[U-Boot] Falcon boot breaks on DRA7 because of commit b9c8ccab "env_mmc.c: Allow environment to be used within SPL"
Hi Tom,
I'm using a TI DRA7 platform and the falcon boot from MMC is broken with v2017. The reason is that the standard "boot_os" is used to tell whether the falcon mode should be used or not, but we can't access it. The root cause is that the environment is stored in a eMMC which is dev 1 not dev 0 on those platforms.
What is the purpose of commit b9c8ccab. Is it because we want to initialize only one MMC device in the SPL to reduce the boot time ?
Jean-Jacques
On Tue, Jan 24, 2017 at 10:26:38AM +0100, Jean-Jacques Hiblot wrote:
Hi Tom,
Please note that b9c8ccaba77b has been in since April 2014, so this is not some new behavior. That said, we have CONFIG_SYS_MMC_ENV_DEV set which is what the commit in question uses to know where the env is. I think you need to run a git bisect between v2016.11 (which I assume is when you last tested this) and v2017.01 to see what commit changed things. It's possible something has changed and broken this case requiring another tweak somewhere or another, thanks!
Hi Tom,
I had noticed that it's quite old indeed. I didn't mean that it's a regression. I'm just puzzled by the commit. what is its purpose ? why is SPL not using CONFIG_SYS_MMC_ENV_DEV ? I can trace this as the reason why I can't access the environment in eMMC (MMC2) when booting from SD (MMC1) and the fix is simply use dev = CONFIG_SYS_MMC_ENV_DEV instead of dev = 0. But I guess that there is a reason for enforcing dev = 0. If the reason is still valid, I'll have to find another way of dealing with this. Otherwise we could revert to dev = CONFIG_SYS_MMC_ENV_DEV or define a CONFIG_SYS_MMC_ENV_SPL_EV with a default value of 0.
Honestly I don't know when it broke. I still have to figure this. It may be that the test case I'm using hasn't work in a long time. From what I understand falcon boot on DRA7 is primarily used from QSPI or eMMC in raw mode. And those modes are not impacted by this problem with the environment.
Hi Tom,
Because in SPL we do not have both MMC devices initialized. We register the one we booted from and thus it is device 0 to U-Boot in this case. I suspect the rest of the issues stem from this quirk, or something having broken around this quirk. Thanks!
That is not always the case. Actually in spl_mmc.c the code requires us to register more than one MMC device to work properly when multiple MMC boot devices can be used (see spl_mmc_get_device_index()) I did the test of registering only MMC2 when booting from eMMC, the SPL fails because it can't find device 1: Trying to boot from MMC2_2 MMC Device 1 not found spl: could not find mmc device. error: -19
Right. So I suspect the problem is that some level of the env_mmc.c code needs to be adapted again for the change in how SPL now works with the possibility of multiple devices. It's possible that the change you found is the right fix, please investigate a bit more and confirm things before submitting a proper patch, thanks!
I did more tests and it turns out that there I find no real benefit of registering only the controller for the boot device. The initialization of the MMC/SD/eMMC is done only prior accessing it, not when it's registered. So in terms of boot time the impact of registering many controllers is not significant. By registering the same controllers in SPL and in u-boot, we would get the same mapping for the MMC devices in SPL and u-boot. It would remove a source of confusion and of #ifdef CONFIG_SPL_BUILD
The catch is that many boards register only one MMC controller in the SPL, depending on what the boot source is (ex: board_mmc_init() in board/freescale/mx6slevk/mx6slevk.c) To reduce the risk of regression, we could deal with those boards in 2 steps: 1) Don't change the code of the board except to override the weak function mmc_get_env_dev() and make it return 0. This is not likely to introduce a regression 2) One by one, change the code of the boards to register all the controllers in SPL as done in u-boot. Also we need to adapt spl_boot_device() to return the right boot device. There has been a partial attempt at this ""ARM: mx6: add MMC2 boot device detection support in SPL" but had to be reverted probably because it was not coherent with the registration of the controllers.
- Don't change the code of the board except to override the weak
Due to the issue you mention in #2, we probably need to do #1 and with care and testing, as there's enough places that assume SPL is a single MMC device that it'll be problematic to do them one at a time.
