[U-Boot] [PATCH v2 0/5] Remove assert()
assert() is almost used in the same way as BUG_ON(), except: - the logic is opposite - currently, assert() is compiled only when DEBUG is defined
Coccinelle can easily convert assert() to BUG_ON(), but the problem is it would grow the image size.
In v2, I introduced CONFIG_ENABLE_BUG_CHECKS. This option is 'n' by default, and makes it BUG_ON etc. into no-op.
Masahiro Yamada (5): Move CONFIG_PANIC_HANG to Kconfig Enable CONFIG_PANIC_HANG for boards without do_reset() Introduce CONFIG_ENABLE_BUG_CHECKS to disable BUG{_ON} by default treewide: convert assert() to BUG_ON() Remove assert()
README | 10 ---- arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 3 + arch/arm/mach-exynos/clock.c | 4 +- arch/arm/mach-tegra/clock.c | 10 ++-- arch/arm/mach-tegra/pinmux-common.c | 80 +++++++++++++-------------- arch/arm/mach-tegra/tegra114/clock.c | 10 ++-- arch/arm/mach-tegra/tegra124/clock.c | 10 ++-- arch/arm/mach-tegra/tegra20/clock.c | 14 ++--- arch/arm/mach-tegra/tegra210/clock.c | 10 ++-- arch/arm/mach-tegra/tegra30/clock.c | 10 ++-- arch/powerpc/cpu/mpc85xx/Kconfig | 37 +++++++++++++ arch/sandbox/cpu/state.c | 4 +- arch/x86/cpu/intel_common/mrc.c | 2 +- arch/x86/lib/efi/efi.c | 2 +- arch/x86/lib/fsp/fsp_support.c | 6 +- arch/x86/lib/physmem.c | 5 +- board/freescale/qemu-ppce500/qemu-ppce500.c | 8 +-- cmd/bootefi.c | 2 +- cmd/mtdparts.c | 2 +- cmd/tpm_test.c | 28 +++++----- common/dlmalloc.c | 86 ++++++++++++++--------------- common/fdt_support.c | 2 +- common/hwconfig.c | 36 ++++++------ configs/TWR-P1025_defconfig | 1 + configs/UCP1020_SPIFLASH_defconfig | 1 + configs/UCP1020_defconfig | 1 + configs/adp-ae3xx_defconfig | 1 + configs/cl-som-imx7_defconfig | 1 + configs/evb-rk3229_defconfig | 1 + configs/mccmon6_sd_defconfig | 1 + configs/opos6uldev_defconfig | 1 + configs/qemu-ppce500_defconfig | 1 + configs/tricorder_defconfig | 1 + configs/tricorder_flash_defconfig | 1 + configs/uniphier_ld4_sld8_defconfig | 1 + configs/uniphier_v7_defconfig | 1 + configs/uniphier_v8_defconfig | 1 + configs/xpedite517x_defconfig | 1 + configs/xpedite520x_defconfig | 1 + configs/xpedite537x_defconfig | 1 + configs/xpedite550x_defconfig | 1 + drivers/clk/clk-uclass.c | 2 +- drivers/clk/rockchip/clk_rk3036.c | 23 ++++---- drivers/clk/rockchip/clk_rk3128.c | 27 ++++----- drivers/clk/rockchip/clk_rk3188.c | 28 ++++------ drivers/clk/rockchip/clk_rk322x.c | 23 ++++---- drivers/clk/rockchip/clk_rk3288.c | 36 +++++------- drivers/clk/rockchip/clk_rk3328.c | 8 +-- drivers/clk/rockchip/clk_rk3368.c | 4 +- drivers/clk/rockchip/clk_rk3399.c | 51 +++++++---------- drivers/clk/rockchip/clk_rv1108.c | 2 +- drivers/core/device-remove.c | 8 +-- drivers/core/device.c | 2 +- drivers/core/ofnode.c | 24 ++++---- drivers/core/uclass.c | 4 +- drivers/gpio/gpio-uclass.c | 2 +- drivers/i2c/i2c-uclass.c | 2 +- drivers/input/input.c | 4 +- drivers/input/key_matrix.c | 2 +- drivers/misc/cros_ec.c | 10 ++-- drivers/misc/cros_ec_i2c.c | 4 +- drivers/mtd/nand/tegra_nand.c | 2 +- drivers/mtd/spi/sandbox.c | 4 +- drivers/net/fsl-mc/mc.c | 2 +- drivers/phy/phy-uclass.c | 2 +- drivers/power/tps6586x.c | 4 +- drivers/rtc/rtc-uclass.c | 10 ++-- drivers/sound/sound.c | 2 +- drivers/spi/exynos_spi.c | 6 +- drivers/usb/emul/sandbox_flash.c | 2 +- drivers/usb/host/usb-uclass.c | 4 +- drivers/video/stb_truetype.h | 2 +- fs/ext4/dev.c | 2 +- fs/ext4/ext4_common.c | 2 +- fs/ext4/ext4_journal.c | 2 +- fs/fat/fat.c | 2 +- include/common.h | 15 ----- include/configs/B4860QDS.h | 1 - include/configs/C29XPCIE.h | 1 - include/configs/MPC8536DS.h | 1 - include/configs/MPC8544DS.h | 1 - include/configs/MPC8572DS.h | 1 - include/configs/P1010RDB.h | 1 - include/configs/P1023RDB.h | 2 - include/configs/P2041RDB.h | 1 - include/configs/T102xQDS.h | 1 - include/configs/T102xRDB.h | 1 - include/configs/T1040QDS.h | 1 - include/configs/T104xRDB.h | 1 - include/configs/T4240RDB.h | 1 - include/configs/UCP1020.h | 1 - include/configs/adp-ae3xx.h | 1 - include/configs/corenet_ds.h | 1 - include/configs/cyrus.h | 1 - include/configs/ls1012a_common.h | 1 - include/configs/ls1088a_common.h | 2 - include/configs/ls2080a_common.h | 2 - include/configs/p1_p2_rdb_pc.h | 1 - include/configs/p1_twr.h | 1 - include/configs/qemu-ppce500.h | 1 - include/configs/t4qds.h | 1 - include/configs/tricorder.h | 1 - include/configs/uniphier.h | 2 - include/configs/xpedite517x.h | 1 - include/configs/xpedite520x.h | 1 - include/configs/xpedite537x.h | 1 - include/configs/xpedite550x.h | 1 - include/configs/xtfpga.h | 4 -- include/dm/ofnode.h | 4 +- include/efi_loader.h | 12 ++-- include/linux/bug.h | 9 ++- lib/Kconfig | 17 ++++++ lib/circbuf.c | 16 +++--- lib/efi_loader/efi_boottime.c | 2 +- lib/efi_loader/efi_device_path.c | 2 +- lib/efi_loader/efi_file.c | 2 +- lib/efi_loader/efi_memory.c | 2 +- lib/fdtdec.c | 8 +-- lib/membuff.c | 4 +- lib/physmem.c | 4 +- lib/qsort.c | 2 +- lib/slre.c | 8 +-- lib/tiny-printf.c | 9 --- lib/vsprintf.c | 9 --- net/eth-uclass.c | 2 +- net/eth_legacy.c | 2 +- net/net.c | 2 +- test/command_ut.c | 30 +++++----- test/compression.c | 16 +++--- test/print_ut.c | 42 +++++++------- 130 files changed, 466 insertions(+), 504 deletions(-)
Freescale (NXP) boards have lots of defconfig files per board. I used "imply PANIC_HANG" for them.
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
Changes in v2: - Re-run tools/moveconfig.py based on commit 02907004294d9
README | 10 --------- arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 3 +++ arch/powerpc/cpu/mpc85xx/Kconfig | 37 +++++++++++++++++++++++++++++++ configs/TWR-P1025_defconfig | 1 + configs/UCP1020_SPIFLASH_defconfig | 1 + configs/UCP1020_defconfig | 1 + configs/adp-ae3xx_defconfig | 1 + configs/qemu-ppce500_defconfig | 1 + configs/tricorder_defconfig | 1 + configs/tricorder_flash_defconfig | 1 + configs/uniphier_ld4_sld8_defconfig | 1 + configs/uniphier_v7_defconfig | 1 + configs/uniphier_v8_defconfig | 1 + configs/xpedite517x_defconfig | 1 + configs/xpedite520x_defconfig | 1 + configs/xpedite537x_defconfig | 1 + configs/xpedite550x_defconfig | 1 + include/configs/B4860QDS.h | 1 - include/configs/C29XPCIE.h | 1 - include/configs/MPC8536DS.h | 1 - include/configs/MPC8544DS.h | 1 - include/configs/MPC8572DS.h | 1 - include/configs/P1010RDB.h | 1 - include/configs/P1023RDB.h | 2 -- include/configs/P2041RDB.h | 1 - include/configs/T102xQDS.h | 1 - include/configs/T102xRDB.h | 1 - include/configs/T1040QDS.h | 1 - include/configs/T104xRDB.h | 1 - include/configs/T4240RDB.h | 1 - include/configs/UCP1020.h | 1 - include/configs/adp-ae3xx.h | 1 - include/configs/corenet_ds.h | 1 - include/configs/cyrus.h | 1 - include/configs/ls1012a_common.h | 1 - include/configs/ls1088a_common.h | 2 -- include/configs/ls2080a_common.h | 2 -- include/configs/p1_p2_rdb_pc.h | 1 - include/configs/p1_twr.h | 1 - include/configs/qemu-ppce500.h | 1 - include/configs/t4qds.h | 1 - include/configs/tricorder.h | 1 - include/configs/uniphier.h | 2 -- include/configs/xpedite517x.h | 1 - include/configs/xpedite520x.h | 1 - include/configs/xpedite537x.h | 1 - include/configs/xpedite550x.h | 1 - include/configs/xtfpga.h | 4 ---- lib/Kconfig | 10 +++++++++ 49 files changed, 64 insertions(+), 48 deletions(-)
diff --git a/README b/README index 2df0e1f..a7d2bef 100644 --- a/README +++ b/README @@ -2168,16 +2168,6 @@ The following options need to be configured: currently only supports clearing the memory.
- Error Recovery: - CONFIG_PANIC_HANG - - Define this variable to stop the system in case of a - fatal error, so that you have to reset it manually. - This is probably NOT a good idea for an embedded - system where you want the system to reboot - automatically as fast as possible, but it may be - useful during development since you can try to debug - the conditions that lead to the situation. - CONFIG_NET_RETRY_COUNT
This variable defines the number of retries for diff --git a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig index 5daf79e..e866193 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig +++ b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig @@ -7,6 +7,7 @@ config ARCH_LS1012A select SYS_FSL_ERRATUM_A010315 select ARCH_EARLY_INIT_R select BOARD_EARLY_INIT_F + imply PANIC_HANG
config ARCH_LS1043A bool @@ -85,6 +86,7 @@ config ARCH_LS1088A select ARCH_EARLY_INIT_R select BOARD_EARLY_INIT_F imply SCSI + imply PANIC_HANG
config ARCH_LS2080A bool @@ -123,6 +125,7 @@ config ARCH_LS2080A select SYS_FSL_ERRATUM_A009203 select ARCH_EARLY_INIT_R select BOARD_EARLY_INIT_F + imply PANIC_HANG
config FSL_LSCH2 bool diff --git a/arch/powerpc/cpu/mpc85xx/Kconfig b/arch/powerpc/cpu/mpc85xx/Kconfig index 92187d3..91fcc43 100644 --- a/arch/powerpc/cpu/mpc85xx/Kconfig +++ b/arch/powerpc/cpu/mpc85xx/Kconfig @@ -29,6 +29,7 @@ config TARGET_B4420QDS select ARCH_B4420 select SUPPORT_SPL select PHYS_64BIT + imply PANIC_HANG
config TARGET_B4860QDS bool "Support B4860QDS" @@ -36,6 +37,7 @@ config TARGET_B4860QDS select BOARD_LATE_INIT if CHAIN_OF_TRUST select SUPPORT_SPL select PHYS_64BIT + imply PANIC_HANG
config TARGET_BSC9131RDB bool "Support BSC9131RDB" @@ -57,6 +59,7 @@ config TARGET_C29XPCIE select SUPPORT_SPL select SUPPORT_TPL select PHYS_64BIT + imply PANIC_HANG
config TARGET_P3041DS bool "Support P3041DS" @@ -64,6 +67,7 @@ config TARGET_P3041DS select ARCH_P3041 select BOARD_LATE_INIT if CHAIN_OF_TRUST imply CMD_SATA + imply PANIC_HANG
config TARGET_P4080DS bool "Support P4080DS" @@ -71,6 +75,7 @@ config TARGET_P4080DS select ARCH_P4080 select BOARD_LATE_INIT if CHAIN_OF_TRUST imply CMD_SATA + imply PANIC_HANG
config TARGET_P5020DS bool "Support P5020DS" @@ -78,6 +83,7 @@ config TARGET_P5020DS select ARCH_P5020 select BOARD_LATE_INIT if CHAIN_OF_TRUST imply CMD_SATA + imply PANIC_HANG
config TARGET_P5040DS bool "Support P5040DS" @@ -85,6 +91,7 @@ config TARGET_P5040DS select ARCH_P5040 select BOARD_LATE_INIT if CHAIN_OF_TRUST imply CMD_SATA + imply PANIC_HANG
config TARGET_MPC8536DS bool "Support MPC8536DS" @@ -92,6 +99,7 @@ config TARGET_MPC8536DS # Use DDR3 controller with DDR2 DIMMs on this board select SYS_FSL_DDRC_GEN3 imply CMD_SATA + imply PANIC_HANG
config TARGET_MPC8541CDS bool "Support MPC8541CDS" @@ -100,6 +108,7 @@ config TARGET_MPC8541CDS config TARGET_MPC8544DS bool "Support MPC8544DS" select ARCH_MPC8544 + imply PANIC_HANG
config TARGET_MPC8548CDS bool "Support MPC8548CDS" @@ -123,6 +132,7 @@ config TARGET_MPC8572DS # Use DDR3 controller with DDR2 DIMMs on this board select SYS_FSL_DDRC_GEN3 imply SCSI + imply PANIC_HANG
config TARGET_P1010RDB_PA bool "Support P1010RDB_PA" @@ -132,6 +142,7 @@ config TARGET_P1010RDB_PA select SUPPORT_TPL imply CMD_EEPROM imply CMD_SATA + imply PANIC_HANG
config TARGET_P1010RDB_PB bool "Support P1010RDB_PB" @@ -141,6 +152,7 @@ config TARGET_P1010RDB_PB select SUPPORT_TPL imply CMD_EEPROM imply CMD_SATA + imply PANIC_HANG
config TARGET_P1022DS bool "Support P1022DS" @@ -153,6 +165,7 @@ config TARGET_P1023RDB bool "Support P1023RDB" select ARCH_P1023 imply CMD_EEPROM + imply PANIC_HANG
config TARGET_P1020MBG bool "Support P1020MBG-PC" @@ -161,6 +174,7 @@ config TARGET_P1020MBG select ARCH_P1020 imply CMD_EEPROM imply CMD_SATA + imply PANIC_HANG
config TARGET_P1020RDB_PC bool "Support P1020RDB-PC" @@ -169,6 +183,7 @@ config TARGET_P1020RDB_PC select ARCH_P1020 imply CMD_EEPROM imply CMD_SATA + imply PANIC_HANG
config TARGET_P1020RDB_PD bool "Support P1020RDB-PD" @@ -177,6 +192,7 @@ config TARGET_P1020RDB_PD select ARCH_P1020 imply CMD_EEPROM imply CMD_SATA + imply PANIC_HANG
config TARGET_P1020UTM bool "Support P1020UTM" @@ -185,6 +201,7 @@ config TARGET_P1020UTM select ARCH_P1020 imply CMD_EEPROM imply CMD_SATA + imply PANIC_HANG
config TARGET_P1021RDB bool "Support P1021RDB" @@ -193,6 +210,7 @@ config TARGET_P1021RDB select ARCH_P1021 imply CMD_EEPROM imply CMD_SATA + imply PANIC_HANG
config TARGET_P1024RDB bool "Support P1024RDB" @@ -201,6 +219,7 @@ config TARGET_P1024RDB select ARCH_P1024 imply CMD_EEPROM imply CMD_SATA + imply PANIC_HANG
config TARGET_P1025RDB bool "Support P1025RDB" @@ -209,6 +228,7 @@ config TARGET_P1025RDB select ARCH_P1025 imply CMD_EEPROM imply CMD_SATA + imply PANIC_HANG
config TARGET_P2020RDB bool "Support P2020RDB-PC" @@ -217,6 +237,7 @@ config TARGET_P2020RDB select ARCH_P2020 imply CMD_EEPROM imply CMD_SATA + imply PANIC_HANG
config TARGET_P1_TWR bool "Support p1_twr" @@ -228,6 +249,7 @@ config TARGET_P2041RDB select BOARD_LATE_INIT if CHAIN_OF_TRUST select PHYS_64BIT imply CMD_SATA + imply PANIC_HANG
config TARGET_QEMU_PPCE500 bool "Support qemu-ppce500" @@ -242,6 +264,7 @@ config TARGET_T1024QDS select PHYS_64BIT imply CMD_EEPROM imply CMD_SATA + imply PANIC_HANG
config TARGET_T1023RDB bool "Support T1023RDB" @@ -250,6 +273,7 @@ config TARGET_T1023RDB select SUPPORT_SPL select PHYS_64BIT imply CMD_EEPROM + imply PANIC_HANG
config TARGET_T1024RDB bool "Support T1024RDB" @@ -258,6 +282,7 @@ config TARGET_T1024RDB select SUPPORT_SPL select PHYS_64BIT imply CMD_EEPROM + imply PANIC_HANG
config TARGET_T1040QDS bool "Support T1040QDS" @@ -266,6 +291,7 @@ config TARGET_T1040QDS select PHYS_64BIT imply CMD_EEPROM imply CMD_SATA + imply PANIC_HANG
config TARGET_T1040RDB bool "Support T1040RDB" @@ -274,6 +300,7 @@ config TARGET_T1040RDB select SUPPORT_SPL select PHYS_64BIT imply CMD_SATA + imply PANIC_HANG
config TARGET_T1040D4RDB bool "Support T1040D4RDB" @@ -282,6 +309,7 @@ config TARGET_T1040D4RDB select SUPPORT_SPL select PHYS_64BIT imply CMD_SATA + imply PANIC_HANG
config TARGET_T1042RDB bool "Support T1042RDB" @@ -290,6 +318,7 @@ config TARGET_T1042RDB select SUPPORT_SPL select PHYS_64BIT imply CMD_SATA + imply PANIC_HANG
config TARGET_T1042D4RDB bool "Support T1042D4RDB" @@ -298,6 +327,7 @@ config TARGET_T1042D4RDB select SUPPORT_SPL select PHYS_64BIT imply CMD_SATA + imply PANIC_HANG
config TARGET_T1042RDB_PI bool "Support T1042RDB_PI" @@ -306,6 +336,7 @@ config TARGET_T1042RDB_PI select SUPPORT_SPL select PHYS_64BIT imply CMD_SATA + imply PANIC_HANG
config TARGET_T2080QDS bool "Support T2080QDS" @@ -336,12 +367,14 @@ config TARGET_T4160QDS select SUPPORT_SPL select PHYS_64BIT imply CMD_SATA + imply PANIC_HANG
config TARGET_T4160RDB bool "Support T4160RDB" select ARCH_T4160 select SUPPORT_SPL select PHYS_64BIT + imply PANIC_HANG
config TARGET_T4240QDS bool "Support T4240QDS" @@ -350,6 +383,7 @@ config TARGET_T4240QDS select SUPPORT_SPL select PHYS_64BIT imply CMD_SATA + imply PANIC_HANG
config TARGET_T4240RDB bool "Support T4240RDB" @@ -357,6 +391,7 @@ config TARGET_T4240RDB select SUPPORT_SPL select PHYS_64BIT imply CMD_SATA + imply PANIC_HANG
config TARGET_CONTROLCENTERD bool "Support controlcenterd" @@ -392,11 +427,13 @@ config TARGET_CYRUS_P5020 bool "Support Varisys Cyrus P5020" select ARCH_P5020 select PHYS_64BIT + imply PANIC_HANG
config TARGET_CYRUS_P5040 bool "Support Varisys Cyrus P5040" select ARCH_P5040 select PHYS_64BIT + imply PANIC_HANG
endchoice
diff --git a/configs/TWR-P1025_defconfig b/configs/TWR-P1025_defconfig index 5dda2bb..45923db 100644 --- a/configs/TWR-P1025_defconfig +++ b/configs/TWR-P1025_defconfig @@ -34,4 +34,5 @@ CONFIG_SYS_NS16550=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_PANIC_HANG=y CONFIG_OF_LIBFDT=y diff --git a/configs/UCP1020_SPIFLASH_defconfig b/configs/UCP1020_SPIFLASH_defconfig index c8f2262..3c3e9fc 100644 --- a/configs/UCP1020_SPIFLASH_defconfig +++ b/configs/UCP1020_SPIFLASH_defconfig @@ -43,4 +43,5 @@ CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_FS_CRAMFS=y +CONFIG_PANIC_HANG=y CONFIG_OF_LIBFDT=y diff --git a/configs/UCP1020_defconfig b/configs/UCP1020_defconfig index 0092e99..bd17e05 100644 --- a/configs/UCP1020_defconfig +++ b/configs/UCP1020_defconfig @@ -43,4 +43,5 @@ CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_FS_CRAMFS=y +CONFIG_PANIC_HANG=y CONFIG_OF_LIBFDT=y diff --git a/configs/adp-ae3xx_defconfig b/configs/adp-ae3xx_defconfig index 6005669..cdbf801 100644 --- a/configs/adp-ae3xx_defconfig +++ b/configs/adp-ae3xx_defconfig @@ -39,3 +39,4 @@ CONFIG_DM_SPI=y CONFIG_ATCSPI200_SPI=y CONFIG_TIMER=y CONFIG_ATCPIT100_TIMER=y +CONFIG_PANIC_HANG=y diff --git a/configs/qemu-ppce500_defconfig b/configs/qemu-ppce500_defconfig index f1db0d0..9d27755 100644 --- a/configs/qemu-ppce500_defconfig +++ b/configs/qemu-ppce500_defconfig @@ -24,4 +24,5 @@ CONFIG_DOS_PARTITION=y CONFIG_NETDEVICES=y CONFIG_E1000=y CONFIG_SYS_NS16550=y +CONFIG_PANIC_HANG=y CONFIG_OF_LIBFDT=y diff --git a/configs/tricorder_defconfig b/configs/tricorder_defconfig index 0f6cccc..27a3b6e 100644 --- a/configs/tricorder_defconfig +++ b/configs/tricorder_defconfig @@ -40,4 +40,5 @@ CONFIG_NAND=y CONFIG_SPL_NAND_SIMPLE=y CONFIG_SYS_NS16550=y CONFIG_BCH=y +CONFIG_PANIC_HANG=y CONFIG_OF_LIBFDT=y diff --git a/configs/tricorder_flash_defconfig b/configs/tricorder_flash_defconfig index 7477b42..78afec0 100644 --- a/configs/tricorder_flash_defconfig +++ b/configs/tricorder_flash_defconfig @@ -39,4 +39,5 @@ CONFIG_NAND=y CONFIG_SPL_NAND_SIMPLE=y CONFIG_SYS_NS16550=y CONFIG_BCH=y +CONFIG_PANIC_HANG=y CONFIG_OF_LIBFDT=y diff --git a/configs/uniphier_ld4_sld8_defconfig b/configs/uniphier_ld4_sld8_defconfig index 542cebd..2f5c986 100644 --- a/configs/uniphier_ld4_sld8_defconfig +++ b/configs/uniphier_ld4_sld8_defconfig @@ -53,3 +53,4 @@ CONFIG_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y CONFIG_USB_STORAGE=y +CONFIG_PANIC_HANG=y diff --git a/configs/uniphier_v7_defconfig b/configs/uniphier_v7_defconfig index 9082ba5..42247cb 100644 --- a/configs/uniphier_v7_defconfig +++ b/configs/uniphier_v7_defconfig @@ -56,3 +56,4 @@ CONFIG_USB_EHCI_GENERIC=y CONFIG_USB_DWC3=y CONFIG_USB_DWC3_UNIPHIER=y CONFIG_USB_STORAGE=y +CONFIG_PANIC_HANG=y diff --git a/configs/uniphier_v8_defconfig b/configs/uniphier_v8_defconfig index 746e451..007f4f3 100644 --- a/configs/uniphier_v8_defconfig +++ b/configs/uniphier_v8_defconfig @@ -53,3 +53,4 @@ CONFIG_USB_EHCI_GENERIC=y CONFIG_USB_DWC3=y CONFIG_USB_DWC3_UNIPHIER=y CONFIG_USB_STORAGE=y +CONFIG_PANIC_HANG=y diff --git a/configs/xpedite517x_defconfig b/configs/xpedite517x_defconfig index a2324c3..3773518 100644 --- a/configs/xpedite517x_defconfig +++ b/configs/xpedite517x_defconfig @@ -27,4 +27,5 @@ CONFIG_DS4510=y CONFIG_MTD_NOR_FLASH=y CONFIG_PHYLIB=y CONFIG_SYS_NS16550=y +CONFIG_PANIC_HANG=y CONFIG_OF_LIBFDT=y diff --git a/configs/xpedite520x_defconfig b/configs/xpedite520x_defconfig index 7518ef2..7fffaa8 100644 --- a/configs/xpedite520x_defconfig +++ b/configs/xpedite520x_defconfig @@ -28,4 +28,5 @@ CONFIG_CMD_PCA953X=y CONFIG_MTD_NOR_FLASH=y CONFIG_PHYLIB=y CONFIG_SYS_NS16550=y +CONFIG_PANIC_HANG=y CONFIG_OF_LIBFDT=y diff --git a/configs/xpedite537x_defconfig b/configs/xpedite537x_defconfig index ead06a7..223bc4c 100644 --- a/configs/xpedite537x_defconfig +++ b/configs/xpedite537x_defconfig @@ -30,4 +30,5 @@ CONFIG_DS4510=y CONFIG_MTD_NOR_FLASH=y CONFIG_PHYLIB=y CONFIG_SYS_NS16550=y +CONFIG_PANIC_HANG=y CONFIG_OF_LIBFDT=y diff --git a/configs/xpedite550x_defconfig b/configs/xpedite550x_defconfig index 80bc914..f3b9280 100644 --- a/configs/xpedite550x_defconfig +++ b/configs/xpedite550x_defconfig @@ -30,4 +30,5 @@ CONFIG_PHYLIB=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_PANIC_HANG=y CONFIG_OF_LIBFDT=y diff --git a/include/configs/B4860QDS.h b/include/configs/B4860QDS.h index 661bc8b..b1b6725 100644 --- a/include/configs/B4860QDS.h +++ b/include/configs/B4860QDS.h @@ -173,7 +173,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_MEMTEST_START 0x00200000 /* memtest works on */ #define CONFIG_SYS_MEMTEST_END 0x00400000 #define CONFIG_SYS_ALT_MEMTEST -#define CONFIG_PANIC_HANG /* do not reset board on panic */
