[U-Boot] [PATCH v3 2/2] m68k: add DM model serial driver
Boards can now use DM serial driver, or still legacy mcf uart driver version.
Signed-off-by: Angelo Dureghello angelo@sysam.it --- Changes for v2: - remove while loops in putc and getc, replacing with return -EAGAIN - remove unneeded ifdef Changes for v3: - no changes --- drivers/serial/mcfuart.c | 188 ++++++++++++++++++++++++++++++++++++----------- 1 file changed, 144 insertions(+), 44 deletions(-)
diff --git a/drivers/serial/mcfuart.c b/drivers/serial/mcfuart.c index 407354f..059cb0f 100644 --- a/drivers/serial/mcfuart.c +++ b/drivers/serial/mcfuart.c @@ -2,6 +2,9 @@ * (C) Copyright 2004-2007 Freescale Semiconductor, Inc. * TsiChung Liew, Tsi-Chung.Liew@freescale.com. * + * Modified to add device model (DM) support + * (C) Copyright 2015 Angelo Dureghello angelo@sysam.it + * * SPDX-License-Identifier: GPL-2.0+ */
@@ -11,9 +14,10 @@ */
#include <common.h> +#include <dm.h> +#include <dm/platform_data/serial_coldfire.h> #include <serial.h> #include <linux/compiler.h> - #include <asm/immap.h> #include <asm/uart.h>
@@ -21,91 +25,110 @@ DECLARE_GLOBAL_DATA_PTR;
extern void uart_port_conf(int port);
-static int mcf_serial_init(void) +static int mcf_serial_init_common(uart_t *uart, int port_idx, int baudrate) { - volatile uart_t *uart; u32 counter;
- uart = (volatile uart_t *)(CONFIG_SYS_UART_BASE); - - uart_port_conf(CONFIG_SYS_UART_PORT); + uart_port_conf(port_idx);
/* write to SICR: SIM2 = uart mode,dcd does not affect rx */ - uart->ucr = UART_UCR_RESET_RX; - uart->ucr = UART_UCR_RESET_TX; - uart->ucr = UART_UCR_RESET_ERROR; - uart->ucr = UART_UCR_RESET_MR; + writeb(UART_UCR_RESET_RX, &uart->ucr); + writeb(UART_UCR_RESET_TX, &uart->ucr); + writeb(UART_UCR_RESET_ERROR, &uart->ucr); + writeb(UART_UCR_RESET_MR, &uart->ucr); __asm__("nop");
- uart->uimr = 0; + writeb(0, &uart->uimr);
/* write to CSR: RX/TX baud rate from timers */ - uart->ucsr = (UART_UCSR_RCS_SYS_CLK | UART_UCSR_TCS_SYS_CLK); + writeb(UART_UCSR_RCS_SYS_CLK | UART_UCSR_TCS_SYS_CLK, &uart->ucsr);
- uart->umr = (UART_UMR_BC_8 | UART_UMR_PM_NONE); - uart->umr = UART_UMR_SB_STOP_BITS_1; + writeb(UART_UMR_BC_8 | UART_UMR_PM_NONE, &uart->umr); + writeb(UART_UMR_SB_STOP_BITS_1, &uart->umr);
/* Setting up BaudRate */ - counter = (u32) ((gd->bus_clk / 32) + (gd->baudrate / 2)); - counter = counter / gd->baudrate; + counter = (u32) ((gd->bus_clk / 32) + (baudrate / 2)); + counter = counter / baudrate;
/* write to CTUR: divide counter upper byte */ - uart->ubg1 = (u8) ((counter & 0xff00) >> 8); + writeb((u8)((counter & 0xff00) >> 8), &uart->ubg1); /* write to CTLR: divide counter lower byte */ - uart->ubg2 = (u8) (counter & 0x00ff); + writeb((u8)(counter & 0x00ff), &uart->ubg2);
- uart->ucr = (UART_UCR_RX_ENABLED | UART_UCR_TX_ENABLED); + writeb(UART_UCR_RX_ENABLED | UART_UCR_TX_ENABLED, &uart->ucr);
return (0); }
