[U-Boot] [PATCH u-boot 0/2] ARM64: meson: Sync DT and Bindings with Linux 4.16
Synchronize the Amlogic Meson GX Device Tree and bindings with Linux 4.16 to beneficiate with the new DT nodes.
The pinctrl bindings has changed since 4.13, so the pinctrl driver must be updated with the changes.
Neil Armstrong (2): ARM64: meson: Sync DT and Bindings with Linux 4.16 pinctrl: meson: Update pinmux with new Linux bindings
arch/arm/dts/meson-gx.dtsi | 87 ++++++++++----- arch/arm/dts/meson-gxbb-odroidc2.dts | 56 ++++++++-- arch/arm/dts/meson-gxbb.dtsi | 137 ++++++++++++++++++++++-- arch/arm/dts/meson-gxl-s905x-khadas-vim.dts | 63 +++++++++++ arch/arm/dts/meson-gxl-s905x-libretech-cc.dts | 108 ++++++++++++++++++- arch/arm/dts/meson-gxl-s905x-p212.dts | 7 ++ arch/arm/dts/meson-gxl-s905x-p212.dtsi | 24 ++++- arch/arm/dts/meson-gxl.dtsi | 147 ++++++++++++++++++++++++-- drivers/pinctrl/meson/pinctrl-meson-gxbb.c | 12 +-- drivers/pinctrl/meson/pinctrl-meson-gxl.c | 14 +-- include/dt-bindings/clock/gxbb-aoclkc.h | 1 + include/dt-bindings/clock/gxbb-clkc.h | 75 +++++++++++++ include/dt-bindings/gpio/meson-gxbb-gpio.h | 2 +- include/dt-bindings/gpio/meson-gxl-gpio.h | 2 +- 14 files changed, 658 insertions(+), 77 deletions(-)
Synchronize the Linux Device Tree for Amlogic Meson GX boards from Linux 4.16.0.
Signed-off-by: Neil Armstrong narmstrong@baylibre.com --- arch/arm/dts/meson-gx.dtsi | 87 ++++++++++----- arch/arm/dts/meson-gxbb-odroidc2.dts | 56 ++++++++-- arch/arm/dts/meson-gxbb.dtsi | 137 ++++++++++++++++++++++-- arch/arm/dts/meson-gxl-s905x-khadas-vim.dts | 63 +++++++++++ arch/arm/dts/meson-gxl-s905x-libretech-cc.dts | 108 ++++++++++++++++++- arch/arm/dts/meson-gxl-s905x-p212.dts | 7 ++ arch/arm/dts/meson-gxl-s905x-p212.dtsi | 24 ++++- arch/arm/dts/meson-gxl.dtsi | 147 ++++++++++++++++++++++++-- include/dt-bindings/clock/gxbb-aoclkc.h | 1 + include/dt-bindings/clock/gxbb-clkc.h | 75 +++++++++++++ include/dt-bindings/gpio/meson-gxbb-gpio.h | 2 +- include/dt-bindings/gpio/meson-gxl-gpio.h | 2 +- 12 files changed, 645 insertions(+), 64 deletions(-)
diff --git a/arch/arm/dts/meson-gx.dtsi b/arch/arm/dts/meson-gx.dtsi index 738ed68..4ee2e79 100644 --- a/arch/arm/dts/meson-gx.dtsi +++ b/arch/arm/dts/meson-gx.dtsi @@ -211,32 +211,39 @@ #size-cells = <2>; ranges;
- cbus: cbus@c1100000 { + cbus: bus@c1100000 { compatible = "simple-bus"; reg = <0x0 0xc1100000 0x0 0x100000>; #address-cells = <2>; #size-cells = <2>; ranges = <0x0 0x0 0x0 0xc1100000 0x0 0x100000>;
+ gpio_intc: interrupt-controller@9880 { + compatible = "amlogic,meson-gpio-intc"; + reg = <0x0 0x9880 0x0 0x10>; + interrupt-controller; + #interrupt-cells = <2>; + amlogic,channel-interrupts = <64 65 66 67 68 69 70 71>; + status = "disabled"; + }; + reset: reset-controller@4404 { compatible = "amlogic,meson-gx-reset", "amlogic,meson-gxbb-reset"; - reg = <0x0 0x04404 0x0 0x20>; + reg = <0x0 0x04404 0x0 0x9c>; #reset-cells = <1>; };
uart_A: serial@84c0 { - compatible = "amlogic,meson-uart"; - reg = <0x0 0x84c0 0x0 0x14>; + compatible = "amlogic,meson-gx-uart"; + reg = <0x0 0x84c0 0x0 0x18>; interrupts = <GIC_SPI 26 IRQ_TYPE_EDGE_RISING>; - clocks = <&xtal>; status = "disabled"; };
uart_B: serial@84dc { - compatible = "amlogic,meson-uart"; - reg = <0x0 0x84dc 0x0 0x14>; + compatible = "amlogic,meson-gx-uart"; + reg = <0x0 0x84dc 0x0 0x18>; interrupts = <GIC_SPI 75 IRQ_TYPE_EDGE_RISING>; - clocks = <&xtal>; status = "disabled"; };
@@ -279,10 +286,9 @@ };
uart_C: serial@8700 { - compatible = "amlogic,meson-uart"; - reg = <0x0 0x8700 0x0 0x14>; + compatible = "amlogic,meson-gx-uart"; + reg = <0x0 0x8700 0x0 0x18>; interrupts = <GIC_SPI 93 IRQ_TYPE_EDGE_RISING>; - clocks = <&xtal>; status = "disabled"; };
@@ -360,33 +366,53 @@ }; };
- aobus: aobus@c8100000 { + aobus: bus@c8100000 { compatible = "simple-bus"; reg = <0x0 0xc8100000 0x0 0x100000>; #address-cells = <2>; #size-cells = <2>; ranges = <0x0 0x0 0x0 0xc8100000 0x0 0x100000>;
- clkc_AO: clock-controller@040 { - compatible = "amlogic,gx-aoclkc", "amlogic,gxbb-aoclkc"; - reg = <0x0 0x00040 0x0 0x4>; - #clock-cells = <1>; - #reset-cells = <1>; + sysctrl_AO: sys-ctrl@0 { + compatible = "amlogic,meson-gx-ao-sysctrl", "syscon", "simple-mfd"; + reg = <0x0 0x0 0x0 0x100>; + + pwrc_vpu: power-controller-vpu { + compatible = "amlogic,meson-gx-pwrc-vpu"; + #power-domain-cells = <0>; + amlogic,hhi-sysctrl = <&sysctrl>; + }; + + clkc_AO: clock-controller { + compatible = "amlogic,meson-gx-aoclkc"; + #clock-cells = <1>; + #reset-cells = <1>; + }; + }; + + cec_AO: cec@100 { + compatible = "amlogic,meson-gx-ao-cec"; + reg = <0x0 0x00100 0x0 0x14>; + interrupts = <GIC_SPI 199 IRQ_TYPE_EDGE_RISING>; + }; + + sec_AO: ao-secure@140 { + compatible = "amlogic,meson-gx-ao-secure", "syscon"; + reg = <0x0 0x140 0x0 0x140>; + amlogic,has-chip-id; };