/* * Config the L3 Cache as L3 SRAM diff --git a/include/configs/C29XPCIE.h b/include/configs/C29XPCIE.h index 7e805ec..f9d8cc6 100644 --- a/include/configs/C29XPCIE.h +++ b/include/configs/C29XPCIE.h @@ -117,7 +117,6 @@
#define CONFIG_SYS_MEMTEST_START 0x00200000 #define CONFIG_SYS_MEMTEST_END 0x00400000 -#define CONFIG_PANIC_HANG
/* DDR Setup */ #define CONFIG_DDR_SPD diff --git a/include/configs/MPC8536DS.h b/include/configs/MPC8536DS.h index 3319a6f..ad339f1 100644 --- a/include/configs/MPC8536DS.h +++ b/include/configs/MPC8536DS.h @@ -69,7 +69,6 @@
#define CONFIG_SYS_MEMTEST_START 0x00010000 /* skip exception vectors */ #define CONFIG_SYS_MEMTEST_END 0x1f000000 /* skip u-boot at top of RAM */ -#define CONFIG_PANIC_HANG /* do not reset board on panic */
/* * Config the L2 Cache as L2 SRAM diff --git a/include/configs/MPC8544DS.h b/include/configs/MPC8544DS.h index 2aea892..8b8e1f5 100644 --- a/include/configs/MPC8544DS.h +++ b/include/configs/MPC8544DS.h @@ -46,7 +46,6 @@ extern unsigned long get_board_sys_clk(unsigned long dummy);
#define CONFIG_SYS_MEMTEST_START 0x00200000 /* memtest works on */ #define CONFIG_SYS_MEMTEST_END 0x00400000 -#define CONFIG_PANIC_HANG /* do not reset board on panic */
#define CONFIG_SYS_CCSRBAR 0xe0000000 #define CONFIG_SYS_CCSRBAR_PHYS_LOW CONFIG_SYS_CCSRBAR diff --git a/include/configs/MPC8572DS.h b/include/configs/MPC8572DS.h index b277cdb..634a9e1 100644 --- a/include/configs/MPC8572DS.h +++ b/include/configs/MPC8572DS.h @@ -58,7 +58,6 @@
#define CONFIG_SYS_MEMTEST_START 0x00000000 /* memtest works on */ #define CONFIG_SYS_MEMTEST_END 0x7fffffff -#define CONFIG_PANIC_HANG /* do not reset board on panic */
/* * Config the L2 Cache as L2 SRAM diff --git a/include/configs/P1010RDB.h b/include/configs/P1010RDB.h index cbc15ae..d50035d 100644 --- a/include/configs/P1010RDB.h +++ b/include/configs/P1010RDB.h @@ -215,7 +215,6 @@
#define CONFIG_SYS_MEMTEST_START 0x00200000 /* memtest works on */ #define CONFIG_SYS_MEMTEST_END 0x1fffffff -#define CONFIG_PANIC_HANG /* do not reset board on panic */
/* DDR Setup */ #define CONFIG_SYS_DDR_RAW_TIMING diff --git a/include/configs/P1023RDB.h b/include/configs/P1023RDB.h index 1b78a4f..17ae6cf 100644 --- a/include/configs/P1023RDB.h +++ b/include/configs/P1023RDB.h @@ -52,8 +52,6 @@ extern unsigned long get_clock_freq(void); #define CONFIG_SYS_MEMTEST_START 0x01000000 /* memtest works on */ #define CONFIG_SYS_MEMTEST_END 0x02000000
-#define CONFIG_PANIC_HANG /* do not reset board on panic */ - /* Implement conversion of addresses in the LBC */ #define CONFIG_SYS_LBC_LBCR 0x00000000 #define CONFIG_SYS_LBC_LCRR LCRR_CLKDIV_8 diff --git a/include/configs/P2041RDB.h b/include/configs/P2041RDB.h index 6008237..7e3a9f1 100644 --- a/include/configs/P2041RDB.h +++ b/include/configs/P2041RDB.h @@ -116,7 +116,6 @@ unsigned long get_board_sys_clk(unsigned long dummy); #define CONFIG_SYS_MEMTEST_START 0x00200000 /* memtest works on */ #define CONFIG_SYS_MEMTEST_END 0x00400000 #define CONFIG_SYS_ALT_MEMTEST -#define CONFIG_PANIC_HANG /* do not reset board on panic */
/* * Config the L3 Cache as L3 SRAM diff --git a/include/configs/T102xQDS.h b/include/configs/T102xQDS.h index 259e8a0..30632ca 100644 --- a/include/configs/T102xQDS.h +++ b/include/configs/T102xQDS.h @@ -196,7 +196,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_MEMTEST_START 0x00200000 /* memtest works on */ #define CONFIG_SYS_MEMTEST_END 0x00400000 #define CONFIG_SYS_ALT_MEMTEST -#define CONFIG_PANIC_HANG /* do not reset board on panic */
/* * Config the L3 Cache as L3 SRAM diff --git a/include/configs/T102xRDB.h b/include/configs/T102xRDB.h index 7dee2f0..791c6ef 100644 --- a/include/configs/T102xRDB.h +++ b/include/configs/T102xRDB.h @@ -219,7 +219,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_MEMTEST_START 0x00200000 /* memtest works on */ #define CONFIG_SYS_MEMTEST_END 0x00400000 #define CONFIG_SYS_ALT_MEMTEST -#define CONFIG_PANIC_HANG /* do not reset board on panic */
/* * Config the L3 Cache as L3 SRAM diff --git a/include/configs/T1040QDS.h b/include/configs/T1040QDS.h index c694e50..4e75a3f 100644 --- a/include/configs/T1040QDS.h +++ b/include/configs/T1040QDS.h @@ -127,7 +127,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_MEMTEST_START 0x00200000 /* memtest works on */ #define CONFIG_SYS_MEMTEST_END 0x00400000 #define CONFIG_SYS_ALT_MEMTEST -#define CONFIG_PANIC_HANG /* do not reset board on panic */
/* * Config the L3 Cache as L3 SRAM diff --git a/include/configs/T104xRDB.h b/include/configs/T104xRDB.h index 2dbeffd..27a1439 100644 --- a/include/configs/T104xRDB.h +++ b/include/configs/T104xRDB.h @@ -226,7 +226,6 @@ $(SRCTREE)/board/freescale/t104xrdb/t1042d4_sd_rcw.cfg #define CONFIG_SYS_MEMTEST_START 0x00200000 /* memtest works on */ #define CONFIG_SYS_MEMTEST_END 0x00400000 #define CONFIG_SYS_ALT_MEMTEST -#define CONFIG_PANIC_HANG /* do not reset board on panic */
/* * Config the L3 Cache as L3 SRAM diff --git a/include/configs/T4240RDB.h b/include/configs/T4240RDB.h index 625130a..ad192fe 100644 --- a/include/configs/T4240RDB.h +++ b/include/configs/T4240RDB.h @@ -96,7 +96,6 @@ #define CONFIG_SYS_MEMTEST_START 0x00200000 /* memtest works on */ #define CONFIG_SYS_MEMTEST_END 0x00400000 #define CONFIG_SYS_ALT_MEMTEST -#define CONFIG_PANIC_HANG /* do not reset board on panic */
/* * Config the L3 Cache as L3 SRAM diff --git a/include/configs/UCP1020.h b/include/configs/UCP1020.h index 902abc4..a526f83 100644 --- a/include/configs/UCP1020.h +++ b/include/configs/UCP1020.h @@ -138,7 +138,6 @@
#define CONFIG_SYS_CCSRBAR 0xffe00000 #define CONFIG_SYS_CCSRBAR_PHYS_LOW CONFIG_SYS_CCSRBAR diff --git a/include/configs/adp-ae3xx.h b/include/configs/adp-ae3xx.h index 5644a61..f75274e 100644 --- a/include/configs/adp-ae3xx.h +++ b/include/configs/adp-ae3xx.h @@ -21,7 +21,6 @@ #define CONFIG_SKIP_TRUNOFF_WATCHDOG
#define CONFIG_CMDLINE_EDITING -#define CONFIG_PANIC_HANG
#define CONFIG_ARCH_MAP_SYSMEM
diff --git a/include/configs/corenet_ds.h b/include/configs/corenet_ds.h index 0dbf149..a463235 100644 --- a/include/configs/corenet_ds.h +++ b/include/configs/corenet_ds.h @@ -128,7 +128,6 @@ #define CONFIG_SYS_MEMTEST_START 0x00200000 /* memtest works on */ #define CONFIG_SYS_MEMTEST_END 0x00400000 #define CONFIG_SYS_ALT_MEMTEST -#define CONFIG_PANIC_HANG /* do not reset board on panic */
/* * Config the L3 Cache as L3 SRAM diff --git a/include/configs/cyrus.h b/include/configs/cyrus.h index 1b20d85..685bff1 100644 --- a/include/configs/cyrus.h +++ b/include/configs/cyrus.h @@ -89,7 +89,6 @@ #define CONFIG_SYS_MEMTEST_START 0x00200000 /* memtest works on */ #define CONFIG_SYS_MEMTEST_END 0x00400000 #define CONFIG_SYS_ALT_MEMTEST -#define CONFIG_PANIC_HANG /* do not reset board on panic */
/* * Config the L3 Cache as L3 SRAM diff --git a/include/configs/ls1012a_common.h b/include/configs/ls1012a_common.h index d2fa50a..e73d988 100644 --- a/include/configs/ls1012a_common.h +++ b/include/configs/ls1012a_common.h @@ -109,7 +109,6 @@ #define CONFIG_AUTO_COMPLETE #define CONFIG_SYS_MAXARGS 64 /* max command args */
-#define CONFIG_PANIC_HANG #define CONFIG_SYS_BOOTM_LEN (64 << 20) /* Increase max gunzip size */
#include <asm/arch/soc.h> diff --git a/include/configs/ls1088a_common.h b/include/configs/ls1088a_common.h index 6b71d47..e543903 100644 --- a/include/configs/ls1088a_common.h +++ b/include/configs/ls1088a_common.h @@ -228,8 +228,6 @@ unsigned long long get_qixis_addr(void); #define CONFIG_AUTO_COMPLETE #define CONFIG_SYS_MAXARGS 64 /* max command args */
-#define CONFIG_PANIC_HANG /* do not reset board on panic */ - #ifdef CONFIG_SPL #define CONFIG_SPL_BSS_START_ADDR 0x80100000 #define CONFIG_SPL_BSS_MAX_SIZE 0x00100000 diff --git a/include/configs/ls2080a_common.h b/include/configs/ls2080a_common.h index f897869..ea74f4a 100644 --- a/include/configs/ls2080a_common.h +++ b/include/configs/ls2080a_common.h @@ -221,8 +221,6 @@ unsigned long long get_qixis_addr(void); #define CONFIG_AUTO_COMPLETE #define CONFIG_SYS_MAXARGS 64 /* max command args */
-#define CONFIG_PANIC_HANG /* do not reset board on panic */ - #define CONFIG_SPL_BSS_START_ADDR 0x80100000 #define CONFIG_SPL_BSS_MAX_SIZE 0x00100000 #define CONFIG_SPL_FRAMEWORK diff --git a/include/configs/p1_p2_rdb_pc.h b/include/configs/p1_p2_rdb_pc.h index 1b665b2..ac2921a 100644 --- a/include/configs/p1_p2_rdb_pc.h +++ b/include/configs/p1_p2_rdb_pc.h @@ -272,7 +272,6 @@
#define CONFIG_SYS_CCSRBAR 0xffe00000 #define CONFIG_SYS_CCSRBAR_PHYS_LOW CONFIG_SYS_CCSRBAR diff --git a/include/configs/p1_twr.h b/include/configs/p1_twr.h index e969204..9792ba3 100644 --- a/include/configs/p1_twr.h +++ b/include/configs/p1_twr.h @@ -71,7 +71,6 @@ extern unsigned long get_board_sys_clk(unsigned long dummy);
#define CONFIG_SYS_CCSRBAR 0xffe00000 #define CONFIG_SYS_CCSRBAR_PHYS_LOW CONFIG_SYS_CCSRBAR diff --git a/include/configs/qemu-ppce500.h b/include/configs/qemu-ppce500.h index eb4cfae..8b78f08 100644 --- a/include/configs/qemu-ppce500.h +++ b/include/configs/qemu-ppce500.h @@ -31,7 +31,6 @@ #define CONFIG_SYS_MEMTEST_START 0x00200000 /* memtest works on */ #define CONFIG_SYS_MEMTEST_END 0x00400000 #define CONFIG_SYS_ALT_MEMTEST -#define CONFIG_PANIC_HANG /* do not reset board on panic */
/* Needed to fill the ccsrbar pointer */
diff --git a/include/configs/t4qds.h b/include/configs/t4qds.h index 4938f43..47b78a2 100644 --- a/include/configs/t4qds.h +++ b/include/configs/t4qds.h @@ -54,7 +54,6 @@ #define CONFIG_SYS_MEMTEST_START 0x00200000 /* memtest works on */ #define CONFIG_SYS_MEMTEST_END 0x00400000 #define CONFIG_SYS_ALT_MEMTEST -#define CONFIG_PANIC_HANG /* do not reset board on panic */
/* * Config the L3 Cache as L3 SRAM diff --git a/include/configs/tricorder.h b/include/configs/tricorder.h index d9ab91c..f892a57 100644 --- a/include/configs/tricorder.h +++ b/include/configs/tricorder.h @@ -90,7 +90,6 @@
/* hang() the board on panic() */ -#define CONFIG_PANIC_HANG
/* environment placement (for NAND), is different for FLASHCARD but does not * harm there */ diff --git a/include/configs/uniphier.h b/include/configs/uniphier.h index 453f3db..12cbe9b 100644 --- a/include/configs/uniphier.h +++ b/include/configs/uniphier.h @@ -218,8 +218,6 @@ /* for LD20; the last 64 byte is used for dynamic DDR PHY training */ #define CONFIG_SYS_MEM_TOP_HIDE 64
-#define CONFIG_PANIC_HANG - #define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_TEXT_BASE)
/* only for SPL */ diff --git a/include/configs/xpedite517x.h b/include/configs/xpedite517x.h index beedc9e..4326984 100644 --- a/include/configs/xpedite517x.h +++ b/include/configs/xpedite517x.h @@ -487,7 +487,6 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); #define CONFIG_SYS_LOAD_ADDR 0x2000000 /* default load address */ #define CONFIG_CMDLINE_EDITING 1 /* Command-line editing */ #define CONFIG_LOADADDR 0x1000000 /* default location for tftp and bootm */ -#define CONFIG_PANIC_HANG /* do not reset board on panic */ #define CONFIG_PREBOOT /* enable preboot variable */ #define CONFIG_INTEGRITY /* support booting INTEGRITY OS */
diff --git a/include/configs/xpedite520x.h b/include/configs/xpedite520x.h index f589d1d..5a56162 100644 --- a/include/configs/xpedite520x.h +++ b/include/configs/xpedite520x.h @@ -291,7 +291,6 @@ #define CONFIG_CMDLINE_EDITING 1 /* add command line history */ #define CONFIG_AUTO_COMPLETE 1 /* add autocompletion support */ #define CONFIG_LOADADDR 0x1000000 /* default location for tftp and bootm */ -#define CONFIG_PANIC_HANG /* do not reset board on panic */ #define CONFIG_PREBOOT /* enable preboot variable */ #define CONFIG_INTEGRITY /* support booting INTEGRITY OS */ #define CONFIG_INTERRUPTS /* enable pci, srio, ddr interrupts */ diff --git a/include/configs/xpedite537x.h b/include/configs/xpedite537x.h index d217eb3..b262237 100644 --- a/include/configs/xpedite537x.h +++ b/include/configs/xpedite537x.h @@ -341,7 +341,6 @@ extern unsigned long get_board_ddr_clk(unsigned long dummy); #define CONFIG_CMDLINE_EDITING 1 /* add command line history */ #define CONFIG_AUTO_COMPLETE 1 /* add autocompletion support */ #define CONFIG_LOADADDR 0x1000000 /* default location for tftp and bootm */ -#define CONFIG_PANIC_HANG /* do not reset board on panic */ #define CONFIG_PREBOOT /* enable preboot variable */ #define CONFIG_INTEGRITY /* support booting INTEGRITY OS */
diff --git a/include/configs/xpedite550x.h b/include/configs/xpedite550x.h index 6c0981b..624e9a8 100644 --- a/include/configs/xpedite550x.h +++ b/include/configs/xpedite550x.h @@ -339,7 +339,6 @@ extern unsigned long get_board_ddr_clk(unsigned long dummy); #define CONFIG_CMDLINE_EDITING 1 /* add command line history */ #define CONFIG_AUTO_COMPLETE 1 /* add autocompletion support */ #define CONFIG_LOADADDR 0x1000000 /* default location for tftp and bootm */ -#define CONFIG_PANIC_HANG /* do not reset board on panic */ #define CONFIG_PREBOOT /* enable preboot variable */ #define CONFIG_INTEGRITY /* support booting INTEGRITY OS */
diff --git a/include/configs/xtfpga.h b/include/configs/xtfpga.h index 3050f17..3119f00 100644 --- a/include/configs/xtfpga.h +++ b/include/configs/xtfpga.h @@ -130,10 +130,6 @@ #define CONFIG_MX_CYCLIC #define CONFIG_SHOW_BOOT_PROGRESS
-#ifdef DEBUG -#define CONFIG_PANIC_HANG 1 /* Require manual reboot */ -#endif -
/*=========================================*/ /* FPGA Registers (board info and control) */ diff --git a/lib/Kconfig b/lib/Kconfig index f447c53..00ac650 100644 --- a/lib/Kconfig +++ b/lib/Kconfig @@ -45,6 +45,16 @@ config USE_TINY_PRINTF
The supported format specifiers are %c, %s, %u/%d and %x.
+config PANIC_HANG + bool "Do not reset the system on fatal error" + help + Define this option to stop the system in case of a fatal error, + so that you have to reset it manually. This is probably NOT a good + idea for an embedded system where you want the system to reboot + automatically as fast as possible, but it may be useful during + development since you can try to debug the conditions that lead to + the situation. + config REGEX bool "Enable regular expression support" default y if NET
Changes in v2:
Freescape/NXP has multiple configuration for each board, and sometimes multiple boards for each SoC. I am not objecting "imply PANIC_HANG" for all of them.
Reviewed-by: York Sun york.sun@nxp.com
York
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com Reviewed-by: York Sun york.sun@nxp.com
Calling panic() for these boards causes build error: undefined reference to `do_reset'
They must compile do_reset(), or define CONFIG_PANIC_HANG.
Changes in v2: None
configs/cl-som-imx7_defconfig | 1 + configs/evb-rk3229_defconfig | 1 + configs/mccmon6_sd_defconfig | 1 + configs/opos6uldev_defconfig | 1 + 4 files changed, 4 insertions(+)
diff --git a/configs/cl-som-imx7_defconfig b/configs/cl-som-imx7_defconfig index d37c82c..150396f 100644 --- a/configs/cl-som-imx7_defconfig +++ b/configs/cl-som-imx7_defconfig @@ -51,3 +51,4 @@ CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y CONFIG_CI_UDC=y CONFIG_OF_LIBFDT=y +CONFIG_PANIC_HANG=y diff --git a/configs/evb-rk3229_defconfig b/configs/evb-rk3229_defconfig index b226f66..21c1bfd 100644 --- a/configs/evb-rk3229_defconfig +++ b/configs/evb-rk3229_defconfig @@ -48,3 +48,4 @@ CONFIG_USB_GADGET_VENDOR_NUM=0x2207 CONFIG_USB_GADGET_PRODUCT_NUM=0x320a CONFIG_USB_GADGET_DWC2_OTG=y CONFIG_ERRNO_STR=y +CONFIG_PANIC_HANG=y diff --git a/configs/mccmon6_sd_defconfig b/configs/mccmon6_sd_defconfig index 97f7f9a..3f00ead 100644 --- a/configs/mccmon6_sd_defconfig +++ b/configs/mccmon6_sd_defconfig @@ -44,3 +44,4 @@ CONFIG_DM_THERMAL=y CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_OF_LIBFDT=y +CONFIG_PANIC_HANG=y diff --git a/configs/opos6uldev_defconfig b/configs/opos6uldev_defconfig index 0149ae3..51ebc73 100644 --- a/configs/opos6uldev_defconfig +++ b/configs/opos6uldev_defconfig @@ -84,3 +84,4 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_VIDEO=y CONFIG_OF_LIBFDT_OVERLAY=y # CONFIG_EFI_LOADER is not set +CONFIG_PANIC_HANG=y
On 3 December 2017 at 20:37, Masahiro Yamada yamada.masahiro@socionext.com wrote:
Changes in v2: None
BUG() and BUG_ON() are generally used to test a condition that should never happen. If it does, it is a bug.
