[U-Boot] [PATCH v2] imx: mx6: Add support for MX6 plugin images
Plugin image is a firmware which can be executed during booting. Unlike device configuration data (DCD) which is static and interpretative configuration, plugin can be used to implement rich logics more than the peripherals configuration.
Customers may consider to use the plugin, for the cases including but not limited to: 1) Need runtime condition judging. 2) Add delay to booting. 3) Apply custom settings to boot device and memory system. 4) Need more perpherals other than the boot device to work during booting.
The boot ROM detects the image type using the plugin flag of the boot data structure. If the plugin flag is 1, then the ROM uses the image as a plugin function. The function must initialize the boot device and copy the program image to the final location. At the end the plugin function must return with the program image parameters.
This patch supports generating plugin images and implement a framework for plugin code entry and exit. For any board to generate the plugin image, the macros below must be implemented: imx6_ddr_setting imx6_clock_gating imx6_qos_setting
Signed-off-by: Ye.Li B37916@freescale.com --- Changes since v1: - Improve the patch message to explicate more about the usage of plugin image.
arch/arm/include/asm/arch-mx6/mx6_plugin.S | 145 +++++++++++++++ tools/imximage.c | 263 ++++++++++++++++++++++------ tools/imximage.h | 10 +- 3 files changed, 366 insertions(+), 52 deletions(-) create mode 100644 arch/arm/include/asm/arch-mx6/mx6_plugin.S
diff --git a/arch/arm/include/asm/arch-mx6/mx6_plugin.S b/arch/arm/include/asm/arch-mx6/mx6_plugin.S new file mode 100644 index 0000000..1f5ae83 --- /dev/null +++ b/arch/arm/include/asm/arch-mx6/mx6_plugin.S @@ -0,0 +1,145 @@ +/* + * Copyright (C) 2012-2014 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#include <config.h> + +#ifdef CONFIG_ROM_UNIFIED_SECTIONS +#define ROM_API_TABLE_BASE_ADDR_LEGACY 0x180 +#define ROM_VERSION_OFFSET 0x80 +#else +#define ROM_API_TABLE_BASE_ADDR_LEGACY 0xC0 +#define ROM_VERSION_OFFSET 0x48 +#endif +#define ROM_API_TABLE_BASE_ADDR_MX6DQ_TO15 0xC4 +#define ROM_API_TABLE_BASE_ADDR_MX6DL_TO12 0xC4 +#define ROM_API_HWCNFG_SETUP_OFFSET 0x08 +#define ROM_VERSION_TO10 0x10 +#define ROM_VERSION_TO12 0x12 +#define ROM_VERSION_TO15 0x15 + +plugin_start: + + push {r0-r4, lr} + + imx6_ddr_setting + imx6_clock_gating + imx6_qos_setting + +/* + * The following is to fill in those arguments for this ROM function + * pu_irom_hwcnfg_setup(void **start, size_t *bytes, const void *boot_data) + * This function is used to copy data from the storage media into DDR. + * start - Initial (possibly partial) image load address on entry. + * Final image load address on exit. + * bytes - Initial (possibly partial) image size on entry. + * Final image size on exit. + * boot_data - Initial @ref ivt Boot Data load address. + */ + adr r0, boot_data2 + adr r1, image_len2 + adr r2, boot_data2 + +#ifdef CONFIG_SYS_BOOT_EIMNOR +#ifdef CONFIG_MX6SX + ldr r3, =ROM_VERSION_OFFSET + ldr r4, [r3] + cmp r4, #ROM_VERSION_TO10 + bgt before_calling_rom___pu_irom_hwcnfg_setup + ldr r3, =0x00900b00 + ldr r4, =0x50000000 + str r4, [r3, #0x5c] +#else + ldr r3, =0x00900800 + ldr r4, =0x08000000 + str r4, [r3, #0xc0] +#endif +#endif + +/* + * check the _pu_irom_api_table for the address + */ +before_calling_rom___pu_irom_hwcnfg_setup: + ldr r3, =ROM_VERSION_OFFSET + ldr r4, [r3] +#if defined(CONFIG_MX6SOLO) || defined(CONFIG_MX6DL) + ldr r3, =ROM_VERSION_TO12 + cmp r4, r3 + ldrge r3, =ROM_API_TABLE_BASE_ADDR_MX6DL_TO12 + ldrlt r3, =ROM_API_TABLE_BASE_ADDR_LEGACY +#elif defined(CONFIG_MX6Q) + ldr r3, =ROM_VERSION_TO15 + cmp r4, r3 + ldrge r3, =ROM_API_TABLE_BASE_ADDR_MX6DQ_TO15 + ldrlt r3, =ROM_API_TABLE_BASE_ADDR_LEGACY +#else + ldr r3, =ROM_API_TABLE_BASE_ADDR_LEGACY +#endif + ldr r4, [r3, #ROM_API_HWCNFG_SETUP_OFFSET] + blx r4 +after_calling_rom___pu_irom_hwcnfg_setup: + + +/* To return to ROM from plugin, we need to fill in these argument. + * Here is what need to do: + * Need to construct the paramters for this function before return to ROM: + * plugin_download(void **start, size_t *bytes, UINT32 *ivt_offset) + */ + pop {r0-r4, lr} + push {r5} + ldr r5, boot_data2 + str r5, [r0] + ldr r5, image_len2 + str r5, [r1] + ldr r5, second_ivt_offset + str r5, [r2] + mov r0, #1 + pop {r5} + + /* return back to ROM code */ + bx lr + +/* make the following data right in the end of the output*/ +.ltorg + +#if (defined(CONFIG_SYS_BOOT_EIMNOR) || defined(CONFIG_SYS_BOOT_QSPI)) +#define FLASH_OFFSET 0x1000 +#else +#define FLASH_OFFSET 0x400 +#endif + +/* + * second_ivt_offset is the offset from the "second_ivt_header" to + * "image_copy_start", which involves FLASH_OFFSET, plus the first + * ivt_header, the plugin code size itself recorded by "ivt2_header" + */ + +second_ivt_offset: .long (ivt2_header + 0x2C + FLASH_OFFSET) + +/* + * The following is the second IVT header plus the second boot data + */ +ivt2_header: .long 0x0 +app2_code_jump_v: .long 0x0 +reserv3: .long 0x0 +dcd2_ptr: .long 0x0 +boot_data2_ptr: .long 0x0 +self_ptr2: .long 0x0 +app_code_csf2: .long 0x0 +reserv4: .long 0x0 +boot_data2: .long 0x0 +image_len2: .long 0x0 +plugin2: .long 0x0 diff --git a/tools/imximage.c b/tools/imximage.c index 526b7d4..70a988e 100644 --- a/tools/imximage.c +++ b/tools/imximage.c @@ -24,6 +24,9 @@ static table_entry_t imximage_cmds[] = { {CMD_DATA, "DATA", "Reg Write Data", }, {CMD_CSF, "CSF", "Command Sequence File", }, {CMD_IMAGE_VERSION, "IMAGE_VERSION", "image version", }, +#ifdef CONFIG_USE_PLUGIN + {CMD_PLUGIN, "PLUGIN", "file plugin_addr", }, +#endif {-1, "", "", }, };
@@ -75,6 +78,8 @@ static uint32_t imximage_ivt_offset = UNDEFINED; static uint32_t imximage_csf_size = UNDEFINED; /* Initial Load Region Size */ static uint32_t imximage_init_loadsize; +static uint32_t imximage_iram_free_start; +static uint32_t imximage_plugin_size;
static set_dcd_val_t set_dcd_val; static set_dcd_rst_t set_dcd_rst; @@ -112,7 +117,11 @@ static uint32_t detect_imximage_version(struct imx_header *imx_hdr)
/* Try to detect V2 */ if ((fhdr_v2->header.tag == IVT_HEADER_TAG) && - (hdr_v2->dcd_table.header.tag == DCD_HEADER_TAG)) + (hdr_v2->data.dcd_table.header.tag == DCD_HEADER_TAG)) + return IMXIMAGE_V2; + + if ((fhdr_v2->header.tag == IVT_HEADER_TAG) && + hdr_v2->boot_data.plugin) return IMXIMAGE_V2;
return IMXIMAGE_VER_INVALID; @@ -157,7 +166,7 @@ static void set_dcd_val_v1(struct imx_header *imxhdr, char *name, int lineno, static void set_dcd_val_v2(struct imx_header *imxhdr, char *name, int lineno, int fld, uint32_t value, uint32_t off) { - dcd_v2_t *dcd_v2 = &imxhdr->header.hdr_v2.dcd_table; + dcd_v2_t *dcd_v2 = &imxhdr->header.hdr_v2.data.dcd_table;
