[U-Boot] [PATCH2/2] Sheevaplug: Add Kirkwood gpio support to Sheevaplug
patch 2 of 2 which adds Kirkwood GPIO support to Sheevaplug. Any comments are welcome!
Dieter
From 528b24be54256cee20f965bc772390034eaeb232 Mon Sep 17 00:00:00 2001 From: Dieter Kiermaier dk-arm-linux@gmx.de Date: Mon, 29 Jun 2009 14:29:15 +0200 Subject: [PATCH] Sheevaplug: Add Kirkwood gpio support to Sheevaplug
Signed-off-by: Dieter Kiermaier dk-arm-linux@gmx.de --- board/Marvell/sheevaplug/sheevaplug.c | 1 + include/configs/sheevaplug.h | 1 + 2 files changed, 2 insertions(+), 0 deletions(-)
diff --git a/board/Marvell/sheevaplug/sheevaplug.c b/board/Marvell/sheevaplug/sheevaplug.c index 547126a..fa28fea 100644 --- a/board/Marvell/sheevaplug/sheevaplug.c +++ b/board/Marvell/sheevaplug/sheevaplug.c @@ -26,6 +26,7 @@ #include <miiphy.h> #include <asm/arch/kirkwood.h> #include <asm/arch/mpp.h> +#include <asm/arch/gpio.h> #include "sheevaplug.h"
DECLARE_GLOBAL_DATA_PTR; diff --git a/include/configs/sheevaplug.h b/include/configs/sheevaplug.h index e62353c..7455c29 100644 --- a/include/configs/sheevaplug.h +++ b/include/configs/sheevaplug.h @@ -43,6 +43,7 @@ #define CONFIG_MD5 /* get_random_hex on krikwood needs MD5 support */ #define CONFIG_SKIP_LOWLEVEL_INIT /* disable board lowlevel_init */ #define CONFIG_KIRKWOOD_EGIGA_INIT /* Enable GbePort0/1 for kernel */ +#define CONFIG_KIRKWOOD_GPIO /* Enable GPIO Support */ #define CONFIG_KIRKWOOD_USBPHY_INIT /* Enable USB PHY init for kernel */ #define CONFIG_KIRKWOOD_RGMII_PAD_1V8 /* Set RGMII Pad voltage to 1.8V */
Dieter
why do you need it??
Best Regards, J.
Jean,
Dieter
I fear it is of no need - it seems it is left from some earlier testing :( Should i repost the patch?
Thanks, Dieter
Best Regards, J.
Hi Jean, hi Prafulla,
here the corrected version.
Many thanks, Dieter
Dieter
Best Regards, J.
From b365a66d5134a11d697e5bf0d9d30c116b7d0f0e Mon Sep 17 00:00:00 2001 From: Dieter Kiermaier dk-arm-linux@gmx.de Date: Mon, 29 Jun 2009 14:29:15 +0200 Subject: [PATCH] Sheevaplug: Add Kirkwood gpio support to Sheevaplug
Signed-off-by: Dieter Kiermaier dk-arm-linux@gmx.de --- board/Marvell/sheevaplug/sheevaplug.c | 1 + 1 files changed, 1 insertions(+), 0 deletions(-)
-----Original Message----- From: Dieter Kiermaier [mailto:dk-arm-linux@gmx.de] Sent: Thursday, July 09, 2009 12:25 PM To: Jean-Christophe PLAGNIOL-VILLARD Cc: u-boot@lists.denx.de; Prafulla Wadaskar Subject: Re: [U-Boot] [PATCH2/2] Sheevaplug: Add Kirkwood gpio support to Sheevaplug
Many thanks, Dieter
Hi Dieter Thanks for your efforts That's good, gpio driver is supported for Kirkwood but, Again question remains the same- Why do you need gpio support on Sheevaplug? Whereas you have no evidence to use it.
Regards.. Prafulla . .
Dieter Kiermaier
Prafulla Wadaskar