Linux always enables them, but doing so in U-Boot causes image size problems on some platforms. Introduce CONFIG_ENABLE_BUG_CHECKS to make them no-op by default. Platforms without image size constraint are free to enable this option to catch bugs easily.
Likewise, silence WARN_ON() unless this option is enabled.
Suggested-by: Tom Rini trini@konsulko.com Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
Changes in v2: - Newly added
include/linux/bug.h | 9 ++++++++- lib/Kconfig | 7 +++++++ 2 files changed, 15 insertions(+), 1 deletion(-)
diff --git a/include/linux/bug.h b/include/linux/bug.h index f07bb71..ac1c7de 100644 --- a/include/linux/bug.h +++ b/include/linux/bug.h @@ -6,17 +6,24 @@ #include <linux/compiler.h> #include <linux/printk.h>
+#ifdef CONFIG_ENABLE_BUG_CHECKS #define BUG() do { \ printk("BUG at %s:%d/%s()!\n", __FILE__, __LINE__, __func__); \ panic("BUG!"); \ } while (0) +#define __WARN() \ + printk("WARNING at %s:%d/%s()!\n", __FILE__, __LINE__, __func__) +#else +#define BUG() +#define __WARN() +#endif
#define BUG_ON(condition) do { if (unlikely(condition)) BUG(); } while (0)
#define WARN_ON(condition) ({ \ int __ret_warn_on = !!(condition); \ if (unlikely(__ret_warn_on)) \ - printk("WARNING at %s:%d/%s()!\n", __FILE__, __LINE__, __func__); \ + __WARN(); \ unlikely(__ret_warn_on); \ })
diff --git a/lib/Kconfig b/lib/Kconfig index 00ac650..36b1b3b 100644 --- a/lib/Kconfig +++ b/lib/Kconfig @@ -45,6 +45,13 @@ config USE_TINY_PRINTF
+config ENABLE_BUG_CHECKS + bool "Enable BUG/BUG_ON() checks and WARN_ON() logs" + help + BUG() and BUG_ON() are no-op by default. This option enables + them to print noisy messages, then reboot or halt the system. + It also enables WARN_ON() messages. + config PANIC_HANG bool "Do not reset the system on fatal error" help
Changes in v2:
- Newly added
Changes in v2:
- Newly added
unlikely(__ret_warn_on); \__WARN(); \
- bool "Enable BUG/BUG_ON() checks and WARN_ON() logs"
- help
This should be 'default y' IMO to keep the current behaviour for all existing platforms.
Lothar Waßmann
Changes in v2:
- Newly added
- help
I brought this up to Masahiro privately as I had been testing the series, and with ENABLE_BUG_CHECKS=n we get a warning over in the USB code, which in turn got me thinking harder. We do want to be able to disable this, for space reasons, when needed, but it should default to enabled (even if this increases the overall size).
2017-12-12 22:47 GMT+09:00 Tom Rini trini@konsulko.com:
Changes in v2:
- Newly added
- help
-- Tom
I will flip the default in v3. Tom privately mentioned this series would be postponed by the next MW. So, I will do v3 when he is ready to receive it.
We do not need multiple ways to do the same thing. Instead of assert(), use BUG_ON() from Linux. The logic is opposite, but Coccinelle is of great help for such a conversion. We could simply convert assert(x) to BUG_ON(!x) for all expressions "x", but I did a bit better job by converting assert(a == b) to BUG_ON(a != b), etc.
The semantic patch I used is as follows:
// <smpl> @@@@ -assert(0) +BUG() @@ expression a; @@ -assert((a)) +assert(a) @@ expression a; @@ -assert(a == 0) +BUG_ON(a) @@ expression a; @@ -assert(a == NULL) +BUG_ON(a) @@ expression a; @@ -assert(a != 0) +BUG_ON(!a) @@ expression a; @@ -assert(a != NULL) +BUG_ON(!a) @@ expression a, b; @@ -assert(a == b) +BUG_ON(a != b) @@ expression a, b; @@ -assert(a != b) +BUG_ON(a == b) @@ expression a, b; @@ -assert(a < b) +BUG_ON(a >= b) @@ expression a, b; @@ -assert(a <= b) +BUG_ON(a > b) @@ expression a; @@ -assert(!a) +BUG_ON(a) @@ expression a; @@ -assert(a) +BUG_ON(!a) // </smpl>
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com Reviewed-by: Simon Glass sjg@chromium.org ---
Changes in v2: - Improve semantic patch and re-run coccinelle based on commit 02907004294d98
arch/arm/mach-exynos/clock.c | 4 +- arch/arm/mach-tegra/clock.c | 10 ++-- arch/arm/mach-tegra/pinmux-common.c | 80 +++++++++++++-------------- arch/arm/mach-tegra/tegra114/clock.c | 10 ++-- arch/arm/mach-tegra/tegra124/clock.c | 10 ++-- arch/arm/mach-tegra/tegra20/clock.c | 14 ++--- arch/arm/mach-tegra/tegra210/clock.c | 10 ++-- arch/arm/mach-tegra/tegra30/clock.c | 10 ++-- arch/sandbox/cpu/state.c | 4 +- arch/x86/cpu/intel_common/mrc.c | 2 +- arch/x86/lib/efi/efi.c | 2 +- arch/x86/lib/fsp/fsp_support.c | 6 +- arch/x86/lib/physmem.c | 5 +- board/freescale/qemu-ppce500/qemu-ppce500.c | 8 +-- cmd/bootefi.c | 2 +- cmd/mtdparts.c | 2 +- cmd/tpm_test.c | 28 +++++----- common/dlmalloc.c | 86 ++++++++++++++--------------- common/fdt_support.c | 2 +- common/hwconfig.c | 36 ++++++------ drivers/clk/clk-uclass.c | 2 +- drivers/clk/rockchip/clk_rk3036.c | 23 ++++---- drivers/clk/rockchip/clk_rk3128.c | 27 ++++----- drivers/clk/rockchip/clk_rk3188.c | 28 ++++------ drivers/clk/rockchip/clk_rk322x.c | 23 ++++---- drivers/clk/rockchip/clk_rk3288.c | 36 +++++------- drivers/clk/rockchip/clk_rk3328.c | 8 +-- drivers/clk/rockchip/clk_rk3368.c | 4 +- drivers/clk/rockchip/clk_rk3399.c | 51 +++++++---------- drivers/clk/rockchip/clk_rv1108.c | 2 +- drivers/core/device-remove.c | 8 +-- drivers/core/device.c | 2 +- drivers/core/ofnode.c | 24 ++++---- drivers/core/uclass.c | 4 +- drivers/gpio/gpio-uclass.c | 2 +- drivers/i2c/i2c-uclass.c | 2 +- drivers/input/input.c | 4 +- drivers/input/key_matrix.c | 2 +- drivers/misc/cros_ec.c | 10 ++-- drivers/misc/cros_ec_i2c.c | 4 +- drivers/mtd/nand/tegra_nand.c | 2 +- drivers/mtd/spi/sandbox.c | 4 +- drivers/net/fsl-mc/mc.c | 2 +- drivers/phy/phy-uclass.c | 2 +- drivers/power/tps6586x.c | 4 +- drivers/rtc/rtc-uclass.c | 10 ++-- drivers/sound/sound.c | 2 +- drivers/spi/exynos_spi.c | 6 +- drivers/usb/emul/sandbox_flash.c | 2 +- drivers/usb/host/usb-uclass.c | 4 +- drivers/video/stb_truetype.h | 2 +- fs/ext4/dev.c | 2 +- fs/ext4/ext4_common.c | 2 +- fs/ext4/ext4_journal.c | 2 +- fs/fat/fat.c | 2 +- include/dm/ofnode.h | 4 +- include/efi_loader.h | 12 ++-- lib/circbuf.c | 16 +++--- lib/efi_loader/efi_boottime.c | 2 +- lib/efi_loader/efi_device_path.c | 2 +- lib/efi_loader/efi_file.c | 2 +- lib/efi_loader/efi_memory.c | 2 +- lib/fdtdec.c | 8 +-- lib/membuff.c | 4 +- lib/physmem.c | 4 +- lib/qsort.c | 2 +- lib/slre.c | 8 +-- net/eth-uclass.c | 2 +- net/eth_legacy.c | 2 +- net/net.c | 2 +- test/command_ut.c | 30 +++++----- test/compression.c | 16 +++--- test/print_ut.c | 42 +++++++------- 73 files changed, 383 insertions(+), 422 deletions(-)
diff --git a/arch/arm/mach-exynos/clock.c b/arch/arm/mach-exynos/clock.c index 3d31f9d..a146103 100644 --- a/arch/arm/mach-exynos/clock.c +++ b/arch/arm/mach-exynos/clock.c @@ -1405,8 +1405,8 @@ static int clock_calc_best_scalar(unsigned int main_scaler_bits, debug("Input Rate is %u, Target is %u, Cap is %u\n", input_rate, target_rate, cap);
- assert(best_fine_scalar != NULL); - assert(main_scaler_bits <= fine_scalar_bits); + BUG_ON(!best_fine_scalar); + BUG_ON(main_scaler_bits > fine_scalar_bits);
*best_fine_scalar = 1;
diff --git a/arch/arm/mach-tegra/clock.c b/arch/arm/mach-tegra/clock.c index dc58b30..47cf867 100644 --- a/arch/arm/mach-tegra/clock.c +++ b/arch/arm/mach-tegra/clock.c @@ -74,7 +74,7 @@ static struct clk_pll *get_pll(enum clock_id clkid) struct clk_rst_ctlr *clkrst = (struct clk_rst_ctlr *)NV_PA_CLK_RST_BASE;
- assert(clock_id_is_pll(clkid)); + BUG_ON(!clock_id_is_pll(clkid)); if (clkid >= (enum clock_id)TEGRA_CLK_PLLS) { debug("%s: Invalid PLL %d\n", __func__, clkid); return NULL; @@ -94,7 +94,7 @@ int clock_ll_read_pll(enum clock_id clkid, u32 *divm, u32 *divn, struct clk_pll_info *pllinfo = &tegra_pll_info_table[clkid]; u32 data;
- assert(clkid != CLOCK_ID_USB); + BUG_ON(clkid == CLOCK_ID_USB);
/* Safety check, adds to code size but is small */ if (!clock_id_is_pll(clkid) || clkid == CLOCK_ID_USB) @@ -454,7 +454,7 @@ unsigned clock_adjust_periph_pll_div(enum periph_id periph_id, if (extra_div) *extra_div = xdiv;
- assert(divider >= 0); + BUG_ON(0 > divider); if (adjust_periph_pll(periph_id, source, mux_bits, divider)) return -1U; debug("periph %d, rate=%d, reg=%p = %x\n", periph_id, rate, @@ -515,7 +515,7 @@ void reset_cmplx_set_enable(int cpu, int which, int reset) u32 mask;
/* Form the mask, which depends on the cpu chosen (2 or 4) */ - assert(cpu >= 0 && cpu < MAX_NUM_CPU); + BUG_ON(!(cpu >= 0 && cpu < MAX_NUM_CPU)); mask = which << cpu;
/* either enable or disable those reset for that CPU */ @@ -665,7 +665,7 @@ int clock_decode_periph_id(struct udevice *dev) if (err) return -1; id = clk_id_to_periph_id(cell[1]); - assert(clock_periph_id_isvalid(id)); + BUG_ON(!clock_periph_id_isvalid(id)); return id; } #endif /* CONFIG_IS_ENABLED(OF_CONTROL) */ diff --git a/arch/arm/mach-tegra/pinmux-common.c b/arch/arm/mach-tegra/pinmux-common.c index 5862c4a..1478a03 100644 --- a/arch/arm/mach-tegra/pinmux-common.c +++ b/arch/arm/mach-tegra/pinmux-common.c @@ -165,8 +165,8 @@ void pinmux_set_func(enum pmux_pingrp pin, enum pmux_func func) return;
/* Error check on pin and func */ - assert(pmux_pingrp_isvalid(pin)); - assert(pmux_func_isvalid(func)); + BUG_ON(!pmux_pingrp_isvalid(pin)); + BUG_ON(!pmux_func_isvalid(func));
if (func >= PMUX_FUNC_RSVD1) { mux = (func - PMUX_FUNC_RSVD1) & 3; @@ -179,7 +179,7 @@ void pinmux_set_func(enum pmux_pingrp pin, enum pmux_func func) } } } - assert(mux != -1); + BUG_ON(mux == -1);
val = readl(reg); val &= ~(3 << MUX_SHIFT(pin)); @@ -193,8 +193,8 @@ void pinmux_set_pullupdown(enum pmux_pingrp pin, enum pmux_pull pupd) u32 val;
/* Error check on pin and pupd */ - assert(pmux_pingrp_isvalid(pin)); - assert(pmux_pin_pupd_isvalid(pupd)); + BUG_ON(!pmux_pingrp_isvalid(pin)); + BUG_ON(!pmux_pin_pupd_isvalid(pupd));
val = readl(reg); val &= ~(3 << PULL_SHIFT(pin)); @@ -208,8 +208,8 @@ static void pinmux_set_tristate(enum pmux_pingrp pin, int tri) u32 val;
/* Error check on pin */ - assert(pmux_pingrp_isvalid(pin)); - assert(pmux_pin_tristate_isvalid(tri)); + BUG_ON(!pmux_pingrp_isvalid(pin)); + BUG_ON(!pmux_pin_tristate_isvalid(tri));
val = readl(reg); if (tri == PMUX_TRI_TRISTATE) @@ -239,8 +239,8 @@ void pinmux_set_io(enum pmux_pingrp pin, enum pmux_pin_io io) return;
/* Error check on pin and io */ - assert(pmux_pingrp_isvalid(pin)); - assert(pmux_pin_io_isvalid(io)); + BUG_ON(!pmux_pingrp_isvalid(pin)); + BUG_ON(!pmux_pin_io_isvalid(io));
val = readl(reg); if (io == PMUX_PIN_INPUT) @@ -261,8 +261,8 @@ static void pinmux_set_lock(enum pmux_pingrp pin, enum pmux_pin_lock lock) return;
/* Error check on pin and lock */ - assert(pmux_pingrp_isvalid(pin)); - assert(pmux_pin_lock_isvalid(lock)); + BUG_ON(!pmux_pingrp_isvalid(pin)); + BUG_ON(!pmux_pin_lock_isvalid(lock));
val = readl(reg); if (lock == PMUX_PIN_LOCK_ENABLE) { @@ -288,8 +288,8 @@ static void pinmux_set_od(enum pmux_pingrp pin, enum pmux_pin_od od) return;
/* Error check on pin and od */ - assert(pmux_pingrp_isvalid(pin)); - assert(pmux_pin_od_isvalid(od)); + BUG_ON(!pmux_pingrp_isvalid(pin)); + BUG_ON(!pmux_pin_od_isvalid(od));
val = readl(reg); if (od == PMUX_PIN_OD_ENABLE) @@ -313,8 +313,8 @@ static void pinmux_set_ioreset(enum pmux_pingrp pin, return;
/* Error check on pin and ioreset */ - assert(pmux_pingrp_isvalid(pin)); - assert(pmux_pin_ioreset_isvalid(ioreset)); + BUG_ON(!pmux_pingrp_isvalid(pin)); + BUG_ON(!pmux_pin_ioreset_isvalid(ioreset));
val = readl(reg); if (ioreset == PMUX_PIN_IO_RESET_ENABLE) @@ -338,8 +338,8 @@ static void pinmux_set_rcv_sel(enum pmux_pingrp pin, return;
/* Error check on pin and rcv_sel */ - assert(pmux_pingrp_isvalid(pin)); - assert(pmux_pin_rcv_sel_isvalid(rcv_sel)); + BUG_ON(!pmux_pingrp_isvalid(pin)); + BUG_ON(!pmux_pin_rcv_sel_isvalid(rcv_sel));
val = readl(reg); if (rcv_sel == PMUX_PIN_RCV_SEL_HIGH) @@ -363,8 +363,8 @@ static void pinmux_set_e_io_hv(enum pmux_pingrp pin, return;
/* Error check on pin and e_io_hv */ - assert(pmux_pingrp_isvalid(pin)); - assert(pmux_pin_e_io_hv_isvalid(e_io_hv)); + BUG_ON(!pmux_pingrp_isvalid(pin)); + BUG_ON(!pmux_pin_e_io_hv_isvalid(e_io_hv));
val = readl(reg); if (e_io_hv == PMUX_PIN_E_IO_HV_HIGH) @@ -388,8 +388,8 @@ static void pinmux_set_schmt(enum pmux_pingrp pin, enum pmux_schmt schmt) return;
/* Error check pad */ - assert(pmux_pingrp_isvalid(pin)); - assert(pmux_schmt_isvalid(schmt)); + BUG_ON(!pmux_pingrp_isvalid(pin)); + BUG_ON(!pmux_schmt_isvalid(schmt));
val = readl(reg); if (schmt == PMUX_SCHMT_ENABLE) @@ -413,8 +413,8 @@ static void pinmux_set_hsm(enum pmux_pingrp pin, enum pmux_hsm hsm) return;
/* Error check pad */ - assert(pmux_pingrp_isvalid(pin)); - assert(pmux_hsm_isvalid(hsm)); + BUG_ON(!pmux_pingrp_isvalid(pin)); + BUG_ON(!pmux_hsm_isvalid(hsm));
val = readl(reg); if (hsm == PMUX_HSM_ENABLE) @@ -523,8 +523,8 @@ static void pinmux_set_drvup_slwf(enum pmux_drvgrp grp, int slwf) return;
/* Error check on pad and slwf */ - assert(pmux_drvgrp_isvalid(grp)); - assert(pmux_slw_isvalid(slwf)); + BUG_ON(!pmux_drvgrp_isvalid(grp)); + BUG_ON(!pmux_slw_isvalid(slwf));
val = readl(reg); val &= ~SLWF_MASK; @@ -544,8 +544,8 @@ static void pinmux_set_drvdn_slwr(enum pmux_drvgrp grp, int slwr) return;
/* Error check on pad and slwr */ - assert(pmux_drvgrp_isvalid(grp)); - assert(pmux_slw_isvalid(slwr)); + BUG_ON(!pmux_drvgrp_isvalid(grp)); + BUG_ON(!pmux_slw_isvalid(slwr));
val = readl(reg); val &= ~SLWR_MASK; @@ -565,8 +565,8 @@ static void pinmux_set_drvup(enum pmux_drvgrp grp, int drvup) return;
/* Error check on pad and drvup */ - assert(pmux_drvgrp_isvalid(grp)); - assert(pmux_drv_isvalid(drvup)); + BUG_ON(!pmux_drvgrp_isvalid(grp)); + BUG_ON(!pmux_drv_isvalid(drvup));
val = readl(reg); val &= ~DRVUP_MASK; @@ -586,8 +586,8 @@ static void pinmux_set_drvdn(enum pmux_drvgrp grp, int drvdn) return;
/* Error check on pad and drvdn */ - assert(pmux_drvgrp_isvalid(grp)); - assert(pmux_drv_isvalid(drvdn)); + BUG_ON(!pmux_drvgrp_isvalid(grp)); + BUG_ON(!pmux_drv_isvalid(drvdn));
val = readl(reg); val &= ~DRVDN_MASK; @@ -608,8 +608,8 @@ static void pinmux_set_lpmd(enum pmux_drvgrp grp, enum pmux_lpmd lpmd) return;
/* Error check pad and lpmd value */ - assert(pmux_drvgrp_isvalid(grp)); - assert(pmux_lpmd_isvalid(lpmd)); + BUG_ON(!pmux_drvgrp_isvalid(grp)); + BUG_ON(!pmux_lpmd_isvalid(lpmd));
val = readl(reg); val &= ~LPMD_MASK; @@ -631,8 +631,8 @@ static void pinmux_set_schmt(enum pmux_drvgrp grp, enum pmux_schmt schmt) return;
/* Error check pad */ - assert(pmux_drvgrp_isvalid(grp)); - assert(pmux_schmt_isvalid(schmt)); + BUG_ON(!pmux_drvgrp_isvalid(grp)); + BUG_ON(!pmux_schmt_isvalid(schmt));
val = readl(reg); if (schmt == PMUX_SCHMT_ENABLE) @@ -656,8 +656,8 @@ static void pinmux_set_hsm(enum pmux_drvgrp grp, enum pmux_hsm hsm) return;
/* Error check pad */ - assert(pmux_drvgrp_isvalid(grp)); - assert(pmux_hsm_isvalid(hsm)); + BUG_ON(!pmux_drvgrp_isvalid(grp)); + BUG_ON(!pmux_hsm_isvalid(hsm));
val = readl(reg); if (hsm == PMUX_HSM_ENABLE) @@ -714,8 +714,8 @@ static void pinmux_mipipadctrl_set_func(enum pmux_mipipadctrlgrp grp, return;
/* Error check grp and func */ - assert(pmux_mipipadctrlgrp_isvalid(grp)); - assert(pmux_func_isvalid(func)); + BUG_ON(!pmux_mipipadctrlgrp_isvalid(grp)); + BUG_ON(!pmux_func_isvalid(func));
if (func >= PMUX_FUNC_RSVD1) { mux = (func - PMUX_FUNC_RSVD1) & 1; @@ -729,7 +729,7 @@ static void pinmux_mipipadctrl_set_func(enum pmux_mipipadctrlgrp grp, } } } - assert(mux != -1); + BUG_ON(mux == -1);
val = readl(reg); val &= ~(1 << 1); diff --git a/arch/arm/mach-tegra/tegra114/clock.c b/arch/arm/mach-tegra/tegra114/clock.c index 177ab6b..0f91141 100644 --- a/arch/arm/mach-tegra/tegra114/clock.c +++ b/arch/arm/mach-tegra/tegra114/clock.c @@ -486,9 +486,9 @@ u32 *get_periph_source_reg(enum periph_id periph_id) if (periph_id == PERIPH_ID_CSI) return &clkrst->crc_clk_src[PERIPH_ID_CSI+1];
- assert(periph_id >= PERIPH_ID_FIRST && periph_id < PERIPH_ID_COUNT); + BUG_ON(!(periph_id >= PERIPH_ID_FIRST && periph_id < PERIPH_ID_COUNT)); internal_id = periph_id_to_internal_id[periph_id]; - assert(internal_id != -1); + BUG_ON(internal_id == -1); if (internal_id >= PERIPHC_VW_FIRST) { internal_id -= PERIPHC_VW_FIRST; return &clkrst->crc_clk_src_vw[internal_id]; @@ -560,7 +560,7 @@ int get_periph_clock_source(enum periph_id periph_id, int mux, err;
err = get_periph_clock_info(periph_id, mux_bits, divider_bits, &type); - assert(!err); + BUG_ON(err);
for (mux = 0; mux < CLOCK_MAX_MUX; mux++) if (clock_source[type][mux] == parent) @@ -580,7 +580,7 @@ void clock_set_enable(enum periph_id periph_id, int enable) u32 reg;
/* Enable/disable the clock to this peripheral */ - assert(clock_periph_id_isvalid(periph_id)); + BUG_ON(!clock_periph_id_isvalid(periph_id)); if ((int)periph_id < (int)PERIPH_ID_VW_FIRST) clk = &clkrst->crc_clk_out_enb[PERIPH_REG(periph_id)]; else @@ -601,7 +601,7 @@ void reset_set_enable(enum periph_id periph_id, int enable) u32 reg;