uart_AO: serial@4c0 { - compatible = "amlogic,meson-uart"; - reg = <0x0 0x004c0 0x0 0x14>; + compatible = "amlogic,meson-gx-uart", "amlogic,meson-ao-uart"; + reg = <0x0 0x004c0 0x0 0x18>; interrupts = <GIC_SPI 193 IRQ_TYPE_EDGE_RISING>; - clocks = <&xtal>; status = "disabled"; };
uart_AO_B: serial@4e0 { - compatible = "amlogic,meson-uart"; - reg = <0x0 0x004e0 0x0 0x14>; + compatible = "amlogic,meson-gx-uart", "amlogic,meson-ao-uart"; + reg = <0x0 0x004e0 0x0 0x18>; interrupts = <GIC_SPI 197 IRQ_TYPE_EDGE_RISING>; - clocks = <&xtal>; status = "disabled"; };
@@ -427,19 +453,24 @@ }; };
- hiubus: hiubus@c883c000 { + hiubus: bus@c883c000 { compatible = "simple-bus"; reg = <0x0 0xc883c000 0x0 0x2000>; #address-cells = <2>; #size-cells = <2>; ranges = <0x0 0x0 0x0 0xc883c000 0x0 0x2000>;
+ sysctrl: system-controller@0 { + compatible = "amlogic,meson-gx-hhi-sysctrl", "syscon", "simple-mfd"; + reg = <0 0 0 0x400>; + }; + mailbox: mailbox@404 { compatible = "amlogic,meson-gx-mhu", "amlogic,meson-gxbb-mhu"; reg = <0 0x404 0 0x4c>; - interrupts = <0 208 IRQ_TYPE_EDGE_RISING>, - <0 209 IRQ_TYPE_EDGE_RISING>, - <0 210 IRQ_TYPE_EDGE_RISING>; + interrupts = <GIC_SPI 208 IRQ_TYPE_EDGE_RISING>, + <GIC_SPI 209 IRQ_TYPE_EDGE_RISING>, + <GIC_SPI 210 IRQ_TYPE_EDGE_RISING>; #mbox-cells = <1>; }; }; @@ -448,7 +479,7 @@ compatible = "amlogic,meson-gx-dwmac", "amlogic,meson-gxbb-dwmac", "snps,dwmac"; reg = <0x0 0xc9410000 0x0 0x10000 0x0 0xc8834540 0x0 0x4>; - interrupts = <0 8 1>; + interrupts = <GIC_SPI 8 IRQ_TYPE_EDGE_RISING>; interrupt-names = "macirq"; status = "disabled"; }; diff --git a/arch/arm/dts/meson-gxbb-odroidc2.dts b/arch/arm/dts/meson-gxbb-odroidc2.dts index d147c85..ee4ada6 100644 --- a/arch/arm/dts/meson-gxbb-odroidc2.dts +++ b/arch/arm/dts/meson-gxbb-odroidc2.dts @@ -50,7 +50,7 @@ / { compatible = "hardkernel,odroid-c2", "amlogic,meson-gxbb"; model = "Hardkernel ODROID-C2"; - + aliases { serial0 = &uart_AO; }; @@ -135,6 +135,24 @@ compatible = "mmc-pwrseq-emmc"; reset-gpios = <&gpio BOOT_9 GPIO_ACTIVE_LOW>; }; + + hdmi-connector { + compatible = "hdmi-connector"; + type = "a"; + + port { + hdmi_connector_in: endpoint { + remote-endpoint = <&hdmi_tx_tmds_out>; + }; + }; + }; +}; + +&cec_AO { + status = "okay"; + pinctrl-0 = <&ao_cec_pins>; + pinctrl-names = "default"; + hdmi-phandle = <&hdmi_tx>; };
ðmac { @@ -156,7 +174,11 @@ #size-cells = <0>;
eth_phy0: ethernet-phy@0 { + /* Realtek RTL8211F (0x001cc916) */ reg = <0>; + interrupt-parent = <&gpio_intc>; + /* MAC_INTR on GPIOZ_15 */ + interrupts = <29 IRQ_TYPE_LEVEL_LOW>; eee-broken-1000t; }; }; @@ -177,6 +199,18 @@ }; };
+&hdmi_tx { + status = "okay"; + pinctrl-0 = <&hdmi_hpd_pins>, <&hdmi_i2c_pins>; + pinctrl-names = "default"; +}; + +&hdmi_tx_tmds_port { + hdmi_tx_tmds_out: endpoint { + remote-endpoint = <&hdmi_connector_in>; + }; +}; + &i2c_A { status = "okay"; pinctrl-0 = <&i2c_a_pins>; @@ -194,7 +228,9 @@ "USB HUB nRESET", "USB OTG Power En", "J7 Header Pin2", "IR In", "J7 Header Pin4", "J7 Header Pin6", "J7 Header Pin5", "J7 Header Pin7", - "HDMI CEC", "SYS LED"; + "HDMI CEC", "SYS LED", + /* GPIO_TEST_N */ + ""; };
&pinctrl_periphs { @@ -233,11 +269,9 @@ "J2 Header Pin12", "J2 Header Pin13", "J2 Header Pin8", "J2 Header Pin10", "", "", "", "", "", - "J2 Header Pin11", "", "J2 Header Pin7", + "J2 Header Pin11", "", "J2 Header Pin7", "", /* Bank GPIOCLK */ - "", "", "", "", - /* GPIO_TEST_N */ - ""; + "", "", "", ""; };
&saradc { @@ -253,7 +287,8 @@ &sd_emmc_b { status = "okay"; pinctrl-0 = <&sdcard_pins>; - pinctrl-names = "default"; + pinctrl-1 = <&sdcard_clk_gate_pins>; + pinctrl-names = "default", "clk-gate";
bus-width = <4>; cap-sd-highspeed; @@ -270,11 +305,11 @@ /* eMMC */ &sd_emmc_c { status = "okay"; - pinctrl-0 = <&emmc_pins>; - pinctrl-names = "default"; + pinctrl-0 = <&emmc_pins>, <&emmc_ds_pins>; + pinctrl-1 = <&emmc_clk_gate_pins>; + pinctrl-names = "default", "clk-gate";
bus-width = <8>; - cap-sd-highspeed; max-frequency = <200000000>; non-removable; disable-wp; @@ -300,6 +335,7 @@
