[PATCH 0/3] fpga: Convert some options to Kconfig
Hei hei,
this is some fallout from migrating some downstream boards with Altera Cyclone FPGAs to recent U-Boot v2022.04. Not entirely sure about that FPGA_COUNT variable in patch 3, which seems to be used in source code in board/astro/mcf5373l/fpga.c only. Maybe that variable can be dropped entirely?
Greets Alex
Cc: Wolfgang Wegner w.wegner@astro-kom.de Cc: Patrick Bruenn p.bruenn@beckhoff.com Cc: Dinh Nguyen dinguyen@kernel.org Cc: Chin-Liang See clsee@altera.com Cc: Marek Vasut marex@denx.de Cc: Dalon Westergreen dwesterg@gmail.com Cc: Humberto Naves hsnaves@gmail.com Cc: Anatolij Gustschin agust@denx.de Cc: Pavel Machek pavel@denx.de Cc: Wolfgang Grandegger wg@aries-embedded.de Cc: Stefan Roese sr@denx.de Cc: Michal Simek michal.simek@amd.com
Alexander Dahl (3): fpga: Convert SYS_FPGA_CHECK_CTRLC to Kconfig fpga: Convert SYS_FPGA_PROG_FEEDBACK to Kconfig fpga: Convert FPGA_COUNT to Kconfig
README | 11 ----------- configs/astro_mcf5373l_defconfig | 2 ++ configs/mx53cx9020_defconfig | 1 + configs/socfpga_arria10_defconfig | 1 + configs/socfpga_arria5_defconfig | 1 + configs/socfpga_cyclone5_defconfig | 1 + configs/socfpga_dbm_soc1_defconfig | 1 + configs/socfpga_de0_nano_soc_defconfig | 1 + configs/socfpga_de10_nano_defconfig | 1 + configs/socfpga_de10_standard_defconfig | 1 + configs/socfpga_de1_soc_defconfig | 1 + configs/socfpga_is1_defconfig | 1 + configs/socfpga_mcvevk_defconfig | 1 + configs/socfpga_sockit_defconfig | 1 + configs/socfpga_socrates_defconfig | 1 + configs/socfpga_sr1500_defconfig | 1 + configs/socfpga_vining_fpga_defconfig | 1 + drivers/fpga/Kconfig | 16 ++++++++++++++++ include/configs/astro_mcf5373l.h | 2 -- include/configs/mx53cx9020.h | 2 -- include/configs/socfpga_common.h | 7 ------- scripts/config_whitelist.txt | 2 -- 22 files changed, 33 insertions(+), 24 deletions(-)
base-commit: 568a226f87655fd5339514f66413c2ad72f65d6f
After commit 8cca60a2cbf2 ("Kconfig: Remove some symbols from the whitelist") downstream builds failed for boards setting this in include/configs/…
Two FPGA drivers consider this definition.
Signed-off-by: Alexander Dahl ada@thorsis.com --- README | 3 --- drivers/fpga/Kconfig | 4 ++++ 2 files changed, 4 insertions(+), 3 deletions(-)
diff --git a/README b/README index b7ab6e5070..3bf7c9dd4e 100644 --- a/README +++ b/README @@ -1418,9 +1418,6 @@ The following options need to be configured: If defined, a function that provides delays in the FPGA configuration driver.
- CONFIG_SYS_FPGA_CHECK_CTRLC - Allow Control-C to interrupt FPGA configuration - CONFIG_SYS_FPGA_CHECK_ERROR
Check for configuration errors during FPGA bitfile diff --git a/drivers/fpga/Kconfig b/drivers/fpga/Kconfig index dc0b3dd31b..ac5641c75a 100644 --- a/drivers/fpga/Kconfig +++ b/drivers/fpga/Kconfig @@ -85,4 +85,8 @@ config FPGA_ZYNQPL Enable FPGA driver for loading bitstream in BIT and BIN format on Xilinx Zynq devices.
+config SYS_FPGA_CHECK_CTRLC + bool "Allow Control-C to interrupt FPGA configuration" + depends on FPGA + endmenu
Signed-off-by: Alexander Dahl ada@thorsis.com --- README | 4 ---- configs/astro_mcf5373l_defconfig | 1 + drivers/fpga/Kconfig | 6 ++++++ include/configs/astro_mcf5373l.h | 1 - scripts/config_whitelist.txt | 1 - 5 files changed, 7 insertions(+), 6 deletions(-)
diff --git a/README b/README index 3bf7c9dd4e..63c8bd5019 100644 --- a/README +++ b/README @@ -1402,10 +1402,6 @@ The following options need to be configured:
Specify the number of FPGA devices to support.