/* Enable/disable reset to the peripheral */ - assert(clock_periph_id_isvalid(periph_id)); + BUG_ON(!clock_periph_id_isvalid(periph_id)); if (periph_id < PERIPH_ID_VW_FIRST) reset = &clkrst->crc_rst_dev[PERIPH_REG(periph_id)]; else diff --git a/arch/arm/mach-tegra/tegra124/clock.c b/arch/arm/mach-tegra/tegra124/clock.c index 5ae718b..2108273 100644 --- a/arch/arm/mach-tegra/tegra124/clock.c +++ b/arch/arm/mach-tegra/tegra124/clock.c @@ -628,9 +628,9 @@ u32 *get_periph_source_reg(enum periph_id periph_id) if (periph_id == PERIPH_ID_CSI) return &clkrst->crc_clk_src[PERIPH_ID_CSI+1];
- assert(periph_id >= PERIPH_ID_FIRST && periph_id < PERIPH_ID_COUNT); + BUG_ON(!(periph_id >= PERIPH_ID_FIRST && periph_id < PERIPH_ID_COUNT)); internal_id = periph_id_to_internal_id[periph_id]; - assert(internal_id != -1); + BUG_ON(internal_id == -1); if (internal_id >= PERIPHC_X_FIRST) { internal_id -= PERIPHC_X_FIRST; return &clkrst->crc_clk_src_x[internal_id]; @@ -706,7 +706,7 @@ int get_periph_clock_source(enum periph_id periph_id, int mux, err;
for (mux = 0; mux < CLOCK_MAX_MUX; mux++) if (clock_source[type][mux] == parent) @@ -726,7 +726,7 @@ void clock_set_enable(enum periph_id periph_id, int enable) u32 reg;
/* Enable/disable the clock to this peripheral */ - assert(clock_periph_id_isvalid(periph_id)); + BUG_ON(!clock_periph_id_isvalid(periph_id)); if ((int)periph_id < (int)PERIPH_ID_VW_FIRST) clk = &clkrst->crc_clk_out_enb[PERIPH_REG(periph_id)]; else if ((int)periph_id < PERIPH_ID_X_FIRST) @@ -749,7 +749,7 @@ void reset_set_enable(enum periph_id periph_id, int enable) u32 reg;
/* Enable/disable reset to the peripheral */ - assert(clock_periph_id_isvalid(periph_id)); + BUG_ON(!clock_periph_id_isvalid(periph_id)); if (periph_id < PERIPH_ID_VW_FIRST) reset = &clkrst->crc_rst_dev[PERIPH_REG(periph_id)]; else if ((int)periph_id < PERIPH_ID_X_FIRST) diff --git a/arch/arm/mach-tegra/tegra20/clock.c b/arch/arm/mach-tegra/tegra20/clock.c index 81fb1d8..903900f 100644 --- a/arch/arm/mach-tegra/tegra20/clock.c +++ b/arch/arm/mach-tegra/tegra20/clock.c @@ -407,9 +407,9 @@ u32 *get_periph_source_reg(enum periph_id periph_id) (struct clk_rst_ctlr *)NV_PA_CLK_RST_BASE; enum periphc_internal_id internal_id;
- assert(clock_periph_id_isvalid(periph_id)); + BUG_ON(!clock_periph_id_isvalid(periph_id)); internal_id = periph_id_to_internal_id[periph_id]; - assert(internal_id != -1); + BUG_ON(internal_id == -1); return &clkrst->crc_clk_src[internal_id]; }
@@ -483,7 +483,7 @@ int get_periph_clock_source(enum periph_id periph_id, int mux, err;
for (mux = 0; mux < CLOCK_MAX_MUX; mux++) if (clock_source[type][mux] == parent) @@ -494,8 +494,8 @@ int get_periph_clock_source(enum periph_id periph_id, * which is not in our table. If not, then they are asking for a * source which this peripheral can't access through its mux. */ - assert(type == CLOCK_TYPE_PCXTS); - assert(parent == CLOCK_ID_SFROM32KHZ); + BUG_ON(type != CLOCK_TYPE_PCXTS); + BUG_ON(parent != CLOCK_ID_SFROM32KHZ); if (type == CLOCK_TYPE_PCXTS && parent == CLOCK_ID_SFROM32KHZ) return 4; /* mux value for this clock */
@@ -513,7 +513,7 @@ void clock_set_enable(enum periph_id periph_id, int enable) u32 reg;
/* Enable/disable the clock to this peripheral */ - assert(clock_periph_id_isvalid(periph_id)); + BUG_ON(!clock_periph_id_isvalid(periph_id)); reg = readl(clk); if (enable) reg |= PERIPH_MASK(periph_id); @@ -530,7 +530,7 @@ void reset_set_enable(enum periph_id periph_id, int enable) u32 reg;
/* Enable/disable reset to the peripheral */ - assert(clock_periph_id_isvalid(periph_id)); + BUG_ON(!clock_periph_id_isvalid(periph_id)); reg = readl(reset); if (enable) reg |= PERIPH_MASK(periph_id); diff --git a/arch/arm/mach-tegra/tegra210/clock.c b/arch/arm/mach-tegra/tegra210/clock.c index c8bb946..463e91a 100644 --- a/arch/arm/mach-tegra/tegra210/clock.c +++ b/arch/arm/mach-tegra/tegra210/clock.c @@ -707,9 +707,9 @@ u32 *get_periph_source_reg(enum periph_id periph_id) if (periph_id == PERIPH_ID_CSI) return &clkrst->crc_clk_src[PERIPH_ID_CSI+1];
- assert(periph_id >= PERIPH_ID_FIRST && periph_id < PERIPH_ID_COUNT); + BUG_ON(!(periph_id >= PERIPH_ID_FIRST && periph_id < PERIPH_ID_COUNT)); internal_id = INTERNAL_ID(periph_id_to_internal_id[periph_id]); - assert(internal_id != -1); + BUG_ON(internal_id == -1);
if (internal_id < PERIPHC_VW_FIRST) /* L, H, U */ @@ -796,7 +796,7 @@ int get_periph_clock_source(enum periph_id periph_id, int mux, err;
for (mux = 0; mux < CLOCK_MAX_MUX; mux++) if (clock_source[type][mux] == parent) @@ -816,7 +816,7 @@ void clock_set_enable(enum periph_id periph_id, int enable) u32 reg;
/* Enable/disable the clock to this peripheral */ - assert(clock_periph_id_isvalid(periph_id)); + BUG_ON(!clock_periph_id_isvalid(periph_id)); if ((int)periph_id < (int)PERIPH_ID_VW_FIRST) clk = &clkrst->crc_clk_out_enb[PERIPH_REG(periph_id)]; else if ((int)periph_id < (int)PERIPH_ID_X_FIRST) @@ -842,7 +842,7 @@ void reset_set_enable(enum periph_id periph_id, int enable) u32 reg;
/* Enable/disable reset to the peripheral */ - assert(clock_periph_id_isvalid(periph_id)); + BUG_ON(!clock_periph_id_isvalid(periph_id)); if (periph_id < PERIPH_ID_VW_FIRST) reset = &clkrst->crc_rst_dev[PERIPH_REG(periph_id)]; else if ((int)periph_id < (int)PERIPH_ID_X_FIRST) diff --git a/arch/arm/mach-tegra/tegra30/clock.c b/arch/arm/mach-tegra/tegra30/clock.c index 282f34f..b3ec1de 100644 --- a/arch/arm/mach-tegra/tegra30/clock.c +++ b/arch/arm/mach-tegra/tegra30/clock.c @@ -466,9 +466,9 @@ u32 *get_periph_source_reg(enum periph_id periph_id) if (periph_id == PERIPH_ID_CSI) return &clkrst->crc_clk_src[PERIPH_ID_CSI+1];
- assert(periph_id >= PERIPH_ID_FIRST && periph_id < PERIPH_ID_COUNT); + BUG_ON(!(periph_id >= PERIPH_ID_FIRST && periph_id < PERIPH_ID_COUNT)); internal_id = periph_id_to_internal_id[periph_id]; - assert(internal_id != -1); + BUG_ON(internal_id == -1); if (internal_id >= PERIPHC_VW_FIRST) { internal_id -= PERIPHC_VW_FIRST; return &clkrst->crc_clk_src_vw[internal_id]; @@ -540,7 +540,7 @@ int get_periph_clock_source(enum periph_id periph_id, int mux, err;
for (mux = 0; mux < CLOCK_MAX_MUX; mux++) if (clock_source[type][mux] == parent) @@ -560,7 +560,7 @@ void clock_set_enable(enum periph_id periph_id, int enable) u32 reg;
/* Enable/disable the clock to this peripheral */ - assert(clock_periph_id_isvalid(periph_id)); + BUG_ON(!clock_periph_id_isvalid(periph_id)); if ((int)periph_id < (int)PERIPH_ID_VW_FIRST) clk = &clkrst->crc_clk_out_enb[PERIPH_REG(periph_id)]; else @@ -581,7 +581,7 @@ void reset_set_enable(enum periph_id periph_id, int enable) u32 reg;
/* Enable/disable reset to the peripheral */ - assert(clock_periph_id_isvalid(periph_id)); + BUG_ON(!clock_periph_id_isvalid(periph_id)); if (periph_id < PERIPH_ID_VW_FIRST) reset = &clkrst->crc_rst_dev[PERIPH_REG(periph_id)]; else diff --git a/arch/sandbox/cpu/state.c b/arch/sandbox/cpu/state.c index 0758448..c8665d7 100644 --- a/arch/sandbox/cpu/state.c +++ b/arch/sandbox/cpu/state.c @@ -333,7 +333,7 @@ int state_setprop(int node, const char *prop_name, const void *data, int size)
struct sandbox_state *state_get_current(void) { - assert(state); + BUG_ON(!state); return state; }
@@ -367,7 +367,7 @@ int state_init(void)
state->ram_size = CONFIG_SYS_SDRAM_SIZE; state->ram_buf = os_malloc(state->ram_size); - assert(state->ram_buf); + BUG_ON(!state->ram_buf);
state_reset_for_test(state); /* diff --git a/arch/x86/cpu/intel_common/mrc.c b/arch/x86/cpu/intel_common/mrc.c index f1a249a..0e0f4f2 100644 --- a/arch/x86/cpu/intel_common/mrc.c +++ b/arch/x86/cpu/intel_common/mrc.c @@ -42,7 +42,7 @@ ulong mrc_common_board_get_usable_ram_top(ulong total_size) }
/* If no suitable area was found, return an error. */ - assert(largest); + BUG_ON(!largest); if (!largest || largest->size < (2 << 20)) panic("No available memory found for relocation");
diff --git a/arch/x86/lib/efi/efi.c b/arch/x86/lib/efi/efi.c index b1746fa..d98dac3 100644 --- a/arch/x86/lib/efi/efi.c +++ b/arch/x86/lib/efi/efi.c @@ -55,7 +55,7 @@ ulong board_get_usable_ram_top(ulong total_size) }
/* If no suitable area was found, return an error. */ - assert(largest); + BUG_ON(!largest); if (!largest || (largest->num_pages << EFI_PAGE_SHIFT) < (2 << 20)) goto err;
diff --git a/arch/x86/lib/fsp/fsp_support.c b/arch/x86/lib/fsp/fsp_support.c index e0c49be..400b96b 100644 --- a/arch/x86/lib/fsp/fsp_support.c +++ b/arch/x86/lib/fsp/fsp_support.c @@ -91,7 +91,7 @@ void fsp_continue(u32 status, void *hob_list) { post_code(POST_MRC);
- assert(status == 0); + BUG_ON(status);
/* The boot loader main function entry */ fsp_init_done(hob_list); @@ -126,7 +126,7 @@ void fsp_init(u32 stack_top, u32 boot_mode, void *nvs_buf) fsp_hdr->cfg_region_off);
/* Verify the VPD data region is valid */ - assert(fsp_vpd->sign == VPD_IMAGE_ID); + BUG_ON(fsp_vpd->sign != VPD_IMAGE_ID);
fsp_upd = &config_data.fsp_upd;
@@ -135,7 +135,7 @@ void fsp_init(u32 stack_top, u32 boot_mode, void *nvs_buf) sizeof(struct upd_region));
/* Verify the UPD data region is valid */ - assert(fsp_upd->terminator == UPD_TERMINATOR); + BUG_ON(fsp_upd->terminator != UPD_TERMINATOR); #endif
memset(&rt_buf, 0, sizeof(struct fspinit_rtbuf)); diff --git a/arch/x86/lib/physmem.c b/arch/x86/lib/physmem.c index c3c709e..6839bae 100644 --- a/arch/x86/lib/physmem.c +++ b/arch/x86/lib/physmem.c @@ -141,8 +141,7 @@ static void x86_phys_memset_page(phys_addr_t map_addr, uintptr_t offset, int c, const uintptr_t window = LARGE_PAGE_SIZE;
/* Make sure the window is below U-Boot. */ - assert(window + LARGE_PAGE_SIZE < - gd->relocaddr - CONFIG_SYS_MALLOC_LEN - CONFIG_SYS_STACK_SIZE); + BUG_ON(window + LARGE_PAGE_SIZE >= gd->relocaddr - CONFIG_SYS_MALLOC_LEN - CONFIG_SYS_STACK_SIZE); /* Map the page into the window and then memset the appropriate part. */ x86_phys_map_page(window, map_addr, 1); memset((void *)(window + offset), c, size); @@ -165,7 +164,7 @@ phys_addr_t arch_phys_memset(phys_addr_t start, int c, phys_size_t size) phys_size_t low_size = min(max_addr + 1 - start, size); void *start_ptr = (void *)(uintptr_t)start;
- assert(((phys_addr_t)(uintptr_t)start) == start); + BUG_ON(((phys_addr_t)(uintptr_t)start) != start); memset(start_ptr, c, low_size); start += low_size; size -= low_size; diff --git a/board/freescale/qemu-ppce500/qemu-ppce500.c b/board/freescale/qemu-ppce500/qemu-ppce500.c index cf5023c..fde83aa 100644 --- a/board/freescale/qemu-ppce500/qemu-ppce500.c +++ b/board/freescale/qemu-ppce500/qemu-ppce500.c @@ -109,7 +109,7 @@ static int pci_map_region(void *fdt, int pci_node, int range_id, return -1;
/* Map virtual memory for range */ - assert(!tlb_map_range(map_addr, addr, size, TLB_MAP_IO)); + BUG_ON(tlb_map_range(map_addr, addr, size, TLB_MAP_IO)); *pmap_addr = map_addr + size;
if (pvaddr) @@ -286,15 +286,13 @@ void init_tlbs(void) init_used_tlb_cams();
/* Create a dynamic AS=0 CCSRBAR mapping */ - assert(!tlb_map_range(CONFIG_SYS_CCSRBAR, CONFIG_SYS_CCSRBAR_PHYS, - 1024 * 1024, TLB_MAP_IO)); + BUG_ON(tlb_map_range(CONFIG_SYS_CCSRBAR, CONFIG_SYS_CCSRBAR_PHYS, 1024 * 1024, TLB_MAP_IO));
/* Create a RAM map that spans all accessible RAM */ setup_ddr_tlbs(ram_size >> 20);
/* Create a map for the TLB */ - assert(!tlb_map_range((ulong)get_fdt_virt(), get_fdt_phys(), - 1024 * 1024, TLB_MAP_RAM)); + BUG_ON(tlb_map_range((ulong)get_fdt_virt(), get_fdt_phys(), 1024 * 1024, TLB_MAP_RAM)); }
void init_laws(void) diff --git a/cmd/bootefi.c b/cmd/bootefi.c index 478bc11..d77e8fd 100644 --- a/cmd/bootefi.c +++ b/cmd/bootefi.c @@ -147,7 +147,7 @@ static unsigned long do_bootefi_exec(void *efi, void *fdt, memdp = efi_dp_from_mem(0, 0, 0); device_path = image_path = memdp; } else { - assert(device_path && image_path); + BUG_ON(!(device_path && image_path)); }
/* Initialize and populate EFI object list */ diff --git a/cmd/mtdparts.c b/cmd/mtdparts.c index 3275eb9..d1d358d 100644 --- a/cmd/mtdparts.c +++ b/cmd/mtdparts.c @@ -852,7 +852,7 @@ static int device_parse(const char *const mtd_dev, const char **ret, struct mtd_
debug("===device_parse===\n");
- assert(retdev); + BUG_ON(!retdev); *retdev = NULL;
if (ret) diff --git a/cmd/tpm_test.c b/cmd/tpm_test.c index 37ad2ff..f9fc558 100644 --- a/cmd/tpm_test.c +++ b/cmd/tpm_test.c @@ -180,13 +180,13 @@ static int test_fast_enable(void) TPM_CHECK(tpm_get_flags(&disable, &deactivated, NULL)); printf("\tdisable is %d, deactivated is %d\n", disable, deactivated); - assert(disable == 1 && deactivated == 1); + BUG_ON(!(disable == 1 && deactivated == 1)); TPM_CHECK(tpm_physical_enable()); TPM_CHECK(tpm_physical_set_deactivated(0)); TPM_CHECK(tpm_get_flags(&disable, &deactivated, NULL)); printf("\tdisable is %d, deactivated is %d\n", disable, deactivated); - assert(disable == 0 && deactivated == 0); + BUG_ON(!(disable == 0 && deactivated == 0)); } printf("\tdone\n"); return 0; @@ -213,22 +213,22 @@ static int test_global_lock(void) /* Verifies that write to index0 fails */ x = 1; result = tpm_nv_write_value(INDEX0, (uint8_t *)&x, sizeof(x)); - assert(result == TPM_AREA_LOCKED); + BUG_ON(result != TPM_AREA_LOCKED); TPM_CHECK(tpm_nv_read_value(INDEX0, (uint8_t *)&x, sizeof(x))); - assert(x == 0); + BUG_ON(x); /* Verifies that write to index1 is still possible */ x = 2; TPM_CHECK(tpm_nv_write_value(INDEX1, (uint8_t *)&x, sizeof(x))); TPM_CHECK(tpm_nv_read_value(INDEX1, (uint8_t *)&x, sizeof(x))); - assert(x == 2); + BUG_ON(x != 2); /* Turns off PP */ tpm_tsc_physical_presence(PHYS_PRESENCE); /* Verifies that write to index1 fails */ x = 3; result = tpm_nv_write_value(INDEX1, (uint8_t *)&x, sizeof(x)); - assert(result == TPM_BAD_PRESENCE); + BUG_ON(result != TPM_BAD_PRESENCE); TPM_CHECK(tpm_nv_read_value(INDEX1, (uint8_t *)&x, sizeof(x))); - assert(x == 2); + BUG_ON(x != 2); printf("\tdone\n"); return 0; } @@ -325,7 +325,7 @@ static int test_redefine_unowned(void) TPM_CHECK(TlclStartupIfNeeded()); TPM_CHECK(tpm_self_test_full()); TPM_CHECK(tpm_tsc_physical_presence(PRESENCE)); - assert(!tpm_is_owned()); + BUG_ON(tpm_is_owned());
/* Ensures spaces exist. */ TPM_CHECK(tpm_nv_read_value(INDEX0, (uint8_t *)&x, sizeof(x))); @@ -344,7 +344,7 @@ static int test_redefine_unowned(void)
/* Verifies that index0 cannot be redefined */ result = tpm_nv_define_space(INDEX0, perm, sizeof(uint32_t)); - assert(result == TPM_AREA_LOCKED); + BUG_ON(result != TPM_AREA_LOCKED);
/* Checks that index1 can */ TPM_CHECK(tpm_nv_define_space(INDEX1, perm, 2 * sizeof(uint32_t))); @@ -355,9 +355,9 @@ static int test_redefine_unowned(void)
/* Verifies that neither index0 nor index1 can be redefined */ result = tpm_nv_define_space(INDEX0, perm, sizeof(uint32_t)); - assert(result == TPM_BAD_PRESENCE); + BUG_ON(result != TPM_BAD_PRESENCE); result = tpm_nv_define_space(INDEX1, perm, sizeof(uint32_t)); - assert(result == TPM_BAD_PRESENCE); + BUG_ON(result != TPM_BAD_PRESENCE);
printf("done\n"); return 0; @@ -376,9 +376,9 @@ static int test_space_perm(void) TPM_CHECK(tpm_continue_self_test()); TPM_CHECK(tpm_tsc_physical_presence(PRESENCE)); TPM_CHECK(tpm_get_permissions(INDEX0, &perm)); - assert((perm & PERMPPGL) == PERMPPGL); + BUG_ON((perm & PERMPPGL) != PERMPPGL); TPM_CHECK(tpm_get_permissions(INDEX1, &perm)); - assert((perm & PERMPP) == PERMPP); + BUG_ON((perm & PERMPP) != PERMPP); printf("done\n"); return 0; } @@ -469,7 +469,7 @@ static int test_write_limit(void) case TPM_SUCCESS: break; case TPM_MAXNVWRITES: - assert(i >= TPM_MAX_NV_WRITES_NOOWNER); + BUG_ON(TPM_MAX_NV_WRITES_NOOWNER > i); default: pr_err("\tunexpected error code %d (0x%x)\n", result, result); diff --git a/common/dlmalloc.c b/common/dlmalloc.c index b395eef..32ef892 100644 --- a/common/dlmalloc.c +++ b/common/dlmalloc.c @@ -57,7 +57,7 @@ GmListElement* makeGmListElement (void* bas) { GmListElement* this; this = (GmListElement*)(void*)LocalAlloc (0, sizeof (GmListElement)); - assert (this); + BUG_ON(!this); if (this) { this->base = bas; @@ -70,19 +70,19 @@ GmListElement* makeGmListElement (void* bas) void gcleanup () { BOOL rval; - assert ( (head == NULL) || (head->base == (void*)gAddressBase)); + BUG_ON(!((head == NULL) || (head->base == (void *)gAddressBase))); if (gAddressBase && (gNextAddress - gAddressBase)) { rval = VirtualFree ((void*)gAddressBase, gNextAddress - gAddressBase, MEM_DECOMMIT); - assert (rval); + BUG_ON(!rval); } while (head) { GmListElement* next = head->next; rval = VirtualFree (head->base, 0, MEM_RELEASE); - assert (rval); + BUG_ON(!rval); LocalFree (head); head = next; } @@ -161,7 +161,7 @@ gAllocatedSize)) } while (gAddressBase == 0);
- assert (new_address == (void*)gAddressBase); + BUG_ON(new_address != (void *)gAddressBase);
gAllocatedSize = new_size;
@@ -734,14 +734,14 @@ static void do_check_chunk(p) mchunkptr p; INTERNAL_SIZE_T sz = p->size & ~PREV_INUSE;
/* No checkable chunk is mmapped */ - assert(!chunk_is_mmapped(p)); + BUG_ON(chunk_is_mmapped(p));
/* Check for legal address ... */ - assert((char*)p >= sbrk_base); + BUG_ON(sbrk_base > (char *)p); if (p != top) - assert((char*)p + sz <= (char*)top); + BUG_ON((char *)p + sz > (char *)top); else - assert((char*)p + sz <= sbrk_base + sbrked_mem); + BUG_ON((char *)p + sz > sbrk_base + sbrked_mem);
