[U-Boot] [PATCH 1/2] board: freescale: ls1012afrx:Common files to support
LS1012A-FRDM and LS1012A-FRWY board.
1-Move all common files applicable for both boards LS1012A-FRDM and LS1012A-FRWY into board directory ls1012afrx. 2-Restructure LS1012A-FRDM code. Only board specific files are in LS1012A-FRDM board directory.
Signed-off-by: Pramod Kumar pramod.kumar_1@nxp.com --- arch/arm/Kconfig | 2 + board/freescale/ls1012afrdm/Kconfig | 60 ---------------------- board/freescale/ls1012afrdm/MAINTAINERS | 12 +---- board/freescale/ls1012afrdm/Makefile | 4 +- board/freescale/ls1012afrx/Kconfig | 27 ++++++++++ board/freescale/{ls1012afrdm => ls1012afrx}/eth.c | 0 .../ls1012afrdm.c => ls1012afrx/ls1012afrx.c} | 0 7 files changed, 32 insertions(+), 73 deletions(-) create mode 100644 board/freescale/ls1012afrx/Kconfig rename board/freescale/{ls1012afrdm => ls1012afrx}/eth.c (100%) rename board/freescale/{ls1012afrdm/ls1012afrdm.c => ls1012afrx/ls1012afrx.c} (100%)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 350653b..c7493e4 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -1320,6 +1320,8 @@ source "board/freescale/ls1046ardb/Kconfig" source "board/freescale/ls1012aqds/Kconfig" source "board/freescale/ls1012ardb/Kconfig" source "board/freescale/ls1012afrdm/Kconfig" +source "board/freescale/ls1012afrx/Kconfig" +source "board/freescale/ls1012afrwy/Kconfig" source "board/freescale/mx31ads/Kconfig" source "board/freescale/mx31pdk/Kconfig" source "board/freescale/mx35pdk/Kconfig" diff --git a/board/freescale/ls1012afrdm/Kconfig b/board/freescale/ls1012afrdm/Kconfig index f52a896..58e592d 100644 --- a/board/freescale/ls1012afrdm/Kconfig +++ b/board/freescale/ls1012afrdm/Kconfig @@ -21,63 +21,3 @@ config SYS_LS_PPA_FW_ADDR default 0x40400000
endif - -if FSL_PFE - -config BOARD_SPECIFIC_OPTIONS # dummy - def_bool y - select PHYLIB - imply PHY_REALTEK - imply PHY_ATHEROS - -config DDR_PFE_PHYS_BASEADDR - hex "PFE DDR physical base address" - default 0x03800000 - -config DDR_PFE_BASEADDR - hex "PFE DDR base address" - default 0x83800000 - -config PFE_EMAC1_PHY_ADDR - hex "PFE DDR base address" - default 0x2 - -config PFE_EMAC2_PHY_ADDR - hex "PFE DDR base address" - default 0x1 - -endif - -if TARGET_LS1012AFRWY - -config SYS_BOARD - default "ls1012afrdm" - -config SYS_VENDOR - default "freescale" - -config SYS_SOC - default "fsl-layerscape" - -config SYS_CONFIG_NAME - default "ls1012afrwy" - -config SYS_LS_PFE_FW_ADDR - hex "Flash address of PFE firmware" - default 0x40020000 - -config SYS_LS_PPA_FW_ADDR - hex "PPA Firmware Addr" - default 0x40060000 - -config SYS_LS_PPA_ESBC_ADDR - hex "PPA Firmware HDR Addr" - default 0x401f4000 - -config SYS_LS_PFE_ESBC_ADDR - hex "PFE Firmware HDR Addr" - default 0x401f8000 - -endif - -source "board/freescale/common/Kconfig" diff --git a/board/freescale/ls1012afrdm/MAINTAINERS b/board/freescale/ls1012afrdm/MAINTAINERS index f3fcdb8..b618d78 100644 --- a/board/freescale/ls1012afrdm/MAINTAINERS +++ b/board/freescale/ls1012afrdm/MAINTAINERS @@ -1,17 +1,7 @@ LS1012AFRDM BOARD M: Prabhakar Kushwaha prabhakar.kushwaha@nxp.com S: Maintained +F: board/freescale/ls1012afrx/ F: board/freescale/ls1012afrdm/ F: include/configs/ls1012afrdm.h F: configs/ls1012afrdm_qspi_defconfig - -LS1012AFRWY BOARD -M: Bhaskar Upadhaya bhaskar.upadhaya@nxp.com -S: Maintained -F: board/freescale/ls1012afrwy/ -F: include/configs/ls1012afrwy.h -F: configs/ls1012afrwy_qspi_defconfig - -M: Vinitha V Pillai vinitha.pillai@nxp.com -S: Maintained -F: configs/ls1012afrwy_qspi_SECURE_BOOT_defconfig diff --git a/board/freescale/ls1012afrdm/Makefile b/board/freescale/ls1012afrdm/Makefile index 1e53c96..a318506 100644 --- a/board/freescale/ls1012afrdm/Makefile +++ b/board/freescale/ls1012afrdm/Makefile @@ -4,5 +4,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-obj-y += ls1012afrdm.o -obj-$(CONFIG_FSL_PFE) += eth.o +obj-y += ../ls1012afrx/ls1012afrx.o +obj-$(CONFIG_FSL_PFE) += ../ls1012afrx/eth.o diff --git a/board/freescale/ls1012afrx/Kconfig b/board/freescale/ls1012afrx/Kconfig new file mode 100644 index 0000000..a2884e5 --- /dev/null +++ b/board/freescale/ls1012afrx/Kconfig @@ -0,0 +1,27 @@ +if FSL_PFE + +config BOARD_SPECIFIC_OPTIONS # dummy + def_bool y + select PHYLIB + imply PHY_REALTEK + imply PHY_ATHEROS + +config DDR_PFE_PHYS_BASEADDR + hex "PFE DDR physical base address" + default 0x03800000 + +config DDR_PFE_BASEADDR + hex "PFE DDR base address" + default 0x83800000 + +config PFE_EMAC1_PHY_ADDR + hex "PFE DDR base address" + default 0x2 + +config PFE_EMAC2_PHY_ADDR + hex "PFE DDR base address" + default 0x1 + +endif + +source "board/freescale/common/Kconfig" diff --git a/board/freescale/ls1012afrdm/eth.c b/board/freescale/ls1012afrx/eth.c similarity index 100% rename from board/freescale/ls1012afrdm/eth.c rename to board/freescale/ls1012afrx/eth.c diff --git a/board/freescale/ls1012afrdm/ls1012afrdm.c b/board/freescale/ls1012afrx/ls1012afrx.c similarity index 100% rename from board/freescale/ls1012afrdm/ls1012afrdm.c rename to board/freescale/ls1012afrx/ls1012afrx.c
Pramod Kumar
