Re: [U-Boot-Users] [PATCH] lwmon5 dspic POST spezification
Hello Wolfgang,
I've found this merge-merge-error.
best regards Sascha Laue
From: Sascha Laue sascha.laue@liebherr.com Date: Wed, 30 Apr 2008 12:27:21 +0200 Subject: [PATCH] fix manual merge error in lwmon5 posttest.
Signed-off-by: Sascha Laue sascha.laue@liebherr.com --- post/board/lwmon5/sysmon.c | 4 ++-- 1 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/post/board/lwmon5/sysmon.c b/post/board/lwmon5/sysmon.c index 793f670..23cb709 100644 --- a/post/board/lwmon5/sysmon.c +++ b/post/board/lwmon5/sysmon.c @@ -132,7 +132,7 @@ static sysmon_table_t sysmon_table[] =
{ "+ 5 V", "V", &sysmon_dspic, NULL, NULL, - 100, 1000, 0, 0xFFFF, 0xFFFF, + 100, 1000, -0x8000, 0x7FFF, 0xFFFF, VOLTAGE_5V_MIN, VOLTAGE_5V_MAX, 0, VOLTAGE_5V_MIN, VOLTAGE_5V_MAX, 0, REG_VOLTAGE_5V, @@ -140,7 +140,7 @@ static sysmon_table_t sysmon_table[] =
{ "+ 5 V standby", "V", &sysmon_dspic, NULL, NULL, - 100, 1000, 0, 0xFFFF, 0xFFFF, + 100, 1000, -0x8000, 0x7FFF, 0xFFFF, VOLTAGE_5V_STANDBY_MIN, VOLTAGE_5V_STANDBY_MAX, 0, VOLTAGE_5V_STANDBY_MIN, VOLTAGE_5V_STANDBY_MAX, 0, REG_VOLTAGE_5V_STANDBY, -- 1.5.2.4
-------- Original-Nachricht --------
Datum: Mon, 28 Apr 2008 22:41:39 +0200 Von: Wolfgang Denk wd@denx.de An: "Sascha Laue" Sascha.Laue@gmx.biz CC: marcel.brasch@liebherr.com, u-boot-users@lists.sourceforge.net, mk@denx.de Betreff: Re: [U-Boot-Users] [PATCH] lwmon5 dspic POST spezification
In message 20080401075646.145810@gmx.net you wrote:
sorry but it's the first time for me. let's try again.
we modified the specification for the lwmon5 board dspic POST. Additionally I have add defines for the temperature- and voltagevalues.
post/board/lwmon5/sysmon.c | 39
1 files changed, 30 insertions(+), 9 deletions(-)
Applied, thanks.
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de Committee, n.: A group of men who individually can do nothing but as a group decide that nothing can be done. - Fred Allen
In message 20080430131635.311880@gmx.net you wrote:
Hello Wolfgang,
Applied, manually - your patch is white-space corrupted and does not apply:
Applying lwmon5: fix manual merge error in POST error: patch failed: post/board/lwmon5/sysmon.c:132 error: post/board/lwmon5/sysmon.c: patch does not apply Using index info to reconstruct a base tree... error: patch failed: post/board/lwmon5/sysmon.c:132 error: post/board/lwmon5/sysmon.c: patch does not apply Did you hand edit your patch? It does not apply to blobs recorded in its index. Cannot fall back to three-way merge. Patch failed at 0001.
Sascha Laue