@@ -758,25 +758,25 @@ static void do_check_free_chunk(p) mchunkptr p; do_check_chunk(p);
/* Check whether it claims to be free ... */ - assert(!inuse(p)); + BUG_ON(inuse(p));
/* Unless a special marker, must have OK fields */ if ((long)sz >= (long)MINSIZE) { - assert((sz & MALLOC_ALIGN_MASK) == 0); - assert(aligned_OK(chunk2mem(p))); + BUG_ON((sz & MALLOC_ALIGN_MASK)); + BUG_ON(!aligned_OK(chunk2mem(p))); /* ... matching footer field */ - assert(next->prev_size == sz); + BUG_ON(next->prev_size != sz); /* ... and is fully consolidated */ - assert(prev_inuse(p)); - assert (next == top || inuse(next)); + BUG_ON(!prev_inuse(p)); + BUG_ON(!(next == top || inuse(next)));
/* ... and has minimally sane links */ - assert(p->fd->bk == p); - assert(p->bk->fd == p); + BUG_ON(p->fd->bk != p); + BUG_ON(p->bk->fd != p); } else /* markers are always of size SIZE_SZ */ - assert(sz == SIZE_SZ); + BUG_ON(sz != SIZE_SZ); }
#if __STD_C @@ -789,7 +789,7 @@ static void do_check_inuse_chunk(p) mchunkptr p; do_check_chunk(p);
/* Check whether it claims to be in use ... */ - assert(inuse(p)); + BUG_ON(!inuse(p));
/* ... and is surrounded by OK chunks. Since more things can be checked with free chunks than inuse ones, @@ -798,13 +798,13 @@ static void do_check_inuse_chunk(p) mchunkptr p; if (!prev_inuse(p)) { mchunkptr prv = prev_chunk(p); - assert(next_chunk(prv) == p); + BUG_ON(next_chunk(prv) != p); do_check_free_chunk(prv); } if (next == top) { - assert(prev_inuse(next)); - assert(chunksize(next) >= MINSIZE); + BUG_ON(!prev_inuse(next)); + BUG_ON(MINSIZE > chunksize(next)); } else if (!inuse(next)) do_check_free_chunk(next); @@ -823,17 +823,17 @@ static void do_check_malloced_chunk(p, s) mchunkptr p; INTERNAL_SIZE_T s; do_check_inuse_chunk(p);
/* Legal size ... */ - assert((long)sz >= (long)MINSIZE); - assert((sz & MALLOC_ALIGN_MASK) == 0); - assert(room >= 0); - assert(room < (long)MINSIZE); + BUG_ON((long)MINSIZE > (long)sz); + BUG_ON((sz & MALLOC_ALIGN_MASK)); + BUG_ON(0 > room); + BUG_ON(room >= (long)MINSIZE);
/* ... and alignment */ - assert(aligned_OK(chunk2mem(p))); + BUG_ON(!aligned_OK(chunk2mem(p)));
/* ... and was allocated at front of an available chunk */ - assert(prev_inuse(p)); + BUG_ON(!prev_inuse(p));
@@ -966,7 +966,7 @@ static mchunkptr mmap_chunk(size) size_t size; if (n_mmaps > max_n_mmaps) max_n_mmaps = n_mmaps;
/* We demand that eight bytes into a page must be 8-byte aligned. */ - assert(aligned_OK(chunk2mem(p))); + BUG_ON(!aligned_OK(chunk2mem(p)));
/* The offset to the start of the mmapped region is stored * in the prev_size field of the chunk; normally it is zero, @@ -992,10 +992,10 @@ static void munmap_chunk(p) mchunkptr p; INTERNAL_SIZE_T size = chunksize(p); int ret;
- assert (chunk_is_mmapped(p)); - assert(! ((char*)p >= sbrk_base && (char*)p < sbrk_base + sbrked_mem)); - assert((n_mmaps > 0)); - assert(((p->prev_size + size) & (malloc_getpagesize-1)) == 0); + BUG_ON(!chunk_is_mmapped(p)); + BUG_ON(((char *)p >= sbrk_base && (char *)p < sbrk_base + sbrked_mem)); + BUG_ON(0 >= n_mmaps); + BUG_ON(((p->prev_size + size) & (malloc_getpagesize - 1)));
n_mmaps--; mmapped_mem -= (size + p->prev_size); @@ -1003,7 +1003,7 @@ static void munmap_chunk(p) mchunkptr p; ret = munmap((char *)p - p->prev_size, size + p->prev_size);
/* munmap returns non-zero on failure */ - assert(ret == 0); + BUG_ON(ret); }
#if HAVE_MREMAP @@ -1019,10 +1019,10 @@ static mchunkptr mremap_chunk(p, new_size) mchunkptr p; size_t new_size; INTERNAL_SIZE_T size = chunksize(p); char *cp;
- assert (chunk_is_mmapped(p)); - assert(! ((char*)p >= sbrk_base && (char*)p < sbrk_base + sbrked_mem)); - assert((n_mmaps > 0)); - assert(((size + offset) & (malloc_getpagesize-1)) == 0); + BUG_ON(!chunk_is_mmapped(p)); + BUG_ON(((char *)p >= sbrk_base && (char *)p < sbrk_base + sbrked_mem)); + BUG_ON(0 >= n_mmaps); + BUG_ON(((size + offset) & (malloc_getpagesize - 1)));
/* Note the extra SIZE_SZ overhead as in mmap_chunk(). */ new_size = (new_size + offset + SIZE_SZ + page_mask) & ~page_mask; @@ -1033,9 +1033,9 @@ static mchunkptr mremap_chunk(p, new_size) mchunkptr p; size_t new_size;
p = (mchunkptr)(cp + offset);
- assert((p->prev_size == offset)); + BUG_ON(p->prev_size != offset); set_head(p, (new_size - offset)|IS_MMAPPED);
mmapped_mem -= size + offset; @@ -1165,7 +1165,7 @@ static void malloc_extend_top(nb) INTERNAL_SIZE_T nb; max_total_mem = mmapped_mem + sbrked_mem;
/* We always land on a page boundary */ - assert(((unsigned long)((char*)top + top_size) & (pagesz - 1)) == 0); + BUG_ON(((unsigned long)((char *)top + top_size) & (pagesz - 1))); }
@@ -1991,7 +1991,7 @@ Void_t* mEMALIGn(alignment, bytes) size_t alignment; size_t bytes; fREe(chunk2mem(p)); p = newp;
- assert (newsize >= nb && (((unsigned long)(chunk2mem(p))) % alignment) == 0); + BUG_ON(!(newsize >= nb && (((unsigned long)(chunk2mem(p))) % alignment) == 0)); }
/* Also give back spare room at the end */ @@ -2380,7 +2380,7 @@ int mALLOPt(param_number, value) int param_number; int value; int initf_malloc(void) { #if CONFIG_VAL(SYS_MALLOC_F_LEN) - assert(gd->malloc_base); /* Set up by crt0.S */ + BUG_ON(!gd->malloc_base); /* Set up by crt0.S */ gd->malloc_limit = CONFIG_VAL(SYS_MALLOC_F_LEN); gd->malloc_ptr = 0; #endif diff --git a/common/fdt_support.c b/common/fdt_support.c index 6896dcb..6a25844 100644 --- a/common/fdt_support.c +++ b/common/fdt_support.c @@ -1107,7 +1107,7 @@ static struct of_bus *of_match_bus(const void *blob, int parentoffset) * in the of_busses array or something equally catastrophic has * gone wrong. */ - assert(0); + BUG(); return NULL; }
diff --git a/common/hwconfig.c b/common/hwconfig.c index e5186d7..fe42a95 100644 --- a/common/hwconfig.c +++ b/common/hwconfig.c @@ -248,37 +248,37 @@ int main()
ret = hwconfig_arg("key1", &len); printf("%zd %.*s\n", len, (int)len, ret); - assert(len == 29); - assert(hwconfig_arg_cmp("key1", "subkey1=value1,subkey2=value2")); - assert(!strncmp(ret, "subkey1=value1,subkey2=value2", len)); + BUG_ON(len != 29); + BUG_ON(!hwconfig_arg_cmp("key1", "subkey1=value1,subkey2=value2")); + BUG_ON(strncmp(ret, "subkey1=value1,subkey2=value2", len));
ret = hwconfig_subarg("key1", "subkey1", &len); printf("%zd %.*s\n", len, (int)len, ret); - assert(len == 6); - assert(hwconfig_subarg_cmp("key1", "subkey1", "value1")); - assert(!strncmp(ret, "value1", len)); + BUG_ON(len != 6); + BUG_ON(!hwconfig_subarg_cmp("key1", "subkey1", "value1")); + BUG_ON(strncmp(ret, "value1", len));
ret = hwconfig_subarg("key1", "subkey2", &len); printf("%zd %.*s\n", len, (int)len, ret); - assert(len == 6); - assert(hwconfig_subarg_cmp("key1", "subkey2", "value2")); - assert(!strncmp(ret, "value2", len)); + BUG_ON(len != 6); + BUG_ON(!hwconfig_subarg_cmp("key1", "subkey2", "value2")); + BUG_ON(strncmp(ret, "value2", len));
ret = hwconfig_arg("key2", &len); printf("%zd %.*s\n", len, (int)len, ret); - assert(len == 6); - assert(hwconfig_arg_cmp("key2", "value3")); - assert(!strncmp(ret, "value3", len)); + BUG_ON(len != 6); + BUG_ON(!hwconfig_arg_cmp("key2", "value3")); + BUG_ON(strncmp(ret, "value3", len));
- assert(hwconfig("key3")); - assert(hwconfig_arg("key4", &len) == NULL); - assert(hwconfig_arg("bogus", &len) == NULL); + BUG_ON(!hwconfig("key3")); + BUG_ON(hwconfig_arg("key4", &len)); + BUG_ON(hwconfig_arg("bogus", &len));
unenv_set("hwconfig");
- assert(hwconfig(NULL) == 0); - assert(hwconfig("") == 0); - assert(hwconfig("key3") == 0); + BUG_ON(hwconfig(NULL)); + BUG_ON(hwconfig("")); + BUG_ON(hwconfig("key3"));
return 0; } diff --git a/drivers/clk/clk-uclass.c b/drivers/clk/clk-uclass.c index 83ba133..52af798 100644 --- a/drivers/clk/clk-uclass.c +++ b/drivers/clk/clk-uclass.c @@ -64,7 +64,7 @@ int clk_get_by_index(struct udevice *dev, int index, struct clk *clk)
debug("%s(dev=%p, index=%d, clk=%p)\n", __func__, dev, index, clk);
- assert(clk); + BUG_ON(!clk); clk->dev = NULL;
ret = dev_read_phandle_with_args(dev, "clocks", "#clock-cells", 0, diff --git a/drivers/clk/rockchip/clk_rk3036.c b/drivers/clk/rockchip/clk_rk3036.c index 280ebb9..c719a12 100644 --- a/drivers/clk/rockchip/clk_rk3036.c +++ b/drivers/clk/rockchip/clk_rk3036.c @@ -58,8 +58,7 @@ static int rkclk_set_pll(struct rk3036_cru *cru, enum rk_clk_id clk_id, vco=%u Hz, output=%u Hz\n", pll, div->fbdiv, div->refdiv, div->postdiv1, div->postdiv2, vco_hz, output_hz); - assert(vco_hz >= VCO_MIN_HZ && vco_hz <= VCO_MAX_HZ && - output_hz >= OUTPUT_MIN_HZ && output_hz <= OUTPUT_MAX_HZ); + BUG_ON(!(vco_hz >= VCO_MIN_HZ && vco_hz <= VCO_MAX_HZ && output_hz >= OUTPUT_MIN_HZ && output_hz <= OUTPUT_MAX_HZ));
/* use integer mode */ rk_setreg(&pll->con1, 1 << PLL_DSMPD_SHIFT); @@ -100,10 +99,10 @@ static void rkclk_init(struct rk3036_cru *cru) * core hz : apll = 1:1 */ aclk_div = APLL_HZ / CORE_ACLK_HZ - 1; - assert((aclk_div + 1) * CORE_ACLK_HZ == APLL_HZ && aclk_div < 0x7); + BUG_ON(!((aclk_div + 1) * CORE_ACLK_HZ == APLL_HZ && aclk_div < 0x7));
pclk_div = APLL_HZ / CORE_PERI_HZ - 1; - assert((pclk_div + 1) * CORE_PERI_HZ == APLL_HZ && pclk_div < 0xf); + BUG_ON(!((pclk_div + 1) * CORE_PERI_HZ == APLL_HZ && pclk_div < 0xf));
rk_clrsetreg(&cru->cru_clksel_con[0], CORE_CLK_PLL_SEL_MASK | CORE_DIV_CON_MASK, @@ -120,13 +119,13 @@ static void rkclk_init(struct rk3036_cru *cru) * set up dependent divisors for PCLK/HCLK and ACLK clocks. */ aclk_div = GPLL_HZ / BUS_ACLK_HZ - 1; - assert((aclk_div + 1) * BUS_ACLK_HZ == GPLL_HZ && aclk_div <= 0x1f); + BUG_ON(!((aclk_div + 1) * BUS_ACLK_HZ == GPLL_HZ && aclk_div <= 0x1f));
pclk_div = GPLL_HZ / BUS_PCLK_HZ - 1; - assert((pclk_div + 1) * BUS_PCLK_HZ == GPLL_HZ && pclk_div <= 0x7); + BUG_ON(!((pclk_div + 1) * BUS_PCLK_HZ == GPLL_HZ && pclk_div <= 0x7));
hclk_div = GPLL_HZ / BUS_HCLK_HZ - 1; - assert((hclk_div + 1) * BUS_HCLK_HZ == GPLL_HZ && hclk_div <= 0x3); + BUG_ON(!((hclk_div + 1) * BUS_HCLK_HZ == GPLL_HZ && hclk_div <= 0x3));
rk_clrsetreg(&cru->cru_clksel_con[0], BUS_ACLK_PLL_SEL_MASK | BUS_ACLK_DIV_MASK, @@ -143,15 +142,13 @@ static void rkclk_init(struct rk3036_cru *cru) * set up dependent divisors for PCLK/HCLK and ACLK clocks. */ aclk_div = GPLL_HZ / PERI_ACLK_HZ - 1; - assert((aclk_div + 1) * PERI_ACLK_HZ == GPLL_HZ && aclk_div < 0x1f); + BUG_ON(!((aclk_div + 1) * PERI_ACLK_HZ == GPLL_HZ && aclk_div < 0x1f));
hclk_div = ilog2(PERI_ACLK_HZ / PERI_HCLK_HZ); - assert((1 << hclk_div) * PERI_HCLK_HZ == - PERI_ACLK_HZ && (hclk_div < 0x4)); + BUG_ON(!((1 << hclk_div) * PERI_HCLK_HZ == PERI_ACLK_HZ && (hclk_div < 0x4)));
pclk_div = ilog2(PERI_ACLK_HZ / PERI_PCLK_HZ); - assert((1 << pclk_div) * PERI_PCLK_HZ == - PERI_ACLK_HZ && pclk_div < 0x8); + BUG_ON(!((1 << pclk_div) * PERI_PCLK_HZ == PERI_ACLK_HZ && pclk_div < 0x8));
rk_clrsetreg(&cru->cru_clksel_con[10], PERI_PLL_SEL_MASK | PERI_PCLK_DIV_MASK | @@ -251,7 +248,7 @@ static ulong rockchip_mmc_set_clk(struct rk3036_cru *cru, uint clk_general_rate,
if (src_clk_div > 128) { src_clk_div = DIV_ROUND_UP(OSC_HZ / 2, freq); - assert(src_clk_div - 1 < 128); + BUG_ON(src_clk_div - 1 >= 128); mux = EMMC_SEL_24M; } else { mux = EMMC_SEL_GPLL; diff --git a/drivers/clk/rockchip/clk_rk3128.c b/drivers/clk/rockchip/clk_rk3128.c index 132d50d..1a0d7fc 100644 --- a/drivers/clk/rockchip/clk_rk3128.c +++ b/drivers/clk/rockchip/clk_rk3128.c @@ -51,8 +51,7 @@ static int rkclk_set_pll(struct rk3128_cru *cru, enum rk_clk_id clk_id, debug("PLL at %p:fd=%d,rd=%d,pd1=%d,pd2=%d,vco=%uHz,output=%uHz\n", pll, div->fbdiv, div->refdiv, div->postdiv1, div->postdiv2, vco_hz, output_hz); - assert(vco_hz >= VCO_MIN_HZ && vco_hz <= VCO_MAX_HZ && - output_hz >= OUTPUT_MIN_HZ && output_hz <= OUTPUT_MAX_HZ); + BUG_ON(!(vco_hz >= VCO_MIN_HZ && vco_hz <= VCO_MAX_HZ && output_hz >= OUTPUT_MIN_HZ && output_hz <= OUTPUT_MAX_HZ));
/* use integer mode */ rk_setreg(&pll->con1, 1 << PLL_DSMPD_SHIFT); @@ -162,10 +161,10 @@ static void rkclk_init(struct rk3128_cru *cru) * core hz : apll = 1:1 */ aclk_div = APLL_HZ / CORE_ACLK_HZ - 1; - assert((aclk_div + 1) * CORE_ACLK_HZ == APLL_HZ && aclk_div < 0x7); + BUG_ON(!((aclk_div + 1) * CORE_ACLK_HZ == APLL_HZ && aclk_div < 0x7));
rk_clrsetreg(&cru->cru_clksel_con[0], CORE_CLK_PLL_SEL_MASK | CORE_DIV_CON_MASK, @@ -182,13 +181,13 @@ static void rkclk_init(struct rk3128_cru *cru) * set up dependent divisors for PCLK/HCLK and ACLK clocks. */ aclk_div = GPLL_HZ / BUS_ACLK_HZ - 1; - assert((aclk_div + 1) * BUS_ACLK_HZ == GPLL_HZ && aclk_div <= 0x1f); + BUG_ON(!((aclk_div + 1) * BUS_ACLK_HZ == GPLL_HZ && aclk_div <= 0x1f));
pclk_div = BUS_ACLK_HZ / BUS_PCLK_HZ - 1; - assert((pclk_div + 1) * BUS_PCLK_HZ == BUS_ACLK_HZ && pclk_div <= 0x7); + BUG_ON(!((pclk_div + 1) * BUS_PCLK_HZ == BUS_ACLK_HZ && pclk_div <= 0x7));
hclk_div = BUS_ACLK_HZ / BUS_HCLK_HZ - 1; - assert((hclk_div + 1) * BUS_HCLK_HZ == BUS_ACLK_HZ && hclk_div <= 0x3); + BUG_ON(!((hclk_div + 1) * BUS_HCLK_HZ == BUS_ACLK_HZ && hclk_div <= 0x3));
rk_clrsetreg(&cru->cru_clksel_con[0], BUS_ACLK_PLL_SEL_MASK | BUS_ACLK_DIV_MASK, @@ -205,15 +204,13 @@ static void rkclk_init(struct rk3128_cru *cru) * set up dependent divisors for PCLK/HCLK and ACLK clocks. */ aclk_div = GPLL_HZ / PERI_ACLK_HZ - 1; - assert((aclk_div + 1) * PERI_ACLK_HZ == GPLL_HZ && aclk_div < 0x1f); + BUG_ON(!((aclk_div + 1) * PERI_ACLK_HZ == GPLL_HZ && aclk_div < 0x1f));
rk_clrsetreg(&cru->cru_clksel_con[10], PERI_PLL_SEL_MASK | PERI_PCLK_DIV_MASK | @@ -372,7 +369,7 @@ static ulong rk3128_peri_set_pclk(struct rk3128_cru *cru, ulong clk_id, uint hz) int src_clk_div;
src_clk_div = PERI_ACLK_HZ / hz; - assert(src_clk_div - 1 < 4); + BUG_ON(src_clk_div - 1 >= 4);
switch (clk_id) { case PCLK_I2C0: @@ -407,7 +404,7 @@ static ulong rk3128_saradc_set_clk(struct rk3128_cru *cru, uint hz) int src_clk_div;
src_clk_div = DIV_ROUND_UP(OSC_HZ, hz) - 1; - assert(src_clk_div < 128); + BUG_ON(src_clk_div >= 128);
rk_clrsetreg(&cru->cru_clksel_con[24], SARADC_DIV_CON_MASK, @@ -422,7 +419,7 @@ static ulong rk3128_vop_set_clk(struct rk3128_cru *cru, ulong clk_id, uint hz) struct pll_div cpll_config = {0};
src_clk_div = GPLL_HZ / hz; - assert(src_clk_div - 1 < 31); + BUG_ON(src_clk_div - 1 >= 31);
switch (clk_id) { case ACLK_VIO0: diff --git a/drivers/clk/rockchip/clk_rk3188.c b/drivers/clk/rockchip/clk_rk3188.c index fca6899..6a34459 100644 --- a/drivers/clk/rockchip/clk_rk3188.c +++ b/drivers/clk/rockchip/clk_rk3188.c @@ -96,9 +96,7 @@ static int rkclk_set_pll(struct rk3188_cru *cru, enum rk_clk_id clk_id,
debug("PLL at %x: nf=%d, nr=%d, no=%d, vco=%u Hz, output=%u Hz\n", (uint)pll, div->nf, div->nr, div->no, vco_hz, output_hz); - assert(vco_hz >= VCO_MIN_HZ && vco_hz <= VCO_MAX_HZ && - output_hz >= OUTPUT_MIN_HZ && output_hz <= OUTPUT_MAX_HZ && - (div->no == 1 || !(div->no % 2))); + BUG_ON(!(vco_hz >= VCO_MIN_HZ && vco_hz <= VCO_MAX_HZ && output_hz >= OUTPUT_MIN_HZ && output_hz <= OUTPUT_MAX_HZ && (div->no == 1 || !(div->no % 2))));
/* enter reset */ rk_setreg(&pll->con3, 1 << PLL_RESET_SHIFT); @@ -295,7 +293,7 @@ static ulong rockchip_mmc_set_clk(struct rk3188_cru *cru, uint gclk_rate, debug("%s: gclk_rate=%u\n", __func__, gclk_rate); /* mmc clock defaulg div 2 internal, need provide double in cru */ src_clk_div = DIV_ROUND_UP(gclk_rate / 2, freq) - 1; - assert(src_clk_div <= 0x3f); + BUG_ON(src_clk_div > 0x3f);
switch (periph) { case HCLK_EMMC: @@ -350,16 +348,16 @@ static ulong rockchip_spi_set_clk(struct rk3188_cru *cru, uint gclk_rate, { int src_clk_div = DIV_ROUND_UP(gclk_rate, freq) - 1;
- assert(src_clk_div < 128); + BUG_ON(src_clk_div >= 128); switch (periph) { case SCLK_SPI0: - assert(src_clk_div <= SPI0_DIV_MASK); + BUG_ON(src_clk_div > SPI0_DIV_MASK); rk_clrsetreg(&cru->cru_clksel_con[25], SPI0_DIV_MASK << SPI0_DIV_SHIFT, src_clk_div << SPI0_DIV_SHIFT); break; case SCLK_SPI1: - assert(src_clk_div <= SPI1_DIV_MASK); + BUG_ON(src_clk_div > SPI1_DIV_MASK); rk_clrsetreg(&cru->cru_clksel_con[25], SPI1_DIV_MASK << SPI1_DIV_SHIFT, src_clk_div << SPI1_DIV_SHIFT); @@ -400,7 +398,7 @@ static void rkclk_init(struct rk3188_cru *cru, struct rk3188_grf *grf, * set up dependent divisors for PCLK/HCLK and ACLK clocks. */ aclk_div = DIV_ROUND_UP(GPLL_HZ, CPU_ACLK_HZ) - 1; - assert((aclk_div + 1) * CPU_ACLK_HZ == GPLL_HZ && aclk_div <= 0x1f); + BUG_ON(!((aclk_div + 1) * CPU_ACLK_HZ == GPLL_HZ && aclk_div <= 0x1f));
rk_clrsetreg(&cru->cru_clksel_con[0], CPU_ACLK_PLL_MASK << CPU_ACLK_PLL_SHIFT | @@ -409,11 +407,11 @@ static void rkclk_init(struct rk3188_cru *cru, struct rk3188_grf *grf, aclk_div << A9_CPU_DIV_SHIFT);
hclk_div = ilog2(CPU_ACLK_HZ / CPU_HCLK_HZ); - assert((1 << hclk_div) * CPU_HCLK_HZ == CPU_ACLK_HZ && hclk_div < 0x3); + BUG_ON(!((1 << hclk_div) * CPU_HCLK_HZ == CPU_ACLK_HZ && hclk_div < 0x3)); pclk_div = ilog2(CPU_ACLK_HZ / CPU_PCLK_HZ); - assert((1 << pclk_div) * CPU_PCLK_HZ == CPU_ACLK_HZ && pclk_div < 0x4); + BUG_ON(!((1 << pclk_div) * CPU_PCLK_HZ == CPU_ACLK_HZ && pclk_div < 0x4)); h2p_div = ilog2(CPU_HCLK_HZ / CPU_H2P_HZ); - assert((1 << h2p_div) * CPU_H2P_HZ == CPU_HCLK_HZ && pclk_div < 0x3); + BUG_ON(!((1 << h2p_div) * CPU_H2P_HZ == CPU_HCLK_HZ && pclk_div < 0x3));
