[U-Boot] [PATCH v3] sunxi: On newer SoCs use words 1-3 instead of just word 3 from the SID
It seems that bytes 13-14 of the SID / bytes 1-2 from word 3 of the SID are always 0 on H3 making it a poor candidate to use as source for the serialnr / mac-address, and the other non constant words (1 and 2) also have quite a few bits which are the same for some boards,
This commits switches to using the crc32 of words 1 - 3 to get a more unique value for the mac-address / serialnr.
Cc: Chen-Yu Tsai wens@csie.org Cc: Corentin LABBE clabbe.montjoie@gmail.com Cc: Amit Singh Tomar amittomer25@gmail.com Signed-off-by: Hans de Goede hdegoede@redhat.com --- Changes in v3: -Use crc32 instead of ex-or-ing the bytes together -Use new algorithm on all newer SoCs -Only check for sid[0] != 0 to capture non initialized sid-s. Changes in v2: -ex-or all 3 words together instead of picking a different word --- board/sunxi/board.c | 20 +++++++++++++++++++- 1 file changed, 19 insertions(+), 1 deletion(-)
diff --git a/board/sunxi/board.c b/board/sunxi/board.c index ef3fe26..209fb1c 100644 --- a/board/sunxi/board.c +++ b/board/sunxi/board.c @@ -27,6 +27,7 @@ #endif #include <asm/gpio.h> #include <asm/io.h> +#include <crc.h> #include <environment.h> #include <libfdt.h> #include <nand.h> @@ -622,7 +623,24 @@ static void setup_environment(const void *fdt) int i, ret;
ret = sunxi_get_sid(sid); - if (ret == 0 && sid[0] != 0 && sid[3] != 0) { + if (ret == 0 && sid[0] != 0) { + /* + * The single words 1 - 3 of the SID have quite a few bits + * which are the same on many models, so we take a crc32 + * of all 3 words, to get a more unique value. + * + * Note we only do this on newer SoCs as we cannot change + * the algorithm on older SoCs since those have been using + * fixed mac-addresses based on only using word 3 for a + * long time and changing a fixed mac-address with an + * u-boot update is not good. + */ +#if !defined(CONFIG_MACH_SUN4I) && !defined(CONFIG_MACH_SUN5I) && \ + !defined(CONFIG_MACH_SUN6I) && !defined(CONFIG_MACH_SUN7I) && \ + !defined(CONFIG_MACH_SUN8I_A23) && !defined(CONFIG_MACH_SUN8I_A33) + sid[3] = crc32(0, (unsigned char *)&sid[1], 12); +#endif + /* Ensure the NIC specific bytes of the mac are not all 0 */ if ((sid[3] & 0xffffff) == 0) sid[3] |= 0x800000;
Acked-by: Ian Campbell ijc@hellion.org.uk
Two minor thoughts:
At some point it might be nice to switch from using sid[3] as the temporary variable to contain the csum since it is no longer the 3rd element of the sid in any meaningful way. If you decide to do so for a v4, then please do keep my ack from above.
Likewise if you decide to express the big chain of ifndef's via Kconfig instead, you can keep the ack.
Ian.
Hans de Goede
Ian Campbell
