[PATCH] sunxi: DT: A64: update devicetree files
Import updated devicetree file from Linux v5.12-rc8.
Besides some node and audio port renames this changes the PHY modes to either rgmii-id or rgmii-txid. From the board files the Pinephone sees a lot of updates.
This also adds the long missing USB PHY property for controller 0, which allows the U-Boot PHY driver to eventually use port 0 in host mode (pending another U-Boot patch).
Signed-off-by: Andre Przywara andre.przywara@arm.com --- arch/arm/dts/sun50i-a64-bananapi-m64.dts | 16 ++-- arch/arm/dts/sun50i-a64-nanopi-a64.dts | 2 +- arch/arm/dts/sun50i-a64-orangepi-win.dts | 10 +-- arch/arm/dts/sun50i-a64-pine64-lts.dts | 15 ++++ arch/arm/dts/sun50i-a64-pine64-plus.dts | 2 +- arch/arm/dts/sun50i-a64-pine64.dts | 8 +- arch/arm/dts/sun50i-a64-pinebook.dts | 13 ++- arch/arm/dts/sun50i-a64-pinephone-1.0.dts | 7 +- arch/arm/dts/sun50i-a64-pinephone-1.1.dts | 7 +- arch/arm/dts/sun50i-a64-pinephone-1.2.dts | 16 +++- arch/arm/dts/sun50i-a64-pinephone.dtsi | 90 +++++++++++++++---- .../dts/sun50i-a64-pinetab-early-adopter.dts | 26 ++++++ arch/arm/dts/sun50i-a64-pinetab.dts | 13 ++- arch/arm/dts/sun50i-a64-sopine-baseboard.dts | 11 +-- arch/arm/dts/sun50i-a64-sopine.dtsi | 3 +- arch/arm/dts/sun50i-a64-teres-i.dts | 12 +-- arch/arm/dts/sun50i-a64.dtsi | 40 ++++++--- 17 files changed, 215 insertions(+), 76 deletions(-) create mode 100644 arch/arm/dts/sun50i-a64-pinetab-early-adopter.dts
diff --git a/arch/arm/dts/sun50i-a64-bananapi-m64.dts b/arch/arm/dts/sun50i-a64-bananapi-m64.dts index 883f217efb8..f7fe9fa50cb 100644 --- a/arch/arm/dts/sun50i-a64-bananapi-m64.dts +++ b/arch/arm/dts/sun50i-a64-bananapi-m64.dts @@ -36,18 +36,18 @@ leds { compatible = "gpio-leds";
- pwr-led { + led-0 { label = "bananapi-m64:red:pwr"; gpios = <&pio 3 24 GPIO_ACTIVE_HIGH>; /* PD24 */ default-state = "on"; };
- green { + led-1 { label = "bananapi-m64:green:user"; gpios = <&pio 4 14 GPIO_ACTIVE_HIGH>; /* PE14 */ };
- blue { + led-2 { label = "bananapi-m64:blue:user"; gpios = <&pio 4 15 GPIO_ACTIVE_HIGH>; /* PE15 */ }; @@ -105,7 +105,7 @@ &emac { pinctrl-names = "default"; pinctrl-0 = <&rgmii_pins>; - phy-mode = "rgmii"; + phy-mode = "rgmii-id"; phy-handle = <&ext_rgmii_phy>; phy-supply = <®_dc1sw>; status = "okay"; @@ -331,10 +331,10 @@ "Microphone", "Microphone Jack", "Microphone", "Onboard Microphone"; simple-audio-card,routing = - "Left DAC", "AIF1 Slot 0 Left", - "Right DAC", "AIF1 Slot 0 Right", - "AIF1 Slot 0 Left ADC", "Left ADC", - "AIF1 Slot 0 Right ADC", "Right ADC", + "Left DAC", "DACL", + "Right DAC", "DACR", + "ADCL", "Left ADC", + "ADCR", "Right ADC", "Headphone Jack", "HP", "MIC2", "Microphone Jack", "Onboard Microphone", "MBIAS", diff --git a/arch/arm/dts/sun50i-a64-nanopi-a64.dts b/arch/arm/dts/sun50i-a64-nanopi-a64.dts index e58db8a6cab..09b3c7fb82c 100644 --- a/arch/arm/dts/sun50i-a64-nanopi-a64.dts +++ b/arch/arm/dts/sun50i-a64-nanopi-a64.dts @@ -35,7 +35,7 @@ leds { compatible = "gpio-leds";