+static void mcf_serial_setbrg_common(uart_t *uart, int baudrate) +{ + u32 counter; + + /* Setting up BaudRate */ + counter = (u32) ((gd->bus_clk / 32) + (baudrate / 2)); + counter = counter / baudrate; + + /* write to CTUR: divide counter upper byte */ + writeb(((counter & 0xff00) >> 8), &uart->ubg1); + /* write to CTLR: divide counter lower byte */ + writeb((counter & 0x00ff), &uart->ubg2); + + writeb(UART_UCR_RESET_RX, &uart->ucr); + writeb(UART_UCR_RESET_TX, &uart->ucr); + + writeb(UART_UCR_RX_ENABLED | UART_UCR_TX_ENABLED, &uart->ucr); +} + +#ifndef CONFIG_DM_SERIAL + +static int mcf_serial_init(void) +{ + uart_t *uart_base; + int port_idx; + + uart_base = (uart_t *)CONFIG_SYS_UART_BASE; + port_idx = CONFIG_SYS_UART_PORT; + + return mcf_serial_init_common(uart_base, port_idx, gd->baudrate); +} + static void mcf_serial_putc(const char c) { - volatile uart_t *uart = (volatile uart_t *)(CONFIG_SYS_UART_BASE); + uart_t *uart = (uart_t *)CONFIG_SYS_UART_BASE;
if (c == '\n') serial_putc('\r');
/* Wait for last character to go. */ - while (!(uart->usr & UART_USR_TXRDY)) ; + while (!(readb(&uart->usr) & UART_USR_TXRDY)) + ;
- uart->utb = c; + writeb(c, &uart->utb); }
static int mcf_serial_getc(void) { - volatile uart_t *uart = (volatile uart_t *)(CONFIG_SYS_UART_BASE); + uart_t *uart = (uart_t *)CONFIG_SYS_UART_BASE;
/* Wait for a character to arrive. */ - while (!(uart->usr & UART_USR_RXRDY)) ; - return uart->urb; -} - -static int mcf_serial_tstc(void) -{ - volatile uart_t *uart = (volatile uart_t *)(CONFIG_SYS_UART_BASE); + while (!(readb(&uart->usr) & UART_USR_RXRDY)) + ;
- return (uart->usr & UART_USR_RXRDY); + return readb(&uart->urb); }
static void mcf_serial_setbrg(void) { - volatile uart_t *uart = (volatile uart_t *)(CONFIG_SYS_UART_BASE); - u32 counter; - - /* Setting up BaudRate */ - counter = (u32) ((gd->bus_clk / 32) + (gd->baudrate / 2)); - counter = counter / gd->baudrate; + uart_t *uart = (uart_t *)CONFIG_SYS_UART_BASE;
- /* write to CTUR: divide counter upper byte */ - uart->ubg1 = ((counter & 0xff00) >> 8); - /* write to CTLR: divide counter lower byte */ - uart->ubg2 = (counter & 0x00ff); + mcf_serial_setbrg_common(uart, gd->baudrate); +}
- uart->ucr = UART_UCR_RESET_RX; - uart->ucr = UART_UCR_RESET_TX; +static int mcf_serial_tstc(void) +{ + uart_t *uart = (uart_t *)CONFIG_SYS_UART_BASE;
- uart->ucr = UART_UCR_RX_ENABLED | UART_UCR_TX_ENABLED; + return readb(&uart->usr) & UART_USR_RXRDY; }
static struct serial_device mcf_serial_drv = { @@ -128,3 +151,80 @@ __weak struct serial_device *default_serial_console(void) { return &mcf_serial_drv; } + +#endif + +#ifdef CONFIG_DM_SERIAL + +static int coldfire_serial_probe(struct udevice *dev) +{ + struct coldfire_serial_platdata *plat = dev->platdata; + + return mcf_serial_init_common((uart_t *)plat->base, + plat->port, plat->baudrate); +} + +static int coldfire_serial_putc(struct udevice *dev, const char ch) +{ + struct coldfire_serial_platdata *plat = dev->platdata; + uart_t *uart = (uart_t *)plat->base; + + /* Wait for last character to go. */ + if (!(readb(&uart->usr) & UART_USR_TXRDY)) + return -EAGAIN; + + writeb(ch, &uart->utb); + + return 0; +} + +static int coldfire_serial_getc(struct udevice *dev) +{ + struct coldfire_serial_platdata *plat = dev->platdata; + uart_t *uart = (uart_t *)(plat->base); + + /* Wait for a character to arrive. */ + if (!