[U-Boot] [PATCH-ARM v2] Add support for Embest SBC2440-II Board
Implementation based on the existing u-boot support for S3C2410-based boards. u-boot programmed into NOR flash.
Tested on an SBC2440-II Board using tftp to copy the files from a server and programming them into NAND flash.
MAKEALL used to build all LIST_ARM9 targets only - no other architectures built as the changes only affect ARM9-based boards.
Changes since v1: - removed all network-related parameters from board config file as requested by Ben Warren
Signed-off-by: Kevin Morfitt kevin.morfitt@fearnside-systems.co.uk --- MAKEALL | 1 + Makefile | 3 + board/embest/sbc2440ii/Makefile | 55 +++++++ board/embest/sbc2440ii/config.mk | 25 ++++ board/embest/sbc2440ii/lowlevel_init.S | 219 ++++++++++++++++++++++++++++ board/embest/sbc2440ii/sbc2440ii.c | 127 ++++++++++++++++ board/embest/sbc2440ii/u-boot.lds | 56 +++++++ common/serial.c | 4 +- cpu/arm920t/s3c24x0/speed.c | 83 ++++++++--- cpu/arm920t/s3c24x0/timer.c | 6 +- cpu/arm920t/s3c24x0/usb.c | 6 +- cpu/arm920t/s3c24x0/usb_ohci.c | 2 + cpu/arm920t/start.S | 35 ++++-- drivers/i2c/s3c24x0_i2c.c | 18 +++ drivers/mtd/nand/Makefile | 2 +- drivers/mtd/nand/s3c2410_nand.c | 223 ++++++++++++++++++++++++----- drivers/rtc/s3c24x0_rtc.c | 2 + drivers/serial/serial_s3c24x0.c | 2 + include/common.h | 3 +- include/configs/sbc2440ii.h | 246 ++++++++++++++++++++++++++++++++ include/s3c2440.h | 231 ++++++++++++++++++++++++++++++ include/s3c24x0.h | 83 +++++++++++ 22 files changed, 1356 insertions(+), 76 deletions(-) create mode 100644 board/embest/sbc2440ii/Makefile create mode 100644 board/embest/sbc2440ii/config.mk create mode 100644 board/embest/sbc2440ii/lowlevel_init.S create mode 100644 board/embest/sbc2440ii/sbc2440ii.c create mode 100644 board/embest/sbc2440ii/u-boot.lds create mode 100644 include/configs/sbc2440ii.h create mode 100644 include/s3c2440.h
diff --git a/MAKEALL b/MAKEALL index c98d03a..e7235e4 100755 --- a/MAKEALL +++ b/MAKEALL @@ -515,6 +515,7 @@ LIST_ARM9=" \ omap5912osk \ omap730p2 \ sbc2410x \ + sbc2440ii \ scb9328 \ smdk2400 \ smdk2410 \ diff --git a/Makefile b/Makefile index 81a5cd0..38f79c2 100644 --- a/Makefile +++ b/Makefile @@ -2876,6 +2876,9 @@ omap730p2_cs3boot_config : unconfig sbc2410x_config: unconfig @$(MKCONFIG) $(@:_config=) arm arm920t sbc2410x NULL s3c24x0
+sbc2440ii_config: unconfig + @$(MKCONFIG) $(@:_config=) arm arm920t sbc2440ii embest s3c24x0 + scb9328_config : unconfig @$(MKCONFIG) $(@:_config=) arm arm920t scb9328 NULL imx
diff --git a/board/embest/sbc2440ii/Makefile b/board/embest/sbc2440ii/Makefile new file mode 100644 index 0000000..85a56fa --- /dev/null +++ b/board/embest/sbc2440ii/Makefile @@ -0,0 +1,55 @@ +# +# (C) Copyright 2000-2006 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# Modified for EMBEST SBC2440-II board with S3C2440 (ARM920T) cpu by: +# (C) Copyright 2009 +# Kevin Morfitt, Fearnside Systems Ltd, kevin.morfitt@fearnside-systems.co.uk +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).a + +COBJS := sbc2440ii.o +SOBJS := lowlevel_init.o + +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) $(SOBJS) + +clean: + rm -f $(SOBJS) $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak $(obj).depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/embest/sbc2440ii/config.mk b/board/embest/sbc2440ii/config.mk new file mode 100644 index 0000000..def11d8 --- /dev/null +++ b/board/embest/sbc2440ii/config.mk @@ -0,0 +1,25 @@ +# +# (C) Copyright 2002 +# Gary Jennejohn, DENX Software Engineering, gj@denx.de +# David Mueller, ELSOFT AG, d.mueller@elsoft.ch +# +# SAMSUNG SMDK2410 board with S3C2410X (ARM920T) cpu +# +# see http://www.samsung.com/ for more information on SAMSUNG +# +# Modified for EMBEST SBC2440-II board with S3C2440 (ARM920T) cpu by: +# (C) Copyright 2009 +# Kevin Morfitt, Fearnside Systems Ltd, kevin.morfitt@fearnside-systems.co.uk + +# +# SBC2440-II has 1 bank of 64 MB DRAM +# +# 3000'0000 to 3800'0000 +# +# Linux-Kernel is expected to be at 3000'8000, entry 3000'8000 +# +# we load ourself to 33F8'0000 +# +# download area is 3000'0000 + +TEXT_BASE = 0x33F80000 diff --git a/board/embest/sbc2440ii/lowlevel_init.S b/board/embest/sbc2440ii/lowlevel_init.S new file mode 100644 index 0000000..90de392 --- /dev/null +++ b/board/embest/sbc2440ii/lowlevel_init.S @@ -0,0 +1,219 @@ +/* + * Memory Setup stuff - taken from blob memsetup.S + * + * Copyright (C) 1999 2000 2001 Erik Mouw (J.A.K.Mouw@its.tudelft.nl) and + * Jan-Derk Bakker (J.D.Bakker@its.tudelft.nl) + * + * Modified for the Samsung SMDK2410 by + * (C) Copyright 2002 + * David Mueller, ELSOFT AG, d.mueller@elsoft.ch + * + * Modified for the friendly-arm SBC-2410X by + * (C) Copyright 2005 + * JinHua Luo, GuangDong Linux Center, luo.jinhua@gd-linux.com + * + * Modified for the Embest SBC2440-II by + * (C) Copyright 2009 + * Kevin Morfitt, Fearnside Systems Ltd, kevin.morfitt@fearnside-systems.co.uk + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <config.h> +#include <version.h> + +/* + * Taken from linux/arch/arm/boot/compressed/head-s3c2410.S + * + * Copyright (C) 2002 Samsung Electronics SW.LEE hitchcar@sec.samsung.com + */ + +#define BWSCON 0x48000000 + +#define DW8 (0x0) +#define DW16 (0x1) +#define DW32 (0x2) +#define WAIT (0x1 << 2) +#define UBLB (0x1 << 3) + +#define B1_BWSCON (DW16) +#define B2_BWSCON (DW16) +#define B3_BWSCON (DW16 + WAIT + UBLB) +#define B4_BWSCON (DW16) +#define B5_BWSCON (DW16) +#define B6_BWSCON (DW32) +#define B7_BWSCON (DW32) +#define BWSCON_VAL ((B1_BWSCON << 4) + (B2_BWSCON << 8) + \ + (B3_BWSCON << 12) + (B4_BWSCON << 16) + \ + (B5_BWSCON << 20) + (B6_BWSCON << 24) + \ + (B7_BWSCON << 28)) + +#define B0_TACS 0x0 +#define B0_TCOS 0x0 +#define B0_TACC 0x7 +#define B0_TCOH 0x0 +#define B0_TAH 0x0 +#define B0_TACP 0x0 +#define B0_PMC 0x0 +#define BANKCON0_VAL ((B0_TACS << 13) + (B0_TCOS << 11) + (B0_TACC << 8) + \ + (B0_TCOH << 6) + (B0_TAH << 4) + (B0_TACP << 2) + \ + B0_PMC) + +#define B1_TACS 0x0 +#define B1_TCOS 0x0 +#define B1_TACC 0x7 +#define B1_TCOH 0x0 +#define B1_TAH 0x0 +#define B1_TACP 0x0 +#define B1_PMC 0x0 +#define BANKCON1_VAL ((B1_TACS << 13) + (B1_TCOS << 11) + (B1_TACC << 8) + \ + (B1_TCOH << 6) + (B1_TAH << 4) + (B1_TACP << 2) + \ + B1_PMC) + +#define B2_TACS 0x0 +#define B2_TCOS 0x0 +#define B2_TACC 0x7 +#define B2_TCOH 0x0 +#define B2_TAH 0x0 +#define B2_TACP 0x0 +#define B2_PMC 0x0 +#define BANKCON2_VAL ((B2_TACS << 13) + (B2_TCOS << 11) + (B2_TACC << 8) + \ + (B2_TCOH << 6) + (B2_TAH << 4) + (B2_TACP << 2) + \ + B2_PMC) + +#define B3_TACS 0x0 /* 0clk */ +#define B3_TCOS 0x3 /* 4clk */ +#define B3_TACC 0x7 /* 14clk */ +#define B3_TCOH 0x1 /* 1clk */ +#define B3_TAH 0x3 /* 4clk */ +#define B3_TACP 0x3 /* 6clk */ +#define B3_PMC 0x0 /* 16data */ +#define BANKCON3_VAL ((B3_TACS << 13) + (B3_TCOS << 11) + (B3_TACC << 8) + \ + (B3_TCOH << 6) + (B3_TAH << 4) + (B3_TACP << 2) + \ + B3_PMC) + +#define B4_TACS 0x0 +#define B4_TCOS 0x0 +#define B4_TACC 0x7 +#define B4_TCOH 0x0 +#define B4_TAH 0x0 +#define B4_TACP 0x0 +#define B4_PMC 0x0 +#define BANKCON4_VAL ((B4_TACS << 13) + (B4_TCOS << 11) + (B4_TACC << 8) + \ + (B4_TCOH << 6) + (B4_TAH << 4) + (B4_TACP << 2) + \ + B4_PMC) + +#define B5_TACS 0x0 +#define B5_TCOS 0x0 +#define B5_TACC 0x7 +#define B5_TCOH 0x0 +#define B5_TAH 0x0 +#define B5_TACP 0x0 +#define B5_PMC 0x0 +#define BANKCON5_VAL ((B5_TACS << 13) + (B5_TCOS << 11) + (B5_TACC << 8) + \ + (B5_TCOH << 6) + (B5_TAH << 4) + (B5_TACP << 2) + \ + B5_PMC) + +#define B6_MT 0x3 /* SDRAM */ +#define B6_TRCD 0x2 +#define B6_SCAN 0x1 /* 9bit */ +#define BANKCON6_VAL ((B6_MT << 15) + (B6_TRCD << 2) + B6_SCAN) + +#define B7_MT 0x3 /* SDRAM */ +#define B7_TRCD 0x2 /* 4clk */ +#define B7_SCAN 0x1 /* 9bit */ +#define BANKCON7_VAL ((B7_MT << 15) + (B7_TRCD << 2) + B7_SCAN) + +/* REFRESH parameter */ +#define REFEN 0x1 /* Refresh enable */ +#define TREFMD 0x0 /* CBR(CAS before RAS)/Auto refresh */ +#define TRP 0x0 /* 2clk */ +#define TRC 0x3 /* 7clk */ +#define TCHR 0x2 /* 3clk */ +#define REFCNT 1259 +#define REFRESH_VAL ((REFEN << 23) + (TREFMD << 22) + (TRP << 20) + \ + (TRC << 18) + (TCHR << 16) + REFCNT) + +/* BANKSIZE parameter */ +#define BURST_EN 1 /* Enable burst mode */ +#define SCKE_EN 1 /* Enable SDRAM power-down mode */ +#define SCLK_EN 1 /* SCLK is active only during the access */ +#define BK67MAP 2 /* 128M/128M */ +#define BANKSIZE_VAL ((BURST_EN << 7) + (SCKE_EN << 5) + \ + (SCLK_EN << 4) + BK67MAP) + +/* MRSRB6 parameter */ +#define WBL6 0 /* Burst */ +#define TM6 0 /* Modem register set */ +#define CL6 3 /* Latency is 3 clocks */ +#define BT6 0 /* Sequential */ +#define BL6 0 +#define MRSRB6_VAL ((WBL6 << 9) + (TM6 << 7) + (CL6 << 4) + \ + (BT6 << 3) + BL6) + +/* MRSRB7 parameter */ +#define WBL7 0 /* Burst */ +#define TM7 0 /* Modem register set */ +#define CL7 3 /* Latency is 3 clocks */ +#define BT7 0 /* Sequential */ +#define BL7 0 +#define MRSRB7_VAL ((WBL7 << 9) + (TM7 << 7) + (CL7 << 4) + \ + (BT7 << 3) + BL7) + +/**************************************/ + +_TEXT_BASE: + .word TEXT_BASE + +.globl lowlevel_init +lowlevel_init: + /* memory control configuration */ + /* make r0 relative the current location so that it */ + /* reads SMRDATA out of FLASH rather than memory ! */ + ldr r0, =SMRDATA + ldr r1, _TEXT_BASE + sub r0, r0, r1 + ldr r1, =BWSCON /* Bus Width Status Controller */ + add r2, r0, #13*4 +0: + ldr r3, [r0], #4 + str r3, [r1], #4 + cmp r2, r0 + bne 0b + + /* everything is fine now */ + mov pc, lr + + .ltorg +/* the literal pools origin */ + +SMRDATA: + .word BWSCON_VAL + .word BANKCON0_VAL + .word BANKCON1_VAL + .word BANKCON2_VAL + .word BANKCON3_VAL + .word BANKCON4_VAL + .word BANKCON5_VAL + .word BANKCON6_VAL + .word BANKCON7_VAL + .word REFRESH_VAL + .word BANKSIZE_VAL + .word MRSRB6_VAL + .word MRSRB7_VAL diff --git a/board/embest/sbc2440ii/sbc2440ii.c b/board/embest/sbc2440ii/sbc2440ii.c new file mode 100644 index 0000000..e0432d5 --- /dev/null +++ b/board/embest/sbc2440ii/sbc2440ii.c @@ -0,0 +1,127 @@ +/* + * (C) Copyright 2002 + * Sysgo Real-Time Solutions, GmbH <www.elinos.com> + * Marius Groeger mgroeger@sysgo.de + * + * (C) Copyright 2002 + * David Mueller, ELSOFT AG, d.mueller@elsoft.ch + * + * (C) Copyright 2005 + * JinHua Luo, GuangDong Linux Center, luo.jinhua@gd-linux.com + * + * Modified for the Embest SBC2440-II by + * (C) Copyright 2009 + * Kevin Morfitt, Fearnside Systems Ltd, kevin.morfitt@fearnside-systems.co.uk + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <s3c2440.h> + +DECLARE_GLOBAL_DATA_PTR; + +/* Configure the PLLs for MPLL = 400MHz, UPLL = 48MHz + The clock frequency ratios are set to 1:4:8 ie: + PCLK = 50MHz + HCLK = 100MHz + FCLK = 400MHz + */ +/* The MPLL values. */ +#define M_MDIV 0x5C +#define M_PDIV 1 +#define M_SDIV 1 + +/* The UPLL values. */ +#define U_MDIV 0x38 +#define U_PDIV 2 +#define U_SDIV 2 + +/* + * Miscellaneous platform dependent initialisations + */ + +static inline void pll_settle_delay(unsigned long loops) +{ + __asm__ volatile ("1:\n" + "subs %0, %1, #1\n" + "bne 1b" : "=r" (loops) : "0" (loops)); +} + +int board_init(void) +{ + S3C24X0_CLOCK_POWER * const clk_power = S3C24X0_GetBase_CLOCK_POWER(); + S3C24X0_GPIO * const gpio = S3C24X0_GetBase_GPIO(); + + /* to reduce PLL lock time, adjust the LOCKTIME register */ + clk_power->LOCKTIME = 0xFFFFFFFF; + + /* configure UPLL */ + clk_power->UPLLCON = ((U_MDIV << 12) + (U_PDIV << 4) + U_SDIV); + + /* some delay between UPLL and MPLL */ + pll_settle_delay(8000); + + /* configure MPLL */ + clk_power->MPLLCON = ((M_MDIV << 12) + (M_PDIV << 4) + M_SDIV); + + /* configure the GPIO */ + gpio->GPACON = 0x007FFFFF; + gpio->GPBCON = 0x00055555; + gpio->GPBUP = 0x000007FF; + gpio->GPBDAT = 0x000001C0; /* Switch on LED1. */ + gpio->GPCCON = 0xAAAAAAAA; + gpio->GPCUP = 0x0000FFFF; + gpio->GPDCON = 0xAAAAAAAA; + gpio->GPDUP = 0x0000FFFF; + gpio->GPECON = 0xAAAAA800; + gpio->GPEUP = 0x00001FFF; + gpio->GPFCON = 0x000055AA; + gpio->GPFUP = 0x000000FF; + gpio->GPGCON = 0xFD95FFBA; + gpio->GPGUP = 0x0000FFFF; + gpio->GPHCON = 0x0002FAAA; + gpio->GPHUP = 0x000007FF; + gpio->GPJCON = 0x02FAAAAA; + gpio->GPJUP = 0x00001FFF; + + gpio->EXTINT0 = 0x22222222; + gpio->EXTINT1 = 0x22222222; + gpio->EXTINT2 = 0x22222222; + gpio->EINTMASK = 0x00FFFFF0; + + /* arch number of SBC2440-II Board */ + gd->bd->bi_arch_number = MACH_TYPE_SBC2440II; + + /* adress of boot parameters */ + gd->bd->bi_boot_params = 0x30000100; + + icache_enable(); + dcache_enable(); + + return 0; +} + +int dram_init(void) +{ + gd->bd->bi_dram[0].start = PHYS_SDRAM_1; + gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE; + + return 0; +} diff --git a/board/embest/sbc2440ii/u-boot.lds b/board/embest/sbc2440ii/u-boot.lds new file mode 100644 index 0000000..3b79776 --- /dev/null +++ b/board/embest/sbc2440ii/u-boot.lds @@ -0,0 +1,56 @@ +/* + * (C) Copyright 2002 + * Gary Jennejohn, DENX Software Engineering, gj@denx.