- blue { + led { label = "nanopi-a64:blue:status"; gpios = <&pio 3 24 GPIO_ACTIVE_LOW>; /* PD24 */ }; diff --git a/arch/arm/dts/sun50i-a64-orangepi-win.dts b/arch/arm/dts/sun50i-a64-orangepi-win.dts index fde9c7a99b1..70e31743f0b 100644 --- a/arch/arm/dts/sun50i-a64-orangepi-win.dts +++ b/arch/arm/dts/sun50i-a64-orangepi-win.dts @@ -120,7 +120,7 @@ &emac { pinctrl-names = "default"; pinctrl-0 = <&rgmii_pins>; - phy-mode = "rgmii"; + phy-mode = "rgmii-id"; phy-handle = <&ext_rgmii_phy>; phy-supply = <®_gmac_3v3>; status = "okay"; @@ -330,10 +330,10 @@ "Microphone", "Microphone Jack", "Microphone", "Onboard Microphone"; simple-audio-card,routing = - "Left DAC", "AIF1 Slot 0 Left", - "Right DAC", "AIF1 Slot 0 Right", - "AIF1 Slot 0 Left ADC", "Left ADC", - "AIF1 Slot 0 Right ADC", "Right ADC", + "Left DAC", "DACL", + "Right DAC", "DACR", + "ADCL", "Left ADC", + "ADCR", "Right ADC", "Headphone Jack", "HP", "MIC2", "Microphone Jack", "Onboard Microphone", "MBIAS", diff --git a/arch/arm/dts/sun50i-a64-pine64-lts.dts b/arch/arm/dts/sun50i-a64-pine64-lts.dts index 302e24be0a3..e79ce49e7e6 100644 --- a/arch/arm/dts/sun50i-a64-pine64-lts.dts +++ b/arch/arm/dts/sun50i-a64-pine64-lts.dts @@ -1,10 +1,25 @@ // SPDX-License-Identifier: (GPL-2.0+ OR MIT) // Copyright (c) 2018 ARM Ltd.
+#include <dt-bindings/leds/common.h> #include "sun50i-a64-sopine-baseboard.dts"
/ { model = "Pine64 LTS"; compatible = "pine64,pine64-lts", "allwinner,sun50i-r18", "allwinner,sun50i-a64"; + + leds { + compatible = "gpio-leds"; + + led { + function = LED_FUNCTION_STATUS; + color = <LED_COLOR_ID_BLUE>; + gpios = <&r_pio 0 7 GPIO_ACTIVE_LOW>; /* PL7 */ + }; + }; +}; + +&mmc0 { + cd-gpios = <&pio 5 6 GPIO_ACTIVE_LOW>; /* PF6 push-push switch */ }; diff --git a/arch/arm/dts/sun50i-a64-pine64-plus.dts b/arch/arm/dts/sun50i-a64-pine64-plus.dts index b26181cf909..b54099b654c 100644 --- a/arch/arm/dts/sun50i-a64-pine64-plus.dts +++ b/arch/arm/dts/sun50i-a64-pine64-plus.dts @@ -13,7 +13,7 @@ &emac { pinctrl-names = "default"; pinctrl-0 = <&rgmii_pins>; - phy-mode = "rgmii"; + phy-mode = "rgmii-txid"; phy-handle = <&ext_rgmii_phy>; status = "okay"; }; diff --git a/arch/arm/dts/sun50i-a64-pine64.dts b/arch/arm/dts/sun50i-a64-pine64.dts index 2165f238af1..329cf276561 100644 --- a/arch/arm/dts/sun50i-a64-pine64.dts +++ b/arch/arm/dts/sun50i-a64-pine64.dts @@ -261,11 +261,11 @@ simple-audio-card,widgets = "Microphone", "Microphone Jack", "Headphone", "Headphone Jack"; simple-audio-card,routing = - "Left DAC", "AIF1 Slot 0 Left", - "Right DAC", "AIF1 Slot 0 Right", + "Left DAC", "DACL", + "Right DAC", "DACR", "Headphone Jack", "HP", - "AIF1 Slot 0 Left ADC", "Left ADC", - "AIF1 Slot 0 Right ADC", "Right ADC", + "ADCL", "Left ADC", + "ADCR", "Right ADC", "MIC2", "Microphone Jack"; status = "okay"; }; diff --git a/arch/arm/dts/sun50i-a64-pinebook.dts b/arch/arm/dts/sun50i-a64-pinebook.dts index 64b1c54f87c..7ae16541d14 100644 --- a/arch/arm/dts/sun50i-a64-pinebook.dts +++ b/arch/arm/dts/sun50i-a64-pinebook.dts @@ -126,8 +126,6 @@ };
