[PATCH v2 0/4] ARM: zynq: Switch to CFI DM driver
this series is switching Zynq to DM based cfi driver. On regular u-boot this is described via SMCC but for cse it is enough to place just node to DT.
Thanks, Michal
Changes in v2: - Add missing zynq cse nor conversion
Michal Simek (4): nand: raw: Do not free xnand structure nand: raw: zynq: Do not try to probe driver if nand flash is disabled ARM: zynq: Do not report NOR flash detection failure ARM: zynq: Enable DM for CFI NOR flash
arch/arm/dts/zynq-cse-nor.dts | 14 ++++++++++++++ configs/xilinx_zynq_virt_defconfig | 1 + configs/zynq_cse_nor_defconfig | 3 +++ drivers/mtd/nand/raw/zynq_nand.c | 25 ++++++++++++++----------- include/configs/zynq-common.h | 3 +-- 5 files changed, 33 insertions(+), 13 deletions(-)
xnand structure is private data structure and it is handled by core and probe shouldn't touch it.
Changes in v2: None
drivers/mtd/nand/raw/zynq_nand.c | 20 +++++++++----------- 1 file changed, 9 insertions(+), 11 deletions(-)
diff --git a/drivers/mtd/nand/raw/zynq_nand.c b/drivers/mtd/nand/raw/zynq_nand.c index 28db4153f5e0..703914969289 100644 --- a/drivers/mtd/nand/raw/zynq_nand.c +++ b/drivers/mtd/nand/raw/zynq_nand.c @@ -1081,18 +1081,18 @@ static int zynq_nand_probe(struct udevice *dev) u8 set_feature[4] = {ONDIE_ECC_FEATURE_ENABLE, 0x00, 0x00, 0x00}; unsigned long ecc_cfg; int ondie_ecc_enabled = 0; - int err = -1; int is_16bit_bw;
smc->reg = (struct zynq_nand_smc_regs *)dev_read_addr(dev); of_nand = dev_read_subnode(dev, "flash@e1000000"); if (!ofnode_valid(of_nand)) { printf("Failed to find nand node in dt\n"); - goto fail; + return -ENODEV; } + if (ofnode_read_resource(of_nand, 0, &res)) { printf("Failed to get nand resource\n"); - goto fail; + return -ENODEV; }
xnand->nand_base = (void __iomem *)res.start; @@ -1119,7 +1119,7 @@ static int zynq_nand_probe(struct udevice *dev) if (is_16bit_bw == NAND_BW_UNKNOWN) { printf("%s: Unable detect NAND based on MIO settings\n", __func__); - goto fail; + return -EINVAL; }
if (is_16bit_bw == NAND_BW_16BIT) @@ -1130,13 +1130,13 @@ static int zynq_nand_probe(struct udevice *dev) /* Initialize the NAND flash interface on NAND controller */ if (zynq_nand_init_nand_flash(mtd, nand_chip->options) < 0) { printf("%s: nand flash init failed\n", __func__); - goto fail; + return -EINVAL; }
/* first scan to find the device and get the page size */ if (nand_scan_ident(mtd, 1, NULL)) { printf("%s: nand_scan_ident failed\n", __func__); - goto fail; + return -EINVAL; } /* Send the command for reading device ID */ nand_chip->cmdfunc(mtd, NAND_CMD_RESET, -1, -1); @@ -1261,14 +1261,12 @@ static int zynq_nand_probe(struct udevice *dev) /* Second phase scan */ if (nand_scan_tail(mtd)) { printf("%s: nand_scan_tail failed\n", __func__); - goto fail; + return -EINVAL; } if (nand_register(0, mtd)) - goto fail; + return -EINVAL; + return 0; -fail: - free(xnand); - return err; }
static const struct udevice_id zynq_nand_dt_ids[] = {
Reviewed-by: Jagan Teki jagan@amarulasolutions.com
There is no reason to continue when DT status property indicates that NAND flash is disabled. But that means that NOR flash should be present that's why try it find it out.
Changes in v2: None
drivers/mtd/nand/raw/zynq_nand.c | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/drivers/mtd/nand/raw/zynq_nand.c b/drivers/mtd/nand/raw/zynq_nand.c index 703914969289..0aea83dac0e6 100644 --- a/drivers/mtd/nand/raw/zynq_nand.c +++ b/drivers/mtd/nand/raw/zynq_nand.c @@ -1090,6 +1090,11 @@ static int zynq_nand_probe(struct udevice *dev) return -ENODEV; }
+ if (!ofnode_is_available(of_nand)) { + debug("Nand node in dt disabled\n"); + return dm_scan_fdt_dev(dev); + } + if (ofnode_read_resource(of_nand, 0, &res)) { printf("Failed to get nand resource\n"); return -ENODEV;
With multi defconfig targeting several board configurations bug report like below is so verbose. Flash: ## Unknown flash on Bank 1 - Size = 0x00000000 = 0 MB 0 Bytes
Do not report that message and simply say "Flash: 0 Bytes" because most of Zynq boards are using different type of flashes than NOR.