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") +/*OUTPUT_FORMAT("elf32-arm", "elf32-arm", "elf32-arm")*/ +OUTPUT_ARCH(arm) +ENTRY(_start) +SECTIONS +{ + . = 0x00000000; + + . = ALIGN(4); + .text : + { + cpu/arm920t/start.o (.text) + *(.text) + } + + . = ALIGN(4); + .rodata : { *(.rodata) } + + . = ALIGN(4); + .data : { *(.data) } + + . = ALIGN(4); + .got : { *(.got) } + + __u_boot_cmd_start = .; + .u_boot_cmd : { *(.u_boot_cmd) } + __u_boot_cmd_end = .; + + . = ALIGN(4); + __bss_start = .; + .bss (NOLOAD) : { *(.bss) } + _end = .; +} diff --git a/common/serial.c b/common/serial.c index 09385d0..fe8799c 100644 --- a/common/serial.c +++ b/common/serial.c @@ -58,7 +58,7 @@ struct serial_device *__default_serial_console (void) #else return &serial0_device; #endif -#elif defined(CONFIG_S3C2410) +#elif defined(CONFIG_S3C2410) || defined(CONFIG_S3C2440) #if defined(CONFIG_SERIAL1) return &s3c24xx_serial0_device; #elif defined(CONFIG_SERIAL2) @@ -131,7 +131,7 @@ void serial_initialize (void) #if defined (CONFIG_STUART) serial_register(&serial_stuart_device); #endif -#if defined(CONFIG_S3C2410) +#if defined(CONFIG_S3C2410) || defined(CONFIG_S3C2440) serial_register(&s3c24xx_serial0_device); serial_register(&s3c24xx_serial1_device); serial_register(&s3c24xx_serial2_device); diff --git a/cpu/arm920t/s3c24x0/speed.c b/cpu/arm920t/s3c24x0/speed.c index e0dca62..064e22e 100644 --- a/cpu/arm920t/s3c24x0/speed.c +++ b/cpu/arm920t/s3c24x0/speed.c @@ -30,12 +30,15 @@ */
#include <common.h> -#if defined(CONFIG_S3C2400) || defined (CONFIG_S3C2410) || defined (CONFIG_TRAB) +#if defined(CONFIG_S3C2400) || defined(CONFIG_S3C2410) || \ + defined(CONFIG_S3C2440) || defined(CONFIG_TRAB)
#if defined(CONFIG_S3C2400) #include <s3c2400.h> #elif defined(CONFIG_S3C2410) #include <s3c2410.h> +#elif defined(CONFIG_S3C2440) +#include <s3c2440.h> #endif
#define MPLL 0 @@ -53,49 +56,81 @@
static ulong get_PLLCLK(int pllreg) { - S3C24X0_CLOCK_POWER * const clk_power = S3C24X0_GetBase_CLOCK_POWER(); - ulong r, m, p, s; - - if (pllreg == MPLL) - r = clk_power->MPLLCON; - else if (pllreg == UPLL) - r = clk_power->UPLLCON; - else - hang(); - - m = ((r & 0xFF000) >> 12) + 8; - p = ((r & 0x003F0) >> 4) + 2; - s = r & 0x3; - - return((CONFIG_SYS_CLK_FREQ * m) / (p << s)); + S3C24X0_CLOCK_POWER * const clk_power = S3C24X0_GetBase_CLOCK_POWER(); + ulong r, m, p, s; + + if (pllreg == MPLL) + r = clk_power->MPLLCON; + else if (pllreg == UPLL) + r = clk_power->UPLLCON; + else + hang(); + + m = ((r & 0xFF000) >> 12) + 8; + p = ((r & 0x003F0) >> 4) + 2; + s = r & 0x3; + +#ifdef CONFIG_S3C2440 + if (pllreg == MPLL) + return (2 * CONFIG_SYS_CLK_FREQ * m) / (p << s); + else + return (CONFIG_SYS_CLK_FREQ * m) / (p << s); +#else + return (CONFIG_SYS_CLK_FREQ * m) / (p << s); +#endif }
/* return FCLK frequency */ ulong get_FCLK(void) { - return(get_PLLCLK(MPLL)); + return get_PLLCLK(MPLL); }
/* return HCLK frequency */ ulong get_HCLK(void) { - S3C24X0_CLOCK_POWER * const clk_power = S3C24X0_GetBase_CLOCK_POWER(); - - return((clk_power->CLKDIVN & 0x2) ? get_FCLK()/2 : get_FCLK()); + S3C24X0_CLOCK_POWER * const clk_power = S3C24X0_GetBase_CLOCK_POWER(); + +#ifdef CONFIG_S3C2440 + switch (clk_power->CLKDIVN & 0x6) { + default: + case 0: + return get_FCLK(); + case 2: + return get_FCLK()/2; + case 4: + return (clk_power->CAMDIVN & (1<<9)) ? + get_FCLK()/8 : get_FCLK()/4; + case 6: + return (clk_power->CAMDIVN & (1<<8)) ? + get_FCLK()/6 : get_FCLK()/3; + } +#else + return (clk_power->CLKDIVN & 0x2) ? + get_FCLK()/2 : get_FCLK(); +#endif }
/* return PCLK frequency */ ulong get_PCLK(void) { - S3C24X0_CLOCK_POWER * const clk_power = S3C24X0_GetBase_CLOCK_POWER(); + S3C24X0_CLOCK_POWER * const clk_power = S3C24X0_GetBase_CLOCK_POWER();
- return((clk_power->CLKDIVN & 0x1) ? get_HCLK()/2 : get_HCLK()); + return (clk_power->CLKDIVN & 0x1) ? get_HCLK()/2 : get_HCLK(); }
/* return UCLK frequency */ ulong get_UCLK(void) { - return(get_PLLCLK(UPLL)); +#ifdef CONFIG_S3C2440 + S3C24X0_CLOCK_POWER * const clk_power = S3C24X0_GetBase_CLOCK_POWER(); + + return (clk_power->CLKDIVN & (1<<3)) ? + get_PLLCLK(UPLL)/2 : get_PLLCLK(UPLL); +#else + return get_PLLCLK(UPLL); +#endif }
-#endif /* defined(CONFIG_S3C2400) || defined (CONFIG_S3C2410) || defined (CONFIG_TRAB) */ +#endif /* defined(CONFIG_S3C2400) || defined (CONFIG_S3C2410) || \ + defined (CONFIG_S3C2440) || defined (CONFIG_TRAB) */ diff --git a/cpu/arm920t/s3c24x0/timer.c b/cpu/arm920t/s3c24x0/timer.c index f0a09cd..134d644 100644 --- a/cpu/arm920t/s3c24x0/timer.c +++ b/cpu/arm920t/s3c24x0/timer.c @@ -30,12 +30,15 @@ */
int timer_load_val = 0; @@ -177,6 +180,7 @@ ulong get_tbclk (void) tbclk = timer_load_val * 100; #elif defined(CONFIG_SBC2410X) || \ defined(CONFIG_SMDK2410) || \ + defined(CONFIG_SBC2440II) || \ defined(CONFIG_VCMA9) tbclk = CONFIG_SYS_HZ; #else diff --git a/cpu/arm920t/s3c24x0/usb.c b/cpu/arm920t/s3c24x0/usb.c index 9ccf575..962ef0d 100644 --- a/cpu/arm920t/s3c24x0/usb.c +++ b/cpu/arm920t/s3c24x0/usb.c @@ -24,12 +24,16 @@ #include <common.h>
#if defined(CONFIG_USB_OHCI_NEW) && defined(CONFIG_SYS_USB_OHCI_CPU_INIT) -# if defined(CONFIG_S3C2400) || defined(CONFIG_S3C2410) +# if defined(CONFIG_S3C2400) || \ + defined(CONFIG_S3C2410) || \ + defined(CONFIG_S3C2440)
#if defined(CONFIG_S3C2400) # include <s3c2400.h> #elif defined(CONFIG_S3C2410) # include <s3c2410.h> +#elif defined(CONFIG_S3C2440) +#include <s3c2440.h> #endif
int usb_cpu_init (void) diff --git a/cpu/arm920t/s3c24x0/usb_ohci.c b/cpu/arm920t/s3c24x0/usb_ohci.c index 7838014..6a46eed 100644 --- a/cpu/arm920t/s3c24x0/usb_ohci.c +++ b/cpu/arm920t/s3c24x0/usb_ohci.c @@ -42,6 +42,8 @@ #include <s3c2400.h> #elif defined(CONFIG_S3C2410) #include <s3c2410.h> +#elif defined(CONFIG_S3C2440) +#include <s3c2440.h> #endif