&ehci0 { - phys = <&usbphy 0>; - phy-names = "usb"; status = "okay"; };
@@ -169,6 +167,7 @@ pinctrl-0 = <&mmc2_pins>, <&mmc2_ds_pin>; vmmc-supply = <®_dcdc1>; vqmmc-supply = <®_eldo1>; + max-frequency = <200000000>; bus-width = <8>; non-removable; cap-mmc-hw-reset; @@ -177,8 +176,6 @@ };
&ohci0 { - phys = <&usbphy 0>; - phy-names = "usb"; status = "okay"; };
@@ -374,15 +371,15 @@ "Headphone", "Headphone Jack", "Speaker", "Internal Speaker"; simple-audio-card,routing = - "Left DAC", "AIF1 Slot 0 Left", - "Right DAC", "AIF1 Slot 0 Right", + "Left DAC", "DACL", + "Right DAC", "DACR", "Speaker Amp INL", "LINEOUT", "Speaker Amp INR", "LINEOUT", "Internal Speaker", "Speaker Amp OUTL", "Internal Speaker", "Speaker Amp OUTR", "Headphone Jack", "HP", - "AIF1 Slot 0 Left ADC", "Left ADC", - "AIF1 Slot 0 Right ADC", "Right ADC", + "ADCL", "Left ADC", + "ADCR", "Right ADC", "Internal Microphone Left", "MBIAS", "MIC1", "Internal Microphone Left", "Internal Microphone Right", "HBIAS", diff --git a/arch/arm/dts/sun50i-a64-pinephone-1.0.dts b/arch/arm/dts/sun50i-a64-pinephone-1.0.dts index 0c42272106a..fb65319a3bd 100644 --- a/arch/arm/dts/sun50i-a64-pinephone-1.0.dts +++ b/arch/arm/dts/sun50i-a64-pinephone-1.0.dts @@ -7,5 +7,10 @@
/ { model = "Pine64 PinePhone Developer Batch (1.0)"; - compatible = "pine64,pinephone-1.0", "allwinner,sun50i-a64"; + compatible = "pine64,pinephone-1.0", "pine64,pinephone", "allwinner,sun50i-a64"; +}; + +&sgm3140 { + enable-gpios = <&pio 2 3 GPIO_ACTIVE_HIGH>; /* PC3 */ + flash-gpios = <&pio 3 24 GPIO_ACTIVE_HIGH>; /* PD24 */ }; diff --git a/arch/arm/dts/sun50i-a64-pinephone-1.1.dts b/arch/arm/dts/sun50i-a64-pinephone-1.1.dts index 3e99a87e9ce..5e59d375217 100644 --- a/arch/arm/dts/sun50i-a64-pinephone-1.1.dts +++ b/arch/arm/dts/sun50i-a64-pinephone-1.1.dts @@ -7,7 +7,7 @@
/ { model = "Pine64 PinePhone Braveheart (1.1)"; - compatible = "pine64,pinephone-1.1", "allwinner,sun50i-a64"; + compatible = "pine64,pinephone-1.1", "pine64,pinephone", "allwinner,sun50i-a64"; };
&backlight { @@ -28,3 +28,8 @@ num-interpolated-steps = <50>; default-brightness-level = <400>; }; + +&sgm3140 { + enable-gpios = <&pio 3 24 GPIO_ACTIVE_HIGH>; /* PD24 */ + flash-gpios = <&pio 2 3 GPIO_ACTIVE_HIGH>; /* PC3 */ +}; diff --git a/arch/arm/dts/sun50i-a64-pinephone-1.2.dts b/arch/arm/dts/sun50i-a64-pinephone-1.2.dts index a9f5b670c9b..4e7e237cb46 100644 --- a/arch/arm/dts/sun50i-a64-pinephone-1.2.dts +++ b/arch/arm/dts/sun50i-a64-pinephone-1.2.dts @@ -7,7 +7,12 @@
/ { model = "Pine64 PinePhone (1.2)"; - compatible = "pine64,pinephone-1.2", "allwinner,sun50i-a64"; + compatible = "pine64,pinephone-1.2", "pine64,pinephone", "allwinner,sun50i-a64"; + + wifi_pwrseq: wifi-pwrseq { + compatible = "mmc-pwrseq-simple"; + reset-gpios = <&r_pio 0 2 GPIO_ACTIVE_LOW>; /* PL2 */ + }; };