switch (fld) { case CFG_REG_ADDRESS: @@ -192,16 +201,18 @@ static void set_dcd_rst_v1(struct imx_header *imxhdr, uint32_t dcd_len, static void set_dcd_rst_v2(struct imx_header *imxhdr, uint32_t dcd_len, char *name, int lineno) { - dcd_v2_t *dcd_v2 = &imxhdr->header.hdr_v2.dcd_table; - - dcd_v2->header.tag = DCD_HEADER_TAG; - dcd_v2->header.length = cpu_to_be16( - dcd_len * sizeof(dcd_addr_data_t) + 8); - dcd_v2->header.version = DCD_VERSION; - dcd_v2->write_dcd_command.tag = DCD_COMMAND_TAG; - dcd_v2->write_dcd_command.length = cpu_to_be16( - dcd_len * sizeof(dcd_addr_data_t) + 4); - dcd_v2->write_dcd_command.param = DCD_COMMAND_PARAM; + if (!imxhdr->header.hdr_v2.boot_data.plugin) { + dcd_v2_t *dcd_v2 = &imxhdr->header.hdr_v2.data.dcd_table; + + dcd_v2->header.tag = DCD_HEADER_TAG; + dcd_v2->header.length = cpu_to_be16( + dcd_len * sizeof(dcd_addr_data_t) + 8); + dcd_v2->header.version = DCD_VERSION; + dcd_v2->write_dcd_command.tag = DCD_COMMAND_TAG; + dcd_v2->write_dcd_command.length = cpu_to_be16( + dcd_len * sizeof(dcd_addr_data_t) + 4); + dcd_v2->write_dcd_command.param = DCD_COMMAND_PARAM; + } }
static void set_imx_hdr_v1(struct imx_header *imxhdr, uint32_t dcd_len, @@ -243,20 +254,87 @@ static void set_imx_hdr_v2(struct imx_header *imxhdr, uint32_t dcd_len, fhdr_v2->header.length = cpu_to_be16(sizeof(flash_header_v2_t)); fhdr_v2->header.version = IVT_VERSION; /* 0x40 */
- fhdr_v2->entry = entry_point; - fhdr_v2->reserved1 = fhdr_v2->reserved2 = 0; - hdr_base = entry_point - imximage_init_loadsize + - flash_offset; - fhdr_v2->self = hdr_base; - fhdr_v2->dcd_ptr = hdr_base + offsetof(imx_header_v2_t, dcd_table); - fhdr_v2->boot_data_ptr = hdr_base - + offsetof(imx_header_v2_t, boot_data); - hdr_v2->boot_data.start = entry_point - imximage_init_loadsize; + if (!hdr_v2->boot_data.plugin) { + fhdr_v2->entry = entry_point; + fhdr_v2->reserved1 = fhdr_v2->reserved2 = 0; + hdr_base = entry_point - imximage_init_loadsize + + flash_offset; + fhdr_v2->self = hdr_base; + fhdr_v2->dcd_ptr = hdr_base + offsetof(imx_header_v2_t, data); + fhdr_v2->boot_data_ptr = hdr_base + + offsetof(imx_header_v2_t, boot_data); + hdr_v2->boot_data.start = entry_point - imximage_init_loadsize; + + fhdr_v2->csf = 0; + + header_size_ptr = &hdr_v2->boot_data.size; + csf_ptr = &fhdr_v2->csf; + } else { + imx_header_v2_t *next_hdr_v2; + flash_header_v2_t *next_fhdr_v2; + + if(imximage_csf_size != 0) { + fprintf(stderr, "Error: Header v2: SECURE_BOOT" + "is only supported in DCD mode!"); + exit(EXIT_FAILURE); + } + + fhdr_v2->entry = imximage_iram_free_start + + flash_offset + sizeof(flash_header_v2_t) + + sizeof(boot_data_t); + + fhdr_v2->reserved1 = fhdr_v2->reserved2 = 0; + fhdr_v2->self = imximage_iram_free_start + flash_offset; + + fhdr_v2->dcd_ptr = 0; + + fhdr_v2->boot_data_ptr = fhdr_v2->self + + offsetof(imx_header_v2_t, boot_data);
- fhdr_v2->csf = 0; + hdr_v2->boot_data.start = imximage_iram_free_start; + /* + * The actural size of plugin image is "imximage_plugin_size + + * sizeof(flash_header_v2_t) + sizeof(boot_data_t)", plus the + * flash_offset space.The ROM code only need to copy this size + * to run the plugin code. However, later when copy the whole + * U-Boot image to DDR, the ROM code use memcpy to copy the + * first part of the image, and use the storage read function + * to get the remaining part. This requires the dividing point + * must be multiple of storage sector size. Here we set the + * first section to be 16KB for this purpose. + */ + hdr_v2->boot_data.size = MAX_PLUGIN_CODE_SIZE; + + /* Security feature are not supported */ + fhdr_v2->csf = 0; + + next_hdr_v2 = (imx_header_v2_t *)((char*)hdr_v2 + + imximage_plugin_size); + + next_fhdr_v2 = &next_hdr_v2->fhdr; + + next_fhdr_v2->header.tag = IVT_HEADER_TAG; /* 0xD1 */ + next_fhdr_v2->header.length = + cpu_to_be16(sizeof(flash_header_v2_t)); + next_fhdr_v2->header.version = IVT_VERSION; /* 0x40 */
- header_size_ptr = &hdr_v2->boot_data.size; - csf_ptr = &fhdr_v2->csf; + next_fhdr_v2->entry = entry_point; + hdr_base = entry_point - sizeof(struct imx_header); + next_fhdr_v2->reserved1 = next_fhdr_v2->reserved2 = 0; + next_fhdr_v2->self = hdr_base + imximage_plugin_size; + + next_fhdr_v2->dcd_ptr = 0; + next_fhdr_v2->boot_data_ptr = next_fhdr_v2->self + + offsetof(imx_header_v2_t, boot_data); + + next_hdr_v2->boot_data.start = hdr_base - flash_offset; + + header_size_ptr = &next_hdr_v2->boot_data.size; + + next_hdr_v2->boot_data.plugin = 0; + + next_fhdr_v2->csf = 0; + } }
static void set_hdr_func(void) @@ -312,16 +390,19 @@ static void print_hdr_v2(struct imx_header *imx_hdr) { imx_header_v2_t *hdr_v2 = &imx_hdr->header.hdr_v2; flash_header_v2_t *fhdr_v2 = &hdr_v2->fhdr; - dcd_v2_t *dcd_v2 = &hdr_v2->dcd_table; - uint32_t size, version; + dcd_v2_t *dcd_v2 = &hdr_v2->data.dcd_table; + uint32_t size, version, plugin;
- size = be16_to_cpu(dcd_v2->header.length) - 8; - if (size > (MAX_HW_CFG_SIZE_V2 * sizeof(dcd_addr_data_t))) { + plugin = hdr_v2->boot_data.plugin; + if (!plugin) { + size = be16_to_cpu(dcd_v2->header.length) - 8; + if (size > (MAX_HW_CFG_SIZE_V2 * sizeof(dcd_addr_data_t))) { fprintf(stderr, "Error: Image corrupt DCD size %d exceed maximum %d\n", (uint32_t)(size / sizeof(dcd_addr_data_t)), MAX_HW_CFG_SIZE_V2); exit(EXIT_FAILURE); + } }
version = detect_imximage_version(imx_hdr); @@ -329,18 +410,82 @@ static void print_hdr_v2(struct imx_header *imx_hdr) printf("Image Type: Freescale IMX Boot Image\n"); printf("Image Ver: %x", version); printf("%s\n", get_table_entry_name(imximage_versions, NULL, version)); - printf("Data Size: "); - genimg_print_size(hdr_v2->boot_data.size); - printf("Load Address: %08x\n", (uint32_t)fhdr_v2->boot_data_ptr); - printf("Entry Point: %08x\n", (uint32_t)fhdr_v2->entry); - if (fhdr_v2->csf && (imximage_ivt_offset != UNDEFINED) && - (imximage_csf_size != UNDEFINED)) { - printf("HAB Blocks: %08x %08x %08x\n", - (uint32_t)fhdr_v2->self, 0, - hdr_v2->boot_data.size - imximage_ivt_offset - - imximage_csf_size); + printf("Mode: %s\n", plugin ? "PLUGIN" : "DCD"); + if (!plugin) { + printf("Data Size: "); + genimg_print_size(hdr_v2->boot_data.size); + printf("Load Address: %08x\n", (uint32_t)fhdr_v2->boot_data_ptr); + printf("Entry Point: %08x\n", (uint32_t)fhdr_v2->entry); + if (fhdr_v2->csf && (imximage_ivt_offset != UNDEFINED) && + (imximage_csf_size != UNDEFINED)) { + printf("HAB Blocks: %08x %08x %08x\n", + (uint32_t)fhdr_v2->self, 0, + hdr_v2->boot_data.size - imximage_ivt_offset - + imximage_csf_size); + } + } else { + imx_header_v2_t *next_hdr_v2; + flash_header_v2_t *next_fhdr_v2; + + /*First Header*/ + printf("Plugin Data Size: "); + genimg_print_size(hdr_v2->boot_data.size); + printf("Plugin Code Size: "); + genimg_print_size(imximage_plugin_size); + printf("Plugin Load Address: %08x\n", hdr_v2->boot_data.start); + printf("Plugin Entry Point: %08x\n", + (uint32_t)fhdr_v2->entry); + + /*Second