I made a survey of the code in 2017.01 to identify the platforms that may be impacted by the change in env_mmc.c
Here is the method: 1) * find the platforms that override mmc_get_env_dev(). Those may not rely on CONFIG_SYS_MMC_ENV_DEV to get the MMC device where the env is stored. * find the platforms that define CONFIG_SYS_MMC_ENV_DEV as not 0 2) Find the paltforms that use CONFIG_SPL_ENV_SUPPORT 3) Cross the info from 1 and 2 to get the platforms that may be impacted by the change
1) Platforms that my use a device that is not dev 0 for en storage:
$ git grep -w mmc_get_env_dev arch/arm/cpu/armv7/mx6/soc.c:int mmc_get_env_dev(void) arch/arm/cpu/armv7/mx7/soc.c:int mmc_get_env_dev(void) arch/arm/mach-uniphier/boot-mode/boot-mode.c:int mmc_get_env_dev(void) board/freescale/mx7dsabresd/mx7dsabresd.c: u32 dev_no = mmc_get_env_dev(); common/env_mmc.c:__weak int mmc_get_env_dev(void) common/env_mmc.c: int dev = mmc_get_env_dev(); common/env_mmc.c: int dev = mmc_get_env_dev(); common/env_mmc.c: int dev = mmc_get_env_dev(); common/env_mmc.c: int dev = mmc_get_env_dev(); common/env_mmc.c: int dev = mmc_get_env_dev(); include/mmc.h:int mmc_get_env_dev(void);
$ git grep -e 'ne\sCONFIG_SYS_MMC_ENV_DEV\s*[1-9a-zA-Z()]' include/ include/configs/am335x_evm.h:#define CONFIG_SYS_MMC_ENV_DEV 1 include/configs/am335x_shc.h:#define CONFIG_SYS_MMC_ENV_DEV 1 include/configs/am335x_sl50.h:#define CONFIG_SYS_MMC_ENV_DEV 1 include/configs/bav335x.h:#define CONFIG_SYS_MMC_ENV_DEV 1 include/configs/cm_t54.h:#define CONFIG_SYS_MMC_ENV_DEV 1 /* SLOT2: eMMC(1) */ include/configs/dra7xx_evm.h:#define CONFIG_SYS_MMC_ENV_DEV 1 /* SLOT2: eMMC(1) */ include/configs/el6x_common.h:#define CONFIG_SYS_MMC_ENV_DEV 1 include/configs/embestmx6boards.h:#define CONFIG_SYS_MMC_ENV_DEV 2 /* SDHC4 */ include/configs/evb_rk3288.h:#define CONFIG_SYS_MMC_ENV_DEV 1 include/configs/evb_rk3399.h:#define CONFIG_SYS_MMC_ENV_DEV 1 include/configs/fennec_rk3288.h:#define CONFIG_SYS_MMC_ENV_DEV 1 include/configs/mx6qarm2.h:#define CONFIG_SYS_MMC_ENV_DEV 1 include/configs/mx6sabresd.h:#define CONFIG_SYS_MMC_ENV_DEV 1 /* SDHC3 */ include/configs/mx6slevk.h:#define CONFIG_SYS_MMC_ENV_DEV 1 /* SDHC2*/ include/configs/mx6sxsabresd.h:#define CONFIG_SYS_MMC_ENV_DEV 2 /*USDHC4*/ include/configs/mx6ul_14x14_evk.h:#define CONFIG_SYS_MMC_ENV_DEV 1 /* USDHC2 */ include/configs/mx6ullevk.h:#define CONFIG_SYS_MMC_ENV_DEV 1 /* USDHC2 */ include/configs/odroid.h:#define CONFIG_SYS_MMC_ENV_DEV CONFIG_MMC_DEFAULT_DEV include/configs/omap4_sdp4430.h:#define CONFIG_SYS_MMC_ENV_DEV 1 /* SLOT2: eMMC(1) */ include/configs/omap5_uevm.h:#define CONFIG_SYS_MMC_ENV_DEV 1 /* SLOT2: eMMC(1) */ include/configs/popmetal_rk3288.h:#define CONFIG_SYS_MMC_ENV_DEV 1 include/configs/s5p_goni.h:#define CONFIG_SYS_MMC_ENV_DEV CONFIG_MMC_DEFAULT_DEV include/configs/s5pc210_universal.h:#define CONFIG_SYS_MMC_ENV_DEV CONFIG_MMC_DEFAULT_DEV include/configs/tbs2910.h:#define CONFIG_SYS_MMC_ENV_DEV 2 /* overwritten on SD boot */ include/configs/trats.h:#define CONFIG_SYS_MMC_ENV_DEV CONFIG_MMC_DEFAULT_DEV include/configs/trats2.h:#define CONFIG_SYS_MMC_ENV_DEV CONFIG_MMC_DEFAULT_DEV