&backlight { @@ -38,3 +43,12 @@ interrupt-parent = <&pio>; interrupts = <1 1 IRQ_TYPE_EDGE_RISING>; /* PB1 */ }; + +&mmc1 { + mmc-pwrseq = <&wifi_pwrseq>; +}; + +&sgm3140 { + enable-gpios = <&pio 3 24 GPIO_ACTIVE_HIGH>; /* PD24 */ + flash-gpios = <&pio 2 3 GPIO_ACTIVE_HIGH>; /* PC3 */ +}; diff --git a/arch/arm/dts/sun50i-a64-pinephone.dtsi b/arch/arm/dts/sun50i-a64-pinephone.dtsi index 25150aba749..9f69d489a81 100644 --- a/arch/arm/dts/sun50i-a64-pinephone.dtsi +++ b/arch/arm/dts/sun50i-a64-pinephone.dtsi @@ -13,6 +13,7 @@
/ { aliases { + ethernet0 = &rtl8723cs; serial0 = &uart0; };
@@ -20,6 +21,7 @@ compatible = "pwm-backlight"; pwms = <&r_pwm 0 50000 PWM_POLARITY_INVERTED>; enable-gpios = <&pio 7 10 GPIO_ACTIVE_HIGH>; /* PH10 */ + power-supply = <®_ps>; /* Backlight configuration differs per PinePhone revision. */ };
@@ -30,25 +32,51 @@ leds { compatible = "gpio-leds";
- blue { + led-0 { function = LED_FUNCTION_INDICATOR; color = <LED_COLOR_ID_BLUE>; gpios = <&pio 3 20 GPIO_ACTIVE_HIGH>; /* PD20 */ };
- green { + led-1 { function = LED_FUNCTION_INDICATOR; color = <LED_COLOR_ID_GREEN>; gpios = <&pio 3 18 GPIO_ACTIVE_HIGH>; /* PD18 */ };
- red { + led-2 { function = LED_FUNCTION_INDICATOR; color = <LED_COLOR_ID_RED>; gpios = <&pio 3 19 GPIO_ACTIVE_HIGH>; /* PD19 */ }; };
+ reg_ps: ps-regulator { + compatible = "regulator-fixed"; + regulator-name = "ps"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + regulator-boot-on; + }; + + reg_vbat_wifi: vbat-wifi { + compatible = "regulator-fixed"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vbat-wifi"; + }; + + sgm3140: led-controller { + compatible = "sgmicro,sgm3140"; + vin-supply = <®_dcdc1>; + + sgm3140_flash: led { + function = LED_FUNCTION_FLASH; + color = <LED_COLOR_ID_WHITE>; + flash-max-timeout-us = <250000>; + }; + }; + speaker_amp: audio-amplifier { compatible = "simple-audio-amplifier"; enable-gpios = <&pio 2 7 GPIO_ACTIVE_HIGH>; /* PC7 */ @@ -142,15 +170,23 @@ status = "okay";
/* Magnetometer */ - lis3mdl: lis3mdl@1e { + lis3mdl: magnetometer@1e { compatible = "st,lis3mdl-magn"; reg = <0x1e>; vdd-supply = <®_dldo1>; vddio-supply = <®_dldo1>; };
+ /* Light/proximity sensor */ + light-sensor@48 { + compatible = "sensortek,stk3311"; + reg = <0x48>; + interrupt-parent = <&pio>; + interrupts = <1 0 IRQ_TYPE_EDGE_FALLING>; /* PB0 */ + }; + /* Accelerometer/gyroscope */ - mpu6050@68 { + accelerometer@68 { compatible = "invensense,mpu6050"; reg = <0x68>; interrupt-parent = <&pio>; @@ -167,6 +203,7 @@
&lradc { vref-supply = <®_aldo3>; + wakeup-source; status = "okay";
button-200 { @@ -195,6 +232,20 @@ status = "okay"; };
+&mmc1 { + pinctrl-names = "default"; + pinctrl-0 = <&mmc1_pins>; + vmmc-supply = <®_vbat_wifi>; + vqmmc-supply = <®_dldo4>; + bus-width = <4>; + non-removable; + status = "okay"; + + rtl8723cs: wifi@1 { + reg = <1>; + }; +}; + &mmc2 { pinctrl-names = "default"; pinctrl-0 = <&mmc2_pins>; @@ -251,10 +302,6 @@
#include "axp803.dtsi"
-&ac_power_supply { - status = "okay"; -}; - &battery_power_supply { status = "okay"; }; @@ -274,8 +321,8 @@
®_aldo3 { regulator-always-on; - regulator-min-microvolt = <2700000>; - regulator-max-microvolt = <3300000>; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3000000>; regulator-name = "vcc-pll-avcc"; };
