[U-Boot] the mips cache code question ?
Dear All:
Recently , i have build a embedded environment with Uboot . And My Chip is adm5120 , mips4kc code.
In the file .\cpu\mips\cache.s , i found some code confounded .
line 152 to line 156 :
cache_op Index_Store_Tag_I t0 PTR_ADDU t0, a2 bne t0, t1, 1b /* fill once, so data field parity is correct */ PTR_LI t0, INDEX_BASE
the code 'PTR_LI t0, INDEX_BASE' is in the branch delay slot , so this instruction will be implement every branch cycle.
Is it right ? Then the cache operation logic seems wrong .
From a quick glance I think the code is OK. I would suggest
disassembling the executable code to make sure of what the assembler did.
The answer depends on what mode the assembler is in. For MIPS assembler there is a 'reorder mode' where the assembler will fill in the branch delay slot for you or place a nop if necessary, and the next instruction in the source is really the one after the delay slot, or there is noreorder mode where the next instruction after the branch is what is put in the delay slot.
Normally the assembler runs in reorder mode, and you use a '.set reorder' and '.set noreorder' to switch between them. Noreorder mode is commonly used in code that requires precise control of where instructions get executed (cache & tlb handling)
Sorry for the two successive posts, I looked at the disassembly...
On Wed, Dec 1, 2010 at 1:26 AM, 奥刘 happyoach@gmail.com wrote:
Dear All:
The assembler does insert a 'NOP' instruction in the branch delay slot, even with ".set noreorder", so this is OK:
810005a8: bd140000 cache 0x14,0(t0) 810005ac: 01064021 addu t0,t0,a2 810005b0: 1509fffd bne t0,t1,810005a8 <mips_init_icache+0x28> 810005b4: 00000000 nop
-- Scott
Andrew Dyer
Scott Nicholas
奥刘