#include <malloc.h> diff --git a/cpu/arm920t/start.S b/cpu/arm920t/start.S index 475cdaf..7e9e6f8 100644 --- a/cpu/arm920t/start.S +++ b/cpu/arm920t/start.S @@ -132,20 +132,30 @@ copyex: bne copyex #endif
-#if defined(CONFIG_S3C2400) || defined(CONFIG_S3C2410) +#if defined(CONFIG_S3C2400) || \ + defined(CONFIG_S3C2410) || \ + defined(CONFIG_S3C2440) /* turn off the watchdog */
# if defined(CONFIG_S3C2400) -# define pWTCON 0x15300000 -# define INTMSK 0x14400008 /* Interupt-Controller base addresses */ +# define pWTCON 0x15300000 +# define INTMSK 0x14400008 /* Interupt-Controller base addresses */ # define CLKDIVN 0x14800014 /* clock divisor register */ #else -# define pWTCON 0x53000000 -# define INTMSK 0x4A000008 /* Interupt-Controller base addresses */ +# define pWTCON 0x53000000 +# define INTMSK 0x4A000008 /* Interupt-Controller base addresses */ # define INTSUBMSK 0x4A00001C # define CLKDIVN 0x4C000014 /* clock divisor register */ # endif
+# if defined(CONFIG_S3C2440) +# define INTSMASK 0xffff +# define CLKDIVVAL 0x5 +#else +# define INTSMASK 0x3ff +# define CLKDIVVAL 0x3 +# endif + ldr r0, =pWTCON mov r1, #0x0 str r1, [r0] @@ -156,8 +166,8 @@ copyex: mov r1, #0xffffffff ldr r0, =INTMSK str r1, [r0] -# if defined(CONFIG_S3C2410) - ldr r1, =0x3ff +# if defined(CONFIG_S3C2410) || defined(CONFIG_S3C2440) + ldr r1, =INTSMASK ldr r0, =INTSUBMSK str r1, [r0] # endif @@ -165,9 +175,16 @@ copyex: /* FCLK:HCLK:PCLK = 1:2:4 */ /* default FCLK is 120 MHz ! */ ldr r0, =CLKDIVN - mov r1, #3 + mov r1, #CLKDIVVAL str r1, [r0] -#endif /* CONFIG_S3C2400 || CONFIG_S3C2410 */ + +#ifdef CONFIG_S3C2440 + /* Set asynchronous bus mode */ + mrc p15, 0, r1, c1, c0, 0 /* read ctrl register */ + orr r1, r1, #0xc0000000 /* Asynchronous */ + mcr p15, 0, r1, c1, c0, 0 /* write ctrl register */ +#endif /* CONFIG_S3C2440 */ +#endif /* CONFIG_S3C2400 || CONFIG_S3C2410 || CONFIG_S3C2440 */
/* * we do sys-critical inits only at reboot, diff --git a/drivers/i2c/s3c24x0_i2c.c b/drivers/i2c/s3c24x0_i2c.c index f0c1aa3..28bf314 100644 --- a/drivers/i2c/s3c24x0_i2c.c +++ b/drivers/i2c/s3c24x0_i2c.c @@ -31,6 +31,8 @@ #include <s3c2400.h> #elif defined(CONFIG_S3C2410) #include <s3c2410.h> +#elif defined(CONFIG_S3C2440) +#include <s3c2440.h> #endif #include <i2c.h>
@@ -66,6 +68,9 @@ static int GetI2CSDA(void) #ifdef CONFIG_S3C2400 return (gpio->PGDAT & 0x0020) >> 5; #endif +#ifdef CONFIG_S3C2440 + return (gpio->GPEDAT & 0x8000) >> 15; +#endif }
#if 0 @@ -85,6 +90,9 @@ static void SetI2CSCL(int x) #ifdef CONFIG_S3C2400 gpio->PGDAT = (gpio->PGDAT & ~0x0040) | (x&1) << 6; #endif +#ifdef CONFIG_S3C2440 + gpio->GPEDAT = (gpio->GPEDAT & ~0x4000) | (x&1) << 14; +#endif }
@@ -142,6 +150,9 @@ void i2c_init (int speed, int slaveadd) #ifdef CONFIG_S3C2400 ulong old_gpecon = gpio->PGCON; #endif +#ifdef CONFIG_S3C2440 + ulong old_gpecon = gpio->GPECON; +#endif /* bus still busy probably by (most) previously interrupted transfer */
#ifdef CONFIG_S3C2410 @@ -152,6 +163,10 @@ void i2c_init (int speed, int slaveadd) /* set I2CSDA and I2CSCL (PG5, PG6) to GPIO */ gpio->PGCON = (gpio->PGCON & ~0x00003c00) | 0x00001000; #endif +#ifdef CONFIG_S3C2440 + /* set I2CSDA and I2CSCL (GPE15, GPE14) to GPIO */ + gpio->GPECON = (gpio->GPECON & ~0xF0000000) | 0x10000000; +#endif
/* toggle I2CSCL until bus idle */ SetI2CSCL (0); @@ -174,6 +189,9 @@ void i2c_init (int speed, int slaveadd) #ifdef CONFIG_S3C2400 gpio->PGCON = old_gpecon; #endif +#ifdef CONFIG_S3C2440 + gpio->GPECON = old_gpecon; +#endif }
/* calculate prescaler and divisor values */ diff --git a/drivers/mtd/nand/Makefile b/drivers/mtd/nand/Makefile index 471cd6b..190abeb 100644 --- a/drivers/mtd/nand/Makefile +++ b/drivers/mtd/nand/Makefile @@ -41,7 +41,7 @@ COBJS-$(CONFIG_NAND_DAVINCI) += davinci_nand.o COBJS-$(CONFIG_NAND_FSL_ELBC) += fsl_elbc_nand.o COBJS-$(CONFIG_NAND_FSL_UPM) += fsl_upm.o COBJS-$(CONFIG_NAND_NOMADIK) += nomadik.o -COBJS-$(CONFIG_NAND_S3C2410) += s3c2410_nand.c +COBJS-$(CONFIG_NAND_S3C2410) += s3c2410_nand.o COBJS-$(CONFIG_NAND_S3C64XX) += s3c64xx.o COBJS-$(CONFIG_NAND_OMAP_GPMC) += omap_gpmc.o endif diff --git a/drivers/mtd/nand/s3c2410_nand.c b/drivers/mtd/nand/s3c2410_nand.c index d27a625..8438a89 100644 --- a/drivers/mtd/nand/s3c2410_nand.c +++ b/drivers/mtd/nand/s3c2410_nand.c @@ -20,46 +20,93 @@
#include <common.h>
-#if 0 -#define DEBUGN printf +#include <nand.h> +#ifndef CONFIG_S3C2440 + #include <s3c2410.h> #else -#define DEBUGN(x, args ...) {} + #include <s3c2440.h> #endif - -#include <nand.h> -#include <s3c2410.h> #include <asm/io.h>
#define __REGb(x) (*(volatile unsigned char *)(x)) #define __REGi(x) (*(volatile unsigned int *)(x)) +#define __REGl(x) (*(volatile unsigned long *)(x))
#define NF_BASE 0x4e000000 #define NFCONF __REGi(NF_BASE + 0x0) -#define NFCMD __REGb(NF_BASE + 0x4) -#define NFADDR __REGb(NF_BASE + 0x8) -#define NFDATA __REGb(NF_BASE + 0xc) -#define NFSTAT __REGb(NF_BASE + 0x10) -#define NFECC0 __REGb(NF_BASE + 0x14) -#define NFECC1 __REGb(NF_BASE + 0x15) -#define NFECC2 __REGb(NF_BASE + 0x16) - -#define S3C2410_NFCONF_EN (1<<15) -#define S3C2410_NFCONF_512BYTE (1<<14) -#define S3C2410_NFCONF_4STEP (1<<13) -#define S3C2410_NFCONF_INITECC (1<<12) -#define S3C2410_NFCONF_nFCE (1<<11) -#define S3C2410_NFCONF_TACLS(x) ((x)<<8) -#define S3C2410_NFCONF_TWRPH0(x) ((x)<<4) -#define S3C2410_NFCONF_TWRPH1(x) ((x)<<0) + +#ifdef CONFIG_S3C2440 + #define NFCONT __REGb(NF_BASE + 0x4) + #define NFCMD __REGb(NF_BASE + 0x8) + #define NFADDR __REGb(NF_BASE + 0xc) + #define NFDATA __REGb(NF_BASE + 0x10) + #define NFSTAT __REGb(NF_BASE + 0x20) + #define NFMECC0 __REGl(NF_BASE + 0x2c) + + #define S3C2440_NFCONT_EN (1<<0) + #define S3C2440_NFCONT_nFCE (1<<1) + #define S3C2440_NFCONT_INITECC (1<<4) + #define S3C2440_NFCONT_MAINECCLOCK (1<<5) + #define S3C2440_NFCONT_SPAREECCLOCK (1<<6) + #define S3C2440_NFCONT_RNBMODE (1<<8) + #define S3C2440_NFCONT_RNBINT (1<<9) + #define S3C2440_NFCONT_ILLEGALINT (1<<10) + #define S3C2440_NFCONT_SOFTLOCK (1<<12) + #define S3C2440_NFCONT_LOCKTIGHT (1<<13) + + #define S3C2440_NFCONF_TACLS(x) ((x)<<12) + #define S3C2440_NFCONF_TWRPH0(x) ((x)<<8) + #define S3C2440_NFCONF_TWRPH1(x) ((x)<<4) +#else + #define NFCMD __REGb(NF_BASE + 0x4) + #define NFADDR __REGb(NF_BASE + 0x8) + #define NFDATA __REGb(NF_BASE + 0xc) + #define NFSTAT __REGb(NF_BASE + 0x10) + #define NFECC0 __REGb(NF_BASE + 0x14) + #define NFECC1 __REGb(NF_BASE + 0x15) + #define NFECC2 __REGb(NF_BASE + 0x16) + + #define S3C2410_NFCONF_EN (1<<15) + #define S3C2410_NFCONF_512BYTE (1<<14) + #define S3C2410_NFCONF_4STEP (1<<13) + #define S3C2410_NFCONF_INITECC (1<<12) + #define S3C2410_NFCONF_nFCE (1<<11) + #define S3C2410_NFCONF_TACLS(x) ((x)<<8) + #define S3C2410_NFCONF_TWRPH0(x) ((x)<<4) + #define S3C2410_NFCONF_TWRPH1(x) ((x)<<0) +#endif