@@ -392,10 +439,10 @@ "Internal Speaker", "Speaker Amp OUTR", "Speaker Amp INL", "LINEOUT", "Speaker Amp INR", "LINEOUT", - "Left DAC", "AIF1 Slot 0 Left", - "Right DAC", "AIF1 Slot 0 Right", - "AIF1 Slot 0 Left ADC", "Left ADC", - "AIF1 Slot 0 Right ADC", "Right ADC", + "Left DAC", "DACL", + "Right DAC", "DACR", + "ADCL", "Left ADC", + "ADCR", "Right ADC", "Internal Microphone", "MBIAS", "MIC1", "Internal Microphone", "Headset Microphone", "HBIAS", @@ -408,6 +455,19 @@ status = "okay"; };
+&uart1 { + pinctrl-names = "default"; + pinctrl-0 = <&uart1_pins>, <&uart1_rts_cts_pins>; + status = "okay"; + + bluetooth { + compatible = "realtek,rtl8723cs-bt"; + device-wake-gpios = <&pio 7 6 GPIO_ACTIVE_LOW>; /* PH6 */ + enable-gpios = <&r_pio 0 4 GPIO_ACTIVE_HIGH>; /* PL4 */ + host-wake-gpios = <&r_pio 0 5 GPIO_ACTIVE_HIGH>; /* PL5 */ + }; +}; + /* Connected to the modem (hardware flow control can't be used) */ &uart3 { pinctrl-names = "default"; diff --git a/arch/arm/dts/sun50i-a64-pinetab-early-adopter.dts b/arch/arm/dts/sun50i-a64-pinetab-early-adopter.dts new file mode 100644 index 00000000000..6265360ce62 --- /dev/null +++ b/arch/arm/dts/sun50i-a64-pinetab-early-adopter.dts @@ -0,0 +1,26 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (C) 2020 Icenowy Zheng icenowy@aosc.io + * + */ + +/dts-v1/; + +#include "sun50i-a64-pinetab.dts" + +/ { + model = "PineTab, Early Adopter's version"; + compatible = "pine64,pinetab-early-adopter", "allwinner,sun50i-a64"; +}; + +&dsi { + /delete-node/ panel@0; + + panel@0 { + compatible = "feixin,k101-im2byl02", "ilitek,ili9881c"; + reg = <0>; + power-supply = <®_dc1sw>; + reset-gpios = <&pio 3 24 GPIO_ACTIVE_LOW>; /* PD24 */ + backlight = <&backlight>; + }; +}; diff --git a/arch/arm/dts/sun50i-a64-pinetab.dts b/arch/arm/dts/sun50i-a64-pinetab.dts index dc4ab6b434f..422a8507f67 100644 --- a/arch/arm/dts/sun50i-a64-pinetab.dts +++ b/arch/arm/dts/sun50i-a64-pinetab.dts @@ -14,7 +14,7 @@ #include <dt-bindings/pwm/pwm.h>
/ { - model = "PineTab"; + model = "PineTab, Development Sample"; compatible = "pine64,pinetab", "allwinner,sun50i-a64";
aliases { @@ -122,9 +122,6 @@ status = "okay";
port { - #address-cells = <1>; - #size-cells = <0>; - csi_ep: endpoint { remote-endpoint = <&ov5640_ep>; bus-width = <8>; @@ -421,15 +418,15 @@ "Headphone", "Headphone Jack", "Speaker", "Internal Speaker"; simple-audio-card,routing = - "Left DAC", "AIF1 Slot 0 Left", - "Right DAC", "AIF1 Slot 0 Right", + "Left DAC", "DACL", + "Right DAC", "DACR", "Speaker Amp INL", "LINEOUT", "Speaker Amp INR", "LINEOUT", "Internal Speaker", "Speaker Amp OUTL", "Internal Speaker", "Speaker Amp OUTR", "Headphone Jack", "HP", - "AIF1 Slot 0 Left ADC", "Left ADC", - "AIF1 Slot 0 Right ADC", "Right ADC", + "ADCL", "Left ADC", + "ADCR", "Right ADC", "Internal Microphone Left", "MBIAS", "MIC1", "Internal Microphone Left", "Internal Microphone Right", "HBIAS", diff --git a/arch/arm/dts/sun50i-a64-sopine-baseboard.dts