[U-Boot] [PATCH] mgcoge, mgsuvd: add I2C deblocking mechanism.
As Documented in README, adding a boardspecific Deblocking mechansim via CFG_I2C_INIT_BOARD for the mgcoge and mgsuvd board. This code was originally written by keymile in association with Anatech and Atmel in 1998. The Code toggels the SCL until the SCA line goes to High (max. 16 times). And after this, a start Condition is send.
Signed-off-by: Heiko Schocher hs@denx.de --- board/keymile/common/common.c | 211 +++++++++++++++++++++++++++++++++++++++++ board/keymile/mgcoge/Makefile | 2 +- drivers/i2c/soft_i2c.c | 11 ++ include/configs/mgcoge.h | 1 + include/configs/mgsuvd.h | 1 + 5 files changed, 225 insertions(+), 1 deletions(-) create mode 100644 board/keymile/common/common.c
diff --git a/board/keymile/common/common.c b/board/keymile/common/common.c new file mode 100644 index 0000000..a6ed379 --- /dev/null +++ b/board/keymile/common/common.c @@ -0,0 +1,211 @@ +/* + * (C) Copyright 2008 + * Heiko Schocher, DENX Software Engineering, hs@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <mpc8260.h> +#include <ioports.h> +#include <malloc.h> + +#if defined(CONFIG_OF_BOARD_SETUP) && defined(CONFIG_OF_LIBFDT) +#include <libfdt.h> +#endif + +#if defined(CONFIG_HARD_I2C) || defined(CONFIG_SOFT_I2C) +#include <i2c.h> +#endif + +#if defined(CONFIG_MGSUVD) +extern int i2c_mgsuvd_read (void); +#endif + +#if defined(CFG_I2C_INIT_BOARD) +#define DELAY_ABORT_SEQ 62 +#define DELAY_HALF_PERIOD (500 / (CFG_I2C_SPEED / 1000)) + +#if defined(CONFIG_MGCOGE) +#define SDA_MASK 0x00010000 +#define SCL_MASK 0x00020000 +static void set_pin (int state, unsigned long mask) +{ + volatile ioport_t *iop = ioport_addr ((immap_t *)CFG_IMMR, 3); + + if (state) + iop->pdat |= (mask); + else + iop->pdat &= ~(mask); + + iop->pdir |= (mask); +} + +static int get_pin (unsigned long mask) +{ + volatile ioport_t *iop = ioport_addr ((immap_t *)CFG_IMMR, 3); + + iop->pdir &= ~(mask); + return (0 != (iop->pdat & (mask))); +} + +static void set_sda (int state) +{ + set_pin (state, SDA_MASK); +} + +static void set_scl (int state) +{ + set_pin (state, SCL_MASK); +} + +static int get_sda (void) +{ + return get_pin (SDA_MASK); +} + +static int get_scl (void) +{ + return get_pin (SCL_MASK); +} + +#if defined(CONFIG_HARD_I2C) +static void setports (int gpio) +{ + volatile ioport_t *iop = ioport_addr ((immap_t *)CFG_IMMR, 3); + + if (gpio) { + iop->ppar &= ~(SDA_MASK | SCL_MASK); + iop->podr &= ~(SDA_MASK | SCL_MASK); + } else { + iop->ppar |= (SDA_MASK | SCL_MASK); + iop->pdir &= ~(SDA_MASK | SCL_MASK); + iop->podr |= (SDA_MASK | SCL_MASK); + } +} +#endif +#endif + +#if defined(CONFIG_MGSUVD) +static void set_sda (int state) +{ + I2C_SDA(state); +} + +static void set_scl (int state) +{ + I2C_SCL(state); +} + +static int get_sda (void) +{ + return i2c_mgsuvd_read (); +} + +static int get_scl (void) +{ + int val; + + *(unsigned short *)(I2C_BASE_DIR) &= ~SCL_CONF; + udelay (1); + val = *(unsigned char *)(I2C_BASE_PORT); + + return ((val & SCL_BIT) == SCL_BIT); +} + +#endif + +static void writeStartSeq (void) +{ + set_sda (1); + udelay (DELAY_HALF_PERIOD); + set_scl (1); + udelay (DELAY_HALF_PERIOD); + set_sda (0); + udelay (DELAY_HALF_PERIOD); + set_scl (0); + udelay (DELAY_HALF_PERIOD); +} + +/* I2C is a synchronous protocol and resets of the processor in the middle + of an access can block the I2C Bus until a powerdown of the full unit is + done. This function toggles the SCL until the SCL and SCA line are + released, but max. 16 times, after this a I2C start-sequence is sent. + This I2C Deblocking mechanism was developed by Keymile in association + with Anatech and Atmel in 1998. + */ +static int i2c_make_abort (void) +{ + int scl_state = 0; + int sda_state = 0; + int i = 0; + int ret = 0; + + if (!get_sda ()) { + ret = -1; + while (i < 16) { + i++; + set_scl (0); + udelay (DELAY_ABORT_SEQ); + set_scl (1); + udelay (DELAY_ABORT_SEQ); + scl_state = get_scl (); + sda_state = get_sda (); + if (scl_state && sda_state) { + ret = 0; + break; + } + } + } + if (ret == 0) { + for (i =0; i < 5; i++) { + writeStartSeq (); + } + } + get_sda (); + return ret; +} + +/** + * i2c_init_board - reset i2c bus. When the board is powercycled during a + * bus transfer it might hang; for details see doc/I2C_Edge_Conditions. + */ +void i2c_init_board(void) +{ +#if