- CONFIG_SYS_FPGA_PROG_FEEDBACK - - Enable printing of hash marks during FPGA configuration. - CONFIG_SYS_FPGA_CHECK_BUSY
Enable checks on FPGA configuration interface busy diff --git a/configs/astro_mcf5373l_defconfig b/configs/astro_mcf5373l_defconfig index 1eea56b5ef..fcdc51df91 100644 --- a/configs/astro_mcf5373l_defconfig +++ b/configs/astro_mcf5373l_defconfig @@ -31,6 +31,7 @@ CONFIG_FPGA_ALTERA=y CONFIG_FPGA_CYCLON2=y CONFIG_FPGA_XILINX=y CONFIG_FPGA_SPARTAN3=y +CONFIG_SYS_FPGA_PROG_FEEDBACK=y CONFIG_SYS_I2C_LEGACY=y CONFIG_SYS_I2C_FSL=y CONFIG_SYS_FSL_I2C_OFFSET=0x58000 diff --git a/drivers/fpga/Kconfig b/drivers/fpga/Kconfig index ac5641c75a..e2e8c13b22 100644 --- a/drivers/fpga/Kconfig +++ b/drivers/fpga/Kconfig @@ -89,4 +89,10 @@ config SYS_FPGA_CHECK_CTRLC bool "Allow Control-C to interrupt FPGA configuration" depends on FPGA
+config SYS_FPGA_PROG_FEEDBACK + bool "Progress output during FPGA configuration" + depends on FPGA + help + Enable printing of hash marks during FPGA configuration. + endmenu diff --git a/include/configs/astro_mcf5373l.h b/include/configs/astro_mcf5373l.h index 9d1203f397..4cae942c55 100644 --- a/include/configs/astro_mcf5373l.h +++ b/include/configs/astro_mcf5373l.h @@ -134,7 +134,6 @@ */
#define CONFIG_FPGA_COUNT 1 -#define CONFIG_SYS_FPGA_PROG_FEEDBACK #define CONFIG_SYS_FPGA_WAIT 1000
/* End of user parameters to be customized */ diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index cecdda6781..d7c412efae 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -939,7 +939,6 @@ CONFIG_SYS_FPGA_FTIM0 CONFIG_SYS_FPGA_FTIM1 CONFIG_SYS_FPGA_FTIM2 CONFIG_SYS_FPGA_FTIM3 -CONFIG_SYS_FPGA_PROG_FEEDBACK CONFIG_SYS_FPGA_SIZE CONFIG_SYS_FPGA_WAIT CONFIG_SYS_FSL_BMAN_ADDR
Besides the two obvious defconfigs, the option was set for all defconfigs where corresponding header file includes include/configs/socfpga_common.h
Signed-off-by: Alexander Dahl ada@thorsis.com --- README | 4 ---- configs/astro_mcf5373l_defconfig | 1 + configs/mx53cx9020_defconfig | 1 + configs/socfpga_arria10_defconfig | 1 + configs/socfpga_arria5_defconfig | 1 + configs/socfpga_cyclone5_defconfig | 1 + configs/socfpga_dbm_soc1_defconfig | 1 + configs/socfpga_de0_nano_soc_defconfig | 1 + configs/socfpga_de10_nano_defconfig | 1 + configs/socfpga_de10_standard_defconfig | 1 + configs/socfpga_de1_soc_defconfig | 1 + configs/socfpga_is1_defconfig | 1 + configs/socfpga_mcvevk_defconfig | 1 + configs/socfpga_sockit_defconfig | 1 + configs/socfpga_socrates_defconfig | 1 + configs/socfpga_sr1500_defconfig | 1 + configs/socfpga_vining_fpga_defconfig | 1 + drivers/fpga/Kconfig | 6 ++++++ include/configs/astro_mcf5373l.h | 1 - include/configs/mx53cx9020.h | 2 -- include/configs/socfpga_common.h | 7 ------- scripts/config_whitelist.txt | 1 - 22 files changed, 22 insertions(+), 15 deletions(-)
diff --git a/README b/README index 63c8bd5019..b2d2d9dc3c 100644 --- a/README +++ b/README @@ -1398,10 +1398,6 @@ The following options need to be configured: Enables support for FPGA family. (SPARTAN2, SPARTAN3, VIRTEX2, CYCLONE2, ACEX1K, ACEX)
- CONFIG_FPGA_COUNT - - Specify the number of FPGA devices to support. - CONFIG_SYS_FPGA_CHECK_BUSY
