[PATCH 0/2] Enable strict signature verification for FIT
FIT load checks the signature on loadable images, but just continues in the case of a failure. This is undesirable behavior because the boot process depends on the authenticity of every loadable part.
Add a check that verifies the FIT's configuration block, and fails if it's not present or the signature doesn't match.
Henry Beberman (1): spl: Add CONFIG_SPL_FIT_SIGNATURE_STRICT
Ricardo Salveti (1): cmd: Add CONFIG_FIT_SIGNATURE_STRICT
cmd/fpga.c | 14 ++++++++++++++ cmd/source.c | 14 ++++++++++++++ cmd/ximg.c | 14 ++++++++++++++ common/Kconfig.boot | 11 +++++++++++ common/spl/spl_fit.c | 21 ++++++++++++++++++++- 5 files changed, 73 insertions(+), 1 deletion(-)
SPL FIT load checks the signature on loadable images but just continues in the case of a failure. This is undesirable behavior because the boot process depends on the authenticity of each loadable part.
Adding CONFIG_SPL_FIT_SIGNATURE_STRICT to halt the platform when any image fails its signature check, including loadable parts.
SPL already supports image signature verification but had no mechanism to check that the FIT's configuration block was signed correctly.
Add a check near the start of spl_load_simple_fit that verifies the FIT's configuration block, and fails if it's not present or the signature doesn't match what's stored in the SPL DTB.
Signed-off-by: Henry Beberman hebeberm@microsoft.com Signed-off-by: Ricardo Salveti ricardo@foundries.io Co-developed-by: Oleksandr Suvorov oleksandr.suvorov@foundries.io Signed-off-by: Oleksandr Suvorov oleksandr.suvorov@foundries.io ---
common/Kconfig.boot | 7 +++++++ common/spl/spl_fit.c | 21 ++++++++++++++++++++- 2 files changed, 27 insertions(+), 1 deletion(-)
diff --git a/common/Kconfig.boot b/common/Kconfig.boot index 902a5b8fbea..6f95d009dfa 100644 --- a/common/Kconfig.boot +++ b/common/Kconfig.boot @@ -166,6 +166,13 @@ config SPL_FIT_SIGNATURE select SPL_IMAGE_SIGN_INFO select SPL_FIT_FULL_CHECK
+config SPL_FIT_SIGNATURE_STRICT + bool "Halt if loadables or firmware don't pass FIT signature verification" + select SPL_FIT_SIGNATURE + help + Strictly requires each loadable or firmware in a FIT image to be + passed verification. Halt if any loadable fails to be verified. + config SPL_LOAD_FIT bool "Enable SPL loading U-Boot as a FIT (basic fitImage features)" select SPL_FIT diff --git a/common/spl/spl_fit.c b/common/spl/spl_fit.c index f41abca0ccb..e7eaaa4cb9e 100644 --- a/common/spl/spl_fit.c +++ b/common/spl/spl_fit.c @@ -315,7 +315,12 @@ static int spl_load_fit_image(struct spl_load_info *info, ulong sector, printf("## Checking hash(es) for Image %s ... ", fit_get_name(fit, node, NULL)); if (!fit_image_verify_with_data(fit, node, src, length)) - return -EPERM; + if (CONFIG_IS_ENABLED(FIT_SIGNATURE_STRICT)) { + puts("Invalid FIT signature found in a required image.\n"); + hang(); + } else { + return -EPERM; + } puts("OK\n"); }
@@ -681,6 +686,20 @@ int spl_load_simple_fit(struct spl_image_info *spl_image, if (ret < 0) return ret;
+ if (CONFIG_IS_ENABLED(FIT_SIGNATURE_STRICT)) { + int cfg_noffset = fit_conf_get_node(fit, NULL); + + if (cfg_noffset >= 0) { + if (fit_config_verify(fit, cfg_noffset)) { + puts("Unable to verify the required FIT config.\n"); + hang(); + } + } else { + puts("SPL_FIT_SIGNATURE_STRICT needs a config node in FIT\n"); + hang(); + } + } + /* skip further processing if requested to enable load-only use cases */ if (spl_load_simple_fit_skip_processing()) return 0;
Add CONFIG_FIT_SIGNATURE_STRICT to require a valid FIT configuration signature for each command that is able to manipulate FIT images.