b/arch/arm/dts/sun50i-a64-sopine-baseboard.dts index 2f6ea9f3f6a..e22b94c8364 100644 --- a/arch/arm/dts/sun50i-a64-sopine-baseboard.dts +++ b/arch/arm/dts/sun50i-a64-sopine-baseboard.dts @@ -79,7 +79,7 @@ &emac { pinctrl-names = "default"; pinctrl-0 = <&rgmii_pins>; - phy-mode = "rgmii"; + phy-mode = "rgmii-id"; phy-handle = <&ext_rgmii_phy>; phy-supply = <®_dc1sw>; status = "okay"; @@ -111,6 +111,7 @@ bus-width = <8>; non-removable; cap-mmc-hw-reset; + mmc-hs200-1_8v; status = "okay"; };
@@ -159,11 +160,11 @@ simple-audio-card,widgets = "Microphone", "Microphone Jack", "Headphone", "Headphone Jack"; simple-audio-card,routing = - "Left DAC", "AIF1 Slot 0 Left", - "Right DAC", "AIF1 Slot 0 Right", + "Left DAC", "DACL", + "Right DAC", "DACR", "Headphone Jack", "HP", - "AIF1 Slot 0 Left ADC", "Left ADC", - "AIF1 Slot 0 Right ADC", "Right ADC", + "ADCL", "Left ADC", + "ADCR", "Right ADC", "MIC2", "Microphone Jack"; status = "okay"; }; diff --git a/arch/arm/dts/sun50i-a64-sopine.dtsi b/arch/arm/dts/sun50i-a64-sopine.dtsi index c48692b06e1..df62044ff7a 100644 --- a/arch/arm/dts/sun50i-a64-sopine.dtsi +++ b/arch/arm/dts/sun50i-a64-sopine.dtsi @@ -32,10 +32,9 @@ pinctrl-names = "default"; pinctrl-0 = <&mmc0_pins>; vmmc-supply = <®_dcdc1>; - non-removable; disable-wp; bus-width = <4>; - cd-gpios = <&pio 5 6 GPIO_ACTIVE_LOW>; /* PF6 */ + cd-gpios = <&pio 5 6 GPIO_ACTIVE_HIGH>; /* PF6 push-pull switch */ status = "okay"; };
diff --git a/arch/arm/dts/sun50i-a64-teres-i.dts b/arch/arm/dts/sun50i-a64-teres-i.dts index f5df5f705b7..f0a16f355e2 100644 --- a/arch/arm/dts/sun50i-a64-teres-i.dts +++ b/arch/arm/dts/sun50i-a64-teres-i.dts @@ -52,12 +52,12 @@ leds { compatible = "gpio-leds";
- capslock { + led-0 { label = "teres-i:green:capslock"; gpios = <&pio 2 7 GPIO_ACTIVE_HIGH>; /* PC7 */ };
- numlock { + led-1 { label = "teres-i:green:numlock"; gpios = <&pio 2 4 GPIO_ACTIVE_HIGH>; /* PC4 */ }; @@ -340,10 +340,10 @@ "Microphone", "Internal Microphone", "Speaker", "Internal Speaker"; simple-audio-card,routing = - "Left DAC", "AIF1 Slot 0 Left", - "Right DAC", "AIF1 Slot 0 Right", - "AIF1 Slot 0 Left ADC", "Left ADC", - "AIF1 Slot 0 Right ADC", "Right ADC", + "Left DAC", "DACL", + "Right DAC", "DACR", + "ADCL", "Left ADC", + "ADCR", "Right ADC", "Headphone Jack", "HP", "Speaker Amp INL", "LINEOUT", "Speaker Amp INR", "LINEOUT", diff --git a/arch/arm/dts/sun50i-a64.dtsi b/arch/arm/dts/sun50i-a64.dtsi index 8dfbcd14407..57786fc120c 100644 --- a/arch/arm/dts/sun50i-a64.dtsi +++ b/arch/arm/dts/sun50i-a64.dtsi @@ -51,7 +51,7 @@ reg = <0>; enable-method = "psci"; next-level-cache = <&L2>; - clocks = <&ccu 21>; + clocks = <&ccu CLK_CPUX>; clock-names = "cpu"; #cooling-cells = <2>; }; @@ -62,7 +62,7 @@ reg = <1>; enable-method = "psci"; next-level-cache = <&L2>; - clocks = <&ccu 21>; + clocks = <&ccu CLK_CPUX>; clock-names = "cpu"; #cooling-cells = <2>; }; @@ -73,7 +73,7 @@ reg = <2>; enable-method = "psci"; next-level-cache = <&L2>; - clocks = <&ccu 