Enable checks on FPGA configuration interface busy diff --git a/configs/astro_mcf5373l_defconfig b/configs/astro_mcf5373l_defconfig index fcdc51df91..3ea4304ba7 100644 --- a/configs/astro_mcf5373l_defconfig +++ b/configs/astro_mcf5373l_defconfig @@ -32,6 +32,7 @@ CONFIG_FPGA_CYCLON2=y CONFIG_FPGA_XILINX=y CONFIG_FPGA_SPARTAN3=y CONFIG_SYS_FPGA_PROG_FEEDBACK=y +CONFIG_FPGA_COUNT=1 CONFIG_SYS_I2C_LEGACY=y CONFIG_SYS_I2C_FSL=y CONFIG_SYS_FSL_I2C_OFFSET=0x58000 diff --git a/configs/mx53cx9020_defconfig b/configs/mx53cx9020_defconfig index f79595db68..11f2e3206b 100644 --- a/configs/mx53cx9020_defconfig +++ b/configs/mx53cx9020_defconfig @@ -23,6 +23,7 @@ CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ARP_TIMEOUT=200 CONFIG_FPGA_ALTERA=y CONFIG_FPGA_CYCLON2=y +CONFIG_FPGA_COUNT=1 CONFIG_FSL_ESDHC_IMX=y CONFIG_MTD=y CONFIG_PHYLIB=y diff --git a/configs/socfpga_arria10_defconfig b/configs/socfpga_arria10_defconfig index 1be9a2df08..64dc562a0a 100644 --- a/configs/socfpga_arria10_defconfig +++ b/configs/socfpga_arria10_defconfig @@ -40,6 +40,7 @@ CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_VERSION_VARIABLE=y CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_FPGA_COUNT=1 CONFIG_DWAPB_GPIO=y CONFIG_FS_LOADER=y CONFIG_SPL_FS_LOADER=y diff --git a/configs/socfpga_arria5_defconfig b/configs/socfpga_arria5_defconfig index dafeafff3e..106a403cc9 100644 --- a/configs/socfpga_arria5_defconfig +++ b/configs/socfpga_arria5_defconfig @@ -43,6 +43,7 @@ CONFIG_VERSION_VARIABLE=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_DFU_MMC=y CONFIG_SYS_DFU_DATA_BUF_SIZE=0x1000000 +CONFIG_FPGA_COUNT=1 CONFIG_DWAPB_GPIO=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_DW=y diff --git a/configs/socfpga_cyclone5_defconfig b/configs/socfpga_cyclone5_defconfig index b09672d8a2..1211354d0b 100644 --- a/configs/socfpga_cyclone5_defconfig +++ b/configs/socfpga_cyclone5_defconfig @@ -43,6 +43,7 @@ CONFIG_VERSION_VARIABLE=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_DFU_MMC=y CONFIG_SYS_DFU_DATA_BUF_SIZE=0x1000000 +CONFIG_FPGA_COUNT=1 CONFIG_DWAPB_GPIO=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_DW=y diff --git a/configs/socfpga_dbm_soc1_defconfig b/configs/socfpga_dbm_soc1_defconfig index a8ef2e934a..ca22c77790 100644 --- a/configs/socfpga_dbm_soc1_defconfig +++ b/configs/socfpga_dbm_soc1_defconfig @@ -52,6 +52,7 @@ CONFIG_BOOTFILE="fitImage" CONFIG_VERSION_VARIABLE=y CONFIG_DFU_MMC=y CONFIG_SYS_DFU_DATA_BUF_SIZE=0x1000000 +CONFIG_FPGA_COUNT=1 CONFIG_DWAPB_GPIO=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_DW=y diff --git a/configs/socfpga_de0_nano_soc_defconfig b/configs/socfpga_de0_nano_soc_defconfig index 2e5bd80d2e..dbf758097a 100644 --- a/configs/socfpga_de0_nano_soc_defconfig +++ b/configs/socfpga_de0_nano_soc_defconfig @@ -43,6 +43,7 @@ CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_VERSION_VARIABLE=y CONFIG_DFU_MMC=y CONFIG_SYS_DFU_DATA_BUF_SIZE=0x1000000 +CONFIG_FPGA_COUNT=1 CONFIG_DWAPB_GPIO=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_DW=y diff --git a/configs/socfpga_de10_nano_defconfig b/configs/socfpga_de10_nano_defconfig index 95b4ef638e..ef78cb9169 100644 --- a/configs/socfpga_de10_nano_defconfig +++ b/configs/socfpga_de10_nano_defconfig @@ -40,6 +40,7 @@ CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_VERSION_VARIABLE=y CONFIG_DFU_MMC=y CONFIG_SYS_DFU_DATA_BUF_SIZE=0x1000000 +CONFIG_FPGA_COUNT=1 CONFIG_DWAPB_GPIO=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_DW=y diff --git a/configs/socfpga_de10_standard_defconfig b/configs/socfpga_de10_standard_defconfig index 91bd49840d..c73e307fe3 100644 --- a/configs/socfpga_de10_standard_defconfig +++ b/configs/socfpga_de10_standard_defconfig @@ -40,6 +40,7 @@ CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_VERSION_VARIABLE=y