[U-Boot] Please pull u-boot-dm
Hi Tom,
I picked up a different patch for the unicode handling.
Passing build here: https://travis-ci.org/sglass68/u-boot/builds/557041198
The following changes since commit ef8b7e045ec744dce385cac4b1438c9be6e2bbc8:
Merge https://gitlab.denx.de/u-boot/custodians/u-boot-i2c (2019-07-10 13:51:53 -0400)
git://git.denx.de/u-boot-dm.git tags/dm-pull-9jul19-take2
for you to fetch changes up to 7ea33579576d2bcd19df76bd8769e7ab3b4a169b:
trace: trace buffer may exceed 2GiB (2019-07-10 16:52:58 -0600)
---------------------------------------------------------------- - Sandbox improvements including .dts refactor - Minor tracing and PCI improvements - Various other minor fixes - Conversion of patman, dtoc and binman to support Python 3
---------------------------------------------------------------- Alex Marginean (4): pci: fixed dm_pci_map_bar comment drivers: pci: add map_bar support for Enhanced Allocation test: dm: Add a test for PCI Enhanced Allocation drivers: pci: add API to issue FLR on a PCI function if supported
Heinrich Schuchardt (5): trace: undefined reference to `trace_early_init' trace: conserve gd register trace: make call depth limit customizable trace: do not limit trace buffer to 2GiB trace: trace buffer may exceed 2GiB
Patrick Delaunay (3): test: check u-boot properties in SPL device tree fdt: Allow indicating a node is for U-Boot proper only dm: doc: add documentation for pre-reloc properties in SPL and TPL
Simon Glass (60): patman: Update cros_subprocess to use bytes patman: Convert print statements to Python 3 binman: Convert print statements to Python 3 binman: Don't show errors for failed tests binman: Remove use of Set() patman: Use items() instead of iteritems() binman: Use items() instead of iteritems() tools: binman: Open all binary files in binary mode tools: dtoc: Open all binary files in binary mode patman: Provide a way to get program output in binary mode binman: Use binary mode when compressing data binman: Drop an unused input file binman: Handle repeated bytes for Python 3 patman: Support use of stringIO in Python 3 patman: Move unicode helpers to tools patman: Sort series output for repeatabily patman: Avoid unicode type in settings unit tests patman: Adjust functional tests for Python 3 patman: Tidy up a few more unicode conversions patman: Don't require Python 2 dtoc: Adjust code for Python 3 dtoc: Sort platdata output from dtoc dtoc: Use GetBytes() to obtain repeating bytes dtoc: Move BytesToValue() out of the Prop class dtoc: Updates BytesToValue() for Python 3 dtoc: Use byte type instead of str in fdt dtoc: Convert the Fdt.Prop class to Python 3 dtoc: Convert the Fdt.Node class to Python 3 dtoc: Use binary mode for reading files dtoc: Test full 64-bit properties with FdtCellsToCpu() dtoc: Add a unit test for BytesToValue() dtoc: Update fdt_util for Python 3 dtoc: Update dtb_platdata to support Python 3 patman: Allow reading files in text mode binman: Avoid changing a dict during iteration binman: Convert to use bytes type binman: Update entry_test to support Python 3 patman: Update fmap code for Python 3 binman: Update 'text' entry for Python 3 binman: Fix up a format string in AssertInList() binman: Read map files as text binman: Document parallel tests binman: Update the README.entries file patman: Update cover-coverage tests for Python 3 Add a simple script to remove boards sandbox: Sync up sandbox64.dts with main DT sandbox: Create a common sandbox DT sandbox: Add an alias for SPI