rk_clrsetreg(&cru->cru_clksel_con[1], AHB2APB_DIV_MASK << AHB2APB_DIV_SHIFT | @@ -428,15 +426,13 @@ static void rkclk_init(struct rk3188_cru *cru, struct rk3188_grf *grf, * set up dependent divisors for PCLK/HCLK and ACLK clocks. */ aclk_div = GPLL_HZ / PERI_ACLK_HZ - 1; - assert((aclk_div + 1) * PERI_ACLK_HZ == GPLL_HZ && aclk_div < 0x1f); + BUG_ON(!((aclk_div + 1) * PERI_ACLK_HZ == GPLL_HZ && aclk_div < 0x1f));
pclk_div = ilog2(PERI_ACLK_HZ / PERI_PCLK_HZ); - assert((1 << pclk_div) * PERI_PCLK_HZ == - PERI_ACLK_HZ && (pclk_div < 0x4)); + BUG_ON(!((1 << pclk_div) * PERI_PCLK_HZ == PERI_ACLK_HZ && (pclk_div < 0x4)));
rk_clrsetreg(&cru->cru_clksel_con[10], PERI_PCLK_DIV_MASK << PERI_PCLK_DIV_SHIFT | diff --git a/drivers/clk/rockchip/clk_rk322x.c b/drivers/clk/rockchip/clk_rk322x.c index ff52b55..300f7f8 100644 --- a/drivers/clk/rockchip/clk_rk322x.c +++ b/drivers/clk/rockchip/clk_rk322x.c @@ -54,8 +54,7 @@ static int rkclk_set_pll(struct rk322x_cru *cru, enum rk_clk_id clk_id, debug("PLL at %p: fb=%d, ref=%d, pst1=%d, pst2=%d, vco=%u Hz, output=%u Hz\n", pll, div->fbdiv, div->refdiv, div->postdiv1, div->postdiv2, vco_hz, output_hz); - assert(vco_hz >= VCO_MIN_HZ && vco_hz <= VCO_MAX_HZ && - output_hz >= OUTPUT_MIN_HZ && output_hz <= OUTPUT_MAX_HZ); + BUG_ON(!(vco_hz >= VCO_MIN_HZ && vco_hz <= VCO_MAX_HZ && output_hz >= OUTPUT_MIN_HZ && output_hz <= OUTPUT_MAX_HZ));
/* use integer mode */ rk_setreg(&pll->con1, 1 << PLL_DSMPD_SHIFT); @@ -101,10 +100,10 @@ static void rkclk_init(struct rk322x_cru *cru) * core hz : apll = 1:1 */ aclk_div = APLL_HZ / CORE_ACLK_HZ - 1; - assert((aclk_div + 1) * CORE_ACLK_HZ == APLL_HZ && aclk_div < 0x7); + BUG_ON(!((aclk_div + 1) * CORE_ACLK_HZ == APLL_HZ && aclk_div < 0x7));
rk_clrsetreg(&cru->cru_clksel_con[0], CORE_CLK_PLL_SEL_MASK | CORE_DIV_CON_MASK, @@ -121,13 +120,13 @@ static void rkclk_init(struct rk322x_cru *cru) * set up dependent divisors for PCLK/HCLK and ACLK clocks. */ aclk_div = GPLL_HZ / BUS_ACLK_HZ - 1; - assert((aclk_div + 1) * BUS_ACLK_HZ == GPLL_HZ && aclk_div <= 0x1f); + BUG_ON(!((aclk_div + 1) * BUS_ACLK_HZ == GPLL_HZ && aclk_div <= 0x1f));
pclk_div = BUS_ACLK_HZ / BUS_PCLK_HZ - 1; - assert((pclk_div + 1) * BUS_PCLK_HZ == GPLL_HZ && pclk_div <= 0x7); + BUG_ON(!((pclk_div + 1) * BUS_PCLK_HZ == GPLL_HZ && pclk_div <= 0x7));
hclk_div = BUS_ACLK_HZ / BUS_HCLK_HZ - 1; - assert((hclk_div + 1) * BUS_HCLK_HZ == GPLL_HZ && hclk_div <= 0x3); + BUG_ON(!((hclk_div + 1) * BUS_HCLK_HZ == GPLL_HZ && hclk_div <= 0x3));
rk_clrsetreg(&cru->cru_clksel_con[0], BUS_ACLK_PLL_SEL_MASK | BUS_ACLK_DIV_MASK, @@ -144,15 +143,13 @@ static void rkclk_init(struct rk322x_cru *cru) * set up dependent divisors for PCLK/HCLK and ACLK clocks. */ aclk_div = GPLL_HZ / PERI_ACLK_HZ - 1; - assert((aclk_div + 1) * PERI_ACLK_HZ == GPLL_HZ && aclk_div < 0x1f); + BUG_ON(!((aclk_div + 1) * PERI_ACLK_HZ == GPLL_HZ && aclk_div < 0x1f));
rk_clrsetreg(&cru->cru_clksel_con[10], PERI_PLL_SEL_MASK | PERI_PCLK_DIV_MASK | @@ -252,7 +249,7 @@ static ulong rockchip_mmc_set_clk(struct rk322x_cru *cru, uint clk_general_rate,
if (src_clk_div > 128) { src_clk_div = DIV_ROUND_UP(OSC_HZ / 2, freq); - assert(src_clk_div - 1 < 128); + BUG_ON(src_clk_div - 1 >= 128); mux = EMMC_SEL_24M; } else { mux = EMMC_SEL_GPLL; diff --git a/drivers/clk/rockchip/clk_rk3288.c b/drivers/clk/rockchip/clk_rk3288.c index ac53239..c97bbc4 100644 --- a/drivers/clk/rockchip/clk_rk3288.c +++ b/drivers/clk/rockchip/clk_rk3288.c @@ -152,9 +152,7 @@ static int rkclk_set_pll(struct rk3288_cru *cru, enum rk_clk_id clk_id,
/* enter reset */ rk_setreg(&pll->con3, 1 << PLL_RESET_SHIFT); @@ -374,14 +372,12 @@ static void rkclk_init(struct rk3288_cru *cru, struct rk3288_grf *grf) * set up dependent divisors for PCLK/HCLK and ACLK clocks. */ aclk_div = GPLL_HZ / PD_BUS_ACLK_HZ - 1; - assert((aclk_div + 1) * PD_BUS_ACLK_HZ == GPLL_HZ && aclk_div < 0x1f); + BUG_ON(!((aclk_div + 1) * PD_BUS_ACLK_HZ == GPLL_HZ && aclk_div < 0x1f)); hclk_div = PD_BUS_ACLK_HZ / PD_BUS_HCLK_HZ - 1; - assert((hclk_div + 1) * PD_BUS_HCLK_HZ == - PD_BUS_ACLK_HZ && (hclk_div < 0x4) && (hclk_div != 0x2)); + BUG_ON(!((hclk_div + 1) * PD_BUS_HCLK_HZ == PD_BUS_ACLK_HZ && (hclk_div < 0x4) && (hclk_div != 0x2)));
pclk_div = PD_BUS_ACLK_HZ / PD_BUS_PCLK_HZ - 1; - assert((pclk_div + 1) * PD_BUS_PCLK_HZ == - PD_BUS_ACLK_HZ && pclk_div < 0x7); + BUG_ON(!((pclk_div + 1) * PD_BUS_PCLK_HZ == PD_BUS_ACLK_HZ && pclk_div < 0x7));
rk_clrsetreg(&cru->cru_clksel_con[1], PD_BUS_PCLK_DIV_MASK | PD_BUS_HCLK_DIV_MASK | @@ -396,15 +392,13 @@ static void rkclk_init(struct rk3288_cru *cru, struct rk3288_grf *grf) * set up dependent divisors for PCLK/HCLK and ACLK clocks. */ aclk_div = GPLL_HZ / PERI_ACLK_HZ - 1; - assert((aclk_div + 1) * PERI_ACLK_HZ == GPLL_HZ && aclk_div < 0x1f); + BUG_ON(!((aclk_div + 1) * PERI_ACLK_HZ == GPLL_HZ && aclk_div < 0x1f));
rk_clrsetreg(&cru->cru_clksel_con[10], PERI_PCLK_DIV_MASK | PERI_HCLK_DIV_MASK | @@ -542,14 +536,12 @@ static ulong rockchip_mmc_set_clk(struct rk3288_cru *cru, uint gclk_rate,
if (src_clk_div > 0x3f) { src_clk_div = DIV_ROUND_UP(OSC_HZ / 2, freq); - assert(src_clk_div < 0x40); + BUG_ON(src_clk_div >= 0x40); mux = EMMC_PLL_SELECT_24MHZ; - assert((int)EMMC_PLL_SELECT_24MHZ == - (int)MMC0_PLL_SELECT_24MHZ); + BUG_ON((int)EMMC_PLL_SELECT_24MHZ != (int)MMC0_PLL_SELECT_24MHZ); } else { mux = EMMC_PLL_SELECT_GENERAL; - assert((int)EMMC_PLL_SELECT_GENERAL == - (int)MMC0_PLL_SELECT_GENERAL); + BUG_ON((int)EMMC_PLL_SELECT_GENERAL != (int)MMC0_PLL_SELECT_GENERAL); } switch (periph) { case HCLK_EMMC: @@ -605,7 +597,7 @@ static ulong rockchip_spi_get_clk(struct rk3288_cru *cru, uint gclk_rate, default: return -EINVAL; } - assert(mux == SPI0_PLL_SELECT_GENERAL); + BUG_ON(mux != SPI0_PLL_SELECT_GENERAL);
return DIV_TO_RATE(gclk_rate, div); } @@ -617,7 +609,7 @@ static ulong rockchip_spi_set_clk(struct rk3288_cru *cru, uint gclk_rate,
debug("%s: clk_general_rate=%u\n", __func__, gclk_rate); src_clk_div = DIV_ROUND_UP(gclk_rate, freq) - 1; - assert(src_clk_div < 128); + BUG_ON(src_clk_div >= 128); switch (periph) { case SCLK_SPI0: rk_clrsetreg(&cru->cru_clksel_con[25], @@ -660,7 +652,7 @@ static ulong rockchip_saradc_set_clk(struct rk3288_cru *cru, uint hz) int src_clk_div;
rk_clrsetreg(&cru->cru_clksel_con[24], CLK_SARADC_DIV_CON_MASK, @@ -766,7 +758,7 @@ static ulong rk3288_clk_set_rate(struct clk *clk, ulong rate)
/* vop aclk source clk: cpll */ div = CPLL_HZ / rate; - assert((div - 1 < 64) && (div * rate == CPLL_HZ)); + BUG_ON(!((div - 1 < 64) && (div * rate == CPLL_HZ)));
switch (clk->id) { case ACLK_VOP0: diff --git a/drivers/clk/rockchip/clk_rk3328.c b/drivers/clk/rockchip/clk_rk3328.c index 4d522a7..21a7a88 100644 --- a/drivers/clk/rockchip/clk_rk3328.c +++ b/drivers/clk/rockchip/clk_rk3328.c @@ -239,9 +239,7 @@ static void rkclk_set_pll(struct rk3328_cru *cru, enum rk_clk_id clk_id, postdiv2=%d, vco=%u khz, output=%u khz\n", pll_con, div->fbdiv, div->refdiv, div->postdiv1, div->postdiv2, vco_khz, output_khz); - assert(vco_khz >= VCO_MIN_KHZ && vco_khz <= VCO_MAX_KHZ && - output_khz >= OUTPUT_MIN_KHZ && output_khz <= OUTPUT_MAX_KHZ && - div->fbdiv >= PLL_DIV_MIN && div->fbdiv <= PLL_DIV_MAX); + BUG_ON(!(vco_khz >= VCO_MIN_KHZ && vco_khz <= VCO_MAX_KHZ && output_khz >= OUTPUT_MIN_KHZ && output_khz <= OUTPUT_MAX_KHZ && div->fbdiv >= PLL_DIV_MIN && div->fbdiv <= PLL_DIV_MAX));
/* * When power on or changing PLL setting, @@ -354,7 +352,7 @@ static ulong rk3328_i2c_set_clk(struct rk3328_cru *cru, ulong clk_id, uint hz) int src_clk_div;
src_clk_div = GPLL_HZ / hz; - assert(src_clk_div - 1 < 127); + BUG_ON(src_clk_div - 1 >= 127);
switch (clk_id) { case SCLK_I2C0: @@ -496,7 +494,7 @@ static ulong rk3328_saradc_set_clk(struct rk3328_cru *cru, uint hz) int src_clk_div;
rk_clrsetreg(&cru->clksel_con[23], CLK_SARADC_DIV_CON_MASK, diff --git a/drivers/clk/rockchip/clk_rk3368.c b/drivers/clk/rockchip/clk_rk3368.c index bfeef39..e295afb 100644 --- a/drivers/clk/rockchip/clk_rk3368.c +++ b/drivers/clk/rockchip/clk_rk3368.c @@ -377,7 +377,7 @@ static ulong rk3368_spi_set_clk(struct rk3368_cru *cru, ulong clk_id, uint hz) int src_clk_div;
src_clk_div = DIV_ROUND_UP(GPLL_HZ, hz); - assert(src_clk_div < 127); + BUG_ON(src_clk_div >= 127);
switch (clk_id) { case SCLK_SPI0 ... SCLK_SPI2: @@ -414,7 +414,7 @@ static ulong rk3368_saradc_set_clk(struct rk3368_cru *cru, uint hz) int src_clk_div;
rk_clrsetreg(&cru->clksel_con[25], CLK_SARADC_DIV_CON_MASK, diff --git a/drivers/clk/rockchip/clk_rk3399.c b/drivers/clk/rockchip/clk_rk3399.c index 2e85ac7..e02342c 100644 --- a/drivers/clk/rockchip/clk_rk3399.c +++ b/drivers/clk/rockchip/clk_rk3399.c @@ -301,9 +301,7 @@ static void rkclk_set_pll(u32 *pll_con, const struct pll_div *div) "postdiv2=%d, vco=%u khz, output=%u khz\n", pll_con, div->fbdiv, div->refdiv, div->postdiv1, div->postdiv2, vco_khz, output_khz); - assert(vco_khz >= VCO_MIN_KHZ && vco_khz <= VCO_MAX_KHZ && - output_khz >= OUTPUT_MIN_KHZ && output_khz <= OUTPUT_MAX_KHZ && - div->fbdiv >= PLL_DIV_MIN && div->fbdiv <= PLL_DIV_MAX); + BUG_ON(!(vco_khz >= VCO_MIN_KHZ && vco_khz <= VCO_MAX_KHZ && output_khz >= OUTPUT_MIN_KHZ && output_khz <= OUTPUT_MAX_KHZ && div->fbdiv >= PLL_DIV_MIN && div->fbdiv <= PLL_DIV_MAX));
/* * When power on or changing PLL setting, @@ -408,16 +406,13 @@ void rk3399_configure_cpu(struct rk3399_cru *cru, rkclk_set_pll(&cru->apll_l_con[0], apll_l_cfgs[apll_l_freq]);
aclkm_div = APLL_HZ / ACLKM_CORE_HZ - 1; - assert((aclkm_div + 1) * ACLKM_CORE_HZ == APLL_HZ && - aclkm_div < 0x1f); + BUG_ON(!((aclkm_div + 1) * ACLKM_CORE_HZ == APLL_HZ && aclkm_div < 0x1f));
pclk_dbg_div = APLL_HZ / PCLK_DBG_HZ - 1; - assert((pclk_dbg_div + 1) * PCLK_DBG_HZ == APLL_HZ && - pclk_dbg_div < 0x1f); + BUG_ON(!((pclk_dbg_div + 1) * PCLK_DBG_HZ == APLL_HZ && pclk_dbg_div < 0x1f));
atclk_div = APLL_HZ / ATCLK_CORE_HZ - 1; - assert((atclk_div + 1) * ATCLK_CORE_HZ == APLL_HZ && - atclk_div < 0x1f); + BUG_ON(!((atclk_div + 1) * ATCLK_CORE_HZ == APLL_HZ && atclk_div < 0x1f));
rk_clrsetreg(&cru->clksel_con[0], ACLKM_CORE_L_DIV_CON_MASK | CLK_CORE_L_PLL_SEL_MASK | @@ -498,7 +493,7 @@ static ulong rk3399_i2c_set_clk(struct rk3399_cru *cru, ulong clk_id, uint hz)
/* i2c0,4,8 src clock from ppll, i2c1,2,3,5,6,7 src clock from gpll*/ src_clk_div = GPLL_HZ / hz; - assert(src_clk_div - 1 < 127); + BUG_ON(src_clk_div - 1 >= 127);
switch (clk_id) { case SCLK_I2C1: @@ -597,7 +592,7 @@ static ulong rk3399_spi_set_clk(struct rk3399_cru *cru, ulong clk_id, uint hz) int src_clk_div;
src_clk_div = DIV_ROUND_UP(GPLL_HZ, hz) - 1; - assert(src_clk_div < 128); + BUG_ON(src_clk_div >= 128);
switch (clk_id) { case SCLK_SPI1 ... SCLK_SPI5: @@ -639,7 +634,7 @@ static ulong rk3399_vop_set_clk(struct rk3399_cru *cru, ulong clk_id, u32 hz) } /* vop aclk source clk: cpll */ div = CPLL_HZ / aclk_vop; - assert(div - 1 < 32); + BUG_ON(div - 1 >= 32);
rk_clrsetreg(aclkreg_addr, ACLK_VOP_PLL_SEL_MASK | ACLK_VOP_DIV_CON_MASK, @@ -705,7 +700,7 @@ static ulong rk3399_mmc_set_clk(struct rk3399_cru *cru, if (src_clk_div > 128) { /* use 24MHz source for 400KHz clock */ src_clk_div = DIV_ROUND_UP(OSC_HZ / 2, set_rate); - assert(src_clk_div - 1 < 128); + BUG_ON(src_clk_div - 1 >= 128); rk_clrsetreg(&cru->clksel_con[16], CLK_EMMC_PLL_MASK | CLK_EMMC_DIV_CON_MASK, CLK_EMMC_PLL_SEL_24M << CLK_EMMC_PLL_SHIFT | @@ -720,7 +715,7 @@ static ulong rk3399_mmc_set_clk(struct rk3399_cru *cru, case SCLK_EMMC: /* Select aclk_emmc source from GPLL */ src_clk_div = DIV_ROUND_UP(GPLL_HZ , aclk_emmc); - assert(src_clk_div - 1 < 32); + BUG_ON(src_clk_div - 1 >= 32);
rk_clrsetreg(&cru->clksel_con[21], ACLK_EMMC_PLL_SEL_MASK | ACLK_EMMC_DIV_CON_MASK, @@ -729,7 +724,7 @@ static ulong rk3399_mmc_set_clk(struct rk3399_cru *cru,
/* Select clk_emmc source from GPLL too */ src_clk_div = DIV_ROUND_UP(GPLL_HZ, set_rate); - assert(src_clk_div - 1 < 128); + BUG_ON(src_clk_div - 1 >= 128);
rk_clrsetreg(&cru->clksel_con[22], CLK_EMMC_PLL_MASK | CLK_EMMC_DIV_CON_MASK, @@ -797,7 +792,7 @@ static ulong rk3399_saradc_set_clk(struct rk3399_cru *cru, uint hz) int src_clk_div;
rk_clrsetreg(&cru->clksel_con[26], CLK_SARADC_DIV_CON_MASK, @@ -945,15 +940,13 @@ static void rkclk_init(struct rk3399_cru *cru)
/* configure perihp aclk, hclk, pclk */ aclk_div = GPLL_HZ / PERIHP_ACLK_HZ - 1; - assert((aclk_div + 1) * PERIHP_ACLK_HZ == GPLL_HZ && aclk_div < 0x1f); + BUG_ON(!((aclk_div + 1) * PERIHP_ACLK_HZ == GPLL_HZ && aclk_div < 0x1f));
hclk_div = PERIHP_ACLK_HZ / PERIHP_HCLK_HZ - 1; - assert((hclk_div + 1) * PERIHP_HCLK_HZ == - PERIHP_ACLK_HZ && (hclk_div < 0x4)); + BUG_ON(!((hclk_div + 1) * PERIHP_HCLK_HZ == PERIHP_ACLK_HZ && (hclk_div < 0x4)));
pclk_div = PERIHP_ACLK_HZ / PERIHP_PCLK_HZ - 1; - assert((pclk_div + 1) * PERIHP_PCLK_HZ == - PERIHP_ACLK_HZ && (pclk_div < 0x7)); + BUG_ON(!((pclk_div + 1) * PERIHP_PCLK_HZ == PERIHP_ACLK_HZ && (pclk_div < 0x7)));
rk_clrsetreg(&cru->clksel_con[14], PCLK_PERIHP_DIV_CON_MASK | HCLK_PERIHP_DIV_CON_MASK | @@ -965,15 +958,13 @@ static void rkclk_init(struct rk3399_cru *cru)
/* configure perilp0 aclk, hclk, pclk */ aclk_div = GPLL_HZ / PERILP0_ACLK_HZ - 1; - assert((aclk_div + 1) * PERILP0_ACLK_HZ == GPLL_HZ && aclk_div < 0x1f); + BUG_ON(!((aclk_div + 1) * PERILP0_ACLK_HZ == GPLL_HZ && aclk_div < 0x1f));
hclk_div = PERILP0_ACLK_HZ / PERILP0_HCLK_HZ - 1; - assert((hclk_div + 1) * PERILP0_HCLK_HZ == - PERILP0_ACLK_HZ && (hclk_div < 0x4)); + BUG_ON(!((hclk_div + 1) * PERILP0_HCLK_HZ == PERILP0_ACLK_HZ && (hclk_div < 0x4)));
pclk_div = PERILP0_ACLK_HZ / PERILP0_PCLK_HZ - 1; - assert((pclk_div + 1) * PERILP0_PCLK_HZ == - PERILP0_ACLK_HZ && (pclk_div < 0x7)); + BUG_ON(!((pclk_div + 1) * PERILP0_PCLK_HZ == PERILP0_ACLK_HZ && (pclk_div < 0x7)));
rk_clrsetreg(&cru->clksel_con[23], PCLK_PERILP0_DIV_CON_MASK | HCLK_PERILP0_DIV_CON_MASK | @@ -985,12 +976,10 @@ static void rkclk_init(struct rk3399_cru *cru)
/* perilp1 hclk select gpll as source */ hclk_div = GPLL_HZ / PERILP1_HCLK_HZ - 1; - assert((hclk_div + 1) * PERILP1_HCLK_HZ == - GPLL_HZ && (hclk_div < 0x1f)); + BUG_ON(!((hclk_div + 1) * PERILP1_HCLK_HZ == GPLL_HZ && (hclk_div < 0x1f)));
pclk_div = PERILP1_HCLK_HZ / PERILP1_HCLK_HZ - 1; - assert((pclk_div + 1) * PERILP1_HCLK_HZ == - PERILP1_HCLK_HZ && (hclk_div < 0x7)); + BUG_ON(!((pclk_div + 1) * PERILP1_HCLK_HZ == PERILP1_HCLK_HZ && (hclk_div < 0x7)));
rk_clrsetreg(&cru->clksel_con[25], PCLK_PERILP1_DIV_CON_MASK | HCLK_PERILP1_DIV_CON_MASK | @@ -1099,7 +1088,7 @@ static ulong rk3399_i2c_set_pmuclk(struct rk3399_pmucru *pmucru, ulong clk_id, int src_clk_div;
src_clk_div = PPLL_HZ / hz; - assert(src_clk_div - 1 < 127); + BUG_ON(src_clk_div - 1 >= 127);
switch (clk_id) { case SCLK_I2C0_PMU: diff --git a/drivers/clk/rockchip/clk_rv1108.c b/drivers/clk/rockchip/clk_rv1108.c index a119548..38d7548 100644 --- a/drivers/clk/rockchip/clk_rv1108.c +++ b/drivers/clk/rockchip/clk_rv1108.c @@ -147,7 +147,7 @@ static ulong rv1108_saradc_set_clk(struct rv1108_cru *cru, uint hz) int src_clk_div;
rk_clrsetreg(&cru->clksel_con[22], CLK_SARADC_DIV_CON_MASK, diff --git a/drivers/core/device-remove.c b/drivers/core/device-remove.c index 3c6ab42..de96024 100644 --- a/drivers/core/device-remove.c +++ b/drivers/core/device-remove.c @@ -32,7 +32,7 @@ static int device_chld_unbind(struct udevice *dev) struct udevice *pos, *n; int ret, saved_ret = 0;
- assert(dev); + BUG_ON(!dev);
list_for_each_entry_safe(pos, n, &dev->child_head, sibling_node) { ret = device_unbind(pos); @@ -54,7 +54,7 @@ static int device_chld_remove(struct udevice *dev, uint flags) struct udevice *pos, *n; int ret;
list_for_each_entry_safe(pos, n, &dev->child_head, sibling_node) { ret = device_remove(pos, flags); @@ -80,7 +80,7 @@ int device_unbind(struct udevice *dev) return -EINVAL;
drv = dev->driver; - assert(drv); + BUG_ON(!drv);
if (drv->unbind) { ret = drv->unbind(dev); @@ -173,7 +173,7 @@ int device_remove(struct udevice *dev, uint flags) return 0;
ret = uclass_pre_remove_device(dev); if (ret) diff --git a/drivers/core/device.c b/drivers/core/device.c index 9a46a7b..df1b6e4 100644 --- a/drivers/core/device.c +++ b/drivers/core/device.c @@ -307,7 +307,7 @@ int device_probe(struct udevice *dev) return 0;
/* Allocate private data if requested and not reentered */ if (drv->priv_auto_alloc_size && !dev->priv) { diff --git a/drivers/core/ofnode.c b/drivers/core/ofnode.c index 0030ab9..e059efe 100644 --- a/drivers/core/ofnode.c +++ b/drivers/core/ofnode.c @@ -18,7 +18,7 @@
int ofnode_read_u32(ofnode node, const char *propname, u32 *outp) { - assert(ofnode_valid(node)); + BUG_ON(!ofnode_valid(node)); debug("%s: %s: ", __func__, propname);
if (ofnode_is_np(node)) { @@ -42,7 +42,7 @@ int ofnode_read_u32(ofnode node, const char *propname, u32 *outp)
int ofnode_read_u32_default(ofnode node, const char *propname, u32 def) { - assert(ofnode_valid(node)); + BUG_ON(!ofnode_valid(node)); ofnode_read_u32(node, propname, &def);
return def; @@ -50,7 +50,7 @@ int ofnode_read_u32_default(ofnode node, const char *propname, u32 def)