cmd/fpga.c | 14 ++++++++++++++ cmd/source.c | 14 ++++++++++++++ cmd/ximg.c | 14 ++++++++++++++ common/Kconfig.boot | 4 ++++ 4 files changed, 46 insertions(+)
diff --git a/cmd/fpga.c b/cmd/fpga.c index 3fdd0b35e80..16d329590fa 100644 --- a/cmd/fpga.c +++ b/cmd/fpga.c @@ -335,6 +335,20 @@ static int do_fpga_loadmk(struct cmd_tbl *cmdtp, int flag, int argc, return CMD_RET_FAILURE; }
+ if (CONFIG_IS_ENABLED(FIT_SIGNATURE_STRICT)) { + /* validate required fit config entry */ + noffset = fit_conf_get_node(fit_hdr, NULL); + if (noffset >= 0) { + if (fit_config_verify(fit_hdr, noffset)) { + puts("Cannot verify FIT config node\n"); + return CMD_RET_FAILURE; + } + } else { + puts("FIT_SIGNATURE_STRICT requires a config node\n"); + return CMD_RET_FAILURE; + } + } + /* get fpga component image node offset */ noffset = fit_image_get_node(fit_hdr, fit_uname); if (noffset < 0) { diff --git a/cmd/source.c b/cmd/source.c index 81e015b64ef..b08406dfcbf 100644 --- a/cmd/source.c +++ b/cmd/source.c @@ -112,6 +112,20 @@ int image_source_script(ulong addr, const char *fit_uname) return 1; }
+ if (CONFIG_IS_ENABLED(FIT_SIGNATURE_STRICT)) { + /* validate required fit config entry */ + noffset = fit_conf_get_node(fit_hdr, NULL); + if (noffset >= 0) { + if (fit_config_verify(fit_hdr, noffset)) { + puts("Cannot verify FIT config node\n"); + return 1; + } + } else { + puts("FIT_SIGNATURE_STRICT requires a config node\n"); + return 1; + } + } + if (!fit_uname) fit_uname = get_default_image(fit_hdr);
diff --git a/cmd/ximg.c b/cmd/ximg.c index 65ba41320a0..39fccd8179c 100644 --- a/cmd/ximg.c +++ b/cmd/ximg.c @@ -141,6 +141,20 @@ do_imgextract(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) return 1; }
+ if (CONFIG_IS_ENABLED(FIT_SIGNATURE_STRICT)) { + /* validate required fit config entry */ + noffset = fit_conf_get_node(fit_hdr, NULL); + if (noffset >= 0) { + if (fit_config_verify(fit_hdr, noffset)) { + puts("Cannot verify FIT config node\n"); + return 1; + } + } else { + puts("FIT_SIGNATURE_STRICT requires a config node\n"); + return 1; + } + } + /* get subimage node offset */ noffset = fit_image_get_node(fit_hdr, uname); if (noffset < 0) { diff --git a/common/Kconfig.boot b/common/Kconfig.boot index 6f95d009dfa..ca7d9a8d971 100644 --- a/common/Kconfig.boot +++ b/common/Kconfig.boot @@ -77,6 +77,10 @@ config FIT_SIGNATURE_MAX_SIZE device memory. Assure this size does not extend past expected storage space.
+config FIT_SIGNATURE_STRICT + bool "Requires a valid FIT configuration signature for every image" + select FIT_SIGNATURE + config FIT_RSASSA_PSS bool "Support rsassa-pss signature scheme of FIT image contents" depends on FIT_SIGNATURE
Hi Oleksandr,
On Thu, Sep 16, 2021 at 4:10 PM Oleksandr Suvorov oleksandr.suvorov@foundries.io wrote:
if (noffset >= 0) {
} else {
if (noffset >= 0) {
return 1;
} else {
return 1;
if (noffset >= 0) {
return 1;
} else {
return 1;
config FIT_RSASSA_PSS bool "Support rsassa-pss signature scheme of FIT image contents" depends on FIT_SIGNATURE -- 2.31.1
There is duplication of the same piece of code in 3 different files, maybe you could rework that and move to some common function?
Hi Igor,
On Thu, Sep 16, 2021 at 6:09 PM Igor Opaniuk igor.opaniuk@foundries.io wrote:
Hi Oleksandr,
if (noffset >= 0) {
} else {
if (noffset >= 0) {
return 1;
} else {
return 1;
if (noffset >= 0) {
return 1;
} else {
return 1;
Yeah, makes sense. I'm reworking this patch. Thanks!
-- Best regards - Freundliche Grüsse - Meilleures salutations
Igor Opaniuk Embedded Software Engineer T: +380 938364067 E: igor.opaniuk@foundries.io W: www.foundries.io
Hi Oleksandr
This sounds very similar to what FIT config verification already does, so I don't understand the motivation behind this patch.
This statement is incorrect. This is exactly what required = "conf"; in u-boot's devicetree is intended to do.
NAK
- bool "Halt if loadables or firmware don't pass FIT signature verification"
- select SPL_FIT_SIGNATURE
- help
- config SPL_LOAD_FIT bool "Enable SPL loading U-Boot as a FIT (basic fitImage features)" select SPL_FIT
return -EPERM;
hang();
hang() is rarely the appropriate thing to do. Once you get -EPERM you could choose to either a) drop to a lower privilege level b) enter some sort of recovery mode c) outright hang.
spl_load_fit_image() isn't the right place to decide (a) or (b), so by extension, it's the wrong place to decide (c).
} else {
return -EPERM;
puts("OK\n"); }}
- if (CONFIG_IS_ENABLED(FIT_SIGNATURE_STRICT)) {
hang();
} else {
hang();
- /* skip further processing if requested to enable load-only use cases */ if (spl_load_simple_fit_skip_processing()) return 0;
Alex G.
Igor Opaniuk
Oleksandr Suvorov