&usb1_phy { status = "okay"; + phy-supply = <&usb_otg_pwr>; };
&usb0 { diff --git a/arch/arm/dts/meson-gxbb.dtsi b/arch/arm/dts/meson-gxbb.dtsi index 17d3efd..3290a4d 100644 --- a/arch/arm/dts/meson-gxbb.dtsi +++ b/arch/arm/dts/meson-gxbb.dtsi @@ -307,6 +307,15 @@ }; };
+&cec_AO { + clocks = <&clkc_AO CLKID_AO_CEC_32K>; + clock-names = "core"; +}; + +&clkc_AO { + compatible = "amlogic,meson-gxbb-aoclkc", "amlogic,meson-gx-aoclkc"; +}; + ðmac { clocks = <&clkc CLKID_ETH>, <&clkc CLKID_FCLK_DIV2>, @@ -314,6 +323,12 @@ clock-names = "stmmaceth", "clkin0", "clkin1"; };
+&gpio_intc { + compatible = "amlogic,meson-gpio-intc", + "amlogic,meson-gxbb-gpio-intc"; + status = "okay"; +}; + &hdmi_tx { compatible = "amlogic,meson-gxbb-dw-hdmi", "amlogic,meson-gx-dw-hdmi"; resets = <&reset RESET_HDMITX_CAPB3>, @@ -370,19 +385,36 @@ reg-names = "mux", "pull", "pull-enable", "gpio"; gpio-controller; #gpio-cells = <2>; - gpio-ranges = <&pinctrl_periphs 0 14 120>; + gpio-ranges = <&pinctrl_periphs 0 0 119>; };
emmc_pins: emmc { mux { groups = "emmc_nand_d07", "emmc_cmd", - "emmc_clk", - "emmc_ds"; + "emmc_clk"; + function = "emmc"; + }; + }; + + emmc_ds_pins: emmc-ds { + mux { + groups = "emmc_ds"; function = "emmc"; }; };
+ emmc_clk_gate_pins: emmc_clk_gate { + mux { + groups = "BOOT_8"; + function = "gpio_periphs"; + }; + cfg-pull-down { + pins = "BOOT_8"; + bias-pull-down; + }; + }; + nor_pins: nor { mux { groups = "nor_d", @@ -421,6 +453,17 @@ }; };
+ sdcard_clk_gate_pins: sdcard_clk_gate { + mux { + groups = "CARD_2"; + function = "gpio_periphs"; + }; + cfg-pull-down { + pins = "CARD_2"; + bias-pull-down; + }; + }; + sdio_pins: sdio { mux { groups = "sdio_d0", @@ -433,6 +476,17 @@ }; };
+ sdio_clk_gate_pins: sdio_clk_gate { + mux { + groups = "GPIOX_4"; + function = "gpio_periphs"; + }; + cfg-pull-down { + pins = "GPIOX_4"; + bias-pull-down; + }; + }; + sdio_irq_pins: sdio_irq { mux { groups = "sdio_irq"; @@ -640,33 +694,74 @@ }; };
+&pwrc_vpu { + resets = <&reset RESET_VIU>, + <&reset RESET_VENC>, + <&reset RESET_VCBUS>, + <&reset RESET_BT656>, + <&reset RESET_DVIN_RESET>, + <&reset RESET_RDMA>, + <&reset RESET_VENCI>, + <&reset RESET_VENCP>, + <&reset RESET_VDAC>, + <&reset RESET_VDI6>, + <&reset RESET_VENCL>, + <&reset RESET_VID_LOCK>; + clocks = <&clkc CLKID_VPU>, + <&clkc CLKID_VAPB>; + clock-names = "vpu", "vapb"; + /* + * VPU clocking is provided by two identical clock paths + * VPU_0 and VPU_1 muxed to a single clock by a glitch + * free mux to safely change frequency while running. + * Same for VAPB but with a final gate after the glitch free mux. + */ + assigned-clocks = <&clkc CLKID_VPU_0_SEL>, + <&clkc CLKID_VPU_0>, + <&clkc CLKID_VPU>, /* Glitch free mux */ + <&clkc CLKID_VAPB_0_SEL>, + <&clkc CLKID_VAPB_0>, + <&clkc CLKID_VAPB_SEL>; /* Glitch free mux */ + assigned-clock-parents = <&clkc CLKID_FCLK_DIV3>, + <0>, /* Do Nothing */ + <&clkc CLKID_VPU_0>, + <&clkc CLKID_FCLK_DIV4>, + <0>, /* Do Nothing */ + <&clkc CLKID_VAPB_0>; + assigned-clock-rates = <0>, /* Do Nothing */ + <666666666>, + <0>, /* Do Nothing */ + <0>, /* Do Nothing */ + <250000000>, + <0>; /* Do Nothing */ +}; + &saradc { compatible = "amlogic,meson-gxbb-saradc", "amlogic,meson-saradc"; clocks = <&xtal>, <&clkc CLKID_SAR_ADC>, - <&clkc CLKID_SANA>, <&clkc CLKID_SAR_ADC_CLK>, <&clkc CLKID_SAR_ADC_SEL>; - clock-names = "clkin", "core", "sana", "adc_clk", "adc_sel"; + clock-names = "clkin", "core", "adc_clk", "adc_sel"; };
&sd_emmc_a { clocks = <&clkc CLKID_SD_EMMC_A>, - <&xtal>, + <&clkc CLKID_SD_EMMC_A_CLK0>, <&clkc CLKID_FCLK_DIV2>; clock-names = "core", "clkin0", "clkin1"; };
&sd_emmc_b { clocks = <&clkc CLKID_SD_EMMC_B>, - <&xtal>, + <&clkc CLKID_SD_EMMC_B_CLK0>, <&clkc CLKID_FCLK_DIV2>; clock-names = "core", "clkin0", "clkin1"; };
&sd_emmc_c { clocks = <&clkc CLKID_SD_EMMC_C>, - <&xtal>, + <&clkc CLKID_SD_EMMC_C_CLK0>, <&clkc CLKID_FCLK_DIV2>; clock-names = "core", "clkin0", "clkin1"; }; @@ -682,6 +777,32 @@ clocks = <&clkc CLKID_SPI>; };