Changes in v2: None
include/configs/zynq-common.h | 1 + 1 file changed, 1 insertion(+)
diff --git a/include/configs/zynq-common.h b/include/configs/zynq-common.h index b1cef4d4695f..33fac35f6e32 100644 --- a/include/configs/zynq-common.h +++ b/include/configs/zynq-common.h @@ -51,6 +51,7 @@ # define CONFIG_SYS_FLASH_WRITE_TOUT 5000 # define CONFIG_FLASH_SHOW_PROGRESS 10 # undef CONFIG_SYS_FLASH_EMPTY_INFO +# define CONFIG_SYS_FLASH_QUIET_TEST #endif
#ifdef CONFIG_NAND_ZYNQ
With multi defconfig NOR flash information about NOR should be taken from DT that's why there is no reason to specify address and sizes via fixed config.
arch/arm/dts/zynq-cse-nor.dts | 14 ++++++++++++++ configs/xilinx_zynq_virt_defconfig | 1 + configs/zynq_cse_nor_defconfig | 3 +++ include/configs/zynq-common.h | 2 -- 4 files changed, 18 insertions(+), 2 deletions(-)
diff --git a/arch/arm/dts/zynq-cse-nor.dts b/arch/arm/dts/zynq-cse-nor.dts index 4030851eb36d..197fbd717aae 100644 --- a/arch/arm/dts/zynq-cse-nor.dts +++ b/arch/arm/dts/zynq-cse-nor.dts @@ -71,6 +71,20 @@ reg = <0x100 0x100>; }; }; + + /* + * This is partially hack because it is normally subnode of smcc + * but for mini U-Boot there is no reason to enable SMCC driver + * which does almost nothing in NOR flash configuration that's + * why place cfi-flash directly here. + */ + flash@e2000000 { + u-boot,dm-pre-reloc; + compatible = "cfi-flash"; + reg = <0xe2000000 0x2000000>; + #address-cells = <1>; + #size-cells = <1>; + }; }; };
diff --git a/configs/xilinx_zynq_virt_defconfig b/configs/xilinx_zynq_virt_defconfig index 2e9f3a0f7508..08b43de103a1 100644 --- a/configs/xilinx_zynq_virt_defconfig +++ b/configs/xilinx_zynq_virt_defconfig @@ -61,6 +61,7 @@ CONFIG_MMC_SDHCI_ZYNQ=y CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y +CONFIG_CFI_FLASH=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y diff --git a/configs/zynq_cse_nor_defconfig b/configs/zynq_cse_nor_defconfig index e2b9454c15c8..3b4e2f93fa30 100644 --- a/configs/zynq_cse_nor_defconfig +++ b/configs/zynq_cse_nor_defconfig @@ -52,8 +52,11 @@ CONFIG_SYS_RELOC_GD_ENV_ADDR=y # CONFIG_DM_DEVICE_REMOVE is not set CONFIG_SPL_DM_SEQ_ALIAS=y # CONFIG_MMC is not set +CONFIG_MTD=y +CONFIG_DM_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y +CONFIG_CFI_FLASH=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y # CONFIG_EFI_LOADER is not set diff --git a/include/configs/zynq-common.h b/include/configs/zynq-common.h index 33fac35f6e32..1eaf65b0a2a1 100644 --- a/include/configs/zynq-common.h +++ b/include/configs/zynq-common.h @@ -43,8 +43,6 @@
/* NOR */ #ifdef CONFIG_MTD_NOR_FLASH -# define CONFIG_SYS_FLASH_BASE 0xE2000000 -# define CONFIG_SYS_FLASH_SIZE (16 * 1024 * 1024) # define CONFIG_SYS_MAX_FLASH_BANKS 1 # define CONFIG_SYS_MAX_FLASH_SECT 512 # define CONFIG_SYS_FLASH_ERASE_TOUT 1000
st 26. 2. 2020 v 11:38 odesÃlatel Michal Simek michal.simek@xilinx.com napsal:
Thanks, Michal
Changes in v2:
-- 2.25.1
Applied all. M
Jagan Teki
Michal Simek
Michal Simek
