nokia_rx51_test failing due to http://repository.maemo.org not reachable
Hello Tom,
I think the http://repository.maemo.org repositories we used should be cloned to Github to make our life easier. Can we put them under the "u-boot" user?
Best regards
Heinrich
On Fri, Jan 13, 2023 at 09:02:17AM +0100, Heinrich Schuchardt wrote:
Hello Tom,
Perhaps Pali has some insight as to why Azure gets rate limited or something so badly?
Hello Tom,
Adding the files to the Docker image would be an alternative solution.
Best regards
Heinrich
Hello Tom,
I do not know about any Azure rate limiting. Maybe it is just a generic issue that server was not available...
I think that this is the proper solution. Also there is no need to rebuild qemu binary every time. Just put everything into the image.
Best regards
Heinrich
Hello Tom,
Consistently, Azure fails (gives up at an hour) to download the files, while they're available normally (I can download them at the same time, or GitLab is also doing it fine, concurrently).
If we're going to go that route, we should also build and package the special qemu, then modify the test script to see if things exist in say /opt/nokia (where I see Heinrich already has a patch to put the debs in).
Pali Rohár