They can be sorted as such: * exynos based: use CONFIG_MMC_DEFAULT_DEV wich is 0. * uniphier : the code in u-boot locates the first MMC (not SD) and use it for the env. But this mechanism is not used in the SPL case => it probably doesn't work with SPL_ENV_SUPPORT. * TI based: The code used to register the controllers is the same for all and all suffer from the problem I described. They will benefit from removing "dev = 0" * Rockchip based : It looks like those platforms use DT to register the controllers. So I expect that they too would benefit from removing "dev = 0" * iMX6/IMX7 based : This is a more complex situation: - imx6/imx7 common code provide relies on board_mmc_get_env_dev() to get the dev where the env is stored if booting from SD/MMC. When implemented this function is usually returns the boot device.The default (weak) implementation returns CONFIG_SYS_MMC_ENV_DEV. - platforms register several MMC controllers in u-boot and usually only one in SPL though there are exceptions (embestmx6boards, mx6qarm2, tbs2910, imx7sabre, etc.). - Removing "dev = 0" in env_mmc.c, would break SPL_ENV_SUPPORT for most of the mx6 based boards
2) platform that use SPL env in their default config
$ git grep -e "CONFIG_SPL_ENV_SUPPORT=y" configs/B4420QDS_NAND_defconfig:CONFIG_SPL_ENV_SUPPORT=y configs/B4860QDS_NAND_defconfig:CONFIG_SPL_ENV_SUPPORT=y configs/P1010RDB-PA_36BIT_SDCARD_defconfig:CONFIG_SPL_ENV_SUPPORT=y configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig:CONFIG_SPL_ENV_SUPPORT=y configs/P1010RDB-PA_SDCARD_defconfig:CONFIG_SPL_ENV_SUPPORT=y configs/P1010RDB-PA_SPIFLASH_defconfig:CONFIG_SPL_ENV_SUPPORT=y configs/P1010RDB-PB_36BIT_SDCARD_defconfig:CONFIG_SPL_ENV_SUPPORT=y configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig:CONFIG_SPL_ENV_SUPPORT=y configs/P1010RDB-PB_SDCARD_defconfig:CONFIG_SPL_ENV_SUPPORT=y configs/P1010RDB-PB_SPIFLASH_defconfig:CONFIG_SPL_ENV_SUPPORT=y configs/P1020MBG-PC_36BIT_SDCARD_defconfig:CONFIG_SPL_ENV_SUPPORT=y configs/P1020MBG-PC_SDCARD_defconfig:CONFIG_SPL_ENV_SUPPORT=y configs/P1020RDB-PC_36BIT_SDCARD_defconfig:CONFIG_SPL_ENV_SUPPORT=y configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig:CONFIG_SPL_ENV_SUPPORT=y configs/P1020RDB-PC_SDCARD_defconfig:CONFIG_SPL_ENV_SUPPORT=y configs/P1020RDB-PC_SPIFLASH_defconfig:CONFIG_SPL_ENV_SUPPORT=y configs/P1020RDB-PD_SDCARD_defconfig:CONFIG_SPL_ENV_SUPPORT=y configs/P1020RDB-PD_SPIFLASH_defconfig:CONFIG_SPL_ENV_SUPPORT=y configs/P1020UTM-PC_36BIT_SDCARD_defconfig:CONFIG_SPL_ENV_SUPPORT=y configs/P1020UTM-PC_SDCARD_defconfig:CONFIG_SPL_ENV_SUPPORT=y configs/P1021RDB-PC_36BIT_SDCARD_defconfig:CONFIG_SPL_ENV_SUPPORT=y configs/P1021RDB-PC_36BIT_SPIFLASH_defconfig:CONFIG_SPL_ENV_SUPPORT=y configs/P1021RDB-PC_SDCARD_defconfig:CONFIG_SPL_ENV_SUPPORT=y configs/P1021RDB-PC_SPIFLASH_defconfig:CONFIG_SPL_ENV_SUPPORT=y