Header*/ + next_hdr_v2 = (imx_header_v2_t *)((char*)hdr_v2 + + imximage_plugin_size); + next_fhdr_v2 = &next_hdr_v2->fhdr; + printf("U-Boot Data Size: "); + genimg_print_size(next_hdr_v2->boot_data.size); + printf("U-Boot Load Address: %08x\n", next_hdr_v2->boot_data.start); + printf("U-Boot Entry Point: %08x\n", + (uint32_t)next_fhdr_v2->entry); + } +} + +#ifdef CONFIG_USE_PLUGIN +static void copy_plugin_code(struct imx_header *imxhdr, char *plugin_file) +{ + int ifd = -1; + struct stat sbuf; + char *plugin_buf = imxhdr->header.hdr_v2.data.plugin_code; + char *ptr; + + ifd = open(plugin_file, O_RDONLY|O_BINARY); + if (fstat(ifd, &sbuf) < 0) { + fprintf(stderr, "Can't stat %s: %s\n", + plugin_file, + strerror(errno)); + exit(EXIT_FAILURE); + } + + ptr = mmap(0, sbuf.st_size, PROT_READ, MAP_SHARED, ifd, 0); + if (ptr == MAP_FAILED) { + fprintf(stderr, "Can't read %s: %s\n", + plugin_file, + strerror(errno)); + exit(EXIT_FAILURE); + } + + if (sbuf.st_size > MAX_PLUGIN_CODE_SIZE) { + printf("plugin binary size too large\n"); + exit(EXIT_FAILURE); } + + memcpy(plugin_buf, ptr, sbuf.st_size); + imximage_plugin_size = sbuf.st_size; + + (void) munmap((void *)ptr, sbuf.st_size); + (void) close(ifd); + + imxhdr->header.hdr_v2.boot_data.plugin = 1; } +#endif
static void parse_cfg_cmd(struct imx_header *imxhdr, int32_t cmd, char *token, char *name, int lineno, int fld, int dcd_len) @@ -411,6 +556,11 @@ static void parse_cfg_cmd(struct imx_header *imxhdr, int32_t cmd, char *token, if (unlikely(cmd_ver_first != 1)) cmd_ver_first = 0; break; +#ifdef CONFIG_USE_PLUGIN + case CMD_PLUGIN: + copy_plugin_code(imxhdr, token); + break; +#endif } }
@@ -434,20 +584,31 @@ static void parse_cfg_fld(struct imx_header *imxhdr, int32_t *cmd, break; case CFG_REG_ADDRESS: case CFG_REG_VALUE: - if (*cmd != CMD_DATA) - return; - - value = get_cfg_value(token, name, lineno); - (*set_dcd_val)(imxhdr, name, lineno, fld, value, *dcd_len); - - if (fld == CFG_REG_VALUE) { - (*dcd_len)++; - if (*dcd_len > max_dcd_entries) { - fprintf(stderr, "Error: %s[%d] -" - "DCD table exceeds maximum size(%d)\n", - name, lineno, max_dcd_entries); - exit(EXIT_FAILURE); + switch (*cmd) { + case CMD_DATA: + value = get_cfg_value(token, name, lineno); + (*set_dcd_val)(imxhdr, name, lineno, fld, value, + *dcd_len); + + if (fld == CFG_REG_VALUE) { + (*dcd_len)++; + if (*dcd_len > max_dcd_entries) { + fprintf(stderr, "Error: %s[%d] -" + "DCD table exceeds maximum\ + size(%d)\n", + name, lineno, max_dcd_entries); + exit(EXIT_FAILURE); + } } + break; +#ifdef CONFIG_USE_PLUGIN + case CMD_PLUGIN: + value = get_cfg_value(token, name, lineno); + imximage_iram_free_start = value; + break; +#endif + default: + return; } break; default: diff --git a/tools/imximage.h b/tools/imximage.h index 5b5ad0e..ef41d52 100644 --- a/tools/imximage.h +++ b/tools/imximage.h @@ -8,7 +8,9 @@ #ifndef _IMXIMAGE_H_ #define _IMXIMAGE_H_
+#include <config.h> #define MAX_HW_CFG_SIZE_V2 220 /* Max number of registers imx can set for v2 */ +#define MAX_PLUGIN_CODE_SIZE (16*1024) #define MAX_HW_CFG_SIZE_V1 60 /* Max number of registers imx can set for v1 */ #define APP_CODE_BARKER 0xB1 #define DCD_BARKER 0xB17219E9 @@ -54,6 +56,7 @@ enum imximage_cmd { CMD_BOOT_OFFSET, CMD_DATA, CMD_CSF, + CMD_PLUGIN, };
enum imximage_fld_types { @@ -149,7 +152,12 @@ typedef struct { typedef struct { flash_header_v2_t fhdr; boot_data_t boot_data; - dcd_v2_t dcd_table; + union { + dcd_v2_t dcd_table; +#ifdef CONFIG_USE_PLUGIN + char plugin_code[MAX_PLUGIN_CODE_SIZE]; +#endif + } data; } imx_header_v2_t;
/* The header must be aligned to 4k on MX53 for NAND boot */
Update "cfg" script to build for plugin image. This default plugin image supports the boot devices as DCD image.
To enable the plugin, must define the CONFIG_USE_PLUGIN in "mx6qarm2.h"
Signed-off-by: Ye.Li B37916@freescale.com --- Changes since v1: - None
board/freescale/mx6qarm2/Makefile | 4 + board/freescale/mx6qarm2/imximage.cfg | 9 + board/freescale/mx6qarm2/imximage_mx6dl.cfg | 9 + board/freescale/mx6qarm2/plugin.S | 943 +++++++++++++++++++++++++++ 4 files changed, 965 insertions(+), 0 deletions(-) create mode 100644 board/freescale/mx6qarm2/plugin.S
diff --git a/board/freescale/mx6qarm2/Makefile b/board/freescale/mx6qarm2/Makefile index 79401f4..ed08acd 100644 --- a/board/freescale/mx6qarm2/Makefile +++ b/board/freescale/mx6qarm2/Makefile @@ -7,3 +7,7 @@ #
obj-y := mx6qarm2.o + +extra-$(CONFIG_USE_PLUGIN) := plugin.bin +$(obj)/plugin.bin: $(obj)/plugin.o + $(OBJCOPY) -O binary --gap-fill 0xff $< $@ diff --git a/board/freescale/mx6qarm2/imximage.cfg b/board/freescale/mx6qarm2/imximage.cfg index c85bde5..c5b927a 100644 --- a/board/freescale/mx6qarm2/imximage.cfg +++ b/board/freescale/mx6qarm2/imximage.cfg @@ -10,6 +10,9 @@ * The syntax is taken as close as possible with the kwbimage */
+#define __ASSEMBLY__ +#include <config.h> + /* image version */ IMAGE_VERSION 2
@@ -19,6 +22,11 @@ IMAGE_VERSION 2 */ BOOT_FROM sd
+#ifdef CONFIG_USE_PLUGIN +/*PLUGIN plugin-binary-file IRAM_FREE_START_ADDR*/ +PLUGIN board/freescale/mx6qarm2/plugin.bin 0x00907000 +#else + /* * Device Configuration Data (DCD) * @@ -336,3 +344,4 @@ DATA 4 0x020e0018 0x007F007F DATA 4 0x020e001c 0x007F007F
#endif /* CONFIG_MX6DQ_LPDDR2 */ +#endif diff --git a/board/freescale/mx6qarm2/imximage_mx6dl.cfg b/board/freescale/mx6qarm2/imximage_mx6dl.cfg index ae8dcc6..0f4048d 100644 --- a/board/freescale/mx6qarm2/imximage_mx6dl.cfg +++ b/board/freescale/mx6qarm2/imximage_mx6dl.cfg @@ -10,6 +10,9 @@ * The syntax is taken as close as possible with the kwbimage */
+#ifdef CONFIG_USE_PLUGIN +/*PLUGIN plugin-binary-file IRAM_FREE_START_ADDR*/ +PLUGIN board/freescale/mx6qarm2/plugin.bin 0x00907000 +#else + /* * Device Configuration Data (DCD) * @@ -460,3 +468,4 @@ DATA 4 0x020e0010 0xF00000CF DATA 4 0x020e0018 0x007F007F DATA 4 0x020e001c 0x007F007F #endif /* CONFIG_MX6DL_LPDDR2 */ +#endif diff --git a/board/freescale/mx6qarm2/plugin.S b/board/freescale/mx6qarm2/plugin.S new file mode 100644 index 0000000..dded80a --- /dev/null +++ b/board/freescale/mx6qarm2/plugin.S @@ -0,0 +1,943 @@ +/* + * Copyright (C) 2012-2014 Freescale Semiconductor, Inc. + * + * Author: Fabio Estevam fabio.estevam@freescale.