[RFC PATCH 0/1] cmd: nvedit: Forbid environment key to be empty.
Hi.
First of all, I hope you are fine and the same for your relatives.
In this patch, I modified the setenv command to decline empty variable name. Indeed, it was strangely possible to give the following to this command: setenv '' foo Which results in the following belonging to environment: =foo And which in turns leads to problem while rebooting: Loading Environment from Flash... Cannot import environment: errno = 22 *** Warning - import failed, using default environment This error message is due to varname being empty and was added in [1].
With this patch, executing the above command will lead to the following being printed: ## Error: variable name cannot be empty And the environment will not be changed.
Here is the diffstat for this patch: Francis Laniel (1): cmd: nvedit: Forbid key to be empty.
cmd/nvedit.c | 5 +++++ 1 file changed, 5 insertions(+)
If you see any way to improve the patch, feel free to share it.
Best regards.
--- [1] https://u-boot.denx.narkive.com/P4aKxVFu/patch-env-don-t-add-an-empty-key-to...
-- 2.25.1
Before this patch, it was possible to do the following using setenv: setenv '' foo Then, on next reboot, U-Boot will not be able to parse environment due to it having: =foo
Now, if the above command is given, an error message is thrown and environment is not modified.
Signed-off-by: Francis Laniel francis.laniel@amarulasolutions.com --- cmd/nvedit.c | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/cmd/nvedit.c b/cmd/nvedit.c index d14ba10cef..64b7aef78d 100644 --- a/cmd/nvedit.c +++ b/cmd/nvedit.c @@ -262,6 +262,11 @@ static int _do_env_set(int flag, int argc, char *const argv[], int env_flag) return 1; }
+ if (!strlen(name)) { + printf("## Error: variable name cannot be empty\n"); + return 1; + } + env_id++;
/* Delete only ? */
Francis Laniel