CONFIG_DFU_MMC=y CONFIG_SYS_DFU_DATA_BUF_SIZE=0x1000000 +CONFIG_FPGA_COUNT=1 CONFIG_DWAPB_GPIO=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_DW=y diff --git a/configs/socfpga_de1_soc_defconfig b/configs/socfpga_de1_soc_defconfig index 75e16be42a..bacbe60a91 100644 --- a/configs/socfpga_de1_soc_defconfig +++ b/configs/socfpga_de1_soc_defconfig @@ -37,6 +37,7 @@ CONFIG_MTDIDS_DEFAULT="nor0=ff705000.spi.0" CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_VERSION_VARIABLE=y +CONFIG_FPGA_COUNT=1 CONFIG_DWAPB_GPIO=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_DW=y diff --git a/configs/socfpga_is1_defconfig b/configs/socfpga_is1_defconfig index 53e9a7296c..c2c15bd97b 100644 --- a/configs/socfpga_is1_defconfig +++ b/configs/socfpga_is1_defconfig @@ -45,6 +45,7 @@ CONFIG_VERSION_VARIABLE=y CONFIG_ARP_TIMEOUT=500 CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_BOOTCOUNT_LIMIT=y +CONFIG_FPGA_COUNT=1 CONFIG_DWAPB_GPIO=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_DW=y diff --git a/configs/socfpga_mcvevk_defconfig b/configs/socfpga_mcvevk_defconfig index 07ca4bf954..9ab548e6ff 100644 --- a/configs/socfpga_mcvevk_defconfig +++ b/configs/socfpga_mcvevk_defconfig @@ -43,6 +43,7 @@ CONFIG_BOOTFILE="fitImage" CONFIG_VERSION_VARIABLE=y CONFIG_DFU_MMC=y CONFIG_SYS_DFU_DATA_BUF_SIZE=0x1000000 +CONFIG_FPGA_COUNT=1 CONFIG_DWAPB_GPIO=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_DW=y diff --git a/configs/socfpga_sockit_defconfig b/configs/socfpga_sockit_defconfig index e245288b92..fc50adcf81 100644 --- a/configs/socfpga_sockit_defconfig +++ b/configs/socfpga_sockit_defconfig @@ -43,6 +43,7 @@ CONFIG_VERSION_VARIABLE=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_DFU_MMC=y CONFIG_SYS_DFU_DATA_BUF_SIZE=0x1000000 +CONFIG_FPGA_COUNT=1 CONFIG_DWAPB_GPIO=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_DW=y diff --git a/configs/socfpga_socrates_defconfig b/configs/socfpga_socrates_defconfig index 7044186469..c16cb59ee4 100644 --- a/configs/socfpga_socrates_defconfig +++ b/configs/socfpga_socrates_defconfig @@ -43,6 +43,7 @@ CONFIG_VERSION_VARIABLE=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_DFU_MMC=y CONFIG_SYS_DFU_DATA_BUF_SIZE=0x1000000 +CONFIG_FPGA_COUNT=1 CONFIG_DWAPB_GPIO=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_DW=y diff --git a/configs/socfpga_sr1500_defconfig b/configs/socfpga_sr1500_defconfig index b0be033953..3d6d264bd5 100644 --- a/configs/socfpga_sr1500_defconfig +++ b/configs/socfpga_sr1500_defconfig @@ -49,6 +49,7 @@ CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_VERSION_VARIABLE=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_BOOTCOUNT_LIMIT=y +CONFIG_FPGA_COUNT=1 CONFIG_DWAPB_GPIO=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_DW=y diff --git a/configs/socfpga_vining_fpga_defconfig b/configs/socfpga_vining_fpga_defconfig index 331975ad30..dac0f044eb 100644 --- a/configs/socfpga_vining_fpga_defconfig +++ b/configs/socfpga_vining_fpga_defconfig @@ -62,6 +62,7 @@ CONFIG_DFU_MMC=y CONFIG_DFU_RAM=y CONFIG_DFU_SF=y CONFIG_SYS_DFU_DATA_BUF_SIZE=0x1000000 +CONFIG_FPGA_COUNT=1 CONFIG_DWAPB_GPIO=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_DW=y diff --git a/drivers/fpga/Kconfig b/drivers/fpga/Kconfig index e2e8c13b22..d89392d9a4 100644 --- a/drivers/fpga/Kconfig +++ b/drivers/fpga/Kconfig @@ -95,4 +95,10 @@ config SYS_FPGA_PROG_FEEDBACK help Enable printing of hash marks during FPGA configuration.