int ofnode_read_s32_default(ofnode node, const char *propname, s32 def) { - assert(ofnode_valid(node)); + BUG_ON(!ofnode_valid(node)); ofnode_read_u32(node, propname, (u32 *)&def);
return def; @@ -60,7 +60,7 @@ bool ofnode_read_bool(ofnode node, const char *propname) { const void *prop;
prop = ofnode_get_property(node, propname, NULL); @@ -75,7 +75,7 @@ const char *ofnode_read_string(ofnode node, const char *propname) const char *str = NULL; int len = -1;
if (ofnode_is_np(node)) { @@ -107,7 +107,7 @@ ofnode ofnode_find_subnode(ofnode node, const char *subnode_name) { ofnode subnode;
- assert(ofnode_valid(node)); + BUG_ON(!ofnode_valid(node)); debug("%s: %s: ", __func__, subnode_name);
if (ofnode_is_np(node)) { @@ -132,7 +132,7 @@ ofnode ofnode_find_subnode(ofnode node, const char *subnode_name) int ofnode_read_u32_array(ofnode node, const char *propname, u32 *out_values, size_t sz) { - assert(ofnode_valid(node)); + BUG_ON(!ofnode_valid(node)); debug("%s: %s: ", __func__, propname);
if (ofnode_is_np(node)) { @@ -147,7 +147,7 @@ int ofnode_read_u32_array(ofnode node, const char *propname,
ofnode ofnode_first_subnode(ofnode node) { - assert(ofnode_valid(node)); + BUG_ON(!ofnode_valid(node)); if (ofnode_is_np(node)) return np_to_ofnode(node.np->child);
@@ -157,7 +157,7 @@ ofnode ofnode_first_subnode(ofnode node)
ofnode ofnode_next_subnode(ofnode node) { - assert(ofnode_valid(node)); + BUG_ON(!ofnode_valid(node)); if (ofnode_is_np(node)) return np_to_ofnode(node.np->sibling);
@@ -167,7 +167,7 @@ ofnode ofnode_next_subnode(ofnode node)
const char *ofnode_get_name(ofnode node) { - assert(ofnode_valid(node)); + BUG_ON(!ofnode_valid(node)); if (ofnode_is_np(node)) return strrchr(node.np->full_name, '/') + 1;
@@ -271,7 +271,7 @@ int ofnode_read_string_count(ofnode node, const char *property) static void ofnode_from_fdtdec_phandle_args(struct fdtdec_phandle_args *in, struct ofnode_phandle_args *out) { - assert(OF_MAX_PHANDLE_ARGS == MAX_PHANDLE_ARGS); + BUG_ON(OF_MAX_PHANDLE_ARGS != MAX_PHANDLE_ARGS); out->node = offset_to_ofnode(in->node); out->args_count = in->args_count; memcpy(out->args, in->args, sizeof(out->args)); @@ -280,7 +280,7 @@ static void ofnode_from_fdtdec_phandle_args(struct fdtdec_phandle_args *in, static void ofnode_from_of_phandle_args(struct of_phandle_args *in, struct ofnode_phandle_args *out) { - assert(OF_MAX_PHANDLE_ARGS == MAX_PHANDLE_ARGS); + BUG_ON(OF_MAX_PHANDLE_ARGS != MAX_PHANDLE_ARGS); out->node = np_to_ofnode(in->np); out->args_count = in->args_count; memcpy(out->args, in->args, sizeof(out->args)); diff --git a/drivers/core/uclass.c b/drivers/core/uclass.c index f5e4067..3a47cdc 100644 --- a/drivers/core/uclass.c +++ b/drivers/core/uclass.c @@ -371,7 +371,7 @@ int uclass_get_device_tail(struct udevice *dev, int ret, struct udevice **devp) if (ret) return ret;
- assert(dev); + BUG_ON(!dev); ret = device_probe(dev); if (ret) return ret; @@ -569,7 +569,7 @@ int uclass_resolve_seq(struct udevice *dev) int seq; int ret;
- assert(dev->seq == -1); + BUG_ON(dev->seq != -1); ret = uclass_find_device_by_seq(dev->uclass->uc_drv->id, dev->req_seq, false, &dup); if (!ret) { diff --git a/drivers/gpio/gpio-uclass.c b/drivers/gpio/gpio-uclass.c index 9faf335..b3e544a 100644 --- a/drivers/gpio/gpio-uclass.c +++ b/drivers/gpio/gpio-uclass.c @@ -480,7 +480,7 @@ const char *gpio_get_bank_info(struct udevice *dev, int *bit_count)
/* Must be called on an active device */ priv = dev_get_uclass_priv(dev); - assert(priv); + BUG_ON(!priv);
*bit_count = priv->gpio_count; return priv->bank_name; diff --git a/drivers/i2c/i2c-uclass.c b/drivers/i2c/i2c-uclass.c index 920811a..3143056 100644 --- a/drivers/i2c/i2c-uclass.c +++ b/drivers/i2c/i2c-uclass.c @@ -51,7 +51,7 @@ static int i2c_setup_offset(struct dm_i2c_chip *chip, uint offset, msg->buf = offset_buf; if (!chip->offset_len) return -EADDRNOTAVAIL; - assert(chip->offset_len <= I2C_MAX_OFFSET_LEN); + BUG_ON(chip->offset_len > I2C_MAX_OFFSET_LEN); offset_len = chip->offset_len; while (offset_len--) *offset_buf++ = offset >> (8 * offset_len); diff --git a/drivers/input/input.c b/drivers/input/input.c index 26da3a9..7fb72f0 100644 --- a/drivers/input/input.c +++ b/drivers/input/input.c @@ -248,7 +248,7 @@ static struct input_key_xlate *process_modifier(struct input_config *config, int i;
/* Start with the main table, and see what modifiers change it */ - assert(config->num_tables > 0); + BUG_ON(0 >= config->num_tables); table = &config->table[0]; for (i = 1; i < config->num_tables; i++) { struct input_key_xlate *tab = &config->table[i]; @@ -356,7 +356,7 @@ static int sort_array_by_ordering(int *dest, int count, int *order, if (array_search(order, ocount, temp[i]) == -1) dest[dest_count++] = temp[i]; } - assert(dest_count == count); + BUG_ON(dest_count != count); return same; }
diff --git a/drivers/input/key_matrix.c b/drivers/input/key_matrix.c index cd5bce3..a30f4c9 100644 --- a/drivers/input/key_matrix.c +++ b/drivers/input/key_matrix.c @@ -184,7 +184,7 @@ int key_matrix_init(struct key_matrix *config, int rows, int cols, config->num_cols = cols; config->key_count = rows * cols; config->ghost_filter = ghost_filter; - assert(config->key_count > 0); + BUG_ON(0 >= config->key_count);
return 0; } diff --git a/drivers/misc/cros_ec.c b/drivers/misc/cros_ec.c index eefaaa5..7d700c5 100644 --- a/drivers/misc/cros_ec.c +++ b/drivers/misc/cros_ec.c @@ -308,7 +308,7 @@ static int ec_command_inptr(struct cros_ec_dev *dev, uint8_t cmd, debug("%s: len=%d, din=%p\n", __func__, len, din); if (dinp) { /* If we have any data to return, it must be 64bit-aligned */ - assert(len <= 0 || !((uintptr_t)din & 7)); + BUG_ON(!(len <= 0 || !((uintptr_t)din & 7))); *dinp = din; }
@@ -338,7 +338,7 @@ static int ec_command(struct cros_ec_dev *dev, uint8_t cmd, int cmd_version, uint8_t *in_buffer; int len;
- assert((din_len == 0) || din); + BUG_ON(!((din_len == 0) || din)); len = ec_command_inptr(dev, cmd, cmd_version, dout, dout_len, &in_buffer, din_len); if (len > 0) { @@ -347,7 +347,7 @@ static int ec_command(struct cros_ec_dev *dev, uint8_t cmd, int cmd_version, * disregard the result. */ if (din && in_buffer) { - assert(len <= din_len); + BUG_ON(len > din_len); memmove(din, in_buffer, len); } } @@ -756,7 +756,7 @@ static int cros_ec_flash_write_block(struct cros_ec_dev *dev,
p->offset = offset; p->size = size; - assert(data && p->size <= EC_FLASH_WRITE_VER0_SIZE); + BUG_ON(!(data && p->size <= EC_FLASH_WRITE_VER0_SIZE)); memcpy(p + 1, data, p->size);
ret = ec_command_inptr(dev, EC_CMD_FLASH_WRITE, 0, @@ -787,7 +787,7 @@ static int cros_ec_flash_write_burst_size(struct cros_ec_dev *dev) */ static int cros_ec_data_is_erased(const uint32_t *data, int size) { - assert(!(size & 3)); + BUG_ON((size & 3)); size /= sizeof(uint32_t); for (; size > 0; size -= 4, data++) if (*data != -1U) diff --git a/drivers/misc/cros_ec_i2c.c b/drivers/misc/cros_ec_i2c.c index 6e09340..6e87014 100644 --- a/drivers/misc/cros_ec_i2c.c +++ b/drivers/misc/cros_ec_i2c.c @@ -135,8 +135,8 @@ static int cros_ec_i2c_command(struct udevice *udev, uint8_t cmd, debug("%s: Cannot receive %d bytes\n", __func__, din_len); return -1; } - assert(dout_len >= 0); - assert(dinp); + BUG_ON(0 > dout_len); + BUG_ON(!dinp);
i2c_msg[0].addr = chip->chip_addr; i2c_msg[0].len = out_bytes; diff --git a/drivers/mtd/nand/tegra_nand.c b/drivers/mtd/nand/tegra_nand.c index c03c9cb..a5251aa 100644 --- a/drivers/mtd/nand/tegra_nand.c +++ b/drivers/mtd/nand/tegra_nand.c @@ -259,7 +259,7 @@ static void nand_command(struct mtd_info *mtd, unsigned int command,
/* Emulate NAND_CMD_READOOB */ if (command == NAND_CMD_READOOB) { - assert(mtd->writesize != 0); + BUG_ON(!mtd->writesize); column += mtd->writesize; command = NAND_CMD_READ0; } diff --git a/drivers/mtd/spi/sandbox.c b/drivers/mtd/spi/sandbox.c index 1ba6815..28ff86d 100644 --- a/drivers/mtd/spi/sandbox.c +++ b/drivers/mtd/spi/sandbox.c @@ -138,7 +138,7 @@ static int sandbox_sf_probe(struct udevice *dev) if (!pdata->filename) { struct sandbox_state *state = state_get_current();
- assert(bus->seq != -1); + BUG_ON(bus->seq == -1); if (bus->seq < CONFIG_SANDBOX_SPI_MAX_BUS) spec = state->spi[bus->seq][cs].spec; if (!spec) { @@ -416,7 +416,7 @@ static int sandbox_sf_xfer(struct udevice *dev, unsigned int bitlen,
cnt = bytes - pos; debug(" tx: read(%u)\n", cnt); - assert(tx); + BUG_ON(!tx); ret = os_read(sbsf->fd, tx + pos, cnt); if (ret < 0) { puts("sandbox_sf: os_read() failed\n"); diff --git a/drivers/net/fsl-mc/mc.c b/drivers/net/fsl-mc/mc.c index c76f582..4572adb 100644 --- a/drivers/net/fsl-mc/mc.c +++ b/drivers/net/fsl-mc/mc.c @@ -591,7 +591,7 @@ static int wait_for_mc(bool booting_mc, u32 *final_reg_gsr) struct mc_ccsr_registers __iomem *mc_ccsr_regs = MC_CCSR_BASE_ADDR;
dmb(); - assert(timeout_ms > 0); + BUG_ON(0 >= timeout_ms); for (;;) { udelay(1000); /* throttle polling */ reg_gsr = in_le32(&mc_ccsr_regs->reg_gsr); diff --git a/drivers/phy/phy-uclass.c b/drivers/phy/phy-uclass.c index 68e518f..203816a 100644 --- a/drivers/phy/phy-uclass.c +++ b/drivers/phy/phy-uclass.c @@ -44,7 +44,7 @@ int generic_phy_get_by_index(struct udevice *dev, int index,
debug("%s(dev=%p, index=%d, phy=%p)\n", __func__, dev, index, phy);
- assert(phy); + BUG_ON(!phy); phy->dev = NULL; ret = dev_read_phandle_with_args(dev, "phys", "#phy-cells", 0, index, &args); diff --git a/drivers/power/tps6586x.c b/drivers/power/tps6586x.c index f50c4d1..12b51b9 100644 --- a/drivers/power/tps6586x.c +++ b/drivers/power/tps6586x.c @@ -151,7 +151,7 @@ int tps6586x_set_pwm_mode(int mask) uchar val; int ret;
- assert(tps6586x_dev); + BUG_ON(!tps6586x_dev); ret = tps6586x_read(PFM_MODE); if (ret != -1) { val = (uchar)ret; @@ -172,7 +172,7 @@ int tps6586x_adjust_sm0_sm1(int sm0_target, int sm1_target, int step, int rate, int sm0, sm1; int bad;
/* get current voltage settings */ if (read_voltages(&sm0, &sm1)) { diff --git a/drivers/rtc/rtc-uclass.c b/drivers/rtc/rtc-uclass.c index 89312c5..29d86ba 100644 --- a/drivers/rtc/rtc-uclass.c +++ b/drivers/rtc/rtc-uclass.c @@ -14,7 +14,7 @@ int dm_rtc_get(struct udevice *dev, struct rtc_time *time) { struct rtc_ops *ops = rtc_get_ops(dev);
- assert(ops); + BUG_ON(!ops); if (!ops->get) return -ENOSYS; return ops->get(dev, time); @@ -24,7 +24,7 @@ int dm_rtc_set(struct udevice *dev, struct rtc_time *time) { struct rtc_ops *ops = rtc_get_ops(dev);
- assert(ops); + BUG_ON(!ops); if (!ops->set) return -ENOSYS; return ops->set(dev, time); @@ -34,7 +34,7 @@ int dm_rtc_reset(struct udevice *dev) { struct rtc_ops *ops = rtc_get_ops(dev);
- assert(ops); + BUG_ON(!ops); if (!ops->reset) return -ENOSYS; return ops->reset(dev); @@ -44,7 +44,7 @@ int rtc_read8(struct udevice *dev, unsigned int reg) { struct rtc_ops *ops = rtc_get_ops(dev);
- assert(ops); + BUG_ON(!ops); if (!ops->read8) return -ENOSYS; return ops->read8(dev, reg); @@ -54,7 +54,7 @@ int rtc_write8(struct udevice *dev, unsigned int reg, int val) { struct rtc_ops *ops = rtc_get_ops(dev);
- assert(ops); + BUG_ON(!ops); if (!ops->write8) return -ENOSYS; return ops->write8(dev, reg, val); diff --git a/drivers/sound/sound.c b/drivers/sound/sound.c index 9dda2db..3ad31c9 100644 --- a/drivers/sound/sound.c +++ b/drivers/sound/sound.c @@ -15,7 +15,7 @@ void sound_create_square_wave(unsigned short *data, int size, uint32_t freq) const int period = freq ? sample / freq : 0; const int half = period / 2;
- assert(freq); + BUG_ON(!freq);
/* Make sure we don't overflow our buffer */ if (size % 2) diff --git a/drivers/spi/exynos_spi.c b/drivers/spi/exynos_spi.c index 89490f7..7b1f9f1 100644 --- a/drivers/spi/exynos_spi.c +++ b/drivers/spi/exynos_spi.c @@ -86,7 +86,7 @@ static void spi_request_bytes(struct exynos_spi *regs, int count, int step) writel(0, ®s->swap_cfg); }
- assert(count && count < (1 << 16)); + BUG_ON(!(count && count < (1 << 16))); setbits_le32(®s->ch_cfg, SPI_CH_RST); clrbits_le32(®s->ch_cfg, SPI_CH_RST);
@@ -183,7 +183,7 @@ static int spi_rx_tx(struct exynos_spi_priv *priv, int todo, * and make sure that we transmit dummy bytes too, to * keep things going. */ - assert(!out_bytes); + BUG_ON(out_bytes); out_bytes = in_bytes; toread = in_bytes; txp = NULL; @@ -355,7 +355,7 @@ static int exynos_spi_xfer(struct udevice *dev, unsigned int bitlen, if ((flags & SPI_XFER_END) && !(priv->mode & SPI_SLAVE)) { spi_cs_deactivate(dev); if (priv->skip_preamble) { - assert(!priv->skip_preamble); + BUG_ON(priv->skip_preamble); debug("Failed to complete premable transaction\n"); ret = -1; } diff --git a/drivers/usb/emul/sandbox_flash.c b/drivers/usb/emul/sandbox_flash.c index 2f84b36..3282bca 100644 --- a/drivers/usb/emul/sandbox_flash.c +++ b/drivers/usb/emul/sandbox_flash.c @@ -222,7 +222,7 @@ static void setup_response(struct sandbox_flash_priv *priv, void *resp, csw->dCSWDataResidue = 0; csw->bCSWStatus = CSWSTATUS_GOOD;
- assert(!resp || resp == priv->buff); + BUG_ON(!(!resp || resp == priv->buff)); priv->buff_used = size; }
diff --git a/drivers/usb/host/usb-uclass.c b/drivers/usb/host/usb-uclass.c index 4e40f4b..49ac144 100644 --- a/drivers/usb/host/usb-uclass.c +++ b/drivers/usb/host/usb-uclass.c @@ -211,7 +211,7 @@ static void usb_scan_bus(struct udevice *bus, bool recurse)
priv = dev_get_uclass_priv(bus);
- assert(recurse); /* TODO: Support non-recusive */ + BUG_ON(!recurse); /* TODO: Support non-recusive */
printf("scanning bus %d for devices... ", bus->seq); debug("\n"); @@ -744,7 +744,7 @@ struct udevice *usb_get_bus(struct udevice *dev) bus = bus->parent; if (!bus) { /* By design this cannot happen */ - assert(bus); + BUG_ON(!bus); debug("USB HUB '%s' does not have a controller\n", dev->name); }
diff --git a/drivers/video/stb_truetype.h b/drivers/video/stb_truetype.h index 26e483c..f2a24b4 100644 --- a/drivers/video/stb_truetype.h +++ b/drivers/video/stb_truetype.h @@ -417,7 +417,7 @@ int main(int arg, char **argv)
#ifndef STBTT_assert #include <assert.h> - #define STBTT_assert(x) assert(x) + #define STBTT_assert(x) BUG_ON(!x) #endif
#ifndef STBTT_strlen diff --git a/fs/ext4/dev.c b/fs/ext4/dev.c index f04fa08..77ddce1 100644 --- a/fs/ext4/dev.c +++ b/fs/ext4/dev.c @@ -38,7 +38,7 @@ static disk_partition_t *part_info;
void ext4fs_set_blk_dev(struct blk_desc *rbdd, disk_partition_t *info) { - assert(rbdd->blksz == (1 << rbdd->log2blksz)); + BUG_ON(rbdd->blksz != (1 << rbdd->log2blksz)); ext4fs_blk_desc = rbdd; get_fs()->dev_desc = rbdd; part_info = info; diff --git a/fs/ext4/ext4_common.c b/fs/ext4/ext4_common.c index dac9545..4b2ca72 100644 --- a/fs/ext4/ext4_common.c +++ b/fs/ext4/ext4_common.c @@ -431,7 +431,7 @@ uint16_t ext4fs_checksum_update(uint32_t i) crc = ext2fs_crc16(crc, &le32_i, sizeof(le32_i)); crc = ext2fs_crc16(crc, desc, offset); offset += sizeof(desc->bg_checksum); /* skip checksum */ - assert(offset == sizeof(*desc)); + BUG_ON(offset != sizeof(*desc)); if (offset < fs->gdsize) { crc = ext2fs_crc16(crc, (__u8 *)desc + offset, fs->gdsize - offset); diff --git a/fs/ext4/ext4_journal.c b/fs/ext4/ext4_journal.c index fed6287..40d4547 100644 --- a/fs/ext4/ext4_journal.c +++ b/fs/ext4/ext4_journal.c @@ -191,7 +191,7 @@ int ext4fs_put_metadata(char *metadata_buffer, uint32_t blknr) return -EINVAL; } if (dirty_block_ptr[gd_index]->buf) - assert(dirty_block_ptr[gd_index]->blknr == blknr); + BUG_ON(dirty_block_ptr[gd_index]->blknr != blknr); else dirty_block_ptr[gd_index]->buf = zalloc(fs->blksz);
diff --git a/fs/fat/fat.c b/fs/fat/fat.c index d16883f..dca22a5 100644 --- a/fs/fat/fat.c +++ b/fs/fat/fat.c @@ -705,7 +705,7 @@ static void fat_itr_child(fat_itr *itr, fat_itr *parent) fsdata *mydata = parent->fsdata; /* for silly macros */ unsigned clustnum = START(parent->dent);
- assert(fat_itr_isdir(parent)); + BUG_ON(!fat_itr_isdir(parent));
itr->fsdata = parent->fsdata; if (clustnum > 0) { diff --git a/include/dm/ofnode.h b/include/dm/ofnode.h index 8b9932a..d81c2dc 100644 --- a/include/dm/ofnode.h +++ b/include/dm/ofnode.h @@ -157,9 +157,7 @@ static inline bool ofnode_is_np(ofnode node) * Check our assumption that flat tree offsets are not used when a * live tree is in use. */ - assert(!ofnode_valid(node) || - (of_live_active() ? _ofnode_to_np(node) - : _ofnode_to_np(node))); + BUG_ON(!(!ofnode_valid(node) || (of_live_active() ? _ofnode_to_np(node) : _ofnode_to_np(node)))); #endif return of_live_active() && ofnode_valid(node); } diff --git a/include/efi_loader.h b/include/efi_loader.h index 1b92edb..8b52385 100644 --- a/include/efi_loader.h +++ b/include/efi_loader.h @@ -25,7 +25,7 @@ const char *__efi_nesting_dec(void); * Enter the u-boot world from UEFI: */ #define EFI_ENTRY(format, ...) do { \ - assert(__efi_entry_check()); \ + BUG_ON(!__efi_entry_check()); \ debug("%sEFI: Entry %s(" format ")\n", __efi_nesting_inc(), \ __func__, ##__VA_ARGS__); \ } while(0) @@ -37,7 +37,7 @@ const char *__efi_nesting_dec(void); typeof(ret) _r = ret; \ debug("%sEFI: Exit: %s: %u\n", __efi_nesting_dec(), \ __func__, (u32)((uintptr_t) _r & ~EFI_ERROR_MASK)); \ - assert(__efi_exit_check()); \ + BUG_ON(!__efi_exit_check()); \ _r; \ })
