[PATCH 1/1] sandbox: fix sandbox_reset()
state_uninit() and dm_uninit() are mutually exclusive:
state_uninit() prints via drivers. So it cannot be executed after dm_uninit().
dm_uninit() requires memory. So it cannot be executed after state_uninit() which releases all memory.
Just skip dm_uninit() when resetting the sandbox. We will wake up in a new process and allocate new memory. So this cleanup is not required. We don't do it in sandbox_exit() either.
This avoids a segmentation error when efi_reset_system_boottime() is invoked by a UEFI application.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- arch/sandbox/cpu/start.c | 3 --- 1 file changed, 3 deletions(-)
diff --git a/arch/sandbox/cpu/start.c b/arch/sandbox/cpu/start.c index e87365e800..4ffd97ccbc 100644 --- a/arch/sandbox/cpu/start.c +++ b/arch/sandbox/cpu/start.c @@ -425,9 +425,6 @@ void sandbox_reset(void) if (state_uninit()) os_exit(2);
- if (dm_uninit()) - os_exit(2); - /* Restart U-Boot */ os_relaunch(os_argv); } -- 2.30.2
Hi Heinrich,
Thanks for fixing this!
Before, I was hitting the following segfault with the sandbox under qemu arm64 when running the UEFI SCT:
Boot services test: ExitBootServices_Conf
Iterations: 1/1
System will cold reset after 2 second and test will be resumed after reboot.resetting ... Writing sandbox state qemu: uncaught target signal 11 (Segmentation fault) - core dumped
With your patch I do not hit this segfault anymore.
FWIW, feel free to add (or not):
Tested-by: Vincent Stehlé vincent.stehle@arm.com
Best regards, Vincent.
- if (dm_uninit())
os_exit(2);
2.30.2
Applied to u-boot-dm/next, thanks!
Vincent Stehlé