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <config.h> + +.macro imx6dlarm2_ddr_setting + ldr r0, =CCM_BASE_ADDR + ldr r1, =0xffffffff + str r1, [r0, #0x068] + ldr r1, =0xffffffff + str r1, [r0, #0x06c] + ldr r1, =0xffffffff + str r1, [r0, #0x070] + ldr r1, =0xffffffff + str r1, [r0, #0x074] + ldr r1, =0xffffffff + str r1, [r0, #0x078] + ldr r1, =0xffffffff + str r1, [r0, #0x07c] + ldr r1, =0xffffffff + str r1, [r0, #0x080] + ldr r1, =0xffffffff + str r1, [r0, #0x084] + + ldr r0, =IOMUXC_BASE_ADDR + ldr r1, =0x000c0000 + str r1, [r0, #0x798] + ldr r1, =0x00000000 + str r1, [r0, #0x758] + + ldr r1, =0x00000030 + str r1, [r0, #0x588] + str r1, [r0, #0x594] + str r1, [r0, #0x56c] + str r1, [r0, #0x578] + str r1, [r0, #0x74c] + str r1, [r0, #0x57c] + + ldr r1, =0x00003000 + str r1, [r0, #0x590] + str r1, [r0, #0x598] + + ldr r1, =0x00000000 + str r1, [r0, #0x58c] + + ldr r1, =0x00003030 + str r1, [r0, #0x59c] + str r1, [r0, #0x5a0] + + ldr r1, =0x00000030 + str r1, [r0, #0x78c] + + ldr r1, =0x00020000 + str r1, [r0, #0x750] + + ldr r1, =0x00000030 + str r1, [r0, #0x5a8] + str r1, [r0, #0x5b0] + str r1, [r0, #0x524] + str r1, [r0, #0x51c] + str r1, [r0, #0x518] + str r1, [r0, #0x50c] + str r1, [r0, #0x5b8] + str r1, [r0, #0x5c0] + + ldr r1, =0x00020000 + str r1, [r0, #0x774] + + ldr r1, =0x00000030 + str r1, [r0, #0x784] + str r1, [r0, #0x788] + str r1, [r0, #0x794] + str r1, [r0, #0x79c] + str r1, [r0, #0x7a0] + str r1, [r0, #0x7a4] + str r1, [r0, #0x7a8] + str r1, [r0, #0x748] + str r1, [r0, #0x5ac] + str r1, [r0, #0x5b4] + str r1, [r0, #0x528] + str r1, [r0, #0x520] + str r1, [r0, #0x514] + str r1, [r0, #0x510] + str r1, [r0, #0x5bc] + str r1, [r0, #0x5c4] + + ldr r0, =MMDC_P0_BASE_ADDR + ldr r1, =MMDC_P1_BASE_ADDR + ldr r2, =0xa1390003 + str r2, [r0, #0x800] + str r2, [r1, #0x800] + + ldr r2, =0x001F001F + str r2, [r0, #0x80c] + str r2, [r0, #0x810] + + ldr r2, =0x00370037 + str r2, [r1, #0x80c] + str r2, [r1, #0x810] + + ldr r2, =0x422f0220 + str r2, [r0, #0x83c] + ldr r2, =0x021f0219 + str r2, [r0, #0x840] + + ldr r2, =0x422f0220 + str r2, [r1, #0x83c] + ldr r2, =0x022d022f + str r2, [r1, #0x840] + + ldr r2, =0x47494b49 + str r2, [r0, #0x848] + ldr r2, =0x48484c47 + str r2, [r1, #0x848] + + ldr r2, =0x39382b2f + str r2, [r0, #0x850] + ldr r2, =0x2f35312c + str r2, [r1, #0x850] + + ldr r2, =0x33333333 + str r2, [r0, #0x81c] + str r2, [r0, #0x820] + str r2, [r0, #0x824] + str r2, [r0, #0x828] + str r2, [r1, #0x81c] + str r2, [r1, #0x820] + str r2, [r1, #0x824] + str r2, [r1, #0x828] + + ldr r2, =0x00000800 + str r2, [r0, #0x8b8] + ldr r2, =0x00000800 + str r2, [r1, #0x8b8] + + ldr r2, =0x0002002d + str r2, [r0, #0x004] + ldr r2, =0x00333030 + str r2, [r0, #0x008] + ldr r2, =0x40445323 + str r2, [r0, #0x00c] + ldr r2, =0xb66e8c63 + str r2, [r0, #0x010] + ldr r2, =0x01ff00db + str r2, [r0, #0x014] + ldr r2, =0x00081740 + str r2, [r0, #0x018] + + ldr r2, =0x00008000 + str r2, [r0, #0x01c] + + ldr r2, =0x000026d2 + str r2, [r0, #0x02c] + ldr r2, =0x00440e21 + str r2, [r0, #0x030] + +#ifdef CONFIG_DDR_32BIT + ldr r2, =0x00000017 + str r2, [r0, #0x040] + ldr r2, =0xc3190000 + str r2, [r0, #0x000] +#else + ldr r2, =0x00000027 + str r2, [r0, #0x040] + ldr r2, =0xc31a0000 + str r2, [r0, #0x000] +#endif + + ldr r2, =0x04008032 + str r2, [r0, #0x01c] + ldr r2, =0x0400803a + str r2, [r0, #0x01c] + + ldr r2, =0x00008033 + str r2, [r0, #0x01c] + ldr r2, =0x0000803b + str r2, [r0, #0x01c] + + ldr r2, =0x00428031 + str r2, [r0, #0x01c] + ldr r2, =0x00428039 + str r2, [r0, #0x01c] + + ldr r2, =0x07208030 + str r2, [r0, #0x01c] + ldr r2, =0x07208038 + str r2, [r0, #0x01c] + + ldr r2, =0x04008040 + str r2, [r0, #0x01c] + ldr r2, =0x04008048 + str r2, [r0, #0x01c] + + ldr r2, =0x00005800 + str r2, [r0, #0x020] + + ldr r2, =0x00000007 + str r2, [r0, #0x818] + str r2, [r1, #0x818] + + ldr r2, =0x0002556d + str r2, [r0, #0x004] + ldr r2, =0x00011006 + str r2, [r1, #0x004] + ldr r2, =0x00000000 + str r2, [r0, #0x01c] +.endm + +.macro imx6dqarm2_ddr_setting + ldr r0, =CCM_BASE_ADDR + ldr r1, =0xffffffff + str r1, [r0, #0x068] + ldr r1, =0xffffffff + str r1, [r0, #0x06c] + ldr r1, =0xffffffff + str r1, [r0, #0x070] + ldr r1, =0xffffffff + str r1, [r0, #0x074] + ldr r1, =0xffffffff + str r1, [r0, #0x078] + ldr r1, =0xffffffff + str r1, [r0, #0x07c] + ldr r1, =0xffffffff + str r1, [r0, #0x080] + ldr r1, =0xffffffff + str r1, [r0, #0x084] + + ldr r0, =IOMUXC_BASE_ADDR + ldr r1, =0x000c0000 + str r1, [r0, #0x798] + ldr r1, =0x00000000 + str r1, [r0, #0x758] + + ldr r1, =0x00000030 + str r1, [r0, #0x588] + ldr r1, =0x00000030 + str r1, [r0, #0x594] + + ldr r1, =0x00000030 + str r1, [r0, #0x56c] + ldr r1, =0x00000030 + str r1, [r0, #0x578] + ldr r1, =0x00000030 + str r1, [r0, #0x74c] + + ldr r1, =0x00000030 + str r1, [r0, #0x57c] + + ldr r1, =0x00000000 + str r1, [r0, #0x58c] + ldr r1, =0x00000030 + str r1, [r0, #0x59c] + ldr r1, =0x00000030 + str r1, [r0, #0x5a0] + ldr r1, =0x00000030 + str r1, [r0, #0x78c] + + ldr r1, =0x00000000 + str r1, [r0, #0x750] + + ldr r1, =0x00000038 + str r1, [r0, #0x5a8] + ldr r1, =0x00000038 + str r1, [r0, #0x5b0] + ldr r1, =0x00000038 + str r1, [r0, #0x524] + ldr r1, =0x00000038 + str r1, [r0, #0x51c] + ldr r1, =0x00000038 + str r1, [r0, #0x518] + ldr r1, =0x00000038 + str r1, [r0, #0x50c] + ldr r1, =0x00000038 + str r1, [r0, #0x5b8] + ldr r1, =0x00000038 + str r1, [r0, #0x5c0] + + ldr r1, =0x00000000 + str r1, [r0, #0x774] + + ldr r1, =0x00000030 + str r1, [r0, #0x784] + ldr r1, =0x00000030 + str r1, [r0, #0x788] + ldr r1, =0x00000030 + str r1, [r0, #0x794] + ldr r1, =0x00000030 + str r1, [r0, #0x79c] + ldr r1, =0x00000030 + str r1, [r0, #0x7a0] + ldr r1, =0x00000030 + str r1, [r0, #0x7a4] + ldr r1, =0x00000030 + str r1, [r0, #0x7a8] + ldr r1, =0x00000030 + str r1, [r0, #0x748] + + ldr r1, =0x00000030 + str r1, [r0, #0x5ac] + ldr r1, =0x00000030 + str r1, [r0, #0x5b4] + ldr r1, =0x00000030 + str r1, [r0, #0x528] + ldr r1, =0x00000030 + str r1, [r0, #0x520] + ldr r1, =0x00000030 + str r1, [r0, #0x514] + ldr r1, =0x00000030 + str r1, [r0, #0x510] + ldr r1, =0x00000030 + str r1, [r0, #0x5bc] + ldr r1, =0x00000030 + str r1, [r0, #0x5c4] + + ldr r0, =MMDC_P0_BASE_ADDR + ldr r2, =0xa1390003 + str r2, [r0, #0x800] + + ldr r2, =0x001F001F + str r2, [r0, #0x80c] + ldr r2, =0x001F001F + str r2, [r0, #0x810] + + ldr r1, =MMDC_P1_BASE_ADDR + ldr r2, =0x00440044 + str r2, [r1, #0x80c] + ldr r2, =0x00440044 + str r2, [r1, #0x810] + + ldr r2, =0x4333033F + str r2, [r0, #0x83c] + ldr r2, =0x0339033E + str r2, [r0, #0x840] + ldr r2, =0x433F0343 + str r2, [r1, #0x83c] + ldr r2, =0x03490320 + str r2, [r1, #0x840] + + ldr r2, =0x42363838 + str r2, [r0, #0x848] + ldr r2, =0x3F343242 + str r2, [r1, #0x848] + + ldr r2, =0x37424844 + str r2, [r0, #0x850] + ldr r2, =0x48264731 + str r2, [r1, #0x850] + + ldr r2, =0x33333333 + str r2, [r0, #0x81c] + ldr r2, =0x33333333 + str r2, [r0, #0x820] + ldr r2, =0x33333333 + str r2, [r0, #0x824] + ldr r2, =0x33333333 + str r2, [r0, #0x828] + ldr r2, =0x33333333 + str r2, [r1, #0x81c] + ldr r2, =0x33333333 + str r2, [r1, #0x820] + ldr r2, =0x33333333 + str r2, [r1, #0x824] + ldr r2, =0x33333333 + str r2, [r1, #0x828] + + ldr r2, =0x00000800 + str r2, [r0, #0x8b8] + ldr r2, =0x00000800 + str r2, [r1, #0x8b8] + + ldr r2, =0x00020036 + str r2, [r0, #0x004] + ldr r2, =0x09444040 + str r2, [r0, #0x008] + ldr r2, =0x555A7975 + str r2, [r0, #0x00c] + ldr r2, =0xFF538F64 + str r2, [r0, #0x010] + ldr