(readb(&uart->usr) & UART_USR_RXRDY)) + return -EAGAIN; + + return readb(&uart->urb); +} + +int coldfire_serial_setbrg(struct udevice *dev, int baudrate) +{ + struct coldfire_serial_platdata *plat = dev->platdata; + uart_t *uart = (uart_t *)(plat->base); + + mcf_serial_setbrg_common(uart, baudrate); + + return 0; +} + +static int coldfire_serial_pending(struct udevice *dev, bool input) +{ + struct coldfire_serial_platdata *plat = dev->platdata; + uart_t *uart = (uart_t *)(plat->base); + + if (input) + return readb(&uart->usr) & UART_USR_RXRDY ? 1 : 0; + else + return readb(&uart->usr) & UART_USR_TXRDY ? 0 : 1; + + return 0; +} + +static const struct dm_serial_ops coldfire_serial_ops = { + .putc = coldfire_serial_putc, + .pending = coldfire_serial_pending, + .getc = coldfire_serial_getc, + .setbrg = coldfire_serial_setbrg, +}; + +U_BOOT_DRIVER(serial_coldfire) = { + .name = "serial_coldfire", + .id = UCLASS_SERIAL, + .probe = coldfire_serial_probe, + .ops = &coldfire_serial_ops, + .flags = DM_FLAG_PRE_RELOC, +}; +#endif
Hi Angelo,
Changes for v2:
Changes for v3:
- no changes
Missing file?
02: dm: gpio: pca953x: introduce driver model support for pca953x 03: m68k: add malloc memory for early malloc 04: m68k: add DM model serial driver m68k: + M5329AFEE M5249EVB M5208EVBE M5475FFE M54451EVB astro_mcf5373l M54418TWR_serial_rmii M54455EVB_intel amcore M5282EVB M54455EVB_i66 M54455EVB_a66 M5475GFE M5485GFE M5253DEMO M54455EVB_stm33 M5475AFE M54455EVB M5485BFE M5329BFEE M52277EVB M5475EFE M54418TWR_nand_mii M5475CFE cobra5272 M5485AFE M5485HFE M54418TWR_nand_rmii_lowfreq M5485DFE M5475DFE M5275EVB M54418TWR M52277EVB_stmicro eb_cpu5282 eb_cpu5282_internal M53017EVB M5485CFE M5475BFE M5485EFE M5253EVBE M5485FFE M5235EVB_Flash32 M5373EVB M54418TWR_nand_rmii M54418TWR_serial_mii M5235EVB M54451EVB_stmicro M5272C3 +../drivers/serial/mcfuart.c:18:46: fatal error: dm/platform_data/serial_coldfire.h: No such file or directory + #include <dm/platform_data/serial_coldfire.h> + ^ +compilation terminated. +make[2]: *** [drivers/serial/mcfuart.o] Error 1 +make[1]: *** [drivers/serial] Error 2
Hi Simon,
i realized this patch (v3) is invalid, due to my tests done with "CONFIG_DM_SRIAL" (missing 'A'), so was using the legacy driver still.
Also, i found a small issue in start.S files.
I send v4 asap later.
thanks,
regards, Angelo Dureghello
On 25/04/2016 23:54, Simon Glass wrote:
Hi Angelo,
Missing file?
- #include <dm/platform_data/serial_coldfire.h>
Hi Angelo,
On 26 April 2016 at 03:03, Angelo Dureghello angelo@sysam.it wrote:
Hi Simon,
OK, thank you. I'll look out for it.
thanks,
Hi Angelo,
Missing file?
Hi Simon,
sent v4.
Tested
- legacy serial driver and DM serial driver in mcf5307 "amcore" board - buildman, pass all boards - checkpatch
Regards, angelo
On 26/04/2016 17:26, Simon Glass wrote:
Hi Angelo,
Hi Simon,
thanks,
Hi Angelo,
Missing file?
Angelo Dureghello