+&uart_A { + clocks = <&xtal>, <&clkc CLKID_UART0>, <&xtal>; + clock-names = "xtal", "pclk", "baud"; +}; + +&uart_AO { + clocks = <&xtal>, <&clkc CLKID_CLK81>, <&xtal>; + clock-names = "xtal", "pclk", "baud"; +}; + +&uart_AO_B { + clocks = <&xtal>, <&clkc CLKID_CLK81>, <&xtal>; + clock-names = "xtal", "pclk", "baud"; +}; + +&uart_B { + clocks = <&xtal>, <&clkc CLKID_UART1>, <&xtal>; + clock-names = "xtal", "pclk", "baud"; +}; + +&uart_C { + clocks = <&xtal>, <&clkc CLKID_UART2>, <&xtal>; + clock-names = "xtal", "pclk", "baud"; +}; + &vpu { compatible = "amlogic,meson-gxbb-vpu", "amlogic,meson-gx-vpu"; + power-domains = <&pwrc_vpu>; }; diff --git a/arch/arm/dts/meson-gxl-s905x-khadas-vim.dts b/arch/arm/dts/meson-gxl-s905x-khadas-vim.dts index 94567eb..71a6e1c 100644 --- a/arch/arm/dts/meson-gxl-s905x-khadas-vim.dts +++ b/arch/arm/dts/meson-gxl-s905x-khadas-vim.dts @@ -67,6 +67,13 @@ }; };
+&cec_AO { + status = "okay"; + pinctrl-0 = <&ao_cec_pins>; + pinctrl-names = "default"; + hdmi-phandle = <&hdmi_tx>; +}; + &hdmi_tx { status = "okay"; pinctrl-0 = <&hdmi_hpd_pins>, <&hdmi_i2c_pins>; @@ -105,6 +112,62 @@ linux,rc-map-name = "rc-geekbox"; };
+&pinctrl_aobus { + gpio-line-names = "UART TX", + "UART RX", + "Power Key In", + "J9 Header Pin35", + "J9 Header Pin16", + "J9 Header Pin15", + "J9 Header Pin33", + "IR In", + "HDMI CEC", + "SYS LED", + /* GPIO_TEST_N */ + ""; +}; + +&pinctrl_periphs { + gpio-line-names = /* Bank GPIOZ */ + "", "", "", "", "", "", "", + "", "", "", "", "", "", "", + "Power OFF", + "VCCK Enable", + /* Bank GPIOH */ + "HDMI HPD", "HDMI SDA", "HDMI SCL", + "HDMI_5V_EN", "SPDIF", + "J9 Header Pin37", + "J9 Header Pin30", + "J9 Header Pin29", + "J9 Header Pin32", + "J9 Header Pin31", + /* Bank BOOT */ + "eMMC D0", "eMMC D1", "eMMC D2", "eMMC D3", + "eMMC D4", "eMMC D5", "eMMC D6", "eMMC D7", + "eMMC Clk", "eMMC Reset", "eMMC CMD", + "", "BOOT_MODE", "", "", "eMMC Data Strobe", + /* Bank CARD */ + "SDCard D1", "SDCard D0", "SDCard CLK", "SDCard CMD", + "SDCard D3", "SDCard D2", "SDCard Det", + /* Bank GPIODV */ + "", "", "", "", "", "", "", "", "", "", "", "", + "", "", "", "", "", "", "", "", "", "", "", "", + "I2C A SDA", "I2C A SCK", "I2C B SDA", "I2C B SCK", + "VCCK Regulator", "VDDEE Regulator", + /* Bank GPIOX */ + "WIFI SDIO D0", "WIFI SDIO D1", "WIFI SDIO D2", + "WIFI SDIO D3", "WIFI SDIO CLK", "WIFI SDIO CMD", + "WIFI Power Enable", "WIFI WAKE HOST", + "Bluetooth PCM DOUT", "Bluetooth PCM DIN", + "Bluetooth PCM SYNC", "Bluetooth PCM CLK", + "Bluetooth UART TX", "Bluetooth UART RX", + "Bluetooth UART CTS", "Bluetooth UART RTS", + "WIFI 32K", "Bluetooth Enable", + "Bluetooth WAKE HOST", + /* Bank GPIOCLK */ + "", "J9 Header Pin39"; +}; + &pwm_AO_ab { status = "okay"; pinctrl-0 = <&pwm_ao_a_3_pins>, <&pwm_ao_b_pins>; diff --git a/arch/arm/dts/meson-gxl-s905x-libretech-cc.dts b/arch/arm/dts/meson-gxl-s905x-libretech-cc.dts index 266fbcf..9671f1e 100644 --- a/arch/arm/dts/meson-gxl-s905x-libretech-cc.dts +++ b/arch/arm/dts/meson-gxl-s905x-libretech-cc.dts @@ -72,6 +72,18 @@ reg = <0x0 0x0 0x0 0x80000000>; };
+ hdmi_5v: regulator-hdmi-5v { + compatible = "regulator-fixed"; + + regulator-name = "HDMI_5V"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + + gpio = <&gpio GPIOH_3 GPIO_ACTIVE_HIGH>; + enable-active-high; + regulator-always-on; + }; + vcc_3v3: regulator-vcc_3v3 { compatible = "regulator-fixed"; regulator-name = "VCC_3V3"; @@ -91,6 +103,16 @@
states = <3300000 0>, <1800000 1>; + + regulator-settling-time-up-us = <200>; + regulator-settling-time-down-us = <50000>; + }; + + vddio_ao18: regulator-vddio_ao18 { + compatible = "regulator-fixed"; + regulator-name = "VDDIO_AO18"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; };
vddio_boot: regulator-vddio_boot { @@ -101,6 +123,13 @@ }; };
+&cec_AO { + status = "okay"; + pinctrl-0 = <&ao_cec_pins>; + pinctrl-names = "default"; + hdmi-phandle = <&hdmi_tx>; +}; + &cvbs_vdac_port { cvbs_vdac_out: endpoint { remote-endpoint = <&cvbs_connector_in>; @@ -111,6 +140,11 @@ status = "okay"; };
+&internal_phy { + pinctrl-0 = <ð_link_led_pins>, <ð_act_led_pins>; + pinctrl-names = "default"; +}; + &ir { status = "okay"; pinctrl-0 = <&remote_input_ao_pins>; @@ -129,14 +163,80 @@ }; };