configs/P1022DS_36BIT_SDCARD_defconfig:CONFIG_SPL_ENV_SUPPORT=y configs/P1022DS_36BIT_SPIFLASH_defconfig:CONFIG_SPL_ENV_SUPPORT=y configs/P1022DS_SDCARD_defconfig:CONFIG_SPL_ENV_SUPPORT=y configs/P1022DS_SPIFLASH_defconfig:CONFIG_SPL_ENV_SUPPORT=y configs/P1024RDB_SDCARD_defconfig:CONFIG_SPL_ENV_SUPPORT=y configs/P1024RDB_SPIFLASH_defconfig:CONFIG_SPL_ENV_SUPPORT=y configs/P1025RDB_SDCARD_defconfig:CONFIG_SPL_ENV_SUPPORT=y configs/P1025RDB_SPIFLASH_defconfig:CONFIG_SPL_ENV_SUPPORT=y configs/P2020RDB-PC_36BIT_SDCARD_defconfig:CONFIG_SPL_ENV_SUPPORT=y configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig:CONFIG_SPL_ENV_SUPPORT=y configs/P2020RDB-PC_SDCARD_defconfig:CONFIG_SPL_ENV_SUPPORT=y configs/P2020RDB-PC_SPIFLASH_defconfig:CONFIG_SPL_ENV_SUPPORT=y configs/T1023RDB_NAND_defconfig:CONFIG_SPL_ENV_SUPPORT=y configs/T1023RDB_SDCARD_defconfig:CONFIG_SPL_ENV_SUPPORT=y configs/T1023RDB_SPIFLASH_defconfig:CONFIG_SPL_ENV_SUPPORT=y configs/T1024QDS_NAND_defconfig:CONFIG_SPL_ENV_SUPPORT=y configs/T1024QDS_SDCARD_defconfig:CONFIG_SPL_ENV_SUPPORT=y configs/T1024QDS_SPIFLASH_defconfig:CONFIG_SPL_ENV_SUPPORT=y configs/T1024RDB_NAND_defconfig:CONFIG_SPL_ENV_SUPPORT=y configs/T1024RDB_SDCARD_defconfig:CONFIG_SPL_ENV_SUPPORT=y configs/T1024RDB_SPIFLASH_defconfig:CONFIG_SPL_ENV_SUPPORT=y configs/T1040D4RDB_NAND_defconfig:CONFIG_SPL_ENV_SUPPORT=y configs/T1040D4RDB_SDCARD_defconfig:CONFIG_SPL_ENV_SUPPORT=y configs/T1040D4RDB_SPIFLASH_defconfig:CONFIG_SPL_ENV_SUPPORT=y configs/T1040RDB_NAND_defconfig:CONFIG_SPL_ENV_SUPPORT=y configs/T1040RDB_SDCARD_defconfig:CONFIG_SPL_ENV_SUPPORT=y configs/T1040RDB_SPIFLASH_defconfig:CONFIG_SPL_ENV_SUPPORT=y configs/T1042D4RDB_NAND_defconfig:CONFIG_SPL_ENV_SUPPORT=y configs/T1042D4RDB_SDCARD_defconfig:CONFIG_SPL_ENV_SUPPORT=y configs/T1042D4RDB_SPIFLASH_defconfig:CONFIG_SPL_ENV_SUPPORT=y configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig:CONFIG_SPL_ENV_SUPPORT=y configs/T1042RDB_PI_NAND_defconfig:CONFIG_SPL_ENV_SUPPORT=y configs/T1042RDB_PI_SDCARD_defconfig:CONFIG_SPL_ENV_SUPPORT=y configs/T1042RDB_PI_SPIFLASH_defconfig:CONFIG_SPL_ENV_SUPPORT=y configs/T2080QDS_NAND_defconfig:CONFIG_SPL_ENV_SUPPORT=y configs/T2080QDS_SDCARD_defconfig:CONFIG_SPL_ENV_SUPPORT=y configs/T2080QDS_SPIFLASH_defconfig:CONFIG_SPL_ENV_SUPPORT=y configs/T2080RDB_NAND_defconfig:CONFIG_SPL_ENV_SUPPORT=y configs/T2080RDB_SDCARD_defconfig:CONFIG_SPL_ENV_SUPPORT=y configs/T2080RDB_SPIFLASH_defconfig:CONFIG_SPL_ENV_SUPPORT=y configs/T2081QDS_NAND_defconfig:CONFIG_SPL_ENV_SUPPORT=y configs/T2081QDS_SDCARD_defconfig:CONFIG_SPL_ENV_SUPPORT=y configs/T2081QDS_SPIFLASH_defconfig:CONFIG_SPL_ENV_SUPPORT=y configs/T4160QDS_NAND_defconfig:CONFIG_SPL_ENV_SUPPORT=y configs/T4160QDS_SDCARD_defconfig:CONFIG_SPL_ENV_SUPPORT=y configs/T4240QDS_NAND_defconfig:CONFIG_SPL_ENV_SUPPORT=y configs/T4240QDS_SDCARD_defconfig:CONFIG_SPL_ENV_SUPPORT=y configs/T4240RDB_SDCARD_defconfig:CONFIG_SPL_ENV_SUPPORT=y configs/a3m071_defconfig:CONFIG_SPL_ENV_SUPPORT=y