@@ -46,9 +46,9 @@ const char *__efi_nesting_dec(void); */ #define EFI_CALL(exp) ({ \ debug("%sEFI: Call: %s\n", __efi_nesting_inc(), #exp); \ - assert(__efi_exit_check()); \ + BUG_ON(!__efi_exit_check()); \ typeof(exp) _r = exp; \ - assert(__efi_entry_check()); \ + BUG_ON(!__efi_entry_check()); \ debug("%sEFI: %lu returned by %s\n", __efi_nesting_dec(), \ (unsigned long)((uintptr_t)_r & ~EFI_ERROR_MASK), #exp); \ _r; \ @@ -59,9 +59,9 @@ const char *__efi_nesting_dec(void); */ #define EFI_CALL_VOID(exp) do { \ debug("%sEFI: Call: %s\n", __efi_nesting_inc(), #exp); \ - assert(__efi_exit_check()); \ + BUG_ON(!__efi_exit_check()); \ exp; \ - assert(__efi_entry_check()); \ + BUG_ON(!__efi_entry_check()); \ debug("%sEFI: Return From: %s\n", __efi_nesting_dec(), #exp); \ } while(0)
diff --git a/lib/circbuf.c b/lib/circbuf.c index 6ed0516..e18601e 100644 --- a/lib/circbuf.c +++ b/lib/circbuf.c @@ -13,12 +13,12 @@
int buf_init (circbuf_t * buf, unsigned int size) { - assert (buf != NULL); + BUG_ON(!buf);
buf->size = 0; buf->totalsize = size; buf->data = (char *) malloc (sizeof (char) * size); - assert (buf->data != NULL); + BUG_ON(!buf->data);
buf->top = buf->data; buf->tail = buf->data; @@ -29,8 +29,8 @@ int buf_init (circbuf_t * buf, unsigned int size)
int buf_free (circbuf_t * buf) { - assert (buf != NULL); - assert (buf->data != NULL); + BUG_ON(!buf); + BUG_ON(!buf->data);
free (buf->data); memset (buf, 0, sizeof (circbuf_t)); @@ -43,8 +43,8 @@ int buf_pop (circbuf_t * buf, char *dest, unsigned int len) unsigned int i; char *p;
- assert (buf != NULL); - assert (dest != NULL); + BUG_ON(!buf); + BUG_ON(!dest);
p = buf->top;
@@ -73,8 +73,8 @@ int buf_push (circbuf_t * buf, const char *src, unsigned int len) unsigned int i; char *p;
- assert (buf != NULL); - assert (src != NULL); + BUG_ON(!buf); + BUG_ON(!src);
p = buf->tail;
diff --git a/lib/efi_loader/efi_boottime.c b/lib/efi_loader/efi_boottime.c index 743b848..b1b25f2 100644 --- a/lib/efi_loader/efi_boottime.c +++ b/lib/efi_loader/efi_boottime.c @@ -62,7 +62,7 @@ int __efi_entry_check(void) { int ret = entry_count++ == 0; #ifdef CONFIG_ARM - assert(efi_gd); + BUG_ON(!efi_gd); app_gd = gd; gd = efi_gd; #endif diff --git a/lib/efi_loader/efi_device_path.c b/lib/efi_loader/efi_device_path.c index f6e368e..fcd2d5f 100644 --- a/lib/efi_loader/efi_device_path.c +++ b/lib/efi_loader/efi_device_path.c @@ -507,7 +507,7 @@ struct efi_device_path *efi_dp_from_eth(void) void *buf, *start; unsigned dpsize = 0;
- assert(eth_get_dev()); + BUG_ON(!eth_get_dev());
#ifdef CONFIG_DM_ETH dpsize += dp_size(eth_get_dev()); diff --git a/lib/efi_loader/efi_file.c b/lib/efi_loader/efi_file.c index 52a4e74..b3b49bb 100644 --- a/lib/efi_loader/efi_file.c +++ b/lib/efi_loader/efi_file.c @@ -249,7 +249,7 @@ static efi_status_t dir_read(struct file_handle *fh, u64 *buffer_size, unsigned int required_size;
if (!fh->dirs) { - assert(fh->offset == 0); + BUG_ON(fh->offset); fh->dirs = fs_opendir(fh->path); if (!fh->dirs) return EFI_DEVICE_ERROR; diff --git a/lib/efi_loader/efi_memory.c b/lib/efi_loader/efi_memory.c index d47759e..94d8435 100644 --- a/lib/efi_loader/efi_memory.c +++ b/lib/efi_loader/efi_memory.c @@ -385,7 +385,7 @@ efi_status_t efi_free_pool(void *buffer)
alloc = container_of(buffer, struct efi_pool_allocation, data); /* Sanity check, was the supplied address returned by allocate_pool */ - assert(((uintptr_t)alloc & EFI_PAGE_MASK) == 0); + BUG_ON(((uintptr_t)alloc & EFI_PAGE_MASK));
r = efi_free_pages((uintptr_t)alloc, alloc->num_pages);
diff --git a/lib/fdtdec.c b/lib/fdtdec.c index 30ec6b9..95c6f1f 100644 --- a/lib/fdtdec.c +++ b/lib/fdtdec.c @@ -78,7 +78,7 @@ static const char * const compat_names[COMPAT_COUNT] = { const char *fdtdec_get_compatible(enum fdt_compat_id id) { /* We allow reading of the 'unknown' ID for testing purposes */ - assert(id >= 0 && id < COMPAT_COUNT); + BUG_ON(!(id >= 0 && id < COMPAT_COUNT)); return compat_names[id]; }
@@ -378,7 +378,7 @@ int fdtdec_next_alias(const void *blob, const char *name, int node, err;
/* snprintf() is not available */ - assert(strlen(name) < MAX_STR_LEN); + BUG_ON(strlen(name) >= MAX_STR_LEN); sprintf(str, "%.*s%d", MAX_STR_LEN, name, *upto); node = fdt_path_offset(blob, str); if (node < 0) @@ -505,7 +505,7 @@ int fdtdec_add_aliases_for_id(const void *blob, const char *name, if (j == maxcount) break;
- assert(!node_list[i]); + BUG_ON(node_list[i]); node_list[i] = nodes[j++]; if (i >= num_found) num_found = i + 1; @@ -585,7 +585,7 @@ int fdtdec_check_fdt(void) * FDT (prior to console ready) will need to make their own * arrangements and do their own checks. */ - assert(!fdtdec_prepare_fdt()); + BUG_ON(fdtdec_prepare_fdt()); return 0; }
diff --git a/lib/membuff.c b/lib/membuff.c index fc37757..4c41624 100644 --- a/lib/membuff.c +++ b/lib/membuff.c @@ -25,7 +25,7 @@ static int membuff_putrawflex(struct membuff *mb, int maxlen, bool update, int len;
/* always write to 'mb->head' */ - assert(data && offsetp); + BUG_ON(!(data && offsetp)); *data = &mb->start; *offsetp = mb->head - mb->start;
@@ -330,7 +330,7 @@ int membuff_extend_by(struct membuff *mb, int by, int max) char *ptr;
/* double the buffer size until it is big enough */ - assert(by >= 0); + BUG_ON(0 > by); for (orig = mb->end - mb->start, size = orig; size < orig + by;) size *= 2; if (max != -1) diff --git a/lib/physmem.c b/lib/physmem.c index f21ac24..463bd09 100644 --- a/lib/physmem.c +++ b/lib/physmem.c @@ -16,7 +16,7 @@ phys_addr_t __weak arch_phys_memset(phys_addr_t s, int c, phys_size_t n) { void *s_ptr = (void *)(uintptr_t)s;
- assert(((phys_addr_t)(uintptr_t)s) == s); - assert(((phys_addr_t)(uintptr_t)(s + n)) == s + n); + BUG_ON(((phys_addr_t)(uintptr_t)s) != s); + BUG_ON(((phys_addr_t)(uintptr_t)(s + n)) != s + n); return (phys_addr_t)(uintptr_t)memset(s_ptr, c, n); } diff --git a/lib/qsort.c b/lib/qsort.c index 5709884..f1d2427 100644 --- a/lib/qsort.c +++ b/lib/qsort.c @@ -28,7 +28,7 @@ void qsort(void *base, char tmp;
if ((nel > 1) && (width > 0)) { - assert(nel <= ((size_t)(-1)) / width); /* check for overflow */ + BUG_ON(nel > ((size_t)(-1)) / width); /* check for overflow */ wgap = 0; do { wgap = 3 * wgap + 1; diff --git a/lib/slre.c b/lib/slre.c index e26d344..5fa92cf 100644 --- a/lib/slre.c +++ b/lib/slre.c @@ -165,7 +165,7 @@ slre_dump(const struct slre *r, FILE *fp) static void set_jump_offset(struct slre *r, int pc, int offset) { - assert(offset < r->code_size); + BUG_ON(offset >= r->code_size);
if (r->code_size - offset > 0xff) r->err_str = "Jump offset is too big"; @@ -507,8 +507,8 @@ match(const struct slre *r, int pc, const char *s, int len,
while (res && r->code[pc] != END) {
- assert(pc < r->code_size); - assert(pc < (int) (sizeof(r->code) / sizeof(r->code[0]))); + BUG_ON(pc >= r->code_size); + BUG_ON(pc >= (int)(sizeof(r->code) / sizeof(r->code[0])));
switch (r->code[pc]) { case BRANCH: @@ -635,7 +635,7 @@ match(const struct slre *r, int pc, const char *s, int len, break; default: printf("unknown cmd (%d) at %d\n", r->code[pc], pc); - assert(0); + BUG(); break; } } diff --git a/net/eth-uclass.c b/net/eth-uclass.c index d30b04b..9c78b8f 100644 --- a/net/eth-uclass.c +++ b/net/eth-uclass.c @@ -42,7 +42,7 @@ static struct eth_uclass_priv *eth_get_uclass_priv(void) struct uclass *uc;
uclass_get(UCLASS_ETH, &uc); - assert(uc); + BUG_ON(!uc); return uc->priv; }
diff --git a/net/eth_legacy.c b/net/eth_legacy.c index be0cf64..0d7c406 100644 --- a/net/eth_legacy.c +++ b/net/eth_legacy.c @@ -187,7 +187,7 @@ int eth_register(struct eth_device *dev) struct eth_device *d; static int index;
- assert(strlen(dev->name) < sizeof(dev->name)); + BUG_ON(strlen(dev->name) >= sizeof(dev->name));
if (!eth_devices) { eth_devices = dev; diff --git a/net/net.c b/net/net.c index 4259c9e..bc69c1d 100644 --- a/net/net.c +++ b/net/net.c @@ -784,7 +784,7 @@ int net_send_udp_packet(uchar *ether, struct in_addr dest, int dport, int sport, int pkt_hdr_size;
/* make sure the net_tx_packet is initialized (net_init() was called) */ - assert(net_tx_packet != NULL); + BUG_ON(!net_tx_packet); if (net_tx_packet == NULL) return -1;
diff --git a/test/command_ut.c b/test/command_ut.c index f76d525..a5360c1 100644 --- a/test/command_ut.c +++ b/test/command_ut.c @@ -19,16 +19,16 @@ static int do_ut_cmd(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[])
/* commands separated by \n */ run_command_list("setenv list 1\n setenv list ${list}1", -1, 0); - assert(!strcmp("11", env_get("list"))); + BUG_ON(strcmp("11", env_get("list")));
/* command followed by \n and nothing else */ run_command_list("setenv list 1${list}\n", -1, 0); - assert(!strcmp("111", env_get("list"))); + BUG_ON(strcmp("111", env_get("list")));
/* a command string with \0 in it. Stuff after \0 should be ignored */ run_command("setenv list", 0); run_command_list(test_cmd, sizeof(test_cmd), 0); - assert(!strcmp("123", env_get("list"))); + BUG_ON(strcmp("123", env_get("list")));
/* * a command list where we limit execution to only the first command @@ -36,26 +36,26 @@ static int do_ut_cmd(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) */ run_command_list("setenv list 1\n setenv list ${list}2; " "setenv list ${list}3", strlen("setenv list 1"), 0); - assert(!strcmp("1", env_get("list"))); + BUG_ON(strcmp("1", env_get("list")));
- assert(run_command("false", 0) == 1); - assert(run_command("echo", 0) == 0); - assert(run_command_list("false", -1, 0) == 1); - assert(run_command_list("echo", -1, 0) == 0); + BUG_ON(run_command("false", 0) != 1); + BUG_ON(run_command("echo", 0)); + BUG_ON(run_command_list("false", -1, 0) != 1); + BUG_ON(run_command_list("echo", -1, 0));
#ifdef CONFIG_HUSH_PARSER run_command("setenv foo 'setenv black 1\nsetenv adder 2'", 0); run_command("run foo", 0); - assert(env_get("black") != NULL); - assert(!strcmp("1", env_get("black"))); - assert(env_get("adder") != NULL); - assert(!strcmp("2", env_get("adder"))); + BUG_ON(!env_get("black")); + BUG_ON(strcmp("1", env_get("black"))); + BUG_ON(!env_get("adder")); + BUG_ON(strcmp("2", env_get("adder"))); #endif
- assert(run_command("", 0) == 0); - assert(run_command(" ", 0) == 0); + BUG_ON(run_command("", 0)); + BUG_ON(run_command(" ", 0));
- assert(run_command("'", 0) == 1); + BUG_ON(run_command("'", 0) != 1);
printf("%s: Everything went swimmingly\n", __func__); return 0; diff --git a/test/compression.c b/test/compression.c index be4e04e..bba1806 100644 --- a/test/compression.c +++ b/test/compression.c @@ -156,8 +156,8 @@ static int compress_using_bzip2(void *in, unsigned long in_size, unsigned long *out_size) { /* There is no bzip2 compression in u-boot, so fake it. */ - assert(in_size == strlen(plain)); - assert(memcmp(plain, in, in_size) == 0); + BUG_ON(in_size != strlen(plain)); + BUG_ON(memcmp(plain, in, in_size));
if (bzip2_compressed_size > out_max) return -1; @@ -189,8 +189,8 @@ static int compress_using_lzma(void *in, unsigned long in_size, unsigned long *out_size) { /* There is no lzma compression in u-boot, so fake it. */ - assert(in_size == strlen(plain)); - assert(memcmp(plain, in, in_size) == 0); + BUG_ON(in_size != strlen(plain)); + BUG_ON(memcmp(plain, in, in_size));
if (lzma_compressed_size > out_max) return -1; @@ -221,8 +221,8 @@ static int compress_using_lzo(void *in, unsigned long in_size, unsigned long *out_size) { /* There is no lzo compression in u-boot, so fake it. */ - assert(in_size == strlen(plain)); - assert(memcmp(plain, in, in_size) == 0); + BUG_ON(in_size != strlen(plain)); + BUG_ON(memcmp(plain, in, in_size));
if (lzo_compressed_size > out_max) return -1; @@ -254,8 +254,8 @@ static int compress_using_lz4(void *in, unsigned long in_size, unsigned long *out_size) { /* There is no lz4 compression in u-boot, so fake it. */ - assert(in_size == strlen(plain)); - assert(memcmp(plain, in, in_size) == 0); + BUG_ON(in_size != strlen(plain)); + BUG_ON(memcmp(plain, in, in_size));
if (lz4_compressed_size > out_max) return -1; diff --git a/test/print_ut.c b/test/print_ut.c index a42c554..5fefefe 100644 --- a/test/print_ut.c +++ b/test/print_ut.c @@ -24,56 +24,56 @@ static int do_ut_print(cmd_tbl_t *cmdtp, int flag, int argc, printf("%s: Testing print\n", __func__);
snprintf(str, sizeof(str), "testing"); - assert(!strcmp("testing", str)); + BUG_ON(strcmp("testing", str));
snprintf(str, sizeof(str), "testing but too long"); - assert(!strcmp("testing b", str)); + BUG_ON(strcmp("testing b", str));
snprintf(str, 1, "testing none"); - assert(!strcmp("", str)); + BUG_ON(strcmp("", str));
*str = 'x'; snprintf(str, 0, "testing none"); - assert(*str == 'x'); + BUG_ON(*str != 'x');
sprintf(big_str, "_%ls_", L"foo"); - assert(!strcmp("_foo_", big_str)); + BUG_ON(strcmp("_foo_", big_str));
/* Test the banner function */ s = display_options_get_banner(true, str, sizeof(str)); - assert(s == str); - assert(!strcmp("\n\nU-Boo\n\n", s)); + BUG_ON(s != str); + BUG_ON(strcmp("\n\nU-Boo\n\n", s));
s = display_options_get_banner(true, str, 1); - assert(s == str); - assert(!strcmp("", s)); + BUG_ON(s != str); + BUG_ON(strcmp("", s));
s = display_options_get_banner(true, str, 2); - assert(s == str); - assert(!strcmp("\n", s)); + BUG_ON(s != str); + BUG_ON(strcmp("\n", s));
s = display_options_get_banner(false, str, sizeof(str)); - assert(s == str); - assert(!strcmp("U-Boot \n\n", s)); + BUG_ON(s != str); + BUG_ON(strcmp("U-Boot \n\n", s));
/* Give it enough space for some of the version */ big_str_len = strlen(version_string) - 5; s = display_options_get_banner_priv(false, FAKE_BUILD_TAG, big_str, big_str_len); - assert(s == big_str); - assert(!strncmp(version_string, s, big_str_len - 3)); - assert(!strcmp("\n\n", s + big_str_len - 3)); + BUG_ON(s != big_str); + BUG_ON(strncmp(version_string, s, big_str_len - 3)); + BUG_ON(strcmp("\n\n", s + big_str_len - 3));
/* Give it enough space for the version and some of the build tag */ big_str_len = strlen(version_string) + 9 + 20; s = display_options_get_banner_priv(false, FAKE_BUILD_TAG, big_str, big_str_len); - assert(s == big_str); + BUG_ON(s != big_str); len = strlen(version_string); - assert(!strncmp(version_string, s, len)); - assert(!strncmp(", Build: ", s + len, 9)); - assert(!strncmp(FAKE_BUILD_TAG, s + 9 + len, 12)); - assert(!strcmp("\n\n", s + big_str_len - 3)); + BUG_ON(strncmp(version_string, s, len)); + BUG_ON(strncmp(", Build: ", s + len, 9)); + BUG_ON(strncmp(FAKE_BUILD_TAG, s + 9 + len, 12)); + BUG_ON(strcmp("\n\n", s + big_str_len - 3));
No more users of assert() except host tools. Remove.
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
Changes in v2: None
include/common.h | 15 --------------- lib/tiny-printf.c | 9 --------- lib/vsprintf.c | 9 --------- 3 files changed, 33 deletions(-)
diff --git a/include/common.h b/include/common.h index 6e24545..f035f76 100644 --- a/include/common.h +++ b/include/common.h @@ -76,21 +76,6 @@ typedef volatile unsigned char vu_char; #define warn_non_spl(fmt, args...) \ debug_cond(!_SPL_BUILD, fmt, ##args)
-/* - * An assertion is run-time check done in debug mode only. If DEBUG is not - * defined then it is skipped. If DEBUG is defined and the assertion fails, - * then it calls panic*( which may or may not reset/halt U-Boot (see - * CONFIG_PANIC_HANG), It is hoped that all failing assertions are found - * before release, and after release it is hoped that they don't matter. But - * in any case these failing assertions cannot be fixed with a reset (which - * may just do the same assertion again). - */ -void __assert_fail(const char *assertion, const char *file, unsigned line, - const char *function); -#define assert(x) \ - ({ if (!(x) && _DEBUG) \ - __assert_fail(#x, __FILE__, __LINE__, __func__); }) - typedef void (interrupt_handler_t)(void *);
#include <asm/u-boot.h> /* boot information for Linux kernel */ diff --git a/lib/tiny-printf.c b/lib/tiny-printf.c index 0b04813..d5b6d69 100644 --- a/lib/tiny-printf.c +++ b/lib/tiny-printf.c @@ -381,12 +381,3 @@ int snprintf(char *buf, size_t size, const char *fmt, ...)
return ret; } - -void __assert_fail(const char *assertion, const char *file, unsigned line, - const char *function) -{ - /* This will not return */ - printf("%s:%u: %s: Assertion `%s' failed.", file, line, function, - assertion); - hang(); -} diff --git a/lib/vsprintf.c b/lib/vsprintf.c index dd572d2..4208239 100644 --- a/lib/vsprintf.c +++ b/lib/vsprintf.c @@ -789,15 +789,6 @@ int vprintf(const char *fmt, va_list args) return i; }
- -void __assert_fail(const char *assertion, const char *file, unsigned line, - const char *function) -{ - /* This will not return */ - panic("%s:%u: %s: Assertion `%s' failed.", file, line, function, - assertion); -} - char *simple_itoa(ulong i) { /* 21 digits plus null terminator, good for 64-bit or smaller ints */
On 3 December 2017 at 20:37, Masahiro Yamada yamada.masahiro@socionext.com wrote:
Changes in v2: None
participants (5)
Lothar Waßmann
Masahiro Yamada
York Sun