+&pinctrl_aobus { + gpio-line-names = "UART TX", + "UART RX", + "Blue LED", + "SDCard Voltage Switch", + "7J1 Header Pin5", + "7J1 Header Pin3", + "7J1 Header Pin12", + "IR In", + "9J3 Switch HDMI CEC/7J1 Header Pin11", + "7J1 Header Pin13", + /* GPIO_TEST_N */ + "7J1 Header Pin15"; +}; + +&pinctrl_periphs { + gpio-line-names = /* Bank GPIOZ */ + "", "", "", "", "", "", "", + "", "", "", "", "", "", "", + "Eth Link LED", "Eth Activity LED", + /* Bank GPIOH */ + "HDMI HPD", "HDMI SDA", "HDMI SCL", + "HDMI_5V_EN", "9J1 Header Pin2", + "Analog Audio Mute", + "2J3 Header Pin6", + "2J3 Header Pin5", + "2J3 Header Pin4", + "2J3 Header Pin3", + /* Bank BOOT */ + "eMMC D0", "eMMC D1", "eMMC D2", "eMMC D3", + "eMMC D4", "eMMC D5", "eMMC D6", "eMMC D7", + "eMMC Clk", "eMMC Reset", "eMMC CMD", + "ALT BOOT MODE", "", "", "", "eMMC Data Strobe", + /* Bank CARD */ + "SDCard D1", "SDCard D0", "SDCard CLK", "SDCard CMD", + "SDCard D3", "SDCard D2", "SDCard Det", + /* Bank GPIODV */ + "", "", "", "", "", "", "", "", "", "", "", "", + "", "", "", "", "", "", "", "", "", "", "", "", + "Green LED", "VCCK Enable", + "7J1 Header Pin27", "7J1 Header Pin28", + "VCCK Regulator", "VDDEE Regulator", + /* Bank GPIOX */ + "7J1 Header Pin22", "7J1 Header Pin26", + "7J1 Header Pin36", "7J1 Header Pin38", + "7J1 Header Pin40", "7J1 Header Pin37", + "7J1 Header Pin33", "7J1 Header Pin35", + "7J1 Header Pin19", "7J1 Header Pin21", + "7J1 Header Pin24", "7J1 Header Pin23", + "7J1 Header Pin8", "7J1 Header Pin10", + "7J1 Header Pin16", "7J1 Header Pin18", + "7J1 Header Pin32", "7J1 Header Pin29", + "7J1 Header Pin31", + /* Bank GPIOCLK */ + "7J1 Header Pin7", ""; +}; + +&saradc { + status = "okay"; + vref-supply = <&vddio_ao18>; +}; + /* SD card */ &sd_emmc_b { status = "okay"; pinctrl-0 = <&sdcard_pins>; - pinctrl-names = "default"; + pinctrl-1 = <&sdcard_clk_gate_pins>; + pinctrl-names = "default", "clk-gate";
bus-width = <4>; cap-sd-highspeed; + sd-uhs-sdr12; + sd-uhs-sdr25; + sd-uhs-sdr50; max-frequency = <100000000>; disable-wp;
@@ -150,11 +250,13 @@ /* eMMC */ &sd_emmc_c { status = "okay"; - pinctrl-0 = <&emmc_pins>; - pinctrl-names = "default"; + pinctrl-0 = <&emmc_pins>, <&emmc_ds_pins>; + pinctrl-1 = <&emmc_clk_gate_pins>; + pinctrl-names = "default", "clk-gate";
bus-width = <8>; cap-mmc-highspeed; + mmc-ddr-3_3v; max-frequency = <50000000>; non-removable; disable-wp; diff --git a/arch/arm/dts/meson-gxl-s905x-p212.dts b/arch/arm/dts/meson-gxl-s905x-p212.dts index 6ab17c1..6e2bf85 100644 --- a/arch/arm/dts/meson-gxl-s905x-p212.dts +++ b/arch/arm/dts/meson-gxl-s905x-p212.dts @@ -71,6 +71,13 @@ }; };
+&cec_AO { + status = "okay"; + pinctrl-0 = <&ao_cec_pins>; + pinctrl-names = "default"; + hdmi-phandle = <&hdmi_tx>; +}; + &cvbs_vdac_port { cvbs_vdac_out: endpoint { remote-endpoint = <&cvbs_connector_in>; diff --git a/arch/arm/dts/meson-gxl-s905x-p212.dtsi b/arch/arm/dts/meson-gxl-s905x-p212.dtsi index f3eea8e..7005068 100644 --- a/arch/arm/dts/meson-gxl-s905x-p212.dtsi +++ b/arch/arm/dts/meson-gxl-s905x-p212.dtsi @@ -28,6 +28,18 @@ reg = <0x0 0x0 0x0 0x80000000>; };
+ hdmi_5v: regulator-hdmi-5v { + compatible = "regulator-fixed"; + + regulator-name = "HDMI_5V"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + + gpio = <&gpio GPIOH_3 GPIO_ACTIVE_HIGH>; + enable-active-high; + regulator-always-on; + }; + vddio_boot: regulator-vddio_boot { compatible = "regulator-fixed"; regulator-name = "VDDIO_BOOT"; @@ -95,7 +107,8 @@ &sd_emmc_a { status = "okay"; pinctrl-0 = <&sdio_pins>; - pinctrl-names = "default"; + pinctrl-1 = <&sdio_clk_gate_pins>; + pinctrl-names = "default", "clk-gate"; #address-cells = <1>; #size-cells = <0>;
@@ -116,7 +129,8 @@ &sd_emmc_b { status = "okay"; pinctrl-0 = <&sdcard_pins>; - pinctrl-names = "default"; + pinctrl-1 = <&sdcard_clk_gate_pins>; + pinctrl-names = "default", "clk-gate";
bus-width = <4>; cap-sd-highspeed; @@ -133,11 +147,11 @@ /* eMMC */ &sd_emmc_c { status = "okay"; - pinctrl-0 = <&emmc_pins>; - pinctrl-names = "default"; + pinctrl-0 = <&emmc_pins>, <&emmc_ds_pins>; + pinctrl-1 = <&emmc_clk_gate_pins>; + pinctrl-names = "default", "clk-gate";
bus-width = <8>; - cap-sd-highspeed; cap-mmc-highspeed; max-frequency = <200000000>; non-removable; diff --git a/arch/arm/dts/meson-gxl.dtsi b/arch/arm/dts/meson-gxl.dtsi index 8d4f316..c851411 100644 --- a/arch/arm/dts/meson-gxl.dtsi +++ b/arch/arm/dts/meson-gxl.dtsi @@ -43,11 +43,20 @@
#include "meson-gx.dtsi" #include <dt-bindings/clock/gxbb-clkc.h> +#include <dt-bindings/clock/gxbb-aoclkc.h> #include <dt-bindings/gpio/meson-gxl-gpio.h> #include <dt-bindings/reset/amlogic,meson-gxbb-reset.h>
/ { compatible = "amlogic,meson-gxl"; + + reserved-memory { + /* Alternate 3 MiB reserved for ARM Trusted Firmware (BL31) */ + secmon_reserved_alt: secmon@5000000 { + reg = <0x0 0x05000000 0x0 0x300000>; + no-map; + }; + }; };
ðmac { @@ -207,6 +216,21 @@ }; };