defined(CONFIG_HARD_I2C) + volatile immap_t *immap = (immap_t *)CFG_IMMR ; + volatile i2c8260_t *i2c = (i2c8260_t *)&immap->im_i2c; + + /* disable I2C controller first, otherwhise it thinks we want to */ + /* talk to the slave port... */ + i2c->i2c_i2mod &= ~0x01; + + /* Set the PortPins to GPIO */ + setports (1); +#endif + + /* Now run the AbortSequence() */ + i2c_make_abort (); + +#if defined(CONFIG_HARD_I2C) + /* Set the PortPins back to use for I2C */ + setports (0); +#endif +} +#endif diff --git a/board/keymile/mgcoge/Makefile b/board/keymile/mgcoge/Makefile index d4087cc..cbf7129 100644 --- a/board/keymile/mgcoge/Makefile +++ b/board/keymile/mgcoge/Makefile @@ -25,7 +25,7 @@ include $(TOPDIR)/config.mk
LIB = $(obj)lib$(BOARD).a
-COBJS := $(BOARD).o +COBJS := $(BOARD).o ../common/common.o
SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(COBJS)) diff --git a/drivers/i2c/soft_i2c.c b/drivers/i2c/soft_i2c.c index 57736da..983b14b 100644 --- a/drivers/i2c/soft_i2c.c +++ b/drivers/i2c/soft_i2c.c @@ -75,7 +75,9 @@ static unsigned int i2c_bus_num __attribute__ ((section ("data"))) = 0; /*----------------------------------------------------------------------- * Local functions */ +#if !defined(CFG_I2C_INIT_BOARD) static void send_reset (void); +#endif static void send_start (void); static void send_stop (void); static void send_ack (int); @@ -83,6 +85,7 @@ static int write_byte (uchar byte); static uchar read_byte (int);
+#if !defined(CFG_I2C_INIT_BOARD) /*----------------------------------------------------------------------- * Send a reset sequence consisting of 9 clocks with the data signal high * to clock any confused device back into an idle state. Also send a @@ -115,6 +118,7 @@ static void send_reset(void) send_stop(); I2C_TRISTATE; } +#endif
/*----------------------------------------------------------------------- * START: High -> Low on SDA while SCL is High @@ -311,6 +315,12 @@ static uchar read_byte(int ack) */ void i2c_init (int speed, int slaveaddr) { +#if defined(CFG_I2C_INIT_BOARD) + /* call board specific i2c bus reset routine before accessing the */ + /* environment, which might be in a chip on that bus. For details */ + /* about this problem see doc/I2C_Edge_Conditions. */ + i2c_init_board(); +#else /* * WARNING: Do NOT save speed in a static variable: if the * I2C routines are called before RAM is initialized (to read @@ -318,6 +328,7 @@ void i2c_init (int speed, int slaveaddr) * system will crash. */ send_reset (); +#endif }
/*----------------------------------------------------------------------- diff --git a/include/configs/mgcoge.h b/include/configs/mgcoge.h index bfbbd45..398e092 100644 --- a/include/configs/mgcoge.h +++ b/include/configs/mgcoge.h @@ -202,6 +202,7 @@ #define CONFIG_I2C_MULTI_BUS 1 #define CONFIG_I2C_CMD_TREE 1 #define CFG_MAX_I2C_BUS 2 +#define CFG_I2C_INIT_BOARD 1
/* EEprom support */ #define CFG_I2C_EEPROM_ADDR_LEN 1 diff --git a/include/configs/mgsuvd.h b/include/configs/mgsuvd.h index 01433ab..17ad6b4 100644 --- a/include/configs/mgsuvd.h +++ b/include/configs/mgsuvd.h @@ -372,6 +372,7 @@ #define CONFIG_I2C_MULTI_BUS 1 #define CONFIG_I2C_CMD_TREE 1 #define CFG_MAX_I2C_BUS 2 +#define CFG_I2C_INIT_BOARD 1
Dear Heiko Schocher,
Which part of the README are you referring to?
Are you talking about doc/I2C_Edge_Conditions?
Hm... quoting doc/I2C_Edge_Conditions:
... Note that this is NOT necessary when using the bit-banging I2C driver (common/soft_i2c.c) as this already includes the I2C bus reset sequence.
Can you please explain what your patch is doing differently, and why it is needed?
documented; board specific deblocking
mechanism
board.
boards.
Keymile
code
high
There are many typos in this commit message. Also, the patch does not apply cleanly:
Apply? [y]es/[n]o/[e]dit/[v]iew patch/[a]ccept all y Applying mgcoge, mgsuvd: add I2C deblocking mechanism. .dotest/patch:140: trailing whitespace. *(unsigned short *)(I2C_BASE_DIR) &= ~SCL_CONF; .dotest/patch:143: trailing whitespace.
.dotest/patch:174: trailing whitespace.
error: board/keymile/mgcoge/Makefile: does not exist in index fatal: sha1 information is lacking or useless (include/configs/mgcoge.h). Repository lacks necessary blobs to fall back on 3-way merge. Cannot fall back to three-way merge. Patch failed at 0005.
Please fix typos, rebase and resubmit.
Heiko Schocher