r2, =0x01ff00db + str r2, [r0, #0x014] + ldr r2, =0x00081740 + str r2, [r0, #0x018] + + ldr r2, =0x00008000 + str r2, [r0, #0x01c] + + ldr r2, =0x000026d2 + str r2, [r0, #0x02c] + ldr r2, =0x005a1023 + str r2, [r0, #0x030] + ldr r2, =0x00000027 + str r2, [r0, #0x040] + + ldr r2, =0x11420000 + str r2, [r0, #0x400] + ldr r2, =0x11420000 + str r2, [r1, #0x400] + + ldr r2, =0xc31a0000 + str r2, [r0, #0x000] + + ldr r2, =0x04088032 + str r2, [r0, #0x01c] + ldr r2, =0x0408803a + str r2, [r0, #0x01c] + + ldr r2, =0x00008033 + str r2, [r0, #0x01c] + ldr r2, =0x0000803b + str r2, [r0, #0x01c] + + ldr r2, =0x00048031 + str r2, [r0, #0x01c] + ldr r2, =0x00048039 + str r2, [r0, #0x01c] + + ldr r2, =0x09408030 + str r2, [r0, #0x01c] + ldr r2, =0x09408038 + str r2, [r0, #0x01c] + + ldr r2, =0x04008040 + str r2, [r0, #0x01c] + ldr r2, =0x04008048 + str r2, [r0, #0x01c] + + ldr r2, =0x00005800 + str r2, [r0, #0x020] + + ldr r2, =0x00011117 + str r2, [r0, #0x818] + str r2, [r1, #0x818] + + ldr r2, =0x00025576 + str r2, [r0, #0x004] + ldr r2, =0x00011006 + str r2, [r0, #0x404] + ldr r2, =0x00000000 + str r2, [r0, #0x01c] +.endm + +.macro imx6dlarm2_lpddr2_setting + ldr r0, =CCM_BASE_ADDR + ldr r1, =0xffffffff + str r1, [r0, #0x068] + ldr r1, =0xffffffff + str r1, [r0, #0x06c] + ldr r1, =0xffffffff + str r1, [r0, #0x070] + ldr r1, =0xffffffff + str r1, [r0, #0x074] + ldr r1, =0xffffffff + str r1, [r0, #0x078] + ldr r1, =0xffffffff + str r1, [r0, #0x07c] + ldr r1, =0xffffffff + str r1, [r0, #0x080] + ldr r1, =0xffffffff + str r1, [r0, #0x084] + + ldr r0, =IOMUXC_BASE_ADDR + ldr r1, =0x00003028 + str r1, [r0, #0x4bc] + str r1, [r0, #0x4c0] + str r1, [r0, #0x4c4] + str r1, [r0, #0x4c8] + str r1, [r0, #0x4cc] + str r1, [r0, #0x4d0] + str r1, [r0, #0x4d4] + str r1, [r0, #0x4d8] + + ldr r1, =0x00000038 + str r1, [r0, #0x470] + str r1, [r0, #0x474] + str r1, [r0, #0x478] + str r1, [r0, #0x47c] + str r1, [r0, #0x480] + str r1, [r0, #0x484] + str r1, [r0, #0x488] + str r1, [r0, #0x48c] + str r1, [r0, #0x464] + str r1, [r0, #0x490] + str r1, [r0, #0x4ac] + str r1, [r0, #0x4b0] + str r1, [r0, #0x494] + str r1, [r0, #0x4a4] + str r1, [r0, #0x4a8] + + ldr r1, =0x00000000 + str r1, [r0, #0x4a0] + ldr r1, =0x00000038 + str r1, [r0, #0x4b4] + str r1, [r0, #0x4b8] + str r1, [r0, #0x764] + str r1, [r0, #0x770] + str r1, [r0, #0x778] + str r1, [r0, #0x77c] + str r1, [r0, #0x780] + str r1, [r0, #0x784] + str r1, [r0, #0x78c] + str r1, [r0, #0x748] + str r1, [r0, #0x74c] + str r1, [r0, #0x76c] + ldr r1, =0x00020000 + str r1, [r0, #0x750] + ldr r1, =0x00000000 + str r1, [r0, #0x754] + ldr r1, =0x00020000 + str r1, [r0, #0x760] + ldr r1, =0x00080000 + str r1, [r0, #0x774] + + ldr r0, =MMDC_P0_BASE_ADDR + ldr r1, =MMDC_P1_BASE_ADDR + ldr r2, =0x00008000 + str r2, [r0, #0x1c] + str r2, [r1, #0x1c] + ldr r2, =0x1b5f01ff + str r2, [r0, #0x85c] + str r2, [r1, #0x85c] + ldr r2, =0xa1390003 + str r2, [r0, #0x800] + ldr r2, =0x00400000 + str r2, [r0, #0x890] + str r2, [r1, #0x890] + ldr r2, =0x00055555 + str r2, [r1, #0x8bc] + ldr r2, =0x00000800 + str r2, [r0, #0x8b8] + str r2, [r1, #0x8b8] + + ldr r2, =0x33333333 + str r2, [r0, #0x81c] + str r2, [r0, #0x820] + str r2, [r0, #0x824] + str r2, [r0, #0x828] + str r2, [r1, #0x81c] + str r2, [r1, #0x820] + str r2, [r1, #0x824] + str r2, [r1, #0x828] + + ldr r2, =0x4b4b524f + str r2, [r0, #0x848] + ldr r2, =0x494f4c44 + str r2, [r1, #0x848] + + ldr r2, =0x3c3d303c + str r2, [r0, #0x850] + ldr r2, =0x3c343d38 + str r2, [r1, #0x850] + + ldr r2, =0x20000000 + str r2, [r0, #0x83c] + str r2, [r1, #0x83c] + ldr r2, =0x00000000 + str r2, [r0, #0x840] + str r2, [r1, #0x840] + + ldr r2, =0x00000a00 + str r2, [r0, #0x858] + str r2, [r1, #0x858] + + ldr r2, =0x00000800 + str r2, [r0, #0x8b8] + str r2, [r1, #0x8b8] + + ldr r2, =0x34386145 + str r2, [r0, #0xc] + ldr r2, =0x00020036 + str r2, [r0, #0x4] + ldr r2, =0x00100c83 + str r2, [r0, #0x10] + ldr r2, =0x000000Dc + str r2, [r0, #0x14] + ldr r2, =0x0000174C + str r2, [r0, #0x18] + ldr r2, =0x0f9f26d2 + str r2, [r0, #0x2c] + ldr r2, =0x0000020e + str r2, [r0, #0x30] + ldr r2, =0x00190778 + str r2, [r0, #0x38] + ldr r2, =0x00000000 + str r2, [r0, #0x8] + + ldr r2, =0x0000005f + str r2, [r0, #0x40] + ldr r2, =0x0000000f + str r2, [r0, #0x404] + + ldr r2, =0xc3010000 + str r2, [r0, #0x0] + + ldr r2, =0x34386145 + str r2, [r1, #0xc] + + ldr r2, =0x00020036 + str r2, [r1, #0x4] + ldr r2, =0x00100c83 + str r2, [r1, #0x10] + ldr r2, =0x000000Dc + str r2, [r1, #0x14] + ldr r2, =0x0000174C + str r2, [r1, #0x18] + ldr r2, =0x0f9f26d2 + str r2, [r1, #0x2c] + ldr r2, =0x0000020e + str r2, [r1, #0x30] + ldr r2, =0x00190778 + str r2, [r1, #0x38] + ldr r2, =0x00000000 + str r2, [r1, #0x8] + + ldr r2, =0x0000003f + str r2, [r1, #0x40] + + ldr r2, =0xc3010000 + str r2, [r1, #0x0] + + ldr r2, =0x003f8030 + str r2, [r0, #0x1c] + ldr r2, =0xff0a8030 + str r2, [r0, #0x1c] + ldr r2, =0xa2018030 + str r2, [r0, #0x1c] + ldr r2, =0x06028030 + str r2, [r0, #0x1c] + ldr r2, =0x01038030 + str r2, [r0, #0x1c] + + ldr r2, =0x003f8030 + str r2, [r1, #0x1c] + ldr r2, =0xff0a8030 + str r2, [r1, #0x1c] + ldr r2, =0xa2018030 + str r2, [r1, #0x1c] + ldr r2, =0x06028030 + str r2, [r1, #0x1c] + ldr r2, =0x01038030 + str r2, [r1, #0x1c] + + ldr r2, =0x00005800 + str r2, [r0, #0x20] + str r2, [r1, #0x20] + + ldr r2, =0x00000000 + str r2, [r0, #0x818] + str r2, [r1, #0x818] + + ldr r2, =0xa1310003 + str r2, [r0, #0x800] + + ldr r2, =0x00000800 + str r2, [r0, #0x8b8] + str r2, [r1, #0x8b8] + + ldr r2, =0x00000000 + str r2, [r0, #0x1c] + str r2, [r1, #0x1c] + + ldr r0, =IOMUXC_BASE_ADDR + ldr r1, =0xF00000CF + str r1, [r0, #0x10] + ldr r1, =0x007F007F + str r1, [r0, #0x18] + ldr r1, =0x007F007F + str r1, [r0, #0x1c] +.endm + +.macro imx6dqarm2_lpddr2_setting + ldr r0, =CCM_BASE_ADDR + ldr r1, =0x60324 + str r1, [r0, #0x18] + ldr r1, =0xffffffff + str r1, [r0, #0x068] + ldr r1, =0xffffffff + str r1, [r0, #0x06c] + ldr r1, =0xffffffff + str r1, [r0, #0x070] + ldr r1, =0xffffffff + str r1, [r0, #0x074] + ldr r1, =0xffffffff + str r1, [r0, #0x078] + ldr r1, =0xffffffff + str r1, [r0, #0x07c] + ldr r1, =0xffffffff + str r1, [r0, #0x080] + ldr r1, =0xffffffff + str r1, [r0, #0x084] + + ldr r0, =IOMUXC_BASE_ADDR + ldr r1, =0x00003038 + str r1, [r0, #0x5a8] + str r1, [r0, #0x5b0] + str r1, [r0, #0x524] + str r1, [r0, #0x51c] + str r1, [r0, #0x518] + str r1, [r0, #0x50c] + str r1, [r0, #0x5b8] + str r1, [r0, #0x5c0] + + ldr r1, =0x00000038 + str r1, [r0, #0x5ac] + str r1, [r0, #0x5b4] + str r1, [r0, #0x528] + str r1, [r0, #0x520] + str r1, [r0, #0x514] + str r1, [r0, #0x510] + str r1, [r0, #0x5bc] + str r1, [r0, #0x5c4] + str r1, [r0, #0x56c] + str r1, [r0, #0x578] + str r1, [r0, #0x588] + str r1, [r0, #0x594] + str r1, [r0, #0x57c] + str r1, [r0, #0x590] + str r1, [r0, #0x598] + + ldr r1, =0x00000000 + str r1, [r0, #0x58c] + ldr