#define S3C2410_ADDR_NALE 4 #define S3C2410_ADDR_NCLE 8
+ +#ifdef CONFIG_S3C2410_NAND_HWECC +/* new oob placement block for use with hardware ecc generation + */ +static struct nand_ecclayout nand_hw_eccoob = { + .eccbytes = 3, + .eccpos = {0, 1, 2}, + .oobfree = { {8, 8} } +}; +#endif + +static void s3c2410_nand_select_chip(struct mtd_info *mtd, int chip) +{ + if (chip == -1) { + debugX(1, "Negating nFCE\n"); + NFCONT |= S3C2440_NFCONT_nFCE; + } else { + debugX(1, "Asserting nFCE\n"); + NFCONT &= ~S3C2440_NFCONT_nFCE; + } +} + +#ifndef CONFIG_S3C2440 static void s3c2410_hwcontrol(struct mtd_info *mtd, int cmd, unsigned int ctrl) { struct nand_chip *chip = mtd->priv;
- DEBUGN("hwcontrol(): 0x%02x 0x%02x\n", cmd, ctrl); + debugX(1, "hwcontrol(): 0x%02x 0x%02x\n", cmd, ctrl);
if (ctrl & NAND_CTRL_CHANGE) { ulong IO_ADDR_W = NF_BASE; @@ -80,27 +127,58 @@ static void s3c2410_hwcontrol(struct mtd_info *mtd, int cmd, unsigned int ctrl) if (cmd != NAND_CMD_NONE) writeb(cmd, chip->IO_ADDR_W); } +#else +static void s3c2410_hwcontrol(struct mtd_info *mtd, int cmd, unsigned int ctrl) +{ + debugX(1, "hwcontrol(): 0x%02x 0x%02x\n", cmd, ctrl); + + if (cmd == NAND_CMD_NONE) + return; + + if (ctrl & NAND_CLE) { + debugX(1, "NFCMD = 0x%08X\n", cmd); + NFCMD = cmd; + } + + if (ctrl & NAND_ALE) { + debugX(1, "NFADDR = 0x%08X\n", cmd); + NFADDR = cmd; + } +} +#endif
static int s3c2410_dev_ready(struct mtd_info *mtd) { - DEBUGN("dev_ready\n"); + debugX(1, "dev_ready\n"); return (NFSTAT & 0x01); }
#ifdef CONFIG_S3C2410_NAND_HWECC void s3c2410_nand_enable_hwecc(struct mtd_info *mtd, int mode) { - DEBUGN("s3c2410_nand_enable_hwecc(%p, %d)\n", mtd, mode); + debugX(2, "s3c2410_nand_enable_hwecc(%p, %d)\n", mtd, mode); +#ifndef CONFIG_S3C2440 NFCONF |= S3C2410_NFCONF_INITECC; +#else + NFCONT |= S3C2440_NFCONT_INITECC; +#endif }
static int s3c2410_nand_calculate_ecc(struct mtd_info *mtd, const u_char *dat, u_char *ecc_code) { +#ifndef CONFIG_S3C2440 ecc_code[0] = NFECC0; ecc_code[1] = NFECC1; ecc_code[2] = NFECC2; - DEBUGN("s3c2410_nand_calculate_hwecc(%p,): 0x%02x 0x%02x 0x%02x\n", +#else + unsigned long ecc = NFMECC0; + + ecc_code[0] = ecc; + ecc_code[1] = ecc >> 8; + ecc_code[2] = ecc >> 16; +#endif + debugX(2, "s3c2410_nand_calculate_hwecc(%p,): 0x%02x 0x%02x 0x%02x\n", mtd , ecc_code[0], ecc_code[1], ecc_code[2]);
return 0; @@ -109,12 +187,53 @@ static int s3c2410_nand_calculate_ecc(struct mtd_info *mtd, const u_char *dat, static int s3c2410_nand_correct_data(struct mtd_info *mtd, u_char *dat, u_char *read_ecc, u_char *calc_ecc) { - if (read_ecc[0] == calc_ecc[0] && - read_ecc[1] == calc_ecc[1] && - read_ecc[2] == calc_ecc[2]) - return 0; + unsigned int diff0, diff1, diff2; + unsigned int bit, byte; + + debugX(2, "s3c2410_nand_correct_data:\n"); + + diff0 = read_ecc[0] ^ calc_ecc[0]; + diff1 = read_ecc[1] ^ calc_ecc[1]; + diff2 = read_ecc[2] ^ calc_ecc[2]; + + debugX(3, "rd %02x%02x%02x calc %02x%02x%02x diff %02x%02x%02x\n", + read_ecc[0], read_ecc[1], read_ecc[2], + calc_ecc[0], calc_ecc[1], calc_ecc[2], + diff0, diff1, diff2); + + if (diff0 == 0 && diff1 == 0 && diff2 == 0) + return 0; /* ECC is ok */ + + /* Can we correct this ECC (ie, one row and column change). + * Note, this is similar to the 256 error code on smartmedia */ + + if (((diff0 ^ (diff0 >> 1)) & 0x55) == 0x55 && + ((diff1 ^ (diff1 >> 1)) & 0x55) == 0x55 && + ((diff2 ^ (diff2 >> 1)) & 0x55) == 0x55) { + /* calculate the bit position of the error */ + + bit = ((diff2 >> 3) & 1) | + ((diff2 >> 4) & 2) | + ((diff2 >> 5) & 4); + + /* calculate the byte position of the error */ + byte = ((diff2 << 7) & 0x100) | + ((diff1 << 0) & 0x80) | + ((diff1 << 1) & 0x40) | + ((diff1 << 2) & 0x20) | + ((diff1 << 3) & 0x10) | + ((diff0 >> 4) & 0x08) | + ((diff0 >> 3) & 0x04) | + ((diff0 >> 2) & 0x02) | + ((diff0 >> 1) & 0x01); + + debugX(2, "correcting error bit %d, byte %d\n", bit, byte); + + dat[byte] ^= (1 << bit); + return 1; + }
- printf("s3c2410_nand_correct_data: not implemented\n"); + debugX(2, "Failed to correct ECC error\n"); return -1; } #endif @@ -125,11 +244,12 @@ int board_nand_init(struct nand_chip *nand) u_int8_t tacls, twrph0, twrph1; S3C24X0_CLOCK_POWER * const clk_power = S3C24X0_GetBase_CLOCK_POWER();
- DEBUGN("board_nand_init()\n"); + debugX(1, "board_nand_init()\n");
clk_power->CLKCON |= (1 << 4);
/* initialize hardware */ +#ifndef CONFIG_S3C2440 twrph0 = 3; twrph1 = 0; tacls = 0;
cfg = S3C2410_NFCONF_EN; @@ -141,20 +261,49 @@ int board_nand_init(struct nand_chip *nand)
/* initialize nand_chip data structure */ nand->IO_ADDR_R = nand->IO_ADDR_W = (void *)0x4e00000c; +#else + twrph0 = 3; twrph1 = 1; tacls = 0; + + cfg = S3C2440_NFCONF_TACLS(tacls); + cfg |= S3C2440_NFCONF_TWRPH0(twrph0); + cfg |= S3C2440_NFCONF_TWRPH1(twrph1); + NFCONF = cfg; + + cfg = S3C2440_NFCONT_EN; + cfg |= S3C2440_NFCONT_nFCE; + NFCONT = cfg; + + /* initialize nand_chip data structure */ + nand->IO_ADDR_R = nand->IO_ADDR_W = (void *)0x4e000010; +#endif
/* read_buf and write_buf are default */ /* read_byte and write_byte are default */
+ nand->select_chip = s3c2410_nand_select_chip; + nand->chip_delay = 50; + /* hwcontrol always must be implemented */ nand->cmd_ctrl = s3c2410_hwcontrol;
nand->dev_ready = s3c2410_dev_ready;