configs/a4m2k_defconfig:CONFIG_SPL_ENV_SUPPORT=y configs/am335x_shc_netboot_defconfig:CONFIG_SPL_ENV_SUPPORT=y configs/am335x_sl50_defconfig:CONFIG_SPL_ENV_SUPPORT=y configs/ls1021aqds_nand_defconfig:CONFIG_SPL_ENV_SUPPORT=y configs/ls1021aqds_sdcard_ifc_defconfig:CONFIG_SPL_ENV_SUPPORT=y configs/ls1021aqds_sdcard_qspi_defconfig:CONFIG_SPL_ENV_SUPPORT=y configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig:CONFIG_SPL_ENV_SUPPORT=y configs/ls1021atwr_sdcard_ifc_defconfig:CONFIG_SPL_ENV_SUPPORT=y configs/ls1021atwr_sdcard_qspi_defconfig:CONFIG_SPL_ENV_SUPPORT=y configs/ls1043aqds_nand_defconfig:CONFIG_SPL_ENV_SUPPORT=y configs/ls1043aqds_sdcard_ifc_defconfig:CONFIG_SPL_ENV_SUPPORT=y configs/ls1043aqds_sdcard_qspi_defconfig:CONFIG_SPL_ENV_SUPPORT=y configs/ls1043ardb_nand_defconfig:CONFIG_SPL_ENV_SUPPORT=y configs/ls1043ardb_sdcard_defconfig:CONFIG_SPL_ENV_SUPPORT=y configs/ls2080aqds_nand_defconfig:CONFIG_SPL_ENV_SUPPORT=y configs/ls2080ardb_nand_defconfig:CONFIG_SPL_ENV_SUPPORT=y configs/pcm051_rev1_defconfig:CONFIG_SPL_ENV_SUPPORT=y configs/pcm051_rev3_defconfig:CONFIG_SPL_ENV_SUPPORT=y configs/pengwyn_defconfig:CONFIG_SPL_ENV_SUPPORT=y configs/sandbox_spl_defconfig:CONFIG_SPL_ENV_SUPPORT=y configs/udoo_neo_defconfig:CONFIG_SPL_ENV_SUPPORT=y
$ git grep -e "define\sCONFIG_SPL_ENV_SUPPORT" include/configs/ls1021aiot.h:#define CONFIG_SPL_ENV_SUPPORT include/configs/ls1046a_common.h:#define CONFIG_SPL_ENV_SUPPORT include/configs/ls1046a_common.h:#define CONFIG_SPL_ENV_SUPPORT include/configs/xilinx_zynqmp.h:# define CONFIG_SPL_ENV_SUPPORT
$ git grep -A2 "SPL_ENV_SUPPORT" | grep -e 'default\sy' board/ti/am335x/Kconfig- default y board/ti/common/Kconfig- default y
3) Cross info. - udoo_neo is the only iMX6 based platform that uses SPL_ENV. But as it register only one SDHC port, there will be no problem. All other iMX6/7 based platforms don't use SPL_ENV_SUPPORT in their default configuration. - all TI platforms are impacted
=> IMO it's safe to make the remove all the 'dev = 0;' from env_mmc and rely on mmc_get_env_dev().
>I had noticed that it's quite old indeed. I didn't mean that it's a >regression. I'm just puzzled by the commit. what is its purpose ? >why is SPL not using CONFIG_SYS_MMC_ENV_DEV ? Because in SPL we do not have both MMC devices initialized.
Here is the method:
- find the platforms that override mmc_get_env_dev(). Those may
- Platforms that my use a device that is not dev 0 for en storage:
- exynos based: use CONFIG_MMC_DEFAULT_DEV wich is 0.
- uniphier : the code in u-boot locates the first MMC (not SD) and
- TI based: The code used to register the controllers is the same
- Rockchip based : It looks like those platforms use DT to register
- iMX6/IMX7 based : This is a more complex situation:
- platform that use SPL env in their default config
- Cross info.
OK, please make a patch, test it on as much of the TI hardware as you can (including BBB), and lets move from there, thanks!
Jean-Jacques Hiblot