r1, =0x00000038 + str r1, [r0, #0x59c] + str r1, [r0, #0x5a0] + str r1, [r0, #0x784] + str r1, [r0, #0x788] + str r1, [r0, #0x794] + str r1, [r0, #0x79c] + str r1, [r0, #0x7a0] + str r1, [r0, #0x7a4] + str r1, [r0, #0x7a8] + str r1, [r0, #0x748] + str r1, [r0, #0x74c] + ldr r1, =0x00020000 + str r1, [r0, #0x750] + ldr r1, =0x00000000 + str r1, [r0, #0x758] + ldr r1, =0x00020000 + str r1, [r0, #0x774] + ldr r1, =0x00000038 + str r1, [r0, #0x78c] + ldr r1, =0x00080000 + str r1, [r0, #0x798] + + ldr r0, =MMDC_P0_BASE_ADDR + ldr r1, =MMDC_P1_BASE_ADDR + ldr r2, =0x00008000 + str r2, [r0, #0x1c] + str r2, [r1, #0x1c] + ldr r2, =0x1b5f01ff + str r2, [r0, #0x85c] + str r2, [r1, #0x85c] + ldr r2, =0xa1390000 + str r2, [r0, #0x800] + str r2, [r1, #0x800] + ldr r2, =0x00400000 + str r2, [r0, #0x890] + str r2, [r1, #0x890] + ldr r2, =0x00055555 + str r2, [r1, #0x8bc] + ldr r2, =0x00000800 + str r2, [r0, #0x8b8] + str r2, [r1, #0x8b8] + + ldr r2, =0x33333333 + str r2, [r0, #0x81c] + str r2, [r0, #0x820] + str r2, [r0, #0x824] + str r2, [r0, #0x828] + str r2, [r1, #0x81c] + str r2, [r1, #0x820] + str r2, [r1, #0x824] + str r2, [r1, #0x828] + + ldr r2, =0xf3333333 + str r2, [r0, #0x82c] + str r2, [r0, #0x830] + str r2, [r0, #0x834] + str r2, [r0, #0x838] + str r2, [r1, #0x82c] + str r2, [r1, #0x830] + str r2, [r1, #0x834] + str r2, [r1, #0x838] + + ldr r2, =0x49383b39 + str r2, [r0, #0x848] + ldr r2, =0x30364738 + str r2, [r0, #0x850] + + ldr r2, =0x3e3c3846 + str r2, [r1, #0x848] + ldr r2, =0x4c294b35 + str r2, [r1, #0x850] + + ldr r2, =0x20000000 + str r2, [r0, #0x83c] + str r2, [r1, #0x83c] + ldr r2, =0x00000000 + str r2, [r0, #0x840] + str r2, [r1, #0x840] + + ldr r2, =0x00000f00 + str r2, [r0, #0x858] + str r2, [r1, #0x858] + + ldr r2, =0x00000800 + str r2, [r0, #0x8b8] + str r2, [r1, #0x8b8] + + ldr r2, =0x555a61a5 + str r2, [r0, #0xc] + ldr r2, =0x00020036 + str r2, [r0, #0x4] + ldr r2, =0x00160e83 + str r2, [r0, #0x10] + ldr r2, =0x000000dd + str r2, [r0, #0x14] + ldr r2, =0x0008174C + str r2, [r0, #0x18] + ldr r2, =0x0f9f26d2 + str r2, [r0, #0x2c] + ldr r2, =0x0000020e + str r2, [r0, #0x30] + ldr r2, =0x200aac + str r2, [r0, #0x38] + ldr r2, =0x00000000 + str r2, [r0, #0x8] + + ldr r2, =0x0000005f + str r2, [r0, #0x40] + + ldr r2, =0xc3010000 + str r2, [r0, #0x0] + + ldr r2, =0x555a61a5 + str r2, [r1, #0xc] + ldr r2, =0x00020036 + str r2, [r1, #0x4] + ldr r2, =0x00160e83 + str r2, [r1, #0x10] + ldr r2, =0x000000dd + str r2, [r1, #0x14] + ldr r2, =0x0008174C + str r2, [r1, #0x18] + ldr r2, =0x0f9f26d2 + str r2, [r1, #0x2c] + ldr r2, =0x0000020e + str r2, [r1, #0x30] + ldr r2, =0x00200aac + str r2, [r1, #0x38] + ldr r2, =0x00000000 + str r2, [r1, #0x8] + + ldr r2, =0x0000003f + str r2, [r1, #0x40] + + ldr r2, =0xc3010000 + str r2, [r1, #0x0] + + ldr r2, =0x003f8030 + str r2, [r0, #0x1c] + ldr r2, =0xff0a8030 + str r2, [r0, #0x1c] + ldr r2, =0xc2018030 + str r2, [r0, #0x1c] + ldr r2, =0x06028030 + str r2, [r0, #0x1c] + ldr r2, =0x02038030 + str r2, [r0, #0x1c] + + ldr r2, =0x003f8030 + str r2, [r1, #0x1c] + ldr r2, =0xff0a8030 + str r2, [r1, #0x1c] + ldr r2, =0xc2018030 + str r2, [r1, #0x1c] + ldr r2, =0x06028030 + str r2, [r1, #0x1c] + ldr r2, =0x02038030 + str r2, [r1, #0x1c] + + ldr r2, =0xa1390003 + str r2, [r0, #0x800] + str r2, [r1, #0x800] + + ldr r2, =0x00007800 + str r2, [r0, #0x20] + str r2, [r1, #0x20] + + ldr r2, =0x00000000 + str r2, [r0, #0x818] + str r2, [r1, #0x818] + + ldr r2, =0xa1310003 + str r2, [r0, #0x800] + str r2, [r1, #0x800] + + ldr r2, =0x00000800 + str r2, [r0, #0x8b8] + str r2, [r1, #0x8b8] + + ldr r2, =0x00000000 + str r2, [r0, #0x1c] + str r2, [r1, #0x1c] + + ldr r2, =0x00011006 + str r2, [r0, #0x404] + + ldr r0, =IOMUXC_BASE_ADDR + ldr r1, =0xF00000CF + str r1, [r0, #0x10] + ldr r1, =0x007F007F + str r1, [r0, #0x18] + ldr r1, =0x007F007F + str r1, [r0, #0x1c] +.endm + +.macro imx6_ddr_setting + #if defined (CONFIG_MX6DQ_LPDDR2) + imx6dqarm2_lpddr2_setting + #elif defined (CONFIG_MX6Q) + imx6dqarm2_ddr_setting + #elif defined (CONFIG_MX6DL_LPDDR2) + imx6dlarm2_lpddr2_setting + #elif defined (CONFIG_MX6DL) + imx6dlarm2_ddr_setting + #else + #error "SOC not configured" + #endif +.endm + +.macro imx6_clock_gating +.endm + +.macro imx6_qos_setting +.endm + +/* include the common plugin code here */ +#include <asm/arch/mx6_plugin.S>
To enable the plugin, must define the CONFIG_USE_PLUGIN in "mx6slevk.h"
board/freescale/mx6slevk/Makefile | 4 + board/freescale/mx6slevk/imximage.cfg | 9 ++ board/freescale/mx6slevk/plugin.S | 187 +++++++++++++++++++++++++++++++++ 3 files changed, 200 insertions(+), 0 deletions(-) create mode 100644 board/freescale/mx6slevk/plugin.S
diff --git a/board/freescale/mx6slevk/Makefile b/board/freescale/mx6slevk/Makefile index 6e1971e..fb44826 100644 --- a/board/freescale/mx6slevk/Makefile +++ b/board/freescale/mx6slevk/Makefile @@ -4,3 +4,7 @@ #
obj-y := mx6slevk.o + +extra-$(CONFIG_USE_PLUGIN) := plugin.bin +$(obj)/plugin.bin: $(obj)/plugin.o + $(OBJCOPY) -O binary --gap-fill 0xff $< $@ diff --git a/board/freescale/mx6slevk/imximage.cfg b/board/freescale/mx6slevk/imximage.cfg index 16ea597..b574357 100644 --- a/board/freescale/mx6slevk/imximage.cfg +++ b/board/freescale/mx6slevk/imximage.cfg @@ -9,6 +9,9 @@ * The syntax is taken as close as possible with the kwbimage */
IMAGE_VERSION 2 @@ -20,6 +23,11 @@ IMAGE_VERSION 2
BOOT_FROM sd
+#ifdef CONFIG_USE_PLUGIN +/*PLUGIN plugin-binary-file IRAM_FREE_START_ADDR*/ +PLUGIN board/freescale/mx6slevk/plugin.bin 0x00907000 +#else + /* * Device Configuration Data (DCD) * @@ -113,3 +121,4 @@ DATA 4 0x021b08b8 0x00000800 DATA 4 0x021b0004 0x00025564 DATA 4 0x021b0404 0x00011006 DATA 4 0x021b001c 0x00000000 +#endif diff --git a/board/freescale/mx6slevk/plugin.S b/board/freescale/mx6slevk/plugin.S new file mode 100644 index 0000000..287dfed --- /dev/null +++ b/board/freescale/mx6slevk/plugin.S @@ -0,0 +1,187 @@ +/* + * Copyright (C) 2014 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <config.h> + +/* DDR script */ +.macro imx6slevk_ddr_setting + ldr r0, =CCM_BASE_ADDR + ldr r1, =0x00260324 + str r1, [r0, #0x018] + + ldr r0, =IOMUXC_BASE_ADDR + ldr r1, =0x00020000 + str r1, [r0, #0x5c0] + ldr r1, =0x00000000 + str r1, [r0, #0x5b4] + + ldr r1, =0x00000028 + str r1, [r0, #0x338] + + ldr r1, =0x00000030 + str r1, [r0, #0x300] + str r1, [r0, #0x31c] + str r1, [r0, #0x320] + + ldr r1, =0x00000000 + str r1, [r0, #0x32c] + + ldr r1, =0x00000030 + str r1, [r0, #0x5ac] + str r1, [r0, #0x5c8] + + ldr r1, =0x00020000 + str r1, [r0, #0x5b0] + + ldr r1, =0x00003030 + str r1, [r0, #0x344] + str r1, [r0, #0x348] + str r1, [r0, #0x34c] + str r1, [r0, #0x350] + + ldr r1, =0x00080000 + str r1, [r0, #0x5d0] + + ldr r1, =0x00000030 + str r1, [r0, #0x5c4] + str r1, [r0, #0x5cc] + str r1, [r0, #0x5d4] + str r1, [r0, #0x5d8] + + str