include/dt-bindings/reset/sun8i-de2.h create mode 100644 include/dt-bindings/reset/sun8i-r-ccu.h
On Tue, Jul 17, 2018 at 09:15:22PM +0530, Jagan Teki wrote:
Hi Tom,
thanks, Jagan.
Jagan Teki
