[[PATCH] colibri-imx6ull: move CONFIG_BOOTCOMMAND from header to defconfig
Move CONFIG_BOOTCOMMAND definition from colibri-imx6ull.h to colibri-imx6ull_defconfig, to be more flexible, for instance, it could be overridden by merge_config.sh script.
Signed-off-by: Ming Liu liu.ming50@gmail.com --- configs/colibri-imx6ull_defconfig | 3 ++- include/configs/colibri-imx6ull.h | 3 --- 2 files changed, 2 insertions(+), 4 deletions(-)
diff --git a/configs/colibri-imx6ull_defconfig b/configs/colibri-imx6ull_defconfig index 739eea7c07..17e3aa65f9 100644 --- a/configs/colibri-imx6ull_defconfig +++ b/configs/colibri-imx6ull_defconfig @@ -14,7 +14,8 @@ CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/toradex/colibri-imx6ull/imximage.cfg,IMX_NAND" CONFIG_BOOTDELAY=1 -# CONFIG_USE_BOOTCOMMAND is not set +CONFIG_USE_BOOTCOMMAND=y +CONFIG_BOOTCOMMAND="run ubiboot; echo; echo ubiboot failed; run distro_bootcmd;" CONFIG_USE_PREBOOT=y CONFIG_PREBOOT="setenv fdtfile imx6ull-colibri${variant}-${fdt_board}.dtb" # CONFIG_CONSOLE_MUX is not set diff --git a/include/configs/colibri-imx6ull.h b/include/configs/colibri-imx6ull.h index 2fa3485173..304f88d8d7 100644 --- a/include/configs/colibri-imx6ull.h +++ b/include/configs/colibri-imx6ull.h @@ -66,9 +66,6 @@ "ubi read ${fdt_addr_r} dtb && " \ "run fdt_fixup && bootz ${kernel_addr_r} - ${fdt_addr_r}\0" \
-/* Run Distro Boot script if ubiboot fails */ -#define CONFIG_BOOTCOMMAND "run ubiboot || run distro_bootcmd;" - #define BOOT_TARGET_DEVICES(func) \ func(MMC, mmc, 0) \ func(USB, usb, 0) \
On Wed, 2021-09-01 at 16:33 +0200, liu.ming50@gmail.com wrote:
Please note that we do have a patch set introducing Colibri iMX6ULL 1GB (eMMC) support [1] in-flight and you likely would need to re-base on top of that one. Thanks!
[1] https://marc.info/?l=u-boot&m=162911970822560
diff --git a/configs/colibri-imx6ull_defconfig b/configs/colibri-imx6ull_defconfig index 739eea7c07..17e3aa65f9 100644 --- a/configs/colibri-imx6ull_defconfig +++ b/configs/colibri-imx6ull_defconfig @@ -14,7 +14,8 @@ CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/toradex/colibri-imx6ull/imximage.cfg,IMX_NAND" CONFIG_BOOTDELAY=1 -# CONFIG_USE_BOOTCOMMAND is not set +CONFIG_USE_BOOTCOMMAND=y +CONFIG_BOOTCOMMAND="run ubiboot; echo; echo ubiboot failed; run distro_bootcmd;" CONFIG_USE_PREBOOT=y CONFIG_PREBOOT="setenv fdtfile imx6ull-colibri${variant}-${fdt_board}.dtb" # CONFIG_CONSOLE_MUX is not set diff --git a/include/configs/colibri-imx6ull.h b/include/configs/colibri-imx6ull.h index 2fa3485173..304f88d8d7 100644 --- a/include/configs/colibri-imx6ull.h +++ b/include/configs/colibri-imx6ull.h @@ -66,9 +66,6 @@ "ubi read ${fdt_addr_r} dtb && " \ "run fdt_fixup && bootz ${kernel_addr_r} - ${fdt_addr_r}\0" \ -/* Run Distro Boot script if ubiboot fails */ -#define CONFIG_BOOTCOMMAND "run ubiboot || run distro_bootcmd;"
Marcel Ziswiler