r1, [r0, #0x30c] + str r1, [r0, #0x310] + str r1, [r0, #0x314] + str r1, [r0, #0x318] + + ldr r0, =MMDC_P0_BASE_ADDR + ldr r2, =0x00008000 + str r2, [r0, #0x01c] + + ldr r2, =0x1b4700c7 + str r2, [r0, #0x85c] + + ldr r2, =0xa1390003 + str r2, [r0, #0x800] + + ldr r2, =0x00300000 + str r2, [r0, #0x890] + + ldr r2, =0x00000800 + str r2, [r0, #0x8b8] + + ldr r2, =0x33333333 + str r2, [r0, #0x81c] + str r2, [r0, #0x820] + str r2, [r0, #0x824] + str r2, [r0, #0x828] + str r2, [r0, #0x82c] + str r2, [r0, #0x830] + str r2, [r0, #0x834] + str r2, [r0, #0x838] + + ldr r2, =0x4241444a + str r2, [r0, #0x848] + + ldr r2, =0x3030312b + str r2, [r0, #0x850] + + ldr r2, =0x20000000 + str r2, [r0, #0x83c] + + ldr r2, =0x00000000 + str r2, [r0, #0x840] + + ldr r2, =0x00000800 + str r2, [r0, #0x8b8] + + ldr r2, =0x33374133 + str r2, [r0, #0x00c] + + ldr r2, =0x00020024 + str r2, [r0, #0x004] + + ldr r2, =0x00100A82 + str r2, [r0, #0x010] + ldr r2, =0x00000093 + str r2, [r0, #0x014] + ldr r2, =0x00001688 + str r2, [r0, #0x018] + ldr r2, =0x0F9F26D2 + str r2, [r0, #0x02c] + + ldr r2, =0x0000020E + str r2, [r0, #0x030] + ldr r2, =0x00190778 + str r2, [r0, #0x038] + ldr r2, =0x00000000 + str r2, [r0, #0x008] + ldr r2, =0x0000004F + str r2, [r0, #0x040] + ldr r2, =0xC3110000 + str r2, [r0, #0x000] + + ldr r2, =0x003F8030 + str r2, [r0, #0x01c] + ldr r2, =0xFF0A8030 + str r2, [r0, #0x01c] + ldr r2, =0x82018030 + str r2, [r0, #0x01c] + ldr r2, =0x04028030 + str r2, [r0, #0x01c] + ldr r2, =0x02038030 + str r2, [r0, #0x01c] + ldr r2, =0xFF0A8038 + str r2, [r0, #0x01c] + ldr r2, =0x82018038 + str r2, [r0, #0x01c] + ldr r2, =0x04028038 + str r2, [r0, #0x01c] + ldr r2, =0x02038038 + str r2, [r0, #0x01c] + + ldr r2, =0xa1310003 + str r2, [r0, #0x800] + + ldr r2, =0x00001800 + str r2, [r0, #0x020] + + ldr r2, =0x00000000 + str r2, [r0, #0x818] + + ldr r2, =0x00000800 + str r2, [r0, #0x8b8] + + ldr r2, =0x00025564 + str r2, [r0, #0x004] + + ldr r2, =0x00011006 + str r2, [r0, #0x404] + + ldr r2, =0x00000000 + str r2, [r0, #0x01c] +.endm +.macro imx6_clock_gating + ldr r0, =CCM_BASE_ADDR + ldr r1, =0xffffffff + str r1, [r0, #0x068] + str r1, [r0, #0x06c] + str r1, [r0, #0x070] + str r1, [r0, #0x074] + str r1, [r0, #0x078] + str r1, [r0, #0x07c] + str r1, [r0, #0x080] + str r1, [r0, #0x084] +.endm + +.macro imx6_qos_setting +.endm + +.macro imx6_ddr_setting + imx6slevk_ddr_setting +.endm + +/* include the common plugin code here */ +#include <asm/arch/mx6_plugin.S>
To enable the plugin, must define the CONFIG_USE_PLUGIN in "mx6sxsabresd.h"
board/freescale/mx6sxsabresd/Makefile | 4 + board/freescale/mx6sxsabresd/imximage.cfg | 6 ++ board/freescale/mx6sxsabresd/plugin.S | 135 +++++++++++++++++++++++++++++ 3 files changed, 145 insertions(+), 0 deletions(-) create mode 100644 board/freescale/mx6sxsabresd/plugin.S
diff --git a/board/freescale/mx6sxsabresd/Makefile b/board/freescale/mx6sxsabresd/Makefile index 97dbfda..bd9ac6f 100644 --- a/board/freescale/mx6sxsabresd/Makefile +++ b/board/freescale/mx6sxsabresd/Makefile @@ -4,3 +4,7 @@ #
obj-y := mx6sxsabresd.o + +extra-$(CONFIG_USE_PLUGIN) := plugin.bin +$(obj)/plugin.bin: $(obj)/plugin.o + $(OBJCOPY) -O binary --gap-fill 0xff $< $@ diff --git a/board/freescale/mx6sxsabresd/imximage.cfg b/board/freescale/mx6sxsabresd/imximage.cfg index c862617..9a99208 100644 --- a/board/freescale/mx6sxsabresd/imximage.cfg +++ b/board/freescale/mx6sxsabresd/imximage.cfg @@ -18,6 +18,11 @@ IMAGE_VERSION 2
BOOT_FROM sd
+#ifdef CONFIG_USE_PLUGIN +/*PLUGIN plugin-binary-file IRAM_FREE_START_ADDR*/ +PLUGIN board/freescale/mx6sxsabresd/plugin.bin 0x00907000 +#else + /* * Device Configuration Data (DCD) * @@ -130,3 +135,4 @@ DATA 4 0x021b001c 0x04008040 DATA 4 0x021b0020 0x00000800 DATA 4 0x021b0818 0x00011117 DATA 4 0x021b001c 0x00000000 +#endif diff --git a/board/freescale/mx6sxsabresd/plugin.S b/board/freescale/mx6sxsabresd/plugin.S new file mode 100644 index 0000000..667095f --- /dev/null +++ b/board/freescale/mx6sxsabresd/plugin.S @@ -0,0 +1,135 @@ +/* + * Copyright (C) 2013-2014 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <config.h> + +/* DDR script */ +.macro imx6sx_sabresd_ddr_setting + ldr r0, =IOMUXC_BASE_ADDR + ldr r1, =0x000c0000 + str r1, [r0, #0x618] + ldr r1, =0x00000000 + str r1, [r0, #0x5fc] + ldr r1, =0x00000030 + str r1, [r0, #0x32c] + + ldr r1, =0x00000020 + str r1, [r0, #0x300] + str r1, [r0, #0x2fc] + str r1, [r0, #0x5f4] + str r1, [r0, #0x340] + + ldr r1, =0x00000000 + str r1, [r0, #0x320] + ldr r1, =0x00000020 + str r1, [r0, #0x310] + str r1, [r0, #0x314] + str r1, [r0, #0x614] + + ldr r1, =0x00020000 + str r1, [r0, #0x5f8] + ldr r1, =0x00000028 + str r1, [r0, #0x330] + str r1, [r0, #0x334] + str r1, [r0, #0x338] + str r1, [r0, #0x33c] + ldr r1, =0x00020000 + str r1, [r0, #0x608] + ldr r1, =0x00000028 + str r1, [r0, #0x60c] + str r1, [r0, #0x610] + str r1, [r0, #0x61c] + str r1, [r0, #0x620] + str r1, [r0, #0x2ec] + str r1, [r0, #0x2f0] + str r1, [r0, #0x2f4] + str r1, [r0, #0x2f8] + + ldr r0, =MMDC_P0_BASE_ADDR + ldr r2, =0xa1390003 + str r2, [r0, #0x800] + ldr r2, =0x00290025 + str r2, [r0, #0x80c] + ldr r2, =0x00220022 + str r2, [r0, #0x810] + ldr r2, =0x41480144 + str r2, [r0, #0x83c] + ldr r2, =0x01340130 + str r2, [r0, #0x840] + ldr r2, =0x3C3E4244 + str r2, [r0, #0x848] + ldr r2, =0x34363638 + str r2, [r0, #0x850] + + ldr r2, =0x33333333 + str r2, [r0, #0x81c] + str r2, [r0, #0x820] + str r2, [r0, #0x824] + str r2, [r0, #0x828] + + ldr r2, =0x00000800 + str r2, [r0, #0x8b8] + ldr r2, =0x0002002d + str r2, [r0, #0x004] + ldr r2, =0x00333030 + str r2, [r0, #0x008] + ldr r2, =0x676b52f3 + str r2, [r0, #0x00c] + ldr r2, =0xb66d8b63 + str r2, [r0, #0x010] + ldr r2, =0x01ff00db + str r2, [r0, #0x014] + ldr r2, =0x00011740 + str r2, [r0, #0x018] + ldr r2, =0x00008000 + str r2, [r0, #0x01c] + ldr r2, =0x000026d2 + str r2, [r0, #0x02c] + ldr r2, =0x006b1023 + str r2, [r0, #0x030] + ldr r2, =0x0000005f + str r2, [r0, #0x040] + ldr r2, =0x84190000 + str r2, [r0, #0x000] + ldr r2, =0x04008032 + str r2, [r0, #0x01c] + ldr r2, =0x00008033 + str r2, [r0, #0x01c] + ldr r2, =0x00048031 + str r2, [r0, #0x01c] + ldr r2, =0x05208030 + str r2, [r0, #0x01c] + ldr r2, =0x04008040 + str r2, [r0, #0x01c] + ldr r2, =0x00000800 + str r2, [r0, #0x020] + ldr r2, =0x00011117 + str r2, [r0, #0x818] + ldr r2, =0x00000000 + str r2, [r0, #0x01c] +.endm +.macro imx6_clock_gating + ldr r0, =CCM_BASE_ADDR + ldr r1, =0xffffffff + str r1, [r0, #0x068] + str r1, [r0, #0x06c] + str r1, [r0, #0x070] + str r1, [r0, #0x074] + str r1, [r0, #0x078] + str r1, [r0, #0x07c] + str r1, [r0, #0x080] + str r1, [r0, #0x084] +.endm + +.macro imx6_qos_setting +.endm + +.macro imx6_ddr_setting + imx6sx_sabresd_ddr_setting +.endm + +/* include the common plugin code here */ +#include <asm/arch/mx6_plugin.S>
Hi Ye,
- Need runtime condition judging.