+&cec_AO { + clocks = <&clkc_AO CLKID_AO_CEC_32K>; + clock-names = "core"; +}; + +&clkc_AO { + compatible = "amlogic,meson-gxl-aoclkc", "amlogic,meson-gx-aoclkc"; +}; + +&gpio_intc { + compatible = "amlogic,meson-gpio-intc", + "amlogic,meson-gxl-gpio-intc"; + status = "okay"; +}; + &hdmi_tx { compatible = "amlogic,meson-gxl-dw-hdmi", "amlogic,meson-gx-dw-hdmi"; resets = <&reset RESET_HDMITX_CAPB3>, @@ -258,19 +282,36 @@ reg-names = "mux", "pull", "pull-enable", "gpio"; gpio-controller; #gpio-cells = <2>; - gpio-ranges = <&pinctrl_periphs 0 10 101>; + gpio-ranges = <&pinctrl_periphs 0 0 100>; };
emmc_pins: emmc { mux { groups = "emmc_nand_d07", "emmc_cmd", - "emmc_clk", - "emmc_ds"; + "emmc_clk"; function = "emmc"; }; };
+ emmc_ds_pins: emmc-ds { + mux { + groups = "emmc_ds"; + function = "emmc"; + }; + }; + + emmc_clk_gate_pins: emmc_clk_gate { + mux { + groups = "BOOT_8"; + function = "gpio_periphs"; + }; + cfg-pull-down { + pins = "BOOT_8"; + bias-pull-down; + }; + }; + nor_pins: nor { mux { groups = "nor_d", @@ -309,6 +350,17 @@ }; };
+ sdcard_clk_gate_pins: sdcard_clk_gate { + mux { + groups = "CARD_2"; + function = "gpio_periphs"; + }; + cfg-pull-down { + pins = "CARD_2"; + bias-pull-down; + }; + }; + sdio_pins: sdio { mux { groups = "sdio_d0", @@ -321,6 +373,17 @@ }; };
+ sdio_clk_gate_pins: sdio_clk_gate { + mux { + groups = "GPIOX_4"; + function = "gpio_periphs"; + }; + cfg-pull-down { + pins = "GPIOX_4"; + bias-pull-down; + }; + }; + sdio_irq_pins: sdio_irq { mux { groups = "sdio_irq"; @@ -568,6 +631,7 @@
internal_phy: ethernet-phy@8 { compatible = "ethernet-phy-id0181.4400", "ethernet-phy-ieee802.3-c22"; + interrupts = <GIC_SPI 9 IRQ_TYPE_LEVEL_HIGH>; reg = <8>; max-speed = <100>; }; @@ -581,33 +645,74 @@ }; };
+&pwrc_vpu { + resets = <&reset RESET_VIU>, + <&reset RESET_VENC>, + <&reset RESET_VCBUS>, + <&reset RESET_BT656>, + <&reset RESET_DVIN_RESET>, + <&reset RESET_RDMA>, + <&reset RESET_VENCI>, + <&reset RESET_VENCP>, + <&reset RESET_VDAC>, + <&reset RESET_VDI6>, + <&reset RESET_VENCL>, + <&reset RESET_VID_LOCK>; + clocks = <&clkc CLKID_VPU>, + <&clkc CLKID_VAPB>; + clock-names = "vpu", "vapb"; + /* + * VPU clocking is provided by two identical clock paths + * VPU_0 and VPU_1 muxed to a single clock by a glitch + * free mux to safely change frequency while running. + * Same for VAPB but with a final gate after the glitch free mux. + */ + assigned-clocks = <&clkc CLKID_VPU_0_SEL>, + <&clkc CLKID_VPU_0>, + <&clkc CLKID_VPU>, /* Glitch free mux */ + <&clkc CLKID_VAPB_0_SEL>, + <&clkc CLKID_VAPB_0>, + <&clkc CLKID_VAPB_SEL>; /* Glitch free mux */ + assigned-clock-parents = <&clkc CLKID_FCLK_DIV3>, + <0>, /* Do Nothing */ + <&clkc CLKID_VPU_0>, + <&clkc CLKID_FCLK_DIV4>, + <0>, /* Do Nothing */ + <&clkc CLKID_VAPB_0>; + assigned-clock-rates = <0>, /* Do Nothing */ + <666666666>, + <0>, /* Do Nothing */ + <0>, /* Do Nothing */ + <250000000>, + <0>; /* Do Nothing */ +}; + &saradc { compatible = "amlogic,meson-gxl-saradc", "amlogic,meson-saradc"; clocks = <&xtal>, <&clkc CLKID_SAR_ADC>, - <&clkc CLKID_SANA>, <&clkc CLKID_SAR_ADC_CLK>, <&clkc CLKID_SAR_ADC_SEL>; - clock-names = "clkin", "core", "sana", "adc_clk", "adc_sel"; + clock-names = "clkin", "core", "adc_clk", "adc_sel"; };
&sd_emmc_c { clocks = <&clkc CLKID_SD_EMMC_C>, - <&xtal>, + <&clkc CLKID_SD_EMMC_C_CLK0>, <&clkc CLKID_FCLK_DIV2>; clock-names = "core", "clkin0", "clkin1"; }; @@ -623,6 +728,32 @@ clocks = <&clkc CLKID_SPI>; };
+&uart_A { + clocks = <&xtal>, <&clkc CLKID_UART0>, <&xtal>; + clock-names = "xtal", "pclk", "baud"; +}; + +&uart_AO { + clocks = <&xtal>, <&clkc CLKID_CLK81>, <&xtal>; + clock-names = "xtal", "pclk", "baud"; +}; + +&uart_AO_B { + clocks = <&xtal>, <&clkc CLKID_CLK81>, <&xtal>; + clock-names = "xtal", "pclk", "baud"; +}; + +&uart_B { + clocks = <&xtal>, <&clkc CLKID_UART1>, <&xtal>; + clock-names = "xtal", "pclk", "baud"; +}; + +&uart_C { + clocks = <&xtal>, <&clkc CLKID_UART2>, <&xtal>; + clock-names = "xtal", "pclk", "baud"; +}; + &vpu { compatible = "amlogic,meson-gxl-vpu", "amlogic,meson-gx-vpu"; + power-domains = <&pwrc_vpu>; }; diff --git a/include/dt-bindings/clock/gxbb-aoclkc.h b/include/dt-bindings/clock/gxbb-aoclkc.h index 3175148..9d15e22 100644 --- a/include/dt-bindings/clock/gxbb-aoclkc.h +++ b/include/dt-bindings/clock/gxbb-aoclkc.h @@ -62,5 +62,6 @@ #define CLKID_AO_UART1 3 #define CLKID_AO_UART2 4 #define CLKID_AO_IR_BLASTER 5 +#define CLKID_AO_CEC_32K 6