sandbox: Exit when SYSRESET_POWER_OFF is requested sandbox: Quit when hang() is called sandbox: spl: Lower priority of standard loader sandbox: Add a comment to board_init_f() sandbox: Allo sdl-config to be overridden sandbox: Add a memory {} node sandbox: Correct spi flash operation sandbox: Add documentation on how to run valgrind x86: Add a forward struct declaration in coreboot_tables.h bootstage: Add support for TPL record count blk: Allow control of the block cache in TPL spi: Avoid using malloc() in a critical function
Thierry Reding (1): fdtdec: test: Fix memory leak
Vabhav Sharma (1): drivers: serial: lpuart: Enable Little Endian Support
arch/sandbox/config.mk | 5 +- arch/sandbox/cpu/spl.c | 3 +- arch/sandbox/cpu/state.c | 1 + arch/sandbox/dts/sandbox.dts | 336 +-------------------------------------------------- arch/sandbox/dts/sandbox.dtsi | 364 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++ arch/sandbox/dts/sandbox64.dts | 275 ++---------------------------------------- arch/sandbox/dts/test.dts | 8 ++ arch/sandbox/include/asm/test.h | 13 ++ arch/x86/include/asm/coreboot_tables.h | 2 + board/sandbox/README.sandbox | 21 ++++ cmd/trace.c | 10 +- common/Kconfig | 7 ++ common/board_f.c | 6 +- doc/README.SPL | 16 +++ doc/README.TPL | 4 + doc/driver-model/README.txt | 4 + drivers/block/Kconfig | 7 ++ drivers/core/util.c | 2 + drivers/misc/swap_case.c | 102 +++++++++++++++- drivers/pci/pci-uclass.c | 70 +++++++++++ drivers/serial/serial_lpuart.c | 4 + drivers/spi/Kconfig | 2 +- drivers/spi/spi-mem.c | 15 ++- drivers/sysreset/sysreset_sandbox.c | 1 + drivers/video/video-uclass.c | 4 +- include/configs/sandbox.h | 4 + include/dm/ofnode.h | 6 +- include/dm/util.h | 6 +- include/pci.h | 35 +++++- include/trace.h | 6 +- lib/Kconfig | 15 +++ lib/fdtdec_test.c | 2 + lib/hang.c | 3 + lib/trace.c | 67 +++++++++-- test/dm/pci.c | 49 ++++++++ test/py/tests/test_ofplatdata.py | 28 +++++ tools/binman/README | 14 +++ tools/binman/README.entries | 15 +++ tools/binman/binman.py | 26 +++- tools/binman/bsection.py | 7 +- tools/binman/control.py | 15 ++- tools/binman/elf.py | 4 +- tools/binman/elf_test.py | 5 +- tools/binman/entry.py | 5 +- tools/binman/entry_test.py | 6 +- tools/binman/etype/_testing.py | 2 +- tools/binman/etype/blob.py | 2 +- tools/binman/etype/fill.py | 4 +- tools/binman/etype/fmap.py | 3 +- tools/binman/etype/gbb.py | 2 +- tools/binman/etype/text.py | 9 +- tools/binman/etype/u_boot_dtb_with_ucode.py | 4 +- tools/binman/etype/u_boot_spl_bss_pad.py | 2 +- tools/binman/etype/u_boot_ucode.py | 4 +- tools/binman/etype/vblock.py | 2 +- tools/binman/fmap_util.py | 12 +- tools/binman/ftest.py | 213 +++++++++++++++++---------------- tools/binman/state.py | 7 +- tools/dtoc/dtb_platdata.py | 10 +- tools/dtoc/dtoc.py | 8 +- tools/dtoc/fdt.py | 148 +++++++++++++---------- tools/dtoc/fdt_util.py | 15 +-- tools/dtoc/test_dtoc.py | 16 +-- tools/dtoc/test_fdt.py | 52 ++++---- tools/patman/cros_subprocess.py | 50 ++++---- tools/patman/func_test.py | 41 ++++--- tools/patman/gitutil.py | 16 +-- tools/patman/patman.py | 2 +- tools/patman/series.py | 20 ++-- tools/patman/settings.py | 34 ++---- tools/patman/test_util.py | 27 +++-- tools/patman/tools.py | 111 ++++++++++++++++- tools/proftool.c | 4 +- tools/rmboard.py | 150 +++++++++++++++++++++++ 74 files changed, 1580 insertions(+), 990 deletions(-) create mode 100644 arch/sandbox/dts/sandbox.dtsi create mode 100755 tools/rmboard.py
On Thu, Jul 11, 2019 at 11:18:43AM -0600, Simon Glass wrote:
Hi Tom,