- Add delay to booting.
- Apply custom settings to boot device and memory system.
- Need more perpherals other than the boot device to work during booting.
Before reviewing deeply these patches, I want to discuss here which are the pros and cons for a plugin approach. We had already in the past a large discussion about this topic, and maybe we have to extend it.
Let's see the advantages you are listing here. Of course, if we are comparing to the way was mostly used for i.MXes, it takes advantages. Using only the DCD, most configurations must be decided at compile time. This does not allow to have a single image for multiple boards, for example if a different i.MX6 variant is mounted on the board. And there are a lot of other things that are known only at runtime.
But generally in the U-Boot project was already found solution, that is not only valid for Freescale's i.MXes: SPL. Using SPL, this adds much more flexibility as with plugins. You can program whatever you want, and of course you can add any runtime detection is possible, without intervention of the BOOT ROM. And this is not limited to ddr settzing, clock gating or pinmux setup.
This is not a new approach, and support for SPL was already added to mainline - see the Gateway's ventana board. The different layout of the pinmux is correctly handled. The processor is detected at runtime, making possible to have a single image for several variations of the same board.
I see that plugins are the way found to circumvent the static limitations of the DCD, but it is not a general solution. On the other side, the SPL concept works well on i.MXes as on other SOCs (TIs, Nvidia,...).
I have not changed my mind and I still think that i.MXes in U-Boot should not be an island in the project. Some general concepts must work for all supported SOCs, including i.MXes. In principle, I tend to reject this patchset, because the same new features you list here are already available with SPL. And I encourage to use SPL for other and new i.MX boards.
Best regards, Stefano Babic
Changes since v1:
- Copyright (C) 2012-2014 Freescale Semiconductor, Inc.
- project.
+plugin_start:
- push {r0-r4, lr}
- imx6_ddr_setting
- imx6_clock_gating
- imx6_qos_setting
- The following is to fill in those arguments for this ROM function
- pu_irom_hwcnfg_setup(void **start, size_t *bytes, const void *boot_data)
- This function is used to copy data from the storage media into DDR.
- start - Initial (possibly partial) image load address on entry.
- bytes - Initial (possibly partial) image size on entry.
- boot_data - Initial @ref ivt Boot Data load address.
- adr r0, boot_data2
- adr r1, image_len2
- adr r2, boot_data2
- ldr r3, =ROM_VERSION_OFFSET
- ldr r4, [r3]
- cmp r4, #ROM_VERSION_TO10
- bgt before_calling_rom___pu_irom_hwcnfg_setup
- ldr r3, =0x00900b00
- ldr r4, =0x50000000
- str r4, [r3, #0x5c]
+#else
- ldr r3, =0x00900800
- ldr r4, =0x08000000
- str r4, [r3, #0xc0]
+#endif +#endif
- check the _pu_irom_api_table for the address
- ldr r4, [r3]
- ldr r3, =ROM_VERSION_TO12
- cmp r4, r3
- ldrge r3, =ROM_API_TABLE_BASE_ADDR_MX6DL_TO12
- ldrlt r3, =ROM_API_TABLE_BASE_ADDR_LEGACY
- ldr r3, =ROM_VERSION_TO15
- cmp r4, r3
- ldrge r3, =ROM_API_TABLE_BASE_ADDR_MX6DQ_TO15
+#else
- ldr r3, =ROM_API_TABLE_BASE_ADDR_LEGACY
- ldr r4, [r3, #ROM_API_HWCNFG_SETUP_OFFSET]
- blx r4
- Here is what need to do:
- Need to construct the paramters for this function before return to ROM:
- plugin_download(void **start, size_t *bytes, UINT32 *ivt_offset)
- pop {r0-r4, lr}
- push {r5}
- ldr r5, boot_data2
- str r5, [r0]
- ldr r5, image_len2
- str r5, [r1]
- ldr r5, second_ivt_offset
- str r5, [r2]
- mov r0, #1
- pop {r5}
- /* return back to ROM code */
- bx lr
- second_ivt_offset is the offset from the "second_ivt_header" to
- "image_copy_start", which involves FLASH_OFFSET, plus the first
- ivt_header, the plugin code size itself recorded by "ivt2_header"
- The following is the second IVT header plus the second boot data
- {CMD_PLUGIN, "PLUGIN", "file plugin_addr", },
return IMXIMAGE_V2;
return IMXIMAGE_V2;
- if (!imxhdr->header.hdr_v2.boot_data.plugin) {
flash_offset;
- if (!hdr_v2->boot_data.plugin) {
flash_offset;
fhdr_v2->csf = 0;
- } else {
exit(EXIT_FAILURE);
- fhdr_v2->csf = 0;
fhdr_v2->csf = 0;
- dcd_v2_t *dcd_v2 = &hdr_v2->data.dcd_table;
- uint32_t size, version, plugin;
if (!plugin) {
imximage_csf_size);
- printf("Mode: %s\n", plugin ? "PLUGIN" : "DCD");
- if (!plugin) {
imximage_csf_size);
- } else {
/*First Header*/
/*Second Header*/
- int ifd = -1;
- struct stat sbuf;
- char *plugin_buf = imxhdr->header.hdr_v2.data.plugin_code;
- char *ptr;
- ifd = open(plugin_file, O_RDONLY|O_BINARY);
- if (fstat(ifd, &sbuf) < 0) {
plugin_file,
strerror(errno));
exit(EXIT_FAILURE);
- ptr = mmap(0, sbuf.st_size, PROT_READ, MAP_SHARED, ifd, 0);
- if (ptr == MAP_FAILED) {
plugin_file,
strerror(errno));
exit(EXIT_FAILURE);
- if (sbuf.st_size > MAX_PLUGIN_CODE_SIZE) {
}exit(EXIT_FAILURE);
- memcpy(plugin_buf, ptr, sbuf.st_size);
- imximage_plugin_size = sbuf.st_size;
- (void) munmap((void *)ptr, sbuf.st_size);
- (void) close(ifd);
- imxhdr->header.hdr_v2.boot_data.plugin = 1;
} +#endif
- case CMD_PLUGIN:
break;
+#endif } }
return;
(*dcd_len)++;
exit(EXIT_FAILURE);
switch (*cmd) {
case CMD_DATA:
*dcd_len);
(*dcd_len)++;
size(%d)\n",
exit(EXIT_FAILURE);
break;
case CMD_PLUGIN:
break;
default:
} break; default:return;
- CMD_PLUGIN,
- union {
dcd_v2_t dcd_table;
- } data;
} imx_header_v2_t;
This seems true that the SPL is another way to implement the 'plug-in' features as they relate to DCD.
I think a portion not taken care of by SPL is 2nd and subsequent image verification. The HAB ROM loader will use the 'plug-in' to initialize and load to alternate media. However, when control returns, I think that the 2nd image is authenticated. In order to do the same in the SPL, you need to restrict the IRAM locations used and make calls to the ROM code or implement some other 2nd image authentication.
For non-secure boots, the SPL seems equivalent. With secondary image verification in the SPL, then I think it would be equivalent to the 'plug-in'. The SPL would be supported in all HAB versions. I don't know if the 'plug-in' is supported with earlier iMx series like the iMx2/3x series using HABv3. So an SPL with image verification seems superior, even for the iMx series by itself.
Fwiw, Bill Pringlemeir.
Hi Bill,
Right.
Not for subsequent images, if the second image is U-Boot. U-Boot supports secure boot via FIT images. Kernel and, generally, other images can be authenticated. This is done without HAB.
If we are talking about SPL, that is true. SPL does not *yet* support to authenticate the u-boot image.
commit 36c1ca4d46ef11ac7b3c0afb5c42dadb4e8773f3 is supposed to do what you are looking for. The authenticate_image() function is called to verify an image via HAB.
It is not, as far as I know, and even not in MX51.
Yes, fully agree.
Bill Pringlemeir
Stefano Babic
Ye.Li