#endif diff --git a/include/dt-bindings/clock/gxbb-clkc.h b/include/dt-bindings/clock/gxbb-clkc.h index e3e9f79..8ba99a5 100644 --- a/include/dt-bindings/clock/gxbb-clkc.h +++ b/include/dt-bindings/clock/gxbb-clkc.h @@ -1,3 +1,4 @@ +/* SPDX-License-Identifier: GPL-2.0 */ /* * GXBB clock tree IDs */ @@ -5,37 +6,96 @@ #ifndef __GXBB_CLKC_H #define __GXBB_CLKC_H
+#define CLKID_SYS_PLL 0 #define CLKID_HDMI_PLL 2 +#define CLKID_FIXED_PLL 3 #define CLKID_FCLK_DIV2 4 #define CLKID_FCLK_DIV3 5 #define CLKID_FCLK_DIV4 6 +#define CLKID_FCLK_DIV5 7 +#define CLKID_FCLK_DIV7 8 #define CLKID_GP0_PLL 9 #define CLKID_CLK81 12 +#define CLKID_MPLL0 13 +#define CLKID_MPLL1 14 #define CLKID_MPLL2 15 +#define CLKID_DDR 16 +#define CLKID_DOS 17 +#define CLKID_ISA 18 +#define CLKID_PL301 19 +#define CLKID_PERIPHS 20 #define CLKID_SPICC 21 #define CLKID_I2C 22 #define CLKID_SAR_ADC 23 +#define CLKID_SMART_CARD 24 #define CLKID_RNG0 25 #define CLKID_UART0 26 +#define CLKID_SDHC 27 +#define CLKID_STREAM 28 +#define CLKID_ASYNC_FIFO 29 +#define CLKID_SDIO 30 +#define CLKID_ABUF 31 +#define CLKID_HIU_IFACE 32 +#define CLKID_ASSIST_MISC 33 #define CLKID_SPI 34 #define CLKID_ETH 36 +#define CLKID_I2S_SPDIF 35 +#define CLKID_DEMUX 37 #define CLKID_AIU_GLUE 38 #define CLKID_IEC958 39 #define CLKID_I2S_OUT 40 +#define CLKID_AMCLK 41 +#define CLKID_AIFIFO2 42 +#define CLKID_MIXER 43 #define CLKID_MIXER_IFACE 44 +#define CLKID_ADC 45 +#define CLKID_BLKMV 46 #define CLKID_AIU 47 #define CLKID_UART1 48 +#define CLKID_G2D 49 #define CLKID_USB0 50 #define CLKID_USB1 51 +#define CLKID_RESET 52 +#define CLKID_NAND 53 +#define CLKID_DOS_PARSER 54 #define CLKID_USB 55 +#define CLKID_VDIN1 56 +#define CLKID_AHB_ARB0 57 +#define CLKID_EFUSE 58 +#define CLKID_BOOT_ROM 59 +#define CLKID_AHB_DATA_BUS 60 +#define CLKID_AHB_CTRL_BUS 61 +#define CLKID_HDMI_INTR_SYNC 62 #define CLKID_HDMI_PCLK 63 #define CLKID_USB1_DDR_BRIDGE 64 #define CLKID_USB0_DDR_BRIDGE 65 +#define CLKID_MMC_PCLK 66 +#define CLKID_DVIN 67 #define CLKID_UART2 68 #define CLKID_SANA 69 +#define CLKID_VPU_INTR 70 +#define CLKID_SEC_AHB_AHB3_BRIDGE 71 +#define CLKID_CLK81_A53 72 +#define CLKID_VCLK2_VENCI0 73 +#define CLKID_VCLK2_VENCI1 74 +#define CLKID_VCLK2_VENCP0 75 +#define CLKID_VCLK2_VENCP1 76 #define CLKID_GCLK_VENCI_INT0 77 +#define CLKID_GCLK_VENCI_INT 78 +#define CLKID_DAC_CLK 79 #define CLKID_AOCLK_GATE 80 #define CLKID_IEC958_GATE 81 +#define CLKID_ENC480P 82 +#define CLKID_RNG1 83 +#define CLKID_GCLK_VENCI_INT1 84 +#define CLKID_VCLK2_VENCLMCC 85 +#define CLKID_VCLK2_VENCL 86 +#define CLKID_VCLK_OTHER 87 +#define CLKID_EDP 88 +#define CLKID_AO_MEDIA_CPU 89 +#define CLKID_AO_AHB_SRAM 90 +#define CLKID_AO_AHB_BUS 91 +#define CLKID_AO_IFACE 92 #define CLKID_AO_I2C 93 #define CLKID_SD_EMMC_A 94 #define CLKID_SD_EMMC_B 95 @@ -50,5 +110,20 @@ #define CLKID_CTS_AMCLK 107 #define CLKID_CTS_MCLK_I958 110 #define CLKID_CTS_I958 113 +#define CLKID_32K_CLK 114 +#define CLKID_SD_EMMC_A_CLK0 119 +#define CLKID_SD_EMMC_B_CLK0 122 +#define CLKID_SD_EMMC_C_CLK0 125 +#define CLKID_VPU_0_SEL 126 +#define CLKID_VPU_0 128 +#define CLKID_VPU_1_SEL 129 +#define CLKID_VPU_1 131 +#define CLKID_VPU 132 +#define CLKID_VAPB_0_SEL 133 +#define CLKID_VAPB_0 135 +#define CLKID_VAPB_1_SEL 136 +#define CLKID_VAPB_1 138 +#define CLKID_VAPB_SEL 139 +#define CLKID_VAPB 140
#endif /* __GXBB_CLKC_H */ diff --git a/include/dt-bindings/gpio/meson-gxbb-gpio.h b/include/dt-bindings/gpio/meson-gxbb-gpio.h index 58654fd..43a68a1 100644 --- a/include/dt-bindings/gpio/meson-gxbb-gpio.h +++ b/include/dt-bindings/gpio/meson-gxbb-gpio.h @@ -29,6 +29,7 @@ #define GPIOAO_11 11 #define GPIOAO_12 12 #define GPIOAO_13 13 +#define GPIO_TEST_N 14
#define GPIOZ_0 0 #define GPIOZ_1 1 @@ -149,6 +150,5 @@ #define GPIOCLK_1 116 #define GPIOCLK_2 117 #define GPIOCLK_3 118 -#define GPIO_TEST_N 119
#endif diff --git a/include/dt-bindings/gpio/meson-gxl-gpio.h b/include/dt-bindings/gpio/meson-gxl-gpio.h index 684d0d7..01f2a2a 100644 --- a/include/dt-bindings/gpio/meson-gxl-gpio.h +++ b/include/dt-bindings/gpio/meson-gxl-gpio.h @@ -25,6 +25,7 @@ #define GPIOAO_7 7 #define GPIOAO_8 8 #define GPIOAO_9 9 +#define GPIO_TEST_N 10
#define GPIOZ_0 0 #define GPIOZ_1 1 @@ -126,6 +127,5 @@ #define GPIOX_18 97 #define GPIOCLK_0 98 #define GPIOCLK_1 99 -#define GPIO_TEST_N 100
#endif
The pinctrl bindings has changed for Amlogic Meson SoCs since Linux 4.13, update the pinctrl driver to take this in account.