#ifdef CONFIG_S3C2410_NAND_HWECC - nand->ecc.hwctl = s3c2410_nand_enable_hwecc; - nand->ecc.calculate = s3c2410_nand_calculate_ecc; - nand->ecc.correct = s3c2410_nand_correct_data; - nand->ecc.mode = NAND_ECC_HW3_512; + nand->ecc.correct = s3c2410_nand_correct_data; + nand->ecc.hwctl = s3c2410_nand_enable_hwecc; + nand->ecc.calculate = s3c2410_nand_calculate_ecc; + nand->ecc.mode = NAND_ECC_HW; + /* change the behaviour depending on whether we are using + * the large or small page nand device */ + if (nand->page_shift > 10) { + nand->ecc.size = 256; + nand->ecc.bytes = 3; + } else { + nand->ecc.size = 512; + nand->ecc.bytes = 3; + nand->ecc.layout = &nand_hw_eccoob; + } + debugX(2, "ecc: size: %d bytes: %d\n", nand->ecc.size, nand->ecc.bytes); #else nand->ecc.mode = NAND_ECC_SOFT; #endif @@ -165,7 +314,7 @@ int board_nand_init(struct nand_chip *nand) nand->options = 0; #endif
- DEBUGN("end of nand_init\n"); + debugX(1, "end of nand_init\n");
return 0; } diff --git a/drivers/rtc/s3c24x0_rtc.c b/drivers/rtc/s3c24x0_rtc.c index 0d3372f..8f7559b 100644 --- a/drivers/rtc/s3c24x0_rtc.c +++ b/drivers/rtc/s3c24x0_rtc.c @@ -34,6 +34,8 @@ #include <s3c2400.h> #elif defined(CONFIG_S3C2410) #include <s3c2410.h> +#elif defined(CONFIG_S3C2440) +#include <s3c2440.h> #endif
#include <rtc.h> diff --git a/drivers/serial/serial_s3c24x0.c b/drivers/serial/serial_s3c24x0.c index 6d69c43..52d5895 100644 --- a/drivers/serial/serial_s3c24x0.c +++ b/drivers/serial/serial_s3c24x0.c @@ -23,6 +23,8 @@ #include <s3c2400.h> #elif defined(CONFIG_S3C2410) #include <s3c2410.h> +#elif defined(CONFIG_S3C2440) +#include <s3c2440.h> #endif
DECLARE_GLOBAL_DATA_PTR; diff --git a/include/common.h b/include/common.h index 30fff7d..161277f 100644 --- a/include/common.h +++ b/include/common.h @@ -490,7 +490,8 @@ ulong get_OPB_freq (void); ulong get_PCI_freq (void); #endif #if defined(CONFIG_S3C2400) || defined(CONFIG_S3C2410) || \ - defined(CONFIG_LH7A40X) || defined(CONFIG_S3C6400) + defined(CONFIG_LH7A40X) || defined(CONFIG_S3C6400) || \ + defined(CONFIG_S3C2440) void s3c2410_irq(void); #define ARM920_IRQ_CALLBACK s3c2410_irq ulong get_FCLK (void); diff --git a/include/configs/sbc2440ii.h b/include/configs/sbc2440ii.h new file mode 100644 index 0000000..a292727 --- /dev/null +++ b/include/configs/sbc2440ii.h @@ -0,0 +1,246 @@ +/* + * (C) Copyright 2002 + * Sysgo Real-Time Solutions, GmbH <www.elinos.com> + * Marius Groeger mgroeger@sysgo.de + * Gary Jennejohn gj@denx.de + * David Mueller d.mueller@elsoft.ch + * + * Modified for the friendly-arm SBC-2410X by + * (C) Copyright 2005 + * JinHua Luo, GuangDong Linux Center, luo.jinhua@gd-linux.com + * + * Modified for the Embest SBC2440-II by + * (C) Copyright 2009 + * Kevin Morfitt, Fearnside Systems Ltd, kevin.morfitt@fearnside-systems.co.uk + * + * Configuation settings for the friendly-arm SBC-2410X board. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + + +#define CONFIG_IDENT_STRING " for Embest SBC2440-II" + +/* + * If we are developing, we might want to start armboot from ram + * so we MUST NOT initialize critical regs like mem-timing ... + */ +#undef CONFIG_SKIP_LOWLEVEL_INIT /* undef for developing */ + +/* + * High Level Configuration Options + * (easy to change) + */ +#define CONFIG_ARM920T 1 /* This is an ARM920T Core */ +#define CONFIG_S3C2440 1 /* in a SAMSUNG S3C2440 SoC */ +#define CONFIG_SBC2440II 1 /* on an Embest SBC-2440-II Board */ + +/* + * input clock of PLL - the SBC2440-II has 12MHz input clock + */ +#define CONFIG_SYS_CLK_FREQ 12000000 + + +#define USE_920T_MMU 1 +#undef CONFIG_USE_IRQ /* we don't need IRQ/FIQ stuff */ + +/* + * Size of malloc() pool + */ +#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128*1024) +/* + * size in bytes reserved for initial data + */ +#define CONFIG_SYS_GBL_DATA_SIZE 128 + +/* + * Hardware drivers + */ +#define CONFIG_DRIVER_CS8900 1 /* we have a CS8900 on-board */ +#define CS8900_BASE 0x19000300 +#define CS8900_BUS16 1 /* the Linux driver does accesses as shorts */ + +/* + * select serial console configuration + */ +#define CONFIG_S3C24X0_SERIAL +#define CONFIG_SERIAL1 1 /* we use SERIAL 1 on SBC2440-II */ + +/************************************************************ + * RTC + ************************************************************/ +#define CONFIG_RTC_S3C24X0 1 + +/* allow to overwrite serial and ethaddr */ +#define CONFIG_ENV_OVERWRITE + +#define CONFIG_BAUDRATE 115200 + + +/* + * BOOTP options + */ +#define CONFIG_BOOTP_BOOTFILESIZE +#define CONFIG_BOOTP_BOOTPATH +#define CONFIG_BOOTP_GATEWAY +#define CONFIG_BOOTP_HOSTNAME + + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_ASKENV +#define CONFIG_CMD_CACHE +#define CONFIG_CMD_DATE +#define CONFIG_CMD_ELF + +#define CONFIG_CMD_PING +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_NAND +#define CONFIG_JFFS2_NAND +#define CONFIG_CMD_MTDPARTS +#define CONFIG_CMD_JFFS2 +#define CONFIG_JFFS2_CMDLINE +#define MTDIDS_DEFAULT "nand0=sbc2440-II-nand" +#define MTDPARTS_DEFAULT \ + "mtdparts=sbc2440-II-nand:2m(kernel),62m(rootfs)" +#define CONFIG_EXTRA_ENV_SETTINGS "autostart=yes" + +#define CONFIG_BOOTDELAY 3 +#define CONFIG_BOOTARGS \ +"noinitrd root=/dev/mtdblock1 rootfstype=jffs2 init=/linuxrc console=ttySAC0" +#define CONFIG_LOADADDR 30008000 +/*#define CONFIG_BOOTFILE "elinos-lart" */ +#define CONFIG_BOOTCOMMAND "nboot 30008000 0 0" +/*#define CONFIG_NFSBOOTCOMMAND NFS_BOOTARGS*/ + +#if defined(CONFIG_CMD_KGDB) +/* + * speed to run kgdb serial port + */ +#define CONFIG_KGDB_BAUDRATE 115200 +/* + * which serial port to use + */ +#define CONFIG_KGDB_SER_INDEX 1 +#endif + +/* + * Miscellaneous configurable options + */ +#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#define CONFIG_SYS_PROMPT "[ SBC2440-II ]# " +#define CONFIG_SYS_CBSIZE 256 +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) +#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE + +#define CONFIG_SYS_MEMTEST_START 0x30000000 +#define CONFIG_SYS_MEMTEST_END 0x33F00000 + +#undef CONFIG_SYS_CLKS_IN_HZ /* everything, incl board info, in Hz */ + +#define CONFIG_SYS_LOAD_ADDR 0x33000000 /* default load address */ + +/* the PWM TImer 4 uses a counter of 15625 for 10 ms, so we need */ +/* it to wrap 100 times (total 1562500) to get 1 sec. */ +#define CONFIG_SYS_HZ 1562500 + +/* valid baudrates */ +#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 } + +/*----------------------------------------------------------------------- + * Stack sizes + * + * The stack sizes are set up in start.S using the settings below + */ +#define CONFIG_STACKSIZE (128*1024) /* regular stack */ +#ifdef CONFIG_USE_IRQ +#define CONFIG_STACKSIZE_IRQ (4*1024) /* IRQ stack */ +#define CONFIG_STACKSIZE_FIQ (4*1024) /* FIQ stack */ +#endif + +/*----------------------------------------------------------------------- + * Physical Memory Map + */ +#define CONFIG_NR_DRAM_BANKS 1 /* we have 1 bank of DRAM */ +#define PHYS_SDRAM_1 0x30000000 /* SDRAM Bank #1 */ +#define PHYS_SDRAM_1_SIZE 0x04000000 /* 64 MB */ + +#define PHYS_FLASH_1 0x00000000 /* Flash Bank #1 */ + +#define CONFIG_SYS_FLASH_BASE PHYS_FLASH_1 +#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE + +/*----------------------------------------------------------------------- + * FLASH and environment and organization + */ + +#define CONFIG_ENV_IS_IN_FLASH 1 +#define CONFIG_ENV_SIZE 0x10000 /* Total Size of Environment Sector */ + +#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* max number of memory banks */ +#define PHYS_FLASH_SIZE 0x00200000 /* 2MB */ +#define CONFIG_SYS_MAX_FLASH_SECT (35) +#define CONFIG_ENV_ADDR \ + (CONFIG_SYS_FLASH_BASE + PHYS_FLASH_SIZE - CONFIG_ENV_SIZE) + +/*----------------------------------------------------------------------- + * FLASH driver setup + */ +#define CONFIG_SYS_FLASH_CFI 1 +#define CONFIG_FLASH_CFI_DRIVER 1 +#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE 1 + +/* timeout values are in ticks */ +#define CONFIG_SYS_FLASH_ERASE_TOUT (20*CONFIG_SYS_HZ) +#define CONFIG_SYS_FLASH_WRITE_TOUT (20*CONFIG_SYS_HZ) + +/*----------------------------------------------------------------------- + * NAND flash settings + */ +#if defined(CONFIG_CMD_NAND) + #define CONFIG_NAND_S3C2410 + #define CONFIG_SYS_NAND_BASE 0x4e00000c + #define CONFIG_SYS_MAX_NAND_DEVICE 1 + #define SECTORSIZE 512 +/* #define CONFIG_S3C2410_NAND_HWECC*/ +#endif /* CONFIG_CMD_NAND */ + +#define CONFIG_SETUP_MEMORY_TAGS +#define CONFIG_INITRD_TAG +#define CONFIG_CMDLINE_TAG + +#define CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " + +#define CONFIG_CMDLINE_EDITING + +#ifdef CONFIG_CMDLINE_EDITING +#undef CONFIG_AUTO_COMPLETE +#else +#define CONFIG_AUTO_COMPLETE +#endif + +#endif /* __CONFIG_H */ diff --git a/include/s3c2440.h b/include/s3c2440.h new file mode 100644 index 0000000..df2eb7a --- /dev/null +++ b/include/s3c2440.h @@ -0,0 +1,231 @@ +/* + * (C) Copyright 2003 + * David Müller ELSOFT AG Switzerland. d.mueller@elsoft.ch + * + * See file CREDITS for list of people who contributed to this + * project. + * + * Modified for the Embest SBC2440-II by + * (C) Copyright 2009 + * Kevin Morfitt, Fearnside Systems Ltd, kevin.morfitt@fearnside-systems.co.uk + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/************************************************ + * NAME : s3c2440.h + * Version : 24.10.2008 + * + * Based on S3C2440X User's manual Rev 1.3 + ************************************************/ + +#ifndef __S3C2440_H__ +#define __S3C2440_H__ + +#define S3C24X0_UART_CHANNELS 3 +#define S3C24X0_SPI_CHANNELS 2 + +/* S3C2410 only supports 512 Byte HW ECC */ +#define S3C2410_ECCSIZE 512 +#define S3C2410_ECCBYTES 3 + +typedef enum { + S3C24X0_UART0, + S3C24X0_UART1, + S3C24X0_UART2 +} S3C24X0_UARTS_NR; + +/* S3C2440 device base addresses */ +#define S3C24X0_MEMCTL_BASE 0x48000000 +#define S3C24X0_USB_HOST_BASE 0x49000000 +#define S3C24X0_INTERRUPT_BASE 0x4A000000 +#define S3C24X0_DMA_BASE 0x4B000000 +#define S3C24X0_CLOCK_POWER_BASE 0x4C000000 +#define S3C24X0_LCD_BASE 0x4D000000 +#define S3C2440_NAND_BASE 0x4E000000 +#define S3C24X0_UART_BASE 0x50000000 +#define S3C24X0_TIMER_BASE 0x51000000 +#define S3C24X0_USB_DEVICE_BASE 0x52000140 +#define S3C24X0_WATCHDOG_BASE 0x53000000 +#define S3C24X0_I2C_BASE 0x54000000 +#define S3C24X0_I2S_BASE 0x55000000 +#define S3C24X0_GPIO_BASE 0x56000000 +#define S3C24X0_RTC_BASE 0x57000000 +#define S3C2410_ADC_BASE 0x58000000 +#define S3C24X0_SPI_BASE 0x59000000 +#define S3C2410_SDI_BASE 0x5A000000 + + +/* include common stuff */ +#include <s3c24x0.h> + + +static inline S3C24X0_MEMCTL *S3C24X0_GetBase_MEMCTL(void) +{ + return (S3C24X0_MEMCTL * const)S3C24X0_MEMCTL_BASE; +} +static inline S3C24X0_USB_HOST *S3C24X0_GetBase_USB_HOST(void) +{ + return (S3C24X0_USB_HOST * const)S3C24X0_USB_HOST_BASE; +} +static inline S3C24X0_INTERRUPT *S3C24X0_GetBase_INTERRUPT(void) +{ + return (S3C24X0_INTERRUPT * const)S3C24X0_INTERRUPT_BASE; +} +static inline S3C24X0_DMAS *S3C24X0_GetBase_DMAS(void) +{ + return (S3C24X0_DMAS * const)S3C24X0_DMA_BASE; +} +static inline S3C24X0_CLOCK_POWER *S3C24X0_GetBase_CLOCK_POWER(void) +{ + return (S3C24X0_CLOCK_POWER * const)S3C24X0_CLOCK_POWER_BASE; +} +static inline S3C24X0_LCD *S3C24X0_GetBase_LCD(void) +{ + return (S3C24X0_LCD * const)S3C24X0_LCD_BASE; +} +static inline S3C2440_NAND *S3C2440_GetBase_NAND(void) +{ + return (S3C2440_NAND * const)S3C2440_NAND_BASE; +} +static inline S3C24X0_UART *S3C24X0_GetBase_UART(S3C24X0_UARTS_NR nr) +{ + return (S3C24X0_UART * const)(S3C24X0_UART_BASE + (nr * 0x4000)); +} +static inline S3C24X0_TIMERS *S3C24X0_GetBase_TIMERS(void) +{ + return (S3C24X0_TIMERS * const)S3C24X0_TIMER_BASE; +} +static inline S3C24X0_USB_DEVICE *S3C24X0_GetBase_USB_DEVICE(void) +{ + return (S3C24X0_USB_DEVICE * const)S3C24X0_USB_DEVICE_BASE; +} +static inline S3C24X0_WATCHDOG *S3C24X0_GetBase_WATCHDOG(void) +{ + return (S3C24X0_WATCHDOG * const)S3C24X0_WATCHDOG_BASE; +} +static inline S3C24X0_I2C *S3C24X0_GetBase_I2C(void) +{ + return (S3C24X0_I2C * const)S3C24X0_I2C_BASE; +} +static inline S3C24X0_I2S *S3C24X0_GetBase_I2S(void) +{ + return (S3C24X0_I2S * const)S3C24X0_I2S_BASE; +} +static inline S3C24X0_GPIO *S3C24X0_GetBase_GPIO(void) +{ + return (S3C24X0_GPIO * const)S3C24X0_GPIO_BASE; +} +static inline S3C24X0_RTC *S3C24X0_GetBase_RTC(void) +{ + return (S3C24X0_RTC * const)S3C24X0_RTC_BASE; +} +static inline S3C2410_ADC *S3C2410_GetBase_ADC(void) +{ + return (S3C2410_ADC * const)S3C2410_ADC_BASE; +} +static inline S3C24X0_SPI *S3C24X0_GetBase_SPI(void) +{ + return (S3C24X0_SPI * const)S3C24X0_SPI_BASE; +} +static inline S3C2410_SDI *S3C2410_GetBase_SDI(void) +{ + return (S3C2410_SDI * const)S3C2410_SDI_BASE; +} + + +/* ISR */ +#define pISR_RESET (*(unsigned *)(_ISR_STARTADDRESS+0x0)) +#define pISR_UNDEF (*(unsigned *)(_ISR_STARTADDRESS+0x4)) +#define pISR_SWI (*(unsigned *)(_ISR_STARTADDRESS+0x8)) +#define pISR_PABORT (*(unsigned *)(_ISR_STARTADDRESS+0xC)) +#define pISR_DABORT (*(unsigned *)(_ISR_STARTADDRESS+0x10)) +#define pISR_RESERVED (*(unsigned *)(_ISR_STARTADDRESS+0x14)) +#define pISR_IRQ (*(unsigned *)(_ISR_STARTADDRESS+0x18)) +#define pISR_FIQ (*(unsigned *)(_ISR_STARTADDRESS+0x1C)) + +#define pISR_EINT0 (*(unsigned *)(_ISR_STARTADDRESS+0x20)) +#define pISR_EINT1 (*(unsigned *)(_ISR_STARTADDRESS+0x24)) +#define pISR_EINT2 (*(unsigned *)(_ISR_STARTADDRESS+0x28)) +#define pISR_EINT3 (*(unsigned *)(_ISR_STARTADDRESS+0x2C)) +#define pISR_EINT4_7 (*(unsigned *)(_ISR_STARTADDRESS+0x30)) +#define pISR_EINT8_23 (*(unsigned *)(_ISR_STARTADDRESS+0x34)) +#define pISR_BAT_FLT (*(unsigned *)(_ISR_STARTADDRESS+0x3C)) +#define pISR_TICK (*(unsigned *)(_ISR_STARTADDRESS+0x40)) +#define pISR_WDT (*(unsigned *)(_ISR_STARTADDRESS+0x44)) +#define pISR_TIMER0 (*(unsigned *)(_ISR_STARTADDRESS+0x48)) +#define pISR_TIMER1 (*(unsigned *)(_ISR_STARTADDRESS+0x4C)) +#define pISR_TIMER2 (*(unsigned *)(_ISR_STARTADDRESS+0x50)) +#define pISR_TIMER3 (*(unsigned *)(_ISR_STARTADDRESS+0x54)) +#define pISR_TIMER4 (*(unsigned *)(_ISR_STARTADDRESS+0x58)) +#define pISR_UART2 (*(unsigned *)(_ISR_STARTADDRESS+0x5C)) +#define pISR_NOTUSED (*(unsigned *)(_ISR_STARTADDRESS+0x60)) +#define pISR_DMA0 (*(unsigned *)(_ISR_STARTADDRESS+0x64)) +#define pISR_DMA1 (*(unsigned *)(_ISR_STARTADDRESS+0x68)) +#define pISR_DMA2 (*(unsigned *)(_ISR_STARTADDRESS+0x6C)) +#define pISR_DMA3 (*(unsigned *)(_ISR_STARTADDRESS+0x70)) +#define pISR_SDI (*(unsigned *)(_ISR_STARTADDRESS+0x74)) +#define pISR_SPI0 (*(unsigned *)(_ISR_STARTADDRESS+0x78)) +#define pISR_UART1 (*(unsigned *)(_ISR_STARTADDRESS+0x7C)) +#define pISR_USBD (*(unsigned *)(_ISR_STARTADDRESS+0x84)) +#define pISR_USBH (*(unsigned *)(_ISR_STARTADDRESS+0x88)) +#define pISR_IIC (*(unsigned *)(_ISR_STARTADDRESS+0x8C)) +#define pISR_UART0 (*(unsigned *)(_ISR_STARTADDRESS+0x90)) +#define pISR_SPI1 (*(unsigned *)(_ISR_STARTADDRESS+0x94)) +#define pISR_RTC (*(unsigned *)(_ISR_STARTADDRESS+0x98)) +#define pISR_ADC (*(unsigned *)(_ISR_STARTADDRESS+0xA0)) + + +/* PENDING BIT */ +#define BIT_EINT0 (0x1) +#define BIT_EINT1 (0x1<<1) +#define BIT_EINT2 (0x1<<2) +#define BIT_EINT3 (0x1<<3) +#define BIT_EINT4_7 (0x1<<4) +#define BIT_EINT8_23 (0x1<<5) +#define BIT_BAT_FLT (0x1<<7) +#define BIT_TICK (0x1<<8) +#define BIT_WDT (0x1<<9) +#define BIT_TIMER0 (0x1<<10) +#define BIT_TIMER1 (0x1<<11) +#define BIT_TIMER2 (0x1<<12) +#define BIT_TIMER3 (0x1<<13) +#define BIT_TIMER4 (0x1<<14) +#define BIT_UART2 (0x1<<15) +#define BIT_LCD (0x1<<16) +#define BIT_DMA0 (0x1<<17) +#define BIT_DMA1 (0x1<<18) +#define BIT_DMA2 (0x1<<19) +#define BIT_DMA3 (0x1<<20) +#define BIT_SDI (0x1<<21) +#define BIT_SPI0 (0x1<<22) +#define BIT_UART1 (0x1<<23) +#define BIT_USBD (0x1<<25) +#define BIT_USBH (0x1<<26) +#define BIT_IIC (0x1<<27) +#define BIT_UART0 (0x1<<28) +#define BIT_SPI1 (0x1<<29) +#define BIT_RTC (0x1<<30) +#define BIT_ADC (0x1<<31) +#define BIT_ALLMSK (0xFFFFFFFF) + +#define ClearPending(bit) {\ + rSRCPND = bit;\ + rINTPND = bit;\ + rINTPND;\ + } +/* Wait until rINTPND is changed for the case that the ISR is very short. */ +#endif /*__S3C2440_H__*/ diff --git a/include/s3c24x0.h b/include/s3c24x0.h index 71f35a5..c51d58e 100644 --- a/include/s3c24x0.h +++ b/include/s3c24x0.h @@ -126,6 +126,9 @@ typedef struct { S3C24X0_REG32 CLKCON; S3C24X0_REG32 CLKSLOW; S3C24X0_REG32 CLKDIVN; +#ifdef CONFIG_S3C2440 + S3C24X0_REG32 CAMDIVN; +#endif } /*__attribute__((__packed__))*/ S3C24X0_CLOCK_POWER;
@@ -154,6 +157,7 @@ typedef struct { } /*__attribute__((__packed__))*/ S3C24X0_LCD;
+#ifdef CONFIG_S3C2410 /* NAND FLASH (see S3C2410 manual chapter 6) */ typedef struct { S3C24X0_REG32 NFCONF; @@ -163,6 +167,27 @@ typedef struct { S3C24X0_REG32 NFSTAT; S3C24X0_REG32 NFECC; } /*__attribute__((__packed__))*/ S3C2410_NAND; +#elif defined CONFIG_S3C2440 +/* NAND FLASH (see S3C2440 manual chapter 6 ) */ +typedef struct { + S3C24X0_REG32 NFCONF; + S3C24X0_REG32 NFCONT; + S3C24X0_REG32 NFCMD; + S3C24X0_REG32 NFADDR; + S3C24X0_REG32 NFDATA; + S3C24X0_REG32 NFMECCD0; + S3C24X0_REG32 NFMECCD1; + S3C24X0_REG32 NFSECCD; + S3C24X0_REG32 NFSTAT; + S3C24X0_REG32 NFESTAT0; + S3C24X0_REG32 NFESTAT1; + S3C24X0_REG32 NFMECC0; + S3C24X0_REG32 NFMECC1; + S3C24X0_REG32 NFSECC; + S3C24X0_REG32 NFSBLOCK; + S3C24X0_REG32 NFEBLOCK; +} /*__attribute__((__packed__))*/ S3C2440_NAND; +#endif
/* UART (see manual chapter 11) */ @@ -451,6 +476,64 @@ typedef struct { S3C24X0_REG32 GSTATUS3; S3C24X0_REG32 GSTATUS4; #endif +#ifdef CONFIG_S3C2440 + S3C24X0_REG32 GPACON; + S3C24X0_REG32 GPADAT; + S3C24X0_REG32 res1[2]; + S3C24X0_REG32 GPBCON; + S3C24X0_REG32 GPBDAT; + S3C24X0_REG32 GPBUP; + S3C24X0_REG32 res2; + S3C24X0_REG32 GPCCON; + S3C24X0_REG32 GPCDAT; + S3C24X0_REG32 GPCUP; + S3C24X0_REG32 res3; + S3C24X0_REG32 GPDCON; + S3C24X0_REG32 GPDDAT; + S3C24X0_REG32 GPDUP; + S3C24X0_REG32 res4; + S3C24X0_REG32 GPECON; + S3C24X0_REG32 GPEDAT; + S3C24X0_REG32 GPEUP; + S3C24X0_REG32 res5; + S3C24X0_REG32 GPFCON; + S3C24X0_REG32 GPFDAT; + S3C24X0_REG32 GPFUP; + S3C24X0_REG32 res6; + S3C24X0_REG32 GPGCON; + S3C24X0_REG32 GPGDAT; + S3C24X0_REG32 GPGUP; + S3C24X0_REG32 res7; + S3C24X0_REG32 GPHCON; + S3C24X0_REG32 GPHDAT; + S3C24X0_REG32 GPHUP; + S3C24X0_REG32 res8; + + S3C24X0_REG32 MISCCR; + S3C24X0_REG32 DCLKCON; + S3C24X0_REG32 EXTINT0; + S3C24X0_REG32 EXTINT1; + S3C24X0_REG32 EXTINT2; + S3C24X0_REG32 EINTFLT0; + S3C24X0_REG32 EINTFLT1; + S3C24X0_REG32 EINTFLT2; + S3C24X0_REG32 EINTFLT3; + S3C24X0_REG32 EINTMASK; + S3C24X0_REG32 EINTPEND; + S3C24X0_REG32 GSTATUS0; + S3C24X0_REG32 GSTATUS1; + S3C24X0_REG32 GSTATUS2; + S3C24X0_REG32 GSTATUS3; + S3C24X0_REG32 GSTATUS4; + S3C24X0_REG32 res9; + + S3C24X0_REG32 DSC0; + S3C24X0_REG32 DSC1; + S3C24X0_REG32 MSLCON; + S3C24X0_REG32 GPJCON; + S3C24X0_REG32 GPJDAT; + S3C24X0_REG32 GPJUP; +#endif } /*__attribute__((__packed__))*/ S3C24X0_GPIO;