21>; + clocks = <&ccu CLK_CPUX>; clock-names = "cpu"; #cooling-cells = <2>; }; @@ -84,7 +84,7 @@ reg = <3>; enable-method = "psci"; next-level-cache = <&L2>; - clocks = <&ccu 21>; + clocks = <&ccu CLK_CPUX>; clock-names = "cpu"; #cooling-cells = <2>; }; @@ -139,10 +139,10 @@ simple-audio-card,mclk-fs = <128>; simple-audio-card,aux-devs = <&codec_analog>; simple-audio-card,routing = - "Left DAC", "AIF1 Slot 0 Left", - "Right DAC", "AIF1 Slot 0 Right", - "AIF1 Slot 0 Left ADC", "Left ADC", - "AIF1 Slot 0 Right ADC", "Right ADC"; + "Left DAC", "DACL", + "Right DAC", "DACR", + "ADCL", "Left ADC", + "ADCR", "Right ADC"; status = "disabled";
cpudai: simple-audio-card,cpu { @@ -157,6 +157,7 @@ timer { compatible = "arm,armv8-timer"; allwinner,erratum-unknown1; + arm,no-tick-in-suspend; interrupts = <GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>, <GIC_PPI 14 @@ -513,7 +514,7 @@ resets = <&ccu RST_BUS_MMC2>; reset-names = "ahb"; interrupts = <GIC_SPI 62 IRQ_TYPE_LEVEL_HIGH>; - max-frequency = <200000000>; + max-frequency = <150000000>; status = "disabled"; #address-cells = <1>; #size-cells = <0>; @@ -592,6 +593,8 @@ <&ccu CLK_USB_OHCI0>; resets = <&ccu RST_BUS_OHCI0>, <&ccu RST_BUS_EHCI0>; + phys = <&usbphy 0>; + phy-names = "usb"; status = "disabled"; };
@@ -602,6 +605,8 @@ clocks = <&ccu CLK_BUS_OHCI0>, <&ccu CLK_USB_OHCI0>; resets = <&ccu RST_BUS_OHCI0>; + phys = <&usbphy 0>; + phy-names = "usb"; status = "disabled"; };
@@ -845,6 +850,20 @@ status = "disabled"; };
+ i2s2: i2s@1c22800 { + #sound-dai-cells = <0>; + compatible = "allwinner,sun50i-a64-i2s", + "allwinner,sun8i-h3-i2s"; + reg = <0x01c22800 0x400>; + interrupts = <GIC_SPI 15 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_I2S2>, <&ccu CLK_I2S2>; + clock-names = "apb", "mod"; + resets = <&ccu RST_BUS_I2S2>; + dma-names = "rx", "tx"; + dmas = <&dma 27>, <&dma 27>; + status = "disabled"; + }; + dai: dai@1c22c00 { #sound-dai-cells = <0>; compatible = "allwinner,sun50i-a64-codec-i2s"; @@ -860,7 +879,8 @@
codec: codec@1c22e00 { #sound-dai-cells = <0>; - compatible = "allwinner,sun8i-a33-codec"; + compatible = "allwinner,sun50i-a64-codec", + "allwinner,sun8i-a33-codec"; reg = <0x01c22e00 0x600>; interrupts = <GIC_SPI 28 IRQ_TYPE_LEVEL_HIGH>; clocks = <&ccu CLK_BUS_CODEC>, <&ccu CLK_AC_DIG>;
Hi Andre!
Dne sreda, 21. april 2021 ob 11:27:12 CEST je Andre Przywara napisal(a):
pwr-led {
PD24 */
green {
PE14 */
blue {
PE15 */
- phy-mode = "rgmii-id"; phy-handle = <&ext_rgmii_phy>; phy-supply = <®_dc1sw>; status = "okay";
Jack",
Microphone";
"Left DAC", "DACL",
"ADCL", "Left ADC",
a64-nanopi-a64.dts
blue {
- phy-mode = "rgmii-id"; phy-handle = <&ext_rgmii_phy>; phy-supply = <®_gmac_3v3>; status = "okay";
Jack",
Microphone";
"Left DAC", "DACL",
"ADCL", "Left ADC",
a64-pine64-lts.dts
- leds {
led {
+&mmc0 {
- cd-gpios = <&pio 5 6 GPIO_ACTIVE_LOW>; /* PF6 push-push switch */
Do you really want to use this version? Today I got another report that this doesn't work. Or do you plan to fix it in -rc release?