+config FPGA_COUNT + int "Number of FPGA devices to support" + depends on FPGA + help + Specify the number of FPGA devices to support. + endmenu diff --git a/include/configs/astro_mcf5373l.h b/include/configs/astro_mcf5373l.h index 4cae942c55..e8065e4a36 100644 --- a/include/configs/astro_mcf5373l.h +++ b/include/configs/astro_mcf5373l.h @@ -133,7 +133,6 @@ * it needs non-blocking CFI routines. */
-#define CONFIG_FPGA_COUNT 1 #define CONFIG_SYS_FPGA_WAIT 1000
/* End of user parameters to be customized */ diff --git a/include/configs/mx53cx9020.h b/include/configs/mx53cx9020.h index fafc5f1adc..3993a35a09 100644 --- a/include/configs/mx53cx9020.h +++ b/include/configs/mx53cx9020.h @@ -16,8 +16,6 @@
#define CONFIG_MXC_UART_BASE UART2_BASE
-#define CONFIG_FPGA_COUNT 1 - /* MMC Configs */ #define CONFIG_SYS_FSL_ESDHC_ADDR 0 #define CONFIG_SYS_FSL_ESDHC_NUM 2 diff --git a/include/configs/socfpga_common.h b/include/configs/socfpga_common.h index 5ecd1e6399..4b8d733cf7 100644 --- a/include/configs/socfpga_common.h +++ b/include/configs/socfpga_common.h @@ -78,13 +78,6 @@ #define CONFIG_DW_ALTDESCRIPTOR #endif
-/* - * FPGA Driver - */ -#ifdef CONFIG_CMD_FPGA -#define CONFIG_FPGA_COUNT 1 -#endif - /* * L4 OSC1 Timer 0 */ diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index d7c412efae..37963c2923 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -96,7 +96,6 @@ CONFIG_FLASH_SHOW_PROGRESS CONFIG_FLASH_SPANSION_S29WS_N CONFIG_FLASH_VERIFY CONFIG_FM_PLAT_CLK_DIV -CONFIG_FPGA_COUNT CONFIG_FPGA_STRATIX_V CONFIG_FSL_CADMUS CONFIG_FSL_CORENET
Hello,
This option has been addressed with commit 60d45642fe0673514aced37e6cc95d4f0fe02a19 ("fpga: Remove CONFIG_FPGA_COUNT") by Tom. I guess I should rebase the series and resend?
Greets Alex
CONFIG_FPGA_COUNT
+config FPGA_COUNT
- int "Number of FPGA devices to support"
- depends on FPGA
- help
- it needs non-blocking CFI routines.
- FPGA Driver
- L4 OSC1 Timer 0
*/ diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index d7c412efae..37963c2923 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -96,7 +96,6 @@ CONFIG_FLASH_SHOW_PROGRESS CONFIG_FLASH_SPANSION_S29WS_N CONFIG_FLASH_VERIFY CONFIG_FM_PLAT_CLK_DIV -CONFIG_FPGA_COUNT CONFIG_FPGA_STRATIX_V CONFIG_FSL_CADMUS CONFIG_FSL_CORENET -- 2.30.2
Alexander Dahl
Alexander Dahl