Signed-off-by: Neil Armstrong narmstrong@baylibre.com --- drivers/pinctrl/meson/pinctrl-meson-gxbb.c | 12 ++++++------ drivers/pinctrl/meson/pinctrl-meson-gxl.c | 14 +++++++------- 2 files changed, 13 insertions(+), 13 deletions(-)
diff --git a/drivers/pinctrl/meson/pinctrl-meson-gxbb.c b/drivers/pinctrl/meson/pinctrl-meson-gxbb.c index 87c9912..928356f 100644 --- a/drivers/pinctrl/meson/pinctrl-meson-gxbb.c +++ b/drivers/pinctrl/meson/pinctrl-meson-gxbb.c @@ -14,7 +14,7 @@
#include "pinctrl-meson.h"
-#define EE_OFF 14 +#define EE_OFF 15
static const unsigned int emmc_nand_d07_pins[] = { PIN(BOOT_0, EE_OFF), PIN(BOOT_1, EE_OFF), PIN(BOOT_2, EE_OFF), @@ -319,8 +319,6 @@ static const char * const gpio_periphs_groups[] = { "GPIOX_10", "GPIOX_11", "GPIOX_12", "GPIOX_13", "GPIOX_14", "GPIOX_15", "GPIOX_16", "GPIOX_17", "GPIOX_18", "GPIOX_19", "GPIOX_20", "GPIOX_21", "GPIOX_22", - - "GPIO_TEST_N", };
static const char * const emmc_groups[] = { @@ -355,6 +353,8 @@ static const char * const gpio_aobus_groups[] = { "GPIOAO_0", "GPIOAO_1", "GPIOAO_2", "GPIOAO_3", "GPIOAO_4", "GPIOAO_5", "GPIOAO_6", "GPIOAO_7", "GPIOAO_8", "GPIOAO_9", "GPIOAO_10", "GPIOAO_11", "GPIOAO_12", "GPIOAO_13", + + "GPIO_TEST_N", };
static const char * const uart_ao_groups[] = { @@ -410,11 +410,11 @@ static struct meson_bank meson_gxbb_aobus_banks[] = {
struct meson_pinctrl_data meson_gxbb_periphs_pinctrl_data = { .name = "periphs-banks", - .pin_base = 14, + .pin_base = 15, .groups = meson_gxbb_periphs_groups, .funcs = meson_gxbb_periphs_functions, .banks = meson_gxbb_periphs_banks, - .num_pins = 120, + .num_pins = 119, .num_groups = ARRAY_SIZE(meson_gxbb_periphs_groups), .num_funcs = ARRAY_SIZE(meson_gxbb_periphs_functions), .num_banks = ARRAY_SIZE(meson_gxbb_periphs_banks), @@ -426,7 +426,7 @@ struct meson_pinctrl_data meson_gxbb_aobus_pinctrl_data = { .groups = meson_gxbb_aobus_groups, .funcs = meson_gxbb_aobus_functions, .banks = meson_gxbb_aobus_banks, - .num_pins = 14, + .num_pins = 15, .num_groups = ARRAY_SIZE(meson_gxbb_aobus_groups), .num_funcs = ARRAY_SIZE(meson_gxbb_aobus_functions), .num_banks = ARRAY_SIZE(meson_gxbb_aobus_banks), diff --git a/drivers/pinctrl/meson/pinctrl-meson-gxl.c b/drivers/pinctrl/meson/pinctrl-meson-gxl.c index eebfaa9..fdc379b 100644 --- a/drivers/pinctrl/meson/pinctrl-meson-gxl.c +++ b/drivers/pinctrl/meson/pinctrl-meson-gxl.c @@ -14,7 +14,7 @@
-#define EE_OFF 10 +#define EE_OFF 11
static const unsigned int emmc_nand_d07_pins[] = { PIN(BOOT_0, EE_OFF), PIN(BOOT_1, EE_OFF), PIN(BOOT_2, EE_OFF), @@ -290,7 +290,7 @@ static struct meson_pmx_group meson_gxl_periphs_groups[] = { GPIO_GROUP(GPIOCLK_0, EE_OFF), GPIO_GROUP(GPIOCLK_1, EE_OFF),
- GPIO_GROUP(GPIO_TEST_N, EE_OFF), + GPIO_GROUP(GPIO_TEST_N, 0),
/* Bank X */ GROUP(sdio_d0, 5, 31), @@ -472,8 +472,6 @@ static const char * const gpio_periphs_groups[] = { "GPIOX_5", "GPIOX_6", "GPIOX_7", "GPIOX_8", "GPIOX_9", "GPIOX_10", "GPIOX_11", "GPIOX_12", "GPIOX_13", "GPIOX_14", "GPIOX_15", "GPIOX_16", "GPIOX_17", "GPIOX_18", - - "GPIO_TEST_N", };
static const char * const emmc_groups[] = { @@ -588,6 +586,8 @@ static const char * const tsin_a_groups[] = { static const char * const gpio_aobus_groups[] = { "GPIOAO_0", "GPIOAO_1", "GPIOAO_2", "GPIOAO_3", "GPIOAO_4", "GPIOAO_5", "GPIOAO_6", "GPIOAO_7", "GPIOAO_8", "GPIOAO_9", + + "GPIO_TEST_N", };
static const char * const uart_ao_groups[] = { @@ -692,11 +692,11 @@ static struct meson_bank meson_gxl_aobus_banks[] = {
struct meson_pinctrl_data meson_gxl_periphs_pinctrl_data = { .name = "periphs-banks", - .pin_base = 10, + .pin_base = 11, .groups = meson_gxl_periphs_groups, .funcs = meson_gxl_periphs_functions, .banks = meson_gxl_periphs_banks, - .num_pins = 101, + .num_pins = 100, .num_groups = ARRAY_SIZE(meson_gxl_periphs_groups), .num_funcs = ARRAY_SIZE(meson_gxl_periphs_functions), .num_banks = ARRAY_SIZE(meson_gxl_periphs_banks), @@ -708,7 +708,7 @@ struct meson_pinctrl_data meson_gxl_aobus_pinctrl_data = { .groups = meson_gxl_aobus_groups, .funcs = meson_gxl_aobus_functions, .banks = meson_gxl_aobus_banks, - .num_pins = 10, + .num_pins = 11, .num_groups = ARRAY_SIZE(meson_gxl_aobus_groups), .num_funcs = ARRAY_SIZE(meson_gxl_aobus_functions), .num_banks = ARRAY_SIZE(meson_gxl_aobus_banks),
Neil Armstrong