Best regards, Jernej
a64-pine64-plus.dts
- phy-mode = "rgmii-txid"; phy-handle = <&ext_rgmii_phy>; status = "okay";
pine64.dts
Jack";
"Left DAC", "DACL",
"ADCL", "Left ADC",
status = "okay";"ADCR", "Right ADC", "MIC2", "Microphone Jack";
pinebook.dts
&ehci0 {
- max-frequency = <200000000>; bus-width = <8>; non-removable; cap-mmc-hw-reset;
&ohci0 {
Jack",
Speaker";
"Left DAC", "DACL",
"ADCL", "Left ADC",
- compatible = "pine64,pinephone-1.0", "pine64,pinephone",
+&sgm3140 {
- enable-gpios = <&pio 2 3 GPIO_ACTIVE_HIGH>; /* PC3 */
- flash-gpios = <&pio 3 24 GPIO_ACTIVE_HIGH>; /* PD24 */
- compatible = "pine64,pinephone-1.1", "pine64,pinephone",
+&sgm3140 {
- enable-gpios = <&pio 3 24 GPIO_ACTIVE_HIGH>; /* PD24 */
- flash-gpios = <&pio 2 3 GPIO_ACTIVE_HIGH>; /* PC3 */
- compatible = "pine64,pinephone-1.2", "pine64,pinephone",
- wifi_pwrseq: wifi-pwrseq {
+&mmc1 {
- mmc-pwrseq = <&wifi_pwrseq>;
+&sgm3140 {
a64-pinephone.dtsi
/ { aliases {
serial0 = &uart0; };ethernet0 = &rtl8723cs;
/* Backlight configuration differs per PinePhonepower-supply = <®_ps>;
revision. */
blue {
PD20 */
green {
PD18 */
red {
PD19 */
- reg_ps: ps-regulator {
regulator-boot-on;
- reg_vbat_wifi: vbat-wifi {
- sgm3140: led-controller {
- speaker_amp: audio-amplifier { compatible = "simple-audio-amplifier"; enable-gpios = <&pio 2 7 GPIO_ACTIVE_HIGH>; /* PC7 */
/* Magnetometer */
light-sensor@48 {
reg = <0x48>;
- mpu6050@68 {
- accelerometer@68 { compatible = "invensense,mpu6050"; reg = <0x68>; interrupt-parent = <&pio>;
@@ -167,6 +203,7 @@
button-200 {
+&mmc1 {
- pinctrl-names = "default";
- pinctrl-0 = <&mmc1_pins>;
- vmmc-supply = <®_vbat_wifi>;
- vqmmc-supply = <®_dldo4>;
- bus-width = <4>;
- non-removable;
- status = "okay";
- rtl8723cs: wifi@1 {
reg = <1>;
-&ac_power_supply {
- status = "okay";
- regulator-min-microvolt = <3000000>;
- regulator-max-microvolt = <3000000>; regulator-name = "vcc-pll-avcc";
"Left DAC", "DACL",
"ADCL", "Left ADC",
+&uart1 {
- pinctrl-0 = <&uart1_pins>, <&uart1_rts_cts_pins>;
- status = "okay";
- bluetooth {
- Copyright (C) 2020 Icenowy Zheng icenowy@aosc.io
+/dts-v1/;
- model = "PineTab, Early Adopter's version";
- compatible = "pine64,pinetab-early-adopter", "allwinner,sun50i-
a64";
+&dsi {
- /delete-node/ panel@0;
- panel@0 {
reg = <0>;
pinetab.dts
aliases {
port {
#size-cells = <0>;
Jack",
Speaker";
"Left DAC", "DACL",
"ADCL", "Left ADC",
- mmc-hs200-1_8v; status = "okay";
Jack";
"Left DAC", "DACL",
"ADCL", "Left ADC",
sopine.dtsi
- cd-gpios = <&pio 5 6 GPIO_ACTIVE_HIGH>; /* PF6 push-pull switch */ status = "okay";
teres-i.dts
capslock {
numlock {
Microphone",
Speaker";
"Left DAC", "DACL",
"ADCL", "Left ADC",
clocks = <&ccu 21>;
};clocks = <&ccu CLK_CPUX>; clock-names = "cpu"; #cooling-cells = <2>;
clocks = <&ccu 21>;
clocks = <&ccu 21>;
clocks = <&ccu 21>;
ADC",
ADC";
"Left DAC", "DACL",
"ADCL", "Left ADC",
interrupts = <GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(4) |arm,no-tick-in-suspend;
<GIC_PPI 14
phys = <&usbphy 0>;
};phy-names = "usb"; status = "disabled";
phys = <&usbphy 0>;
i2s2: i2s@1c22800 {
CLK_I2S2>;
- dai: dai@1c22c00 { #sound-dai-cells = <0>; compatible = "allwinner,sun50i-a64-codec-
i2s";
@@ -860,7 +879,8 @@
CLK_AC_DIG>;
-- 2.17.5
On Wed, 21 Apr 2021 23:16:48 +0200 Jernej Škrabec jernej.skrabec@siol.net wrote:
Hi Jernej,
thanks for having a look!
- leds {
led {
+&mmc0 {
Well, this is a verbatim copy of the current Linux mainline tree. I just wanted to post this to see if people have any comments. Yes, there is one patch missing, but ideally this one hits mainline Linux before this update here gets merged (so I merge the updated version), or I push it as a hot fix afterwards.
Cheers, Andre
Files are identical, so:
Reviewed-by: Jernej Skrabec jernej.skrabec@siol.net
Andre Przywara
Jernej Škrabec
