[U-Boot] [PATCH] MAKEALL: fix awk warning
This fixes following warning:
---8<--- abiessmann@punisher % ./MAKEALL -m at91rm9200ek at91rm9200ek:awk: warning: escape sequence `\ ' treated as plain ` ' awk: warning: escape sequence `\ ' treated as plain ` ' andreas.devel@gmail.com --->8---
Signed-off-by: Andreas Bießmann andreas.devel@googlemail.com Cc: Albert Aribaud albert.u.boot@aribaud.net --- tested with gawk 4.0.1 here
MAKEALL | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/MAKEALL b/MAKEALL index a9253d3..b03f87b 100755 --- a/MAKEALL +++ b/MAKEALL @@ -518,7 +518,7 @@ get_target_location() { local vendor=""
# Automatic mode - local line=`awk -F '\ +' '$7 == "'"$target"'" { print $0 }' boards.cfg` + local line=`awk -F ' +' '$7 == "'"$target"'" { print $0 }' boards.cfg` if [ -z "${line}" ] ; then echo "" ; return ; fi
set ${line} @@ -556,7 +556,7 @@ get_target_location() { get_target_maintainers() { local name=`echo $1 | cut -d : -f 3`
- local line=`awk -F '\ +' '$7 == "'"$target"'" { print $0 }' boards.cfg` + local line=`awk -F ' +' '$7 == "'"$target"'" { print $0 }' boards.cfg` if [ -z "${line}" ]; then echo "" return ;
Hello, Andreas.
I already posted a patch to fix this issue. http://patchwork.ozlabs.org/patch/285071/
Tom, when would be possible to apply my patch?
Best Regards Masahiro Yamada
Dear Masahiro Yamada,
On 11/08/2013 03:01 AM, Masahiro Yamada wrote:
Hello, Andreas.
sorry, haven't seen that patch. Please ignore my patch then.
Best regards
Andreas Bießmann
Andreas Bießmann
Masahiro Yamada
